HomeSupportSwitchesS7500X-G SeriesConfigure & DeployConfiguration GuidesH3C S7500X-G Switch Series Configuration Guides-R7755Pxx-6W10001-Fundamentals Configuration Guide
13-Device management configuration
13-Device management configuration 432.27 KB
Managing the device· 1
Device management tasks at a glance· 1
Configuring the device name· 2
Configuring the system ID·· 2
Configuring the system time· 2
About the system time· 2
Restrictions and guidelines for configuring the system time· 3
System time configuration tasks at a glance· 3
Setting the system time at the CLI 3
Obtaining the UTC time through a time protocol 4
Setting the time zone· 4
Setting the daylight saving time· 4
Enabling displaying the copyright statement 4
Configuring banners· 5
Disabling password recovery capability· 6
Setting the device operating mode· 6
Specifying an operating mode for a service module· 7
Specifying the multicast forwarding mode· 8
Setting the load mode for MPUs· 9
Setting the port status detection timer 10
Monitoring CPU usage· 10
Setting memory alarm thresholds· 12
Monitoring DMA memory· 15
Configuring resource monitoring· 15
Setting the temperature alarm thresholds· 17
Disabling the notification of hardware resource alarms· 18
Configuring hardware failure detection and protection· 18
Specifying the actions to be taken for hardware failures· 18
Enabling data forwarding path failure detection· 19
Configuring consistency error logging for software and hardware forwarding entries· 19
Configuring parity error and ECC error logging for entries on forwarding chips· 20
Configuring uncorrectable parity error and ECC error logging for entries on forwarding chips· 20
Managing power supply· 21
About power supply management 21
Restrictions and guidelines· 21
Power supply management tasks at a glance· 21
Enabling power supply management 21
Specifying the number of redundant power modules· 22
Setting power supply priorities for interface modules· 22
Powering on or off a card· 23
Verifying and diagnosing transceiver modules· 24
Verifying transceiver modules· 24
Diagnosing transceiver modules· 24
Configuring transceiver monitoring· 25
Configuring transceiver health check· 25
Resetting a transceiver module· 26
Scheduling a task· 26
About task scheduling· 26
Restrictions and guidelines· 26
Procedure· 27
Example: Scheduling a task· 28
Manually triggering an active/standby switchover 31
Enabling the port-down feature globally· 31
Configuring an asset profile for a physical component 32
Rebooting the device· 32
About device reboot 32
Restrictions and guidelines for device reboot 32
Rebooting the device immediately at the CLI 33
Rebooting the standby MPU· 33
Scheduling a device reboot 34
Restoring the factory-default configuration· 34
Display and maintenance commands for device management configuration· 35
Managing the device
This chapter describes how to configure basic device parameters and manage the device.
All device management tasks are optional. You can perform any of the tasks in any order.
·     Configuring basic parameters
¡     Configuring the device name
¡     Configuring the system ID
¡     Configuring the system time
¡     Enabling displaying the copyright statement
¡     Configuring banners
·     Configuring security parameters
¡     Disabling password recovery capability
·     Adjusting device capacities
¡     Setting the device operating mode
¡     Specifying an operating mode for a service module
¡     Specifying the multicast forwarding mode
¡     Setting the load mode for MPUs
¡     Setting the port status detection timer
·     Monitoring the device
¡     Monitoring CPU usage
¡     Setting memory alarm thresholds
¡     Monitoring DMA memory
¡     Configuring resource monitoring
¡     Setting the temperature alarm thresholds
¡     Disabling the notification of hardware resource alarms
¡     Configuring hardware failure detection and protection
¡     Enabling data forwarding path failure detection
·     Managing resources
¡     Managing power supply
¡     Verifying and diagnosing transceiver modules
¡     Configuring transceiver monitoring
¡     Configuring transceiver health check
·     Maintaining the device
¡     Scheduling a task
¡     Manually triggering an active/standby switchover
¡     Rebooting the device
¡     Restoring the factory-default configuration
A device name (also called hostname) identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
On an underlay network, the device uses the device name that you have configured for it. If you do not configure a device name for the device but automated underlay network deployment is enabled, the device uses the device name assigned by the VCF fabric feature. For more information about VCF fabric, see VCF fabric configuration in Network Management and Monitoring Configuration Guide.
2.     Configure the device name.
sysname sysname
By default, the device name is H3C.
You can use the system ID to indicate the position or functionality of the device or any other information.
2.     Configure the system ID.
sysid system-id
By default, the device does not have a system ID.
Correct system time is essential to network management and communication. Configure the system time correctly before you run the device on the network.
The device can use one of the following methods to obtain the system time:
·     Uses the locally set system time, and then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
·     Periodically obtains the UTC time from an NTP or PTP source, and uses the UTC time, time zone, and daylight saving time to calculate the system time. For more information about NTP and PTP, see Network Management and Monitoring Configuration Guide.
The system time calculated by using the UTC time from a time source is more precise.
After you execute the clock protocol none command, the clock datetime command determines the system time, whether or not the time zone or daylight saving time has been configured.
If you configure or change the time zone or daylight saving time after the device obtains the system time, the device recalculates the system time. To view the system time, execute the display clock command.
This feature is supported only on the default MDC. All MDCs on the device use the same system time.
To configure the system time, perform the following tasks:
1.     Configuring the system time
¡     Setting the system time at the CLI
¡     Obtaining the UTC time through a time protocol
2.     (Optional.) Setting the time zone
Make sure each network device uses the time zone of the place where the device resides.
3.     (Optional.) Setting the daylight saving time
Make sure each network device uses the daylight saving time parameters of the place where the device resides.
2.     Configure the device to use the local system time.
clock protocol none
By default, the device uses the NTP time source specified on the default MDC.
If you execute the clock protocol command multiple times, the most recent configuration takes effect.
3.     Return to user view.
4.     Set the local system time.
clock datetime time date
By default, the system time is UTC time 00:00:00 01/01/2011.
CAUTION
CAUTION:
Change of the system time affects execution of system time-related features (such as scheduled tasks) and cooperative operation with other devices (such as log reporting and statistics collection). Before using this command, make sure you understand its impact on the live network.
2.     Specify the system time source.
clock protocol { ntp | ptp } mdc mdc-id
3.     Configure time protocol parameters.
For more information about NTP and PTP configuration, see Network Management and Monitoring Configuration Guide.
