- 04-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-IP forwarding basics configuration
- 06-Fast forwarding configuration
- 07-Adjacency table configuration
- 08-IRDP configuration
- 09-IP performance optimization configuration
- 10-UDP helper configuration
- 11-IPv6 basics configuration
- 12-DHCPv6 configuration
- 13-IPv6 fast forwarding configuration
- 14-Tunneling configuration
- 15-GRE configuration
- 16-HTTP redirect configuration
05-IP forwarding basics configuration | 139.85 KB |
Configuring IP forwarding basic settings························································ 1
About FIB table······························································································································· 1
Saving the IP forwarding entries to a file··························································································· 2
Enabling split horizon forwarding······································································································ 2
Enabling packet-drop statistics collection on interfaces····································································· 3
Enabling IPv4 packet forwarding on an interface with no IPv4 address configured······························ 3
Forwarding specific packets received from VXLAN tunnels in hardware·············································· 4
Enabling SNMP notifications for FIB events······················································································ 4
Enabling SNMP notifications for IP forwarding events······································································· 5
Display and maintenance commands for FIB table············································································ 5
Configuring load sharing··················································································· 6
About load sharing·························································································································· 6
Configuring load sharing mode········································································································ 6
Enabling per-packet load sharing on an interface·············································································· 7
Enabling IPv4 bandwidth-based load sharing···················································································· 7
Enabling local-first load sharing······································································································· 8
Enabling symmetric load sharing······································································································ 8
Configuring ACL rules for load sharing····························································································· 9
Display and maintenance commands for load sharing······································································· 9
Loading sharing configuration examples························································································· 10
Example: Configuring load sharing based on source and destination addresses························ 10
About FIB table
A device uses the FIB table to make packet forwarding decisions.
A device selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next hop IP address and output interface for packets destined for a specific subnet or host.
For more information about the routing table, see Layer 3—IP Routing Configuration Guide.
Use the display fib command to display the FIB table. The following example displays the entire FIB table.
<Sysname> display fib
Destination count: 8 FIB entry count: 8
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
0.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
127.255.255.255/32 127.0.0.1 UH InLoop0 Null
224.0.0.0/4 0.0.0.0 UB NULL0 Null
224.0.0.0/24 0.0.0.0 UB NULL0 Null
255.255.255.255/32 127.0.0.1 UH InLoop0 Null
A FIB entry includes the following items:
· Destination—Destination IP address.
· Mask—Network mask. The mask and the destination address identify the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask includes a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
· Nexthop—IP address of the next hop.
· Flag—Route flag.
· OutInterface—Output interface.
· Token—MPLS Label Switched Path index number.
· Label—Inner label.
The feature automatically creates the file if you specify a nonexistent file. If the file already exists, this feature overwrites the file content.
This feature triggers one-time saving of the IP forwarding entries.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
To save the IP forwarding entries to a file, execute the following command in any view:
ip forwarding-table save filename filename
This feature prevents IPv4, IPv6, and MPLS packets from being forwarded out of the physical interface on which they were received, avoiding network loops.
You can enable this feature globally in system view or enable this feature for a specific interface in interface view. This feature takes effect on an interface if it is enabled for the interface or enabled globally.
To disable this feature, you must disable it in both system view and interface view.
Procedure (System view)
1. Enter system view.
2. Enable split horizon forwarding.
forwarding split-horizon
By default, split horizon forwarding is disabled.
Procedure (Layer 3 interface view)
2. Enter Layer 3 interface view.
3. Enable split horizon forwarding.
Procedure (Layer 2 interface view)
This feature enables the device to collect statistics on specific packet drops on interfaces and report the statistics to the collector through gRPC.
This feature takes effect on only physical interfaces.
