04-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S6805 & S6825 & S6850 & S9850 Configuration Guides-Release 6715-6W10004-Layer 3—IP Services Configuration Guide
06-Fast forwarding configuration
06-Fast forwarding configuration 54.49 KB
Configuring fast forwarding
About fast forwarding
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields: source IP address, source port number, destination IP address, destination port number, and protocol number. After a flow's first packet is forwarded through the routing table, fast forwarding creates an entry and uses the entry to forward subsequent packets of the flow.
Restrictions and guidelines: Fast forwarding configuration
Fast forwarding can process fragmented IP packets, but it does not fragment IP packets.
Configuring the aging time for software fast forwarding entries
The fast forwarding table uses an aging timer for each forwarding entry. If an entry is not updated before the timer expires, the device deletes the entry. If an entry has a hit within the aging time, the aging timer restarts.
2.     Configure the aging time for fast forwarding entries on the software side.
ip fast-forwarding aging-time aging-time
By default, the aging time is 30 seconds for fast forwarding entries on the software side.
Configuring fast forwarding load sharing for software
Software fast forwarding load sharing enables the device to identify a data flow by using the packet information.
If fast forwarding load sharing is disabled on the software side, the device identifies a data flow by the packet information and the input interface.
2.     Configure fast forwarding load sharing on the software side. Choose one option as needed:
¡     Enable fast forwarding load sharing on the software side.
ip fast-forwarding load-sharing
¡     Disable fast forwarding load sharing on the software side.
undo ip fast-forwarding load-sharing
By default, fast forwarding load sharing is enabled on the software side.
Display and maintenance commands for fast forwarding
Display the aging time of fast forwarding entries.
display ip fast-forwarding aging-time
Display fast forwarding entries.
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
Display fast forwarding entries about fragmented packets.
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
Clear the fast forwarding table.
reset ip fast-forwarding cache [ slot slot-number ]
