HomeSupportSwitchesS7500X-G SeriesConfigure & DeployConfiguration GuidesH3C S7500X-G Switch Series Configuration Guides-R7755Pxx-6W10001-Fundamentals Configuration Guide
09-ISSU configuration
09-ISSU configuration 407.36 KB
Performing an ISSU·· 1
About ISSU· 1
ISSU advantages· 1
ISSU methods· 1
ISSU commands· 2
Operating mechanism·· 2
Application scenarios· 3
Restrictions and guidelines: ISSU· 4
Prerequisites for ISSU· 5
Logging in to the device through the console port 5
Identifying availability of ISSU and licensing requirements· 5
Verifying the device operating status· 5
Preparing the upgrade images· 6
Identifying the ISSU methods· 6
Verifying the device configuration· 6
Verifying feature status· 6
Determining the upgrade procedure· 7
Adjusting and saving the running configuration· 7
Performing an ISSU by using issu commands· 8
Performing a compatible upgrade on a multichassis IRF fabric (in IRF mode) 8
Performing an incompatible upgrade on a multichassis IRF fabric (in IRF mode) 9
Performing an ISSU by using install commands· 10
ISSU tasks at a glance· 10
Decompressing an .ipe file· 10
Installing and upgrading software images· 11
Deactivating software images· 12
Rolling back the running software images· 13
Aborting a software activate or deactivate operation· 14
Committing software changes· 14
Verifying software images· 14
Deleting inactive software images· 15
Terminating the ongoing ISSU process forcibly· 15
Display and maintenance commands for ISSU· 15
Examples of using issu commands for ISSU (in IRF mode) 18
Example: Upgrading the system software to a compatible version· 18
Example: Upgrading the system software to an incompatible version· 24
Example: Rolling back the system software· 28
Examples of using install commands for ISSU (in standalone mode) 33
Example: Upgrading the system software· 33
Example: Rolling back a feature· 36
Examples of using install commands for ISSU (in IRF mode) 37
Example: Upgrading the system software· 37
Example: Rolling back a feature· 42
Performing an ISSU
About ISSU
The In-Service Software Upgrade (ISSU) feature upgrades the Comware software with a minimum amount of downtime.
Unless otherwise stated, the term "upgrade" refers to both software upgrade and downgrade in ISSU.
ISSU advantages
The Comware software includes the boot image, the system image, and feature images. ISSU supports upgrading the images individually.
When you use ISSU to upgrade a feature, only the related feature images are affected. Other features can continue to provide services.
ISSU supports installing patch images to fix system bugs without a system reboot.
ISSU methods
ISSU methods are determined at software release depending on the compatibility between software versions.
ISSU supports the following upgrade types:
·     Compatible upgrade—The new software version is compatible with the running software version. This upgrade type supports the ISSU methods in Table 1.
·     Incompatible upgrade—The new software version is incompatible with the running software version. The two versions cannot run concurrently.
This upgrade type supports only one upgrade method (also called incompatible upgrade). This method requires a cold reboot to upgrade both control and data planes. Incompatible upgrade disrupts service if hardware redundancy is not available.
For the compatibility matrix, see the ISSU upgrade type matrix in the release notes.
For information about identifying the ISSU method, see "Identifying the ISSU methods."
Table 1 ISSU methods for compatible upgrade
ISSU method
Incremental upgrade:
·     Service Upgrade
·     File Upgrade
Upgrades only user mode processes that have differences between the new and old software versions. Backup processes and a main/backup process switchover are required for service continuity.
·     Service upgrade—Upgrades service features. The upgrade does not affect the operation of the features that are not being upgraded.
·     File upgrade—Upgrades hidden system program files. The system can provide services during the upgrade.
Reboot
CAUTION CAUTION:
The Reboot method disrupts service if hardware redundancy is not available. As a best practice, schedule the downtime carefully to minimize the upgrade impact on the services.
(In standalone mode.) Reboots MPUs to complete the software upgrade. While one MPU is rebooting, the other MPU can provide services.
(In IRF mode.) Reboots MPUs to complete the software upgrade. While one MPU is rebooting, the other MPUs can provide services.
ISSU commands
ISSU includes the install and issu command sets. After you identify the recommended ISSU method, use Table 2 to choose the command set you want to use.
Table 2 Command set comparison
Item
issu commands
install commands
Upgrade types
·     Compatible.
·     Incompatible.
Compatible.
Upgrade mode
Chassis by chassis.
MPU by MPU.
Impact on the system
Large.
Small.
Technical skill requirements
Low.
As a best practice, use this command set.
High.
Administrators must have extensive system knowledge and understand the impact of each upgrade task on the network.
Operating mechanism
As shown in Figure 1, the upgrade operates as follows:
1.     The device is in Init state before the upgrade and enters Loading state when the issu load command is executed to upgrade a subordinate device in the IRF fabric. When the upgrade completes, the device enters Loaded state.
