09-Security Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C S12500&S10500&S7500 Switch Series Configuration Examples-R7639Pxx-6W10009-Security Configuration Examples
10-Port Security Configuration Examples
10-Port Security Configuration Examples 651.28 KB
Introduction· 1
Prerequisites· 1
General restrictions and guidelines· 1
Example: Configuring autoLearn mode· 2
Network configuration· 2
Applicable hardware and software versions· 2
Restrictions and guidelines· 3
Procedures· 3
Verifying the configuration· 3
Configuration files· 5
Example: Configuring userLoginWithOUI mode· 5
Network configuration· 5
Applicable hardware and software versions· 6
Procedures· 6
Configuring the RADIUS server 6
Configuring the device· 9
Verifying the configuration· 10
Configuration files· 13
Example: Configuring macAddressElseUserLoginSecure mode· 13
Network configuration· 13
Applicable hardware and software versions· 14
Software versions used· 14
Procedures· 15
Configuring the RADIUS server 15
Configuring the device· 17
Verifying the configuration· 18
Configuration files· 21
Example: Configuring port security to support redirect URL assignment by a ClearPass RADIUS server 22
Network configuration· 22
Applicable hardware and software versions· 23
Prerequisites· 23
Procedures· 23
Configuring the ClearPass RADIUS server 23
Configuring the device· 25
Verifying the configuration· 26
Configuration files· 30
Example: Configuring secure MAC entry aging for port security MAC move· 31
Network configuration· 31
Analysis· 32
Restrictions and guidelines· 32
Applicable hardware and software versions· 33
Procedures· 33
Configuring Device A· 33
Configuring Device B· 34
Verifying the configuration· 35
Configuration files· 35
Introduction
This document provides port security configuration examples.
Port security combines and extends 802.1X and MAC authentication to provide MAC-based network access control. The feature provides the following functions:
·     Prevents unauthorized access to a network by checking the source MAC address of inbound traffic.
·     Prevents access to unauthorized devices or hosts by checking the destination MAC address of outbound traffic.
·     Controls MAC address learning and authentication on a port to make sure the port learns only source trusted MAC addresses.
Port security supports the following categories of security modes:
·     MAC learning control—Includes two modes: autoLearn and secure. MAC address learning is permitted on a port in autoLearn mode and disabled in secure mode.
·     Authentication—Security modes in this category implement MAC authentication, 802.1X authentication, or a combination of these two authentication methods.
Port security can add sticky MAC addresses learned in autoLearn mode to the secure MAC address table. Only packets with the secure MAC addresses can pass through the port. A secure MAC address can be added on only one port in one VLAN.
By default, secure MAC addresses do not age out. The non-aging secure MAC addresses can lead to the following issues:
·     If a legitimate user leaves a port and an illegitimate user spoofs the legitimate user's source MAC to access the network, the legitimate user can no longer access the network through that port.
·     When a legitimate user moves to another port within the same VLAN, if the original port's secure MAC does not age out, the user will not be able to access the network from the new port.
·     Even though a legitimate user has left the port, it still occupies the port's MAC address resources, preventing other legitimate users from accessing the network.
Therefore, in some scenarios, allowing secure MAC addresses to age out can improve the security of port access and the utilization of port resources.
This document assumes that you have basic knowledge of port security.
When you configure port security, follow these restrictions and guidelines:
·     Disable global 802.1X and MAC authentications before you enable port security on a port.
·     Port security automatically modifies the following 802.1X or MAC authentication settings for different security modes:
¡     The status of 802.1X and MAC authentication.
¡     The 802.1X access control method.
¡     The 802.1X port authorization state.
·     Disabling port security on a port will log off all online users on that port.
·     Port security modes are mutually exclusive with link aggregation and service loopback group.
·     The maximum number of users a port supports equals the smaller value from the following values:
¡     The maximum number of secure MAC addresses that port security allows.
¡     The maximum number of concurrent users the authentication mode in use allows.
For example, if 802.1X allows more concurrent users than port security's limit on the number of MAC addresses on the port in userLoginSecureExt mode, port security's limit takes effect.
·     To change the security mode of a port security-enabled port, you must use the undo port-security port-mode command to set the port in noRestrictions mode first.
As shown in Figure 1:
·     Configure port security mode autoLearn on Ten-GigabitEthernet 1/0/1 to allow users to access the network without authentication.
·     Configure the port to accept a maximum of 64 users (secure MAC addresses) to access the network. After the number of secure MAC addresses reaches 64, the port stops learning secure MAC addresses and no new user can access the network.
·     To prevent inactive users from using secure MAC address entries, configure a secure MAC address aging timer.
·     Configure Ten-GigabitEthernet 1/0/1 to shut down temporarily for 30 seconds when a new user accesses the network after the number of secure MAC addresses reaches 64.
Figure 1 Network diagram
Hardware
Software version
S12500G-AF switch series
Release 7639P01 and later
S10500X switch series
S10500 switch series
S7500E-X switch series
S7500E switch series
S7500X switch series
Before you enable the autoLearn mode, you must set the maximum number of secure MAC addresses that port security allows on the port (by using the port-security max-mac-count command). You cannot change the setting after the port is set to the autoLearn mode.
