06-Comware 7 CLI-based configuration examples (AP standalone deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10206-Comware 7 CLI-based configuration examples (AP standalone deployment)
09-Interoperation of Fat APs and Switch for WLAN Access and Roaming Configuration Examples
H3C Access Points
Comware 7 Interoperation of Fat APs and Switches for WLAN Access and Roaming
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring a WLAN with multiple fat APs switches.
This document applies to Comware 7-based access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access points.
This document assumes that you have basic knowledge of WLAN access and WLAN roaming.
Example: Configuring WLAN with multiple fat APs and switches
As shown in Figure 1, the WLAN includes H3C Wi-Fi 6 wireless access points, PoE switch, and Layer 3 switch. Make sure the network configuration meets the following requirements:
·     The Layer 3 switch acts as a DHCP server to assign IP addresses to clients.
·     The Layer 2 switch supplies power to APs in PoE mode.
·     The clients access the WLAN over VLAN 100.
·     The IP addresses of APs are manually assigned.
·     The client can roam from one radio to another radio within a fat AP or roam from one fat AP to another fat AP.
Figure 1 Network diagram
Table 1 IP address planning and VLAN planning
Device
IP address
L3 switch
VLAN-interface 100
10.100.2.111/16
L2 switch
VLAN-interface 100
10.100.2.112/16
AP 1
VLAN-interface 100
10.100.2.121/16
AP 2
VLAN-interface 100
10.100.2.122/16
AP 3
VLAN-interface 100
10.100.2.123/16
AP 4
VLAN-interface 100
10.100.2.124/16
Analysis
·     To ensure successful communication, configure Layer 2 connectivity between fat APs and the Layer 2 switch.
·     For dynamic IP address assignment to clients, enable the DHCP server feature on the Layer 3 switch.
·     Enable PoE power supply on the Layer 2 switch to supply power for fat APs.
·     Configure a valid region code for each fat AP.
·     Configure a fat AP mobility group for inter-AP roaming.
Procedures
Configuring the Layer 3 switch
1.     Configure interface settings:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface.
<L3 switch>system-view
[L3 switch] vlan 100
[L3 switch-vlan100] quit
[L3 switch] interface vlan-interface 100
[L3 switch-Vlan-interface1] ip address 10.100.2.111 255.255.0.0
[L3 switch-Vlan-interface1] quit
# Configure the interface that is connected to the Layer 2 switch as a trunk port, and assign the port to VLAN 100. In this example, the interface is GigabitEthernet 1/0/2.
[L3 switch] interface gigabitethernet 1/0/2
[L3 switch-GigabitEthernet1/0/2] port link-type trunk
[L3 switch-GigabitEthernet1/0/2] port trunk permit vlan 100
[L3 switch-GigabitEthernet1/0/2] quit
2.     Configure DHCP server settings:
# Create DHCP address pool 100 for dynamic address assignment to clients. Specify subnet 10.100.2.0/16 for the pool and exclude IP address 10.100.2.112 and IP range 10.100.2.121 to 10.100.2.124 from dynamic allocation. Set the gateway IP address to 10.100.2.111.
[L3 switch] dhcp server ip-pool 100
[L3 switch-dhcp-pool-100] network 10.100.2.0 mask 255.255.0.0
[L3 switch-dhcp-pool-100] gateway-list 10.100.2.111
[L3 switch-dhcp-pool-100] forbidden-ip 10.100.2.112
[L3 switch-dhcp-pool-100] forbidden-ip-range 10.100.2.121 10.100.2.124
[L3 switch-dhcp-pool-100] quit
# Enable the DHCP server feature.
[L3 switch] dhcp enable
Configuring the Layer 2 switch
<L2 switch> system-view
[L2 switch] interface vlan-interface 100
[L2 switch-Vlan-interface100] ip address 10.100.2.112 255.255.0.0
[L2 switch-Vlan-interface100] quit
[L2 switch] vlan 100
[L2 switch-vlan100] quit
# Configure the interface that is connected to the Layer 3 switch as a trunk port, and assign the port to VLAN 100. In this example, the interface is GigabitEthernet 1/0/1.
