11-Network Management and Monitoring Command Reference
HomeSupportSwitchesS5560X-EI SeriesReference GuidesCommand ReferencesH3C S5560X-EI & S5500V2-EI & MS4520V2 & ES5500 Command References-R6652Pxx-6W10011-Network Management and Monitoring Command Reference
19-IPv6 NetStream commands
19-IPv6 NetStream commands 155.14 KB
display fpga-working-mode status
Use display fpga-working-mode status to display the working mode of a NetStream interface extension module.
display fpga-working-mode status slot slot-number
slot slot-number: Specifies an IRF member device by its member ID.
# Display the working mode of a NetStream interface extension module.
[Sysname] display fpga-working-mode status slot 1
Slot 1 Fpga-working-mode status:
     Fpga-work-mode in use: NORMAL MODE(default)
      Fpga-work-mode for next reboot: NORMAL MODE(default)
Current working mode of the NetStream interface extension module:
·     NORMAL MODE—In this mode, the device does not support NetStream.
·     NETSTREAM—In this mode, the NetStream interface extension module works in the unidirectional NetStream mode.
·     NETSTREAM SESSION—In this mode, the NetStream interface extension module works in the bidirectional session-based NetStream mode. This mode is not supported in the current software version.
The working mode of the NetStream interface extension module for next reboot:
fpga-working-mode
display ipv6 netstream cache
Use display ipv6 netstream cache to display IPv6 NetStream entry information.
display ipv6 netstream cache [ verbose ] [ type { ip | ipl2 | l2 } ] [ destination destination-ipv6 | interface interface-type interface-number | source source-ipv6 ] * [ slot slot-number ]
verbose: Displays detailed information about IPv6 NetStream entries. If you do not specify this keyword, this command displays brief information about IPv6 NetStream entries.
type: Specifies the IPv6 NetStream entry type. If you do not specify this keyword, this command displays information about all types of IPv6 NetStream entries.
ip: Specifies IP flow NetStream entries.
ipl2: Specifies Layer 2 and Layer 3 flow NetStream entries.
l2: Specifies Layer 2 flow NetStream entries.
destination destination-ipv6: Specifies a destination IPv6 address. If you specify this option, this command does not display Layer 2 flow NetStream entries.
source source-ipv6: Specifies a source IPv6 address. If you specify this option, this command does not display Layer 2 flow NetStream entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about IPv6 NetStream entries for all member devices.
Statistics about packets containing IP headers are classified as ipl2 (Layer 2 and Layer 3). Statistics about packets without IP headers are classified as l2 (Layer 2).
# Display detailed information about IPv6 NetStream entries.
<Sysname> display ipv6 netstream cache verbose
IPv6 NetStream cache information:
  Active flow timeout             : 5 min
  Inactive flow timeout           : 300 sec
  Max number of entries           : 1048576
  IPv6 active flow entries        : 1
  MPLS active flow entries        : 0
  IPL2 active flow entries        : 1
  IPv6 flow entries counted       : 10
  MPLS flow entries counted       : 0
  IPL2 flow entries counted       : 20
  Last statistics resetting time  : 01/01/2019 at 00:01:02
IPv6 packet size distribution (1103746 packets in total):
1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
.249 .694 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .027 .000 .027 .000 .000 .000 .000 .000 .000 .000
Protocol          Total Packets    Flows  Packets Active(sec) Idle(sec)
                  Flows /sec       /sec   /flow   /flow       /flow
TCP-Telnet      2656855     372        4       86        49        27
TCP-FTP         5900082      86        9        9        11        33
TCP-FTPD        3200453    1006        5      193        45        33
TCP-WWW       546778274   11170      887       12         8        32
TCP-other      49148540    3752       79       47        30        32
UDP-DNS       117240379     570      190        3         7        34
UDP-other      45502422    2272       73       30         8        37
ICMP           14837957     125       24        5        12        34
IP-other          77406       5        0       47        52        27
Type DstIP(Port)         SrcIP(Port)      Pro TC  FlowLbl If(Direct)   Pkts
     DstMAC(VLAN)        SrcMAC(VLAN)
     TopLblType(IP/MASK) Lbl-Exp-S-List
IP   2001::1(1024)      2002::1(21)        6   0   0x6000  GE1/0/1(I)  42996
     TcpFlag:    0x1b
     DstMask:      24   SrcMask:      24
     DstAS:         0   SrcAS:         0
     NextHop:           2001::2
     BGPNextHop:        0:0:0:0:0:0:0:0
     InVRF:      mvpn   NextHeader:   58
     SamplerMode:   0  SamplerInt:    0
     Active:      120   Bytes/Pkt:   152
IP&  2003::1(2048)      2008::1(0)         1   0   0x0     GE1/0/2(O)  10
IP&  2010::1(1024)      2020::1(67)        17  0   0x12345 GE1/0/3(I)  1848
Active flow timeout
Aging timer for active flows, in minutes.
