13-Network Management and Monitoring Command Reference
HomeSupportSwitchesS7500X SeriesReference GuidesCommand ReferencesH3C S7500X Switch Series Command References-Release7639Pxx-6W10013-Network Management and Monitoring Command Reference
16-IPv6 NetStream commands
16-IPv6 NetStream commands 177.64 KB
display ipv6 netstream cache
Use display ipv6 netstream cache to display IPv6 NetStream entry information.
In standalone mode:
display ipv6 netstream cache [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ipv6 | interface interface-type interface-number | source source-ipv6 ] * [ slot slot-number ]
In IRF mode:
display ipv6 netstream cache [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ipv6 | interface interface-type interface-number | source source-ipv6 ] * [ chassis chassis-number slot slot-number ]
verbose: Displays detailed information about IPv6 NetStream entries. If you do not specify this keyword, this command displays brief information about IPv6 NetStream entries.
type: Specifies the IPv6 NetStream entry type. If you do not specify this keyword, this command displays information about all types of IPv6 NetStream entries.
ip: Specifies IP flow NetStream entries.
ipl2: Specifies Layer 2 and Layer 3 flow NetStream entries.
l2: Specifies Layer 2 flow NetStream entries.
mpls: Specifies MPLS flow NetStream entries.
label-position1 label-value1: Specifies a label by its position and value. The value range for the label-position1 argument is 1 to 6, representing labels from the innermost to the outermost. The value range for the label-value1 argument is 0 to 1048575.
label-position2 label-value2: Specifies a label by its position and value. The value range for the label-position2 argument is 1 to 6, representing labels from the innermost to the outermost. The value range for the label-value2 argument is 0 to 1048575.
label-position3 label-value3: Specifies a label by its position and value. The value range for the label-position3 argument is 1 to 6, representing labels from the innermost to the outermost. The value range for the label-value3 argument is 0 to 1048575.
destination destination-ipv6: Specifies a destination IPv6 address. If you specify this option, this command does not display Layer 2 flow NetStream entries.
source source-ipv6: Specifies a source IPv6 address. If you specify this option, this command does not display Layer 2 flow NetStream entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about IPv6 NetStream entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about IPv6 NetStream entries for all cards. (In IRF mode.)
Statistics about packets containing IP headers are classified as ipl2 (Layer 2 and Layer 3). Statistics about packets without IP headers are classified as l2 (Layer 2).
# Display detailed information about IPv6 NetStream entries.
<Sysname> display ipv6 netstream cache verbose
IPv6 NetStream cache information:
  Active flow timeout             : 5 min
  Inactive flow timeout           : 10 sec
  Max number of entries           : 1000
  IPv6 active flow entries        : 1
  MPLS active flow entries        : 0
  IPL2 active flow entries        : 1
  IPv6 flow entries counted       : 10
  MPLS flow entries counted       : 0
  IPL2 flow entries counted       : 20
  Last statistics resetting time  : 01/01/2019 at 00:01:02
IPv6 packet size distribution (1103746 packets in total):
1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
.249 .694 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .027 .000 .027 .000 .000 .000 .000 .000 .000 .000
Protocol          Total Packets    Flows  Packets Active(sec) Idle(sec)
                  Flows /sec       /sec   /flow   /flow       /flow
TCP-Telnet      2656855     372        4       86        49        27
TCP-FTP         5900082      86        9        9        11        33
TCP-FTPD        3200453    1006        5      193        45        33
TCP-WWW       546778274   11170      887       12         8        32
TCP-other      49148540    3752       79       47        30        32
UDP-DNS       117240379     570      190        3         7        34
UDP-other      45502422    2272       73       30         8        37
ICMP           14837957     125       24        5        12        34
IP-other          77406       5        0       47        52        27
Type DstIP(Port)         SrcIP(Port)      Pro TC  FlowLbl If(Direct)   Pkts
     DstMAC(VLAN)        SrcMAC(VLAN)
     TopLblType(IP/MASK) Lbl-Exp-S-List
IP   2001::1(1024)      2002::1(21)        6   0   0x6000  XGE1/0/1(I) 42996
     TcpFlag:    0x1b
     DstMask:      24   SrcMask:      24
     DstAS:         0   SrcAS:         0
     NextHop:           2001::2
     BGPNextHop:        0:0:0:0:0:0:0:0
     InVRF:      mvpn   NextHeader:   58
     SamplerMode:   0  SamplerInt:    0
     Active:      120   Bytes/Pkt:   152
MPLS LDP(3.3.3.3/24)    1:18-6-0                           XGE1/0/2(O) 291
                        2:24-6-0
                        3:30-6-1
     Active:      660   Bytes/Pkt:   100
IP&  2003::1(2048)      2008::1(0)         1   0   0x0     XGE1/0/2(O) 10
IP&  2010::1(1024)      2020::1(67)        17  0   0x12345 XGE1/0/3(I) 1848
MPLS LDP(4.4.4.4/24)    1:55-6-0
                        2:16-6-1
                        2:0-0-0
     TcpFlag:       0
     DstAS:         0   SrcAS:         0
     NextHop:           2020::2
     InVRF:      vpn1   NextHeader:   58
     Active:      382   Bytes/Pkt:  1426
Active flow timeout
Aging timer for active flows, in minutes.