Procedures
# Enable port security.
[Device] port-security enable
# Set the secure MAC aging timer to 30 minutes.
[Device] port-security timer autolearn aging 30
# Set port security's limit on the number of secure MAC addresses to 64 on Ten-GigabitEthernet 3/0/1.
[Device-Ten-GigabitEthernet1/0/1] port-security max-mac-count 64
# Set the port security mode to autoLearn.
[Device-Ten-GigabitEthernet1/0/1] port-security port-mode autolearn
# Specify the intrusion protection action as disableport-temporarily.
[Device-Ten-GigabitEthernet1/0/1] port-security intrusion-mode disableport-temporarily
# Configure the port to be silent for 30 seconds after the intrusion protection feature is triggered.
[Device] port-security timer disableport 30
# Verify that port security is correctly configured.
[Device] display port-security interface ten-gigabitethernet 1/0/1
Global port security parameters:
   Port security          : Enabled
   M-LAG load sharing mode (criterion)     : Distributed (local)
   M-LAG member's authentication scope     : Local M-LAG interfaces
   M-LAG member configuration conflict     : Unknown
   AutoLearn aging time   : 30 min
   Disableport timeout    : 30 s
   Blockmac timeout       : 180 s
   MAC move               : Denied
   Overwrite local entry for a moved MAC   : Enabled
   Authorization fail     : Online
   NAS-ID profile         : Not configured
   Dot1x-failure trap     : Disabled
   Dot1x-logon trap       : Disabled
   Dot1x-logoff trap      : Disabled
   Intrusion trap         : Disabled
   Address-learned trap   : Disabled
   Mac-auth-failure trap  : Disabled
   Mac-auth-logon trap    : Disabled
   Mac-auth-logoff trap   : Disabled
   Open authentication    : Disabled
   Traffic-statistics                         : Disabled
   User aging period for preauth domain   : 82800 sec
   User aging period for Auth-Fail domain : 82800 sec
   User aging period for critical domain  : 82800 sec
   Reauth period for preauth domain        : 600 sec
   Reauth period for Auth-Fail domain      : 600 sec
   MAC move for topology change protection : Denied
     Topology change detection period       : 5 sec
     Max detection attempts                   : 3
   OUI value list         :
Ten-GigabitEthernet1/0/1 is link-up
   Port mode                                     : autoLearn
   Pre-auth domain                             : Not configured
   URL-unavailable domain                      : Not configured
   NeedToKnow mode                             : Disabled
   Intrusion protection mode                 : DisablePortTemporarily
   Security MAC address attribute
       Learning mode                            : Sticky
       Aging type                                : Periodical
   Max secure MAC addresses                   : 64
   Current secure MAC addresses              : 5
   Authorization                                : Permitted
   Free VLANs                                    : Not configured
   MAC-move VLAN check bypass                 : Disabled
The port performs MAC address learning, and you can view the number of learned MAC addresses in the Current secure MAC addresses field.
# Display information about the learned MAC addresses.
[Device-Ten-GigabitEthernet1/0/1] display this
 port link-mode bridge
 port-security mac-address security sticky 00e0-fc00-5920 vlan 1
 port-security mac-address security sticky 00e0-fc00-592a vlan 1
 port-security mac-address security sticky 00e0-fc00-592b vlan 1
 port-security mac-address security sticky 00e0-fc00-592c vlan 1
 port-security mac-address security sticky 00e0-fc00-592d vlan 1
# Verify that the port security mode changes to secure after the number of MAC addresses learned by the port reaches 64.
# Verify that the port is disabled after it receives a frame with an unknown MAC address.
[Device] display interface ten-gigabitethernet 1/0/1
# Verify that the interface is re-enabled after 30 seconds.
# Delete several secure MAC addresses.
[Device-Ten-GigabitEthernet1/0/1] undo port-security mac-address security sticky 00e0-fc00-5920 vlan 1
[Device-Ten-GigabitEthernet1/0/1] undo port-security mac-address security sticky 00e0-fc00-592a vlan 1
# Verify that the port security mode changes to autoLearn and the port can learn MAC addresses again. (Details not shown.)
Configuration files
As shown in Figure 2:
·     An 802.1X user on a host and a printer are attached to port Ten-GigabitEthernet 1/0/1 on the device.
·     The device uses a RADIUS server (IMC in this example) to perform authentication, authorization, and accounting for all users in ISP domain sun.
·     The device and the server use the shared key expert for secure RADIUS communication.
Configure port security mode userLoginWithOUI on port Ten-GigabitEthernet 1/0/1 to meet the following requirements:
·     Permit only one 802.1X user to pass authentication.
·     Permit the printer to access the Internet.
For the printer to pass authentication, add its OUI to the OUI list of port security.
Configure the blockmac intrusion protection action on Ten-GigabitEthernet 1/0/1, so the device adds the source MAC addresses of illegal frames to the blocked MAC address list. The device discards all frames sourced from the blocked MAC addresses.
Figure 2 Network diagram
Hardware
Software version
Procedures
In this example, the RADIUS server runs IMC PLAT 7.0 (E0201) and IMC EIA 7.0 (E0201).
1.     Add the device to IMC as an access device:
a.     Click the User tab.
b.     From the navigation tree, select User Access Policy > Access Device Management > Access Device.
c.     Click Add.
