- 14-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-IPv6 static routing configuration
- 04-RIP configuration
- 05-RIPng configuration
- 06-OSPF configuration
- 07-OSPFv3 configuration
- 08-IS-IS configuration
- 09-BGP configuration
- 10-Policy-based routing configuration
- 11-IPv6 policy-based routing configuration
- 12-Routing policy configuration
- 13-Guard route configuration
- 14-RIR configuration
| 09-BGP configuration | 1.80 MB |
Settlements for problems in large-scale BGP networks
Basic BGP network configuration tasks at a glance (IPv4 unicast/IPv4 multicast)
Basic BGP network configuration tasks at a glance (IPv6 unicast/IPv6 multicast)
Configuring an IBGP peer group
Configuring an EBGP peer group
Specifying the source address of TCP connections
Controlling BGP route generation
Configuring BGP route summarization
Advertising a default route to a peer or peer group
Controlling BGP route advertisement
Advertising optimal routes in the IP routing table
Configuring BGP route distribution filtering policies
Configuring BGP route update delay
Controlling BGP route reception
Limiting routes received from a peer or peer group
Configuring BGP route reception filtering policies
Configuring the keepalive interval and hold time
Setting the session retry timer
Configuring the interval for sending updates for the same route
Configuring BGP logging and notifications
Enabling logging for session state changes
Configuring BGP network management
Display and maintenance commands for basic BGP network building
Basic IPv4 BGP network configuration examples
Example: Configuring basic BGP
Basic IPv6 BGP network configuration examples
Example: Configuring IPv6 basic BGP
State of the connection to a peer cannot become established
Configuring large-scale BGP networks
Large-scale BGP network configuration tasks at a glance
Configuring BGP route dampening
Configuring BGP route reflection
Configuring a BGP route reflector
Ignoring the ORIGINATOR_ID attribute
Configuring BGP confederation settings
Configuring a BGP confederation
Configuring confederation compatibility
Display and maintenance commands for large-scale BGP network configuration
Controlling BGP path selection
BGP path selection control tasks at a glance
Configuring preferences for BGP routes
Configuring the NEXT_HOP attribute
Setting a preferred value for received routes
Configuring the default local preference
Configuring the AS_PATH attribute
Permitting local AS number to appear in routes from a peer or peer group
Ignoring the AS_PATH attribute during optimal route selection
Advertising a fake AS number to a peer or peer group
Configuring AS number substitution
Removing private AS numbers from sent updates
Ignoring the first AS number of EBGP route updates
Configuring the default MED value
Enabling MED comparison for routes from different ASs
Enabling MED comparison for routes on a per-AS basis
Enabling MED comparison for routes from confederation peers
Preferring routes learned from a peer or peer group during optimal route selection
Ignoring IGP metrics during optimal route selection
Ignoring router IDs during optimal route selection
Display and maintenance commands for BGP path selection control
Tuning and optimizing BGP networks
BGP network tuning and optimization tasks at a glance
Enabling BGP to establish an EBGP session over multiple hops
Enabling immediate re-establishment of direct EBGP connections upon link failure
Enabling 4-byte AS number suppression
Disabling BGP session establishment
About disabling BGP session establishment
Enabling route refresh (IPv4 unicast/multicast address family)
Enabling route refresh (IPv6 unicast/multicast address family)
Saving updates (IPv4 unicast/multicast address family)
Saving updates (IPv6 unicast/multicast address family)
Configuring manual soft-reset (IPv4 unicast/multicast address family)
Configuring manual soft-reset (IPv6 unicast/multicast address family)
Configuring BGP load balancing
Configuring the BGP Additional Paths feature
Protecting an EBGP peer when memory usage reaches level 2 threshold
Specifying the longest match principle for next hop recursion
Flushing the suboptimal BGP route to the RIB
Disabling BGP from flushing specific routes to the routing table
Specifying a label allocation mode
Recursing unlabeled public BGP routes to LSPs
Display and maintenance commands for BGP network tuning and optimization
Configuring BGP security features
BGP security feature configuration tasks at a glance
Enabling MD5 authentication for BGP peers
Enabling keychain authentication for BGP peers
Configuring IPsec for IPv6 BGP
Improving BGP network reliability
BGP network reliability improvement tasks at a glance
Configuring BGP FRR by using a routing policy (IPv4 unicast address family)
Configuring BGP FRR by using a routing policy (IPv6 unicast address family)
Configuring BGP FRR through PIC (IPv4 unicast address family)
Configuring BGP FRR through PIC (IPv6 unicast address family)
Configuring BFD-powered nexthop connectivity detection for BGP FRR
Configuring BGP maintenance features
About BGP maintenance features
Display and maintenance commands for BGP network reliability improvement
Configuring extended BGP features
Extended BGP feature configuration tasks at a glance
Configuring BGP LS route reflection
Specifying an AS number and a router ID for BGP LS messages
Performing manual soft-reset for BGP sessions of LS address family
Display and maintenance commands for extended BGP features
BGP overview
Border Gateway Protocol (BGP) is an exterior gateway protocol (EGP). It is called internal BGP (IBGP) when it runs within an AS and called external BGP (EBGP) when it runs between ASs. The current version in use is BGP-4 (RFC 4271).
BGP characteristics
BGP has the following characteristics:
· Focuses on route control and selection rather than route discovery and calculation.
· Uses TCP to enhance reliability.
· Measures the distance of a route by using a list of ASs that the route must travel through to reach the destination. BGP is also called a path-vector protocol.
· Supports CIDR.
· Reduces bandwidth consumption by advertising only incremental updates. BGP is very suitable to advertise large numbers of routes on the Internet.
· Eliminates routing loops by adding AS path information to BGP route updates.
· Uses policies to implement flexible route filtering and selection.
· Has good scalability.
BGP speaker and BGP peer
A router running BGP is a BGP speaker. A BGP speaker establishes peer relationships with other BGP speakers to exchange routing information over TCP connections.
BGP peers include the following types:
· IBGP peers—Reside in the same AS as the local router.
· EBGP peers—Reside in different ASs from the local router.
BGP message types
BGP uses the following message types:
· Open—After establishing a TCP connection, BGP sends an OPEN message to establish a session to the peer.
· Update—BGP sends UPDATE messages to exchange routing information between peers. Each UPDATE message can advertise a group of feasible routes with identical attributes and multiple withdrawn routes.
· Keepalive—BGP sends KEEPALIVE messages between peers to maintain connectivity.
· Route-refresh—BGP sends a ROUTE-REFRESH message to request the routing information for a specific address family from a peer.
· Notification—BGP sends a NOTIFICATION message upon detecting an error and immediately closes the connection.
BGP finite state machine
During session establishment, the devices at the two ends transition between different BGP states, as shown in Figure 1.
Figure 1 BGP finite state machine
Idle
This state is the initial BGP state. In this state, BGP rejects any connection requests. Only upon receiving a Start event, the device assigns resources to BGP, and attempts to establish a TCP connection and transition to Connect state.
BGP transitions to Idle state from the remaining states upon a TCP disconnection error, packet error, connection closed due to configuration issues, and reception of a NOTIFICATION message.
Connect
In this state, BGP starts a Connect Retry timer and waits for TCP connection establishment to be completed.
· If TCP connection establishment succeeds before the Connect Retry timer expires, BGP closes the Connect Retry timer, sends an OPEN message to the peer, and transitions to OpenSent state.
· If TCP connection establishment fails before the Connect Retry timer expires, BGP transitions to Active state.
· If the Connect Retry timer expires, and no connection response is received, BGP resets the Connect Retry timer, tries to establish a TCP connection with the peer again, and stays in Connect state.
Active
In this state, BGP continuously attempts to establish a TCP connection.
· If TCP connection establishment succeeds, BGP closes the Connect Retry timer, sends an OPEN message to the peer, and transitions to OpenSent state.
· If TCP connection establishment fails, BGP resets the Connect Retry timer and stays in Active state.
· If the Connect Retry timer expires and no connection response is received, BGP resets the Connect Retry timer and transitions to Connect state.
OpenSent
In this state, BGP waits for an OPEN message from the peer, and checks the BGP version number and AS number in the OPEN message.
· If the OPEN message is correct, BGP sends a KEEPALIVE message to the peer, and transitions to OpenConfirm state.
· If the OPEN message is incorrect, BGP sends a NOTIFICATION message to the peer, and transitions to Idle state.
If the TCP connection is disconnected in this state, BGP resets the Connect Retry timer, transitions to Active state, and tries to establish a TCP connection again.
OpenConfirm
In this state, BGP waits for a KEEPALIVE or NOTIFICATION message.
· Upon receiving a KEEPALIVE message, BGP transitions to Established state.
· Upon receiving a NOTIFICATION message, BGP transitions to Idle state.
Established
In this state, BGP can exchange UPDATE, KEEPALIVE, ROUTE-REFRESH, and NOTIFICATION messages with the peer.
· Upon receiving a correct UPDATE or KEEPALIVE message, BGP stays in Established state.
· Upon receiving an incorrect UPDATE or KEEPALIVE message, BGP sends a NOTIFICATION message to the peer and transitions to Idle state.
· Upon receiving a ROUTE-REFRESH message, BGP does not change its state.
BGP path attributes
BGP uses the following path attributes in UPDATE messages for route filtering and selection:
ORIGIN
The ORIGIN attribute specifies the origin of BGP routes. This attribute has the following types:
· IGP—Has the highest priority. Routes generated in the local AS have the IGP attribute.
· EGP—Has the second highest priority. Routes obtained through EGP have the EGP attribute.
· INCOMPLETE—Has the lowest priority. The source of routes with this attribute is unknown. Routes redistributed from other routing protocols have the INCOMPLETE attribute.
AS_PATH
The AS_PATH attribute identifies the ASs through which a route has passed. Before advertising a route to another AS, BGP adds the local AS number into the AS_PATH attribute, so the receiver can determine ASs to route the message back.
The AS_PATH attribute has the following types:
· AS_SEQUENCE—Arranges AS numbers in sequence. As shown in Figure 2, the number of the AS closest to the receiver's AS is leftmost.
· AS_SET—Arranges AS numbers randomly.
Figure 2 AS_PATH attribute
BGP uses the AS_PATH attribute to implement the following functions:
· Avoid routing loops—A BGP router does not receive routes containing the local AS number to avoid routing loops.
· Affect route selection—BGP gives priority to the route with the shortest AS_PATH length if other factors are the same. As shown in Figure 2, the BGP router in AS 50 gives priority to the route passing AS 40 for sending data to the destination 8.0.0.0. In some applications, you can apply a routing policy to control BGP route selection by modifying the AS_PATH length. For more information about routing policy, see "Configuring routing policies."
· Filter routes—By using an AS path list, you can filter routes based on AS numbers contained in the AS_PATH attribute. For more information about AS path list, see "Configuring routing policies."
NEXT_HOP
The NEXT_HOP attribute may not be the IP address of a directly connected router. Its value is determined as follows:
· When a BGP speaker advertises a self-originated route to a BGP peer, it sets the address of the sending interface as the NEXT_HOP.
· When a BGP speaker sends a received route to an EBGP peer, it sets the address of the sending interface as the NEXT_HOP.
· When a BGP speaker sends a route received from an EBGP peer to an IBGP peer, it does not modify the NEXT_HOP attribute. If load balancing is configured, BGP modifies the NEXT_HOP attribute for the equal-cost routes. For load balancing information, see "BGP load balancing."
MED (MULTI_EXIT_DISC)
BGP advertises the MED attribute between two neighboring ASs, each of which does not advertise the attribute to any other AS.
Similar to metrics used by IGPs, MED is used to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it selects the route with the smallest MED value as the optimal route. As shown in Figure 4, traffic from AS 10 to AS 20 travels through Router B that is selected according to MED.
Figure 4 MED attribute
Generally BGP only compares MEDs of routes received from the same AS. You can also use the compare-different-as-med command to force BGP to compare MED values of routes received from different ASs.
LOCAL_PREF
The LOCAL_PREF attribute is exchanged between IBGP peers only, and is not advertised to any other AS. It indicates the priority of a BGP router.
BGP uses LOCAL_PREF to determine the optimal route for traffic leaving the local AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it selects the route with the highest LOCAL_PREF value as the optimal route. As shown in Figure 5, traffic from AS 20 to AS 10 travels through Router C that is selected according to LOCAL_PREF.
Figure 5 LOCAL_PREF attribute
COMMUNITY
The COMMUNITY attribute identifies the community of BGP routes. A BGP community is a group of routes with the same characteristics. It has no geographical boundaries. Routes of different ASs can belong to the same community.
A route can carry one or more COMMUNITY attribute values (each of which is represented by a 4-byte integer). A router uses the COMMUNITY attribute to determine whether to advertise the route and the advertising scope without using complex filters such as ACLs. This mechanism simplifies routing policy configuration, management, and maintenance.
Well-known COMMUNITY attributes involve the following:
· INTERNET—By default, all routes belong to the Internet community. Routes with this attribute can be advertised to all BGP peers.
· NO_EXPORT—Routes with this attribute cannot be advertised out of the local AS or out of the local confederation, but can be advertised to other sub-ASs in the confederation. For confederation information, see "Settlements for problems in large-scale BGP networks."
· No_ADVERTISE—Routes with this attribute cannot be advertised to other BGP peers.
· No_EXPORT_SUBCONFED—Routes with this attribute cannot be advertised out of the local AS or other sub-ASs in the local confederation.
You can configure BGP community lists to filter BGP routes based on the BGP COMMUNITY attribute.
Extended community attribute
To meet new demands, BGP defines the extended community attribute. The extended community attribute has the following advantages over the COMMUNITY attribute:
· Provides more attribute values by extending the attribute length to eight bytes.
· Allows for using different types of extended community attributes in different scenarios to enhance route filtering and control and simplify configuration and management.
The device supports the following extended community attributes: route target, Site of Origin (SoO), color, and Priority-Color.
The SoO attribute specifies the site where the route originated. It prevents advertising a route back to the originating site. If the AS-path attribute is lost, the router can use the SoO attribute to avoid routing loops.
The SoO attribute has the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 100:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
BGP route selection
BGP discards routes with unreachable NEXT_HOPs. If multiple routes to the same destination are available, BGP selects the optimal route in the following sequence:
1. The route with the highest Preferred_value.
2. The route with the highest LOCAL_PREF.
3. The route generated by the network command, the route redistributed by the import-route command, or the summary route in turn.
4. The route with the shortest AS_PATH.
5. The IGP, EGP, or INCOMPLETE route in turn.
6. The route with the lowest MED value.
7. The route learned from EBGP, confederation EBGP, confederation IBGP, or IBGP in turn.
8. The route with the smallest IGP metric.
9. The route with the smallest recursion depth.
10. If a route received from an EBGP peer is the current optimal route, BGP does not change the optimal route when it receives routes from other EBGP peers.
11. The route advertised by the router with the smallest router ID.
If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routers. Then, BGP selects the route with the smallest ID as the optimal route.
12. The route with the shortest CLUSTER_LIST.
13. The route advertised by the peer with the lowest IP address.
The CLUSTER_IDs of route reflectors form a CLUSTER_LIST. If a route reflector receives a route that contains its own CLUSTER ID in the CLUSTER_LIST, the router discards the route to avoid routing loops.
If load balancing is configured, the system selects available routes to implement load balancing.
BGP route advertisement rules
BGP follows these rules for route advertisement:
· When multiple feasible routes to a destination exist, BGP advertises only the optimal route to its peers. If the advertise-rib-active command is configured, BGP advertises the optimal route in the IP routing table. If not, BGP advertises the optimal route in the BGP routing table.
· BGP advertises only routes that it uses.
· BGP advertises routes learned from an EBGP peer to all BGP peers, including both EBGP and IBGP peers.
· BGP advertises routes learned from an IBGP peer to EBGP peers, rather than other IBGP peers.
· After establishing a session to a new BGP peer, BGP advertises all the routes matching the above rules to the peer. After that, BGP advertises only incremental updates to the peer.
BGP load balancing
BGP load balancing is applicable between EBGP peers, between IBGP peers, and between confederations.
BGP implements load balancing through route recursion and route selection.
BGP load balancing through route recursion
The next hop of a BGP route might not be directly connected. One of the reasons is that the next hop information exchanged between IBGP peers is not modified. The BGP router must find the directly connected next hop through IGP. The matching route with the direct next hop is called the recursive route. The process of finding a recursive route is route recursion.
If multiple recursive routes to the same destination are load balanced, BGP generates the same number of next hops to forward packets.
BGP load balancing based on route recursion is always enabled in the system.
BGP load balancing through route selection
IGP routing protocols, such as RIP and OSPF, can use route metrics as criteria to load balance between routes that have the same metric. BGP cannot load balance between routes by route metrics as an IGP protocol does, because BGP does not have a route computation algorithm.
BGP uses the following load balancing criteria to determine load balanced routes:
· The routes have the same ORIGIN, LOCAL_PREF, and MED attributes.
· The routes meet the following requirements on the AS_PATH attribute:
¡ If the balance as-path-neglect command is configured, the routes can have different AS_PATH attributes.
¡ If only the balance as-path-relax command is configured, the routes can have different AS_PATH attributes, but the length of the AS_PATH attributes must be the same.
¡ If neither the balance as-path-neglect nor the balance as-path-relax command is configured, the routes must have the same AS_PATH attribute.