Aging timer for inactive flows, in seconds.
Maximum number of IPv6 flows allowed in the cache.
Number of active IPv6 flows in the cache.
Number of active IPv6 MPLS flows in the cache.
Number of active Layer 2 flows with IPv6 protocol information.
Number of IPv6 flows that have been counted.
Number of MPLS flows that have been counted.
Number of Layer 2 flows (with IPv6 protocol information) that have been counted.
Last time the reset ipv6 netstream statistics command was executed. This field displays Never if you have never executed this command.
Distribution of IPv6 packets by packet size, and the bracketed number is the total number of IPv6 packets.
The value is displayed in the proportion of the number of IPv6 packets of the specified sizes to the total number of IPv6 packets. The value is displayed with three decimal places.
320  352  384  416  448  480 512  544  576
Range of IPv6 packet length (excluding data link layer header).
·     For the values in the range of 1 to 576 bytes, the range increases in the step of 32 bytes. For example, 1-32 shows the number of packets with the size of 1 to 32 bytes. 64 shows the number of packets with the size of 33 to 64 bytes.
·     For the values greater than 1024 bytes, the range increases in the step of 512 bytes. For example, 1536 shows the number of packets with the size of 1025 to 1536 bytes.
·     Packets with the size of 577 to 1024 bytes are recorded in the 1024 entry.
Protocol     Total Flows     Packets/Sec
Flow/Sec   Packets/flow
Active(sec)/ flow   Idle(sec)/flow
Statistics of packets by protocol type:
·     Protocol type.
·     Total number of flows.
·     Number of packets per second.
·     Number of flows per second.
·     Number of packets per flow.
·     Active time (in seconds) of each flow.
·     Inactive time (in seconds) of each flow.
Statistics of the active flows in the current cache:
·     Flow type. Flows are classified into the following types:
¡     IP flows.
¡     Layer 2 flows with IPv6 protocol information (IPL2).
¡     MPLS flows without IP options (MPLS). This field is not supported in the current software version.
¡     MPLS flows with IP options (IP&MPLS). This field is not supported in the current software version.
·     Destination IPv6 address (destination port).
·     Source IPv6 address (source port).
·     Protocol number.
·     Traffic classification.
·     Flow label.
·     Interface name (direction).
·     Number of packets.
ICMPv6 packets do not contain port number fields, so the type and code fields are captured. The value for the destination port represents these two fields:
·     The highest 8 bits represent the type field.
·     The lowest 8 bits represent the code field.
The value for the source port is set to 0 and does not indicate any statistics.
Layer 2 information for the active flows in the current cache:
·     Destination MAC address, followed by the destination VLAN ID in parenthesis.
·     Source MAC address, followed by the source VLAN ID in parenthesis.
Information about the active MPLS flows in the current cache:
·     Type of the labels at the top of the label stack:
¡     IP address associated with the label.
¡     Mask associated with the label.
·     Label list:
¡     Lbl—20-bit label value.
¡     Exp—3-bit field for implementing QoS.
¡     S—1-bit bottom of stack flag. The S field is set to 1 if the label is the bottom label and set to 0 if not.
TcpFlag:
DstMask:   SrcMask:
DstAS:       SrcAS:
NextHop:
BGPNextHop:
OutVRF:     InVRF:            NextHeader
SamplerMode:                  SamplerInt:
Active:       Bytes/Pkt:
Other information about the active flows in the cache:
·     TCP flag.
·     Destination mask.
·     Source mask.
·     Destination AS.
·     Source AS.
·     Routing next hop.
·     BGP next hop.
·     VPN to which the outbound packets belong.
·     Type of the next header in the IPv6 packet headers.
·     VPN to which the inbound packets belong.