The Add Access Device page opens.
d.     In the Access Configuration area, configure the following parameters:
-     Enter 1812 in the Authentication Port field, and enter 1813 in the Accounting Port field.
-     Select LAN Access Service from the Service Type list.
-     Select HP(Comware) from the Access Device Type list.
-     Enter expert in the Shared Key and Confirm Shared Key field.
-     Use the default values for other parameters.
e.     In the Device List area, click Select or Add Manually to add the device at 192.168.0.34 as an access device.
You must specify the source IP address of outgoing RADIUS packets on the device as the IP address of the access device on the server.
On the device, the source IP address is configured by using the nas-ip or radius nas-ip command. The IP address configured by using the nas-ip command has a higher priority than the IP address configured by using the radius nas-ip command. If no IP address is specified as the source IP address, the IP address of the packet outbound interface is used as the source IP address. In this example, the IP address of the packet outbound interface is used, which is 192.168.0.34.
f.     Click OK.
Figure 3 Adding the device as an access device
2.     Add an access policy:
b.     From the navigation tree, select User Access Policy > Access Policy.
c.     Click Add.
d.     On the page that opens, configure the following parameters, as shown in Figure 4:
-     Enter 802.1X-auth in the Access Policy Name field.
Figure 4 Adding an access policy
e.     Click OK.
3.     Add an access service:
b.     From the navigation tree, select User Access Policy > Access Service.
c.     Click Add.
d.     On the page that opens, configure the following parameters, as shown in Figure 5:
-     Enter 802.1X-auth in the Service Name field.
-     Select 802.1X-auth from the Default Access Policy list.
Figure 5 Adding an access service
e.     Click OK.
4.     Add an access user:
b.     From the navigation tree, select Access User Management > All Access Users.
c.     Click Add.
d.     On the Add Access User page, configure the following parameters, as shown in Figure 6:
-     Click Select or Add User to associate the user with IMC Platform user hello.
-     Enter 802.1X in the Account Name field.
-     Enter 802.1X in the Password and Confirm Password fields.
-     Configure other parameters in the Access Information area as needed.
-     Select 802.1X-auth from the Access Service list.
Figure 6 Adding an access user account
e.     Click OK.
The following steps have AAA RADIUS commands. For more information about the AAA RADIUS commands, see AAA commands in the security command reference for the device.
1.     Assign an IP address to each interface, as shown in Figure 2. Make sure the host, printer, device, and RADIUS server can reach each other. (Details not shown.)
2.     Configure the RADIUS scheme:
# Create RADIUS scheme radsun.
[Device] radius scheme radsun
New RADIUS scheme.
# Specify the server at 192.168.0.38 as the primary RADIUS authentication server.
[Device-radius-radsun] primary authentication 192.168.0.38
# Specify the server at 192.168.0.38 as the primary RADIUS accounting server.
[Device-radius-radsun] primary accounting 192.168.0.38
# Set the authentication shared key to expert in plain text for secure communication between the device and the RADIUS server.
[Device-radius-radsun] key authentication simple expert
# Set the accounting shared key to expert in plain text for secure communication between the device and the RADIUS server.
[Device-radius-radsun] key accounting simple expert
# Set the response timeout time of the RADIUS server to 5 seconds.
[Device-radius-radsun] timer response-timeout 5
# Set the maximum number of RADIUS packet retransmission attempts to 5.
[Device-radius-radsun] retry 5
# Set the real-time accounting interval to 15 minutes.
[Device-radius-radsun] timer realtime-accounting 15
# Exclude domain names from the usernames sent to the RADIUS server.
[Device-radius-radsun] user-name-format without-domain
[Device-radius-radsun] quit
# Create ISP domain sun and enter ISP domain view.
[Device] domain sun
# Configure ISP domain sun to use RADIUS scheme radsun for authentication, authorization, and accounting of all LAN users.
[Device-isp-sun] authentication lan-access radius-scheme radsun
[Device-isp-sun] authorization lan-access radius-scheme radsun
[Device-isp-sun] accounting lan-access radius-scheme radsun
[Device-isp-sun] quit
# Configure domain sun as the default domain.
[Device] domain default enable sun
3.     Set the 802.1X authentication method to CHAP. By default, the authentication method for 802.1X is CHAP.
[Device] dot1x authentication-method chap
4.     Configure port security:
# Add five OUI values, including the OUI of the printer. You can add a maximum of 16 OUI values. If the MAC address of a user matches one of the OUIs, the device will allow the user to pass authentication. Each port can permit only one OUI user to pass authentication.