2. Enable the device to collect statistics on packets dropped on interfaces.
packet-drop statistics enable [ in-acl | out-acl | in-checksum | out-checksum | in-illegal-interface | in-l2-mtu | out-l2-mtu | in-l3-header | in-l3-header-ipv6 | in-l3-mtu | in-l3-nexthop | in-l3-rib | in-l3-rib-ipv6 | in-l3-ttl | in-stp-block | out-stp-block | in-same-interface | in-storm-suppression | in-vlan-mismatch | out-vlan-mismatch ] *
By default, the device does not count packet drops on interfaces.
On a device that supports both IPv4 and IPv6, the next hop of an IPv4 packet might be an IPv4 address or an IPv6 address. If the output interface has no IPv4 address configured, the interface cannot forward the IPv4 packet. To solve this problem, enable this feature on the interface. This feature allows the interface to forward IPv4 packets even though the interface has no IPv4 address configured.
2. Enter interface view.
3. Enable IPv4 packet forwarding on an interface that has no IPv4 address configured.
ip forwarding
By default, the IPv4 packet forwarding is disabled on the interface that has no IPv4 address configured.
By default, the device forwards packets received from VXLAN tunnels to the CPU for processing when acting as a VTEP in a distributed EVPN gateway network. If a large number of packets are received, packet loss might occur because of software rate limit, which might cause service exceptions on downlink devices.
To resolve this issue, you can enable the device to forward specific packets received from VXLAN tunnels in hardware without delivering them to the CPU.
2. Enable hardware forwarding for specific packets received from VXLAN tunnels.
forwarding vxlan-packet inner-protocol { ipv4 | ipv6 } *
By default, packets received from VXLAN tunnels are delivered to the CPU for processing.
This feature enables the FIB module to generate SNMP notifications for critical FIB events, such as the exceeding of the message queue length threshold. The SNMP notifications are sent to the SNMP module.
You can enable specific SNMP notifications for FIB events as needed. If you do not specify any SNMP notification types, the command enables all types of SNMP notifications.
· With ecmp-limit specified, when the number of ECMP routes learned by a module exceeds the upper limit, the device sends an SNMP notification that carries the module number to the SNMP module.
· With entry-consistency specified, if the FIB software and hardware entries on a module are inconsistent, the device sends an SNMP notification that carries the module number to the SNMP module.
· With entry-limit specified, when the number of FIB entries exceeds the upper limit, the device sends an SNMP notification that carries the FIB entry module name to the SNMP module.
· With deliver-failed specified, when FIB entry deployment to the hardware fails, the device sends an SNMP notification that carries the entry VRF, IP address type, IP address, mask, and failure reason to the SNMP module.
For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for FIB events.
snmp-agent trap enable fib [ deliver-failed | ecmp-limit | entry-consistency | entry-limit ] *
By default, SNMP notifications for FIB events are enabled.
This feature enables the IP forwarding module to generate SNMP notifications for critical IP forwarding events. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for IP forwarding events.
snmp-agent trap enable ip-forwarding
By default, SNMP notifications for IP forwarding events are enabled.
Task |
Command |
Display FIB entries. |
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ] |
Display FIB table usage information. |
display fib usage |
Display information about the ECMP groups stored in FIB. |
display fib ecmp-group [ group-id ] slot slot-number |
About load sharing
If a routing protocol finds multiple equal-cost best routes to the same destination, the device forwards packets over the equal-cost routes to implement load sharing.
In the per-flow load sharing mode, the device forwards flows over equal-cost routes. Packets of one flow travel along the same routes. You can configure the device to identify a flow based on the following criteria: source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port.
In a complex network, when the traffic is not load shared equally, you can use the algorithm keyword to specify an algorithm to improve the load sharing.
When load-sharing (ip load-sharing mode) and Rail-Group are configured at the same time, Rail-Group will take precedence. In other words, under this circumstance, the traffic on interfaces in the Rail-Group will be load-shared according to the Rail-Group configuration, and the traffic on other interfaces will be load-shared according to the IP load-sharing configuration. For more information about Rail-Group, see Ethernet interface configuration in Interface Configuration Guide.