·     Sampling mode. This field is not supported in the current software version.
·     Sampling interval. This field is not supported in the current software version.
·     Flow's active time.
·     Number of bytes per packet.
display ipv6 netstream export
Use display ipv6 netstream export to display information about the IPv6 NetStream data export.
IP NetStream export information varies by aggregation mode. This command displays IPv6 NetStream export information for all the configured aggregation modes.
# Display information about the IPv6 NetStream data export.
<Sysname> display ipv6 netstream export
protocol-port aggregation export information:
  Flow source interface                              : Ten-GigabitEthernet1/0/1
  Flow destination VPN instance                      : VPN1
  Flow destination IPv6 address (UDP)                : 40::1 (30000)
  Version  9 exported flow number                    : 16
  Version  9 exported UDP datagram number (failed)   : 2 (0)
  Version 10 exported flow number                    : 0
  Version 10 exported UDP datagram number (failed)   : 0 (0)
IPv6 export information:
  Version  9 exported UDP datagram number (failed)   : 16 (0)
MPLS export information:
  Version  9 exported flow number                    : 20
Statistics of IPv6 NetStream protocol-port aggregation in the version 9 format.
Information about the IPv6 NetStream data export.
Source interface from which the IPv6 NetStream data is exported.
VPN to which the destination address of the IPv6 NetStream data export belongs.
Destination IPv6 address and UDP port number of the IPv6 NetStream data export.
Number of flows that are exported in the version 9 format.
Number of UDP packets that are sent in the version 9 format. The value in the parentheses displays the number of UDP packets that failed to be sent.
Number of flows that are exported in the version 10 format.
Number of UDP packets that are sent in the version 10 format. The value in the parentheses displays the number of UDP packets that failed to be sent.
display ipv6 netstream template
Use display ipv6 netstream template to display IPv6 NetStream template information.
In standalone mode:
display ipv6 netstream template [ slot slot-number ]
In IRF mode:
display ipv6 netstream template [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command displays IPv6 NetStream template information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 NetStream template information for the global active MPU. (In IRF mode.)
IPv6 NetStream templates vary by aggregation mode. This command displays IPv6 NetStream template information for all the configured aggregation modes.
# Display IPv6 NetStream template information.
<Sysname> display ipv6 netstream template
 Flow template refresh frequency            : 20
 Flow template refresh interval             : 30 min
 Active flow templates                      : 2
 Created flow templates                     : 2
Protocol-port outbound template:
 Template ID                : 3258
 Field count                : 15
 Field type                   Field length (bytes)
 Flows                        4
 Out packets                  8
 Out bytes                    8
 First forwarded              4
 Last forwarded               4
 Protocol                     1
 IP protocol version          1
 Direction                    1
 PAD                          1
 L4 source port               2
 L4 destination port          2
 Sampling algorithm           1
 PAD                          1
 PAD                          1
 PAD                          1
 Sampling interval            4
 Serial number                65535
Protocol-port inbound template:
 Template ID                : 3257
 Field count                : 15
 Flows                        4
 In packets                   8
 In bytes                     8
 First forwarded              4
 Last forwarded               4
 Protocol                     1
 Direction                    1
 PAD                          1
 L4 source port               2
 PAD                          1
 PAD                          1
 PAD                          1
 Sampling interval            4
 Serial number                65535
Refresh frequency at which the templates are sent, in packets.
Refresh interval at which the templates are sent, in minutes.
Number of active IPv6 NetStream templates.
Number of templates that have been created.
Information about the protocol-port template in the outbound direction.
Information about the protocol-port template in the inbound direction.
Field count
Total number of fields in the template.
Field type
Type of a field in the template.
Flows
Number of flows.
Out packets
Number of sent packets.
In packets
Number of received packets.
Out bytes
Number of sent bytes.
In bytes
Number of received bytes.
First forwarded
System time when the first packet was forwarded, accurate to milliseconds.
Last forwarded
System time when the last packet was forwarded, accurate to milliseconds.
Direction
Traffic direction.
L4 source port
Source UDP or TCP port.
L4 destination port
Destination UDP or TCP port.
Sampling algorithm
Sampling algorithm (not supported).
PAD
Padding string.
Sampling interval
Sampling rate (not supported).
Serial number
Device serial number.
enable
Use enable to enable an IPv6 NetStream aggregation mode.
Use undo enable to disable an IPv6 NetStream aggregation mode.
enable
undo enable
No IPv6 NetStream aggregation mode is enabled.