· The next hops of the routes meet the following requirements on IGP metrics:
¡ If the bestroute igp-metric-ignore command is not configured, the next hops of the routes must have the same IGP metric value.
¡ If the bestroute igp-metric-ignore command is configured, the next hops of the routes can have different IGP metric values.
BGP does not use the route selection rules described in "BGP route selection" for load balancing.
As shown in Figure 6, Router A and Router B are IBGP peers of Router C. Router C allows a maximum number of two ECMP routes for load balancing.
Router D and Router E both advertise a route 9.0.0.0 to Router C. Router C installs the two routes to its routing table for load balancing if the routes meet the BGP load balancing criteria. After that, Router C forwards to Router A and Router B a single route whose attributes are changed as follows:
· AS_PATH attribute:
¡ If the balance as-path-neglect and balance as-path-relax commands are not configured, the AS_PATH attribute does not change.
¡ If the balance as-path-neglect or balance as-path-relax command is configured, the AS_PATH attribute is changed to the attribute of the optimal route.
· The NEXT_HOP attribute is changed to the IP address of Router C.
· Other attributes are changed to be the same as the optimal route.
You can use the following methods to facilitate management and improve route distribution efficiency on a large-scale BGP network.
Route summarization
Route summarization can reduce the BGP routing table size by advertising summary routes rather than more specific routes.
The system supports both manual and automatic route summarization. Manual route summarization allows you to determine the attribute of a summary route and whether to advertise more specific routes.
Route dampening
Route flapping (a route comes up and disappears in the routing table frequently) causes BGP to send many routing updates. It can consume too many resources and affect other operations.
In most cases, BGP runs in complex networks where route changes are more frequent. To solve the problem caused by route flapping, you can use BGP route dampening to suppress unstable routes.
BGP route dampening uses a penalty value to judge the stability of a route. The bigger the value, the less stable the route. Each time a route state changes from reachable to unreachable, or a reachable route's attribute changes, BGP adds a penalty value of 1000 to the route. When the penalty value of the route exceeds the suppress value, the route is suppressed and cannot become the optimal route. When the penalty value reaches the upper limit, no penalty value is added.
If the suppressed route does not flap, its penalty value gradually decreases to half of the suppress value after a period of time. This period is called "Half-life." When the value decreases to the reusable threshold value, the route is usable again.
Figure 7 BGP route dampening
Peer group
You can organize BGP peers with the same attributes into a group to simplify their configurations.
When a peer joins the peer group, the peer obtains the same configuration as the peer group. If the configuration of the peer group is changed, the configuration of group members is changed.
Community
You can apply a community list or an extended community list to a routing policy for route control. For more information, see "BGP path attributes."
Route reflector
IBGP peers must be fully meshed to maintain connectivity. If n routers exist in an AS, the number of IBGP connections is n(n-1)/2. If a large number of IBGP peers exist, large amounts of network and CPU resources are consumed to maintain sessions.
Using route reflectors can solve this issue. In an AS, a router acts as a route reflector, and other routers act as clients connecting to the route reflector. The route reflector forwards routing information received from a client to other clients. In this way, all clients can receive routing information from one another without establishing BGP sessions.
A router that is neither a route reflector nor a client is a non-client, which, as shown in Figure 8, must establish BGP sessions to the route reflector and other non-clients.
Figure 8 Network diagram for a route reflector
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the Cluster_ID. You can configure more than one route reflector in a cluster to improve availability, as shown in Figure 9. The configured route reflectors must have the same Cluster_ID to avoid routing loops.
Figure 9 Network diagram for route reflectors
When the BGP routers in an AS are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use commands to disable route reflection instead of modifying network configuration or changing network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
Confederation
Confederation is another method to manage growing IBGP connections in an AS. It splits an AS into multiple sub-ASs. In each sub-AS, IBGP peers are fully meshed. As shown in Figure 10, intra-confederation EBGP connections are established between sub-ASs in AS 200.
Figure 10 Confederation network diagram
A non-confederation BGP speaker does not need to know sub-ASs in the confederation. To the BGP speaker, the confederation is one AS and the confederation ID is the AS number. In the above figure, AS 200 is the confederation ID.
Confederation has a deficiency. When you change an AS into a confederation, you must reconfigure the routers, and the topology will be changed.
In large-scale BGP networks, you can use both route reflector and confederation.
MP-BGP
Supported address families
BGP-4 can only advertise IPv4 unicast routing information. Multiprotocol Extensions for BGP-4 (MP-BGP) can advertise routing information for the following address families:
· IPv6 unicast address family.
· IPv4 multicast address family and IPv6 multicast address family.
PIM uses static and dynamic unicast routes to perform RPF check before creating multicast routing entries. When the multicast and unicast topologies are different, you can use MP-BGP to advertise the routes for RPF check. MP-BGP stores the routes in the BGP multicast routing table. For more information about PIM and RPF check, see IP Multicast Configuration Guide.
· VPNv4 address family and VPNv6 address family.
MP-BGP extended attributes
Prefixes and next hops are key routing information. BGP-4 uses UPDATE messages to carry the following information:
· Feasible route prefixes in the Network Layer Reachability Information (NLRI) field.
· Unfeasible route prefixes in the withdrawn routes field.
· Next hops in the NEXT_HOP attribute.
BGP-4 cannot carry routing information for multiple network layer protocols.
To support multiple network layer protocols, MP-BGP defines the following path attributes:
· MP_REACH_NLRI—Carries feasible route prefixes and next hops for multiple network layer protocols.
· MP_UNREACH_NLRI—Carries unfeasible route prefixes for multiple network layer protocols.
MP-BGP uses these two attributes to advertise feasible and unfeasible routes for different network layer protocols. BGP speakers not supporting MP-BGP ignore updates containing these attributes and do not forward them to its peers.
Address family
MP-BGP uses address families and subsequent address families to identify different network layer protocols for routes contained in the MP_REACH_NLRI and MP_UNREACH_NLRI attributes. For example, an Address Family Identifier (AFI) of 2 and a Subsequent Address Family Identifier (SAFI) of 1 identify IPv6 unicast routing information carried in the MP_REACH_NLRI attribute. For address family values, see RFC 1700.
Exchanging IPv4 and IPv6 routes in both IPv4 and IPv6 address families
MP-BGP supports IPv4 route exchange between IPv6 peers and IPv6 route exchange between IPv4 peers as follows:
· When the next hop of an IPv6 route is an IPv4 address, MP-BGP maps the IPv4 address to an IPv6 address encapsulated in the NEXT_HOP attribute of update messages. In this scenario, you must specify a routing policy to change the next hop of the IPv6 route to the IPv6 address of the peer.
· When the next hop of an IPv4 route is an IPv6 address, BGP negotiates the extended next hop encoding capability with its peer. Then, BGP encapsulates the IPv4 NLRI in the MP_REACH_NLRI attribute of update messages. In this scenario, you must specify a routing policy to change the next hop of the IPv4 route to the IPv4 address of the peer.
Figure 11 Exchanging IPv4 and IPv6 routes in both IPv4 and IPv6 address families
As shown in Figure 11, an IPv6 BGP peer relationship is established between Device A and Device B, between Device B and Device C, and between Device C and Device D. An IPv4 BGP peer relationship is established between Device A and Device B and between Device C and Device D. Device A and Device D can learn both IPv4 and IPv6 routes from each other and traffic is forwarded correctly in both IPv4 and IPv6 address families. For Device C to correctly receive IPv4 routes using the IPv6 address of Device B as the next hop, configure a routing policy on Device C. Use the routing policy to change the next hop of these routes to the IPv4 address of Device B.
BGP multi-instance
A BGP router can run multiple BGP processes. Each BGP process corresponds to a BGP instance. BGP maintains an independent routing table for each BGP instance.
When you create multiple BGP instances, follow these restrictions and guidelines:
· You can create multiple public address families for a BGP instance. However, each public address family (except for IPv4 unicast address family, IPv6 unicast address family, VPNv4 address family, and VPNv6 address family) can belong to only one BGP instance.
· You can create multiple VPN instances for a BGP instance, and each VPN instance can have multiple address families. A VPN instance can belong to only one BGP instance.
· On the public network, a peer address can establish a session to only one BGP instance. Multiple BGP instances cannot synchronously establish sessions to the same peer address.
· The IPv4 and IPv6 multicast address families must belong to the same BGP instance.
· Different BGP instances can have the same AS number but cannot have the same name.
BGP configuration views
BGP uses different views to manage routing information for different BGP instances, VPN instances, and address families. Most BGP commands are available in all BGP views. BGP supports multiple VPN instances by establishing a separate routing table for each VPN instance.
Table 1 describes different BGP configuration views.
Table 1 BGP configuration views
View names |
Ways to enter the views |
Remarks |
BGP instance view |
You can create a BGP instance and enter its view by specifying the instance keyword in the bgp command. Configurations in this view apply to all public address families for the specified BGP instance. Some configurations (such as confederation, GR, and logging configurations) also apply to the address families of VPN instances. |
BGP IPv4 unicast address family view |
Configurations in this view apply to public IPv4 unicast routes and peers of the specified BGP instance. |
BGP IPv6 unicast address family view |
Configurations in this view apply to public IPv6 unicast routes and peers of the specified BGP instance. |
BGP IPv4 multicast address family view |
Configurations in this view apply to IPv4 multicast routes and peers of the specified BGP instance. |
BGP IPv6 multicast address family view |
Configurations in this view apply to IPv6 multicast routes and peers of the specified BGP instance. |
BGP VPNv4 address family view |
Configurations in this view apply to VPNv4 routes and peers of the specified BGP instance. |
BGP VPNv6 address family view |
Configurations in this view apply to VPNv6 routes and peers of the specified BGP instance. |
BGP-VPN instance view |
Configurations in this view apply to all address families in the specified VPN instance of the specified BGP instance. |
BGP-VPN IPv4 unicast address family view |
Configurations in this view apply to IPv4 unicast routes and peers in the specified VPN instance of the specified BGP instance. |
BGP-VPN IPv6 unicast address family view |
Configurations in this view apply to IPv6 unicast routes and peers in the specified VPN instance of the specified BGP instance. |
BGP IPv4 MVPN address family view |
Configurations in this view apply to MVPN routes and peers of the specified BGP instance. |
BGP LS address family view |
Configurations in this view apply to LS messages and peers of the specified BGP instance. |
BGP IPv4 RT filter address family view |
Configurations in this view apply to IPv4 RT filter routes and peers of the specified BGP instance. |
Protocols and standards
· RFC 1700, ASSIGNED NUMBERS
· RFC 1997, BGP Communities Attribute
· RFC 2439, BGP Route Flap Damping
· RFC 2545, Use of BGP-4 Multiprotocol Extensions for IPv6 Inter-Domain Routing
· RFC 2918, Route Refresh Capability for BGP-4
· RFC 3107, Carrying Label Information in BGP-4
· RFC 4271, A Border Gateway Protocol 4 (BGP-4)
· RFC 4275, BGP-4 MIB Implementation Survey
· RFC 4277, Experience with the BGP-4 Protocol
· RFC 4360, BGP Extended Communities Attribute
· RFC 4451, BGP MULTI_EXIT_DISC (MED) Consideration
· RFC 4456, BGP Route Reflection: An Alternative to Full Mesh Internal BGP
· RFC 4486, Subcodes for BGP Cease Notification Message
· RFC 4724, Graceful Restart Mechanism for BGP
· RFC 4760, Multiprotocol Extensions for BGP-4
· RFC 5004, Avoid BGP Best Path Transitions from One External to Another
· RFC 5065, Autonomous System Confederations for BGP
· RFC 5082, The Generalized TTL Security Mechanism (GTSM)
· RFC 5668, 4-Octet AS Specific BGP Extended Community
· RFC 6608, Subcodes for BGP Finite State Machine Error
· RFC 6624, Layer 2 Virtual Private Networks Using BGP for Auto-Discovery and Signaling
· RFC 6793, BGP Support for Four-Octet Autonomous System (AS) Number Space
· RFC 7752, North-Bound Distribution of Link-State and Traffic Engineering (TE) Information Using BGP
Building basic BGP networks
To build basic BGP networks for the IPv4 unicast or IPv4 multicast address family, perform the following tasks:
a. Enabling BGP
c. Configuring dynamic BGP peers
d. Configuring an IBGP peer group
Configure BGP peer groups on large-scale BGP networks for easy configuration and maintenance.
e. Configuring an EBGP peer group
f. (Optional.) Specifying the source address of TCP connections
2. Controlling BGP route generation
¡ (Optional.) Configuring BGP route summarization
¡ (Optional.) Advertising a default route to a peer or peer group
3. (Optional.) Controlling BGP route advertisement
¡ Advertising optimal routes in the IP routing table
BGP cannot advertise optimal routes in the IP routing table for IPv4 multicast address family.
¡ Configuring BGP route distribution filtering policies
¡ Configuring BGP route update delay
4. (Optional.) Controlling BGP route reception
¡ Limiting routes received from a peer or peer group
¡ Configuring BGP route reception filtering policies
¡ Configuring the SoO attribute
5. (Optional.) Configuring BGP timers
¡ Configuring the keepalive interval and hold time
¡ Setting the session retry timer
¡ Configuring the interval for sending updates for the same route
6. (Optional.) Configuring BGP logging and notifications
¡ Enabling logging for session state changes
¡ Configuring BGP network management
To build basic BGP networks for the IPv6 unicast or IPv6 multicast address family, perform the following tasks:
a. Enabling BGP
BGP cannot advertise optimal routes in the IP routing table for IPv6 multicast address family.
Enabling BGP
A router ID is the unique identifier of a BGP router in an AS.
· To ensure the uniqueness of a router ID and enhance availability, specify in BGP instance view the IP address of a local loopback interface as the router ID. Different BGP instances can have the same router ID.
· If no router ID is specified in BGP instance view, the global router ID is used.
· To modify a non-zero router ID of a BGP instance , use the router-id command in BGP instance view, rather than the router id command in system view.
· If you specify a router ID in BGP instance view and then remove the interface that owns the router ID, the router does not select a new router ID. To select a new router ID, use the undo router-id command in BGP instance view.
1. Enter system view.
2. Configure a global router ID.
router id router-id
By default, no global router ID is configured.
If no global router ID is configured, the following rules apply:
¡ If loopback interfaces configured with an IP address exist, BGP uses the highest loopback interface IP address as the router ID.
¡ If no loopback interface IP address is available, BGP uses the highest physical interface IP address as the route ID regardless of the interface status.
3. Enable BGP and enter BGP instance view.
By default, BGP is disabled and no BGP instances exist.
4. (Optional.) Configure a router ID for the BGP instance.
router-id router-id
By default, no router ID is configured for a BGP instance, and the BGP instance uses the global router ID configured by the router-id command in system view.
5. (Optional.) Enter BGP-VPN instance view.
The specified VPN instance must have been created and have an RD.
6. (Optional.) Configure a router ID for the BGP VPN instance.
By default, no router ID is configured for a BGP VPN instance.
The BGP VPN instance uses the router ID configured in BGP instance view. If no router ID is configured in BGP instance view, the BGP VPN instance uses the global router ID configured in system view.
Configuring a BGP peer
A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
Procedure (Exchanging IPv4 unicast routes with IPv4 peers)
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
¡ Enter BGP-VPN instance view.
3. Create an IPv4 BGP peer and specify its AS number.
4. (Optional.) Configure a description for a peer.
By default, no description is configured for a peer.
5. Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
6. Enable the router to exchange IPv4 unicast routing information with the specified peer.
peer ipv4-address enable
By default, the router cannot exchange IPv4 unicast routing information with the peer.
Procedure (Exchanging IPv6 unicast routes with IPv4 peers)
2. Enter BGP instance view.
4. (Optional.) Configure a description for the IPv4 peer.
By default, no description is configured for an IPv4 peer.
5. Create the BGP IPv6 unicast address family and enter its view.
6. Enable BGP to exchange IPv6 unicast routing information with the IPv4 peer.
By default, BGP cannot exchange IPv6 unicast routing information with an IPv4 peer.
7. Use a routing policy to modify the next hop of routes received from the IPv4 peer.
peer ipv4-address route-policy route-policy-name import
Procedure (Exchanging IPv6 unicast routes with IPv6 peers)
3. Create an IPv6 BGP peer and specify its AS number.
5. Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
6. Enable the router to exchange IPv6 unicast routing information with the specified peer.
peer ipv6-address enable
By default, the router cannot exchange IPv6 unicast routing information with the peer.
Procedure (Exchanging IPv4 unicast routes with IPv6 peers)
4. (Optional.) Configure a description for the IPv6 peer.
By default, no description is configured for an IPv6 peer.
5. Create the BGP IPv4 unicast address family and enter its view.
6. Enable BGP to exchange IPv4 unicast routing information with the IPv6 peer.
By default, BGP cannot exchange IPv4 unicast routing information with an IPv6 peer.
7. Use a routing policy to modify the next hop of routes received from the IPv6 peer.
peer ipv6-address route-policy route-policy-name import
Procedure (Exchanging IPv4 multicast routes with IPv4 peers)
4. (Optional.) Configure a description for the peer.
5. Create the BGP IPv4 multicast address family and enter its view.
address-family ipv4 multicast
6. Enable the router to exchange IPv4 unicast routing information used for RPF check with the specified peer.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peer.