2.     Set the time zone.
By default, the system uses the UTC time zone.
2.     Set the daylight saving time.
By default, the daylight saving time is not set.
This feature enables the device to display the copyright statement in the following situations:
·     When a Telnet or SSH user logs in.
·     When a console user quits user view. This is because the device automatically tries to restart the user session.
If you disable displaying the copyright statement, the device does not display the copyright statement in any situations.
2.     Enable displaying the copyright statement.
copyright-info enable
By default, displaying the copyright statement is enabled.
Configuring banners
Banners are messages that the system displays when a user logs in.
The system supports the following banners:
·     Legal banner—Appears after the copyright statement.
·     Message of the Day (MOTD) banner—Appears after the legal banner and before the login banner.
·     Login banner—Appears only when password or scheme authentication is configured.
·     Shell banner—Appears when the user accesses user view.
The system displays the banners in the following order: legal banner, MOTD banner, login banner, and shell banner.
Banner input methods
You can configure a banner by using one of the following methods:
·     Input the entire command line in a single line.
The banner cannot contain carriage returns. The entire command line, including the command keywords, the banner, and the delimiters, can have a maximum of 511 characters. The delimiters for the banner can be any printable character but must be the same. You cannot press Enter before you input the end delimiter.
For example, you can configure the shell banner "Have a nice day." as follows:
<System> system-view
[System] header shell %Have a nice day.%
·     Input the command line in multiple lines.
The banner can contain carriage returns. A carriage return is counted as two characters.
To input a banner configuration command line in multiple lines, use one of the following methods:
¡     Press Enter after the final command keyword, type the banner, and end the final line with the delimiter character %. The banner plus the delimiter can have a maximum of 1999 characters.
For example, you can configure the banner "Have a nice day." as follows:
Have a nice day.%
¡     After you type the final command keyword, type any printable character as the start delimiter for the banner and press Enter. Then, type the banner and end the final line with the same delimiter. The banner plus the end delimiter can have a maximum of 1999 characters.
[System] header shell A
Please input banner content, and quit with the character 'A'.
Have a nice day.A
¡     After you type the final command keyword, type the start delimiter and part of the banner. Make sure the final character of the final string is different from the start delimiter. Then, press Enter, type the rest of the banner, and end the final line with the same delimiter. The banner plus the start and end delimiters can have a maximum of 2002 characters.
[System] header shell AHave a nice day.
A
2.     Configure the legal banner.
header legal text
3.     Configure the MOTD banner.
header motd text
4.     Configure the login banner.
header login text
5.     Configure the shell banner.
header shell text
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus. For more information about BootWare menus, see the release notes.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure a new password.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
(In standalone mode.) (In IRF mode.) To access the device configuration without authentication, you must connect to the active MPU and access the BootWare menu while the MPU is starting up.
2.     Disable password recovery capability.
undo password-recovery enable
By default, password recovery capability is enabled.
Supported features and feature specifications vary by device operating mode.
The device can operate in one of the following modes:
·     advance—Advanced mode.
·     expert—Expert mode.
·     standard—Standard mode.
To change the operating mode to advance, make sure the device has enough IFP ACL resources. To display the current IFP ACL resource information, use the display qos-acl resource command. For more information about this command, see ACL and QoS Command Reference.
The LSCM1GT48SC0 interface card does not support the advance mode.
Some early SC MPUs with interfaces on the rear panels do not support the expert mode. When you specify the expert mode, the device will prompt that the specified mode is not supported.
The following cards are not supported when the device operates in expert mode:
·     SC interface modules prefixed with LSCM2.
·     SE interface modules.
·     LSCM1GT48SC0 module.
If the operating mode of the device installed with the above interface modules changes from another mode to expert, these interface modules will try to restart but fail to start up.
A change to the device operating mode takes effect after a device reboot.
2.     Set the device operating mode.
system-working-mode { advance | expert | standard }
By default, the device operates in standard mode.
The MAC address table size and routing table size of a service module vary by operating mode. Table 1 lists the feature highlights and application scenarios of operating modes.
Table 1 Operating modes and feature highlights and application scenarios
Operating mode
Feature highlights
Recommended application scenario
normal
Uses the default MAC address table and routing table.
Common networks.
bridging
Increases the MAC address table size to provide higher Layer 2 packet forwarding performance.
A large MAC address table is required.
routing
Increases the IPv4 routing table size to provide higher Layer 3 packet forwarding performance.
A large IPv4 routing table is required.
balance
Increases the MAC address table size, ARP table size, and routing table size to provide more balanced Layer 2 and Layer 3 packet forwarding performance.
Requirements for the MAC address table, ARP table, and routing table are balanced.
The enhanced operating modes include enhance, enhance-bridging, enhance-routing, and enhance-balance. An enhanced operating mode doubled the capacities of the MAC address table, ARP table, IPv4 FIB table, ND table, IPv6 FIB table, and ACL table, but decreases the forwarding performance. An enhanced operating mode is suitable for a network that has high requirements on table capacities but low requirements on forwarding performance.
SF interfaces do not support enhanced modes.
The LSCM1GT48SC0 service module supports only the normal, bridging, routing, and balance modes.
You can specify an operating mode for a service module after the service module is installed in a service module slot. The configuration takes effect only after you save the running configuration and reboot the service module.
Follow these guidelines if you replace the service module in a slot that is already configured with an operating mode:
·     If the new service module supports the operating mode configured for the slot, the new service module will operate in the configured operating mode.
·     If the new service module does not support the operating mode configured for the slot, the new service module will operate in the default operating mode.
·     To view the operating mode information about a service module, use the display switch-mode status command.
2.     Specify an operating mode for a service module.
In standalone mode:
switch-mode slot slot-number { balance | bridging | enhance | enhance-balance | enhance-bridging | enhance-routing | normal | routing }
In IRF mode:
switch-mode chassis chassis-number slot slot-number { balance | bridging | enhance | enhance-balance | enhance-bridging | enhance-routing | normal | routing}
By default, the operating mode for a service module is normal.
The following multicast forwarding modes are supported:
·     enhanced—Enhanced mode. If the multicast traffic across cards is large, set the multicast forwarding mode to enhanced as a best practice.
This feature takes effect only after you save the running configuration and reboot the device.
This feature is not supported on the S7503X-G or S7503X-M-G switch.