2.     The device enters Switching state when the issu run switchover command is executed to perform an ISSU switchover. When the switchover completes, the device enters Switchover state.
3.     The device enters Accepted state when the issu accept command is executed successfully to accept the upgrade to a compatible version and delete the automatic rollback timer.
4.     The device enters Committing state when the issu commit command is executed to upgrade all other member devices in the IRF fabric. When the upgrade completes, the device enters Init state.
IMPORTANT
IMPORTANT:
If a rollback is performed during the upgrade process, the system will roll back to the version before the upgrade.
Figure 1 Performing a compatible upgrade on a multichassis IRF fabric
As shown in Figure 2, the upgrade operates as follows:
2.     The device enters Switching state when the issu run switchover command is executed to perform an ISSU switchover. All the other members will be upgraded. When the switchover completes, the device enters Init state.
IMPORTANT
IMPORTANT:
Figure 2 Performing an incompatible upgrade on a multichassis IRF fabric
Traditional software upgrade methods require a device reboot, which will affect the services running on the system and communication service quality. To address this issue, you can use ISSU to upgrade the software to ensure uninterrupted services or a short service interruption period during the upgrade process.
IMPORTANT
IMPORTANT:
·     For a successful ISSU, you must remove all commands that the new version does not support and save the running configuration. To identify the feature changes between the current version and the new version, read the release notes for the device.
·     To ensure correct system operation, you must remove the commands configured for features to be uninstalled and save the running configuration before uninstalling the features.
During an ISSU, follow these restrictions and guidelines:
·     Do not execute the install, issu, or boot-loader command before the current upgrade action completes.
·     Do not perform any of the following tasks:
¡     Reboot, add, or remove cards.
¡     Perform tasks that are irrelevant to the ISSU, such as modifying the configuration and displaying information.
¡     Modify, delete, or rename image files.
·     You cannot use both install and issu commands for the same ISSU.
·     For better service continuity, strictly follow the recommended ISSU procedure. Make sure a step is completed before you proceed to the next step.
·     You only need to perform the upgrade on the default MDC. The system completes software upgrade for all the other MDCs automatically.
·     Before executing the issu load command for the first time, use the display system stable state command to verify that the system is stable. If the System State field displays Stable, the system is stable.
·     Before executing the following commands, use the display system stable state command to verify that the system is stable:
¡     issu commandsissu load, issu run switchover, and issu commit.
¡     install commandsinstall activate and install deactivate.
·     You may use issu commands to upgrade all or some of the software images. If you are upgrading only some of the images, make sure the new images are compatible with the images that are not to be upgraded. The upgrade will fail if a conflict exists.
·     You can install up to 32 .bin files on the device, including one boot image file, one system image file, and up to 30 feature and patch image files.
·     A patch image file can be incremental or non-incremental. You can install up to 30 incremental patch image files by using a single command. Because each boot, system, or feature image can have one non-incremental patch image file, you can install up to 16 non-incremental patch image files by using a single command. For more information about incremental and non-incremental patch image files, see "Upgrading software."
After an ISSU, you must log in to the device again before you can use the changed or added commands.
After an ISSU, use the display boot-loader command to verify that the new software images have been successfully loaded. The startup software images must always be in the flash memory and cannot be deleted. If you delete them, the device cannot restart after being rebooted.
To perform a successful ISSU, make sure all the preparation requirements are met.
Log in to the device through the console port. If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
Read the software release notes to identify the following items:
·     Support of the device for ISSU between the current software version and the new software version.
·     Licensing requirements for the upgrade software images. If the upgrade software images require licenses, make sure the device has the required licenses. For more information about license installation, see "Managing licenses."
Verify the following items:
·     Use the display device command to verify that all installed components are in Master, Standby, or Normal state.
·     Use the display mdc command to verify that all MDCs are in active state.
·     Use the switchto mdc command to log in to each MDC and verify that no automatic configuration process is in progress. If an automatic configuration process is in progress on an MDC, wait for the process to complete. If automatic configuration is not deployed for the MDC, quit the automatic configuration process as prompted. For more information about automatic configuration, see "Using automatic configuration."
·     Use the display irf command to verify that all member devices are operating correctly.
·     Use the display cpu-usage command to verify that no CPU usage alarm exists on the device. As a best practice, verify that the CPU usage is lower than the CPU usage recovery threshold on each component.
·     Use the display memory and display memory-threshold commands to verify that no memory alarm exists on the device. As a best practice, verify that the free memory is greater than the normal state threshold on each component.
·     Use the display fan command to verify that all fans are in Normal state.
·     Use the display power command to verify that all power supplies are in Normal state.
·     Use the display environment command to verify that the temperature of each component is lower than the high-temperature warning threshold.
·     Use the display counters rate inbound interface command to verify that all interfaces are forwarding packets correctly.
·     Use the display interface | include CRC command to verify that all interfaces are forwarding packets correctly.
