09-Security Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C S12500&S10500&S7500 Switch Series Configuration Examples-R7639Pxx-6W10009-Security Configuration Examples
05-MAC Authentication Configuration Examples
05-MAC Authentication Configuration Examples 1.14 MB
Introduction
The following information provides examples for configuring MAC authentication to ensure network access security.
The following information is provided based on the assumption that you have basic knowledge of MAC authentication.
Example: Configuring local MAC authentication
As shown in Figure 1, the device performs local MAC authentication on GigabitEthernet 1/0/1 to control Internet access of users.
Configure the device to meet the following requirements:
·     Detect whether a user has gone offline every 180 seconds.
·     Deny a user for 180 seconds if the user fails MAC authentication.
·     Authenticate all users in ISP domain bbb.
·     Use the MAC address of each user as both the username and password for authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in lower case. In this example, both the username and password are 08-00-27-00-98-d2.
Figure 1 Network diagram
Hardware
Software version
S12500G-AF switch series
Release 7639P01 and later
S10500X switch series
S10500 switch series
S7500E-X switch series
S7500E switch series
S7500X switch series
·     To avoid valid users from being blocked, do not enable MAC authentication globally before you finish all settings.
·     When you create a local user, the username and password must match the user account policy for MAC authentication. If MAC-based accounts are used, make sure the username and password of each user account are the same as the MAC address of the corresponding MAC authentication user.
Procedures
# Add a network access user, set both the username and password to the MAC address of the host, and allow the user to use the LAN access service.
[Device] local-user 08-00-27-00-98-d2 class network
[Device-luser-network-08-00-27-00-98-d2] password simple 08-00-27-00-98-d2
[Device-luser-network-08-00-27-00-98-d2] service-type lan-access
[Device-luser-network-08-00-27-00-98-d2] quit
# Configure ISP domain bbb to use local authentication for LAN users.
[Device] domain bbb
[Device-isp-bbb] authentication lan-access local
[Device-isp-bbb] quit
# Specify ISP domain bbb as the global MAC authentication domain.
[Device] mac-authentication domain bbb
# Configure MAC authentication timers.
[Device] mac-authentication timer offline-detect 180
[Device] mac-authentication timer quiet 180
# Use the MAC address of each user as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in lower case.
[Device] mac-authentication user-name-format mac-address with-hyphen lowercase
# Enable MAC authentication on interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] mac-authentication
# Enable MAC authentication globally.
# Display MAC authentication settings and statistics.
<Device> display mac-authentication
   MAC authentication                         : Enabled
   Authentication method                      : PAP
   M-LAG member configuration conflict        : Unknown
   Username format                            : MAC address in lowercase(xx-xx-xx-xx-xx-xx)
           Username                           : mac
           Password                           : Not configured
   MAC range accounts                         : 0
          MAC address          Mask                 Username
   Offline detect period                      : 180 s
   Quiet period                               : 180 s
   Server timeout                             : 100 s
   Reauth period                              : 3600 s
   User aging period for critical VLAN        : 1000 s
   User aging period for critical VSI         : 1000 s
   User aging period for guest VLAN           : 1000 s
   User aging period for guest VSI            : 1000 s
   User aging period for critical microsegment: 1000 s
   Authentication domain                      : bbb
   HTTP proxy port list                       : Not configured
   HTTPS proxy port list                      : Not configured
   Max number of silent MACs                  : 1024 (per slot)
 Online MAC-auth wired users                  : 1
 Silent MAC users:
          MAC address       VLAN ID  From port               Port index
 GigabitEthernet1/0/1  is link-up
   Carry User-IP                    : Disabled
   Authentication domain            : Not configured
   Auth-delay timer                 : Disabled
   Periodic reauth                  : Disabled
   Re-auth server-unreachable       : Logoff
   Guest VLAN                       : Not configured
   Guest VLAN reauthentication      : Enabled
     Guest VLAN auth-period         : 30 s
   Critical VLAN                    : Not configured
   Critical voice VLAN              : Disabled
   Host mode                        : Single VLAN
   Offline detection                : Enabled
   Authentication order             : Default
   User aging                       : Enabled
   Server-recovery online-user-sync : Disabled
   Guest VSI                        : Not configured
   Guest VSI reauthentication       : Enabled
     Guest VSI auth-period          : 30 s
   Critical VSI                     : Not configured
   Critical microsegment ID         : Not configured
   Critical profile                 : Not configured
   URL user logoff                  : No
   Auto-tag feature                 : Disabled
   VLAN tag configuration ignoring  : Disabled
   Max online users                 : 4294967295
   Max online preauth-domain users  : 4294967295
   Max online Auth-Fail-domain users: 4294967295
   Authentication attempts          : successful 1, failed 0
   Current online users             : 1
          MAC address       Auth state
          0800-2700-98d2    Authenticated
Configuration files
 mac-authentication
domain bbb
 password cipher $c$3$rTXB/eL1h+bXc/t2nyQOrhDMC0PWfyiPb93BqMCK+JFYwvn5
mac-authentication
Example: Configuring MAC authentication with authorization VSI assignment
As shown in Figure 2:
·     Configure the device to use the RADIUS servers to perform authentication, authorization, and accounting for the user on the host that is connected to GigabitEthernet 1/0/1.