The device supports specifying a multicast forwarding mode only when the device are installed with MPUs prefixed with LSCM1 and interface modules prefixed with LSCM1.
To form an IRF fabric, all IRF member devices must be configured with the same multicast forwarding mode. For more information about IRF, see Virtual Technologies Configuration Guide.
Before setting the multicast forwarding mode to enhanced, make sure the following requirements are met:
·     The device is configured with local-first load sharing for link aggregation. For more information about local-first load sharing for link aggregation, see Ethernet link aggregation configuration in Layer 2—LAN Switching Configuration Guide.
·     The marks and interface numbers on the cards that host the IRF physical interfaces at both ends of an IRF link must be the same. For more information about IRF, see Virtual Technologies Configuration Guide.
If you specify the multicast forwarding mode as enhanced, only MPUs prefixed with LSCM1 and interface modules prefixed with LSCM1 (except LSCM1GT48SC0) can operate correctly.
2.     Specify the multicast forwarding mode.
fabric multicast-forwarding mode { enhanced | standard }
By default, the multicast forwarding mode is standard.
The device supports the following MPU load modes:
·     load-balance—The MPUs share the load to process and forward packets.
·     load-single—Only the active MPU processes and forwards packets. The standby MPUs back up data and monitor the status of the active MPU.
This feature does not take effect on the S7503X-G and S7503X-M-G switches.
A single-MPU device supports only the load-single mode. If you set the MPU load mode to load-balance, the device automatically switches to load-single mode.
2.     Set the load mode for MPUs.
In standalone mode:
xbar { load-balance | load-single }
In IRF mode:
xbar chassis chassis-number { load-balance | load-single }
By default, MPUs operate in load-balance mode.
The device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
2.     Set the port status detection timer.
shutdown-interval time
The default setting is 30 seconds.
To monitor CPU usage, the device performs the following operations:
·     Samples CPU usage at 1-minute intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
·     Samples CPU core usage at 1-minute intervals, and compares the samples with CPU core usage thresholds to identify the CPU core usage status. If a sample is greater than the threshold, the device sends a log message.
·     Samples and saves CPU usage at a configurable interval if CPU usage tracking is enabled. You can use the display cpu-usage history command to display the historical CPU usage statistics in a coordinate system.
The device supports the following CPU usage thresholds:
·     Minor threshold—If the CPU usage increases to or above the minor threshold but is less than the severe threshold, the CPU usage enters minor alarm state. The device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed.
·     Severe threshold—If the CPU usage increases above the severe threshold, the CPU usage enters severe alarm state. The device sends severe alarms periodically until the severe alarm is removed.
·     Recovery threshold—If the CPU usage decreases below the recovery threshold, the CPU usage enters recovered state. The device sends a recovery notification.
CPU usage alarms and notifications can be sent to NETCONF, SNMP, and the information center to be encapsulated as NETCONF events, SNMP traps and informs, and log messages. For more information, see NETCONF, SNMP, and information center in Network Management and Monitoring Configuration Guide.
Figure 1 CPU alarms and alarm-removed notifications
2.     Set the CPU usage alarm thresholds.
In standalone mode:
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] }
In IRF mode:
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The default settings are as follows:
¡     Severe CPU usage alarm threshold99%.
¡     Minor CPU usage alarm threshold80%.
¡     CPU usage recovery threshold60%.
CAUTION
CAUTION:
If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal service processing will be affected.
3.     Set CPU usage alarm resending intervals.
In standalone mode:
In IRF mode:
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
By default, the minor alarm resending interval is 300 seconds and the severe alarm resending interval is 60 seconds.
4.     Set the sampling interval for CPU usage tracking.
In standalone mode:
In IRF mode:
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
By default, the sampling interval for CPU usage tracking is 1 minute.
5.     Enable CPU usage tracking.
In standalone mode:
In IRF mode:
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
By default, CPU usage tracking is enabled.
6.     (Optional.) Enable periodic CPU usage logging.
monitor cpu-usage logging interval interval-time
By default, periodic CPU usage logging is disabled.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space reaches the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules and processes.
The system can also issue an early warning to warn you of an approaching insufficient-memory condition.
You can use the display memory command to display memory usage information.
As shown in the following table and figure, the system supports these free-memory thresholds:
·     Sufficient-memory threshold.
·     Early-warning threshold.
·     Normal state threshold.
·     Minor alarm threshold.
·     Severe alarm threshold.
·     Critical alarm threshold.
Table 2 Memory alarm notifications and memory alarm-removed notifications
Notification
Triggering condition
Remarks
Early-warning notification
The amount of free memory space decreases below the early-warning threshold.
After generating and sending an early-warning notification, the system does not generate and send any additional early-warning notifications until the early warning is removed.
Minor alarm notification
The amount of free memory space decreases below the minor alarm threshold.
After generating and sending a minor alarm notification, the system does not generate and send any additional minor alarm notifications until the minor alarm is removed.
Severe alarm notification
The amount of free memory space decreases below the severe alarm threshold.
After generating and sending a severe alarm notification, the system does not generate and send any additional severe alarm notifications until the severe alarm is removed.
Critical alarm notification
The amount of free memory space decreases below the critical alarm threshold.
After generating and sending a critical alarm notification, the system does not generate and send any additional critical alarm notifications until the critical alarm is removed.
Critical alarm-removed notification
The amount of free memory space increases above the severe alarm threshold.
N/A
Severe alarm-removed notification
The amount of free memory space increases above the minor alarm threshold.
N/A
Minor alarm-removed notification
The amount of free memory space increases above the normal state threshold.
N/A
Early-warning-removed notification
The amount of free memory space increases above the sufficient-memory threshold.
N/A
Figure 2 Memory alarm notifications and alarm-removed notifications
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
The system will restart a card if one of the following conditions is met:
·     After a critical alarm occurs, the remaining free-memory value has been smaller than the critical alarm threshold for 30 seconds.
·     The interval between two consecutive critical alarms is shorter than 30 seconds.
·     The critical alarm has occurred three times within three minutes.
·     After a critical alarm occurs, the system will periodically sample free memory space and predict if the free memory space will be exhausted within 30 seconds. If the prediction result indicates that the free memory space will be exhausted within 30 seconds, the system will restart the card.
