07-VLAN Configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Routers Easy and Effortless Routing Feature Configuration Examples-6W10107-VLAN Configuration
02-Internet Access Through a Routing Protocol (CLI)
Introduction
The following information provides examples for configuring a routing protocol to implement Internet access for a switch.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is based on the assumption that you have basic knowledge of VLANs and static routes.
Configuration example
As shown in Figure 1, Host A and Host B are connected to the switch. Host A belongs to VLAN 2, and Host B belongs to VLAN 3. On the switch, the IP address of VLAN interface 1 is 192.168.1.254/24, the IP address of VLAN interface 2 is 192.168.2.1/24, and the IP address of VLAN interface 3 is 192.168.3.1/24. On the device, the IP address of VLAN interface 1 is 192.168.1.1/24. Configure the switch and the device to enable Host A and Host B to access the Internet.
Figure 1 Network diagram
Analysis
To allow Layer 3 forwarding between the device and the switch through VLAN interface 1:
·     Configure two static routes on the device: one route has a destination address of 192.168.2.0/24 and a next hop of 192.168.1.254, and the other route has a destination address of 192.168.3.0/24 and a next hop of 192.168.1.254.
·     Configure a default route with a next hop of 192.168.1.1 on the switch.
1.     Configure Host A and Host B:
# Assign IP address 192.168.2.2/24 to Host A, and configure its gateway address as 192.168.2.1/24. Assign IP address 192.168.3.2/24 to Host B, and configure its gateway address as 192.168.3.1/24.
2.     Configure the switch:
# Create VLAN 2 and VLAN 3.
<Switch> system-view
[Switch] vlan 2 to 3
# Assign GigabitEthernet 1/0/2 to VLAN 2.
[Switch-GigabitEthernet1/0/2] port access vlan 2
# Assign GigabitEthernet 1/0/3 to VLAN 3.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port access vlan 3
[Switch-GigabitEthernet1/0/3] quit
# Create VLAN interface 1, and assign IP address 192.168.1.254/24 to the interface.
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 192.168.1.254 255.255.255.0
[Switch-Vlan-interface1] quit
# Create VLAN interface 2, and assign IP address 192.168.2.1/24 to the interface.
[Switch-Vlan-interface2] ip address 192.168.2.1 255.255.255.0
[Switch-Vlan-interface2] quit
# Create VLAN interface 3, and assign IP address 192.168.3.1/24 to the interface.
[Switch-Vlan-interface3] ip address 192.168.3.1 255.255.255.0
[Switch-Vlan-interface3] quit
# Configure a default route.
[Switch] ip route-static 0.0.0.0 0.0.0.0 192.168.1.1
3.     Configure the device:
# Create VLAN interface 1, and assign IP address 192.168.1.1/24 to the interface.
[Device] vlan 1
[Device-vlan1] quit
[Device] interface vlan-interface 1
[Device-Vlan-interface1] ip address 192.168.1.1 255.255.255.0
[Device-Vlan-interface1] quit
# Configure two static routes.
[Device] ip route-static 192.168.2.0.0 255.255.255.0 192.168.1.254
[Device] ip route-static 192.168.3.0.0 255.255.255.0 192.168.1.254
Verify that both Host A and Host B can access the Internet.
Configuration files
·     Switch:
vlan 1
vlan 2
vlan 3
interface Vlan-interface1
interface Vlan-interface2
interface Vlan-interface3
 port link-mode bridge
 port access vlan 2
 port access vlan 3
 ip route-static 0.0.0.0 0 192.168.1.1
·     Device:
vlan 1
 ip route-static 192.168.2.0.0 24 192.168.1.254
 ip route-static 192.168.3.0.0 24 192.168.1.254
Related documentation
·     VLAN Configuration in H3C MSR Router Series Comware 7 Configuration Guides
·     VLAN Commands in H3C MSR Router Series Comware 7 Command References
·     Static Routing Configuration in H3C MSR Router Series Comware 7 Configuration Guides
·     Static Routing Commands in H3C MSR Router Series Comware 7 Command References
