08-Multicast
HomeSupportReference GuidesMIB CompanionH3C SR6600[SR6600-X] Routers MIB Reference-R6749-6W10008-Multicast
05-PIM-BSR-MIB
05-PIM-BSR-MIB 84.46 KB
PIM-BSR-MIB
About this MIB
Use this MIB to manage PIM BSR settings.
MIB file name
rfc5240-pim-bsr.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pimBsrMIB(172)
Tabular objects
pimBsrCandidateRPTable
About this table
This table contains the IP multicast group for which the local router is to advertise itself as a Candidate-RP.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimBsrCandidateRPAddressType, pimBsrCandidateRPAddress, pimBsrCandidateRPGroupAddress, and pimBsrCandidateRPGroupPrefixLength.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.172.1.1.1.1)
not-accessible
InetAddressType
ipv4(1),
ipv6(2),
Address type of a C-RP.
Supports only values ipv4(1) and ipv6(2).
(1.3.6.1.2.1.172.1.1.1.2)
not-accessible
InetAddress
OCTET STRING (4|16)
IP address of the C-RP.
As per the MIB.
(1.3.6.1.2.1.172.1.1.1.3)
not-accessible
InetAddress
OCTET STRING (4|16)
IP address of the multicast group for which the C-RP is advertised.
Supports only multicast group addresses.
(1.3.6.1.2.1.172.1.1.1.4)
not-accessible
InetAddressPrefixLength
Unsigned32(4..128)
Mask of the multicast group for which the C-RP is advertised.
pimBsrCandidateRPBidir
(1.3.6.1.2.1.172.1.1.1.5)
read-create
TruthValue
true(1),
false(2)
PIM mode of the multicast group range for the RP, BIDIR-PIM or PIM-SM.
Read-only.
pimBsrCandidateRPAdvTimer
(1.3.6.1.2.1.172.1.1.1.6)
read-only
TimeTicks
Standard MIB values.
Time remaining before the local router sends a Candidate-RP-Advertisement to the elected BSR for this zone.
To disable this timer, set the value of this object to 0.
pimBsrCandidateRPPriority
(1.3.6.1.2.1.172.1.1.1.7)
read-create
Unsigned32
Unsigned32(0..255)
Priority for the C-RP.
Read-only.
pimBsrCandidateRPAdvInterval
(1.3.6.1.2.1.172.1.1.1.8)
read-create
Unsigned32
Unsigned32(1..26214)
Time interval between two consecutive advertisements, in seconds.
Read-only.
pimBsrCandidateRPHoldtime
(1.3.6.1.2.1.172.1.1.1.9)
read-create
Unsigned32
Unsigned32(0..65535)
Holdtime for the C-RP.
Read-only.
Value table: 1:1..65535.
pimBsrCandidateRPStatus
(1.3.6.1.2.1.172.1.1.1.10)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
Read-only.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
pimBsrCandidateRPStorageType
(1.3.6.1.2.1.172.1.1.1.11)
read-create
StorageType
other(1)
Row storage type.
Read-only.
Supports only value other(1).
pimBsrElectedBSRRPSetTable
About this table
This table contains BSR-specific information about PIM group mappings. It supports only the public network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are pimBsrElectedBSRGrpMappingAddrType, pimBsrElectedBSRGrpMappingGrpAddr, pimBsrElectedBSRGrpMappingGrpPrefixLen, and pimBsrElectedBSRGrpMappingRPAddr.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.172.1.2.1.2)
not-accessible
InetAddressType
ipv4(1),
ipv6(2)
Address type of a multicast group.
(1.3.6.1.2.1.172.1.2.1.3)
not-accessible
InetAddress
OCTET STRING (4|16)
IP address of the multicast group.
As per the MIB.
(1.3.6.1.2.1.172.1.2.1.4)
not-accessible
Unsigned32(4..128)
Mask of the multicast group address.
As per the MIB.
(1.3.6.1.2.1.172.1.2.1.5)
not-accessible
InetAddress
OCTET STRING (4|16)
IP address of the RP to be used for the multicast group.