Procedure (Exchanging IPv6 multicast routes with IPv6 peers)
5. Create the BGP IPv6 multicast address family and enter its view.
address-family ipv6 multicast
6. Enable the router to exchange IPv6 unicast routing information used for RPF check with the specified peer.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peer.
This feature enables BGP to establish dynamic BGP peer relationships with devices in a network. BGP accepts connection requests from the network but it does not initiate connection requests to the network.
After a device in the network initiates a connection request, BGP establishes a dynamic peer relationship with the device.
If multiple BGP peers reside in the same network, you can use this feature to simplify BGP peer configuration.
For a remote device to establish a peer relationship with the local device, you must specify the IP address of the local device on the remote device.
Procedure (Exchanging IPv4 unicast routes with dynamic IPv4 peers)
3. Specify devices in a network as dynamic BGP peers and specify an AS number for the peers.
4. (Optional.) Configure a description for dynamic BGP peers.
By default, no description is configured for dynamic BGP peers.
6. Enable BGP to exchange IPv4 unicast routing information with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv4 unicast routing information with dynamic BGP peers.
Procedure (Exchanging IPv6 unicast routes with dynamic IPv4 peers)
3. Specify devices in an IPv4 network as dynamic IPv4 BGP peers and specify an AS number for the peers.
By default, no description is configured for dynamic peers.
6. Enable BGP to exchange IPv6 unicast routing information with the dynamic IPv4 peers.
By default, BGP cannot exchange IPv6 unicast routing information with dynamic IPv4 peers.
7. Use a routing policy to modify the next hop of routes received from the dynamic IPv4 peers.
peer ipv4-address mask-length route-policy route-policy-name import
Procedure (Exchanging IPv6 unicast routes with dynamic IPv6 peers)
6. Enable BGP to exchange IPv6 unicast routing information with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv6 unicast routing information with dynamic BGP peers.
Procedure (Exchanging IPv4 unicast routes with dynamic IPv6 peers)
3. Specify devices in an IPv6 network as dynamic IPv6 BGP peers and specify an AS number for the peers.
4. (Optional.) Configure a description for the dynamic IPv6 peers.
6. Enable BGP to exchange IPv4 unicast routing information with dynamic IPv6 peers.
By default, BGP cannot exchange IPv4 unicast routing information with dynamic IPv6 peers.
7. Use a routing policy to modify the next hop of routes received from the dynamic IPv6 peers.
peer ipv6-address prefix-length route-policy route-policy-name import
Procedure (Exchanging IPv4 multicast routes with dynamic IPv4 peers)
6. Enable BGP to exchange IPv4 unicast routing information used for RPF check with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv4 unicast routing information used for RPF check with dynamic BGP peers.
Procedure (Exchanging IPv6 multicast routes with dynamic IPv6 peers)
6. Enable BGP to exchange IPv6 unicast routing information used for RPF check with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv6 unicast routing information used for RPF check with dynamic BGP peers.
A peer group is an IBGP peer group if peers in it belong to the same AS as the local router.
After you create an IBGP peer group and then add a peer into it, the system creates the peer in BGP instance view and specifies the local AS number for the peer.
If you configure a BGP setting at both the peer group and the peer level, the most recent configuration takes effect on the peer.
3. Create an IBGP peer group.
group group-name [ internal ]
4. Add a peer into the IBGP peer group.
The as-number as-number option must specify the local AS number.
5. (Optional.) Configure a description for the peer group.
By default, no description is configured for the peer group.
6. Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
7. Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
peer group-name enable
By default, the router cannot exchange IPv4 unicast routing information with the peers.
4. Add an IPv4 peer into the IBGP peer group.
By default, no description is configured for a peer group.
6. Create the BGP IPv6 unicast address family and enter its view.
7. Enable BGP to exchange IPv6 unicast routing information with peers in the peer group.
By default, BGP cannot exchange IPv6 unicast routing information with peers in a peer group.
8. Use a routing policy to modify the next hop of routes received from peers in the peer group.
peer group-name route-policy route-policy-name import
6. Create the BGP IPv4 multicast address family and enter its view.
7. Enable the router to exchange IPv4 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers in the peer group.
6. Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
7. Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information with the peers.
4. Add an IPv6 peer into the IBGP peer group.
6. Create the BGP IPv4 unicast address family and enter its view.
7. Enable BGP to exchange IPv4 unicast routing information with peers in the peer group.
By default, BGP cannot exchange IPv4 unicast routing information with peers in a peer group.
6. Create the BGP IPv6 multicast address family and enter its view.
7. Enable the router to exchange IPv6 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peers in the peer group.
A peer group is an EBGP peer group if peers in it belong to different ASs.
If peers in an EBGP group belong to the same external AS, the EBGP peer group is a pure EBGP peer group. If not, it is a mixed EBGP peer group.
Use one of the following methods to configure an EBGP peer group:
· Method 1—Create an EBGP peer group, specify its AS number, and add peers into it. All the added peers have the same AS number. All peers in the peer group have the same AS number as the peer group. You can specify an AS number for a peer before adding it into the peer group. The AS number must be the same as that of the peer group.
· Method 2—Create an EBGP peer group, specify an AS number for a peer, and add the peer into the peer group. Peers added in the group can have different AS numbers.
· Method 3—Create an EBGP peer group and add a peer with an AS number into it. Peers added in the group can have different AS numbers.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 unicast routes with IPv4 peers)
3. Create an EBGP peer group.
group group-name external
4. Specify the AS number of the group.
By default, no AS number is specified.
If a peer group contains peers, you cannot remove or change its AS number.
5. Add a peer into the EBGP peer group.
The as-number as-number option must specify the same AS number as the peer group-name as-number as-number command.
6. (Optional.) Configure a description for the peer group.
7. Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
8. Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 unicast routes with IPv4 peers)
4. Create an IPv4 BGP peer and specify its AS number.
5. Add the peer into the EBGP peer group.
The as-number as-number option must specify the same AS number as the peer ipv4-address [ mask-length ] as-number as-number command.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 unicast routes with IPv4 peers)
4. Add a peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 unicast routes with IPv4 peers)
4. Specify an AS number for the peer group.
By default, no AS number is specified for a peer group.
5. Add an IPv4 peer into the EBGP peer group.
7. Create the BGP IPv6 unicast address family and enter its view.
8. Enable BGP to exchange IPv6 unicast routing information with peers in the peer group.
9. Use a routing policy to modify the next hop of routes received from peers in the peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 unicast routes with IPv4 peers)
5. Add the IPv4 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 unicast routes with IPv4 peers)
4. Add an IPv4 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 multicast routes with IPv4 peers)
5. Add an IPv4 BGP peer into the EBGP peer group.
7. Create the BGP IPv4 multicast address family and enter its view.
8. Enable the router to exchange IPv4 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers in the group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 multicast routes with IPv4 peers)
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 multicast routes with IPv4 peers)
4. Add an IPv4 BGP peer into the EBGP peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 unicast routes with IPv6 peers)
7. Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
8. Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 unicast routes with IPv6 peers)
4. Create an IPv6 BGP peer and specify its AS number.
peer ipv6-address [ prefix-length ] as-number as-number
The as-number as-number option must specify the same AS number as the peer ipv6-address [ prefix-length ] as-number as-number command.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 unicast routes with IPv6 peers)
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 unicast routes with IPv6 peers)
5. Add an IPv6 peer into the EBGP peer group.
7. Create the BGP IPv4 unicast address family and enter its view.
8. Enable BGP to exchange IPv4 unicast routing information with peers in the peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 unicast routes with IPv6 peers)
5. Add the IPv6 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 unicast routes with IPv6 peers)
4. Add an IPv6 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 multicast routes with IPv6 peers)
5. Add an IPv6 BGP peer into the EBGP peer group.
7. Create the BGP IPv6 multicast address family and enter its view.
8. Enable the router to exchange IPv6 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peers in the group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 multicast routes with IPv6 peers)
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 multicast routes with IPv6 peers)
4. Add an IPv6 BGP peer into the EBGP peer group.
BGP uses TCP as the transport layer protocol. Perform this task in the following scenarios to specify the source address or source interface of TCP connections to a peer or peer group:
· The peer's IPv4/IPv6 address does not belong to the interface directly connected to the local router. To ensure successful TCP connection establishment, use one of the following methods:
¡ Specify the interface to which the IPv4/IPv6 address belongs as the source interface on the peer.
¡ Specify the IPv4/IPv6 address of the interface directly connected to the local router as the source address on the peer.
· A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
· On a BGP router that has multiple links to a peer, the source interface for TCP connection changes because the primary source interface fails. To avoid this problem, specify a loopback interface as the source interface or specify the IP address of a loopback interface as the source address.
· You want to establish multiple BGP sessions to a router. In this case, BGP might fail to determine the source address for each TCP connection based on the optimal route to the peer. To prevent this problem, use one of the following methods:
¡ If the BGP sessions use IP addresses of different interfaces, specify a source interface or source address for each session.
¡ If the BGP sessions use different IP addresses of the same interface, specify a source address for each session.
BGP immediately tears down the session to an IBGP peer or peer group when the following conditions exist:
· The source interface of TCP connections to the IBGP peer or peer group is a physical interface.
· The source interface fails and the link to the IBGP peer or peer group goes down.
Procedure (IPv4 unicast/multicast address family)
3. Specify the source address or source interface of TCP connections to a peer or peer group.
¡ Specify the source address of TCP connections to a peer or peer group.
¡ Specify the source interface of TCP connections to a peer or peer group.
By default, BGP uses the primary IPv4 address of the output interface in the optimal route to a peer or peer group as the source address of TCP connections to the peer or peer group.
Procedure (IPv6 unicast/multicast address family)
3. Specify the source IPv6 address or source interface of TCP connections to a peer or peer group.
¡ Specify the source IPv6 address of TCP connections to a peer or peer group.
By default, BGP uses the IPv6 address of the output interface in the optimal route to the BGP peer or peer group as the source address of TCP connections to the peer or peer group.
Injecting a local network
Perform this task to inject a network in the local routing table to the BGP routing table, so BGP can advertise the network to BGP peers. The ORIGIN attribute of BGP routes advertised in this way is IGP. You can also use a routing policy to control route advertisement.
The specified network must be available and active in the local IP routing table.
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
¡ Enter BGP IPv4 unicast address family view.
¡ Enter BGP-VPN IPv4 unicast address family view.
¡ Enter BGP IPv4 multicast address family view.
3. Configure BGP to advertise a local network.
By default, BGP does not advertise local networks.
2. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
¡ Enter BGP IPv6 unicast address family view.
¡ Enter BGP-VPN IPv6 unicast address family view.
¡ Enter BGP IPv6 multicast address family view.
Redistributing IGP routes
Perform this task to configure route redistribution from an IGP to BGP.
By default, BGP does not redistribute default IGP routes. You can use the default-route imported command to redistribute default IGP routes into the BGP routing table.
The ORIGIN attribute of BGP routes redistributed from IGPs is INCOMPLETE.
Only active routes can be redistributed. To view route state information, use the display ip routing-table protocol or display ipv6 routing-table protocol command. For more information about the commands, see Layer 3—IP Routing Command Reference.
If you execute the import-route command multiple times for an IGP process, the most recent configuration takes effect. To redistribute more routes from an IGP process without overwriting the routes redistributed before, use the import-route-append command.
When you execute both the import-route and import-route-append commands for an IGP process, the commands take effect as follows:
· A route is redistributed as long as it matches the criteria of either command.
· If a route matches the criteria of both commands, the route is redistributed, and the apply clauses in the routing policies specified in the two commands take effect as follows:
¡ If the apply clauses do not conflict, all apply clauses take effect.
¡ If conflicts occur between the apply clauses, only the apply clauses in the import-route-append command take effect.
· The MED value specified by the import-route-append command takes precedence over that specified by the import-route command.
3. Enable route redistribution from the specified IGP into BGP.
¡ Redistribute IS-IS, OSPF, or RIP routes.
¡ Redistribute direct or static routes.
import-route { direct | static } [ med med-value | route-policy route-policy-name ] *
By default, BGP does not redistribute IGP routes.
4. (Optional.) Redistribute routes from an IGP without overwriting the routes redistributed by the import-route command.
import-route-append { isis | ospf | rip } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
import-route-append { direct | static } [ med med-value | route-policy route-policy-name ] *
5. (Optional.) Enable default route redistribution into BGP.
By default, BGP does not redistribute default routes.
¡ Redistribute IPv6 IS-IS, OSPFv3, or RIPng routes.
import-route-append { isisv6 | ospfv3 | ripng } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
Route summarization can reduce the number of redistributed routes and the routing table size. IPv4 BGP supports automatic route summarization and manual route summarization. Manual summarization takes precedence over automatic summarization. IPv6 BGP supports only manual route summarization.
Automatic route summarization enables BGP to summarize IGP subnet routes redistributed by the import-route command, so BGP advertises only natural network routes.
By configuring manual route summarization, you can do the following:
· Summarize both redistributed routes and routes injected using the network command.
· Determine the mask length for a summary route.
Restrictions and guidelines for configuring BGP route summarization
The output interface of a BGP summary route is Null 0 on the originating router. Therefore, a summary route must not be an optimal route on the originating router. Otherwise, BGP will fail to forward packets matching the route. If a summarized specific route has the same mask as the summary route, but has a lower priority, the summary route becomes the optimal route. To ensure correct packet forwarding, change the priority of the summary or specific route to make the specific route the optimal route.
Configuring automatic route summarization (IPv4 unicast/multicast address family)
3. Configure automatic route summarization.
summary automatic
By default, automatic route summarization is not configured.
Configuring manual route summarization (IPv4 unicast/multicast address family)
3. Create a summary route in the BGP routing table.
By default, no summary routes are configured.
Configuring BGP manual route summarization (IPv6 unicast/multicast address family)
3. Create a summary route in the IPv6 BGP routing table.
Perform this task to advertise a default BGP route with the next hop being the advertising router to a peer or peer group.
3. Advertise a default route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ]
By default, no default route is advertised.
The ipv6-address [ prefix-length ] argument is supported only in BGP IPv4 unicast address family view.
The ipv4-address [ mask-length ] argument is supported only in BGP IPv6 unicast address family view.
By default, BGP advertises optimal routes in the BGP routing table, which may not be optimal in the IP routing table. This task allows you to advertise BGP routes that are optimal in the IP routing table.
Procedure (IPv4 unicast)
3. Enable BGP to advertise optimal routes in the IP routing table.
By default, BGP advertises optimal routes in the BGP routing table.
4. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
5. Enable BGP to advertise optimal routes in the IP routing table of the address family in the VPN instance.
By default, the setting is the same as that in BGP instance view.
Procedure (IPv6 unicast)
3. Enable BGP to advertise optimal routes in the IPv6 routing table.
4. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
5. Enable BGP to advertise optimal routes in the IPv6 routing table of the address family in the VPN instance.
To configure BGP route distribution filtering policies, use the following methods:
· Use an ACL or prefix list to filter routing information advertised to all peers.
· Use a routing policy, ACL, conditional advertisement policy (existent policy or nonexistent policy), AS path list, or prefix list to filter routing information advertised to a peer or peer group.
If you configure multiple filtering policies, apply them in the following sequence:
1. peer prefix-list export
2. peer filter-policy export
3. peer as-path-acl export
4. filter-policy export
5. peer advertise-policy exist-policy
6. peer advertise-policy non-exist-policy
7. peer route-policy export
Only routes passing all the configured policies can be advertised.
Before you configure BGP routing filtering policies, configure the following filters used for route filtering as needed:
· ACL (see ACL and QoS Configuration Guide).
· Prefix list (see "Configuring routing policies").
· Routing policy (see "Configuring routing policies").
· AS path list (see "Configuring routing policies").
When you specify an ACL, prefix list, or routing policy as a filtering policy to filter BGP routing information, follow these restrictions and guidelines:
· If the specified ACL, prefix list, or routing policy does not exist, all BGP routes can pass the filtering policy.
· When you specify an ACL or prefix list as a BGP route filtering policy (for example, use filter-policy export to specify an ACL for route filtering), the following rules apply:
¡ BGP routes can pass the filtering policy only when one of the following conditions exists:
- They match a permit rule in the specified ACL.
- They match a permit item in the specified prefix list.
When the ACL has only deny rules or the prefix list has only deny items, no BGP routes can pass the filtering policy.
¡ When the ACL match order is config, BGP routes match against rules in ascending order of rule ID. When BGP routes match against the items of the prefix list, an item with a smaller index number is matched first.
In either of the match modes above, a BGP route does not match against the next ACL rule or prefix list item when it already matches the current ACL rule or prefix list item. To avoid wasting filter resources, set a small match range for each ACL rule or prefix list item when you configure multiple ACL rules or prefix list items for an ACL or prefix list.
¡ You can use the rule [ rule-id ] permit ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to create a rule for an advanced ACL to match specific routes. The source sour-addr option represents the destination network address and the destination dest-addr option represents the mask in dotted decimal notation. For example, to match route 3.3.3.0/24, the rule configuration should be rule [ rule-id ] permit ip source 3.3.3.0 0.0.0.255 destination 255.255.255.0 0.0.0.255.
· When you specify a routing policy as a BGP route filtering policy, the following rules apply:
¡ BGP routes can pass the filtering policy only when they match a permit node in the routing policy.