·     Enable MAC authentication on GigabitEthernet 1/0/1 to control Internet access.
·     Configure the RADIUS servers to assign VSI bbb to the user when the user passes MAC authentication. After that, the user can access resources in the VXLAN created on the VSI. In this example, the VXLAN is VXLAN 5.
·     Authenticate the user in ISP domain 2000.
·     Use the MAC address of the host as both the username and password for MAC authentication. The MAC address is in hexadecimal notation with hyphens, and letters are in lower case. In this example, both the username and password are d4-85-64-be-c6-3e.
IMC acts as the RADIUS servers.
Figure 2 Network diagram
Analysis
·     For the device to use IMC as the RADIUS servers for user authentication, authorization, and accounting, perform the following tasks on IMC:
a.     Add the device to IMC as an access device.
b.     Add an access policy.
c.     Add an access service and specify the access policy in the access service.
d.     Add an access user and specify the access service for the access user.
·     For the device to perform RADIUS-based authentication, authorization, and accounting for the MAC authentication access user, configure AAA settings on the device, including ISP domain settings and RADIUS scheme settings.
·     To assign a VSI to the user after the user passes authentication and allow the user to access resources in the VXLAN created on the VSI, perform the following tasks:
¡     On IMC, specify the VSI for the user when you add an access policy for the user.
¡     On the device, create the VSI and its VXLAN.
Hardware
Software version
·     When you add an access user on IMC, make sure the user account on IMC matches the MAC authentication user account policy on the device. If MAC-based accounts are used, make sure the username and password of each user account are the same as the MAC address of the corresponding MAC authentication user.
·     In standard RADIUS protocol, the authentication port on RADIUS servers is UDP port 1812. If an H3C device is used as a RADIUS server, the authentication port on the RADIUS server is UDP port 1645.
Procedures
If an ADCAM server is used for authentication and authorization, configure VSIs on the server. The server will assign these VSIs to the device. You do not need to configure VSIs on the device.
Configuring the RADIUS server
This example uses IMC PLAT 7.3 (E0506), IMC EIA 7.3 (E0503), and IMC EIP 7.3 (E0503) to describe the procedure.
Adding the device to the IMC Platform as an access device
1.     Log in to IMC.
2.     Click the User tab.
3.     From the navigation pane, select User Access Policy > Access Device Management > Access Device.
4.     Click Add.
5.     On the page that opens, configure access device parameters.
a.     Set the ports for authentication and accounting to 1812 and 1813, respectively.
b.     Select H3C (General) from the Access Device Type list.
c.     Set the shared key to expert for secure authentication and accounting communication.
d.     Select an access device from the device list or manually add an access device. In this example, the IP address of the access device is 10.1.1.2.
e.     Use the default values for other parameters.
f.     Click OK.
The IP address of the access device specified on IMC must be the same as the source IP address of the RADIUS packets sent from the device. On the device, the source IP address is chosen in the following order:
a.     IP address specified by using the nas-ip command.
b.     IP address specified by using the radius nas-ip command.
c.     IP address of the outbound interface (the default).
In this example, the device uses the IP address of the outbound interface as the source IP address of RADIUS packets.
Figure 3 Adding an access device
Adding an access policy
1.     Click the User tab.
2.     From the navigation pane, select User Access Policy > Access Policy.
3.     Click Add.
4.     On the page that opens, configure access policy parameters.
a.     Enter access policy name MACauth.
b.     Set the name of the VSI to be deployed to bbb.
c.     Configure other parameters as needed.
d.     Click OK.
