- 13-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-PTP commands
- 06-Network synchronization commands
- 07-PoE commands
- 08-SNMP commands
- 09-RMON commands
- 10-NETCONF commands
- 11-EAA commands
- 12-Process monitoring and maintenance commands
- 13-Sampler commands
- 14-Mirroring commands
- 15-NetStream commands
- 16-IPv6 NetStream commands
- 17-sFlow commands
- 18-Information center commands
- 19-GOLD commands
- 20-Packet capture commands
- 21-VCF fabric commands
- 22-CWMP commands
- 23-SmartMC commands
- 24-SQA commands
- 25-eMDI commands
- 26-Performance management commands
- 27-EPS agent commands
- 28-Cloud connection commands
- 29-EPA commands
- 30-KPI data collection commands
29-EPA commands | 76.48 KB |
EPA commands
display epa monitor-information
Use display epa monitor-information to display endpoint association and disassociation information detected by EPA.
display epa monitor-information [ online | offline ] [ device device-id | mac mac-address [ vlan vlan-id ] ] [ verbose ]
online: Displays endpoint association information.
offline: Displays endpoint disassociation information.
device device-id: Specifies a device by its bridge MAC address in the H-H-H format. In a SmartMC network, you can specify the bridge MAC address of a member to display only information about endpoints connecting to the member.
mac mac-address: Specifies an endpoint by its MAC address in the H-H-H format.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify this option, the command displays information in all VLANs.
verbose: Displays detailed information about identified endpoints. If you do not specify this keyword, the command displays brief information.
In a SmartMC network, you can execute this command on the commander or on a member.
· If you execute this command on the commander, you can view information on all devices in the network or information on a specific device.
· If you execute this command on a member, you can view only association events of endpoints connecting to the member.
In a non-SmartMC network, this command displays information only on the device on which the command is executed. For more information about SmartMC, see Network Management and Monitoring Configuration Guide.
If an endpoint has multiple IP addresses, only one IP address is displayed.
# In a SmartMC network, display endpoint association and disassociation information on the member device with ID 3cf5-cc97-772f.
<Sysname> display epa monitor-information device 3cf5-cc97-772f
Auto identification : Disabled
Local device type : SmartMC TM
Local device ID : ae05-0607-eaaa
Endpoint information:
Access device ID MAC address VLAN Interface Status
3cf5-cc97-772f 0e74-e2fb-0400 11 Ten-GigabitEthernet1/0/1 Online
3cf5-cc97-772f 5caf-2e5f-0100 11 Ten-GigabitEthernet1/0/1 Offline
# In a non-SmartMC network, display endpoint association and disassociation information on the current device.
Local device type : Self-managed
Local device ID : d461-fe34-15c0
d461-fe34-15c0 0026-ba12-3456 1 Ten-GigabitEthernet1/0/1 Online
d461-fe34-15c0 2064-3211-1111 1 Ten-GigabitEthernet1/0/1 Online
# (Devices not supporting automatic endpoint identification) In a SmartMC network, display detailed endpoint information on the commander.
<Sysname> display epa monitor-information verbose
Auto identification: Disabled
Total endpoints identified by EPA: 1
Access device ID: ac74-0935-9dbe
MAC address : 1cab-3464-ad82 VLAN : 100
IP address : 1.1.1.1
Interface : Ten-GigabitEthernet1/0/1 Status: Online
Category : Camera Vendor: -
OS : -
# (Devices not supporting automatic endpoint identification) In a non-SmartMC network, display detailed endpoint information on the current device.
Access device ID: d461-fe34-15c0
MAC address : 0026-ba12-3456 VLAN : 1
OS : -
# (Devices supporting automatic endpoint identification) In a SmartMC network, display detailed endpoint information on the TM.
Auto identification: Enabled
Total endpoints identified by EPA: 2
Interface : GigabitEthernet1/0/1 Status: Online
OS : -
MAC address: 0000-0000-0002 VLAN : 1
IP address : 1.1.1.2
Interface : GigabitEthernet1/0/1 Status: Offline
Category : Phone Vendor: Samsung
OS : Android
# (Devices supporting automatic endpoint identification) In a non-SmartMC network, display detailed endpoint information on the current device.