As per the MIB.
pimBsrElectedBSRRPSetPriority
(1.3.6.1.2.1.172.1.2.1.6)
read-only
Unsigned32
Unsigned32(0..255)
Priority of the RP.
As per the MIB.
pimBsrElectedBSRRPSetHoldtime
(1.3.6.1.2.1.172.1.2.1.7)
read-only
Unsigned32
Holdtime of the RP.
As per the MIB.
pimBsrElectedBSRRPSetExpiryTime
(1.3.6.1.2.1.172.1.2.1.8)
read-only
TimeTicks
Minimum time remaining before this entry will be aged out.
Value zero indicates that the entry will age out immediately.
pimBsrElectedBSRRPSetGrpBidir
(1.3.6.1.2.1.172.1.2.1.9)
read-only
TruthValue
true(1),
false(2)
PIM mode used for the multicast group, BIDIR-PIM or PIM-SM.
As per the MIB.
pimBsrCandidateBSRTable
About this table
This table contains C-BSR settings.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is pimBsrCandidateBSRZoneIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.172.1.3.1.1)
not-accessible
InetZoneIndex
Unsigned32(1..4294967295)
Index of the zone to which a C-BSR is attached.
Supports only 0xFFFFFFFF 0X7FFFFFFF.
pimBsrCandidateBSRAddressType
(1.3.6.1.2.1.172.1.3.1.2)
read-create
InetAddressType
ipv4(1),
ipv6(2)
Address type of the C-BSR.
(1.3.6.1.2.1.172.1.3.1.3)
read-create
InetAddress
OCTET STRING (4|16)
IP address of the C-BSR.
As per the MIB.
pimBsrCandidateBSRPriority
(1.3.6.1.2.1.172.1.3.1.4)
read-create
Unsigned32
Unsigned32(0..255)
Priority of the C-BSR.
Default: 1:64 (int).
Value range: 1:0..255.
pimBsrCandidateBSRHashMaskLength
(1.3.6.1.2.1.172.1.3.1.5)
read-create
Unsigned32
Unsigned32(0..32)
Mask length for the IP address of the C-BSR.
Value range: 1:0..32.
pimBsrCandidateBSRElectedBSR
(1.3.6.1.2.1.172.1.3.1.6)
read-only
TruthValue
true(1),
false(2)
Whether this router is a BSR.
As per the MIB.
pimBsrCandidateBSRBootstrapTimer
(1.3.6.1.2.1.172.1.3.1.7)
read-only
TimeTicks
Time remaining for this router to send the next BSR message.
As per the MIB.
pimBsrCandidateBSRStatus
(1.3.6.1.2.1.172.1.3.1.8)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
pimBsrCandidateBSRStorageType
(1.3.6.1.2.1.172.1.3.1.9)
read-create
StorageType
other(1)
Row storage type.
Read-only.
pimBsrElectedBSRTable
About this table
This table contains BSR settings. It supports only the public network and does not support administratively-scoped zones.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported.
Supports only index 0xffffffff.
Supports only IPv4.
Columns
The table index is pimBsrElectedBSRZoneIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.172.1.4.1.1)
not-accessible
InetZoneIndex
pimBsrElectedBSRAddressType
(1.3.6.1.2.1.172.1.4.1.2)
read-only
InetAddressType
ipv4(1),
ipv6(2)
Address type of a BSR.
(1.3.6.1.2.1.172.1.4.1.3)
read-only
InetAddress
OCTET STRING (4|16)
IP address of the BSR.
As per the MIB.
pimBsrElectedBSRPriority
(1.3.6.1.2.1.172.1.4.1.4)
read-only
Unsigned32
Unsigned32(0..255)
Priority of the BSR.
As per the MIB.
pimBsrElectedBSRHashMaskLength
(1.3.6.1.2.1.172.1.4.1.5)
read-only
Unsigned32
Unsigned32(0..128)
Mask length for the BSR's IP address.
Value range: 1:0..128.
pimBsrElectedBSRExpiryTime
(1.3.6.1.2.1.172.1.4.1.6)
read-only
TimeTicks
Time remaining before the BSR ages out.
As per the MIB.
