- 06-IP Multicast Configuration Examples
- 01-IGMP Snooping Configuration Examples
- 02-IGMP Configuration Examples
- 03-IPv6 Multicast VLAN Configuration Examples
- 04-MLD Snooping Configuration Examples
- 05-Layer 3 Multicast on Multicast Source-Side M-LAG System Configuration Examples
- 06-BIDIR-PIM Configuration Examples
- 07-Multicast VPN Configuration Examples
- 08-Static Multicast MAC Address Entry Configuration Examples
| 06-BIDIR-PIM Configuration Examples | 175.80 KB |
Introduction
This document introduces BIDIR-PIM configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of BIDIR-PIM.
Example: Configuring BIDIR-PIM
As shown in Figure 1:
· Switch A, Switch B, and Switch C run OSPF.
· Source 1 and Source 2 send multicast data to multicast group 225.1.1.1.
· Host A and Host B are member hosts of multicast group 225.1.1.1.
Configure BIDIR-PIM on the switches to implement multicast forwarding.
Device |
IP address |
Device |
IP address |
Switch A |
Vlan-int100 |
10.10.1.1/24 |
Switch C |
Vlan-int102 |
10.102.1.1/24 |
Switch A |
Vlan-int12 |
10.12.1.1/24 |
Switch C |
Vlan-int13 |
10.13.1.3/24 |
Switch A |
Vlan-int13 |
10.13.1.1/24 |
Switch C |
Vlan-int23 |
10.23.1.3/24 |
Switch B |
Vlan-int101 |
10.101.1.1/24 |
Switch C |
Vlan-int33 |
Switch B |
Vlan-int12 |
10.12.1.2/24 |
Source 1 |
10.10.1.2/24 |
Switch B |
Vlan-int23 |
10.23.1.2/24 |
Source 2 |
10.33.1.4/24 |
Analysis
To meet the network requirements, perform the following tasks:
· To establish the bidirectional RPT, configure VLAN-interface 12 on Switch A as a C-RP.
· To use the BSR mechanism to dynamically elect the RP, configure VLAN-interface 12 on Switch A as a C-BSR.
· To avoid multicast forwarding interruption when the RP fails, specify the unused IP address 10.13.1.4/24 as the static RP. In this way, the link on the subnet 10.13.1.0/24 becomes the RPL. Switch A and Switch C on the link function as the RPs.
Hardware |
Software version |
S12500G-AF switch series |
Release 7639P01 and later |
S10500X switch series |
S10500 switch series |
S7500E-X switch series |
S7500E switch series |
S7500X switch series |
When you configure BIDIR-PIM, follow these restrictions and guidelines:
· Enable the same PIM mode on the interfaces that belong to the same VPN instance on each switch.
· Configure the same static RP on all the switches in the BIDIR-PIM domain.
· Enable PIM-SM for all interfaces on the switches in the BIDIR-PIM domain.
· Enable IGMP for the interfaces that connect to the stub networks on all the switches in the BIDIR-PIM domain.
Procedures
Configure Switch A
1. Enable IP multicast routing.
[SwitchA] multicast routing
[SwitchA-mrib] quit
2. Configure each interface and enable PIM-SM.
# Create VLAN 100, and assign Ten-GigabitEthernet 1/0/1 to this VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port ten-gigabitethernet 1/0/1