IPv6 NetStream aggregation mode view
# Enable IPv6 NetStream destination-prefix aggregation mode.
[Sysname] ipv6 netstream aggregation destination-prefix
[Sysname-ns6-aggregation-dstpre] enable
ipv6 netstream
Use ipv6 netstream to enable IPv6 NetStream on an interface.
Use undo ipv6 netstream to disable IPv6 NetStream on an interface.
ipv6 netstream { inbound | outbound }
undo ipv6 netstream { inbound | outbound }
IPv6 NetStream is disabled on an interface.
Interface view
inbound: Enables IPv6 NetStream for incoming traffic.
outbound: Enables IPv6 NetStream for outgoing traffic.
# Enable IPv6 NetStream for inbound traffic on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 netstream inbound
Use ipv6 netstream aggregation to specify an IPv6 NetStream aggregation mode and enter its view.
Use undo ipv6 netstream aggregation to remove the configuration for an IPv6 NetStream aggregation mode.
ipv6 netstream aggregation{ destination-prefix | prefix | protocol-port | source-prefix }
undo ipv6 netstream aggregation{ destination-prefix | prefix | protocol-port | source-prefix }
No IPv6 NetStream aggregation mode is specified.
destination-prefix: Specifies the destination-prefix aggregation by destination AS number, destination address mask length, destination prefix, and output interface index.
prefix: Specifies the source and destination prefix aggregation by the following criteria:
·     Source AS number.
·     Destination AS number.
·     Source address mask length.
·     Destination address mask length.
·     Source prefix.
·     Destination prefix.
·     Input interface index.
·     Output interface index.
protocol-port: Specifies the protocol-port aggregation by protocol number, source port, and destination port.
source-prefix: Specifies the source-prefix aggregation by source AS number, source address mask length, source prefix, and input interface index.
In IPv6 NetStream aggregation mode view, you can perform the following tasks:
·     Enable or disable the specified IPv6 NetStream aggregation mode.
·     Configure source interface, destination IPv6 address, and destination port for the IPv6 NetStream data export.
A flow matching multiple aggregation modes is counted as multiple aggregate flows.
# Set the IPv6 NetStream aggregation mode to destination-prefix, and enter IPv6 NetStream destination-prefix aggregation mode view.
enable
ipv6 netstream export host
ipv6 netstream export source
ipv6 netstream aggregation advanced
Use ipv6 netstream aggregation advanced to enable IPv6 NetStream hardware aggregation.
Use undo ipv6 netstream aggregation advanced to disable NetStream hardware aggregation..
IPv6 NetStream hardware aggregation is disabled.
The IPv6 NetStream hardware aggregation does not take effect if the destination host is configured for NetStream traditional data export.
The IPv6 NetStream hardware aggregation entries are stored in the same cache as IPv6 NetStream traditional data entries and are exportable.
# Enable the IPv6 NetStream hardware aggregation.
[Sysname] ipv6 netstream aggregation advanced
Use ipv6 netstream export host to specify a destination host for IPv6 NetStream data export.
Use undo ipv6 netstream export host to remove the specified destination host or all destination hosts that are configured in the current view.
ipv6 netstream export host { ipv4-address | ipv6-address } udp-port [ vpn-instance vpn-instance-name ]
undo ipv6 netstream export host [ ipv4-address | ipv6-address ] [ vpn-instance vpn-instance-name ]
No destination host is specified for IPv6 NetStream data export.
ipv4-address: Specifies the destination IPv4 address.
ipv6-address: Specifies the destination IPv6 address.
udp-port: Specifies the destination UDP port number in the range of 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination is on the public network, do not specify this option.
You can specify the same destination host address and UDP port in different IPv6 NetStream aggregation mode views. If an aggregation mode is not enabled, the display ipv6 netstream export command cannot display the destination host configuration for the mode.
If no destination host is specified in an IPv6 NetStream aggregation mode view, the destination host in system view applies. If destination hosts are specified in an IPv6 NetStream aggregation view and system view, the destination hosts in aggregation view take effect.
In system view or in IPv6 NetStream aggregation mode view, you can specify a maximum of four IPv4 destination hosts and four IPv6 destination hosts, respectively. If you specify a destination host with the same destination address but different UDP ports in the same view, the most recent configuration takes effect. You can specify destination hosts with the same destination address and UDP port but different VPN instances.
IPv6 NetStream traditional data is exported to all destination hosts in system view. IPv6 NetStream aggregation data is exported to all destination hosts in the related aggregation view. If you expect only IPv6 NetStream aggregation data, specify destination hosts only in the IPv6 NetStream aggregation mode view. Aggregation data export reduces bandwidth usage.