Figure 4 Adding an access policy
Adding an access service
2.     From the navigation pane, select User Access Policy > Access Service.
3.     Click Add.
4.     On the page that opens, configure access service parameters.
a.     Enter service name MACauth Service and set the service suffix to 2000. The service suffix is the authentication domain for the MAC authentication user.
IMPORTANT
IMPORTANT:
With the service suffix configured, you must configure the device to send usernames that include the domain name to the RADIUS servers.
b.     Select MACauth from the Default Access Policy list.
d.     Click OK.
Figure 5 Adding an access service
Adding an access user
2.     From the navigation pane, select Access User > Access User.
3.     Click Add.
4.     On the page that opens, configure access user parameters.
a.     Select the user or add a user named test.
b.     Enter account name d4-85-64-be-c6-3e and password d4-85-64-be-c6-3e.
c.     Select MACauth Service in the Access Service area.
d.     Configure other parameters as needed.
e.     Click OK.
Figure 6 Adding an access user
Configuring the device
# Configure a RADIUS scheme.
IMPORTANT
IMPORTANT:
With the service suffix configured on IMC, you must configure the device to send usernames that include the domain name to the RADIUS servers. By default, the device includes the domain name in the usernames sent to a RADIUS server.
[Device] radius scheme bbb
[Device-radius-bbb] primary authentication 10.1.1.1
[Device-radius-bbb] primary accounting 10.1.1.2
[Device-radius-bbb] key authentication simple expert
[Device-radius-bbb] key accounting simple expert
[Device-radius-bbb] user-name-format with-domain
[Device-radius-bbb] quit
# Configure ISP domain 2000.
[Device] domain 2000
[Device-isp-2000] authentication lan-access radius-scheme bbb
[Device-isp-2000] authorization lan-access radius-scheme bbb
[Device-isp-2000] accounting lan-access radius-scheme bbb
[Device-isp-2000] quit
# Enable MAC-based traffic match mode for dynamic Ethernet service instances on interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] mac-based ac
# Enable L2VPN.
[Device] l2vpn enable
# Create a VSI named bbb and the associated VXLAN.
[Device] vsi bbb
[Device-vsi-bbb] vxlan 5
[Device-vsi-bbb-vxlan-5] quit
[Device-vsi-bbb] quit
# Specify ISP domain 2000 as the global MAC authentication domain.
[Device] mac-authentication domain 2000
# Verify that VSI bbb is assigned to the MAC authentication user after the user passes authentication.
[Device] display mac-authentication connection
Total connections: 1
Slot ID: 1
User MAC address: d485-64be-c63e
Username: d4-85-64-be-c6-3e
User access state: Successful
Authentication domain: 2000
IPv4 address: 192.168.1.1
Initial VLAN: 1
Authorization untagged VLAN: N/A
Authorization VSI: bbb
Authorization microsegment ID: N/A
Authorization ACL ID: N/A
Authorization CAR:
  Average input rate: 102400 bps
  Peak input rate: 204800 bps
  Average output rate: 102400 bps
  Peak output rate: 204800 bps
Authorization URL: N/A
Authorization IPv6 URL: N/A
Authorization temporary redirect: Disabled
Start accounting: Successful
Real-time accounting-update failures: 0
Termination action: N/A
Session timeout period: N/A
Offline detection: 100 sec (server-assigned)
Online from: 2016/06/13 09:06:37
Online duration: 0h 0m 35s
# Verify that a dynamic AC is created for MAC address d485-64be-c63e.
[Device] display l2vpn forwarding ac verbose
VSI Name: bbb
  Interface: GE1/0/1  Service Instance: 1
    Link ID      : 0
    Access Mode  : VLAN
    Encapsulation: untagged
    Type         : Dynamic (MAC-based)
    MAC address  : d485-64be-c63e
Configuration files
radius scheme bbb
 key authentication cipher $c$3$+zuETC3Y0LHiW3bxzBb+UNEuWlxHkQ==
 key accounting cipher $c$3$2b8hx6mbWlnMMQY82TeUzgh0VnWXbg==
domain 2000
 mac-authentication
 mac-based ac
vsi bbb
 vxlan 5
 l2vpn enable
 mac-authentication
Example: Configuring MAC authentication with ACL assignment
As shown in Figure 7:
·     Use an ACL to deny the user to access the FTP server at 10.0.0.1 after the user passes authentication.
