07-MPLS
HomeSupportDiagnose & MaintainAlarms ReferencesH3C SR6600[SR6600-X] Routers Alarm Reference-R6749-6W10007-MPLS
03-MPLS-LSR-STD-MIB
03-MPLS-LSR-STD-MIB 86.80 KB
MPLS-LSR-STD-MIB
About this MIB
A label switching router (LSR) is a router that performs MPLS forwarding. Based on the traditional routing table, LSRs establish label switching paths through a label distribution protocol to perform fast label switching.
MPLS-LSR-STD-MIB is a standard MIB based on RFC 3813.
MIB file name
rfc3813-mpls-lsr-std.mib
Notifications
mplsXCUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.2.0.1
mplsXCup
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the MPLSXC state (mplsXCOperStatus) of a tunnel (such as LDP tunnel or MPLS TE tunnel) changes to UP.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.2.1.10.1.9 (mplsXCAdminStatus)
Operational status of the label.
mplsXCIndex
mplsXCInSegmentIndex
mplsXCOutSegmentIndex
INTEGER
up(1), down(2), testing(3)
1.3.6.1.2.1.10.166.2.1.10.1.10
(mplsXCOperStatus)
Actual operational status of the cross-connect.
mplsXCIndex
INTEGER
up(1), down(2),  testing(3), unknown(4), dormant(5), notPresent(6), lowerLayerDown(7)
Recommended action
No action is required.
mplsXCDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.2.0.2
A cross-connect enters down state.
Error
Major
1.3.6.1.2.1.10.166.2.0.1(mplsXCUp)
ON
This notification is generated when the MPLSXC state (mplsXCOperStatus) of a tunnel (such as LDP tunnel or MPLS TE tunnel) changes to down.
Possible causes:
1.     MPLS is disabled on the interfaces that the tunnel passes through.
2.     A protocol fault occurs on the tunnel. For example, LDP is disabled globally or on the interfaces that the tunnel passes through.
3.     A fault occurs on the path that the tunnel passes through.
4.     Dependent routes of the tunnel have been withdrawn.
5.     The tunnel is switched to a new path and the new path has problem 1 or 2.
System impact
Service traffic carried on the tunnel will be interrupted.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
mplsXCIndex
INTEGER
(mplsXCOperStatus)
mplsXCIndex
INTEGER
Recommended action
According to the protocol, tunnel destination address, outgoing interface/next hop and outgoing label information in the mplsXCDown notification message, execute the following steps to resolve this issue:
1.     Check routes: Execute the display ip routing-table command or the display ipv6 routing-table command to view whether the route corresponding to the tunnel destination address exists.
¡     If the route does not exist, configure a proper routing protocol to generate a route to the tunnel destination address. Check whether an mplsXCUp notification is generated. If yes, the issue is resolved. If not, go to step 2.
¡     If the route exists, go to step 2.
2.     According to the outgoing interface/next hop information, execute the display mpls interface command to identify whether the outgoing interface is enabled with MPLS.
¡     If the interface is not enabled with MPLS, execute the mpls enable command on the interface. Check whether an mplsXCUp notification is generated. If yes, the issue is resolved. If not, go to step 3.
¡     If the interface is enabled with MPLS, go to step 3.
3.     According to the tunnel protocol information, check the protocol capabilities on the interface. Take an LDP tunnel as an example. Execute the display mpls ldp interface command to check whether LDP is enabled on the outgoing interface.
¡     If LDP is not enabled, execute the mpls ldp command in system view to enable LDP globally and the mpls ldp enable command in interface view to enable LDP on the interface. Check whether an mplsXCUp notification is generated. If yes, the issue is resolved. If not, go to step 4.
¡     If LDP is enabled globally and on the outgoing interface, go to step 4.
4.     According to the route in step 1, find the next hop. Execute step 1 through step 3 on the next hop device. Repeat this step to troubleshoot all the nodes that the tunnel passes until the issue is resolved.
5.     If the issue persists, contact Technical Support.