1.     Use the dir command to verify that every file system has sufficient free storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete /unreserved file-url command. If the files to be deleted will be used, back up the files before deleting them. You will be unable to restore a deleted file if the /unreserved keyword is used. For more information, see "Managing file systems."
2.     (In standalone mode.) Use FTP or TFTP to transfer upgrade image files (in .bin or .ipe) to the root directory of a file system on the active MPU.
3.     (In IRF mode.) Use FTP or TFTP to transfer upgrade image files (in .bin or .ipe) to the root directory of a file system on the global active MPU.
1.     Execute the display version comp-matrix file command to identify the recommended ISSU methods.
¡     For a compatible upgrade, check the Upgrade Way field to identify the recommended ISSU methods.
¡     For an incompatible upgrade, check the end of command output for the Incompatible upgrade string.
For more information about ISSU methods, see Table 1.
For a successful ISSU reboot or incompatible upgrade and the IRF fabric integrity during the ISSU, a set of features must have the same configuration as expected after the upgrade. The following are the features and the commands for you to change and verify feature settings:
·     System operating mode.
system-working-mode
display system-working-mode
·     Maximum number of ECMP routes.
max-ecmp-num
display max-ecmp-num
For more information about system operating mode, see device management in Fundamentals Configuration Guide.
For more information about ECMP routes, see basic IP routing configuration in Layer 3IP Routing Configuration Guide.
For service continuity during an ISSU, configure the following feature settings:
Feature
Setting requirements
GR and NSR
Enable GR or NSR for protocols including  OSPF, ISIS, BGP, and FSPF.
Use the display commands to verify that the system is in stable state after GR or NSR is enabled for a protocol. For example, use the display ospf graceful-restart or display ospf non-stop-routing status command to verify that the system is in stable state after GR or NSR is enabled for OSPF.
BFD
Disable BFD for protocols including  OSPF, IS-IS, RIP, BGP, VRRP, and NQA.
Ethernet link aggregation
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups.
Make sure all member ports are Selected ports.
IRF
Before performing an incompatible upgrade for the IRF fabric, verify that IRF MAD is disabled. To use IRF MAD, enable IRF MAD after finishing the upgrade.
Configure IRF bridge MAC persistence as follows:
·     Compatible upgrade—Execute the irf mac-address persistent timer or irf mac-address persistent always command.
·     Incompatible upgrade—Execute the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command.
1.     Use Table 2 to choose an upgrade command set, depending on the ISSU method.
2.     Identify the hardware redundancy condition.
ISSU can maintain service continuity only when the following conditions are met:
¡     (In IRF mode.) The IRF fabric has multiple members and uses the ring topology.
¡     (In standalone mode.) The device has two MPUs that are operating correctly.
¡     (In IRF mode.) The IRF fabric has two or more MPUs that are operating correctly.
IMPORTANT
IMPORTANT:
If hardware redundancy is not available, service discontinuity is not avoidable during a reboot upgrade or an incompatible upgrade. Make sure you understand the impact of the upgrade on the network.
3.     Choose the correct procedure from the procedures described in "Performing an ISSU by using issu commands" or "Performing an ISSU by using install commands."
1.     Remove all commands that the new software version does not support from the running configuration. To identify all feature changes between the current version and the new version, read the release notes for the device.
2.     To uninstall a feature image, remove the commands configured for the feature.
3.     Use the save command to save the running configuration.
Upgrade a subordinate member device first. Then, upgrade the remaining member devices, including the original master.
1.     (Optional.) Disable Disable automatic rollback:
a.     Enter system view.
b.     Disable automatic rollback.
issu rollback-timer 0
By default, the automatic rollback timer is 45 minutes.
The automatic rollback feature is complex. As a best practice, disable automatic rollback before performing an ISSU.
c.     Return to user view.
2.     Verify that the system is stable.
The system is stable if the System State field displays Stable. For a successful ISSU, you must make sure the system is stable before you proceed to the next step.
3.     Load the upgrade images as main startup software images on a subordinate member to upgrade the subordinate member.
¡     Use .bin files:
issu load file { boot filename | system filename | feature filename&<1-30> | patch filename&<1-30> } * chassis chassis-number [ reboot ]
¡     Use an .ipe file:
issu load file ipe ipe-filename [ patch filename&<1-30> ] chassis chassis-number&<1-3> [ reboot ]
The software images for the device are digitally signed. The system verifies the digital signatures of the specified software images for authenticity and integrity before it sets or loads them as main startup images. If the digital signature verification fails, the system will not set or load the specified images as main startup images and you will receive a digital signature verification failure message.
4.     Verify that the system is stable.
The system is stable if the System State field displays Stable. For a successful ISSU, you must make sure the system is stable before you proceed to the next step. If the system reported an error in the previous step, verify that the system is stable and then use the issu rollback command to roll back the upgrade.
5.     Perform an ISSU switchover.
issu run switchover
This command also starts the automatic rollback timer. If the timer expires, the system automatically rolls back to the original software images..
