- 15-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-NTP commands
- 06-PoE commands
- 07-SNMP commands
- 08-RMON commands
- 09-Event MIB commands
- 10-NETCONF commands
- 11-CWMP commands
- 12-EAA commands
- 13-Process monitoring and maintenance commands
- 14-Sampler commands
- 15-Mirroring commands
- 16-NetStream commands
- 17-IPv6 NetStream commands
- 18-sFlow commands
- 19-Performance management commands
- 20-Flow log commands
- 21-Information center commands
- 22-Packet capture commands
- 23-Cloud connection commands
- 24-GOLD commands
- 25-eMDI commands
- 26-SmartMC commands (self-mesh not supported)
- 27-Fast log output commands
- 28-SQA commands
| 26-SmartMC commands (self-mesh not supported) | 301.14 KB |
display smartmc backup configuration status
display smartmc batch-file status
display smartmc replace status
display smartmc resource-monitor
display smartmc resource-monitor configuration
display smartmc tc log restart
display smartmc upgrade status
smartmc auto-link-aggregation enable
smartmc backup configuration max-number
smartmc backup configuration interval
smartmc resource-monitor interval
smartmc resource-monitor max-age
smartmc tc startup-configuration
smartmc topology-refresh interval
smartmc upgrade startup-configuration
SmartMC commands
The following compatibility matrixes show the support of hardware platforms for SmartMC:
Model |
SmartMC compatibility |
MSR610 |
Yes |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
No |
MSR3640-G |
No |
MSR3640-X1-HI |
Yes |
Model |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Model |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Model |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
boot-loader
Use boot-loader to specify the upgrade startup software files for a SmartMC group.
Use undo boot-loader to restore the default.
boot-loader file { ipe-filename | boot boot-filename system system-filename }
undo boot-loader
No upgrade startup software files are specified for a SmartMC group.
SmartMC group view
ipe-filename: Specifies an IPE file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .ipe extension.
boot boot-filename: Specifies a boot image file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .bin extension.
system system-filename: Specifies a system image file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .bin extension.
# Specify IPE file device.ipe for SmartMC group testgroup.
[Sysname] smartmc group testgroup
[Sysname-smartmc-group-testgroup] boot-loader file device.ipe
smartmc group
smartmc upgrade boot-loader
create batch-file
Use create batch-file to create a batch file.
create batch-file batch-file-name
No batch files exist.
batch-file-name: Specifies a name for the batch file, a case-insensitive string of 1 to 255 characters. If you do not specify a file extension when specifying a file name, the default extension .cmdset is used.
After executing this command, you will enter the batch edit mode. In this mode, each command occupies a line. When you finish editing all command lines, enter a percent sign (%) to return to user view.
Make sure the command lines that you enter are correct because the system does not verify whether the command lines are correct.
# Create batch file test.cmdset, and enter the command lines for specifying the device name as Sysname and enabling Telnet.
<Sysname> create batch-file test.cmdset
Begin to edit batch commands, and quit with the character '%'.
sysname Sysname
telnet server enable%
<Sysname>
smartmc batch-file deploy
Use display smartmc backup configuration status to display the backup status on members.
This command displays the status of the ongoing backup task or the most recent backup task if the member is not performing backup.
# Display the backup status on members.
<Sysname> display smartmc backup configuration status
ID IpAddress MacAddress Status Time
1 192.168.56.30 08d2-38ff-0300 Finished 2017-04-05 11:30:35
2 192.168.56.40 62d2-c21c-0400 Finished 2017-04-05 11:30:40
ID |
ID of the member. |
IpAddress |
IP address of the member. |
MacAddress |
MAC address of the member. |
Status |
Backup status: · Waiting—The member is waiting for configuration backup. · Processing—The member is backing up the configuration. · Finished—The member has finished backing up the configuration. · Timeout—Configuration backup times out. · Failed—The member failed to back up the configuration. |
Time |
Time when the member finished backing up the configuration. If the member has not finished backing up the configuration, this field displays a hyphen (-). |
Use display smartmc batch-file status to display the batch file execution result.
display smartmc batch-file status [ ap | last number | phone ]
ap: Displays the result of the most recent batch file deployment for ports connected to APs.
last number: Specifies a batch file deployment (performed by using the smartmc batch-file deploy command) by its number counting from the most recent batch file deployment. The value range for the number argument is 1 to 5.
phone: Displays the result of the most recent batch file deployment for ports connected to IP phones.
If you do not specify any parameters, this command displays the result of the most recent batch file deployment performed by using the smartmc batch-file deploy command.
# Display the result of the most recent batch file deployment. In this example, the batch file contains the display smartmc configuration command.