[SwitchA-vlan100] quit
# Assign an IP address to VLAN-interface 100, and enable PIM-SM on the interface.
[SwitchA-Vlan-interface100] ip address 10.10.1.1 24
# Create VLAN 12, and assign Ten-GigabitEthernet 1/0/2 to the VLAN.
[SwitchA] vlan 12
[SwitchA-vlan12] port ten-gigabitethernet 1/0/2
[SwitchA-vlan12] quit
# Assign an IP address to VLAN-interface 12, enable PIM-SM on the interface.
[SwitchA-vlan12] interface vlan-interface 12
[SwitchA-Vlan-interface12] ip address 10.12.1.1 24
[SwitchA-Vlan-interface12] pim sm
[SwitchA-Vlan-interface12] quit
# Create VLAN 13, and assign Ten-GigabitEthernet 1/0/3 to the VLAN.
[SwitchA] vlan 13
[SwitchA-vlan13] port ten-gigabitethernet 1/0/3
[SwitchA-vlan13] quit
# Assign an IP address to VLAN-interface 13, enable PIM-SM on the interface.
[SwitchA] interface vlan-interface 13
[SwitchA-Vlan-interface13] ip address 10.13.1.1 24
[SwitchA-Vlan-interface13] pim sm
[SwitchA-Vlan-interface13] quit
3. Configure a C-RP, a C-BSR, and the static RP.
# Configure VLAN-interface 12 as a C-BSR and a C-RP.
[SwitchA] pim
[SwitchA-pim] c-bsr 10.12.1.1
[SwitchA-pim] c-rp 10.12.1.1 bidir
# Specify the unused IP address 10.13.1.4 as a static RP.
[SwitchA-pim] static-rp 10.13.1.4 bidir
4. Enable BIDIR-PIM.
[SwitchA-pim] bidir-pim enable
[SwitchA-pim] quit
5. Configure OSPF.
[SwitchA] ospf 1
[SwitchA-ospf-1] import-route direct
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchA-ospf-1] quit
Configure Switch B
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Create VLAN 12, and assign Ten-GigabitEthernet 1/0/2 to this VLAN.