# In system view, specify 40::1 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Sysname] ipv6 netstream export host 40::1 5000
ipv6 netstream export rate
Use ipv6 netstream export rate to limit the IPv6 NetStream data export rate.
Use undo ipv6 netstream export rate to restore the default.
ipv6 netstream export rate rate
The export rate of IPv6 NetStream data is not limited.
rate: Specifies the export rate in the range of 1 to 1000.
This command sets the maximum number of IPv6 NetStream packets that can be exported per second. Packets that cannot be exported due to the export rate limit are buffered for later export. When the buffer is full, the system will temporarily invalidate the rate limit and export packets as fast as possible until the buffer has space for new packets.
# Allow a maximum of 10 packets to be exported per second.
[Sysname] ipv6 netstream export rate 10
Use ipv6 netstream export source to specify the source interface for data packets sent to NetStream servers. The IPv6 address of the interface is used as the source IPv6 address of the data packets.
Use undo ipv6 netstream export source to restore the default.
ipv6 netstream export source interface interface-type interface-number
The packets take the IPv6 address of the output interface as the source IPv6 address.
interface-type interface-number: Specifies a source interface by its type and number for the IPv6 NetStream data export.
You can configure different source interfaces in different IPv6 NetStream aggregation mode views.
If no source interface is configured in IPv6 NetStream aggregation mode view, the source interface in system view applies.
As a best practice, connect the management Ethernet interface to a NetStream server, and configure the interface as the source interface.
# In system view, specify Ten-GigabitEthernet 1/0/1 as the source interface for IPv6 NetStream traditional data packets.
[Sysname] ipv6 netstream export source interface ten-gigabitethernet 1/0/1
# In destination-prefix aggregation mode view, specify Ten-GigabitEthernet 1/0/2 as the source interface for IPv6 NetStream aggregation data packets.
[Sysname-ns6-aggregation-dstpre] ipv6 netstream export source interface ten-gigabitethernet 1/0/2
ipv6 netstream export template refresh-rate
Use ipv6 netstream export template refresh-rate to set the refresh rate for the IPv6 NetStream version 9 or version 10 template.
Use undo ipv6 netstream export template refresh-rate to restore the default.
ipv6 netstream export template refresh-rate { packet packets | time minutes }
undo ipv6 netstream export template refresh-rate { packet | time }
The packet count-based refresh rate is 20 packets, and the time-based refresh interval is 30 minutes.
packet packets: Specifies the number of packets that are sent before the template is sent. The value range is 1 to 600.
time minutes: Specifies the interval at which the template is sent, in the range of 1 to 3600 minutes.
Version 9 and version 10 are template-based and support user-defined formats. An IPv6 NetStream device must send the version 9 or version 10 template to NetStream servers regularly, because the servers do not permanently save templates.
The refresh rate can be packet count-based or time-based. If both settings are configured, the template is sent when either of the conditions is met.
# Configure the device to send the IPv6 NetStream version 9 or version 10 template every 100 packets.
[Sysname] ipv6 netstream export template refresh-rate packet 100
ipv6 netstream export version
Use ipv6 netstream export version 9 to export IPv6 NetStream data in the version 9 format and choose whether to record AS, BGP next hop, and serial number information.
Use ipv6 netstream export version 10 to export IPv6 NetStream data in the version 10 format and choose whether to record AS, BGP next hop, and serial number information.
Use undo ipv6 netstream export version to restore the default.
ipv6 netstream export version { 9 | 10 } { origin-as | peer-as } [ bgp-nexthop ] [ serial-number ]
The version 9 format is used to export IPv6 NetStream data.
The peer AS numbers are recorded. The BGP next hop and serial number are not recorded.
origin-as: Records the source AS of the source address and the destination AS of the destination address.
peer-as: Records the ASs before and after the AS where the NetStream device resides as the source AS and destination AS, respectively.
bgp-nexthop: Records BGP next hops.
serial-number: Records the device serial number.
Only one version format can take effect on the device. If you execute the  ipv6 netstream export version command multiple times, the most recent configuration takes effect.
An IPv6 NetStream entry records the source IPv6 address, destination IPv6 address, and two AS numbers for each address. You can choose to configure which AS numbers are to be exported as the source AS and destination AS.
In version 9 and version 10 formats, you can also choose whether to record the BGP next hop and serial number information.
# Configure the device to export IPv6 NetStream data in the version 9 format, and specify the IPv6 NetStream data to include the source AS and destination AS.