<Sysname> display smartmc batch-file status last 1
TC ID 1
Device MAC : 8ad5-3d05-0200
Start Time : 2018-12-24 16:23:49
End Time : 2018-12-24 16:23:54
Result :
<Sysname>display smartmc configuration
Device role : TC
TM IP : 192.168.22.103
TM MAC : 8ad5-35d1-0100
TM sysname : Sysname
<Sysname>
TC ID 2
Device MAC : 8ad5-4642-0300
Start Time : 2018-12-24 16:23:54
End Time : 2018-12-24 16:23:58
Result :
Device role : TC
<Sysname>
TC ID |
ID of the member. |
Device MAC |
Start Time |
Batch command line execution start time. |
End Time |
Batch command line execution end time. |
Result |
Batch command line execution result in details. |
create batch-file
smartmc batch-file apply
Use display smartmc configuration to display the SmartMC configuration.
# Display the SmartMC configuration on the commander.
<Sysname> display smartmc configuration
Device role : TM
FTP server IP : 192.168.22.103
FTP server username : admin
Topology-refresh interval : 60(s)
Backup startup-configuration interval : N/A
Sync backup number : 5
Device status : Lack
Some configurations are absent on the TM, such as Telnet or LLDP configuration.
# Display commander information on a member.
Device role : TC
TM MAC : 8288-468d-0100
Device role |
Role of the device. |
FTP server IP |
IP address of the FTP server. If no FTP server IP address is configured, this field displays N/A. |
FTP server username |
FTP server username. If no username is configured, this field displays N/A. |
Topology-refresh interval |
Topology refresh interval, in seconds. |
Backup startup-configuration interval |
Automatic configuration file backup interval, in hours. If no interval is set, this field displays N/A. |
Sync backup number |
Number of members that can perform configuration backup at the same time. |
Device status |
Commander status: · Normal. · Lack—Lack of configuration, such as NETCONF, Telnet, local user, and LLDP. |
TM IP |
IP address of the commander. If the member failed to obtain the commander's IP address, this field displays N/A. |
TM MAC |
MAC address of the commander, If the member failed to obtain the commander's MAC address, this field displays N/A. |
TM sysname |
Name of the commander. If the member failed to obtain the commander's name, this field displays N/A. |
Some configurations are absent on the TM, such as XXX. |
This field is available only when the Device status field displays Lack. Lack of configuration will affect SmartMC functions. Please follow the prompt to complete the configuration. |
display smartmc device-link
Use display smartmc device-link to display connections between devices in the SmartMC network.
# Display connections between the devices in the SmartMC network.
<Sysname> display smartmc device-link
(TM IP)[192.168.56.20]
ID Hop LocalPort LocalIP PeerPort PeerIP
0 0 GigabitEthernet1/0/2 192.168.56.20 GigabitEthernet1/0/1 192.168.56.30
1 1 GigabitEthernet1/0/1 192.168.56.30 GigabitEthernet1/0/2 192.168.56.20
1 2 GigabitEthernet1/0/2 192.168.56.30 GigabitEthernet1/0/1 192.168.56.40
2 3 GigabitEthernet1/0/1 192.168.56.40 GigabitEthernet1/0/2 192.168.56.30
TM IP |
IP address of the commander. |
ID |
ID of the commander or member. |
Hop |
Number of hops between the commander and member. |
LocalPort |
Local port. |
LocalIP |
IP address of the local device. |
PeerPort |
Peer port. |
PeerIP |
IP address of the peer port. |
display smartmc group
Use display smartmc group to display SmartMC group information.
display smartmc group [ group-name ] [ verbose ]
group-name: Specifies a SmartMC group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this argument, the command displays information about all SmartMC groups.
verbose: Displays detailed SmartMC group information. If you do not specify this keyword, the command displays brief SmartMC group information.
# Display detailed information about all SmartMC groups.
<Sysname> display smartmc group verbose
Group name : test
TC count : 3
Boot-loader file :
Startup-configuration file :
Rule :
Match IP-address 192.168.2.0 24
TCID DeviceType IpAddress MacAddress Status Version Sysname
1 MSR810-W-LM 192.168.2.3 0440-a90c-b46a Normal R0707 TC1
2 MSR810-W-LM 192.168.2.4 0440-a90c-a83a Normal R0707 TC2
3 MSR810-W-LM 192.168.2.5 0440-a90c-ad34 Normal R0707 TC3
Table 5 Command output
GroupName |
Name of the SmartMC group. |
TC count |
Number of members in the SmartMC group. |
Boot-loader file |
Names of the upgrade startup software files for upgrading the SmartMC group. If no upgrade startup software files are specified, this field displays null. |
Startup-configuration file |
Name of the configuration file for upgrading the SmartMC group. If no configuration file is specified, this field displays null. |
Rule |
Match criteria of the SmartMC group. |
Match |
Match type and its value. The match types include the following: · Device-type—Matches members by device type. · IP-address—Matches members by IP address. · MAC-address—Matches members by MAC address. |
TCID |
ID of the member. |
DeviceType |
Device type of the member. |
Sysname |
Device name of the member. |
IpAddress |
MacAddress |
Version |
Software version of the member. |
Status |
Operating status of the member: · Offline—The member is offline. · Normal—The member is online. |
match
smartmc group
Use display smartmc replace status to display faulty member replacement status.