6.     (Optional.) Accept the upgrade and delete the automatic rollback timer.
issu accept
Execute this command before the automatic rollback timer expires.
7.     Verify that the system is stable.
8.     Upgrade the remaining members to complete the ISSU.
issu commit chassis chassis-number
CAUTION
CAUTION:
Repeat the previous step and this step to upgrade the remaining member devices, including the original master device. After you execute this command for one member device, wait for the member device to start up and join the IRF fabric again before you upgrade another member device. This practice ensures a successful ISSU.
After all members are upgraded, the ISSU status changes to Init, and the ISSU process ends and cannot be rolled back.
9.     Verify that the ISSU is finished.
display issu state
If the ISSU state field displays Init, the ISSU is finished.
Upgrade one or more subordinate member devices first. Then, upgrade the remaining member devices, including the original master.
To perform an incompatible upgrade on a multichassis IRF fabric, execute the following commands in user view:
1.     Verify that the system is stable.
2.     Load the upgrade images as main startup software images on subordinate members to upgrade the subordinate members.
¡     Use .bin files:
issu load file { boot filename | system filename | feature filename&<1-30> | patch filename&<1-30> } * chassis chassis-number&<1-3> [ reboot ]
¡     Use an .ipe file:
As a best practice on a ring-topology IRF fabric, specify half of the subordinate members for this command to reduce service interruption. Make sure the specified subordinate members are physically connected.
3.     Verify that the system is stable.
4.     Perform an ISSU switchover to complete the ISSU process.
issu run switchover
5.     Verify that the ISSU is finished.
display issu state
1.     (Optional.) Decompressing an .ipe file
2.     Installing and upgrading software images
3.     (Optional.) Deactivating software images
4.     (Optional.) Rolling back the running software images
5.     (Optional.) Aborting a software activate or deactivate operation
6.     (Optional.) Verifying software images
7.     Committing software changes
8.     (Optional.) Deleting inactive software images
1.     (Optional.) Identify images that are included in the .ipe file.
display install ipe-info
2.     Decompress the .ipe file.
install add ipe-filename filesystem
Use this task to install new feature and patch images or upgrade the boot, system, or feature images.
Software image installation and upgrade methods
Use one of the following methods to install or upgrade software images:
·     Slot by slot—Activate all the images on one slot, and then move to the next slot.
·     Image by image—Activate one image on all slots before moving to another image. Before using this method, read the release notes to make sure the upgrade images are compatible with the current images. If the upgrade images are not compatible with the current images, the upgrade might fail.
In standalone mode:
·     To install an image, you must begin with the active MPU.
·     To upgrade an image, you must begin with the standby MPU.
In IRF mode:
·     To install an image, you must begin with the master. On each member device, you must begin with the active MPU.
·     To upgrade an image, you must begin with a subordinate device. On each member device, you must begin with the standby MPU.
(In standalone mode.) (In IRF mode.)  You do not need to upgrade LPUs or switching fabric modules separately. They are upgraded automatically when MPUs are upgraded.
Installing or upgrading boot, system, and feature images
Execute the following commands in user view:
2.     (Optional.) Identify the recommended ISSU method and the possible impact of the upgrade.
In standalone mode:
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number test
In IRF mode:
install activate { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number slot slot-number test
3.     Activate images.
In standalone mode:
In IRF mode:
The software images for the device are digitally signed. The system will verify the digital signatures of the specified software images for authenticity and integrity before it activates them. If the digital signature verification fails, the system will not activate the specified images and you will receive a digital signature verification failure message.
Installing patch images
To install patch images, execute the following commands in user view:
The system is stable if the System State field displays Stable. For a successful installation, you must make sure the system is stable before you proceed to the next step.
2.     Install patch images.
In standalone mode:
install activate patch filename { all | slot slot-number }
You can specify only one patch image file for this command at a time. However, you can execute this command multiple times to install multiple patch image files.
The install activate patch filename all command installs the specified patch images on all hardware and the images can survive a reboot. You do not need to execute the install commit command for the installation.
In IRF mode:
install activate patch filename { all | chassis chassis-number slot slot-number }
The software images for the device are digitally signed. The system verifies the digital signature of a patch image for authenticity and integrity before it activates it. If the digital signature verification fails, the system will not activate the image and you will receive a digital signature verification failure message.
You can deactivate only feature and patch images.
The deactivate operation only removes images from the current software image list. For the image changes to take effect after a reboot, you must perform a commit operation to remove the images from the main startup image list.
Deactivated images are still stored on the storage medium. To permanently delete the images, execute the install remove command. For more information, see "Deleting inactive software images."
Deactivating feature images
To deactivate feature images, execute the following commands in user view:
The system is stable if the System State field displays Stable. For a successful deactivate operation, you must make sure the system is stable before you proceed to the next step.