¡ A BGP route matches against the nodes of the routing policy in ascending order of node number. It does not match against the next node when it already matches the current node (unless a continue clause exists).
¡ When a BGP route matches against a routing policy that has an ACL or prefix-list if-match clause, it can pass the routing policy only when the following conditions exist:
i The route matches a permit rule in the ACL or a permit item in the prefix list.
ii The route matches a permit node in the routing policy.
3. Configure BGP route distribution filtering policies. Choose the options to configure as needed:
¡ Reference an ACL or IP prefix list to filter advertised BGP routes.
filter-policy { ipv4-acl-number | prefix-list ipv4-prefix-list-name } export [ direct | { isis | ospf | rip } process-id | static ]
¡ Specify a routing policy as the existent policy to control route advertisement.
This command is supported only in BGP IPv4 unicast address family view.
¡ Specify a routing policy as the nonexistent policy to control route advertisement.
¡ Reference a routing policy to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name export
¡ Reference an ACL to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv4-acl-number } export
¡ Reference an AS path list to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl as-path-acl-number export
¡ Reference an IPv4 prefix list to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name export
By default, no BGP distribution filtering policy is configured.
¡ Reference an ACL or IPv6 prefix list to filter advertised BGP routes.
filter-policy { ipv6-acl-number | prefix-list ipv6-prefix-list-name } export [ direct | { isisv6 | ospfv3 | ripng } process-id | static ]
This command is supported only in BGP IPv6 unicast address family view.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv6-acl-number } export
¡ Reference an IPv6 prefix list to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name export
This task reduces traffic loss. With this task performed, BGP delays sending route updates when it restores after a device reboot. During the delay time, BGP finishes learning all routes from other peers, and then selects the optimal route. After the delay time elapses, BGP will advertise the optimal route.
You can specify a prefix list and enable BGP to immediately send route updates for routes that match the prefix list.
3. Configure BGP to delay sending route updates when it restores after a device reboot.
By default, BGP immediately sends route updates to BGP peers in established state when it restores after a device reboot.
4. (Optional.) Configure BGP to immediately send route updates for routes that match a prefix list.
By default, no prefix list is specified to filter routes.
This feature can prevent attacks that send a large number of BGP routes to the router.
If the number of routes received from a peer or peer group exceeds the upper limit, the router takes one of the following actions based on your configuration:
· Tears down the BGP session to the peer or peer group and does not attempt to re-establish the session.
· Continues to receive routes from the peer or peer group and generates a log message.
· Retains the session to the peer or peer group, but it discards excess routes and generates a log message.
· Tears down the BGP session to the peer or peer group and, after a specific period of time, re-establishes a BGP session to the peer or peer group.
You can specify a percentage threshold for the router to generate a log message. When the ratio of the number of received routes to the maximum number reaches the percentage value, the router generates a log message.
3. Specify the maximum number of routes that a router can receive from a peer or peer group.
By default, the number of routes that a router can receive from a peer or peer group is not limited.
You can use the following methods to configure BGP route reception filtering policies:
· Use an ACL or prefix list to filter routing information received from all peers.
· Use a routing policy, ACL, AS path list, or prefix list to filter routing information received from a peer or peer group.
1. peer filter-policy import
2. peer prefix-list import
3. peer as-path-acl import
4. filter-policy import
5. peer route-policy import
Only routes passing all the configured policies can be received.
Before you configure BGP route reception filtering policies, configure the following filters used for route filtering as needed:
When you specify an ACL, prefix list, or routing policy as a filtering policy to filter BGP routing information, follow these guidelines:
· When you specify an ACL or prefix list as a BGP route filtering policy (for example, use filter-policy import to specify an ACL for route filtering), the following rules apply:
3. Configure BGP route reception filtering policies. Choose the options to configure as needed:
¡ Reference an ACL or IP prefix list to filter BGP routes received from all peers.
filter-policy { ipv4-acl-number | prefix-list ipv4-prefix-list-name } import
¡ Reference a routing policy to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name import
¡ Reference an ACL to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv4-acl-number } import
¡ Reference an AS path list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl as-path-acl-number import
¡ Reference an IPv4 prefix list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name import
By default, no route reception filtering is configured.
¡ Reference ACL or IPv6 prefix list to filter BGP routes received from all peers.
filter-policy { ipv6-acl-number | prefix-list ipv6-prefix-list-name } import
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv6-acl-number } import
¡ Reference an IPv6 prefix list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name import
After you configure the SoO attribute for a BGP peer or peer group, BGP adds the SoO attribute into the route updates received from the BGP peer or peer group. In addition, before advertising route updates to the peer or peer group, BGP checks the SoO attribute of the route update against the configured SoO attribute. If they are the same, BGP does not advertise the route updates to the BGP peer or peer group.
3. Configure the SoO attribute for a peer or peer group.
By default, no SoO attribute is configured for a peer or peer group.
BGP sends KEEPALIVE messages regularly to keep the BGP session between two routers.
If a router receives no KEEPALIVE or UPDATE message from a peer within the hold time, it tears down the session.
You can configure the keepalive interval and hold time globally or for a peer or peer group. The individual settings take precedence over the global settings.
The actual keepalive interval and hold time are determined as follows:
· If the hold time settings on the local and peer routers are different, the smaller setting is used. If the hold time is 0, BGP does not send KEEPALIVE messages to its peers and never tears down the session.
· If the keepalive interval is not 0, the actual keepalive interval is the smaller one between 1/3 of the hold time and the keepalive interval.
The hold time must be a minimum of three times the keepalive interval.
You can perform this task for all BGP peers or for a specific BGP peer or peer group. For a BGP peer or peer group, the configuration of the peer timer command takes precedence over that of the timer command. If you do not configure the peer timer command for the peer or peer group, the configuration of the timer command takes effect on the peer or peer group.
3. Configure the keepalive interval and hold time.
¡ Configure the global keepalive interval and hold time.
This command takes effect for new BGP sessions and does not affect existing sessions.
¡ Configure the keepalive interval and hold time for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } timer keepalive keepalive hold holdtime
By default, the keepalive interval is 60 seconds, and hold time is 180 seconds.
The timers configured with the timer and peer timer commands do not take effect until a session is re-established (for example, a session is reset).
peer { group-name | ipv6-address [ prefix-length ] } timer keepalive keepalive hold holdtime
To speed up session establishment to a peer or peer group and route convergence, set a small session retry timer. If the BGP session flaps, you can set a large session retry timer to reduce the impact.
The timer set by the peer timer connect-retry command takes precedence over the timer set by the timer connect-retry command.
3. Set the session retry timer.
¡ Set the session retry timer for all peers or peer groups.
¡ Set the session retry timer for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } timer connect-retry retry-time
By default, the session retry timer is 32 seconds for a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } timer connect-retry retry-time
A BGP router sends an UPDATE message to its peers when a route is changed. If the route changes frequently, the BGP router keeps sending updates for the same route, resulting route flapping. To prevent this situation, perform this task to configure the interval for sending updates for the same route to a peer or peer group.
This feature does not take effect on withdrawn routes. For withdrawn routes, BGP sends the withdrawal messages immediately.
3. Configure the interval for sending updates for the same route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } route-update-interval interval
By default, the interval is 15 seconds for an IBGP peer and 30 seconds for an EBGP peer.
peer { group-name | ipv6-address [ prefix-length ] } route-update-interval interval
Perform this task to enable BGP to log BGP session establishment and disconnection events. To display the log information, use the display bgp peer ipv4 unicast log-info command or the display bgp peer ipv6 unicast log-info command. The logs are sent to the information center. The output rules of the logs (whether to output the logs and where to output) are determined by the information center configuration.
For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
Procedure (IPv4 unicast/IPv4 multicast)
3. Enable logging for session state changes globally.
log-peer-change
By default, logging for session state changes is enabled globally.
4. (Optional.) Enter BGP-VPN instance view.
5. Enable logging for session state changes for a peer or peer group.
By default, logging for session state changes is enabled for all peers and peer groups.
Procedure (IPv6 unicast/IPv6 multicast)
log-peer-change
peer { group-name | ipv6-address [ prefix-length ] } log-change
After you enable SNMP notifications for BGP, the device generates a notification when a BGP neighbor state change occurs. The notification includes the neighbor address, the error code and subcode of the most recent error, and the current neighbor state. For BGP notifications to be sent correctly, you must also configure SNMP on the device.
BGP does not know the BGP instance to which a managed MIB node belongs. To resolve this issue, configure different SNMP contexts for different BGP instances.
The device selects a MIB for an SNMP packet according to the context (for SNMPv3) or community name (for SNMPv1/v2c) in the following ways:
· For an SNMPv3 packet:
¡ The device selects the MIB of the default BGP instance if the packet does not carry a context and no SNMP context is configured for the default BGP instance.
¡ The device selects the MIB of a BGP instance if the packet meets the following conditions:
- Carries a context that is configured with the snmp-agent context command in system view.
- Matches the context of the BGP instance.
¡ The device does not process any MIBs in other situations.
· For an SNMPv1/v2c packet:
¡ The device selects the MIB of the default BGP instance if the following conditions are met:
- No community name-to-SNMP context mapping is configured with the snmp-agent community-map command in system view.
- No SNMP context is configured for the default BGP instance.
¡ The device selects the MIB of a BGP instance if the community name is mapped to an SNMP context and the context matches the context of the BGP instance.
For more information about SNMP contexts and community names, see SNMP configuration in Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for BGP.
snmp-agent trap enable bgp [ instance instance-name ]
By default, SNMP notifications for BGP are enabled.
3. Enter BGP instance view.
4. Configure an SNMP context for the BGP instance.
By default, no SNMP context is configured for the BGP instance.
Display and maintenance commands for basic BGP network building
Displaying BGP
Displaying BGP (IPv4 unicast address family)
Task |
Command |
Display BGP IPv4 unicast peer group information. |
display bgp [ instance instance-name ] group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command. |
display bgp [ instance instance-name ] network ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] |
Display BGP IPv4 unicast peer or peer group information. |
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ] |
Display BGP IPv4 unicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl as-path-acl-number ] |
Display BGP IPv4 unicast routing information. |
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ] |
Display BGP IPv4 unicast address family update group information. |
display bgp [ instance instance-name ] update-group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address ] display bgp [ instance instance-name ] update-group ipv4 [ unicast ] [ ipv6-address ] |
Display information about all BGP instances. |
display bgp instance-info |
Displaying BGP (IPv6 unicast address family)
Task |
Command |
Display BGP IPv6 unicast peer group information. |
display bgp [ instance instance-name ] group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
display bgp [ instance instance-name ] network ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] |
Display BGP IPv6 unicast peer or peer group information. |
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ] display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ ipv4-address mask-length | ipv4-address log-info | [ ipv4-address ] verbose ] |
Display BGP IPv6 unicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl as-path-acl-number ] |
Display BGP IPv6 unicast routing information. |
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ] display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] peer ipv4-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] |
Display BGP IPv6 unicast address family update group information. |
display bgp [ instance instance-name ] update-group ipv6 [ unicast ] [ ipv4-address | ipv6-address ] display bgp [ instance instance-name ] update-group ipv6 [ unicast ] vpn-instance vpn-instance-name [ ipv6-address ] |
Displaying BGP (IPv4 multicast address family)
Task |
Command |
Display BGP IPv4 multicast peer group information. |
display bgp [ instance instance-name ] group ipv4 multicast [ group-name group-name ] |
display bgp [ instance instance-name ] network ipv4 multicast |
Display BGP path attribute information. |
display bgp [ instance instance-name ] paths [ as-regular-expression ] |
Display BGP IPv4 multicast peer or peer group information. |
display bgp [ instance instance-name ] peer ipv4 multicast [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] |
Display BGP IPv4 multicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl as-path-acl-number ] |
Display BGP IPv4 multicast routing information. |
display bgp [ instance instance-name ] routing-table ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ] |
Display BGP IPv4 multicast address family update group information. |
display bgp [ instance instance-name ] update-group ipv4 multicast [ ipv4-address ] |
Displaying BGP (IPv6 multicast address family)
Task |
Command |
Display BGP IPv6 multicast peer group information. |
display bgp [ instance instance-name ] group ipv6 multicast [ group-name group-name ] |
display bgp [ instance instance-name ] network ipv6 multicast |
Display BGP IPv6 multicast peer or peer group information. |
display bgp [ instance instance-name ] peer ipv6 multicast [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ] |
Display BGP IPv6 multicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv6 multicast [ ipv6-address prefix-length | as-path-acl as-path-acl-number ] |
Display BGP IPv6 multicast routing information. |
display bgp [ instance instance-name ] routing-table ipv6 multicast [ ipv6-address prefix-length [ advertise-info ] | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ] |
Display BGP IPv6 multicast address family update group information. |
display bgp [ instance instance-name ] update-group ipv6 multicast [ ipv6-address ] |
Resetting BGP sessions
CAUTION: A reset operation tears down BGP sessions for a short period of time. |
Execute reset commands in user view.
Task |
Command |
Reset BGP sessions for IPv4 unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] reset bgp [ instance instance-name ] ipv6-address [ prefix-length ] ipv4 [ unicast ] |
Reset BGP sessions for IPv4 multicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 multicast |
Reset BGP sessions for IPv6 unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] reset bgp [ instance instance-name ] ipv4-address [ mask-length ] ipv6 [ unicast ] |
Reset BGP sessions for IPv6 multicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 multicast |
Reset all BGP sessions. |
reset bgp [ instance instance-name ] all |
Clearing BGP information
Task |
Command |
Clear flap information for BGP IPv4 unicast routes. |
reset bgp [ instance instance-name ] flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] | as-path-acl as-path-acl-number | peer ipv4-address [ mask-length ] ] |
Clear flap information for BGP IPv4 multicast routes. |
reset bgp [ instance instance-name ] flap-info ipv4 multicast [ ipv4-address [ mask-length | mask ] | as-path-acl as-path-acl-number | peer ipv4-address [ mask-length ] ] |
Clear flap information for BGP IPv6 unicast routes. |
reset bgp [ instance instance-name ] flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl as-path-acl-number | peer ipv6-address [ prefix-length ] ] |
Clear flap information for BGP IPv6 multicast routes. |
reset bgp [ instance instance-name ] flap-info ipv6 multicast [ ipv6-address prefix-length | as-path-acl as-path-acl-number | peer ipv6-address [ prefix-length ] ] |
Basic IPv4 BGP network configuration examples
Example: Configuring basic BGP
As shown in Figure 12, all devices run BGP. Run EBGP between Device A and Device B, and run IBGP between Device B and Device C to allow Device C to access network 8.1.1.0/24 connected to Device A.
1. Configure IP addresses for interfaces. (Details not shown.)
2. Add each interface on Device B to a security zone according to Figure 12.
[DeviceB] security-zone name untrust
[DeviceB-security-zone-Untrust] import interface gigabitethernet 1/0/1
[DeviceB-security-zone-Untrust] quit
[DeviceB] security-zone name trust
[DeviceB-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceB-security-zone-Trust] quit
3. Configure security policies.
a. Configure a security policy to allow EBGP session establishment between Device A and Device B by permitting traffic between security zone untrust and security zone local.
# Create security policy rule ebgplocalin and permit Device B to receive BGP packets from Device A.
[DeviceB] security-policy ip
[DeviceB-security-policy-ip] rule name ebgplocalin
[DeviceB-security-policy-ip-0-ebgplocalin] source-zone untrust
[DeviceB-security-policy-ip-0-ebgplocalin] destination-zone local
[DeviceB-security-policy-ip-0-ebgplocalin] service bgp
[DeviceB-security-policy-ip-0-ebgplocalin] action pass
[DeviceB-security-policy-ip-0-ebgplocalin] quit
# Create security policy rule ebgplocalout and permit Device B to send BGP packets to Device A.
[DeviceB-security-policy-ip] rule name ebgplocalout
[DeviceB-security-policy-ip-1-ebgplocalout] source-zone local
[DeviceB-security-policy-ip-1-ebgplocalout] destination-zone untrust
[DeviceB-security-policy-ip-1-ebgplocalout] service bgp
[DeviceB-security-policy-ip-1-ebgplocalout] action pass
[DeviceB-security-policy-ip-1-ebgplocalout] quit
b. Configure a security policy to allow IBGP session establishment between Device B and Device C by permitting traffic between security zone trust and security zone local.
# Create security policy rule bgplocalout and permit Device B to send BGP and OSPF packets to Device C.
[DeviceB-security-policy-ip] rule name bgplocalout
[DeviceB-security-policy-ip-2-bgplocalout] source-zone local
[DeviceB-security-policy-ip-2-bgplocalout] destination-zone trust
[DeviceB-security-policy-ip-2-bgplocalout] service bgp
[DeviceB-security-policy-ip-2-bgplocalout] service ospf
[DeviceB-security-policy-ip-2-bgplocalout] action pass
[DeviceB-security-policy-ip-2-bgplocalout] quit
# Create security policy rule bgplocalin and permit Device B to receive BGP and OSPF packets from Device C.
[DeviceB-security-policy-ip] rule name bgplocalin
[DeviceB-security-policy-ip-3-bgplocalin] source-zone trust
[DeviceB-security-policy-ip-3-bgplocalin] destination-zone local
[DeviceB-security-policy-ip-3-bgplocalin] service bgp
[DeviceB-security-policy-ip-3-bgplocalin] service ospf
[DeviceB-security-policy-ip-3-bgplocalin] action pass
[DeviceB-security-policy-ip-3-bgplocalin] quit
c. Configure a security policy to permit traffic between security zone untrust and security zone trust so that Device C can access network 8.1.1.0/24 connected to Device A.