Once the free memory space reaches the early warning, minor, severe, or critical alarm threshold, the device will display the current memory usage information when you log in to the device through console or Telnet login, or execute every command.
After you configure this feature, if the amount of the free memory space reaches the minor alarm threshold, the device cannot generate an asymmetric key pair through the public-key local create command. For more information, see PKI configuration in Security Configuration Guide.
2.     Set the memory usage threshold.
In standalone mode:
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
By default, the memory usage threshold is 100%.
3.     Set the free-memory thresholds.
In standalone mode:
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value [ early-warning early-warning-value secure secure-value ]
¡     Minor alarm threshold—194 MB.
¡     Severe alarm threshold—136 MB.
¡     Critical alarm threshold—77 MB.
¡     Normal state threshold—252 MB.
¡     Early-warning threshold—311 MB.
¡     Sufficient-memory threshold—350 MB.
4.     Set memory depletion alarm resending intervals.
In standalone mode:
In IRF mode:
monitor resend memory-threshold { critical-interval critical-interval | early-warning-interval early-warning-interval | minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The following are the default settings:
¡     Early warning resending interval—1 hour.
¡     Minor alarm resending interval—12 hours.
¡     Severe alarm resending interval—3 hours.
¡     Critical alarm resending interval—1 hour.
5.     (Optional.) Enable periodic memory usage logging.
monitor memory-usage logging interval interval-time
By default, periodic memory usage logging is disabled.
To ensure correct operation of services that use Direct Memory Access (DMA) memory, the system monitors the amount of free DMA memory space regularly. If the amount of free DMA memory space decreases to or below the alarm threshold, the system generates a notification that the DMA memory space is insufficient. If the amount of free DMA memory space increases above the normal state threshold, the system generates a notification that the DMA memory space is sufficient.
DMA memory alarm notifications are sent to NETCONF, SNMP, and the information center to be encapsulated as NETCONF events, SNMP traps and informs, and log messages. For more information about NETCONF, SNMP, and information center, see Network Management and Monitoring Configuration Guide.
2.     Set the DMA memory thresholds.
In standalone mode:
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
In IRF mode:
memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
By default, the DMA memory alarm threshold is 2048 KB, and the normal state threshold is 4096 KB.
The resource monitoring feature enables the device to monitor the available amounts of types of resources, for example, the space for ARP entries. The device samples the available amounts periodically and compares the samples with resource depletion thresholds to identify the resource depletion status.
The device supports a minor resource depletion threshold and a severe resource depletion threshold for each supported resource type.
·     If the available amount is equal to or less than the minor resource depletion threshold but greater than the severe resource depletion threshold, the resource type is in minor alarm state.
·     If the available amount is equal to or less than the severe resource depletion threshold, the resource type is in severe alarm state.
·     If the available amount increases above the minor resource depletion threshold, the resource type is in recovered state.
When a resource type enters severe alarm state, the device issues a severe alarm. If the resource type stays in severe alarm state, the device resends severe alarms periodically.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
Resource depletion alarms can be sent to NETCONF, SNMP, and the information center to be encapsulated as NETCONF events, SNMP traps and informs, and log messages. For more information, see NETCONF, SNMP, and information center in Network Management and Monitoring Configuration Guide.
Figure 3 Resource depletion alarms and alarm-removed notifications
This feature is not supported on the LSCM1GT48SC0 card.
2.     Set resource depletion thresholds.
In standalone mode:
resource-monitor resource resource-name slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
In IRF mode:
resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
The default settings vary by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
3.     Specify destinations for resource depletion alarms.
By default, resource depletion alarms are sent to NETCONF, SNMP, and the information center.
4.     Enable resending of minor resource depletion alarms.
resource-monitor minor resend enable
By default, resending of minor resource depletion alarms is enabled.
The device monitors its temperature based on the following thresholds:
·     Low-temperature threshold.
·     High-temperature warning threshold.
·     High-temperature alarming threshold.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
2.     Configure the temperature alarm thresholds.
In standalone mode:
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
In IRF mode:
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
The high-temperature alarming threshold must be higher than the high-temperature warning threshold, and the high-temperature warning threshold must be higher than the low-temperature threshold.
Perform this task to disable the notification of hardware resource alarms.
2.     Disable the notification of hardware resource alarms.
hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port | device | disk | fan | interface | power | subcard | transceiver | voltage } disable
By default, the notification of all hardware resource alarms is enabled.
The device can automatically detect hardware failures on components, cards, and the forwarding plane, and take actions in response.
The device can take the following actions in response to hardware failures:
·     isolate—Performs the following tasks as appropriate to reduce impact from the failures:
¡     Prohibits loading software for the relevant cards.
¡     Isolates the relevant cards.
¡     Powers off the relevant cards.
·     reset—Restarts the relevant components or cards to recover from failures.
·     warning—Sends traps to report the failures. If a card failure is detected on control paths, the system will try to recover from the failure by restarting the card.
You can configure this feature only on the default MDC. However, the configuration takes effect on all MDCs.
2.     Specify the action to be taken in response to a type of hardware failures.
hardware-failure-detection { board | chip | forwarding } { off | isolate | reset | warning }
By default, the system takes the action of reset in response to hardware failures on chips, cards, and the forwarding plane.
You can enable the device to automatically detect data forwarding path failures and to output log information.
2.     Enable data forwarding path failure detection.
forward-path-detection enable
By default, data forwarding path failure detection is enabled.
To forward packets, the device generates hardware forwarding entries in forwarding chips on cards and software forwarding entries in memory at the same time. The cards automatically detects whether the hardware forwarding entries and the software forwarding entries are consistent.
The consistency error logging for software and hardware forwarding entries enables a card to collect statistics for consistency errors between software and hardware forwarding entries periodically. If the number of consistency errors reaches the logging threshold, the card generates a log message.
2.     Set the statistics period for consistency errors between software and hardware forwarding entries.
parity-error consistency-check period value
The default statistics period is 3600 seconds.
3.     Set the logging threshold for consistency errors between software and hardware forwarding entries.
parity-error consistency-check threshold value
By default, the logging threshold is 10.
4.     Enable consistency error logging for software and hardware forwarding entries.
parity-error consistency-check log enable
By default, consistency error logging is disabled for software and hardware forwarding entries.