[Sysname] ipv6 netstream export version 9 origin-as
# Configure the device to export IPv6 NetStream data in the version 9 format, and specify the IPv6 NetStream data to include the source AS and destination AS. Record the BGP next hop and serial number information.
[Sysname] ipv6 netstream export version 9 origin-as bgp-nexthop serial-number
ipv6 netstream filter
Use ipv6 netstream filter to enable IPv6 NetStream filtering on an interface.
Use undo ipv6 netstream filter to disable IPv6 NetStream filtering on an interface.
ipv6 netstream { inbound | outbound } filter acl acl-number
undo ipv6 netstream { inbound | outbound } filter
IPv6 NetStream filtering is disabled. IPv6 NetStream collects statistics about all IPv6 packets passing through an interface.
Interface view
inbound: Filters incoming traffic.
outbound: Filters outgoing traffic.
acl acl-number:Specifies an ACL by its number. The supported value ranges for ACLs are as follows:
·     2000 to 2999: Basic ACLs
·     3000 to 3999: Advanced ACLs
·     4000 to 4999: Layer 2 ACLs
·     5000 to 5999: User-defined ACLs
IPv6 NetStream filtering uses an ACL to identify intended packets.
·     If you want to collect data for specific flows, use the ACL permit statements to identify the flows. IPv6 NetStream collects data only for these flows.
·     If you do not want to collect data for specific flows, use the ACL deny statements to identify the flows. IPv6 NetStream does not collect data for these flows.
# Use ACL 2003 for inbound IPv6 NetStream filtering on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 netstream inbound filter acl 2003
ipv6 netstream sampler
Use ipv6 netstream sampler to enable IPv6 NetStream sampling.
Use undo ipv6 netstream sampler to disable IPv6 NetStream sampling.
ipv6 netstream { inbound | outbound } sampler sampler-name
undo ipv6 netstream { inbound | outbound } sampler
IPv6 NetStream sampling is disabled.
Interface view
inbound: Enables IPv6 NetStream sampling in the inbound direction.
outbound: Enables IPv6 NetStream sampling in the outbound direction.
sampler sampler-name: Specifies a sampler by its name. The name is a case-insensitive string of 1 to 31 characters.
# Use sampler abc for inbound IPv6 NetStream sampling on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 netstream inbound sampler abc
ipv6 netstream timeout active
Use ipv6 netstream timeout active to set the aging timer for active flows.
Use undo ipv6 netstream timeout active to restore the default.
ipv6 netstream timeout active minutes
The aging timer is 5 minutes for active flows.
minutes: Sets the aging timer for active flows, in the range of 1 to 5 minutes.
A flow is considered active if packets for the IPv6 NetStream entry arrive before the timer set by this command expires.
# Set the aging timer to 4 minutes for active flows.
[Sysname] ipv6 netstream timeout active 4
ipv6 netstream timeout inactive
Use ipv6 netstream timeout inactive to set the aging timer for inactive flows.
Use undo ipv6 netstream timeout inactive to restore the default.
ipv6 netstream timeout inactive seconds
The aging timer is 300 seconds for inactive flows.
seconds: Sets the aging timer for inactive flows, in the range of 10 to 320 seconds.
A flow is considered inactive if no packet for the IPv6 NetStream entry arrives before the timer set by this command expires.
# Set the aging timer to 60 seconds for inactive flows.
[Sysname] ipv6 netstream timeout inactive 60
Use reset ipv6 netstream statistics to age out all flows in the cache and export IPv6 NetStream data.
Usage guide
It takes the system several minutes to execute the command. During this period, the system does not collect IPv6 NetStream data.
# Age out and export all IPv6 NetStream data.
<Sysname> reset ipv6 netstream statistics
This process may take a few minutes.
NetStream statistic function is disabled during this process.
snmp-agent trap enable ipv6 netstream
Use snmp-agent trap enable ipv6 netstream to enable SNMP notifications for IPv6 NetStream.
Use undo snmp-agent trap enable ipv6 netstream to disable SNMP notifications for IPv6 NetStream.
SNMP notifications are enabled for IPv6 NetStream.
Use this feature to report important events for IPv6 NetStream through SNMP notifications. The generated alarm information will be sent to the SNMP module on the device and you can configure the SNMP notification sending parameters to determine the export attributes of the alarm information. For more information, see "Configuring SNMP."
# Enable SNMP notifications for IPv6 NetStream.
[Sysname] snmp-agent trap enable ipv6 netstream