# Create security policy rule trust-untrust and permit packets from security zone trust to security zone untrust to pass.
[DeviceB-security-policy-ip] rule name trust-untrust
[DeviceB-security-policy-ip-4-trust-untrust] source-zone trust
[DeviceB-security-policy-ip-4-trust-untrust] destination-zone untrust
[DeviceB-security-policy-ip-4-trust-untrust] source-ip-subnet 9.1.1.0 24
[DeviceB-security-policy-ip-4-trust-untrust] destination-ip-subnet 8.1.1.0 24
[DeviceB-security-policy-ip-4-trust-untrust] action pass
[DeviceB-security-policy-ip-4-trust-untrust] quit
[DeviceB-security-policy-ip] quit
4. Configure IBGP:
¡ To prevent route flapping caused by port state changes, this example uses loopback interfaces to establish IBGP connections.
¡ Because loopback interfaces are virtual interfaces, you need to use the peer connect-interface command to specify the loopback interface as the source interface for BGP connection establishment.
¡ Enable OSPF in AS 65009 to ensure that Device B can communicate with Device C through loopback interfaces.
# Configure Device B.
[DeviceB] bgp 65009
[DeviceB-bgp-default] router-id 2.2.2.2
[DeviceB-bgp-default] peer 3.3.3.3 as-number 65009
[DeviceB-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[DeviceB-bgp-default] address-family ipv4 unicast
[DeviceB-bgp-default-ipv4] peer 3.3.3.3 enable
[DeviceB-bgp-default-ipv4] quit
[DeviceB-bgp-default] quit
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[DeviceB-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
# Configure Device C.
<DeviceC> system-view
[DeviceC] bgp 65009
[DeviceC-bgp-default] router-id 3.3.3.3
[DeviceC-bgp-default] peer 2.2.2.2 as-number 65009
[DeviceC-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[DeviceC-bgp-default] address-family ipv4 unicast
[DeviceC-bgp-default-ipv4] peer 2.2.2.2 enable
[DeviceC-bgp-default-ipv4] quit
[DeviceC-bgp-default] quit
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[DeviceC-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
[DeviceC] display bgp peer ipv4
BGP local router ID : 3.3.3.3
Local AS number : 65009
Total number of peers : 1 Peers in established state : 1
* - Dynamically created peer
2.2.2.2 65009 2 2 0 0 00:00:13 Established
The output shows that Device C has established an IBGP peer relationship with Device B.
5. Configure EBGP:
¡ The EBGP peers (usually in different ISPs), are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so directly connected interfaces are used for establishing EBGP sessions.
¡ To enable Device C to access the network 8.1.1.0/24 connected directly to Device A, inject network 8.1.1.0/24 to the BGP routing table of Device A.
# Configure Device A.
[DeviceA] bgp 65008
[DeviceA-bgp-default] router-id 1.1.1.1
[DeviceA-bgp-default] peer 3.1.1.1 as-number 65009
[DeviceA-bgp-default] address-family ipv4 unicast
[DeviceA-bgp-default-ipv4] peer 3.1.1.1 enable
[DeviceA-bgp-default-ipv4] network 8.1.1.0 24
[DeviceA-bgp-default-ipv4] quit
[DeviceA-bgp-default] quit
[DeviceB] bgp 65009
[DeviceB-bgp-default] peer 3.1.1.2 as-number 65008
[DeviceB-bgp-default-ipv4] peer 3.1.1.2 enable
# Display BGP peer information on Device B.
[DeviceB] display bgp peer ipv4
BGP local router ID : 2.2.2.2
Total number of peers : 2 Peers in established state : 2
3.3.3.3 65009 4 4 0 0 00:02:49 Established
3.1.1.2 65008 2 2 0 0 00:00:05 Established
The output shows that Device B has established an IBGP peer relationship with Device C and an EBGP peer relationship with Device A.
# Display the BGP routing table on Device A.
[DeviceA] display bgp routing-table ipv4
Total number of routes: 1
* > 8.1.1.0/24 8.1.1.1 0 32768 i
# Display the BGP routing table on Device B.
[DeviceB] display bgp routing-table ipv4
* >e 8.1.1.0/24 3.1.1.2 0 0 65008i
# Display the BGP routing table on Device C.
[DeviceC] display bgp routing-table ipv4
i 8.1.1.0/24 3.1.1.2 0 100 0 65008i
The outputs show that Device A has no route to AS 65009, and Device C has learned network 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
6. Redistribute direct routes:
# Configure BGP to redistribute direct routes on Device B, so Device A can obtain the route to 9.1.1.0/24, and Device C can obtain the route to 3.1.1.0/24.
[DeviceB] bgp 65009
[DeviceB-bgp-default-ipv4] import-route direct
Total number of routes: 4
* >e 2.2.2.2/32 3.1.1.1 0 0 65009?
* >e 3.1.1.0/24 3.1.1.1 0 0 65009?
* >e 9.1.1.0/24 3.1.1.1 0 0 65009?
Two routes 2.2.2.2/32 and 9.1.1.0/24 have been added in Device A's routing table.
* >i 2.2.2.2/32 2.2.2.2 0 100 0 ?
* >i 3.1.1.0/24 2.2.2.2 0 100 0 ?
* >i 8.1.1.0/24 3.1.1.2 0 100 0 65008i
* >i 9.1.1.0/24 2.2.2.2 0 100 0 ?
The output shows that the route 8.1.1.0 has become valid and the next hop is Device A.
# Verify that Device C can ping 8.1.1.1.
[DeviceC] ping 8.1.1.1
Ping 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 8.1.1.1: icmp_seq=0 ttl=255 time=2.000 ms
56 bytes from 8.1.1.1: icmp_seq=1 ttl=255 time=0.000 ms
56 bytes from 8.1.1.1: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 8.1.1.1: icmp_seq=3 ttl=255 time=0.000 ms
56 bytes from 8.1.1.1: icmp_seq=4 ttl=255 time=1.000 ms
round-trip min/avg/max/std-dev = 0.000/0.600/2.000/0.800 ms
Basic IPv6 BGP network configuration examples
Example: Configuring IPv6 basic BGP
As shown in Figure 13, all devices run BGP. Run EBGP between Device A and Device B, and run IBGP between Device B and Device C to allow Device C to access network 50::/64 connected to Device A.
1. Configure IPv6 addresses for interfaces and IPv4 addresses for Loopback interfaces. (Details not shown.)
2. Add each interface on Device B to a security zone according to Figure 13.
[DeviceB] security-policy ipv6
[DeviceB-security-policy-ipv6] rule name ebgplocalin
[DeviceB-security-policy-ipv6-0-ebgplocalin] source-zone untrust
[DeviceB-security-policy-ipv6-0-ebgplocalin] destination-zone local
[DeviceB-security-policy-ipv6-0-ebgplocalin] service bgp
[DeviceB-security-policy-ipv6-0-ebgplocalin] action pass
[DeviceB-security-policy-ipv6-0-ebgplocalin] quit
[DeviceB-security-policy-ipv6] rule name ebgplocalout
[DeviceB-security-policy-ipv6-1-ebgplocalout] source-zone local
[DeviceB-security-policy-ipv6-1-ebgplocalout] destination-zone untrust
[DeviceB-security-policy-ipv6-1-ebgplocalout] service bgp
[DeviceB-security-policy-ipv6-1-ebgplocalout] action pass
[DeviceB-security-policy-ipv6-1-ebgplocalout] quit
# Create security policy rule bgplocalout and permit Device B to send BGP packets to Device C.
[DeviceB-security-policy-ipv6] rule name bgplocalout
[DeviceB-security-policy-ipv6-2-bgplocalout] source-zone local
[DeviceB-security-policy-ipv6-2-bgplocalout] destination-zone trust
[DeviceB-security-policy-ipv6-2-bgplocalout] service bgp
[DeviceB-security-policy-ipv6-2-bgplocalout] action pass
[DeviceB-security-policy-ipv6-2-bgplocalout] quit
c. Configure a security policy to permit traffic between security zone untrust and security zone trust so that Device C can access network 50::/64 connected to Device A.
[DeviceB-security-policy-ipv6] rule name trust-untrust
[DeviceB-security-policy-ipv6-3-trust-untrust] source-zone trust
[DeviceB-security-policy-ipv6-3-trust-untrust] destination-zone untrust
[DeviceB-security-policy-ipv6-3-trust-untrust] source-ip-subnet 9:: 64
[DeviceB-security-policy-ipv6-3-trust-untrust] destination-ip-subnet 50:: 64
[DeviceB-security-policy-ipv6-3-trust-untrust] action pass
[DeviceB-security-policy-ipv6-3-trust-untrust] quit
[DeviceB-security-policy-ipv6] quit
4. Configure IBGP:
[DeviceB] bgp 65009
[DeviceB-bgp-default] peer 9::2 as-number 65009
[DeviceB-bgp-default] address-family ipv6
[DeviceB-bgp-default-ipv6] peer 9::2 enable
[DeviceB-bgp-default-ipv6] quit
[DeviceC] bgp 65009
[DeviceC-bgp-default] peer 9::1 as-number 65009
[DeviceC-bgp-default] address-family ipv6
[DeviceC-bgp-default-ipv6] peer 9::1 enable
5. Configure EBGP:
[DeviceA] bgp 65008
[DeviceA-bgp-default] peer 10::1 as-number 65009
[DeviceA-bgp-default] address-family ipv6
[DeviceA-bgp-default-ipv6] peer 10::1 enable
[DeviceB-bgp-default] peer 10::2 as-number 65008
[DeviceB-bgp-default-ipv6] peer 10::2 enable
6. Inject network routes to the BGP routing table:
[DeviceA-bgp-default-ipv6] network 10:: 64
[DeviceA-bgp-default-ipv6] network 50:: 64
[DeviceA-bgp-default-ipv6] quit
[DeviceB-bgp-default-ipv6] network 10:: 64
[DeviceB-bgp-default-ipv6] network 9:: 64
[DeviceC-bgp-default-ipv6] network 9:: 64
[DeviceC-bgp-default-ipv6] quit
# Display IPv6 BGP peer information on Device B.
[DeviceB] display bgp peer ipv6
BGP local router ID: 2.2.2.2
Local AS number: 65009
Total number of peers: 2 Peers in established state: 2
9::2 65009 41 43 0 1 00:29:00 Established
10::2 65008 38 38 0 2 00:27:20 Established
The output shows that Device A and Device B have established an EBGP connection, and Device B and Device C have established an IBGP connection.
# Display IPv6 BGP routing table information on Device A.
[DeviceA] display bgp routing-table ipv6
* >e Network : 9:: PrefixLen : 64
NextHop : 10::1 LocPrf :
PrefVal : 0 OutLabel : NULL
MED : 0
Path/Ogn: 65009i
* > Network : 10:: PrefixLen : 64
NextHop : :: LocPrf :
MED : 0
Path/Ogn: i
* e Network : 10:: PrefixLen : 64
MED : 0
Path/Ogn: 65009i
* > Network : 50:: PrefixLen : 64
MED : 0
Path/Ogn: i
The output shows that Device A has learned routing information of AS 65009.
# Display IPv6 BGP routing table information on Device C.
[DeviceC] display bgp routing-table ipv6
* > Network : 9:: PrefixLen : 64
MED : 0
Path/Ogn: i
* i Network : 9:: PrefixLen : 64
NextHop : 9::1 LocPrf : 100
MED : 0
Path/Ogn: i
* >i Network : 10:: PrefixLen : 64
MED : 0
Path/Ogn: i
* >i Network : 50:: PrefixLen : 64
NextHop : 10::2 LocPrf : 100
MED : 0
Path/Ogn: 65008i
The output shows that Device C has learned the route 50::/64.
# Verify that Device C can ping hosts on network 50::/64.
[DeviceC]ping ipv6 50::1
Ping6(56 data bytes) 9::2 --> 50::1, press CTRL+C to break
56 bytes from 50::1, icmp_seq=0 hlim=63 time=1.000 ms
56 bytes from 50::1, icmp_seq=1 hlim=63 time=1.000 ms
56 bytes from 50::1, icmp_seq=2 hlim=63 time=2.000 ms
56 bytes from 50::1, icmp_seq=3 hlim=63 time=1.000 ms
56 bytes from 50::1, icmp_seq=4 hlim=63 time=1.000 ms
--- Ping6 statistics for 50::1 ---
round-trip min/avg/max/std-dev = 1.000/1.200/2.000/0.400 ms
Troubleshooting BGP
State of the connection to a peer cannot become established
Symptom
The display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command output shows that the state of the connection to a peer cannot become established.
Analysis
To become BGP peers, any two routers must establish a TCP connection using port 179 and exchange OPEN messages successfully.
Solution
1. To resolve the problem:
a. Use the display current-configuration command to verify the current configuration, and verify that the peer's AS number is correct.
b. Use the display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command to verify that the peer's IP/IPv6 address is correct.
c. If a loopback interface is used, verify that the loopback interface is specified with the peer connect-interface command.
d. If the peer is a non-direct EBGP peer, verify that the peer ebgp-max-hop command is configured.
e. If the peer ttl-security hops command is configured, verify that the command is configured on the peer. Verify that the hop-count values configured on them are greater than the number of hops between them.
f. Verify that a valid route to the peer is available.
g. Use the ping command to verify the connectivity to the peer.
h. Use the display tcp verbose or display ipv6 tcp verbose command to verify the TCP connection.
i. Verify that no ACL rule is applied to disable TCP port 179.
2. If the problem persists, contact H3C Support.
Configuring large-scale BGP networks
Large-scale BGP network configuration tasks at a glance
To configure large-scale BGP networks, perform the following tasks:
· Configuring BGP route dampening
· Configuring BGP route reflection
· Configuring BGP confederation settings
¡ Configuring a BGP confederation
¡ (Optional.) Configuring confederation compatibility
Route dampening enables BGP to not select unstable routes as optimal routes.
This feature applies to EBGP routes but not to IBGP routes.
If an EBGP peer goes down after you configure this feature, routes coming from the peer are dampened but not deleted.
1. Enter system view.
address-family ipv4 multicast
3. Configure BGP route dampening.
By default, BGP route dampening is not configured.
address-family ipv6 multicast
3. Configure IPv6 BGP route dampening.
By default, IPv6 BGP route dampening is not configured.
Configuring BGP communities
By default, a router does not advertise the COMMUNITY or extended community attribute to its peers or peer groups. When the router receives a route carrying the COMMUNITY or extended community attribute, it removes the attribute before advertising the route to other peers or peer groups.
Perform this task to enable a router to advertise the COMMUNITY or extended community attribute to its peers for route filtering and control. You can also use a routing policy to add or modify the COMMUNITY or extended community attribute for specific routes. For more information about routing policy, see "Configuring routing policies."
2. Create a routing policy and a node, and enter routing policy node view.
For more information about this command, see routing policy commands in Layer 3—IP Routing Command Reference.
3. (Optional.) Configure if-match clauses as BGP route match criteria.
The routing policy can configure the COMMUNITY attribute of BGP routes only when these routes match a permit node.
For more information about if-match clauses, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
4. Configure the COMMUNITY attribute and extended community attribute of BGP routes.
¡ Set the COMMUNITY attribute for BGP routes.
¡ Delete COMMUNITY attribute values from BGP routes.
By default, no COMMUNITY attribute value is deleted from BGP routes.
¡ Set the RT extended community attribute for BGP routes.
¡ Set the color extended community attribute for BGP routes.
apply extcommunity color color [ additive ]
For more information about these commands, see routing policy commands in Layer 3—IP Routing Command Reference.
5. Return to system view.
6. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
7. Advertise the COMMUNITY attribute to a peer or peer group.
By default, the COMMUNITY attribute is not advertised.
8. Advertise the extended community attribute to a peer or peer group.
By default, the extended community attribute is not advertised.
9. Apply a routing policy to routes advertised to a peer or peer group.
By default, no routing policy is applied.
6. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
Configuring a BGP route reflector
Perform this task to configure a BGP route reflector and its clients. The route reflector and its clients automatically form a cluster identified by the router ID of the route reflector. The route reflector forwards route updates among its clients.
To improve availability, you can specify multiple route reflectors for a cluster. The route reflectors in the cluster must have the same cluster ID to avoid routing loops.
When a route reflector connects to multiple clusters, you can configure different cluster IDs for different peers or peer groups.
You only need to configure BGP route reflection on the device that acts as a route reflector. Other devices do not need to know the role of the local device in route reflection.
After you configure a device as a route reflector, it advertises routes as follows:
· Advertises routes received from a non-client IBGP peer to all clients.
· Advertises routes received from an IBGP peer that acts as a client to all peers.
· Advertises routes received from an EBGP peer to all peers.
By default, the route reflector does not change the attributes of routes before route reflection to avoid routing loops. When you replan network traffic, you can perform this task to allow the route reflector to change the attributes of the routes to be reflected.
After using the reflect change-path-attribute command, you can use the peer route-policy export command to apply a routing policy that can change the attributes of the routes to be reflected. The following apply commands can define how the routing policy modifies route attributes:
· Use apply origin to change the ORIGIN attribute of routes.