The device automatically detects parity errors and ECC errors in entries on forwarding chips on cards. The parity error and ECC error logging feature collects parity errors and ECC error statistics periodically, and generates a log message if the number of parity errors and ECC errors reaches the logging threshold.
2.     Set the parity error and ECC error statistics period for entries on forwarding chips.
parity-error monitor period value
By default, the parity error and ECC error statistics period for entries on forwarding chips is 60 seconds.
3.     Set the parity error and ECC error logging threshold for entries on forwarding chips.
parity-error monitor threshold value
By default, the parity error and ECC error logging threshold for entries on forwarding chips is 5000.
4.     Enable parity error and ECC error logging for entries on forwarding chips.
parity-error monitor log enable
By default, parity error and ECC error logging is disabled for entries on forwarding chips.
The device automatically detects parity errors and ECC errors in entries on forwarding chips on cards and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect statistics for uncorrectable parity errors and ECC errors periodically. If the number of uncorrectable parity errors and ECC errors reaches the logging threshold on a card, the card generates a log message.
Uncorrectable parity errors and ECC errors in entries on forwarding chips on cards might affect system services. To remove the errors from the entries on forwarding chips, you can enable automatic card reboot upon generation of an uncorrectable parity error and ECC error log.
2.     Set the statistics period for uncorrectable parity error and ECC errors for entries on forwarding chips.
parity-error unrecoverable period value
By default, the statistics period for uncorrectable parity error and ECC errors for entries on forwarding chips is 60 seconds.
3.     Set the logging threshold for uncorrectable parity errors and ECC errors for entries on forwarding chips.
parity-error unrecoverable threshold value
By default, the logging threshold for uncorrectable parity errors and ECC errors for entries on forwarding chips is 1.
4.     Enable uncorrectable parity error and ECC error logging for entries on forwarding chips.
parity-error unrecoverable log enable
By default, uncorrectable parity error and ECC error logging is enabled for entries on forwarding chips
5.     (Optional.) Enable automatic card reboot upon generation of an uncorrectable parity error and ECC error log.
parity-error unrecoverable reboot
By default, the card reboots automatically upon generation of an uncorrectable parity error and ECC error log.
Power modules might have problems such as overload overcurrent, overvoltage, overtemperature, and short circuit. Some power modules use a hardware protection measure, for example, powering off the device, to protect the entire device from being damaged. The hardware protection measure helps protect the device but causes service outage. The power supply management feature can minimize service outage while protecting the device against overload problems.
The power supply management feature constantly monitors the available power and the system loads. If a potential power supply overload problem is found, this feature takes protective measures immediately to remove requirements for power supply hardware protection. Examples of protective measures include sending a notification and starting redundant power supplies.
To manage power supply, perform the following tasks:
1.     Enabling power supply management
2.     (Optional.) Specifying the number of redundant
To avoid overload problems, you can install redundant power modules.
3.     (Optional.) Setting power supply priorities for interface modules
When available power increases, the device automatically chooses and powers on interface modules by priority. When overload problems occur, the device automatically chooses and powers off interface modules by priority.
4.     (Optional.) Powering on or off a card
You can manually power on or off cards.
2.     Enable power supply management.
In standalone mode:
power-supply policy enable
In IRF mode:
power-supply policy chassis chassis-number enable
By default, power supply management is disabled.
To avoid overload problems, you can install redundant power modules. For example, if the device requires a minimum of N power modules to operate correctly, you can install M power modules (M > N). The M power modules operate in load balance mode. When a power module fails, the load is rebalanced among the other power modules.
After you specify the number of redundant power modules, the device compares the maximum power consumption of a newly added card with the remaining power.
·     If the remaining power is sufficient for the card, the device powers on the card.
·     If the power is insufficient, the device does not power on the card. You can add power modules or scale the number of redundant power modules down.
This feature takes effect only if power supply management is enabled.
2.     Specify the number of redundant power modules.
In standalone mode:
power-supply policy redundant module-count
In IRF mode:
power-supply policy chassis chassis-number redundant module-count
By default, the number of redundant power supplies is 0.
After you set power supply priorities for interface modules, the power supply management feature operates as follows:
·     When power becomes insufficient because of a power module failure or removal, automatically powers off the interface modules of the lowest priorities.
·     When power becomes sufficient, automatically powers on the interface modules of the highest priorities.
Specify higher power supply priorities for critical-service modules so they are preferentially powered.
The system automatically guarantees that an interface module that holds IRF physical interfaces receives a higher priority.
·     After you bind interfaces on an interface module to IRF ports, the system automatically assigns the interface module a higher priority. You cannot use this feature to change the power supply priority for the card anymore.
·     If you specify a power supply priority for an interface module and then bind its interfaces to IRF ports, the priority setting is retained but does not take effect.
2.     Specify a power supply priority for an interface module.
In standalone mode:
power-supply policy slot slot-number priority priority
In IRF mode:
power-supply policy chassis chassis-number slot slot-number priority priority
By default, the power supply priority value for an interface card is 5.
A smaller priority value represents a higher priority.
You can manually power on or off cards. To view the power supply status, use the display power-supply command.
To power on or power off a card, you must enable power supply management first.
(In IRF mode.) To avoid IRF split, do not power off an interface module that contains the only active physical IRF port.
Powering on a card
To power on a card, execute one of the following commands in user view:
In standalone mode:
power-supply on slot slot-number
In IRF mode:
power-supply on chassis chassis-number slot slot-number
Powering off a card
To power off a card, execute one of the following commands in user view:
In standalone mode:
power-supply off slot slot-number
In IRF mode:
power-supply off chassis chassis-number slot slot-number
CAUTION
CAUTION:
A card cannot receive or send packets after a forced power-off. Before using this command, make sure you understand its impact on the live network.
You can use one of the following methods to verify the genuineness of a transceiver module:
·     Display the key parameters of a transceiver module, including its transceiver type, connector type, central wavelength of the transmit laser, transfer distance, and vendor name.
·     Display its electronic label. The electronic label is a profile of the transceiver module and contains the permanent configuration, including the serial number, manufacturing date, and vendor name. The data was written to the transceiver module or the device's storage component during debugging or testing of the transceiver module or device.
The device regularly checks transceiver modules for their vendor names. If a transceiver module does not have a vendor name or the vendor name is not H3C, the device repeatedly outputs traps and log messages. For information about logging rules, see Network Management and Monitoring Configuration Guide.