Figure 7 Network diagram
Analysis
·     To use an ACL to restrict the user's network access behaviors after the user passes authentication, perform the following tasks:
¡     On IMC, specify the ACL number for the user when you add an access policy for the user.
¡     On the device, create the ACL and configure its rules.
Hardware
Software version
Procedures
1.     Log in to IMC.
4.     Click Add.
f.     Click OK.
Figure 8 Adding an access device
3.     Click Add.
b.     Select Deploy ACL and manually enter ACL number 3000.
d.     Click OK.
Figure 9 Adding an access policy
6
3.     Click Add.
a.     Enter service name MACauth Services and set the service suffix to 2000. The service suffix is the authentication domain for the MAC authentication user.
IMPORTANT
IMPORTANT:
d.     Click OK.
Figure 10 Adding an access service
3.     Click Add.
c.     Select MACauth Services in the Access Service area.
e.     Click OK.
Figure 11 Adding an access user
1.     Configure advanced ACL 3000 to deny packets destined for 10.0.0.1.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule 0 deny ip destination 10.0.0.1 0
2.     Configure RADIUS-based MAC authentication:
IMPORTANT
IMPORTANT:
[Device] radius scheme 2000
[Device-radius-2000] primary authentication 10.1.1.1 1812
[Device-radius-2000] primary accounting 10.1.1.2 1813
[Device-radius-2000] key authentication simple expert
[Device-radius-2000] key accounting simple expert
[Device-radius-2000] user-name-format with-domain
[Device-radius-2000] quit
# Create ISP domain bbb and configure the ISP domain to use RADIUS scheme 2000 for user authentication, authorization, and accounting.
[Device] domain bbb
[Device-isp-bbb] authentication default radius-scheme 2000
[Device-isp-bbb] authorization default radius-scheme 2000
[Device-isp-bbb] accounting default radius-scheme 2000
           Username                           : mac
   Offline detect period                      : 300 s
   Quiet period                               : 60 s
 Silent MAC users:
   Server-recovery online-user-sync : Enabled
          0800-2712-3456    Authenticated
# Verify that you cannot ping the FTP server from the host.
C:\>ping 10.0.0.1
Pinging 10.0.0.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.0.0.1:
   Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
The output shows that ACL 3000 has been assigned to GigabitEthernet 1/0/1 to deny access to the FTP server.
Configuration files
acl advanced 3000
 radius scheme 2000
 key authentication cipher $c$3$PJM7Px3rbC96Kvh8RyFWHMLatExagQ==
 key accounting cipher $c$3$rr7AO7ZuSNZ+b+deWrfb/Qg1JPc97g==
 domain bbb
 mac-authentication
 mac-authentication
Example: Configuring MAC authentication with authorization voice VLAN assignment
As shown in Figure 12, a company plans to deploy IP telephony in office areas and conference rooms. To ensure call quality, establish separate VLANs for voice and data traffic. Additionally, to prevent unauthorized IP phones from accessing the network, IP phones must pass MAC authentication before joining a voice VLAN.
Configure the devices to meet the following requirements:
·     IP phones in offices automatically join voice VLAN 200.
·     IP phones in conference rooms are manually added to voice VLAN 400.
·     Hosts in offices communicate using VLAN 100 for their data packets.
·     IP phones in offices and conference rooms must pass MAC authentication before joining a voice VLAN.
·     Host users connected to the IP phones in the office area must pass 802.1X authentication before going online.
Figure 12 Network diagram
Analysis
·     Specify the voice VLANs on the IP phone's access ports and ensure the voice VLAN feature is inactive before authentication by deleting the matching OUI configuration for the IP phones.
·     Authorize the voice VLAN proprietary attributes to allow authenticated IP phones to join the voice VLANs.
·     Configure MAC authentication and 802.1X authentication on the access ports for IP phones.
Hardware
Software version
·     After you specify a voice VLAN on a port, voice VLAN is enabled on the port. After you specify a voice VLAN on a port, if an IP phone matches the OUI address configured on the device, the port automatically joins that voice VLAN. Therefore, if IP phones must pass MAC authentication before joining a voice VLAN, the phones cannot match the OUI addresses configured on the device before authentication.
·     If LLDP is enabled, configure the interface to operate in manual voice VLAN assignment mode.
·     Execute the undo voice-vlan security enable command globally if the VLAN tag carried in the IP phone traffic matches the voice VLAN configured on an interface.