Aging timer for inactive flows, in seconds.
Maximum number of IPv6 flows allowed in the cache.
Number of active IPv6 flows in the cache.
Number of active IPv6 MPLS flows in the cache.
Number of active Layer 2 flows with IPv6 protocol information.
Number of IPv6 flows that have been counted.
Number of MPLS flows that have been counted.
Number of Layer 2 flows (with IPv6 protocol information) that have been counted.
Last time the reset ipv6 netstream statistics command was executed. This field displays Never if you have never executed this command.
Distribution of IPv6 packets by packet size, and the bracketed number is the total number of IPv6 packets.
The value is displayed in the proportion of the number of IPv6 packets of the specified sizes to the total number of IPv6 packets. The value is displayed with three decimal places.
320  352  384  416  448  480 512  544  576
Range of IPv6 packet length (excluding data link layer header).
·     For the values in the range of 1 to 576 bytes, the range increases in the step of 32 bytes. For example, 1-32 shows the number of packets with the size of 1 to 32 bytes. 64 shows the number of packets with the size of 33 to 64 bytes.
·     For the values greater than 1024 bytes, the range increases in the step of 512 bytes. For example, 1536 shows the number of packets with the size of 1025 to 1536 bytes.
·     Packets with the size of 577 to 1024 bytes are recorded in the 1024 entry.
Protocol     Total Flows     Packets/Sec
Flow/Sec   Packets/flow
Active(sec)/ flow   Idle(sec)/flow
Statistics of packets by protocol type:
·     Protocol type.
·     Total number of flows.
·     Number of packets per second.
·     Number of flows per second.
·     Number of packets per flow.
·     Active time (in seconds) of each flow.
·     Inactive time (in seconds) of each flow.
Statistics of the active flows in the current cache:
·     Flow type. Flows are classified into the following types:
¡     IP flows.
¡     Layer 2 flows with IPv6 protocol information (IPL2).
¡     MPLS flows without IP options (MPLS). This field is not supported in the current software version.
¡     MPLS flows with IP options (IP&MPLS). This field is not supported in the current software version.
·     Destination IPv6 address (destination port).
·     Source IPv6 address (source port).
·     Protocol number.
·     Traffic classification.
·      Flow label.
·     Interface name (direction).
·     Number of packets.
ICMPv6 packets do not contain port number fields, so the type and code fields are captured. The value for the destination port represents these two fields:
·     The highest 8 bits represent the type field.
·     The lowest 8 bits represent the code field.
The value for the source port is set to 0 and does not indicate any statistics.
Layer 2 information for the active flows in the current cache:
·     Destination MAC address, followed by the destination VLAN ID in parenthesis.
·     Source MAC address, followed by the source VLAN ID in parenthesis.
Information about the active MPLS flows in the current cache:
·     Type of the labels at the top of the label stack:
¡     IP address associated with the label.
¡     Mask associated with the label.
·     Label list:
¡     Lbl—20-bit label value.
¡     Exp—3-bit field for implementing QoS.
¡     S—1-bit bottom of stack flag. The S field is set to 1 if the label is the bottom label and set to 0 if not.
TcpFlag:
DstMask:   SrcMask:
DstAS:       SrcAS:
NextHop:
BGPNextHop:
OutVRF:     InVRF:            NextHeader
SamplerMode:                  SamplerInt:
Active:       Bytes/Pkt:
Other information about the active flows in the cache:
·     TCP flag.
·     Destination mask.
·     Source mask.
·     Destination AS.
·     Source AS.
·     Routing next hop.
·     BGP next hop.
·     VPN to which the outbound packets belong.
·     Type of the next header in the IPv6 packet headers.
·     VPN to which the inbound packets belong.
·     Sampling mode. IPv6 NetStream supports the following sampling modes:
¡     0—No sampling.
¡     1—Fixed sampling.
¡     2—Random sampling.
·     Sampling interval.
·     Flow's active time.
·     Number of bytes per packet.
display ipv6 netstream export
Use display ipv6 netstream export to display information about the IPv6 NetStream data export.