Auto identification : Enabled
OS : -
MAC address : 2064-3211-1111 VLAN : 1
Category : Smartphone Vendor: Samsung
OS : Android
Auto identification |
This field is not supported in the current software version. State of automatic endpoint identification. |
Local device type |
Local device type. Options include: · Self-managed—Indicates a device in a non-SmartMC network. · SmartMC TM—Indicates the commander in a SmartMC network. · SmartMC TC—Indicates a member in a SmartMC network. |
Local device ID |
Local device ID (bridge MAC address). |
Access device ID |
ID (bridge MAC address) of the connected device. |
MAC address |
MAC address of the endpoint. |
VLAN |
VLAN in which the endpoint resides. |
Interface to which the endpoint is connected. |
Status |
Endpoint status. Options include: · Online. · Offline. |
Category |
Endpoint category. This field is fixed at Camera for static endpoint identification. |
Vendor |
This field is not supported in the current software version. Vendor of the endpoint. This field displays a hyphen (-) if the vendor fails to be obtained. |
OS |
This field is not supported in the current software version. OS of the endpoint. This field displays a hyphen (-) if the OS fails to be obtained. |
epa monitor-rule
epa auto-identify enable
Use epa auto-identify enable to enable automatic endpoint identification.
Use undo epa auto-identify enable to disable automatic endpoint identification.
Automatic endpoint identification is disabled.
This feature enables EPA to work with BYOD. When a device connects to the corporate network through BYOD, EPA automatically checks the rule database for BYOD endpoint type identification, and identifies the endpoint MAC address, type, and manufacturer information.
For the automatic endpoint identification feature to take effect, you must first complete the BYOD configuration.
For an online endpoint, if you change the fingerprint information for the endpoint in the rule database for BYOD endpoint type identification, the changes take effect the next time the endpoint is identified by EPA.
# Enable automatic endpoint identification.
[Sysname] epa auto-identify enable
display byod rule (Security Command Reference)
epa monitor-rule
Use epa monitor-rule to create a static endpoint identification rule.
Use undo epa monitor-rule to remove a static endpoint identification rule.
epa monitor-rule [ monitor-rule-id ] mac mac-address [ mask mac-mask ] [ vlan vlan-id ]
undo epa monitor-rule { monitor-rule-id | mac mac-address [ mask mac-mask ] [ vlan vlan-id ] }
No static endpoint identification rules exist.
monitor-rule-id: Specifies the rule ID in the range of 1 to 1024. If you do not specify this argument, the command assigns the smallest available ID to the rule.
mac mac-address: Specifies the MAC address of the endpoint to monitor, in the H-H-H format.
mask mac-mask: Specifies a MAC address mask, in the H-H-H format.
vlan vlan-id: Specifies the VLAN in which the endpoint will be monitored. The vlan-id argument represents the VLAN ID in the range of 1 to 4094. If you do not specify this option, the command creates a rule that monitors the endpoint in all VLANs.
In a SmartMC network, you can execute this command only on the commander. The commander will deploy the rule to all members to monitor associations and disassociations of the specified endpoint in the entire network.
In a non-SmartMC network, this command enables the device to monitor associations and disassociations of the specified endpoint only on the device itself.
# Create a static endpoint identification rule to monitor endpoints whose MAC address starts with 0e74 in all VLANs.
[Sysname] epa monitor-rule mac 0e74-e2fb-0400 mask ffff-0000-0000
epa online-offline-log disable
Use epa online-offline-log disable to disable EPA logging.
Use undo epa online-offline-log disable to enable EPA logging.
EPA logging is enabled.
By default, the EPA module logs endpoint associations and disassociations. If a monitored endpoint comes online or goes offline frequently, the device will generate a large number of log entries. In this case, to avoid affecting device performance, disable EPA logging as a best practice.
# Disable EPA logging.
[Sysname] epa online-offline-log disable
epa monitor-rule