· Use apply ip-address next-hop or apply ipv6 next-hop to change the NEXT_HOP attribute of routes.
· Use apply cost to change the MED attribute of routes.
· Use apply local-preference to change the local preference for routes.
· Use apply community to configure the COMMUNITY attribute of routes. For BGP to advertise the COMMUNITY attribute to a peer or peer group, use the peer advertise-community command.
· Use apply comm-list delete to delete COMMUNITY attribute values from routes.
· Use apply extcommunity to configure the RT extended community attribute of routes. For BGP to advertise the extended community attribute to a peer or peer group, use the peer advertise-ext-community command.
· Use apply extcommunity color to configure the color extended community attribute of routes.
For more information about the apply commands, see routing policy commands in Layer 3—IP Routing Command Reference.
3. Configure the router as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
4. (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
5. (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
6. (Optional.) Allow the RR to change the attributes of routes to be reflected.
By default, the RR cannot change the attributes of routes to be reflected.
This command is not supported in BGP IPv4 multicast address family view.
This command is not supported in BGP-VPN IPv6 unicast address family view.
This command is not supported in BGP IPv6 multicast address family view.
Ignoring the ORIGINATOR_ID attribute
By default, BGP drops incoming route updates whose ORIGINATOR_ID attribute is the same as the local router ID. Some special networks such as firewall networks require BGP to accept such route updates. To meet the requirement, you must configure BGP to ignore the ORIGINATOR_ID attribute.
Make sure this command does not result in a routing loop.
After you execute this command, BGP also ignores the CLUSTER_LIST attribute.
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
¡ Enter BGP-VPN instance view.
3. Ignore the ORIGINATOR_ID attribute.
By default, BGP does not ignore the ORIGINATOR_ID attribute.
peer { group-name | ipv6-address [ prefix-length ] } ignore-originatorid
About BGP confederation
BGP confederation provides another way to reduce IBGP connections in an AS.
A confederation contains sub-ASs. In each sub-AS, IBGP peers are fully meshed. Sub-ASs establish EBGP connections in between.
2. Enter BGP instance view.
3. Configure a confederation ID.
confederation id as-number
By default, no confederation ID is configured.
From an outsider's perspective, the sub-ASs of the confederation is a single AS, which is identified by the confederation ID.
4. Specify confederation peer sub-ASs in the confederation.
By default, no confederation peer sub-ASs are specified.
A confederation can contain a maximum of 32 sub-ASs. The AS number of a sub-AS is effective only in the confederation.
If the router needs to establish EBGP connections to other sub-ASs, you must specify the peering sub-ASs in the confederation.
If any routers in the confederation do not comply with RFC 3065, enable confederation compatibility to allow the router to work with those routers.
3. Enable confederation compatibility.
confederation nonstandard
By default, confederation compatibility is disabled.
Display and maintenance commands for large-scale BGP network configuration
Task |
Command |
Display BGP IPv4 unicast route dampening parameter information. |
display bgp [ instance instance-name ] dampening parameter ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] |
Display dampened BGP IPv4 unicast route information. |
display bgp [ instance instance-name ] routing-table dampened ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] |
Task |
Command |
Display BGP IPv6 unicast route dampening parameter information. |
display bgp [ instance instance-name ] dampening parameter ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] |
Display dampened BGP IPv6 unicast route information. |
display bgp [ instance instance-name ] routing-table dampened ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] |
Task |
Command |
Display BGP IPv4 multicast route dampening parameter information. |
display bgp [ instance instance-name ] dampening parameter ipv4 multicast |
Display dampened BGP IPv4 multicast route information. |
display bgp [ instance instance-name ] routing-table dampened ipv4 multicast |
Task |
Command |
Display BGP IPv6 multicast route dampening parameter information. |
display bgp [ instance instance-name ] dampening parameter ipv6 multicast |
Display dampened BGP IPv6 multicast route information. |
display bgp [ instance instance-name ] routing-table dampened ipv6 multicast |
Controlling BGP path selection
BGP path selection control tasks at a glance
By configuring BGP path attributes, you can control BGP path selection.
To control BGP path selection, perform the following tasks:
1. Configuring preferences for BGP routes
2. Configuring the NEXT_HOP attribute
3. Setting a preferred value for received routes
4. Configuring the default local preference
5. Configuring the AS_PATH attribute
¡ Permitting local AS number to appear in routes from a peer or peer group
¡ Ignoring the AS_PATH attribute during optimal route selection
¡ Advertising a fake AS number to a peer or peer group
¡ Removing private AS numbers from sent updates
¡ Ignoring the first AS number of EBGP route updates
6. Configuring the MED attribute
¡ Configuring the default MED value
¡ Enabling MED comparison for routes from different ASs
¡ Enabling MED comparison for routes on a per-AS basis
¡ Enabling MED comparison for routes from confederation peers
7. Preferring routes learned from a peer or peer group during optimal route selection
8. Ignoring IGP metrics during optimal route selection
9. Ignoring router IDs during optimal route selection
Routing protocols each have a default preference. If they find multiple routes destined for the same network, the route found by the routing protocol with the highest preference is selected as the optimal route. A smaller preference value indicates a higher preference.
You can use the preference command to modify preferences for EBGP, IBGP, and local BGP routes, or use a routing policy to set a preference for matching routes. For routes not matching the routing policy, the default preference applies.
If a device has an EBGP route and a local BGP route to reach the same destination, it does not select the EBGP route because the EBGP route has a lower preference than the local BGP route by default. You can use the network short-cut command to configure the EBGP route as a shortcut route that has the same preference as the local BGP route. The EBGP route will more likely become the optimal route.
Procedure (IPv4 unicast/multicast address family)
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
¡ Enter BGP IPv4 unicast address family view.
¡ Enter BGP-VPN IPv4 unicast address family view.
¡ Enter BGP IPv4 multicast address family view.
3. Configure preferences for EBGP, IBGP, and local BGP routes.
By default, the preferences for EBGP, IBGP, and local BGP routes are 255, 255, and 130, respectively.
4. (Optional.) Configure an EBGP route as a shortcut route.
By default, an EBGP route has a preference of 255.
Procedure (IPv6 unicast/multicast address family)
2. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
¡ Enter BGP IPv6 unicast address family view.
¡ Enter BGP-VPN IPv6 unicast address family view.
¡ Enter BGP IPv6 multicast address family view.
By default, a BGP router does not set itself as the next hop for routes advertised to an IBGP peer or peer group. In some cases, however, you must configure the advertising router as the next hop to ensure that the BGP peer can find the correct next hop.
For example, as shown in Figure 14, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. If Router C has no route destined for IP address 1.1.1.1/24, you must configure Router B to set itself 3.1.1.1/24 as the next hop for the network 2.1.1.1/24 advertised to Router C.
Figure 14 NEXT_HOP attribute configuration
If a BGP router has two peers on a broadcast network, it does not set itself as the next hop for routes sent to an EBGP peer by default. As shown in Figure 15, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. They are on the same broadcast network 1.1.1.0/24. When Router B sends EBGP routes to Router A, it does not set itself as the next hop by default. However, you can configure Router B to set it (1.1.1.2/24) as the next hop for routes sent to Router A by using the peer next-hop-local command as needed.
Figure 15 NEXT_HOP attribute configuration
If you have configured BGP load balancing, the device sets itself as the next hop for routes sent to an IBGP peer or peer group regardless of whether the peer next-hop-local command is configured.
3. Specify the device as the next hop for routes sent to a peer or peer group.
By default, the device sets itself as the next hop for routes sent to an EBGP peer or peer group. However, it does not set itself as the next hop for routes sent to an IBGP peer or peer group. When the device sends equal-cost routes to IBGP peers, it sets the local device IP as the next hop of the optimal route among these routes.
peer { group-name | ipv6-address [ prefix-length ] } next-hop-local
Perform this task to set a preferred value for specific routes to control BGP path selection.
Among multiple routes that have the same destination/mask and are learned from different peers, the one with the greatest preferred value is selected as the optimal route.
3. Set a preferred value for routes received from a peer or peer group.
By default, the preferred value is 0 for routes received from a peer or peer group.
The ipv6-address [ prefix-length ] argument is supported only in BGP IPv4 unicast address family view.
The ipv4-address [ mask-length ] argument is supported only in BGP IPv6 unicast address family view.
The local preference is used to determine the optimal route for traffic leaving the local AS. When a BGP router obtains from several IBGP peers multiple routes to the same destination, but with different next hops, it selects the route with the highest local preference as the optimal route.
This task allows you to specify the default local preference for routes sent to IBGP peers.
3. Configure the default local preference.
The default local preference is 100.
In general, BGP checks whether the AS_PATH attribute of a route from a peer contains the local AS number. If yes, it discards the route to avoid routing loops.
In certain network environments, however, the AS_PATH attribute of a route from a peer must be allowed to contain the local AS number. Otherwise, the route cannot be advertised correctly.
3. Permit the local AS number to appear in routes from a peer or peer group and set the appearance times.
By default, the local AS number is not allowed in routes from a peer or peer group.
3. Configure BGP to ignore the AS_PATH attribute during optimal route selection.
bestroute as-path-neglect [ all-instance ]
By default, BGP includes the AS_PATH attribute in optimal route selection.
The all-instance keyword is supported only in BGP instance view.
After you move a BGP router from an AS to another AS (from AS 2 to AS 3 for example), you have to modify the AS number of the router on all its EBGP peers. To avoid such modifications, you can configure the router to advertise a fake AS number 2 to its EBGP peers so that the EBGP peers still think that Router A is in AS 2.
This command applies only to EBGP peers or EBGP peer groups.
3. Advertise a fake AS number to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } fake-as as-number
By default, no fake AS number is advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } fake-as as-number
Configuring AS number substitution
To use EBGP between PE and CE in MPLS L3VPN, VPN sites in different geographical areas should have different AS numbers. Otherwise, BGP discards route updates containing the local AS number. If two CEs connected to different PEs use the same AS number, you must configure AS number substitution on each PE. This substitution can replace the AS number in route updates originated by the remote CE as its own AS number before advertising them to the connected CE.
Figure 16 AS number substitution configuration (in an IPv4 network)
As shown in Figure 16, CE 1 and CE 2 use the same AS number 800. To ensure bidirectional communication between the two sites, configure AS number substitution on PE 2. PE 2 replaces AS 800 with AS 100 for the BGP route update originated from CE 1 before advertising it to CE 2. Perform the same configuration on PE 1.
Do not configure AS number substitution in normal circumstances. Otherwise, routing loops might occur.
3. Configure AS number substitution for a peer or peer group.
By default, AS number substitution is not configured.
peer { group-name | ipv6-address [ prefix-length ] } substitute-as
Private AS numbers are typically used in test networks, and should not be transmitted in public networks. The range of private AS numbers is from 64512 to 65535.
Perform this task to enable BGP to remove private AS numbers from the AS_PATH attribute of updates sent to a peer or peer group.
This feature is applicable only to EBGP peers or peer groups.
3. Configure BGP to remove private AS numbers from the AS_PATH attribute of updates sent to an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
By default, BGP checks the first AS number of an EBGP-learned route update. If the first AS number is neither the AS number of the BGP peer nor a private AS number, the BGP router disconnects the BGP session to the peer.
Ignoring the first AS number of all EBGP route updates
3. Enable BGP to ignore the first AS number of EBGP route updates.
ignore-first-as
By default, BGP checks the first AS number of EBGP-learned route updates.
Ignoring the first AS number of EBGP route updates received from a peer or peer group (IPv4 unicast/multicast address family)
3. Enable BGP to ignore the first AS number of EBGP route updates received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } ignore-first-as
Ignoring the first AS number of EBGP route updates received from a peer or peer group (IPv6 unicast/multicast address family)
peer { group-name | ipv6-address [ prefix-length ] } ignore-first-as
About the MED attribute
BGP uses MED to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes with the same destination but with different next hops, it selects the route with the smallest MED value as the optimal route if other conditions are the same.
Configuring the default MED value (IPv4 unicast/multicast address family)
3. Configure the default MED value.
default med med-value
The default MED value is 0.
Configuring the default MED value (IPv6 unicast/multicast address family)
By default, BGP only compares the MEDs of routes from the same AS. This task enables BGP to compare the MEDs of routes from different ASs.
3. Enable MED comparison for routes from different ASs.
compare-different-as-med
By default, MED comparison for routes from different ASs is disabled.
This task enables BGP to compare the MEDs of routes from an AS.
Figure 17 Route selection based on MED (in an IPv4 network)
As shown in Figure 17, Device D establishes indirect EBGP peer relationships with Device A, Device B, and Device C, and learns addresses 1.1.1.1/32, 2.2.2.2/32, and 3.3.3.3/32 through OSPF. The following output shows the routing information on Device D.
1.1.1.1/32 O_INTRA 10 10 11.1.1.2 Interface D1
2.2.2.2/32 O_INTRA 10 20 12.1.1.2 Interface D2
3.3.3.3/32 O_INTRA 10 30 13.1.1.2 Interface D3
Device D learns network 10.0.0.0 from both Device A and Device B. Because the route learned from Device B has a smaller IGP metric, the route is optimal. The following output shows the BGP routing table on Device D.
*>e 10.0.0.0 2.2.2.2 50 0 300 400e
* e 3.3.3.3 50 0 200 400e
When Device D learns network 10.0.0.0 from Device C, it compares the route with the optimal route in its routing table. Because Device C and Device B reside in different ASs, BGP does not compare the MEDs of the two routes. The route from Device C has a smaller IGP metric than the route from Device B, so the route from Device C becomes optimal. The following output shows the BGP routing table on Device D.
*>e 10.0.0.0 1.1.1.1 60 0 200 400e
* e 10.0.0.0 2.2.2.2 50 0 300 400e
However, Device C and Device A reside in the same AS, and Device C has a greater MED, so network 10.0.0.0 learned from Device C should not be optimal.
To avoid this problem, you can configure the bestroute compare-med command to enable MED comparison for routes from the same AS on Device D. After that, Device D puts the routes received from each AS into a group, selects the route with the lowest MED from each group, and compares routes from different groups. Network 10.0.0.0 learned from Device B is the optimal route. The following output shows the BGP routing table on Device D.
* e 1.1.1.1 60 0 200 400e
3. Enable MED comparison for routes on a per-AS basis.
bestroute compare-med [ all-instance ]
By default, MED comparison for routes on a per-AS basis is disabled.
This task enables BGP to compare the MEDs of routes received from confederation peers. However, if a route received from a confederation peer has an AS number that does not belong to the confederation, BGP does not compare the route with other routes. For example, a confederation has three AS numbers 65006, 65007, and 65009. BGP receives three routes from different confederation peers. The AS_PATH attributes of these routes are 65006 65009, 65007 65009, and 65008 65009, and the MED values of them are 2, 3, and 1. Because the third route's AS_PATH attribute contains AS number 65008 that does not belong to the confederation, BGP does not compare it with other routes. As a result, the first route becomes the optimal route.
3. Enable MED comparison for routes from confederation peers.
bestroute med-confederation [ all-instance ]
By default, MED comparison for routes from confederation peers is disabled.
By default, BGP selects an optimal route based on rules in "BGP route selection." It does not prefer routes learned from any peer or peer groups during optimal route selection.
After you perform this task, routes learned from the specified peer or peer group take precedence over other routes if these routes have the same prefix. BGP uses this rule to continue route selection if it fails to select an optimal route by using the peer type selection rule. If BGP still fails route selection, it uses the IGP metric selection rule to select an optimal route.
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv4 multicast address family view:
3. Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority
By default, BGP does not prefer routes learned from any peer or peer groups during optimal route selection.
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv6 multicast address family view:
By default, BGP includes IGP metrics in optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest IGP metric as the optimal route.
Perform this task to enable BGP to ignore IGP metrics during optimal route selection.
3. Configure BGP to ignore IGP metrics during optimal route selection.
bestroute igp-metric-ignore [ all-instance ]
By default, BGP compares router IDs during optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest router ID as the optimal route.
Perform this task to enable BGP to ignore router IDs during optimal route selection.
3. Enable BGP to ignore router IDs during optimal route selection.
bestroute router-id-ignore [ all-instance ]
Display and maintenance commands for BGP path selection control
Task |
Command |
Task |
Command |
Task |
Command |
Task |
Command |
Tuning and optimizing BGP networks
BGP network tuning and optimization tasks at a glance
To tune and optimize BGP networks, perform the following tasks:
· Establishing and resetting EBGP sessions
¡ Enabling BGP to establish an EBGP session over multiple hops
¡ Enabling immediate re-establishment of direct EBGP connections upon link failure
· Establishing, terminating, and resetting BGP sessions
¡ Enabling 4-byte AS number suppression
¡ Disabling BGP session establishment
· Configuring BGP load balancing
· Configuring the BGP Additional Paths feature
· Protecting an EBGP peer when memory usage reaches level 2 threshold
· Specifying the longest match principle for next hop recursion
· Flushing the suboptimal BGP route to the RIB
· Disabling BGP from flushing specific routes to the routing table
· Specifying a label allocation mode
· Recursing unlabeled public BGP routes to LSPs
To establish an EBGP session, two routers must have a direct physical link and use directly connected interfaces. If no direct link is available, you must use the peer ebgp-max-hop command to enable BGP to establish an EBGP session over multiple hops and specify the maximum hops.
