- 06-IP Multicast Configuration Examples
- 01-IGMP Snooping Configuration Examples
- 02-IGMP Configuration Examples
- 03-IPv6 Multicast VLAN Configuration Examples
- 04-MLD Snooping Configuration Examples
- 05-Layer 3 Multicast on Multicast Source-Side M-LAG System Configuration Examples
- 06-BIDIR-PIM Configuration Examples
- 07-Multicast VPN Configuration Examples
- 08-Static Multicast MAC Address Entry Configuration Examples
| 05-Layer 3 Multicast on Multicast Source-Side M-LAG System Configuration Examples | 205.32 KB |
Example: Configuring Layer 3 IPv4 multicast on an M-LAG system attached to multicast sources
Assigning IP addresses and configuring unicast routing
Example: Configuring Layer 3 IPv6 multicast on an M-LAG system attached to multicast sources
Assigning IPv6 addresses and configuring unicast routing
Introduction
This document provides examples for configuring Layer 3 multicast on an M-LAG system attached to multicast sources.
PIM and IPv6 PIM use multichassis link aggregation (M-LAG) to virtualize two physical devices into one system, which connects to a remote aggregation system and then to a multicast source or multicast receivers. This avoids multicast interruption caused by a single point of failure and improves the reliability of the multicast network.
This document assumes that you have basic knowledge of M-LAG and Layer 3 multicast.
As shown in Figure 1:
· OSPF runs on the network.
· VOD streams are sent to receiver hosts in multicast. The receivers of different subnets form stub networks, and a minimum of one receiver host exist on each stub network.
· The entire PIM-SM domain contains only one BSR.
· Device C is a Layer 2 device attached to the multicast source. Device A and Device B are virtualized into an M-LAG system, which is connected to Device C through a multichassis aggregate link. VLAN-interface 20 interfaces on the M-LAG system are the gateway for the multicast source.
· Host A is a multicast data receiver attached to Device D.
· The Ten-GigabitEthernet 1/0/3 interfaces on Device A and Device B are excluded from the shutdown action by M-LAG MAD to set up the keepalive link.
· A VRRP group is configured on VLAN-interface 20 interfaces. In the VRRP group, Device A is the master.
· M-LAG interfaces on Device A and Device B permit packets from VLAN 20 to pass through. PIM is enabled on VLAN-interface 20 of Device A and Device B.
· IP multicast routing is enabled on Device and Device B.
Device |
IP address |
Device |
IP address |
Device A |
Vlan-int20 |
20.0.0.1/24 |
Device D |
Vlan-int10 |
100.0.0.2/24 |
XGE1/0/3 |
200.0.0.1/24 |
Vlan-int30 |
30.0.0.2/24 |
Vlan-int10 |
100.0.0.1/24 |
Vlan-int40 |
40.0.0.2/24 |
Loop0 |
1.1.1.1 |
Device B |
Vlan-int20 |
20.0.0.2/24 |
XGE1/0/3 |
200.0.0.2/24 |
Vlan-int30 |
30.0.0.1/24 |
Loop0 |
2.2.2.2 |
Hardware |
Software version |
S12500G-AF switch series |
Release 7639P01 and later |
S10500X switch series |
S10500 switch series |
S7500E-X switch series |
S7500E switch series |
S7500X switch series |
Procedures
Assign an IP address and subnet mask to each interface as shown in Figure 1, and configure OSPF on the devices in the PIM-SM domain. (Details not shown.)
Configuring Device A
# Configure the M-LAG system settings.
[DeviceA] m-lag system-mac 1-1-1
[DeviceA] m-lag system-number 1
[DeviceA] m-lag system-priority 123
# Configure M-LAG keepalive packet parameters.
[DeviceA] m-lag keepalive ip destination 200.0.0.2 source 200.0.0.1
# Exclude the interface used for M-LAG keepalive detection (Ten-GigabitEthernet 1/0/3) from the shutdown action by M-LAG MAD.