# Display information about the IPv6 NetStream data export.
<Sysname> display ipv6 netstream export
IPv6 export information:
  Flow source interface                              : GigabitEthernet1/0/1
  Flow destination VPN instance                      : VPN1
  Flow destination IPv6 address (UDP)                : 40::1 (30000)
  Version  9 exported flow number                    : 16
  Version  9 exported UDP datagram number (failed)   : 16 (0)
  Version 10 exported flow number                    : 0
  Version 10 exported UDP datagram number (failed)   : 0 (0)
Information about the IPv6 NetStream data export.
Source interface from which the IPv6 NetStream data is exported.
VPN to which the destination address of the IPv6 NetStream data export belongs.
Destination IPv6 address and UDP port number of the IPv6 NetStream data export.
Number of flows that are exported in the version 9 format.
Number of UDP packets that are sent in the version 9 format. The value in the parentheses displays the number of UDP packets that failed to be sent.
Number of flows that are exported in the version 10 format.
Number of UDP packets that are sent in the version 10 format. The value in the parentheses displays the number of UDP packets that failed to be sent.
display ipv6 netstream template
Use display ipv6 netstream template to display IPv6 NetStream template information.
display ipv6 netstream template [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 NetStream template information for the master device.
# Display IPv6 NetStream template information.
<Sysname> display ipv6 netstream template
 Flow template refresh frequency            : 20
 Flow template refresh interval             : 30 min
 Active flow templates                      : 2
 Created flow templates                     : 2
Protocol-port outbound template:
 Template ID                : 3258
 Field count                : 15
 Field type                   Field length (bytes)
 Flows                        4
 Out packets                  8
 Out bytes                    8
 First forwarded              4
 Last forwarded               4
 Protocol                     1
 IP protocol version          1
 Direction                    1
 PAD                          1
 L4 source port               2
 L4 destination port          2
 Sampling algorithm           1
 PAD                          1
 PAD                          1
 PAD                          1
 Sampling interval            4
 Serial number                65535
Protocol-port inbound template:
 Template ID                : 3257
 Field count                : 15
 Flows                        4
 In packets                   8
 In bytes                     8
 First forwarded              4
 Last forwarded               4
 Protocol                     1
 Direction                    1
 PAD                          1
 L4 source port               2
 PAD                          1
 PAD                          1
 PAD                          1
 Sampling interval            4
 Serial number                65535
Refresh frequency at which the templates are sent, in packets.
Refresh interval at which the templates are sent, in minutes.
Number of active IPv6 NetStream templates.
Number of templates that have been created.
Field count
Total number of fields in the template.
Field type
Type of a field in the template.
Flows
Number of flows.
Out packets
Number of sent packets.
In packets
Number of received packets.
Out bytes
Number of sent bytes.
In bytes
Number of received bytes.
First forwarded
System time when the first packet was forwarded, accurate to milliseconds.
Last forwarded
System time when the last packet was forwarded, accurate to milliseconds.
Direction
Traffic direction.
L4 source port
Source UDP or TCP port.
L4 destination port
Destination UDP or TCP port.
Sampling algorithm
Sampling algorithm.
PAD
Padding string.
Sampling interval
Sampling rate.
Serial number
Device serial number.
fpga-working-mode
Use fpga-working-mode to specify a working mode for a NetStream interface extension module.
fpga-working-mode slot slot-number { 0 | 1 }
A NetStream interface extension module works in mode 0 and the device does not support IPv6 NetStream.
0: Specifies the normal mode. NetStream is not supported.
1: Specifies the NetStream mode. The NetStream interface extension module works in the unidirectional NetStream mode.
To make the configuration take effect, save the configuration and reboot the device. Before rebooting the device, evaluate the effect of the device reboot on the network.
# Configure a NetStream interface extension module to work in the unidirectional NetStream mode.
[Sysname] fpga-working-mode slot 1 1
ipv6 netstream
Use ipv6 netstream to enable IPv6 NetStream on an interface.
Use undo ipv6 netstream to disable IPv6 NetStream on an interface.
ipv6 netstream { inbound | outbound }
undo ipv6 netstream { inbound | outbound }
IPv6 NetStream is disabled on an interface.
Interface view
inbound: Enables IPv6 NetStream for incoming traffic.
outbound: Enables IPv6 NetStream for outgoing traffic.
# Enable IPv6 NetStream for inbound traffic on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 netstream inbound
ipv6 netstream export host
Use ipv6 netstream export host to specify a destination host for IPv6 NetStream data export.