[Device] port-security oui index 1 mac-address 1234-0100-1111
[Device] port-security oui index 2 mac-address 1234-0200-1111
[Device] port-security oui index 3 mac-address 1234-0300-1111
[Device] port-security oui index 4 mac-address 1234-0400-1111
[Device] port-security oui index 5 mac-address 1234-0500-1111
# Set the port security mode to userLoginWithOUI.
[Device-Ten-GigabitEthernet1/0/1] port-security port-mode userlogin-withoui
# Configure port Ten-GigabitEthernet 1/0/1 to perform the blockmac intrusion protection action.
[Device-Ten-GigabitEthernet1/0/1] port-security intrusion-mode blockmac
# Display RADIUS scheme radsun.
[Device] display radius scheme radsun
Total 1 RADIUS schemes
RADIUS scheme name: radsun
  Index: 0
  Primary authentication server:
    Host name: Not configured
    IP   : 192.168.0.38                             Port: 1812
    VPN  : Not configured
    State: Active
    Test profile: Not configured
    Weight: 0
  Primary accounting server:
    IP   : 192.168.0.38                             Port: 1813
    State: Active
    Weight: 0
  Accounting-On function                     : Disabled
    extended function                        : Disabled
    retransmission times                     : 50
    retransmission interval(seconds)         : 3
  Timeout Interval(seconds)                  : 5
  Retransmission Times                       : 5
  Retransmission Times for Accounting Update : 5
  Server Quiet Period(minutes)               : 5
  Realtime Accounting Interval(seconds)      : 900
  Stop-accounting packets buffering          : Enabled
    Retransmission times                     : 500
  NAS IP Address                             : Not configured
  User Name Format                           : without-domain
  Data flow unit                             : Byte
  Packet unit                                : One
  Attribute 15 check-mode                    : Strict
  Attribute 25                               : Standard
  Attribute Remanent-Volume unit             : Kilo
  server-load-sharing                        : Disabled
  Attribute 31 MAC format                    : HH-HH-HH-HH-HH-HH
  Stop-accounting-packet send-force          : Disabled
  Reauthentication server selection          : Reselect
# Display the port security configuration on Ten-GigabitEthernet 1/0/1.
   AutoLearn aging time                       : 0 min
   Disableport timeout                        : 20 s
   MAC move                                     : Denied
   OUI value list         :
       Index :  1       Value : 123401
       Index :  2       Value : 123402
       Index :  3       Value : 123403
       Index :  4       Value : 123404
       Index :  5       Value : 123405
   Port mode                                    : userLoginWithOUI
   Intrusion protection mode                  : NoAction
   Max secure MAC addresses                   : Not configured
   Current secure MAC addresses              : 0
After the 802.1X user comes online, the number of secure MAC addresses on the port is 1.
# Display 802.1X information.
[Device] display dot1x interface ten-gigabitethernet 1/0/1
# Verify that Ten-GigabitEthernet 1/0/1 allows a user whose MAC address has an OUI from the specified OUIs to pass authentication.
[Device] display mac-address interface ten-gigabitethernet 1/0/1
MAC Address      VLAN ID    State            Port/NickName            Aging
1234-0300-0011  1            Learned         XGE1/0/1                  Y
Configuration files
 port-security oui index 1 mac-address 1234-0100-0000
 port-security oui index 2 mac-address 1234-0200-0000
 port-security oui index 3 mac-address 1234-0300-0000
 port-security oui index 4 mac-address 1234-0400-0000
 port-security oui index 5 mac-address 1234-0500-0000
 key authentication cipher $c$3$s9TAYm34R8sS5k/Cylg2sDm69ZRupMvGJg==
 key accounting cipher $c$3$UaUPGk8AfZAQLHFlbKNcEoM2HXGiuWowBQ==
 retry 5
domain sun
As shown in Figure 7:
·     Users on hosts are attached to port Ten-GigabitEthernet 1/0/1 on the device.
·     All MAC authentication users use a shared user account with username aaa and password 123456.
·     The device uses a RADIUS server (IMC in this example) to perform authentication, authorization, and accounting for all users in domain sun.
·     The device and the server use shared key expert for secure RADIUS communication.
Configure port security mode macAddressElseUserLoginSecure on port Ten-GigabitEthernet 1/0/1 to meet the following requirements:
·     Allow only one 802.1X user to pass authentication, and allow multiple MAC authentication users to pass authentication.
·     MAC authentication has a higher priority than 802.1X authentication. For an 802.1X user, the device initiates MAC authentication first, and then 802.1X authentication if the user fails MAC authentication. For a MAC authentication user, the device initiates only MAC authentication.
Configure port Ten-GigabitEthernet 1/0/1 to accept a maximum of 64 authenticated users.
Set the NTK mode to ntkonly mode on port Ten-GigabitEthernet 1/0/1 to prevent outbound frames from being sent to unknown MAC addresses.
Figure 7 Network diagram
Hardware
Software version
This configuration example was created and verified on XXXX.
The RADIUS server runs IMC PLAT 7.0 (E0201) and IMC UAM 7.0 (E0201).
Procedures
1.     Add the device to IMC as an access device in the same way the device is added to IMC in "Example: Configuring userLoginWithOUI mode."
2.     Add an access policy, an access service, and an access user for 802.1X authentication in the same way they are added in "Example: Configuring userLoginWithOUI mode."
3.     Add an access policy for MAC authentication:
c.     Click Add.
d.     On the page that opens, configure the following parameters, as shown in Figure 8:
-     Enter MAC-auth in the Access Policy Name field.
Figure 8 Adding an access policy
e.     Click OK.
4.     Add an access service for MAC authentication:
c.     Click Add.
d.     On the page that opens, configure the following parameters, as shown in Figure 9:
-     Enter MAC-auth in the Service Name field.
-     Select MAC-auth from the Default Access Policy list.
Figure 9 Adding an access service
e.     Click OK.