[DeviceA] m-lag mad exclude interface ten-gigabitethernet 1/0/3
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation1] quit
# Assign Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to aggregation group 1.
[DeviceA-Ten-GigabitEthernet1/0/1] port link-aggregation group 1
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] port link-aggregation group 1
[DeviceA-Ten-GigabitEthernet1/0/2] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 2.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation2] quit
# Assign Ten-GigabitEthernet 1/0/5 and Ten-GigabitEthernet 1/0/6 to aggregation group 1.
[DeviceA] interface ten-gigabitethernet 1/0/5
[DeviceA-Ten-GigabitEthernet1/0/5] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet1/0/5] quit
[DeviceA] interface ten-gigabitethernet 1/0/6
[DeviceA-Ten-GigabitEthernet1/0/6] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet1/0/6] quit
# Configure Bridge-Aggregation 1 as a trunk port, assign it to all VLANs, and specify it as the peer-link interface.
[DeviceA-Bridge-Aggregation1] port link-type trunk
[DeviceA-Bridge-Aggregation1] port trunk permit vlan all
[DeviceA-Bridge-Aggregation1] port m-lag peer-link 1
# Configure Bridge-Aggregation 2 as a trunk port, and assign it to VLAN 20 and an M-LAG group.
[DeviceA-Bridge-Aggregation2] port link-type trunk
[DeviceA-Bridge-Aggregation2] port trunk permit vlan 20
[DeviceA-Bridge-Aggregation2] port m-lag group 1
# Configure VRRP group 1 on VLAN-interface 20, and set the priority of Device A to 200 for it to be the master in the VRRP group.
[DeviceA] vlan 20
[DeviceA-vlan20] quit
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] vrrp vrid 1 virtual-ip 20.0.0.10
[DeviceA-Vlan-interface20] vrrp vrid 1 priority 200
[DeviceA-Vlan-interface20] quit
# Enable IP multicast routing, enable IGMP and PIM on VLAN-interface 10, and enable PIM-SM on other interfaces as required.
[DeviceA] multicast routing
[DeviceA-mrib] quit
[DeviceA-Vlan-interface10] igmp enable
[DeviceA-Vlan-interface10] pim sm
[DeviceA-Vlan-interface20] pim sm
[DeviceA] interface loopback 0
[DeviceA-LoopBack0] pim sm
[DeviceA-LoopBack0] quit
# Specify the IP address of Loopback 0 as a C-RP and a C-BSR.
[DeviceA] pim
[DeviceA-pim] c-rp 1.1.1.1
[DeviceA-pim] c-bsr 1.1.1.1
[DeviceA-pim] quit
Configuring Device B
Configure Device B in the same way you configure Device A. (Details not shown.)
Configuring Device C
<DeviceC> system-view
[DeviceC] interface bridge-aggregation 1
[DeviceC-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceC-Bridge-Aggregation1] quit
# Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 to aggregation group 1.
[DeviceC] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
[DeviceC-if-range] port link-aggregation group 1
[DeviceC-if-range] quit
# Configure Bridge-Aggregation 2 as a trunk port, and assign it to VLAN 20.
[DeviceC-Bridge-Aggregation1] port link-type trunk
[DeviceC-Bridge-Aggregation1] port trunk permit vlan 20
# Assign Ten-GigabitEthernet 1/0/5 to VLAN 20.
[DeviceC] interface ten-gigabitethernet 1/0/5
[DeviceC-Ten-GigabitEthernet1/0/5] port access vlan 20
[DeviceC-Ten-GigabitEthernet1/0/5] quit
Configuring Device D
# Assign Ten-GigabitEthernet 1/0/1, Ten-GigabitEthernet 1/0/2, and Ten-GigabitEthernet 1/0/3 to VLAN 10, VLAN 30, and VLAN 40, respectively.