[SwitchB] vlan 12
[SwitchB-vlan12] port ten-gigabitethernet 1/0/2
[SwitchB-vlan12] quit
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ip address 10.12.1.2 24
[SwitchB-Vlan-interface12] pim sm
[SwitchB-Vlan-interface12] quit
# Create VLAN 23, and assign Ten-GigabitEthernet 1/0/3 to this VLAN.
[SwitchB] vlan 23
[SwitchB-vlan23] port ten-gigabitethernet 1/0/3
[SwitchB-vlan23] quit
# Assign an IP address to VLAN-interface 23, enable PIM-SM on the interface.
[SwitchB] interface vlan-interface 23
[SwitchB-Vlan-interface23] ip address 10.23.1.2 24
[SwitchB-Vlan-interface23] pim sm
[SwitchB-Vlan-interface23] quit
# Create VLAN 101, and assign Ten-GigabitEthernet 1/0/1 to this VLAN.
[SwitchB] vlan 101
[SwitchB-vlan101] port ten-gigabitethernet 1/0/1
[SwitchB-vlan101] quit
# Assign an IP address to VLAN-interface 101, enable PIM-SM and IGMP on the interface.
[SwitchB-Vlan-interface101] ip address 10.101.1.1 24
[SwitchB-Vlan-interface101] igmp enable
3. Specify the unused IP address 10.13.1.4 as a static RP.
[SwitchB] pim
[SwitchB-pim] static-rp 10.13.1.4 bidir
[SwitchB-pim] bidir-pim enable
[SwitchB-pim] quit
5. Configure OSPF.
[SwitchB] ospf 1
[SwitchB-ospf-1] import-route direct
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchB-ospf-1] quit
Configure Switch C
[SwitchC] multicast routing
[SwitchC-mrib] quit
# Create VLAN 33, and assign Ten-GigabitEthernet 1/0/4 to this VLAN.
[SwitchC] vlan 33
[SwitchC-vlan33] port ten-gigabitethernet 1/0/4
[SwitchC-vlan33] quit
# Assign an IP address to VLAN-interface 33, enable PIM-SM on the interface.
[SwitchC] interface vlan-interface 33
[SwitchC-Vlan-interface33] ip address 10.33.1.3 24
[SwitchC-Vlan-interface33] pim sm
[SwitchC-Vlan-interface33] quit
# Create VLAN 13, and assign Ten-GigabitEthernet 1/0/3 to this VLAN.
[SwitchC] vlan 13
[SwitchC-vlan13] port ten-gigabitethernet 1/0/3
[SwitchC-vlan13] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] ip address 10.13.1.3 24
[SwitchC-Vlan-interface13] pim sm
[SwitchC-Vlan-interface13] quit
# Create VLAN 23, and assign Ten-GigabitEthernet 1/0/2 to this VLAN.
[SwitchC] vlan 23
[SwitchC-vlan23] port ten-gigabitethernet 1/0/2
[SwitchC-vlan23] quit
[SwitchC] interface vlan-interface 23
[SwitchC-Vlan-interface23] ip address 10.23.1.3 24
[SwitchC-Vlan-interface23] pim sm
[SwitchC-Vlan-interface23] quit
# Create VLAN 102, and assign Ten-GigabitEthernet 1/0/1 to this VLAN.
[SwitchC] vlan 102
[SwitchC-vlan102] port ten-gigabitethernet 1/0/1
[SwitchC-vlan102] quit
# Assign an IP address to VLAN-interface 102, enable PIM-SM and IGMP on the interface.
[SwitchC-Vlan-interface102] ip address 10.102.1.1 24
[SwitchC-Vlan-interface102] igmp enable
[SwitchC] pim
[SwitchC-pim] static-rp 10.13.1.4 bidir
4. Enable BIDIR-PIM
[SwitchC-pim] bidir-pim enable
[SwitchC-pim] quit
5. Configure OSPF.
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchC-ospf-1] quit
1. Verify that Switch A, Switch B, and Switch C have established PIM neighbor relationships.
# Display PIM neighbor information on Switch A.
[SwitchA] display pim neighbor
Total Number of Neighbors = 2
Neighbor Interface Uptime Expires DR-Priority Mode
10.12.1.2 Vlan12 00:02:27 00:01:45 1 B
10.13.1.3 Vlan13 00:02:27 00:01:19 1 B
# Display PIM neighbor information on Switch B.
[SwitchB] display pim neighbor
10.12.1.1 Vlan12 00:03:05 00:01:44 1 B
10.23.1.3 Vlan23 00:13:49 00:01:29 1 B
# Display PIM neighbor information on Switch C.
[SwitchC] display pim neighbor
10.13.1.1 Vlan13 00:03:28 00:01:39 1 B
10.23.1.2 Vlan23 00:14:05 00:01:36 1 B
2. Verify that VLAN-interface 12 on Switch A has been elected as the BSR on each switch.
# Display BSR information on Switch A.
[SwitchA] display pim bsr-info
Scope: non-scoped
State: Elected
Bootstrap timer: 00:01:18
Elected BSR address: 10.12.1.1
Priority: 64
Hash mask length: 30
Uptime: 00:04:01
Candidate BSR address: 10.12.1.1
Priority: 64
# Display BSR information on Switch B.
[SwitchB] display pim bsr-info
Scope: non-scoped
State: Accept Preferred
Bootstrap timer: 00:00:26
Priority: 64
Uptime: 00:10:41
# Display BSR information on Switch C.
[SwitchC] display pim bsr-info
Scope: non-scoped
Bootstrap timer: 00:02:08
Priority: 64
Uptime: 00:15:41
3. Verify that VLAN-interface 12 on Switch A has been elected as the RP, and verify that the IP address of the static RP is 10.13.1.4 on each switch.
# Display RP information on Switch A.
[SwitchA] display pim rp-info
RP address: 10.12.1.1
Interface: Vlan-interface100
State : Win DF preference: 0
DF metric : 0 DF uptime : 00:01:09
DF address: 10.10.1.1 (local)
Interface: Vlan-interface12
State : - DF preference: -
DF metric : - DF uptime : -
DF address: -
Interface: Vlan-interface13
DF metric : 0 DF uptime : 00:01:10
DF address: 10.13.1.1 (local)
RP address: 10.13.1.4
DF metric : 0 DF uptime : 00:00:07
DF address: 10.12.1.1 (local)