To verify transceiver modules, execute the following commands in any view:
·     Display the key parameters of transceiver modules.
·     Display the electrical label information of transceiver modules.
The device provides the alarm and digital diagnosis functions for transceiver modules. When a transceiver module fails or is not operating correctly, you can perform the following tasks:
·     Check the alarms that exist on the transceiver module to identify the fault source.
·     Examine the key parameters monitored by the digital diagnosis function, including the temperature, voltage, laser bias current, TX power, and RX power.
To diagnose transceiver modules, execute the following commands in any view:
·     Display transceiver alarms.
·     Display the current values of the digital diagnosis parameters on transceiver modules.
After transceiver monitoring is enabled, the device samples the parameters of transceiver modules periodically, including the input power and output power of transceiver modules. If a sampled value reaches the alarm threshold, the device generates a log to notify users.
2.     Set the transceiver monitoring interval.
transceiver monitor interval interval
By default, the transceiver monitoring interval is 600 seconds.
3.     Enable transceiver monitoring.
transceiver monitor enable
By default, transceiver monitoring is disabled.
The transceiver health is calculated based on the weights of five diagnosis parameters of transceiver modules, including temperature, voltage, bias current, transmit power, and receive power.
Transceiver health check enables the device to automatically check transceiver module status, and calculate transceiver health and diagnosis parameter health based on the configured weights of diagnosis parameters.
After transceiver health check is enabled and the weights for transceiver health calculation are configured, you can use the display transceiver health command to view transceiver health information. A greater health value indicates a healthier status.
The sum of the weights of temperature, voltage, bias current, transmit power, and receive power for transceiver health calculation must be 100.
2.     Enable transceiver health check.
transceiver health check enable
By default, transceiver health check is disabled.
3.     Configure the weights for transceiver health calculation.
transceiver health weight temp temp-weight voltage voltage-weight bias bias-weight rxpower rxpower-weight txpower txpower-weight
¡     Temperature weight: 15.
¡     Voltage weight: 5.
¡     Bias current weight: 30.
¡     Receive power weight: 10.
¡     Transmit power weight: 40.
Use this feature only when you cannot troubleshoot transceiver modules by using other methods.
This task will restart transceiver modules. Before performing  this task, make sure you understand its impact on the live network.
This feature is supported only on QSPF transceiver modules.
To reset a 400G transceiver module, execute the following command in user view:
reset transceiver interface [ interface-type interface-number]
Scheduling a task
You can schedule the device to automatically execute a command or a set of commands without administrative interference.
You can configure a periodic schedule or a non-periodic schedule. A non-periodic schedule is not saved to the configuration file and is lost when the device reboots. A periodic schedule is saved to the startup configuration file and is automatically executed periodically.
·     The default system time is always restored at reboot. To make sure a task schedule can be executed as expected, reconfigure the system time or configure NTP after you reboot the device. For more information about NTP, see Network Management and Monitoring Configuration Guide.
·     To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
·     Make sure all commands in a schedule are compliant to the command syntax. The system does not check the syntax when you assign a command to a job.
·     A schedule cannot contain any one of these commands: telnet, ftp, ssh2, and monitor process.
·     A schedule does not support user interaction. If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
·     A schedule is executed in the background, and no output (except for logs, traps, and debug information) is displayed for the schedule.
2.     Create a job.
scheduler job job-name
3.     Assign a command to the job.
command id command
By default, no command is assigned to a job.
You can assign multiple commands to a job. A command with a smaller ID is executed first.
4.     Exit to system view.
5.     Create a schedule.
6.     Assign a job to the schedule.
job job-name
By default, no job is assigned to a schedule.
You can assign multiple jobs to a schedule. The jobs will be executed concurrently.
7.     Assign user roles to the schedule.
user-role role-name
By default, a schedule has the user role of the schedule creator.
You can assign a maximum of 64 user roles to a schedule. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule.
8.     Specify the execution time for the schedule.
Choose one option as needed:
¡     Execute the schedule at specific points of time.
time at time date
¡     Execute the schedule after a period of time.
time once delay time
¡     Execute the schedule at the specified time on every specified day in a month or week.
¡     Execute the schedule periodically from the specified time on.
time repeating [ at time [date ] ] interval interval
By default, no execution time is specified for a schedule.
The time commands overwrite each other. The most recently executed command takes effect.
9.     (Optional.) Set the schedule log file size limit.
scheduler logfile size value
By default, the schedule log file size limit is 16 KB.
The schedule log file stores log messages for execution results of commands in jobs. After the limit is reached, the system deletes the oldest log messages to store the new log messages. If the remaining space of the log file is not enough for a single log message, the system truncates the message and does not store the extra part.
As shown in Figure 4, two interfaces of the device are connected to users.
To save energy, configure the device to perform the following operations:
·     Enable the interfaces at 8:00 a.m. every Monday through Friday.
·     Disable the interfaces at 18:00 every Monday through Friday.
Figure 4 Network diagram
# Enter system view.
# Configure a job for disabling interface Ten-GigabitEthernet 3/0/1.
[Sysname] scheduler job shutdown-Ten-GigabitEthernet3/0/1
[Sysname-job-shutdown-Ten-GigabitEthernet3/0/1] command 1 system-view
[Sysname-job-shutdown-Ten-GigabitEthernet3/0/1] command 2 interface ten-gigabitethernet 3/0/1
[Sysname-job-shutdown-Ten-GigabitEthernet3/0/1] command 3 shutdown
[Sysname-job-shutdown-Ten-GigabitEthernet3/0/1] quit
# Configure a job for enabling interface Ten-GigabitEthernet 3/0/1.
[Sysname] scheduler job start-Ten-GigabitEthernet3/0/1
[Sysname-job-start-Ten-GigabitEthernet3/0/1] command 1 system-view
[Sysname-job-start-Ten-GigabitEthernet3/0/1] command 2 interface ten-gigabitethernet 3/0/1