Use undo ipv6 netstream export host to remove the specified destination host or all destination hosts that are configured in the current view.
ipv6 netstream export host { ipv4-address | ipv6-address } udp-port [ vpn-instance vpn-instance-name ]
undo ipv6 netstream export host [ ipv4-address | ipv6-address ] [ vpn-instance vpn-instance-name ]
No destination host is specified for IPv6 NetStream data export.
ipv4-address: Specifies the destination IPv4 address.
ipv6-address: Specifies the destination IPv6 address.
udp-port: Specifies the destination UDP port number in the range of 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination is on the public network, do not specify this option.
In system view or in IPv6 NetStream aggregation mode view, you can specify a maximum of four IPv4 destination hosts and four IPv6 destination hosts, respectively. If you specify a destination host with the same destination address but different UDP ports in the same view, the most recent configuration takes effect. You can specify destination hosts with the same destination address and UDP port but different VPN instances.
IPv6 NetStream traditional data is exported to all destination hosts in system view.
# In system view, specify 40::1 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Sysname] ipv6 netstream export host 40::1 5000
ipv6 netstream export source
ipv6 netstream export rate
Use ipv6 netstream export rate to limit the IPv6 NetStream data export rate.
Use undo ipv6 netstream export rate to restore the default.
ipv6 netstream export rate rate
The export rate of IPv6 NetStream data is not limited.
rate: Specifies the export rate in the range of 1 to 1000.
This command sets the maximum number of IPv6 NetStream packets that can be exported per second. Packets that cannot be exported due to the export rate limit are buffered for later export. When the buffer is full, the system will temporarily invalidate the rate limit and export packets as fast as possible until the buffer has space for new packets.
# Allow a maximum of 10 packets to be exported per second.
[Sysname] ipv6 netstream export rate 10
Use ipv6 netstream export source to specify the source interface for data packets sent to NetStream servers. The IPv6 address of the interface is used as the source IPv6 address of the data packets.
Use undo ipv6 netstream export source to restore the default.
ipv6 netstream export source interface interface-type interface-number
The packets take the IPv6 address of the output interface as the source IPv6 address.
interface-type interface-number: Specifies a source interface by its type and number for the IPv6 NetStream data export.
As a best practice, connect the management Ethernet interface to a NetStream server, and configure the interface as the source interface.
# In system view, specify GigabitEthernet 1/0/1 as the source interface for IPv6 NetStream traditional data packets.
[Sysname] ipv6 netstream export source interface gigabitethernet 1/0/1
ipv6 netstream export template refresh-rate
Use ipv6 netstream export template refresh-rate to set the refresh rate for the IPv6 NetStream version 9 or version 10 template.
Use undo ipv6 netstream export template refresh-rate to restore the default.
ipv6 netstream export template refresh-rate { packet packets | time minutes }
undo ipv6 netstream export template refresh-rate { packet | time }
The packet count-based refresh rate is 20 packets, and the time-based refresh interval is 30 minutes.
packet packets: Specifies the number of packets that are sent before the template is sent. The value range is 1 to 600.
time minutes: Specifies the interval at which the template is sent, in the range of 1 to 3600 minutes.
Version 9 and version 10 are template-based and support user-defined formats. An IPv6 NetStream device must send the version 9 or version 10 template to NetStream servers regularly, because the servers do not permanently save templates.
The refresh rate can be packet count-based or time-based. If both settings are configured, the template is sent when either of the conditions is met.
# Configure the device to send the IPv6 NetStream version 9 or version 10 template every 100 packets.
[Sysname] ipv6 netstream export template refresh-rate packet 100
ipv6 netstream export version
Use ipv6 netstream export version 9 to export IPv6 NetStream data in the version 9 format and choose whether to record AS, BGP next hop, and serial number information.
Use ipv6 netstream export version 10 to export IPv6 NetStream data in the version 10 format and choose whether to record AS, BGP next hop, and serial number information.
Use undo ipv6 netstream export version to restore the default.
ipv6 netstream export version { 9 | 10 } { origin-as | peer-as } [ bgp-nexthop ] [ serial-number ]
The version 9 format is used to export IPv6 NetStream data.
The peer AS numbers are recorded. The BGP next hop and serial number are not recorded.
origin-as: Records the source AS of the source address and the destination AS of the destination address.
peer-as: Records the ASs before and after the AS where the NetStream device resides as the source AS and destination AS, respectively.
bgp-nexthop: Records BGP next hops.
serial-number: Records the device serial number.