<DeviceD> system-view
[DeviceD] vlan 10
[DeviceD-vlan10] quit
[DeviceD] interface ten-gigabitethernet 1/0/1
[DeviceD-Ten-GigabitEthernet1/0/1] port access vlan 10
[DeviceD-Ten-GigabitEthernet1/0/1] quit
[DeviceD] vlan 40
[DeviceD-vlan40] quit
[DeviceD] interface ten-gigabitethernet 1/0/3
[DeviceD-Ten-GigabitEthernet1/0/3] port access vlan 40
[DeviceD] vlan 30
[DeviceD-vlan30] quit
[DeviceD] interface ten-gigabitethernet 1/0/2
[DeviceD-Ten-GigabitEthernet1/0/2] port access vlan 30
# Enable IP multicast routing, and enable PIM-SM on VLAN-interface 10 and VLAN-interface 30.
[DeviceD] multicast routing
[DeviceD-mrib] quit
[DeviceD] interface vlan-interface 10
[DeviceD-Vlan-interface10] pim sm
[DeviceD-Vlan-interface10] quit
[DeviceD] vlan 30
[DeviceD] interface vlan-interface 30
# Enable IGMPv2 on VLAN-interface 40.
[DeviceD] interface vlan-interface 40
[DeviceD-Vlan-interface40] igmp enable
[DeviceD-Vlan-interface40] igmp version 2
[DeviceD-Vlan-interface40] quit
# Verify that Device B sends and receives keepalive packets correctly.
<DeviceB> display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 176 s 237 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 200.0.0.1
Time: 2021/12/21 15:12:43
Action: Accept
Distributed relay keepalive parameters:
Destination IP address: 200.0.0.1
Source IP address: 200.0.0.2
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
# Verify that interfaces used by M-LAG operate correctly on Device B.
<DeviceB> display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
M-LAG interface information
M-LAG IF M-LAG group Local state (cause) Peer state Remaining down time(s)
BAGG2 1 UP UP -
# Verify that the M-LAG interface on Device B operates correctly.
<DeviceB> display link-aggregation verbose bridge-aggregation 2
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H -- Expired
Aggregate Interface: Bridge-Aggregation2
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
System ID: 0x7b, 0001-0001-0001
Local:
Port Status Priority Index Oper-Key Flag
XGE1/0/5(R) S 32768 32770 40001 {ACDEF}
XGE1/0/6 S 32768 32770 40001 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
XGE1/0/5 32768 2 1 0x8000, 84c4-42e5-0300 {ACDEF}
XGE1/0/6 32768 2 1 0x8000, 84c4-42e5-0300 {ACDEF}
# Verify that the IGMP group information on Device D is correct.
<DeviceD> display igmp group
IGMP groups in total: 1
Vlan-interface40(40.0.0.2):
IGMP groups reported in total: 1
Group address Last reporter Uptime Expires
225.0.0.1 40.0.0.10 00:02:04 00:01:15
# Verify that PIM routing entries have been created on Device B.
<DeviceB> display pim routing-table
Total 1 (*, G) entries; 1 (S, G) entries
(*, 225.0.0.1)
RP: 2.2.2.2 (local)
Protocol: pim-sm, Flag: WC
UpTime: 00:00:20
Upstream interface: Register-Tunnel0
Upstream neighbor: NULL
RPF prime neighbor: NULL
Downstream interface information:
1: Vlan-interface30
Protocol: pim-sm, UpTime: 00:00:20, Expires: -
(20.0.0.100, 225.0.0.1)
RP: 2.2.2.2 (local)
Protocol: pim-sm, Flag: SPT ACT 2MVPN
UpTime: 00:00:19
Upstream interface: Vlan-interface20
1: Vlan-interface30
Protocol: pim-sm, UpTime: 00:00:19, Expires: -
# Verify that multicast forwarding entries have been created on Device B.
<DeviceB> display multicast forwarding-table
Total 1 entries, 1 matched
00001. (20.0.0.100, 225.0.0.1)
Flags: 0x0
Uptime: 00:00:55, Timeout in: 00:03:18
Incoming interface: Vlan-interface20
List of 1 outgoing interfaces:
1: Vlan-interface30
Matched 1293 packets(36204 bytes), Wrong If 0 packets
Forwarded 1291 packets(36148 bytes)
# Verify that Device A does not create PIM routing entries or multicast forwarding entries, which indicates that Device B forwards all multicast traffic to the receiver. (Details not shown.)