DF address: -
# Display RP information on Switch B.
[SwatchB] display pim rp-info
DF address: -
Interface: Vlan-interface23
DF metric : 0 DF uptime : 00:01:46
DF address: 10.23.1.2 (local)
Interface: Vlan-interface101
DF metric : 0 DF uptime : 00:01:45
DF address: 10.101.1.1 (local)
State : Lose DF preference: 0
DF metric : 0 DF uptime : 00:00:44
DF metric : 0 DF uptime : 00:00:53
DF address: 10.23.1.3
State : Win DF preference: 10
DF metric : 2 DF uptime : 00:00:53
# 查看Switch C上双向PIM的DF信息。
[SwitchC] display pim df-info
Interface: Vlan-interface102
DF metric : 2 DF uptime : 00:02:07
DF address: 10.102.1.1 (local)
Interface: Vlan-interface33
DF metric : 2 DF uptime : 00:02:06
DF address: 10.33.1.3 (local)
DF metric : 0 DF uptime : 00:02:07
DF metric : 0 DF uptime : 00:01:24
DF metric : 0 DF uptime : 00:01:23
DF address: -
DF address: 10.23.1.3 (local)
# Display RP information on Switch C.
[SwitchC] display pim rp-info
BSR RP information:
Scope: non-scoped
Group/MaskLen: 224.0.0.0/4 [B]
RP address Priority HoldTime Uptime Expires
10.12.1.1 192 150 00:06:51 00:02:05
Static RP information:
RP address ACL Mode Preferred
10.13.1.4 ---- bidir No
4. Verify that the DFs have been elected for BIDIR-PIM on each switch.
# Display information about DFs for BIDIR-PIM on Switch A.
[SwitchA] display pim df-info
Interface State DF-Pref DF-Metric DF-Uptime DF-Address
Vlan100 Win 0 0 00:01:09 10.10.1.1 (local)
Vlan12 - - - - -
Vlan13 Win 0 0 00:01:10 10.13.1.1 (local)
Vlan100 Win 0 0 00:00:07 10.10.1.1 (local)
Vlan12 Win 0 0 00:00:07 10.12.1.1 (local)
Vlan13 - - - - -
# Display information about DFs for BIDIR-PIM on Switch B.
[SwatchB] display pim df-info
Vlan12 - - - - -
Vlan23 Win 0 0 00:01:46 10.23.1.2 (local)
Vlan101 Win 0 0 00:01:45 10.101.1.1 (local)
Vlan12 Lose 0 0 00:00:44 10.12.1.1
Vlan23 Lose 0 0 00:00:53 10.23.1.3
Vlan101 Win 10 2 00:00:53 10.101.1.1 (local)
# Display information about DFs for BIDIR-PIM on Switch C.
Vlan102 Win 10 2 00:02:07 10.102.1.1 (local)
Vlan33 Win 10 2 00:02:06 10.33.1.3 (local)
Vlan13 Lose 0 0 00:02:07 10.13.1.1
Vlan23 Lose 0 0 00:02:07 10.23.1.2
Vlan102 Win 0 0 00:01:24 10.102.1.1 (local)
Vlan33 Win 0 0 00:01:23 10.33.1.3 (local)
Vlan13 - - - - -
Vlan23 Win 0 0 00:01:24 10.23.1.3 (local)
5. Verify that DFs for multicast forwarding are correct on each switch.
# Display information about DFs for multicast forwarding on Switch A.
[SwitchA] display multicast forwarding df-info
Total 2 RPs, 2 matched
00001. RP address: 10.12.1.1
Flags: 0x0
Uptime: 00:02:42
RPF interface: Vlan-interface12
List of 2 DF interfaces:
1: Vlan-interface100
2: Vlan-interface13
00002. RP address: 10.13.1.4
Flags: 0x0
Uptime: 00:01:41
RPF interface: Vlan-interface13
2: Vlan-interface12
# Display information about DFs for multicast forwarding on Switch B.
[SwitchB] display multicast forwarding df-info
Flags: 0x0
Uptime: 00:03:18
1: Vlan-interface23
2: Vlan-interface101
Flags: 0x0
Uptime: 00:02:24
RPF interface: Vlan-interface23
List of 1 DF interfaces:
1: Vlan-interface101
# Display information about DFs for multicast forwarding on Switch C.
[SwitchC] display multicast forwarding df-info
Flags: 0x0
Uptime: 00:03:38
1: Vlan-interface102
2: Vlan-interface33
Flags: 0x0
Uptime: 00:02:41
List of 3 DF interfaces:
1: Vlan-interface33
2: Vlan-interface23
3: Vlan-interface102
6. Send IGMP reports from Host A and Host B to join multicast group 225.1.1.1, and send multicast data from Source 1 and Source 2 to the group. (Details not shown.)
7. Verify that PIM forwarding entries have been correctly established on each switch.
# Display information about PIM routing entries on Switch A.
[SwitchA] display pim routing-table
Total 1 (*, G) entries; 0 (S, G) entries
(*, 225.1.1.1)
RP: 10.12.1.1 (local)
Protocol: pim-bidir, Flag: WC LOC ACT
UpTime: 00:21:59
Upstream interface: Vlan-interface12
Upstream neighbor: NULL
RPF prime neighbor: NULL
1: Vlan-interface12
Protocol: pim-bidir, UpTime: 00:21:59, Expires: -
2: Vlan-interface13
Protocol: pim-bidir, UpTime: 00:03:26, Expires: -
# Display information about PIM routing entries on Switch B.
[SwitchB] display pim routing-table
(*, 225.1.1.1)
RP: 10.12.1.1
UpTime: 00:23:47
Total number of downstreams: 3
1: Vlan-interface12
Protocol: pim-bidir, UpTime: 00:23:47, Expires: -
2: Vlan-interface23
Protocol: pim-bidir, UpTime: 00:21:56, Expires: -
3: Vlan-interface101
Protocol: igmp, UpTime: 00:23:47, Expires: -
# Display information about PIM routing entries on Switch C.
[SwitchC] display pim routing-table
(*, 225.1.1.1)
RP: 10.12.1.1
Protocol: pim-bidir, Flag: WC ACT
UpTime: 00:01:45
Upstream interface: Vlan-interface23
Upstream neighbor: 10.23.1.2
RPF prime neighbor: 10.23.1.2
Total number of downstreams: 2
Protocol: igmp, UpTime: 00:01:05, Expires: -
2: Vlan-interface23
Protocol: pim-bidir, UpTime: 00:00:53, Expires: -
Configuration files
· Switch A:
ospf 1
area 0.0.0.0
vlan 12 to 13
vlan 100
interface Vlan-interface12
ip address 10.12.1.1 255.255.255.0
pim sm
interface Vlan-interface13
ip address 10.13.1.1 255.255.255.0
pim sm
interface Vlan-interface100
ip address 10.10.1.1 255.255.255.0
pim sm
port link-mode bridge
port access vlan 100
port access vlan 12
port access vlan 13
multicast routing
pim
bidir-pim enable
c-bsr 10.12.1.1
· Switch B:
ospf 1
area 0.0.0.0
vlan 12
Vlan 23
vlan 101
ip address 10.12.1.2 255.255.255.0
pim sm
interface Vlan-interface23
ip address 10.23.1.2 255.255.255.0
pim sm
interface Vlan-interface101
ip address 10.101.1.1 255.255.255.0
igmp enable
port access vlan 101
port access vlan 12
port access vlan 23
multicast routing
pim
bidir-pim enable
· Switch C:
ospf 1
area 0.0.0.0
vlan 13
vlan 23
vlan 33
vlan 102
ip address 10.13.1.3 255.255.255.0
pim sm
ip address 10.23.1.3 255.255.255.0
pim sm
interface Vlan-interface33
ip address 10.33.1.3 255.255.255.0
pim sm
interface Vlan-interface102
ip address 10.102.1.1 255.255.255.0
igmp enable
port access vlan 102
port access vlan 23
port access vlan 13
interface Ten-GigabitEthernet1/0/4
port access vlan 33
multicast routing
pim
bidir-pim enable