5.     Add an access user for MAC authentication:
c.     Click Add.
d.     On the Add Access User page, configure the following parameters, as shown in Figure 10:
-     Click Select or Add User to associate the user with IMC Platform user hello2.
-     Enter aaa in the Account Name field.
-     Enter 123456 in the Password and Confirm Password fields.
-     Select MAC-auth from the Access Service list.
Figure 10 Adding an access user account
e.     Click OK.
1.     Assign an IP address to each interface, as shown in Figure 7. Make sure the hosts, device, and RADIUS server can reach each other. (Details not shown.)
New RADIUS scheme.
[Device] domain sun
# Specify ISP domain sun as the default domain.
3.     Configure MAC authentication:
# Configure a shared account for MAC authentication users, and set the username to aaa and password to plaintext string of 123456.
[Device] mac-authentication user-name-format fixed account aaa password simple 123456
# Specify domain sun as the global MAC authentication domain.
[Device] mac-authentication domain sun
4.     Set the 802.1X authentication method to CHAP. By default, the authentication method for 802.1X is CHAP.
5.     Configure port security:
# Set port security's limit on the number of secure MAC addresses to 64 on Ten-GigabitEthernet 1/0/1.
# Set the port security mode to macAddressElseUserLoginSecure.
[Device-Ten-GigabitEthernet1/0/1] port-security port-mode mac-else-userlogin-secure
# Set the NTK mode of the port to ntkonly.
[Device-Ten-GigabitEthernet1/0/1] port-security ntk-mode ntkonly
   MAC move                                      : Denied
   OUI value list         :
   Port mode                                    : macAddressElseUserLoginSecure
   NeedToKnow mode                             : NeedToKnowOnly
# Verify that port Ten-GigabitEthernet 1/0/1 allows multiple MAC authentication users to be authenticated.
[Device] display mac-authentication interface ten-gigabitethernet 1/0/1
   MAC authentication                  : Enabled
   Authentication method               : PAP
   Username format                     : Fixed account
           Username                    : aaa
           Password                    : ******
   Offline detect period               : 300 s
   Quiet period                        : 60 s
   Server timeout                      : 100 s
   Reauth period                       : 3600 s
   User aging period for critical VLAN : 1000 s
   User aging period for critical VSI  : 1000 s
   User aging period for guest VLAN    : 1000 s
   User aging period for guest VSI     : 1000 s
   Authentication domain               : sun
 Online MAC-auth wired user            : 3
 Silent MAC users:
          MAC address       VLAN ID  From port               Port index
   Carry User-IP                    : Disabled
   Authentication domain            : Not configured
   Auth-delay timer                 : Disabled
   Periodic reauth                  : Disabled
   Re-auth server-unreachable       : Logoff
   Guest VLAN                       : Not configured
   Guest VLAN auth-period           : 30
   Critical VLAN                    : Not configured
   Critical voice VLAN              : Disabled
   Host mode                        : Single VLAN
   Offline detection                : Enabled
   Authentication order             : Default
   User aging                       : Enabled
   Server-recovery online-user-sync : Enabled
   Guest VSI                        : Not configured
   Guest VSI auth-period            : 30 s
   Critical VSI                     : Not configured
   Auto-tag feature                 : Disabled
   VLAN tag configuration ignoring  : Disabled
   Max online users                 : 4294967295
   Authentication attempts          : successful 0, failed 0
   Current online users             : 3
          MAC address       Auth state
          1234-0300-0011   authenticated
          1234-0300-0012   authenticated
          1234-0300-0013   authenticated
# Verify that Ten-GigabitEthernet 1/0/1 allows only one 802.1X user to be authenticated.
Global 802.1X parameters:
   802.1X authentication                : Enabled
   CHAP authentication                  : Enabled
   Max-tx period                        : 30 s
   Handshake period                     : 15 s
   Quiet timer                          : Disabled
       Quiet period                     : 60 s
   Supp timeout                         : 30 s
   Max auth requests                    : 2
   User aging period for Auth-Fail VLAN : 1000 s
   User aging period for Auth-Fail VSI  : 1000 s
   EAD assistant function               : Disabled
       EAD timeout                      : 30 min
   Domain delimiter                     : @
 Online 802.1X wired users              : 1
   Handshake                        : Enabled
   Handshake reply                  : Disabled
   Handshake security               : Disabled
   Offline detection                : Disabled
   Unicast trigger                  : Disabled
   Port role                        : Authenticator
   Authorization mode               : Auto
   Port access control              : MAC-based
   Multicast trigger                : Enabled
   Mandatory auth domain            : Not configured
   Auth-Fail VLAN                   : Not configured
   Add Guest VLAN delay             : Disabled
   User IP freezing                 : Disabled
   Reauth period                    : 0 s
   Send Packets Without Tag         : Disabled
   Max Attempts Fail Number         : 0
   Auth-Fail VSI                    : Not configured
   Add Guest VSI delay              : Disabled
   Auth-Fail EAPOL                  : Disabled
   Critical EAPOL                   : Disabled
   EAPOL packets: Tx 0, Rx 0
   Sent EAP Request/Identity packets : 0
        EAP Request/Challenge packets: 0
        EAP Success packets: 0
        EAP Failure packets: 0
   Received EAPOL Start packets : 0
            EAPOL LogOff packets: 0
            EAP Response/Identity packets : 0
            EAP Response/Challenge packets: 0
            Error packets: 0
   Online 802.1X users: 1
# Verify that frames with an unknown destination MAC address, multicast address, or broadcast address are discarded. (Details not shown.)