When the BGP GTSM feature is enabled, two peers can establish an EBGP session after passing GTSM check, regardless of whether the maximum number of hops is reached.
To ensure correct BGP route recursion, do not specify any direct EBGP peer or peer group when you configure the peer ebgp-max-hop command.
3. Enable BGP to establish an EBGP session to an indirectly connected peer or peer group and specify the maximum hop count.
peer { group-name | ipv4-address [ mask-length ] } ebgp-max-hop [ hop-count ]
By default, BGP cannot establish an EBGP session to an indirectly connected peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } ebgp-max-hop [ hop-count ]
With this feature disabled, when the link to a directly connected EBGP peer goes down, the router does not re-establish a session to the peer until the hold time timer expires. This feature enables BGP to immediately discover the link failure and recreate the session in that situation. When this feature is disabled, route flapping does not affect EBGP session state.
3. Enable immediate re-establishment of direct EBGP connections upon link failure.
ebgp-interface-sensitive
By default, immediate re-establishment of direct EBGP connections is enabled.
BGP supports 4-byte AS numbers. The 4-byte AS number occupies four bytes, in the range of 1 to 4294967295. By default, a device sends an OPEN message to the peer device for session establishment. The OPEN message indicates that the device supports 4-byte AS numbers. If the peer device supports 2-byte AS numbers instead of 4-byte AS numbers, the session cannot be established. To resolve this issue, enable the 4-byte AS number suppression feature. The device then sends an OPEN message to inform the peer that it does not support 4-byte AS numbers, so the BGP session can be established.
If the peer device supports 4-byte AS numbers and the peer AS number is larger than 65535, do not enable the 4-byte AS number suppression feature. Otherwise, the BGP session cannot be established.
3. Enable 4-byte AS number suppression.
peer { group-name | ipv4-address [ mask-length ] } capability-advertise suppress-4-byte-as
By default, 4-byte AS number suppression is disabled.
peer { group-name | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
About disabling BGP session establishment
This task enables you to temporarily tear down BGP sessions to a peer/peer group. You can perform network upgrade and maintenance without needing to delete and reconfigure the peers and peer groups. To recover the sessions, execute the undo peer ignore command.
Disabling BGP session establishment with a peer or peer group (IPv4 unicast/multicast address family)
3. Disable BGP session establishment with a peer or peer group.
By default, BGP can establish a session to a peer or peer group.
CAUTION: · If a session has been established to a peer, executing the peer ignore command for the peer tears down the session and clears all related routing information. · If sessions have been established to a peer group, executing the peer ignore command for the peer group tears down the sessions to all peers in the group and clears all related routing information. |
Disabling BGP session establishment with a peer or peer group (IPv6 unicast/multicast address family)
Configuring BGP soft-reset
About BGP soft-reset
After you modify the route selection policy, for example, modify the preferred value, you must reset BGP sessions to apply the new policy. The reset operation tears down and re-establishes BGP sessions.
To avoid tearing down BGP sessions, you can use one of the following soft-reset methods to apply the new policy:
· Enabling route refresh—The BGP router advertises a ROUTE-REFRESH message to the specified peer, and the peer resends its routing information to the router. After receiving the routing information, the router filters the routing information by using the new policy.
This method requires that both the local router and the peer support route refresh.
· Saving updates—Use the peer keep-all-routes command to save all route updates from the specified peer. After modifying the route selection policy, filter routing information by using the new policy.
This method does not require that the local router and the peer support route refresh but it uses more memory resources to save routes.
· Manual soft-reset—Use the refresh bgp command to enable BGP to send local routing information or advertise a ROUTE-REFRESH message to the specified peer. The peer then resends its routing information. After receiving the routing information, the router filters the routing information by using the new policy.
Enabling route refresh (IPv4 unicast/multicast address family)
3. Enable BGP route refresh for a peer or peer group.
¡ Enable BGP route refresh for the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } capability-advertise route-refresh
¡ Enable the BGP route refresh, multi-protocol extension, and 4-byte AS number features for the specified peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] } capability-advertise conventional
By default, the BGP route refresh, multi-protocol extension, and 4-byte AS number features are enabled.
Enabling route refresh (IPv6 unicast/multicast address family)
peer { group-name | ipv6-address [ prefix-length ] } capability-advertise route-refresh
undo peer { group-name | ipv6-address [ prefix-length ] } capability-advertise conventional
Saving updates (IPv4 unicast/multicast address family)
3. Save all route updates from the peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
By default, route updates from peers and peer groups are not saved.
This command takes effect only for the routes received after this command is executed.
Saving updates (IPv6 unicast/multicast address family)
Configuring manual soft-reset (IPv4 unicast/multicast address family)
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise route-refresh
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise conventional
4. Perform manual soft-reset:
a. Return to system view.
b. Return to user view.
c. Perform manual soft-reset.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
refresh bgp [ instance instance-name ] ipv6-address [ mask-length ] { export | import } ipv4 [ unicast ]
Configuring manual soft-reset (IPv6 unicast/multicast address family)
refresh bgp [ instance instance-name ] { ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
refresh bgp [ instance instance-name ] ipv4-address [ mask-length ] { export | import } ipv6 [ unicast ]
Perform this task to specify the maximum number of BGP ECMP routes for load balancing.
¡ Execute the following commands in sequence to enter BGP-VPN instance view:
3. (Optional.) Enable BGP to ignore IGP metrics during optimal route selection.
By default, BGP compares IGP metrics during optimal route selection, and selects the route with the smallest IGP metric as the optimal route.
BGP cannot use routes with different IGP metrics to implement load balancing. To resolve this issue, you can use this command.
4. Return to system view.
¡ In BGP instance view:
¡ In BGP-VPN instance view:
5. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
6. Specify the maximum number of BGP ECMP routes for load balancing.
balance [ ebgp | eibgp | ibgp ] number
By default, load balancing is disabled.
7. (Optional.) Enable BGP to ignore the AS_PATH attribute when it implements load balancing.
balance as-path-neglect
By default, BGP does not ignore the AS_PATH attribute when it implements load balancing.
8. (Optional.) Enable BGP to perform load balancing for routes that have different AS_PATH attributes of the same length.
balance as-path-relax
By default, BGP cannot perform load balancing for routes that have different AS_PATH attributes of the same length.
5. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
On a large-scale network, a route reflector can receive multiple BGP routes with the same prefix. By default, BGP advertises only one optimal route. When the optimal route fails, traffic forwarding will be interrupted until route convergence completes.
To resolve this issue, configure the BGP Additional Paths (Add-Path) feature on the route reflector. This feature enables the device to advertise multiple routes with the same prefix to a peer or peer group. On receipt of these routes, the peer generates multiple links to the same destination network. You can use these links to implement load balancing with the balance command or configure backup routes. When the optimal link fails, another link can take over to forward traffic, which enhances the reliability of data transmission.
BGP Additional Paths capabilities include the sending capability and the receiving capability. You can enable either of the sending and receiving capabilities or both on a peer. For two BGP peers to successfully negotiate the Additional Paths capabilities, make sure one end has the sending capability and the other end has the receiving capability.
Procedure (IPv4 unicast address family)
2. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
3. Configure the BGP Additional Paths capabilities.
peer { group-name | ipv4-address [ make-length ] } additional-paths { receive | send } *
By default, no BGP Additional Paths capabilities are configured.
4. Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv4-address [ make-length ] } advertise additional-paths best number
By default, a maximum number of one Add-Path optimal route can be advertised to a peer or peer group.
5. Set the maximum number of Add-Path optimal routes that can be advertised to all peers.
By default, a maximum number of one Add-Path optimal route can be advertised to all peers.
Procedure (IPv6 unicast address family)
2. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
¡ In BGP IPv6 unicast address family view:
¡ In BGP-VPN IPv6 unicast address family view:
peer { group-name | ipv6-address [ prefix-length ] } additional-paths { receive | send } *
peer { group-name | ipv6-address [ prefix-length ] } advertise additional-paths best number
Memory usage includes the following threshold levels: normal, level 1, level 2, and level 3. When the level 2 threshold is reached, BGP periodically tears down an EBGP session to release memory resources until the memory usage falls below the level 2 threshold. You can configure this feature to avoid tearing down the EBGP session to an EBGP peer when the memory usage reaches the level 2 threshold.
For more information about memory usage thresholds, see device management configuration in Fundamentals Configuration Guide.
3. Configure BGP to protect an EBGP peer or peer group when the memory usage reaches level 2 threshold.
peer { group-name | ipv4-address [ mask-length ] } low-memory-exempt
By default, BGP periodically tears down an EBGP session to release memory resources when level 2 threshold is reached.
peer { group-name | ipv6-address [ prefix-length ] } low-memory-exempt
By default, BGP tears down an EBGP session to release memory resources periodically when level 2 threshold is reached.
By default, BGP first looks up in its directly connected routes for a recursive route during a route recursion. If no matching routes exist, BGP will look up in routes generated by all routing protocols based on the longest match principle. The device considers the next hop of a received BGP route as directly connected when the next hop belongs to the same subnet as a direct route. As a result, packet forwarding failure will occur when the device uses this BGP route to forward matching packets.
As shown in Figure 18, Device B has established an IBGP session to Device A and Device C respectively. All devices use a loopback interface as the source port for TCP connection. On receipt of BGP route 8.0.0.0/24 from Device C, Device B reflects the route to Device A. The addresses of the interfaces that connect Device A and Device B belong to subnet 3.3.0.0/16.
If the next hop information exchanged between IBGP peers remains unchanged, the next hop of BGP route 8.0.0.0/24 is 3.3.3.3. Device A considers 3.3.3.3 as a directly connected next hop because 3.3.3.3 belongs to subnet 3.3.0.0/16 and a direct route to 3.3.0.0/16 exists. Packet forwarding failure will occur if Device A forwards packets destined for subnet 8.0.0.0/24 over 3.3.3.3.
Figure 18 Next hop recursion error
To resolve this issue, you can specify the longest match principle for next hop recursion to ensure the recursive route is reachable. BGP will directly look up in routes generated by all routing protocols and select a matching route based on the longest match principle.
Procedure (IPv4 unicast)
3. Specify the longest match principle for BGP next hop recursion.
nexthop recursive-lookup longest-match [ route-policy route-policy-name ]
This command applies to all BGP routes received from peers in one of the following scenarios:
¡ The route-policy route-policy-name option is not specified.
¡ The specified routing policy does not exist.
Procedure (IPv6 unicast)
This feature flushes the suboptimal BGP route to the RIB when the following conditions are met:
· The optimal route is generated by the network command or is redistributed by the import-route command.
· The suboptimal route is received from a BGP peer.
After the suboptimal route is flushed to the RIB on a network, BGP immediately switches traffic to the suboptimal route when the optimal route fails.
For example, the device has a static route to the subnet 1.1.1.0/24 that has a higher priority than a BGP route. BGP redistributes the static route and receives a route to 1.1.1.0/24 from a peer. After the flush suboptimal-route command is executed, BGP flushes the received BGP route to the RIB as the suboptimal route. When the static route fails, BGP immediately switches traffic to the suboptimal route if inter-protocol FRR is enabled. For more information about inter-protocol FRR, see "Configuring basic IP routing."
2. Enter BGP view.
3. Flush the suboptimal BGP route to the RIB.
By default, BGP is disabled from flushing the suboptimal BGP route to the RIB, and only the optimal route is flushed to the RIB.
Perform this task to disable BGP from flushing routes that match the specified routing policy to the routing table.
This feature applies to the following scenarios:
· In an MPLS L3VPN network, all the optimal private BGP routes will be flushed to the routing table of a PE by default. You can configure this feature to prevent unnecessary routes from being flushed to the IP routing table and improve the forwarding performance of the PE.
· In a route reflection network, configure this feature to not flush specific BGP routes to the routing table of the RR. Then, the RR only advertises and receives routes but does not forward service traffic, which saves the system resources of the RR.
3. Disable BGP from flushing routes that match the specified routing policy to the routing table.
routing-table bgp-rib-only [ route-policy route-policy-name ]
By default, BGP flushes the optimal routes to the routing table.
BGP supports the following label allocation modes:
· Per-prefix—Allocates a label to each route prefix.
· Per-next-hop—Allocates a label to each next hop. This mode is applicable when the number of labels required by the per-prefix mode exceeds the maximum number of labels supported by the device.
· Per-VPN-instance—Allocates a label to each VPN instance. This mode is applicable when the number of labels required by the per-next-hop mode exceeds the maximum number of labels supported by the device.
When you specify the per-prefix or per-next-hop label allocation mode, you can execute the vpn popgo command to specify the POPGO forwarding mode on an egress PE. The egress PE will pop the label for each packet and forward the packet out of the interface corresponding to the label.
When you specify the per-VPN instance label allocation mode, do not execute the vpn popgo command because it is mutually exclusive with the label-allocation-mode per-vrf command. The egress PE will pop the label for each packet and forward the packet through the FIB table.
3. Specify a label allocation mode.
label-allocation-mode { per-prefix | per-vrf }
By default, BGP allocates labels on a per-next-hop basis.
CAUTION: A change to the label allocation mode enables BGP to re-advertise all routes, which will cause temporary service interruption. Use this feature with caution. |
To perform IP forwarding on customer packets, carrier network devices must learn a large number of routes. To reduce workload and save resources on carrier network devices, configure this feature to recurse unlabeled public BGP routes to LSPs on user access devices. This feature allows the carrier network devices to forward customer packets based on labels, without the need to learn customer network routes.
After you configure this feature, unlabeled public BGP routes will be preferentially recursed to LSPs. If a route fails to be recursed to an LSP, the route will be recursed to the IP next hop.
To recurse unlabeled public IPv6 BGP routes to IPv4 tunnels, you must configure the egress node to assign a non-null label to the penultimate hop.
3. Enter BGP IPv4 unicast address family view.
4. Recurse unlabeled public BGP routes to LSPs.
unicast-route recursive-lookup tunnel [ prefix-list ipv4-prefix-list-name ] [ tunnel-policy tunnel-policy-name ]
By default, unlabeled public BGP routes are recursed to IP next hops instead of LSPs.
3. Enter BGP IPv6 unicast address family view.
unicast-route recursive-lookup tunnel [ prefix-list ipv6-prefix-list-name ] [ tunnel-policy tunnel-policy-name ]
Display and maintenance commands for BGP network tuning and optimization
Resetting BGP sessions
CAUTION: A reset operation tears down BGP sessions for a short period of time. |
Execute reset commands in user view.
Task |
Command |
Reset BGP sessions for IPv4 unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] reset bgp [ instance instance-name ] ipv6-address [ prefix-length ] ipv4 [ unicast ] |
Reset BGP sessions for IPv4 multicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 multicast |
Reset BGP sessions for IPv6 unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] reset bgp [ instance instance-name ] ipv4-address [ mask-length ] ipv6 [ unicast ] |
Reset BGP sessions for IPv6 multicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 multicast |
Reset all BGP sessions. |
reset bgp [ instance instance-name ] all |
Configuring BGP security features
BGP security feature configuration tasks at a glance
To configure BGP security features, perform the following tasks:
· Enabling MD5 authentication for BGP peers
· Enabling keychain authentication for BGP peers
· Configuring IPsec for IPv6 BGP
MD5 authentication provides the following benefits:
· Peer authentication ensures that only BGP peers that have the same password can establish TCP connections.
· Integrity check ensures that BGP packets exchanged between peers are intact.
3. Enable MD5 authentication for a BGP peer group or peer.
peer { group-name | ipv4-address [ mask-length ] } password { cipher | simple } password
By default, MD5 authentication is disabled.
peer { group-name | ipv6-address [ prefix-length ] } password { cipher | simple } password
Keychain authentication enhances the security of BGP in the following ways:
· BGP peers can establish TCP connections only when they are both enabled with keychain authentication.
· The keys used by the BGP peers at the same time must have the same ID.
· The keys with the same ID must use the same authentication algorithm and key string.
For more information about keychains, see Security Configuration Guide.
Follow these restrictions and guidelines when you configure the algorithm and key ID in keychain authentication:
· BGP supports the HMAC-MD5, HMAC-SHA-256, HMAC-SM3, SM3, and MD5 algorithms. To configure an algorithm, execute the authentication-algorithm command.
· BGP supports key IDs in the range of 0 to 63. To configure a key ID, execute the key command.
3. Enable keychain authentication for a BGP peer or peer group.
peer { group-name | ip-address [ mask-length ] } keychain keychain-name
By default, keychain authentication is disabled.
peer { group-name | ipv6-address [ prefix-length ] } keychain keychain-name
Configuring GTSM for BGP
The Generalized TTL Security Mechanism (GTSM) protects a BGP session by comparing the TTL value in the IP header of incoming BGP packets against a valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded.
The valid TTL range is from 255 – the configured hop count + 1 to 255.
When GTSM is configured, the BGP packets sent by the device have a TTL of 255.
GTSM provides best protection for directly connected EBGP sessions, but not for multihop EBGP or IBGP sessions because the TTL of packets might be modified by intermediate devices.
When GTSM is configured, the local device can establish an EBGP session to the peer after both devices pass GTSM check, regardless of whether the maximum number of hops is reached.
To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values for them.