2.     Deactivate feature images.
In standalone mode:
install deactivate feature filename&<1-30> slot slot-number
In IRF mode:
install deactivate feature filename&<1-30> chassis chassis-number slot slot-number
Deactivating patch images
To deactivate patch images, execute the following commands in user view:
2.     Deactivate patch images.
In standalone mode:
install deactivate patch filename { all | slot slot-number }
You can specify only one patch image file for this command at a time. However, you can execute this command multiple times to deactivate multiple patch image files.
The install deactivate patch filename all command deactivates the specified patch images on all hardware and the image changes can survive a reboot. You do not need to execute the install commit command for the deactivation.
In IRF mode:
install deactivate patch filename { all | chassis chassis-number slot slot-number }
During an incremental upgrade, the system creates a rollback point for each activate or deactivate operation of a boot, system, or feature image. The system can maintain a maximum of 50 rollback points. If this limit has been reached when a rollback point is created, the system removes the earliest rollback point. You can roll back the software to any of the rollback points.
During a reboot upgrade, the system does not create rollback points. After an ISSU reboot or reboot upgrade, you can roll back the software only to the status before any activate or deactivate operations were performed.
You can perform this task only before committing software changes. A commit operation deletes all rollback points.
For an incremental upgrade rollback to take effect after a reboot, you must perform a commit operation to update the main startup image list.
To roll back the running software images, execute the following commands in user view:
1.     (Optional.) Display available rollback points.
display install rollback
2.     Roll back the software.
install rollback to { point-id | original }
While the system is activating or deactivating a software image for a service upgrade or file upgrade, you can abort the activate or deactivate operation. After an operation is aborted, the system runs with the software images that it was running with before the operation.
To abort a software activate or deactivate operation, use one of the following methods:
·     Execute the install abort [ job-id ] command in user view.
·     Press Ctrl+C.
When you activate or deactivate images for an incremental upgrade, or activate or deactivate patch images, the main startup image list does not update with the changes. The software changes are lost at reboot. For the changes to take effect after a reboot, you must commit the changes.
To commit software changes, execute the following command in user view:
install commit
Perform this task to verify the following items:
·     Integrity—Verify that the boot, system, and feature images are integral.
·     Consistency—Verify that the same active images are running across the entire system.
·     Software commit status—Verify that the active images are committed as needed.
To verify software images, execute the following commands in user view:
1.     Verify software images.
install verify
2.     Activate or deactivate images as required.
install { activate | deactivate }
3.     Commit the software changes.
install commit
After completing an ISSU, you can use this task to delete old image files permanently.
This task deletes image files permanently. You cannot use the install rollback to command to revert the operation, or use the install abort command to abort the operation.
To delete inactive software image files, execute the following command in user view:
In standalone mode:
install remove [ slot slot-number ] { filename | inactive }
In IRF mode:
install remove [ chassis chassis-number slot slot-number ] { filename | inactive }
Use this feature to terminate the ISSU process if one of the following exceptions occurs and you cannot perform an upgrade or rollback:
·     The ISSU status is not Init but the upgrade has stopped.
·     The ISSU status is Init but the upgrade has not completed.
2.     Terminate the ongoing ISSU process forcibly.
issu quit
CAUTION
CAUTION:
The reset install rollback oldest command clears the specified rollback point and all rollback points earlier than the specified rollback point. You will be unable to roll back the configuration to the status when any of these rollback points was created.
Unless otherwise stated, the display and reset commands can be used during an ISSU, regardless of whether the install or issu commands are used.
(In standalone mode.) Execute display commands in any view and reset commands in user view.
Remarks
Display active software images.
display install active [ slot slot-number ] [ verbose ]
N/A
Display backup startup software images.
display install backup [ slot slot-number ] [ verbose ]
N/A
Display main startup software images.
display install committed [ slot slot-number ] [ verbose ]
N/A
Display inactive software images in the root directories of file systems.
display install inactive [ slot slot-number ] [ verbose ]
N/A
Display the software images included in an .ipe file.
display install ipe-info ipe-filename
N/A
Display ongoing ISSU activate, deactivate, and rollback operations.
display install job
N/A
Display ISSU log entries.
display install log [ log-id ] [ verbose ]
N/A
Display software image file information.
display install package { filename | all } [ verbose ]
N/A
Display rollback point information.
display install rollback [ point-id ]
The system does not record rollback points during an ISSU that uses issu commands.
Display the software image file that includes a specific component or file.
display install which { component name | file filename } [ slot slot-number ]
N/A
Display automatic rollback timer information.
display issu rollback-timer
N/A
Display ISSU status information.
display issu state
This command applies only to an ISSU that uses issu commands.
Display the ISSU methods.
display version comp-matrix file { boot filename | system filename | feature filename&<1-30> | patch filename&<1-30> } *
display version comp-matrix file ipe ipe-filename [ patch filename&<1-30> ]
N/A
Clear ISSU log entries.
reset install log-history oldest log-number
N/A
Clear ISSU rollback points.
reset install rollback oldest point-id
N/A
(In IRF mode.) Execute display commands in any view and reset commands in user view.
