04-Interface
HomeSupportWirelessWX3800X Series Access ControllersDiagnose & MaintainAlarms ReferencesH3C Wireless Products Alarm Reference(R14xx R12xx)-6W10004-Interface
03-IF-MIB
03-IF-MIB 54.58 KB
IF-MIB
About this MIB
This MIB describes generic attributes for network interfaces.
MIB file name
rfc2863-if.mib
Notifications
linkDown
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.6.3.1.1.5.3
Link down.
Error
Major
1.3.6.1.6.3.1.1.5.4 (linkUp)
ON
Notification triggers
This notification is generated when the SNMPv2 entity, acting in an agent role, has detected that the ifOperStatus object for one of its communication links is about to enter the down state from some other state (but not from the notPresent state. Other states refer to the values of the ifOperStatus variable.
Possible reasons are:
The physical link of the interface is down, and the link is disconnected.
The interface goes down at the data link layer.
The interface is shut down.
This notification is generated if an interface is deleted.
System impact
The interface cannot normally forward packets, and the services carried over the interface are interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable standard linkdown command.
OFF
CLI: Use the undo snmp-agent trap enable standard linkdown command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of an interface.
ifIndex
InterfaceIndex
Integer32 (1..2147483647)
1.3.6.1.2.1.2.2.1.7 (ifAdminStatus)
Administrative status of the interface.
ifIndex
INTEGER
up(1), down(2), testing(3)
1.3.6.1.2.1.2.2.1.8 (ifOperStatus)
Operational status of the interface.
ifIndex
INTEGER
up(1), down(2), testing(3), unknown(4), dormant(5), notPresent(6), lowerLayerDown(7)
Recommended action
To resolve the issue:
1.If this interface is deleted, no action is required.
2.Execute the display this command in interface view to identify whether the interfaces on both end are shut down. If the interfaces are shut down, execute the undo shutdown command in interface view to bring them up. Identify whether the interfaces have restored.
3.Execute the display interface [ interface-type [ interface-number ] ] command to view the interface state. If an interface is down at the data link layer, check the protocol down reason according to the data link layer protocol.
4.Identify whether the physical connection is normal (for example, whether the network cables or transceiver modules are firmly connected). If the physical connection is abnormal, correctly connect the interfaces. Identify whether the alarm is cleared.
5.If the issue persists, contact H3C Support.
linkUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.6.3.1.1.5.4
Link up.
Recovery
Major
N/A (N/A)
ON
This notification is generated when that the SNMPv2 entity, acting in an  agent role, has detected that the ifOperStatus object for one of its communication links left the down state and transitioned into some other state (but not into the notPresent state).  Other states refer to the values of the ifOperStatus variable.
The undo shutdown command is executed on the interface.
The interface or link failure is resolved.
The physical state of the interface comes up.
The interface comes up at the data link layer.
The newly created interface can operate normally.
System impact
The interface can normally forward packets.
Status control
ON
CLI: Use the snmp-agent trap enable standard linkup command.
OFF
CLI: Use the undo snmp-agent trap enable standard linkup command.
Object
OID (object name)
Index
Value range
ifIndex
InterfaceIndex
ifIndex
INTEGER
ifIndex
INTEGER
Recommended action
No action is required.