Only one version format can take effect on the device. If you execute the  ipv6 netstream export version command multiple times, the most recent configuration takes effect.
An IPv6 NetStream entry records the source IPv6 address, destination IPv6 address, and two AS numbers for each address. You can choose to configure which AS numbers are to be exported as the source AS and destination AS.
In version 9 and version 10 formats, you can also choose whether to record the BGP next hop and serial number information.
# Configure the device to export IPv6 NetStream data in the version 9 format, and specify the IPv6 NetStream data to include the source AS and destination AS.
[Sysname] ipv6 netstream export version 9 origin-as
# Configure the device to export IPv6 NetStream data in the version 9 format, and specify the IPv6 NetStream data to include the source AS and destination AS. Record the BGP next hop and serial number information.
[Sysname] ipv6 netstream export version 9 origin-as bgp-nexthop serial-number
ipv6 netstream sampler
Use ipv6 netstream sampler to enable IPv6 NetStream sampling.
Use undo ipv6 netstream sampler to disable IPv6 NetStream sampling.
ipv6 netstream { inbound | outbound } sampler sampler-name
undo ipv6 netstream { inbound | outbound } sampler
IPv6 NetStream sampling is disabled.
Interface view
inbound: Enables IPv6 NetStream sampling in the inbound direction.
outbound: Enables IPv6 NetStream sampling in the outbound direction.
sampler sampler-name: Specifies a sampler by its name. The name is a case-insensitive string of 1 to 31 characters.
By default, IPv6 NetStream collects all data of target flows. If the flow traffic is heavy, IPv6 NetStream is resource-consuming and can cause high CPU usage, which impacts the device forwarding performance. IPv6 NetStream sampling is helpful to decrease the NetStream traffic volume. If the collected statistics can basically reflect the network status, you can enable this feature and set a proper sampling rate. The higher the sampling rate, the less impact on device performance.
# Use sampler abc for inbound IPv6 NetStream sampling on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 netstream inbound sampler abc
ipv6 netstream timeout active
Use ipv6 netstream timeout active to set the aging timer for active flows.
Use undo ipv6 netstream timeout active to restore the default.
ipv6 netstream timeout active minutes
The aging timer is 5 minutes for active flows.
minutes: Sets the aging timer for active flows, in the range of 1 to 60 minutes.
A flow is considered active if packets for the IPv6 NetStream entry arrive before the timer set by this command expires.
# Set the aging timer to 4 minutes for active flows.
[Sysname] ipv6 netstream timeout active 4
ipv6 netstream timeout inactive
Use ipv6 netstream timeout inactive to set the aging timer for inactive flows.
Use undo ipv6 netstream timeout inactive to restore the default.
ipv6 netstream timeout inactive seconds
The aging timer is 300 seconds for inactive flows.
seconds: Sets the aging timer for inactive flows, in the range of 10 to 3600 seconds.
A flow is considered inactive if no packet for the IPv6 NetStream entry arrives before the timer set by this command expires.
# Set the aging timer to 60 seconds for inactive flows.
[Sysname] ipv6 netstream timeout inactive 60
Use reset ipv6 netstream statistics to age out all flows in the cache and export IPv6 NetStream data.
Usage guide
It takes the system several minutes to execute the command. During this period, the system does not collect IPv6 NetStream data.
# Age out and export all IPv6 NetStream data.
<Sysname> reset ipv6 netstream statistics
This process may take a few minutes.
NetStream statistic function is disabled during this process.
snmp-agent trap enable ipv6 netstream
Use snmp-agent trap enable ipv6 netstream to enable SNMP notifications for IPv6 NetStream.
Use undo snmp-agent trap enable ipv6 netstream to disable SNMP notifications for IPv6 NetStream.
snmp-agent trap enable ipv6 netstream [ entry-limit ]
undo snmp-agent trap enable ipv6 netstream [ entry-limit ]
SNMP notification is disabled for IPv6 NetStream.
entry-limit: Generates an alarm when the number of cached IPv6 NetStream entries exceeds 80% or drops below 70% of the maximum permitted value. If you do not specify this keyword, the system enables or disables all SNMP notifications for IPv6 NetStream.
Use this feature to report important events for IPv6 NetStream through SNMP notifications. The generated alarm information will be sent to the SNMP module on the device and you can configure the SNMP notification sending parameters to determine the export attributes of the alarm information. For more information, see "Configuring SNMP."
# Enable SNMP notifications for IPv6 NetStream.
[Sysname] snmp-agent trap enable ipv6 netstream