Configuration files
· Device A:
sysname DeviceA
ospf 1
router-id 2.2.2.2
area 0.0.0.0
vlan 1
vlan 10
vlan 20
interface Bridge-Aggregation1
interface Bridge-Aggregation2
port trunk permit vlan 1 20
port m-lag group 1
interface LoopBack0
ospf 1 area 0.0.0.0
pim sm
ip address 1.1.1.1 255.255.255.255
interface Vlan-interface10
ospf 1 area 0.0.0.0
pim sm
ip address 100.0.0.1 255.255.255.0
interface Vlan-interface20
ospf 1 area 0.0.0.0
pim sm
ip address 20.0.0.1 255.255.255.0
ip address 200.0.0.1 255.255.255.0
interface Ten-GigabitEthernet1/0/5
interface Ten-GigabitEthernet1/0/6
interface Ten-GigabitEthernet1/0/4
port access vlan 10
multicast routing
pim
c-bsr 1.1.1.1
c-rp 1.1.1.1
m-lag system-mac 0001-0001-0001
m-lag mad exclude interface Ten-GigabitEthernet1/0/3
· Device B:
sysname DeviceB
ospf 1
router-id 3.3.3.3
area 0.0.0.0
area 0.0.0.9
vlan 20
vlan 30
port m-lag group 1
interface LoopBack0
ospf 1 area 0.0.0.0
pim sm
ip address 2.2.2.2/32
ospf 1 area 0.0.0.0
pim sm
ip address 20.0.0.2 255.255.255.0
vrrp vrid 1 priority 100
interface Vlan-interface30
ospf 1 area 0.0.0.0
pim sm
ip address 30.0.0.1 255.255.255.0
ospf 1 area 0.0.0.0
ip address 200.0.0.2 255.255.255.0
port access vlan 30
multicast routing
pim
c-bsr 1.1.1.1
c-rp 1.1.1.1
m-lag system-number 2
m-lag keepalive ipv6 destination 200.0.0.1 source 200.0.0.2
· Device C:
sysname DeviceC
vlan 1
vlan 20
interface LoopBack1
ip address 3.3.3.3 255.255.255.255
port access vlan 20
· Device D:
sysname DeviceD
ospf 1
router-id 4.4.4.4
area 0.0.0.0
vlan 10
vlan 40
vlan 30
ospf 1 area 0.0.0.0
pim sm
ip address 100.0.0.2 255.255.255.0
interface Vlan-interface40
ospf 1 area 0.0.0.0
ip address 40.0.0.2 255.255.255.0
igmp enable
igmp version 2
ospf 1 area 0.0.0.0
pim sm
ip address 30.0.0.2 255.255.255.0
port access vlan 40
port access vlan 10
port access vlan 30
multicast routing
As shown in Figure 2:
· OSPFv3 runs on the network.
· The entire IPv6 PIM-SM domain contains only one BSR.
· IPv6 multicast routing is enabled on Device A and Device B.
Device |
IP address |
Device |
IP address |
Device A |
Vlan-int20 |
2000::1/80 |
Device D |
Vlan-int10 |
2003::2/80 |
XGE1/0/3 |
2002::1/80 |
Vlan-int30 |
2004::2/80 |
Vlan-int10 |
2003::1/80 |
Vlan-int40 |
20::1/80 |
Loop0 |
1111::1111/128 |
Device B |
Vlan-int20 |
2000::2/80 |
XGE1/0/3 |
2002::2/80 |
Vlan-int30 |
2004::1/80 |
Loop0 |
2222::2222/128 |
Hardware |
Software version |
Procedures
Assign an IPv6 address and prefix to each interface as shown in Figure 2, and configure OSPFv3 on the devices in the IPv6 PIM-SM domain. (Details not shown.)
[DeviceA] m-lag keepalive ipv6 destination 2002::2 source 2002::1
# Configure Bridge-Aggregation 2 as a trunk port, assign it to VLAN 20, and assign it to an M-LAG group.
# Configure VRRP group 1 on VLAN-interface 20, and set the priority of Device A to 200 for it to become the master in the VRRP group.
[DeviceA-Vlan-interface20] vrrp ipv6 vrid 1 virtual-ip FE80::10 link-local
[DeviceA-Vlan-interface20] vrrp ipv6 vrid 1 virtual-ip 2000::10
[DeviceA-Vlan-interface20] vrrp ipv6 vrid 1 priority 200
# Enable IPv6 multicast routing, enable MLD and IPv6 PIM on VLAN-interface 10, and enable IPv6 PIM-SM on other interfaces as required.