Configuration files
 mac-authentication user-name-format fixed account aaa password cipher $c$3$HAlQ
nyXOwZXTgiOBPd7+kSPClKm7JbZ1Rw==
 retry 5
domain sun
As shown in Figure 11:
·     Users on hosts are attached to port Ten-GigabitEthernet 1/0/1 on the device. All MAC authentication users use a shared user account with username dot1x and password Abc123!.
·     The device acts as the NAS and a ClearPass RADIUS server performs remote authentication, authorization, and accounting for all users in domain sun. If a user passes authentication, the ClearPass server assigns a redirect URL to that user for Web authentication.
Configure port security mode macAddressElseUserLoginSecureExt on port Ten-GigabitEthernet 1/0/1 to meet the following requirements:
·     Allow multiple 802.1X users and MAC authentication users to pass authentication.
Set the NTK mode to ntkonly mode on Ten-GigabitEthernet 1/0/1 to prevent outbound frames from being sent to unknown MAC addresses.
Figure 11 Network diagram
Hardware
Software version
Install ClearPass Policy Manager on an ESX/ESXi Virtual Machine and set up the ClearPass server, including: importing CPPM-VM-x86_64-6.5.0.71095-ESX-CP-VA-500-ovf, adding resources to VMs, configuring the ClearPass management IP address (192.168.0.38 in this example), and setting the system time zone.
For more information about ClearPass server configuration, see the manual for the server.
Procedures
In this example, the ClearPass server runs CPPM-VM-x86_64-6.5.0.71095-ESX-CP-VA-500-ovf.
1.     Log in to the ClearPass Policy Manager (CPPM).
2.     On the Configuration > Network > Devices page, click Add at the top-right corner. On the page that opens, perform the following tasks:
a.     Specify the IP address of the network access device (192.168.0.34 in this example).
b.     Enter the RADIUS shared secret (also referred to as RADIUS shared key). In this example, the shared secret is expert.
c.     Select the device vendor name.
d.     Enable RADIUS CoA and use the default port number (3799) of RADIUS CoA.
e.     Click Add.
3.     On the Configuration > Network > Device Groups page, click Add at the top-right corner. On the page that opens, perform the following tasks:
a.     Set the group name to Group1.
b.     Add the IP address of the network access device (192.168.0.34 in this example) to the device group.
c.     Click Save.
4.     On the Configuration > Identity > Local Users page, click Add at the top-right corner. On the page that opens, perform the following tasks:
a.     Set the user ID and name to dot1x and set the password to Abc123!,
b.     Enable the user.
c.     Select Employee as the user role.
d.     Click Add.
5.     On the Configuration > Identity > Role Mappings page, click Add at the top-right corner. On the page that opens, perform the following tasks:
a.     Set the role mapping policy name to dot1x-redirect-role-map.
b.     Select Employee as the default user role.
c.     On the Mapping Rules tab, click Add Rule. On the page that opens, configure the parameters as follows:
-     Select Radius:IETF as the type.
-     Select User-Name as the name.
-     Select EQUALS as the operator.
-     Set the value to dot1x.
d.     Click Save.
e.     On the Summary tab, verify that the configuration is correct.
6.     On the Configuration > Enforcement > Profiles page, click Add at the top-right corner. On the page that opens, perform the following tasks:
a.     On the Profile tab, set the enforcement profile name to dot1x and select the device group that contains the network access device.
b.     On the Attributes tab, configure the redirect URL and specify an ACL to permit traffic that requires URL redirection. You must configure ACL rules on the network access device for the ACL.
In this example, the redirect URL is the address of the ClearPass server. The following shows the values for the redirect URL and ACL in the enforcement profile on the server:
-     url-redirect=https://192.168.0.38/guest/ciscowiredguest.php?mac=%{Connection:Client-Mac-Address-Colon}
-     url-redirect-acl=3001
c.     Click Save.
d.     On the Summary tab, verify that the configuration is correct.
7.     On the Configuration > Enforcement > Enforcement Policies page, click Add at the top-right corner. On the page that opens, perform the following tasks:
a.     On the Enforcement tab, set the enforcement policy name to dot1x-redirect, and select dot1x as the default profile. The enforcement type is RADIUS.
b.     On the Rules tab, click Add Rule. On the page that opens, configure the parameters as follows.
-     Set the type to Tips.
-     Set the name to Role.
-     Set the operator to EQUALS.
-     Set the value to Employee.
-     Select [RADIUS] dot1x as the enforcement profile.
c.     Click Save.
8.     On the Configuration > Services page, click Add at the top-right corner. On the page that opens, set the service name to dot1x-wired-service. Associate the service with other configuration items in different tabs and save the configuration.
¡     Select PAP as the authentication method.
¡     Add authentication source [Guest User Repository] [Local SQL DB].
¡     Select dot1x-redirect-role-map as the role mapping policy.
¡     Select dot1x-redirect as the enforcement policy.