Remarks
display install active [ chassis chassis-number slot slot-number ] [ verbose ]
N/A
display install backup [ chassis chassis-number slot slot-number ] [ verbose ]
N/A
display install committed [ chassis chassis-number slot slot-number ] [ verbose ]
N/A
display install inactive [ chassis chassis-number slot slot-number ] [ verbose ]
N/A
N/A
display install job
N/A
N/A
N/A
display install which { component name | file filename } [ chassis chassis-number slot slot-number ]
N/A
N/A
display issu state
N/A
N/A
N/A
As shown in Figure 3, the IRF fabric has two members. Each member has one active MPU (slot 0) and one standby MPU (slot 1).
Upgrade the boot, system, and feature images from T0001015 to T0001016. The two versions are compatible.
Figure 3 Network diagram
# Download the upgrade image files from the TFTP server.
<Sysname> tftp 2.2.2.2 get boot-t0001016.bin
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   6078464  100  6078464     0     0    764      0 --:--:-- --:--:-- --:--:--   810
Writing file...Done.
<Sysname> tftp 2.2.2.2 get system-t0001016.bin
100   97750016  100  97750016     0     0    764      0 --:--:-- --:--:-- --:--:--   810
<Sysname> tftp 2.2.2.2 get feature-t0001016.bin
100   1008640  100  1008640     0     0    764      0 --:--:-- --:--:-- --:--:--   810
# Display active software images.
<Sysname> display install active
Active packages on chassis 1 slot 0:
  flash:/boot-t0001015.bin
  flash:/system-t0001015.bin
  flash:/feature-t0001015.bin
Active packages on chassis 1 slot 1:
Active packages on chassis 2 slot 0:
Active packages on chassis 2 slot 1:
# Identify the recommended ISSU methods.
<Sysname> display version comp-matrix file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin
Verifying the file flash:/boot-t0001016.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/system-t0001016.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/feature-t0001016.bin on chassis 1 slot 0..................................Done.
Identifying the upgrade methods....Done.
  Chassis   Slot              Upgrade Way
  1         0                 Reboot
  1         1                 Reboot
  2         0                 Reboot
  2         1                 Reboot
The output shows that reboot upgrades are recommended.
# Disable automatic rollback.
[Sysname] issu rollback-timer 0
# Enable the IRF bridge MAC address to be permanent.
[Sysname] irf mac-address persistent always
# Set the link-down and link-up event suppression intervals to 0 seconds on Ethernet interfaces.
[Sysname] interface gigabitethernet1/3/0/1
[Sysname-GigabitEthernet1/3/0/1] link-delay down 0
[Sysname-GigabitEthernet1/3/0/1] link-delay up 0
[Sysname-GigabitEthernet1/3/0/1] quit
[Sysname] interface gigabitethernet2/3/0/1
[Sysname-GigabitEthernet2/3/0/1] link-delay down 0
[Sysname-GigabitEthernet2/3/0/1] link-delay up 0
[Sysname-GigabitEthernet2/3/0/1] quit
[Sysname] quit
# Save the running configuration.
<Sysname> save
# Upgrade the system software on the subordinate member.
<Sysname> issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Copying file flash:/boot-t0001016.bin to chassis2#slot0#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis2#slot0#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis2#slot0#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 2 slot 0...Done.
Verifying the file flash:/system-t0001016.bin on chassis 2 slot 0............Done.
Verifying the file flash:/feature-t0001016.bin on chassis 2 slot 0...Done.
Copying file flash:/boot-t0001016.bin to chassis2#slot1#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis2#slot1#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis2#slot1#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 2 slot 1...Done.
Verifying the file flash:/system-t0001016.bin on chassis 2 slot 1............Done.
Verifying the file flash:/feature-t0001016.bin on chassis 2 slot 1...Done.
Identifying the upgrade methods….Done.
  Running Version             New Version
  Test 0001015                Test 0001016
  2         0                 Reboot
  2         1                 Reboot
This operation might take several minutes, please wait...Done.
# Verify that the ISSU is in a stable state.
<Sysname> display issu state
ISSU state: Loaded
Compatibility: Compatible
Work state: Normal
Upgrade method: Chassis by chassis
Upgraded chassis:
  chassis 2
Current upgrading chassis: None
Previous version list:
  boot: 7.1.070, Test 0001015
  system: 7.1.070, Test 0001015
  feature: 7.1.070, Test 0001015
Previous software images:
Upgrade version list:
  boot: 7.1.070, Test 0001016
  system: 7.1.070, Test 0001016
  feature: 7.1.070, Test 0001016
Upgrade software images:
The Loaded state is a stable state, which indicates that the system is waiting for a master/subordinate switchover. Chassis 2 has completed the upgrade, and chassis 1 has not.
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
  Chassis   Slot              Switchover Way
  1         0                 Master subordinate switchover
This operation might take several minutes, please wait.........