·     The device and RADIUS server must have the same setting on whether to include the domain name in usernames.
Procedures
Configuring voice VALNs
# Create VLAN 100, VLAN 200, and VLAN 400.
[Device] vlan 100
[Device-vlan100] quit
[Device] vlan 200
[Device-vlan200] quit
[Device] vlan 400
[Device-vlan400] quit
# Configure VLAN interface addresses. (Details not shown.)
# Add port GigabitEthernet 1/0/1 to data VLAN 100.
[Device-GigabitEthernet1/0/1] port link-type hybrid
[Device-GigabitEthernet1/0/1] port hybrid pvid vlan 100
[Device-GigabitEthernet1/0/1] port hybrid vlan 100 untagged
# Configure port GigabitEthernet 1/0/1 to operate in automatic voice VLAN assignment mode. (Optional. By default, a port's voice VLAN operates in automatic mode.)
[Device-GigabitEthernet1/0/1] voice-vlan mode auto
# Enable voice VLAN and configure VLAN 200 as the voice VLAN on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] voice-vlan 200 enable
# Configure GigabitEthernet 1/0/2 as a hybrid port and assign it to VLAN 400 as a tagged VLAN member.
[Device-GigabitEthernet1/0/2] port link-type hybrid
[Device-GigabitEthernet1/0/2] port hybrid vlan 400 tagged
# Configure port GigabitEthernet 1/0/2 to operate in manual voice VLAN assignment mode, and configure VLAN 400 as the voice VLAN on the port.
[Device-GigabitEthernet1/0/2] undo voice-vlan mode auto
[Device-GigabitEthernet1/0/2] voice-vlan 400 enable
# Delete the default OUI. (Optional. Perform this configuration if IP phones can match the device's default OUI. This example deletes the default OUI 000f-e200-0000 for H3C devices.)
[Device] undo voice-vlan mac-address 000f-e200-0000
# Configure voice VLANs to operate in security mode, so they are only used for transmitting voice packets. (Optional. By default, voice VLANs operate in security mode.)
[Device] voice-vlan security enable
# Set the voice VLAN aging timer to 30 minutes.
[Device] voice-vlan aging 30
Configuring AAA
1.     Configure a RADIUS scheme:
# Create a RADIUS scheme. In the RADIUS scheme, specify the primary authentication and accounting servers and their shared keys, and exclude the domain name from the usernames sent to the RADIUS server.
[Device] radius scheme radius1
[Device-radius-radius1] primary authentication 192.168.56.10
[Device-radius-radius1] primary accounting 192.168.56.10
[Device-radius-radius1] key authentication simple 123456
[Device-radius-radius1] key accounting simple 123456
[Device-radius-radius1] user-name-format without-domain
[Device-radius-radius1] quit
# Create ISP domain bbb, and configure LAN users to use RADIUS scheme radius1 for authentication, authorization, and accounting.
[Device] domain bbb
[Device-isp-bbb] authentication lan-access radius-scheme radius1
[Device-isp-bbb] authorization lan-access radius-scheme radius1
[Device-isp-bbb] accounting lan-access radius-scheme radius1
2.     Configure MAC authentication:
# Enable MAC authentication on ports GigabitEthernet1/0/1 and GigabitEthernet1/0/2.
[Device-GigabitEthernet1/0/2] mac-authentication
# Specify the ISP domain for MAC authentication users.
# Configure MAC authentication to use the MAC address of a user as both the username and password, with the MAC address including hyphens and using lowercase letters.
# Enable global MAC authentication.
3.     Configure 802.1X authentication:
# Enable 802.1X on port GigabitEthernet1/0/2.
[Device-GigabitEthernet1/0/2] dot1x
# Specify ISP domain bbb as the mandatory authentication domain for 802.1X users on the port.
[Device-GigabitEthernet1/0/2] dot1x mandatory-domain bbb
[Device] quit
# Enable the 802.1X feature globally.
[Device] dot1x
This example uses IMC as the RADIUS server. The IMC versions are IMC PLAT 7.3(E0703), IMC EIA 7.3(E0611), and IMC EIP 7.3(E0611).
This example configures the RADIUS server to authorize the voice VLAN proprietary attribute for IP phones. The configuration for other access users and authorization attributes is similar.
1.     Log in to IMC and then click the User tab.
2.     From the navigation pane, select User Access Policy > Access Device Management > Access Device.
3.     Click Add.
3.The Add Access Device page opens.
