11-Network Management and Monitoring Command Reference
HomeSupportSwitchesS5560X-EI SeriesReference GuidesCommand ReferencesH3C S5560X-EI & S5500V2-EI & MS4520V2 & ES5500 Command References-R6652Pxx-6W10011-Network Management and Monitoring Command Reference
16-Sampler commands
16-Sampler commands 52.28 KB
Sampler commands
display sampler
Use display sampler to display configuration information for a sampler.
display sampler [ sampler-name ] [ slot slot-number ]
sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a sampler, this command displays configuration information for all samplers.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays sampler configuration information for the master device.
# Display the configuration information about sampler 256.
<Sysname> display sampler 256
 Sampler name: 256
  Mode: Random;  Packet-interval: 8; IsNpower: Y
Sampler name
Name of the sampler.
Mode
Sampling mode, including fixed mode and random mode.
Packet-interval
Sampling rate.
IsNpower
Whether the sampling rate is 2 to the nth power:
·     Y—Yes.
·     N—No.
sampler
Use sampler to create a sampler.
Use undo sampler to delete a sampler.
sampler sampler-name mode { fixed | random } packet-interval [ n-power ] rate
undo sampler sampler-name
No samplers exist.
fixed: Specifies the fixed sampling mode. A sampler in this mode selects the first packet per sampling.
random: Specifies the random sampling mode. A sampler in this mode randomly selects a packet out of a group of packets. Which packet is selected for each sampling varies.
n-power: Specifies the sampling rate as 2 to the nth power.
rate: Specifies the sampling rate. If the n-power keyword is not specified, one packet is selected from rate packets in each sampling. If the n-power keyword is specified, one packet is selected from 2 to the rateth power packets in each sampling. For example, if n-power 8 is specified, one packet is selected from 256 (2 to the 8th power) packets in each sampling.
# Create sampler abc in random sampling mode. Set the sampling rate to 8 to select one packet from 8 packets in each sampling.
[Sysname] sampler abc mode random packet-interval  8