[Sysname-job-start-Ten-GigabitEthernet3/0/1] command 3 undo shutdown
[Sysname-job-start-Ten-GigabitEthernet3/0/1] quit
# Configure a job for disabling interface Ten-GigabitEthernet 3/0/2.
[Sysname] scheduler job shutdown-Ten-GigabitEthernet3/0/2
[Sysname-job-shutdown-Ten-GigabitEthernet3/0/2] command 1 system-view
[Sysname-job-shutdown-Ten-GigabitEthernet3/0/2] command 2 interface ten-gigabitethernet 3/0/2
[Sysname-job-shutdown-Ten-GigabitEthernet3/0/2] command 3 shutdown
[Sysname-job-shutdown-Ten-GigabitEthernet3/0/2] quit
# Configure a job for enabling interface Ten-GigabitEthernet 3/0/2.
[Sysname] scheduler job start-Ten-GigabitEthernet3/0/2
[Sysname-job-start-Ten-GigabitEthernet3/0/2] command 1 system-view
[Sysname-job-start-Ten-GigabitEthernet3/0/2] command 2 interface ten-gigabitethernet 3/0/2
[Sysname-job-start-Ten-GigabitEthernet3/0/2] command 3 undo shutdown
[Sysname-job-start-Ten-GigabitEthernet3/0/2] quit
# Configure a periodic schedule for enabling the interfaces at 8:00 a.m. every Monday through Friday.
[Sysname] scheduler schedule START-pc1/pc2
[Sysname-schedule-START-pc1/pc2] job start-Ten-GigabitEthernet3/0/1
[Sysname-schedule-START-pc1/pc2] job start-Ten-GigabitEthernet3/0/2
[Sysname-schedule-START-pc1/pc2] time repeating at 8:00 week-day mon tue wed thu fri
[Sysname-schedule-START-pc1/pc2] quit
# Configure a periodic schedule for disabling the interfaces at 18:00 every Monday through Friday.
[Sysname] scheduler schedule STOP-pc1/pc2
[Sysname-schedule-STOP-pc1/pc2] job shutdown-Ten-GigabitEthernet3/0/1
[Sysname-schedule-STOP-pc1/pc2] job shutdown-Ten-GigabitEthernet3/0/2
[Sysname-schedule-STOP-pc1/pc2] time repeating at 18:00 week-day mon tue wed thu fri
[Sysname-schedule-STOP-pc1/pc2] quit
# Display the configuration information of all jobs.
[Sysname] display scheduler job
Job name: shutdown-Ten-GigabitEthernet3/0/1
 shutdown
Job name: shutdown-Ten-GigabitEthernet3/0/2
 shutdown
Job name: start-Ten-GigabitEthernet3/0/1
Job name: start-Ten-GigabitEthernet3/0/2
# Display the schedule information.
[Sysname] display scheduler schedule
Schedule name        : START-pc1/pc2
Schedule type        : Run on every Mon Tue Wed Thu Fri at 08:00:00
Start time           : Wed Sep 28 08:00:00 2011
Last execution time  : Wed Sep 28 08:00:00 2011
Last completion time : Wed Sep 28 08:00:03 2011
Execution counts     : 1
start-Ten-GigabitEthernet3/0/1                                 Successful
start-Ten-GigabitEthernet3/0/2                                 Successful
Schedule name        : STOP-pc1/pc2
Schedule type        : Run on every Mon Tue Wed Thu Fri at 18:00:00
Start time           : Wed Sep 28 18:00:00 2011
Last execution time  : Wed Sep 28 18:00:00 2011
Last completion time : Wed Sep 28 18:00:01 2011
shutdown-Ten-GigabitEthernet3/0/1                              Successful
shutdown-Ten-GigabitEthernet3/0/2                              Successful
# Display schedule log information.
[Sysname] display scheduler logfile
Job name        : start-Ten-GigabitEthernet3/0/1
Execution time  : Wed Sep 28 08:00:00 2011
Completion time : Wed Sep 28 08:00:02 2011
<Sysname>system-view
[Sysname]interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1]undo shutdown
Job name        : start-Ten-GigabitEthernet3/0/2
[Sysname]interface ten-gigabitethernet 3/0/2
[Sysname-Ten-GigabitEthernet3/0/2]undo shutdown
Job name        : shutdown-Ten-GigabitEthernet3/0/1
Execution time  : Wed Sep 28 18:00:00 2011
Completion time : Wed Sep 28 18:00:01 2011
[Sysname-Ten-GigabitEthernet3/0/1]shutdown
Job name        : shutdown-Ten-GigabitEthernet3/0/2
[Sysname-Ten-GigabitEthernet3/0/2]shutdown
If the device has two MPUs, one MPU is in active state and the other one is in standby state. Typically, the device uses the MPU that has a smaller slot number as the active MPU.
The standby MPU automatically synchronizes its running configuration with the active MPU. If the active MPU fails or is removed, the standby MPU immediately takes over to ensure device operation continuity. You can also manually trigger an active/standby switchover.
This feature is available only in standalone mode.
As a best practice, save the running configuration before triggering an active/standby switchover. After you trigger an active/standby switchover, the current active MPU reboots.
2.     Manually trigger an active/standby switchover.
system switchover
The port-down feature applies to scenarios where two devices (one active and one standby) are used for high availability. This feature shuts down all service ports on the active device immediately after both MPUs on the active device are removed or reboot abnormally. The shutdown operation ensures quick service switchover to the standby device.
This feature takes effect only when no MPUs are available on the active device.
2.     Enable the port-down feature globally.
monitor handshake-timeout disable-port
By default, the port-down feature is enabled.
For easy management, this feature allows you to configure an asset profile for a physical component, such as a frame and a card.
2.     Configure an asset profile for a physical component.
In standalone mode:
set asset-info { chassis | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
In IRF mode:
set asset-info chassis chassis-number { chassis | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
About device reboot
The following device reboot methods are available:
·     Schedule a reboot at the CLI, so the device automatically reboots at the specified time or after the specified period of time.
·     Immediately reboot the device at the CLI.
During the reboot process, the device performs the following operations:
a.     Resets all of its chips.
b.     Uses the BootWare to verify the startup software package, decompress the package, and load the images.
c.     Initializes the system.
·     Power off and then power on the device. This method might cause data loss, and is the least-preferred method.
Using the CLI, you can reboot the device from a remote host.
For data security, the device does not reboot while it is performing file operations.
Perform the following steps in any view:
1.     Verify that the next-startup configuration file is correctly specified.
display startup
For more information about the display startup command, see Fundamentals Command Reference.
2.     Verify that the startup image files are correctly specified.
display boot-loader
If one main startup image file is damaged or does not exist, you must specify another main startup image file before rebooting the device.