[L2 switch] interface gigabitethernet 1/0/1
[L2 switch-GigabitEthernet1/0/1] port link-type trunk
[L2 switch-GigabitEthernet1/0/1] port trunk permit vlan 100
[L2 switch-GigabitEthernet1/0/1] quit
# Configure the interface that is connected to a FAT AP as an access port, assign the port to VLAN 100, and then enable PoE power supply. In this example, the interface is GigabitEthernet 1/0/2.
[L2 switch] interface range gigabitethernet 1/0/2
[L2 switch-GigabitEthernet1/0/2] port access vlan 100
[L2 switch-GigabitEthernet1/0/2] poe enable
[L2 switch-GigabitEthernet1/0/2] quit
Configuring fat APs
The fat AP configuration takes fat AP 1 as an example. You can configure fat APs 2, 3, and 4 in the same way as you configure fat AP 1.
1.     Specify a region code for fat AP 1. If the default region code of fat AP 1 is the same as the example region code, skip this step.
<AP> system-view
[AP] wlan global-configuration
[AP-wlan-global-configuration] region-code JP
This operation may reset the radio parameters. Continue? [Y/N]:y
[AP-wlan-global-configuration] quit
2.     Configure interface settings for fat AP 1:
[AP] interface vlan-interface 100
[AP-Vlan-interface100] ip address 10.100.2.121 255.255.0.0
[AP-Vlan-interface100] quit
[AP] vlan 100
[AP-vlan100] quit
# Configure the interface that is connected to the Layer 2 switch as an access port, and assign the port to VLAN 100. In this example, the interface is GigabitEthernet 1/0/1.
[AP] interface gigabitethernet 1/0/1
[AP-GigabitEthernet1/0/1] port link-type access
[AP-GigabitEthernet1/0/1] port access vlan 100
[AP-GigabitEthernet1/0/1] quit
3.     Configure service template settings for fat AP 1:
# Create service template service1 and enter its view.
[AP] wlan service-template service1
# Configure the SSID as service.
[AP-wlan-st-service1] ssid service
# Assign the clients that come online through service template service1 to VLAN 100.
[AP-wlan-st-service1] vlan 100
# Specify PSK as the AKM mode and specify 12345678 as the plaintext key.
[AP-wlan-st-service1] akm mode psk
[AP-wlan-st-service1] preshared-key pass-phrase simple 12345678
# Specify CCMP as the cipher suite and specify RSN as the security IE.
[AP-wlan-st-service1] cipher-suite ccmp
[AP-wlan-st-service1] security-ie rsn
# Enable service template service1.
[AP-wlan-st-service1] service-template enable
[AP-wlan-st-service1] quit
# Bind service template service1 to interface WLAN-Radio 1/0/1.
[AP] interface wlan-radio 1/0/1
[AP-WLAN-Radio1/0/1] undo shutdown
[AP-WLAN-Radio1/0/1] service-template service1
[AP-WLAN-Radio1/0/1] quit
# Bind service template service1 to interface WLAN-Radio 1/0/2.
[AP] interface wlan-radio 1/0/2
[AP-WLAN-Radio1/0/2] undo shutdown
[AP-WLAN-Radio1/0/2] service-template service1
[AP-WLAN-Radio1/0/2] quit
4.     Configure mobility group settings for fat AP 1:
# Create mobility group office.
[AP] wlan mobility group office
# Set the IP address type to IPv4 for IADTP tunnels.
[AP-wlan-mg-office] tunnel-type ipv4
# Set the source IP address for IACTP tunnel establishment to the IP address of fat AP 1. In this example, the IP address of fat AP 1 is 10.100.2.121. Fat AP 1 uses the specified source IP address for IACTP tunnel establishment when it is added to mobility group office.