4.     Specify the authentication and accounting port numbers to 1812 and 1813, respectively.
5.     Select H3C (General) as the access device type.
6.     Set the shared key for exchanging authentication and accounting packets with the device to 123456.
7.     Select or manually add the device with IP address 192.168.56.20 as an access device.
8.     Use the default values for other parameters.
9.     Click OK.
The added access device's IP address must be the source address used by the device to send RADIUS packets. By default, the source IP address of outgoing RADIUS packets is the IP address of the interface that sends the RADIUS packets. If the device specifies the source address for sending RADIUS packets through the nas-ip or radius nas-ip command, you need to set the access device's IP address here to the specified source address for consistency.
Figure 13 Adding an access device
Adding a proprietary attribute assignment policy
2.     From the navigation pane, select User Access Policy > Access Device Management > Proprietary Attribute.
3.     Click Add to access the page for adding a proprietary attribute assignment policy.
4.     Specify the policy name as Voice.
5.     Click Add in the attribute list.
6.     Search for the H3C_AVPair attribute, select it, and then click OK.
7.     Select the attribute value Access-Accept, and carry the voice VLAN proprietary attribute device-traffic-class=voice.
8.     Click OK.
3.     Click Add to enter the page for adding an access policy.
4.     Enter the access policy name MACauth.
5.     Configure other parameters as needed.
6.     Click OK.
Figure 14 Adding an access policy
4.     Enter the service name MACauth Service. Leave the service suffix empty because the access device is configured to not include a domain name in the usernames sent to the server.
5.     Select MACauth as the default access policy.
6.     Select Voice as the default proprietary attribute assignment policy.
7.     Configure other parameters as needed.
8.     Click OK.
Figure 15 Adding an access service
2.     From the navigation pane, select Access User > All Access Users.
3.     Click Add.
The Add Access User page opens.
The following information configures an access user account for IP Phone B.
4.     Select or manually add a user named Phone.
5.     Enter account name 72-22-1e-f7-02-02 and password 72-22-1e-f7-02-02.
6.     In the Access Service area, select the access service named MACauth Service.
8.     Click OK.
Figure 16 Adding an access user
# Log in to the 802.1X client on the host (MAC address: 0200-0000-0003), enter the username and password. After successfully coming online, use the display dot1x connection command to view the status of the 802.1X user.
<Device> display dot1x connection
Slot ID: 0
User MAC address: 0200-0000-0003
Username: dot1x
Authentication domain: bbb
EAP packet identifier: 2
Authentication method: CHAP
AAA authentication method: RADIUS
Initial VLAN: 100
Authorization tagged VLAN list: N/A
Authorization VSI: N/A
Authorization ACL number/name: N/A
Authorization CAR: N/A
Termination action: Default
Online from: 2022/10/21 14:06:26
Online duration: 0h 0m 1s
# After the IP phone successfully comes online, use the display mac-authentication connection command to view the online status of the IP phone.
<Device> display mac-authentication connection
Total connections: 2
Slot ID: 0
User MAC address: 7409-0db9-0302
Username: 74-09-0d-b9-03-02
Initial VLAN: 100
Authorization tagged VLAN: 200
Offline detection: 300 sec (command-configured)
Online from: 2022/10/21 14:08:24
Online duration: 0h 0m 6s
Port-down keep online: Disabled (offline)
Slot ID: 0
User MAC address: 7222-1ef7-0202
Access interface: GigabitEthernet1/0/2
Username: 72-22-1e-f7-02-02
Initial VLAN: 1
Authorization tagged VLAN: 400
Online from: 2022/10/21 14:08:13
Online duration: 0h 0m 17s
Configuration files
 voice-vlan aging 30
 dot1x
 mac-authentication
vlan 1
vlan 100
vlan 200
vlan 400
interface Vlan-interface1
 ip address 192.168.56.20 255.255.0.0
 port link-mode bridge
 port hybrid vlan 1 100 untagged
 dot1x
 mac-authentication
 port hybrid vlan 1 untagged
 mac-authentication
interface GigabitEthernet1/0/4
 key authentication cipher $c$3$WTVJgwaRYO+vetgJGOiOD7gJjVkPZYjPIw==
 key accounting cipher $c$3$tb1uodOzhHSFWneLUEJeyj/O1eiOWdcJqg==
domain bbb