For more information about the display boot-loader command, see Fundamentals Command Reference.
3.     Save the running configuration to the next-startup configuration file.
save
To avoid configuration loss, save the running configuration before a reboot.
For more information about the save command, see Fundamentals Command Reference.
To reboot the device immediately at the CLI, execute one of the following commands in user view:
In standalone mode:
In IRF mode:
CAUTION
CAUTION:
·     A device reboot might result in a service outage. Before using this command, make sure you understand its impact on the live network.
·     Use the force keyword to reboot the device only when the system is faulty or fails to start up normally. A forced device reboots might cause file system damage. Before using the force keyword to reboot the device, make sure you understand its impact.
Using this feature has the same effect as specifying the slot number for the reboot slot slot-number command and executing the command. This feature does not require you to specify an argument and is easier to use.
2.     Reboot the standby MPU.
restart standby
(In standalone mode.) The automatic reboot configuration is canceled if an active/standby switchover occurs.
(In IRF mode.) The automatic reboot configuration is effective on all member devices. It will be canceled if a switchover between the global active MPU and a global standby MPU occurs.
The device supports only one device reboot schedule. If you execute the scheduler reboot command multiple times, the most recent configuration takes effect.
To schedule a reboot, execute one of the following commands in user view:
·     scheduler reboot at time [ date ]
·     scheduler reboot delay time
By default, no device reboot time is specified.
CAUTION
CAUTION:
This task enables the device to reboot at a scheduled time, resulting in service interruption. Before using this command, make sure you understand its impact on the live network.
If you want to use the device in a different scenario or you cannot troubleshoot the device by using other methods, use this task to restore the factory-default configuration.
This task does not delete .bin files and license files.
This feature is disruptive.
1.     Execute the following command in user view to restore the factory-default configuration for the device:
restore factory-default
2.     Reboot the device.
reboot
CAUTION
CAUTION:
This command restores the device to the factory default settings. Before using this command, make sure you understand its impact on the live network.
When the command prompts you to choose whether to save the running configuration, enter N. If you choose to save the running configuration, the device loads the saved configuration at startup.
Execute display commands in any view. Execute the reset scheduler logfile command in user view. Execute reset version-update-record in system view.
Display device alarm information.
In standalone mode:
display alarm [ slot slot-number ]
In IRF mode:
display alarm [ chassis chassis-number slot slot-number ]
Display the asset profile for a physical component.
In standalone mode:
display asset-info { chassis | slot slot-number } [ csn | custom| department | description | location | service-date | state ]
In IRF mode:
display asset-info chassis chassis-number { chassis | slot slot-number } [ csn | custom| department | description | location | service-date | state ]
Display the system time, date, time zone, and daylight saving time.
display clock
Display the copyright statement.
display copyright
Display CPU usage statistics.
The core keyword is mutually exclusive with the control-plane and data-plane keywords.
In standalone mode:
display cpu-usage [ control-plane | data-plane ]  [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
In IRF mode:
display cpu-usage [ control-plane | data-plane ]  [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
Display CPU usage monitoring settings.
In standalone mode:
In IRF mode:
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display the historical CPU usage statistics in a coordinate system.
In standalone mode:
In IRF mode:
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display hardware information.
In standalone mode:
display device[ flash | usb ]  [ slot slot-number [ subslot subslot-number ] | verbose ]
In IRF mode:
display device[ flash | usb ]  [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
Display electronic label information for the device.
In standalone mode:
In IRF mode:
display device manuinfo [ chassis chassis-number [ slot slot-number ] ]
Display electronic label information for the chassis backplane.
In standalone mode:
display device manuinfo chassis-only
In IRF mode:
display device manuinfo chassis chassis-number chassis-only
Display electronic label information for a power module. This feature is supported only on the S7506X-G and S7510X-G switches.
In standalone mode:
display device manuinfo power power-id
In IRF mode:
display device manuinfo chassis chassis-number power power-id
Display information about card uptime starting from the latest startup.
display device uptime
Display or save operating information for features and hardware modules.
display diagnostic-information [ hardware | ifmgr | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
Display device temperature information.
In standalone mode:
In IRF mode:
display environment [ chassis chassis-number [ slot slot-number ] ]
Display the operating states of fan trays.
In standalone mode:
display fan [ verbose ]
In IRF mode:
display fan [ chassis chassis-number ] [ verbose ]
Display hardware failure detection and fix information.
display hardware-failure-detection
Display memory usage statistics.
In standalone mode:
In IRF mode:
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display DMA memory usage statistics.
In standalone mode:
display memory dma [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display memory dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display memory alarm thresholds and statistics.
In standalone mode:
In IRF mode:
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display DMA memory alarm information.
In standalone mode:
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display power module information.
In standalone mode:
display power [ power-id | verbose ]
In IRF mode:
display power [ chassis chassis-number [ power-id | verbose ] ]
Display power supply management information.
In standalone mode:
In IRF mode:
display power-supply [ chassis chassis-number ]
Display resource monitoring information.
In standalone mode:
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display resource-monitor [ resource resource-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display job configuration information.
Display job execution log information.
Display the automatic reboot schedule.
display scheduler reboot
Display schedule information.
Display system heath status information.
In standalone mode:
display system health
In IRF mode:
display system health [ chassis chassis-number ]
Display historical system heath status change information.
In standalone mode:
display system health history
In IRF mode:
display system health history[ chassis chassis-number ]
Display system stability and status information.
display system stable state [ mdc { mdc-id | all } ]
Display system working mode information.
display system-working-mode
Display health information of transceiver modules.
display transceiver health interface [ interface-type interface-number ]
Display power information for transceiver modules.
display transceiver power [ interface interface-type interface-number ]
Display transceiver module status information.
This command is supported only on the 400G, SFP, and QSFP transceiver modules.
display transceiver status interface [ interface-type interface-number ]
Display system version information.
display version
Display startup software image upgrade records.
display version-update-record
Display the load modes for MPUs. The load mode information does not take effect on the S7503X-G and S7503X-M-G switches.
In standalone mode:
display xbar
In IRF mode:
display xbar [ chassis chassis-number ]
Clear the asset profile for a physical component.
In standalone mode:
reset asset-info { chassis | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
In IRF mode:
reset asset-info chassis chassis-number { chassis | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
Clear job execution log information.
Clear startup software image upgrade records.