[AP-wlan-mg-office] source ip 10.100.2.121
# Enable automatic group member discovery.
[AP-wlan-mg-office] member auto-discovery
# Enable mobility group office.
[AP-wlan-mg-office] group enable
[AP-wlan-mg-office] quit
After the client roam from AP 1 to AP 2, use commands to view the following roaming information:
# Display mobility group information to verify mobility group office has been created on AP 1.
[AP1] display wlan mobility group
Mobility group name: office
 Tunnel type: IPv4
 Source IPv4: 10.100.2.121
 Source IPv6: Not configured
 Authentication method: Not configured
 Mobility group status: Enabled
 Member entries: 1
 IP address                              State          Online time
 10.100.2.122                            Up             00hr 00min 12sec
10.100.2.123                            Up             00hr 00min 15sec
10.100.2.124                            Up             00hr 00min 20sec
# Display mobility group information to verify mobility group office has been created on AP 2.
[AP2] display wlan mobility group
 Tunnel type: IPv4
 Source IPv4: 10.100.2.122
 Member entries: 1
 10.100.2.121                            Up             00hr 00min 05sec
# Display client roaming information on AP 1 to verify that the client came online from AP 1 and roamed to AP 2. You can use the display wlan mobility roam-track mac-address command to display client roaming information.
[AP1] display wlan mobility roam-track mac-address bce2-659a-3232
Total entries  : 2
Current entries: 2
BSSID           Created at           Online time       AP IP address  RID  AP name
74ea-c8fd-c200  2016-06-14 11:12:28  00hr 06min 56sec  10.100.2.122   2    ap2
74ea-c8fd-c1e0  2016-06-14 11:11:28  00hr 03min 30sec  127.0.0.1      1    ap1
# On AP 1, verify that the client has roamed to AP 2. You can use the display wlan mobility roam-out command to display information about the clients that have roamed from AP 1.
[AP1] display wlan mobility roam-out
Total entries: 1
MAC address     BSSID           VLAN ID  Online time       FA IP address
bce2-659a-3232  74ea-c8fd-c200  1        00hr 01min 59sec  10.100.2.122
# On AP 2, verify that the client has associated with AP 2, and the roaming status is Inter-AP Roam. You can use the display wlan client command to display information about the clients associated with AP 2.
[AP2] display wlan client verbose
Total number of clients: 1
 MAC address                       : bce2-659a-3232
 IPv4 address                      : 10.100.2.125
 IPv6 address                      : N/A
 Username                          : N/A
 AID                               : 978
 Radio ID                          : 2
 Channel                           : 36
 SSID                              : service
 BSSID                             : 74ea-c8fd-c200
 VLAN ID                           : 100
 VLAN ID2                          : N/A
 Sleep count                       : 49
 Roam status                       : Inter-AP roam
 Key derivation                    : N/A
 PMF status                        : N/A
 Forwarding policy name            : Not configured
 Online time                       : 0days 0hours 0minutes 54seconds
 FT status                         : Inactive
# On AP 2, verify that the client has roamed to AP 2. You can use the display wlan mobility roam-in command to display information about the clients that have roamed to AP 2.
[AP2] display wlan mobility roam-in
Total entries: 1
MAC address     BSSID           VLAN ID  HA IP address
bce2-659a-3232  74ea-c8fd-c200  100      10.100.2.121
Configuration files
·     L3 Switch
vlan 100
interface Vlan-interface100
dhcp server ip-pool vlan100
 forbidden-ip range 10.100.2.121 10.100.2.124
dhcp enable
·     L2 Switch
vlan 100
poe enable
·     FAT AP 1
vlan 100
 ssid service
 vlan 100
akm mode psk
cipher-suite ccmp
security-ie rsn
interface WLAN-Radio1/0/1
interface WLAN-Radio1/0/2
 tunnel-type ipv4
 group enable
Related documentation
·     Network Connectivity Command Reference in H3C Access Points Cloud Mode Command References
·     Network Connectivity Configuration Guide in H3C Access Points Cloud Mode Configuration Guides
·     WLAN Access Command Reference in H3C Access Points Cloud Mode Command References
·     WLAN Access Configuration Guide in H3C Access Points Cloud Mode Configuration Guides
·     WLAN Roaming Command Reference in H3C Access Points Cloud Mode Command References
·     WLAN Roaming Configuration Guide in H3C Access Points Cloud Mode Configuration Guides