2. Configure load sharing.
ip load-sharing mode { per-flow [ algorithm algorithm-number [ seed seed-number ] [ shift shift-number ] | [ dest-ip | dest-port | flow-label | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { all | inner | outer } ] | per-packet } { global | slot slot-number }
By default, the device performs per-flow load sharing based on the following criteria: source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port.
3. Display the load sharing path selected for a flow.
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address | flow-label flow-label ] } [ dest-port port-id | ip-pro protocol-id | src-port port-id ] *
The option settings in this command must match both the options displayed in the display ip load-sharing mode command and the field values in load shared packets. If the option settings do not meet the requirement, the path displayed by this command might be different from the real path for load sharing.
In scenarios where service traffic and packets are forwarded through fixed interfaces, per-packet load sharing has higher performance than per-flow load sharing. When per-flow load sharing applies globally, you can use this feature to enable per-packet load sharing on specific interfaces and set the load sharing algorithm for device performance test purposes. In per-packet load sharing, the robin algorithm does not consider the packet size, but the spray algorithm considers the size of different packets to achieve a more balanced load. If you do not specify an algorithm, the spray algorithm is used by default.
With this feature configured, the interfaces do not inherit the load sharing settings configured in system view.
This feature takes effect only when all Layer 3 interfaces on an equal-cost route are enabled this feature.
Per-packet load sharing is supported only when the ECMP mode is normal (undo ecmp mode). For more information about ECMP, see basic IP routing commands in Layer 3 — IP Routing Command Reference.
When you configure per-packet load sharing, make sure equal-cost route's outbound interface is a Layer 3 Ethernet interface, Layer 3 Ethernet subinterface, or VLAN interface. If the multiple outbound interfaces configured with this feature contain an aggregate interface, this feature does not take effect.
In an IRF fabric, if the traffic requires forwarding across member devices, the specified spray algorithm does not take effect.
The spray algorithm supports a maximum of 64 equal-cost routes, and the robin algorithm supports a maximum of 128 equal-cost routes.
3. Enable per-packet load sharing on the interface.
ip load-sharing mode per-packet [ robin | spray ]
By default, no load sharing mode is specified on an interface. The interface uses the load sharing settings configured in system view.
This feature load shares flow traffic among multiple output interfaces based on their load percentages. The device calculates the load percentage for each output interface in terms of the interface expected bandwidth.
Devices that run load sharing protocols, such as Locator/ID Separation Protocol (LISP), implement load sharing based on the ratios defined by these protocols.
This feature is mutually exclusive with enhanced ECMP mode, which is configured by using the ecmp mode enhanced command.
After you configure this feature, make sure the expected bandwidth of the interface does not exceed the physical bandwidth of the interface.
2. Enable IPv4 bandwidth-based load sharing.
bandwidth-based-sharing
By default, the IPv4 bandwidth-based load sharing is disabled.
3. (Optional.) Configure the expected bandwidth of the interface.
a. Enter interface view.
b. Configure the expected bandwidth of the interface.
bandwidth bandwidth
By default, the expected bandwidth is the physical bandwidth of the interface.
Local-first load sharing distributes traffic preferentially across the output interfaces on the receiving IRF member device if output interfaces for multiple equal-cost routes are on different members. This feature enhances packets forwarding efficiency.
2. Enable local-first load sharing.
ip load-sharing local-first enable
By default, local-first load sharing is enabled.
Symmetric load sharing ensures that bidirectional traffic specific to a source and destination address pair flow along the same path.
Symmetric load sharing can take effect only after you use the ip load-sharing mode command to configure the device to perform 5-Tuple-based load sharing. The 5-Tuple includes source IP address, destination IP address, source port number, destination port number, and IP protocol number. If you do not use the ip load-sharing mode command, the device uses the default load sharing mode. In this mode, the packet ingress port is included in load sharing calculation and symmetric load sharing does not take effect.
After you execute the ip load-sharing symmetric enable command, symmetric load sharing also takes effect for aggregate interfaces.
2. Enable symmetric load sharing.
By default, symmetric load sharing is disabled.