3. Configure GTSM for the specified BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } ttl-security hops hop-count
By default, GTSM is disabled.
peer { group-name | ipv6-address [ prefix-length ] } ttl-security hops hop-count
Perform this task to configure IPsec for IPv6 BGP. IPsec can provide privacy, integrity, and authentication for IPv6 BGP packets exchanged between BGP peers.
When two IPv6 BGP peers are configured with IPsec (for example, Device A and Device B), Device A encapsulates an IPv6 BGP packet with IPsec before sending it to Device B. If Device B successfully receives and de-encapsulates the packet, it establishes an IPv6 BGP peer relationship with Device A and learns IPv6 BGP routes from Device A. If Device B receives but fails to de-encapsulate the packet, or receives a packet not protected by IPsec, it discards the packet.
2. Configure an IPsec transform set and a manual IPsec profile.
See IPsec configuration in VPN Configuration Guide.
3. Enter BGP instance view or BGP-VPN instance view.
4. Apply the IPsec profile to an IPv6 BGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } ipsec-profile profile-name
By default, no IPsec profile is configured for any IPv6 BGP peer or peer group.
This command supports only IPsec profiles in manual mode.
Improving BGP network reliability
BGP network reliability improvement tasks at a glance
To improve the BGP network reliability, perform the following tasks:
· Configuring BGP maintenance features
Configuring BGP GR
Graceful Restart (GR) ensures forwarding continuous when a routing protocol restarts or an active/standby switchover occurs. Two routers are required to complete a GR process. The following are router roles in a GR process:
· GR restarter—Performs GR upon a BGP restart or active/standby switchover.
· GR helper—Helps the GR restarter to complete the GR process.
A device can act as a GR restarter and GR helper at the same time.
BGP GR works as follows:
1. The BGP GR restarter and helper exchange OPEN messages for GR capability negotiation. If both parties have the GR capability, they establish a GR-capable session. The GR restarter sends the GR timer set by the graceful-restart timer restart command to the GR helper in an OPEN message.
2. When an active/standby switchover occurs or BGP restarts, the GR restarter does not remove existing BGP routes from Routing Information Base (RIB) and Forwarding Information Base (FIB). It still uses these routes for packet forwarding, and it starts the RIB purge timer (set by the graceful-restart timer purge-time command). The GR helper marks all routes learned from the GR restarter as stale instead of deleting them. It continues to use these routes for packet forwarding. During the GR process, packet forwarding is not interrupted.
3. After the active/standby switchover or BGP restart completes, the GR restarter re-establishes a BGP session to the GR helper. If the BGP session fails to be established after both the GR timer and the extra timer to wait expire, the GR helper removes the stale routes. To set the extra timer to wait after the restart timer expires, execute the peer graceful-restart timer restart extra command.
4. If the BGP session is established, routing information is exchanged for the GR restarter to retrieve route entries and for the GR helper to recover stale routes.
5. Both the GR restarter and the GR helper start the End-Of-RIB marker waiting timer.
The End-Of-RIB marker waiting time is set by the graceful-restart timer wait-for-rib command. If routing information exchange is not completed within the time, the GR restarter does not receive new routes. The GR restarter updates the RIB with the BGP routes already learned, and removes the aged routes from the RIB. The GR helper removes the stale routes.
6. The GR restarter quits the GR process if routing information exchange is not completed within the RIB purge timer. It updates the RIB with the BGP routes already learned, and removes the aged routes.
When the TCP connection goes down, the hold timer expires, or the address families supporting route exchange change, BGP tears down and then re-establishes the peer sessions, which will cause traffic interruption. To avoid traffic interruption in these cases, enable BGP to reset peer sessions gracefully.
Follow these guidelines when you configure BGP GR:
· The End-Of-RIB indicates the end of route updates.
· The maximum time to wait for the End-of-RIB marker configured on the local end is not advertised to the peer. It controls the time for the local end to receive updates from the peer. Set a large value for the maximum time to wait for the End-of-RIB marker when a large number of routes need to be exchanged.
· As a best practice, perform the BGP GR configuration on both the GR restarter and GR helper.
3. Enable GR capability for BGP.
graceful-restart
By default, GR capability is disabled for BGP.
4. (Optional.) Configure the GR timer.
The default setting is 150 seconds.
The time that a peer waits to re-establish a session must be less than the hold time.
5. (Optional.) Set the extra time to wait after the restart timer expires.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } graceful-restart timer restart extra { time | no-limit }
By default, the extra time to wait after the restart timer expires is 0 seconds.
6. (Optional.) Configure the maximum time to wait for the End-of-RIB marker.
The default setting is 180 seconds.
7. (Optional.) Configure the RIB purge timer.
The default setting is 480 seconds.
8. (Optional.) Enable BGP to reset peer sessions gracefully.
graceful-restart peer-reset [ all ]
By default, BGP does not reset peer sessions gracefully.
Configuring BGP NSR
To use BGP nonstop routing (NSR), the system must have a minimum of two IRF member devices.
NSR ensures nonstop services when BGP has redundant processes on multiple IRF member devices. In contrast to GR, NSR does not require a neighbor device to recover routing information.
BGP NSR backs up BGP state and data information from the active BGP process to the standby BGP process. The standby BGP process takes over when any of the following events occurs:
· The active BGP process restarts.
· The MPU that runs the active BGP process fails.
· An ISSU starts on the MPU that runs the active BGP process.
When both GR and NSR are configured for BGP, NSR has a higher priority than GR. The device will not act as the GR restarter. If the device acts as a GR helper, it cannot help the restarter to complete GR.
3. Enable BGP NSR.
non-stop-routing
By default, BGP NSR is disabled.
Configuring BFD for BGP
BGP maintains neighbor relationships based on the keepalive timer and hold timer in seconds. It requires that the hold time must be at least three times the keepalive interval. This mechanism slows down link failure detection. Once a failure occurs on a high-speed link, a large quantity of packets will be dropped before routing convergence completes. BFD for BGP can solve this problem by fast detecting link failures to reduce convergence time.
Before you enable BFD for a BGP peer or peer group, you must establish a BGP session between the local router and the peer or peer group.
For more information about BFD, see BFD configuration in Network Management and Monitoring Configuration Guide.
If you have enabled GR, use BFD with caution because BFD might detect a failure before the system performs GR, which will result in GR failure. If you have enabled both BFD and GR for BGP, do not disable BFD during a GR process to avoid GR failure.
To detect the link to a BGP peer established through link-local addresses, you must configure single-hop BFD.
To establish a BFD session to a BGP peer, you must configure the same BFD detection mode (multi-hop or single-hop) on the local router and the BGP peer.
3. Enable BFD to detect the link to the specified BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bfd [ multi-hop | single-hop ]
By default, BFD is disabled.
3. Enable BFD to detect the link to the specified IPv6 BGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } bfd [ multi-hop | single-hop ]
Configuring BGP FRR
About BGP FRR
When a link fails, the packets on the link are discarded, and a routing loop might occur until BGP completes routing convergence based on the new network topology.
You can enable BGP fast reroute (FRR) to resolve this issue.
Figure 19 Network diagram for BGP FRR
After you configure FRR on Router B as shown in Figure 19, BGP generates a backup next hop Router C for the primary route. BGP uses ARP or BFD echo packet mode in an IPv4 network or ND in an IPv6 network to detect the connectivity to Router D. When the link to Router D fails, BGP directs packets to the backup next hop. At the same time, BGP calculates a new optimal route, and forwards packets over the optimal route.
You can use the following methods to configure BGP FRR:
· Method 1—Execute the pic command in BGP address family view. BGP calculates a backup next hop for each BGP route in the address family if there are two or more unequal-cost routes that reach the destination.
· Method 2—Execute the fast-reroute route-policy command to use a routing policy in which a backup next hop is specified by using the command apply [ ipv6 ] fast-reroute backup-nexthop. The backup next hop calculated by BGP must be the same as the specified backup next hop. Otherwise, BGP does not generate a backup next hop for the primary route. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
BGP supports FRR for IPv4 and IPv6 unicast routes, but not for IPv4 and IPv6 multicast routes.
Configuring BGP FRR by using a routing policy (IPv4 unicast address family)
1. Enter system view.
2. Configure the source address of echo packets.
bfd echo-source-ip ipv4-address
By default, no source address is specified for echo packets.
This step is required when BFD echo packet mode is used to detect the connectivity to the next hop of the primary route.
Specify a source IP address that does not belong to any local network.
For more information about this command, see BFD commands in Network Management and Monitoring Command Reference.
3. Create a routing policy and enter routing policy view.
route-policy route-policy-name permit node node-number
For more information about this command, see routing policy commands in Layer 3—IP Routing Command Reference.
4. Set the backup next hop for FRR.
apply fast-reroute backup-nexthop ipv4-address
By default, no backup next hop is set.
6. Enter BGP instance view.
7. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
8. Apply a routing policy to FRR for the address family.
The apply fast-reroute backup-nexthop command and apply ipv6 fast-reroute backup-nexthop command can take effect in the applied routing policy. Other apply commands do not take effect.
Configuring BGP FRR by using a routing policy (IPv6 unicast address family)
2. Create a routing policy and enter routing policy view.
3. Set the backup next hop for FRR.
apply ipv6 fast-reroute backup-nexthop ipv6-address
5. Enter BGP instance view or BGP-VPN instance view.
6. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
7. Apply a routing policy to FRR for the address family.
The apply fast-reroute backup-nexthop and apply ipv6 fast-reroute backup-nexthop commands can take effect in the applied routing policy. Other apply commands do not take effect.
Configuring BGP FRR through PIC (IPv4 unicast address family)
This feature might result in routing loops. Use it with caution.
3. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
4. Enable BGP FRR through PIC.
pic
By default, BGP FRR is disabled.
Configuring BGP FRR through PIC (IPv6 unicast address family)
3. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
pic
Configuring BFD-powered nexthop connectivity detection for BGP FRR
By default, BGP FRR uses ARP to detect next hop connectivity for the primary route. This method is not efficient at detecting the failure of the primary route. As a result, data loss might occur when the primary route fails, because the backup path might not take over to forward traffic in time. To resolve this issue, enable BFD-powered nexthop connectivity detection for BGP FRR. This feature enables BGP to create an IP FRR BFD session that detects next hop connectivity for the primary route. This can speed up primary and backup route switchover when the next hop of the primary route fails.
This feature takes effect and creates an IP FRR BFD session only when the primary route has a backup next hop.
BGP does not support backup next hop calculation for the routes used for load balancing. This command cannot take effect when the primary route is an equal-cost route.
BGP can establish a control-mode BFD session with a peer only after negotiation. To use control-mode BFD to detect the next hop of the primary link, perform one of the following tasks:
· Configure the primary-path-detect bfd command on the peer device in the primary link.
This task is applicable when both ends of the primary link are configured with FRR.
· Manually configure a static BFD session that uses the following settings on the peer device in the primary link:
¡ Source IP address: Destination IP address of the BFD session automatically created on the local device in the primary link.
¡ Destination IP address: Source IP address of the BFD session automatically created on the local device in the primary link.
¡ Remote ID: Local ID of the BFD session automatically created on the local device in the primary link.
When you configure echo-mode BFD for nexthop connectivity detection, you only need to configure this feature on the local router.
When another routing protocol (such as OSPF or IS-IS) uses BFD to detect next hop connectivity for the primary route, it also creates a BFD session. If the detected link is the same as the link attached to the next hop of the BGP primary route, BGP reuses the BFD session created by the protocol. In this situation, BGP will not create an additional BFD session.
3. (Optional.) Enable BFD-powered nexthop connectivity detection for BGP FRR.
primary-path-detect bfd { ctrl | echo }
By default, BGP FRR uses ARP to detect nexthop connectivity for the primary route.
About BGP maintenance features
For maintenance purposes, you can use either BGP isolation or BGP shutdown to remove the device from the network. The device will not be used for forwarding traffic from its peers after they reselect an optimal route. BGP isolation or BGP shutdown retains the device configuration to facilitate maintenance workload.
After maintenance, you can disable BGP isolation or BGP shutdown to add the device back to the network.
Configuring BGP isolation
To maintain a BGP network device, you can use BGP isolation to remove the device from the network. This feature reduces configuration workload and impact on the network by retaining the device configuration during the maintenance. After maintenance, you can disable BGP isolation to add the device back to the network.
BGP isolation works as follows:
1. BGP withdraws all routes advertised by the device except for the directly-connected routes.
2. BGP keeps all routes learned from its peers.
3. Each peer of the device reselects an optimal route and updates the FIB table. During optimal route selection, the peers can still use the routes advertised by the device to forward traffic.
4. After an optimal route is selected and the FIB table is updated, the peers stop forwarding packets except for those destined for the device to the device. The device is fully isolated from the network and you can upgrade it.
5. After the maintenance, disable BGP isolation on the device to gracefully add it back to the network. After returning to the network, the device advertises and learns routes as follows:
¡ Advertises routes to its peers.
¡ Learns routes if BGP was reset during the isolation.
To avoid isolation failure, do not use this feature when GR or NSR is enabled for the device.
3. Enable BGP isolation to gracefully remove the device from the network.
isolate enable
By default, BGP isolation is disabled.
4. Disable BGP isolation to gracefully add the device to the network.
undo isolate enable
Configuring BGP shutdown
For maintenance purposes, you can use this feature to temporarily disconnect BGP sessions from all peers and peer groups. After maintenance, you can disable this feature to restore these sessions.
With this feature enabled, the device tears down all sessions and clears all routing information.
The device cannot establish BGP sessions in one of the following conditions:
· BGP shutdown is configured.
· BGP session establishment is disabled. For more information about disabling BGP session establishment, see "Disabling BGP session establishment."
2. Enter BGP instance view.
3. Shut down BGP sessions to all peers and peer groups.
shutdown process
By default, BGP does not shut down sessions to any peers or peer groups.
4. Restore the BGP sessions to add the device back to the network.
undo shutdown process
Display and maintenance commands for BGP network reliability improvement
Displaying BGP (IPv4 unicast address family)
Task |
Command |
Display BGP NSR status information. |
display bgp [ instance instance-name ] non-stop-routing status |
Displaying BGP (IPv6 unicast address family)
Task |
Command |
Displaying BGP (IPv4 multicast address family)
Task |
Command |
Displaying BGP (IPv6 multicast address family)
Task |
Command |
Configuring extended BGP features
vSystem support for features
Non-default vSytems support 6PE.
For information about non-default vSystems' support for the commands, see BGP command reference. For information about vSystem, see Virtual Technologies Configuration Guide.
Extended BGP feature configuration tasks at a glance
To configure extended BGP features, perform the following tasks:
¡ (Optional.) Configuring BGP LS route reflection
¡ (Optional.) Specifying an AS number and a router ID for BGP LS messages
¡ (Optional.) Preferring routes learned from a peer or peer group during optimal route selection
¡ (Optional.) Performing manual soft-reset for BGP sessions of LS address family
Configuring BGP LS
About BGP LS
The BGP Link State (LS) feature implements inter-domain and inter-AS advertisement of link state database (LSDB) and TE database (TEDB) information.
The device sends the collected link state information to the controller, which implements end-to-end traffic management and scheduling and meets the requirements of intended applications.
Configuring basic BGP LS
3. Specify an AS number for an LS peer or peer group.
peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-number as-number
By default, no AS number is specified.
4. Create the BGP LS address family and enter its view.
address-family link-state
5. Enable the device to exchange LS information with the peer or peer group.
By default, the device cannot exchange LS information with the peer or peer group.
Perform this task to configure a BGP route reflector and its clients. The route reflector and its clients automatically form a cluster identified by the router ID of the route reflector. The route reflector forwards route updates among its clients.
3. Enter BGP LS address family view.
4. Configure BGP LS route reflection.
¡ Configure the device as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
¡ (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
This command can reduce the number of IBGP connections in an AS.
¡ (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
4. Specify an AS number and a router ID for BGP LS messages.
domain-distinguisher as-number:router-id
By default, the AS number and router ID of the current BGP process are used.
Configure this command to ensure that LS messages sent by devices in the same AS have the same AS number and router ID.
4. Prefer routes learned from the specified peer or peer group during optimal route selection.
3. Enable BGP route refresh.
¡ Enable BGP route refresh for a peer or peer group.
¡ Enable the BGP route refresh, multi-protocol extension, and 4-byte AS number features for a peer or peer group.
4. Perform manual soft-reset for BGP sessions of LS address family:
c. Perform manual soft-reset for BGP sessions of LS address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } link-state
Display and maintenance commands for extended BGP features
Displaying BGP
Displaying BGP (LS address family)
Task |
Command |
Display BGP LS peer group information. |
display bgp [ instance instance-name ] group link-state [ group-name group-name ] |
Display BGP LS information. |
display bgp [ instance instance-name ] link-state [ ls-prefix | peer { ipv4-address | ipv6-address } { advertised | received } [ statistics ] | statistics ] display bgp [ instance instance-name ] link-state [ color color-value end-point { ipv4 ipv4-address | ipv6 ipv6-address } ] |
Display BGP LS peer or peer group information. |
display bgp [ instance instance-name ] peer link-state [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ] |
Display BGP LS address family update group information. |
display bgp [ instance instance-name ] update-group link-state [ ipv4-address | ipv6-address ] |
Task |
Command |
Reset BGP sessions for LS address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } link-state |