9.     On the Summary page, verify that the configuration is correct.
1.     Assign an IP address to each interface, as shown in Figure 11. Make sure the hosts, device, and RADIUS server can reach each other. (Details not shown.)
New RADIUS scheme.
# Specify 192.168.0.34 as the source IP address of outgoing RADIUS packets.
[Device-radius-radsun] nas-ip 192.168.0.34
[Device] domain sun
3.     Configure port security:
# Enable port security globally.
# Set the port security mode to macAddressElseUserLoginSecureExt and set the NTK mode to ntkonly on Ten-GigabitEthernet 1/0/1.
[Device-Ten-GigabitEthernet1/0/1] port-security port-mode mac-else-userlogin-secure-ext
# Configure a shared account for MAC authentication users, and set the username to dot1x and password to plaintext string of Abc123!.
[Device] mac-authentication user-name-format fixed account dot1x password simple Abc123!
# Enable the access device to terminate EAP packets and perform PAP authentication with the RADIUS server.
[Device] dot1x authentication-method pap
4.     Configure advanced ACL 3001 to permit traffic destined for the redirect URL. The redirect URL is the address of the ClearPass server. Make sure the ACL number is the same as that assigned by the ClearPass server.
[Device] acl advanced 3001
[Device-acl-ipv4-adv-3001] rule 0 permit ip destination 192.168.0.38 0
   MAC move                                      : Denied
   OUI value list         :
   Port mode                                    : macAddressElseUserloginSecureExt
# Display MAC authentication information on Ten-GigabitEthernet 1/0/1.
           Username                    : dot1x
           Password                    : ******
   Quiet period                        : 60 s
 Online MAC-auth wired user            : 1
 Silent MAC users:
   Guest VLAN auth-period           : 30 s
   Authentication attempts          : successful 5, failed 38
   Current online users             : 1
          acf1-df6c-ff48    Authenticated
# Display 802.1X information on Ten-GigabitEthernet 1/0/1.
   PAP authentication                   : Enabled
       Quiet period                     : 60 s
   Supp timeout                         : 30 s
 Online 802.1X wired users              : 0
   Handshake                        : Enabled
   Reauth period                    : 0 s
   EAPOL packets: Tx 165, Rx 0
   Sent EAP Request/Identity packets : 165
            Error packets: 0
   Online 802.1X users: 0
# Display online user information after users pass authentication.
<Device> display mac-authentication connection
Total connections: 1
Slot ID: 2
User MAC address: acf1-df6c-ff48
Username: dot1x
User access state: Successful
Authentication domain: sun
IPv4 address: 192.168.1.5
Initial VLAN: 4
Authorization untagged VLAN: N/A
Authorization VSI: N/A
Authorization ACL ID: 3001
Authorization CAR: N/A
Authorization URL: https://192.168.0.38/guest/ciscowiredguest.php?mac=ac:f1:df:6c:ff:48
Termination action: Default
Session timeout period: N/A
Online from: 2018/03/02 12:52:17
Online duration: 0h 11m 12s
# Verify that frames with an unknown destination MAC address, multicast address, or broadcast address are discarded on Ten-GigabitEthernet 1/0/1. (Details not shown.)
Configuration files
 mac-authentication user-name-format fixed account dot1x password cipher $c$3$HAlQ
acl advanced 3001
 retry 5
 nas-ip 192.168.0.34
domain sun
As shown in Figure 12, the hosts in the confidential room of a company are connected to the internal network of the company through devices. When multiple hosts are connected to a port, the port only accepts the MAC address of one host. The MAC addresses of other hosts are blocked on the port. In addition, the hosts can flexibly move between ports on different devices in the same VLAN.
Configure the devices to meet the following requirements:
·     When both Host A and Host B are connected to port GigabitEthernet 1/0/1 on Device A, only Host A can successfully come online.
·     After Host A is disconnected from port GigabitEthernet 1/0/1 on Device A and connected to port GigabitEthernet 1/0/1 on Device B, it can successfully come online on the latter port.
Figure 12 Network diagram
Analysis
·     To ensure that the MAC address of Host A is the only secure MAC address learned on GigabitEthernet 1/0/1 of Device A, set the maximum number of secure MAC address port security allows on that port to 1.
·     To ensure that the secure MAC entry of Host A on a port can automatically age out after Host A goes offline, you can enable the dynamic secure MAC feature or inactivity aging for secure MAC addresses on the port. The configuration ensures that Host A can come online from another port in the same VLAN after it goes offline from this port.
To ensure that the secure MAC entry of Host A on a port can automatically age out after Host A is disconnected from that port, you can use one of the following features according to the actual network situation:
·     Dynamic secure MAC feature—When this feature is enabled, the secure MAC entry of Host A on the port immediately ages out after Host A is disconnected from the port.
¡     As a best practice, enable this feature and disable inactivity aging if the traffic of Host A is inactive. If inactivity aging is enabled on the port and the port does not detect any traffic for Host A within the detection time, the secure MAC entry of Host A on the port will age out. Another user might access the network through the port and occupy the only secure MAC entry resource on the port. As a result, Host A cannot come online.
¡     To ensure that Host A can occupy the only secure MAC entry resource on the port, perform a minimum of one task from the following tasks:
-     Make sure Host A is the first user to access the port.