In a RoCE network, using ACL rules defined by the driver hardware can automatically identify protocol packets and data packets. This allows protocol packets to be load-shared on a per-flow basis to maintain the packet sequence, and data packets to be load-shared on a per-packet basis to achieve a more even load-sharing effect.
If you execute this command without specifying any parameters, the ACL rules customized by the driver hardware are used.
· You can configure IPv4 and IPv6 ACL rules in one execution or through multiple executions.
· If the ACL rules to be issued from the CLI are not configured, the system does not issue ACL rules to the driver hardware. After the user-defined ACL rules are created, the system issues the ACL rules to the driver hardware. After the ACL rules are deleted, the system notifies the driver hardware to delete the ACL rules.
· If you do not specify any ACL rules when executing the undo ip load-sharing acl command, the command deletes all ACL rule reference relations.
· After an ACL rule is issued to the driver hardware, packets that do not match the configured ACL rule is load-shared in dynamic loadshare balance (DLB) mode. For packets matching the ACL rule, the non-DLB mode is used. For more information about DLB, see the ecmp mode command.
2. Configure the ACL rule for load sharing.
ip load-sharing acl [ { ipv4 { ipv4-acl-number | name ipv4-acl-name } | ipv6 { ipv6-acl-number | name ipv6-acl-name } }* | user-defined { user-define-acl-number | name user-define-acl-name } ]
By default, no ACL rule is configured.
Task |
Command |
Display the load sharing mode in use. |
display ip load-sharing mode slot slot-number |
Display the load sharing path selected for a flow. |
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address | flow-label flow-label ] } [ dest-port port-id | ip-pro protocol-id | src-port port-id ] * |
As shown in Figure 1, Switch A has two equal-cost routes to Switch B. Configure load sharing on Switch A to forward packets through Switch B to the destination IP address 1.2.3.4/24.
# On Switch A, assign Twenty-FiveGigE 1/0/1 to VLAN 10, and Twenty-FiveGigE 1/0/2 to VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] port twenty-fivegige 1/0/1
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] port twenty-fivegige 1/0/2
[SwitchA-vlan20] quit
# On Switch A, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 10.1.1.1 24
[SwitchA-Vlan-interface20] ip address 20.1.1.1 24
# On Switch B, assign Twenty-FiveGigE 1/0/1 to VLAN 10, and Twenty-FiveGigE 1/0/2 to VLAN 20.
[SwitchB] vlan 10
[SwitchB-vlan10] port twenty-fivegige 1/0/1
[SwitchB-vlan10] quit
[SwitchB] vlan 20
[SwitchB-vlan20] port twenty-fivegige 1/0/2
[SwitchB-vlan20] quit
# On Switch B, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchB-Vlan-interface10] ip address 10.1.1.2 24
[SwitchB] interface vlan-interface 20
[SwitchB-Vlan-interface20] ip address 20.1.1.2 24
[SwitchB-Vlan-interface20] quit
# On Switch A, configure two static routes to the destination IP address.
[SwitchA] ip route-static 1.2.3.4 24 10.1.1.2
[SwitchA] ip route-static 1.2.3.4 24 20.1.1.2
[SwitchA] quit
# On Switch A, display FIB entries matching the destination IP address 1.2.3.4.
<SwitchA> display fib 1.2.3.4
Destination count: 1 FIB entry count: 2
Flag:
R:Relay F:FRR
1.2.3.0/24 10.1.1.2 USGR Vlan10 Null
1.2.3.0/24 20.1.1.2 USGR Vlan20 Null
# On Switch A, configure per-flow load sharing based on the source IP address and destination IP address.
[SwitchA] ip load-sharing mode per-flow dest-ip src-ip global
# Verify that Switch A implements load sharing.
<SwitchA> display counters outbound interface GigabitEthernet
Interface Total (pkts) Broadcast (pkts) Multicast (pkts) Err (pkts)
WGE1/0/1 1045 0 0 0
WGE1/0/2 1044 0 0 0