ISSU state: Switchover
Work state: Normal
Upgraded chassis:
  chassis 2
The Switchover state is a stable state, which indicates that the system has completed the master/subordinate switchover and is waiting for a commit operation to upgrade chassis 1.
# Upgrade the system software on the original master.
<Sysname> issu commit chassis 1
Copying file flash:/boot-t0001016.bin to chassis1#slot1#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis1#slot1#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis1#slot1#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 1 slot 1...Done.
Verifying the file flash:/system-t0001016.bin on chassis 1 slot 1............Done.
Verifying the file flash:/feature-t0001016.bin on chassis 1 slot 1...Done.
  1         0                 Reboot
  1         1                 Reboot
Verifying the upgrade
# Verify that the ISSU is finished.
ISSU state: Init
Compatibility: Unknown
Upgraded chassis: None
Current version list:
Current software images:
The ISSU state field displays Init, which indicates that the ISSU is finished.
# Verify that both members are running the new software images.
As shown in Figure 4, the IRF fabric has two members. Each member has one MPU in slot 0 (active MPU) and one MPU in slot 1 (standby MPU).
Upgrade the boot, system, and feature images from T0001015 to T0001017. The two versions are incompatible.
Figure 4 Network diagram
<Sysname> display version comp-matrix file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin
Verifying the file flash:/boot-t0001017.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/system-t0001017.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/feature-t0001017.bin on chassis 1 slot 0..................................Done.
Incompatible upgrade.
The output shows that an incompatible upgrade is recommended.
[Sysname] quit
<Sysname> save
# Upgrade the system software on the subordinate member. After the upgrade, the subordinate member will leave the original IRF fabric and form a new IRF fabric by itself.
<Sysname> issu load file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin chassis 2
Do you want to delete flash:/all.ipe now? [Y/N]:n
Copying file flash:/boot-t0001017.bin to chassis2#slot0#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis2#slot0#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis2#slot0#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 2 slot 0...Done.
Verifying the file flash:/system-t0001017.bin on chassis 2 slot 0............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 2 slot 0...Done.
Copying file flash:/boot-t0001017.bin to chassis2#slot1#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis2#slot1#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis2#slot1#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 2 slot 1...Done.
Verifying the file flash:/system-t0001017.bin on chassis 2 slot 1............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 2 slot 1...Done.
  Test 0001015                Test 0001017
  2         0                 Reboot
  2         1                 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
ISSU state: Loaded
Compatibility: Incompatible
Work state: Normal
Upgraded chassis:
  chassis 2
  boot: 7.1.070, Test 0001017
  system: 7.1.070, Test 0001017
  feature: 7.1.070, Test 0001017
# Perform a master/subordinate switchover to upgrade the original master. The original master will reboot and join the new IRF fabric.
Copying file flash:/boot-t0001017.bin to chassis1#slot1#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis1#slot1#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis1#slot1#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 1 slot 1...Done.
Verifying the file flash:/system-t0001017.bin on chassis 1 slot 1............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 1 slot 1...Done.
  1         0                 Reboot
  1         1                 Reboot
ISSU state: Init
Work state: Normal
As shown in Figure 5, the IRF fabric has two members. Each member has one MPU in slot 0 (active MPU) and one MPU in slot 1 (standby MPU).
Roll back the boot, system, and feature images from T0001016 to T0001015 after upgrading them from T0001015 to T0001016. T0001016 and T0001015 are compatible.
Figure 5 Network diagram
  1         0                 Reboot
  1         1                 Reboot
  2         0                 Reboot
  2         1                 Reboot
<Sysname> save
<Sysname> issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin chassis 2 reboot
  2         0                 Reboot
  2         1                 Reboot
ISSU state: Loaded
Work state: Normal
Upgraded chassis:
  chassis 2
Work state: Normal
Upgraded chassis:
  chassis 2
# Roll back the software images to T0001015.
<Sysname> issu rollback
This command will quit the ISSU process and roll back to the previous version. Continue? [Y/N]:Y
# Verify that the rollback is finished.
ISSU state: Init
Work state: Normal
The ISSU state field displays Init, which indicates that the rollback is finished.
# Verify that both members are running the old software images.
As shown in Figure 6, the device has two MPUs. The active MPU is in slot 0. The standby MPU is in slot 1.
Upgrade the Feature1 feature image from T0001015 to T0001016. The two versions are compatible.
Figure 6 Network diagram
# Download the .ipe file that contains the T0001016 Feature1 feature image from the TFTP server.
<Sysname> tftp 2.2.2.2 get feature1-t0001016.ipe
100   256  100  256     0     0    764      0 --:--:-- --:--:-- --:--:--   810
# Decompress the .ipe file.
<Sysname> install add flash:/feature1-t0001016.ipe flash:/
Verifying the file flash:/feature1-t0001016.ipe on slot 0...Done.
Decompressing file feature1-t0001016.bin to flash:/feature1-t0001016.bin.......................Done.