-     When the port does not have an access user, use the port-security mac-address security sticky command to manually configure the MAC address of Host A as a sticky secure MAC address.
·     Inactivity aging—If the device does not detect any traffic for Host A within the detection time on the port, the secure MAC entry of Host A on the port will age out.
¡     As a best practice, enable this feature and disable the dynamic secure MAC feature when the link is unstable and Host A has active traffic. This configuration prevents Host A from directly going offline when the port temporarily goes down because of an unstable link.
¡     To ensure that Host A can occupy the only secure MAC entry resource on the port, make sure Host A is the first user to access the port.
Hardware
Software version
Procedures
Configuring VLAN and port settings
# Create VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] quit
# Set the link type of GigabitEthernet 1/0/1 to access and assign the port to VLAN 2.
[DeviceA-GigabitEthernet1/0/1] port link-mode bridge
[DeviceA-GigabitEthernet1/0/1] port link-type access
[DeviceA-GigabitEthernet1/0/1] port access vlan 2
# Set the link type of GigabitEthernet 1/0/2 to trunk, set the PVID to VLAN 2, and allow only traffic in VLAN 2 to pass through the port.
[DeviceA-GigabitEthernet1/0/2] port link-mode bridge
[DeviceA-GigabitEthernet1/0/2] port trunk pvid vlan 2
[DeviceA-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[DeviceA-GigabitEthernet1/0/2] port trunk permit vlan 2
# Set the link type of GigabitEthernet 1/0/3 to trunk, set the PVID to VLAN 2, and allow traffic in VLAN 10 and VLAN 2 to pass through the port. In this example, the IP network belongs to VLAN 10.
[DeviceA-GigabitEthernet1/0/3] port link-mode bridge
[DeviceA-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-GigabitEthernet1/0/3] port trunk pvid vlan 2
[DeviceA-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[DeviceA-GigabitEthernet1/0/3] port trunk permit vlan 2 10
[DeviceA] port-security enable
# Set the maximum number of secure MAC addresses port security allows on GigabitEthernet 1/0/1 to 1.
[DeviceA-GigabitEthernet1/0/1] port-security max-mac-count 1
# Place the port in autoLearn mode for port security.
[DeviceA-GigabitEthernet1/0/1] port-security port-mode autolearn
# Configure the intrusion protection action on GigabitEthernet 1/0/1 as blocking source MAC addresses of illegal frames.
[DeviceA-GigabitEthernet1/0/1] port-security intrusion-mode blockmac
# Configure the MAC address of Host A as a sticky secure MAC address. You can skip this step if you can ensure that Host A is the first user that accesses the port.
[DeviceA-GigabitEthernet1/0/1] port-security mac-address security sticky 0800-2700-98d2 vlan 2
# Configure secure MAC entry aging. With the configuration, the device can age the secure MAC entry of Host A after the host goes offline. Choose one of the following methods to configure secure MAC entry aging:
·     Enable the dynamic secure MAC feature.
[DeviceA-GigabitEthernet1/0/1] port-security mac-address dynamic
·     Enable inactivity aging for secure MAC addresses and set the secure MAC aging timer to 10 seconds.
[DeviceA-GigabitEthernet1/0/1] port-security mac-address aging-type inactivity
[DeviceA] port-security timer autolearn aging second 10
# Configure Device B in the same way Device A is configured. (Details not shown.)
1.     Connect Host A and Host B to port GigabitEthernet 1/0/1 on Device A in sequence.
# Display secure MAC entry information on port GigabitEthernet 1/0/1 of Device A. Verify that the MAC address of Host A is a secure MAC address and can access network resources, and the MAC address of Host B is a blocked MAC address and cannot access network resources.
<DeviceA> display mac-address interface gigabitethernet 1/0/1
MAC Address      VLAN ID    State            Port/Nickname            Aging
0800-2700-98d2   2          Security         GE1/0/1                  N
0200-2700-0003   2          Blocked          GE1/0/1                  N
2.     Disconnect Host A from Device A's port GigabitEthernet 1/0/1 and connect it to Device B's port GigabitEthernet 1/0/1.
# Display secure MAC entry information on port GigabitEthernet 1/0/1 of Device A. After the secure MAC entry of Host A ages out and the MAC address of Host B is removed from the blocked MAC address list on the port, verify that the port can learn the MAC address of Host B.
<DeviceA> display mac-address interface GigabitEthernet 1/0/1
0200-2700-0003   2          Security         GE1/0/1                   N
By default, a MAC address is removed from the blocked MAC address list after 6 minutes. To set the block timer, use the port-security timer blockmac command. The port can learn the MAC address of Host B only after the MAC address is removed from the blocked MAC address list.
# Display secure MAC entry information on port GigabitEthernet 1/0/1 of Device B. Verify that the MAC address of Host A is a secure MAC address and can access network resources.
<DeviceB> display mac-address interface GigabitEthernet 1/0/1
Configuration files
·     Configuration file used when the dynamic secure MAC feature is enabled:
vlan 2
 port access vlan 2
interface GigabitEthernet0/0/2
·     Configuration file used when inactivity aging is enabled for secure MAC addresses:
vlan 2
 port access vlan 2