[DeviceA] ipv6 multicast routing
[DeviceA-mrib6] quit
[DeviceA-Vlan-interface10] mld enable
[DeviceA-Vlan-interface10] ipv6 pim sm
[DeviceA-Vlan-interface20] ipv6 pim sm
[DeviceA-LoopBack0] ipv6 pim sm
# Specify the IPv6 address of Loopback 0 as a C-RP and a C-BSR.
[DeviceA] ipv6 pim
[DeviceA-pim6] c-rp 1111::1111
[DeviceA-pim6] c-bsr 1111::1111
[DeviceA-pim6] quit
[DeviceD] vlan 10
[DeviceD] vlan 40
[DeviceD] vlan 30
# Enable IPv6 multicast routing, and enable IPv6 PIM-SM on VLAN-interface 10 and VLAN-interface 30.
[DeviceD] ipv6 multicast routing
[DeviceD-mrib6] quit
[DeviceD-Vlan-interface10] ipv6 pim sm
[DeviceD] vlan 30
[DeviceD-Vlan-interface30] ipv6 pim sm
[DeviceD-Vlan-interface30] quit
# Enable MLDv2 on VLAN-interface 40.
[DeviceD-Vlan-interface40] mld enable
[DeviceD-Vlan-interface40] mld version 2
Neighbor is alive for: 2128 s 421 ms
Sent: Successful
Source IP address: 2002::1
Time: 2021/12/21 15:45:15
Action: Accept
M-LAG keepalive parameters:
Destination IP address: 2002::1
Source IP address: 2002::2
BAGG2 1 UP UP -
Local:
Remote:
# Verify that the MLD group information on Device D is correct.
<DeviceD> display mld group
MLD groups in total: 1
Vlan-interface40(FE80::200:FCFF:FE00:3472):
MLD groups reported in total: 1
Group address: FF08::2
Last reporter: FE80::1
Uptime: 01:56:46
Expires: 00:02:43
# Verify that IPv6 PIM routing entries have been created on Device B.
<DeviceB> display ipv6 pim routing-table
(*, FF08::2)
RP: 2222::2222(local)
UpTime: 00:17:51
1: Vlan-interface30
Protocol: pim-sm, UpTime: 00:17:51, Expires: 00:02:39
(2000::111, FF08::2)
Protocol: pim-sm, Flag: LOC
UpTime: 00:17:54
1: Vlan-interface30
Protocol: pim-sm, UpTime: 00:17:54, Expires: 00:02:36
# Verify that IPv6 multicast forwarding entries have been created on Device B.
<DeviceB> display ipv6 multicast forwarding-table
00001. (2000::111, FF08::2)
Flags: 0x0
Uptime: 00:08:27, Timeout in: 00:03:27
1: Vlan-interface30
Matched 23531 packets(194368 bytes), Wrong If 0 packets
Forwarded 23531 packets(171592 bytes)
# Verify that Device A does not create IPv6 PIM routing entries or multicast forwarding entries, which indicates that Device B forwards all multicast traffic to the receiver. (Details not shown.)
Configuration files
· Device A:
sysname DeviceA
ospfv3 1
router-id 2.2.2.2
area 0.0.0.0
vlan 10
vlan 20
port m-lag group 1
interface LoopBack0
ospfv3 1 area 0.0.0.0
ipv6 pim sm
ipv6 address 1111::1111/128
ipv6 pim sm
ipv6 address 2003::1/80
ipv6 pim sm
ipv6 address 2000::1/80
ipv6 address 2002::1/80
port access vlan 10
ipv6 pim
c-bsr 1111::1111
c-rp 1111::1111
· Device B:
sysname DeviceB
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
vlan 20
vlan 30
port m-lag group 1
interface LoopBack0
ipv6 pim sm
ipv6 address 2222::2222/128
ipv6 pim sm
ipv6 address 2000::2/80
vrrp ipv6 vrid 1 priority 100
ipv6 pim sm
ipv6 address 2004::1/80
ipv6 address 2002::2/80
port access vlan 30
ipv6 pim
c-bsr 2222::2222
c-rp 2222::2222
m-lag keepalive ipv6 destination 2002::1 source 2002::2
· Device C:
sysname DeviceC
vlan 20
interface LoopBack1
ipv6 address FE80::2 link-local
port access vlan 20
· Device D:
sysname DeviceD
ospfv3 1
router-id 4.4.4.4
area 0.0.0.0
vlan 10
vlan 40
vlan 30
ipv6 pim sm
ipv6 address 2003::2/80
ipv6 address 20::1/80
mld enable
mld version 2
ipv6 pim sm
ipv6 address 2004::2/80
port access vlan 40
port access vlan 10
port access vlan 30
pim