Active packages on slot 0:
  flash:/feature1-t0001015.bin
Active packages on slot 1:
# Identify the recommended ISSU methods and possible impact of the upgrade.
<Sysname> install activate feature flash:/feature1-t0001016.bin slot 1 test
Copying file flash:/feature1-t0001016.bin to slot1#flash:/feature1-t0001016.bin......Done.
Verifying the file flash:/feature1-t0001016.bin on slot 1...Done.
  Slot                        Upgrade Way
  1                           Service Upgrade
Influenced service according to following table on slot 1:
         Feature1
<Sysname> install activate feature flash:/feature1-t0001016.bin slot 0 test
Verifying the file flash:/feature1-t0001016.bin on slot 0...Done.
  Slot                        Upgrade Way
  0                           Service Upgrade
  1                           Service Upgrade
Influenced service according to following table on slot 0:
         Feature1
The output shows that both MPUs need a service upgrade and the Feature1 module will be rebooted during the upgrade.
# Activate the new Feature1 image to upgrade the Feature1 feature.
flash:/feature1-t0001016.bin already exists on slot 1.
Overwrite it?[Y/N]:y
  Slot                        Upgrade Way
  1                           Service Upgrade
  Slot                        Upgrade Way
  0                           Service Upgrade
  1                           Service Upgrade
# Verify that the new Feature1 image has been activated.
# Commit the software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
The current software images have been saved as the startup software images.
Current software images on slot 0:
Current software images on slot 1:
The Feature1 feature has been upgraded from T0001015 to T0001016. However, the software change has not been committed.
Roll back the Feature1 feature from T0001016 to T0001015.
# Display available rollback points.
<Sysname> display install rollback
  Install rollback information 1 on slot 0:
    Updating from flash:/feature1-t0001015.bin
  Install rollback information 2 on slot 1:
# Roll back the Feature1 feature to T0001015.
<Sysname> install rollback to original
# Verify that the MPUs are running the old Feature1 image.
As shown in Figure 7, the IRF fabric has two members. Each member has one MPU in slot 0 (active MPU) and one MPU in slot 1 (standby MPU).
Figure 7 Network diagram
Verifying the file flash:/feature1-t0001016.ipe on slot 1...Done.
<Sysname> install activate feature flash:/feature1-t0001016.bin chassis 2 slot 1 test
Copying file flash:/feature1-t0001016.bin to chassis2#slot1#flash:/feature1-t0001016.bin......Done.
Verifying the file flash:/feature1-t0001016.bin on chassis 2 slot 1...Done.
  2         0                 Service Upgrade
  2         1                 Service Upgrade
Influenced service according to following table on chassis 2 slot 0:
         Feature1
Influenced service according to following table on chassis 2 slot 1:
         Feature1
<Sysname> install activate feature flash:/feature1-t0001016.bin chassis 2 slot 0 test
Copying file flash:/feature1-t0001016.bin to chassis2#slot0#flash:/feature1-t0001016.bin......Done.
Verifying the file flash:/feature1-t0001016.bin on chassis 2 slot 0...Done.
  2         0                 Service Upgrade
         Feature1
<Sysname> install activate feature flash:/feature1-t0001016.bin chassis 1 slot 1 test
Copying file flash:/feature1-t0001016.bin to chassis1#slot1#flash:/feature1-t0001016.bin......Done.
Verifying the file flash:/feature1-t0001016.bin on chassis 1 slot 1...Done.
  1         0                 Service Upgrade
  1         1                 Service Upgrade
Influenced service according to following table on chassis 1 slot 0:
         Feature1
Influenced service according to following table on chassis 1 slot 1:
         Feature1
<Sysname> install activate feature flash:/feature1-t0001016.bin chassis 1 slot 0 test
Verifying the file flash:/feature1-t0001016.bin on chassis 1 slot 0...Done.
  1         0                 Service Upgrade
         Feature1
The output shows that all the MPUs need a service upgrade and the Feature1 module will be rebooted during the upgrade.
flash:/feature1-t0001016.bin already exists on chassis 2 slot 1.
  2         0                 Service Upgrade
  2         1                 Service Upgrade
flash:/feature1-t0001016.bin already exists on chassis 2 slot 0.
  2         0                 Service Upgrade
flash:/feature1-t0001016.bin already exists on chassis 1 slot 1.
  1         0                 Service Upgrade
  1         1                 Service Upgrade
Upgrading software images to compatible versions. Continue? [Y/N]: y
  1         0                 Service Upgrade
Current software images on chassis 1 slot 0:
Current software images on chassis 1 slot 1:
Current software images on chassis 2 slot 0:
Current software images on chassis 2 slot 1:
  Install rollback information 1 on chassis 1 slot 0:
  Install rollback information 2 on chassis 1 slot 1:
  Install rollback information 3 on chassis 2 slot 0:
  Install rollback information 4 on chassis 2 slot 1:
