| 02-HH3C-STORM-CONSTRAIN-MIB | 54.91 KB |
About this MIB
Use this MIB to obtain the interface status, configure traffic constrain, and define corresponding alarm thresholds.
MIB file name
hh3c-storm-constrain.mib
Notifications
hh3cStormRising
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.66.3.1 |
Traffic of a type on an interface exceeded the upper limit. |
Error |
Warning |
1.3.6.1.4.1.25506.2.66.3.2 (hh3cStormFalling) |
ON |
Notification triggers
This notification is generated when traffic control is enabled and traffic of any type on an interface exceeds the upper limit of this traffic type.
System impact
Traffic of this type might be dropped.
Status control
ON
CLI: Use the storm-constrain enable trap command.
OFF
CLI: Use the undo storm-constrain enable trap command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Index of an interface. |
ifIndex |
InterfaceIndex |
Integer32 (1..2147483647) |
1.3.6.1.4.1.25506.2.66.1.1 (hh3cStormTrapType) |
Type of the notification. |
ifIndex |
INTEGER |
broadcast(1), multicast(2), unicast(3) |
1.3.6.1.4.1.25506.2.66.1.2 (hh3cStormTrapThreshold) |
Alarm threshold. |
ifIndex |
Integer32 |
Same as the standard MIB. |
1.3.6.1.4.1.25506.2.66.2.1.1.1 (hh3cStormCtrlPortStatus) |
Status of the interface. |
ifIndex |
INTEGER |
controlled(1), normal(2) |
Recommended action
To resolve the issue:
1.Verify traffic of this type on the interface does not exceed the upper limit of this traffic type. If the threshold is too low, adjust it as needed.
2.If the issue persists, contact H3C Support.
hh3cStormFalling
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.66.3.2 |
Traffic of a type on an interface dropped below the lower limit. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when traffic control is enabled and traffic of any type on an interface dropped below the upper limit of this traffic type.
System impact
The services are not impacted.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
ifIndex |
InterfaceIndex |
ifIndex |
INTEGER |
Alarm threshold. |
ifIndex |
Integer32 |
ifIndex |
INTEGER |
Recommended action
No action is required.