# Display faulty member replacement status.
<Sysname> display smartmc replace status
Faulty ID : 2
Faulty MAC : 94e2-cdcb-0600
Replacement ID : 3
Replacement MAC: 2443-5f8c-0200
Mode : Manual
Status : Successful
Start time : 2017-03-21 15:01:31
End time : 2017-03-21 15:01:40
Table 6 Command output
Faulty ID |
ID of the faulty member. |
Faulty MAC |
MAC address of the faulty member. |
Replacement ID |
ID of the new member. |
Replacement MAC |
MAC address of the new member. |
Mode |
Replacement method, which can be Manual or Auto. |
Status |
Replacement status: · Successful. · Failed. · Replacing. · Timeout. |
Start time |
Replacement start time |
End time |
Replacement end time. |
smartmc auto-replace enable
smartmc replace
Use display smartmc resource-monitor to display resource monitoring information.
display smartmc resource-monitor [ cpu | memory | temperature ] * [ tc tc-id | tm ]
cpu: Displays CPU usage.
memory: Displays memory usage.
temperature: Displays temperature information.
tc tc-id: Specify a member by its ID in the range of 1 to 255.
tm: Specify the commander.
If you do not specify a resource type, this command displays the resource monitoring information of all types.
If you do not specify a member or the commander, this command displays the resource monitoring information for the commander and all members.
# Display all resource monitoring information for member 1.
<Sysname> display smartmc resource-monitor tc 1
TC 1
Collection time : 2017-07-25 18:02:30
Slot 1 :
CPU 0 CPU usage: 1%
Memory usage : 587076/903332
Temperature : 30
Table 7 Command output
Collection time |
Time when the resource monitoring information was collected. |
Use display smartmc resource-monitor configuration to display resource monitoring configuration.
# Display resource monitoring configuration.
<Sysname> display smartmc resource-monitor configuration
ID MacAddress CPU Memory Temperature
1 1234-2222-3333 Y N N
2 1234-2222-3334 Y N N
3 1234-2222-3335 Y N N
Table 8 Command output
ID |
Device ID. |
MacAddress |
MAC address of the device. |
CPU |
CPU usage monitoring status: · Y—CPU usage monitoring is enabled. · N—CPU usage monitoring is disabled. · -—The device does not support CPU usage monitoring. |
Memory |
Memory usage monitoring status: · Y—Memory usage monitoring is enabled. · N—Memory usage monitoring is disabled. · -—The device does not support memory usage monitoring. |
Temperature |
Temperature monitoring status: · Y—Temperature monitoring is enabled. · N—Temperature monitoring is disabled. · -—The device does not support temperature monitoring. |
display smartmc tc
Use display smartmc tc to display member information.
display smartmc tc [ tc-id ] [ verbose ]
tc-id: Specifies a member by its ID in the range of 1 to 255. If you do not specify a member, this command displays information about all members.
verbose: Displays detailed member information. If you do not specify this keyword, the command displays brief member information.
# Display brief information about all members.
<Sysname> display smartmc tc
TCID DeviceType Sysname IpAddress MacAddress Status Version
1 MSR810-W-LM 192.168.22.104 201c-e7c3-0300 Normal R0707 S1
Table 9 Command output
TCID |
ID of the member. |
DeviceType |
Sysname |
IpAddress |
MacAddress |
Status |
Operating status of the member: · Normal—The member is operating correctly. · Offline—The member is offline. |
Version |
# Display detailed information about all members.
<Sysname> display smartmc tc verbose
TC ID : 1
Adding method : Manual
Sysname : S1
Model : MSR810
Device type : MSR810-W-LM
SYSOID : 1.3.6.1.4.1.25506
MAC address : 0e74-e2fb-0400
IP address : 192.168.56.103
Boot image :
Boot image version :
System image :
System image version :
Current-configuration file :
Uptime : 2 days, 3 hours, 4 minutes
System CPU usage : 0%
System memory usage : 0%
Status : Offline
Boot-loader file :
Table 10 Command output
TC ID |
ID of the member. |
Adding method |
Method through which the member is added to the SmartMC network: · Manual. · Auto. |
Sysname |
Model |
Device model of the member. |
Device type |
SYSOID |
SYSOID of the member. |
MAC address |
IP address |
Boot image |
Boot image file that the member runs. |
Boot image version |
Version of the boot image file. |
System image |
System image file that the member runs. |
System image version |
Version of the system image file. |
Current-configuration file |
Current startup configuration file used by the member. |
Uptime |
Operation duration of the member. |
System CPU usage |
CPU usage on the member. |
System memory usage |
Memory usage on the member. |
Status |
Boot-loader file |
Upgrade startup software files. |
Upgrade configuration file. |
display smartmc tc log buffer
Use display smartmc tc log buffer to display log information in the log buffer on a member.
display smartmc tc tc-id log buffer [ module module-name [ mnemonic mnemonic-value ] ]
module module-name: Specifies a module by its name, a case-insensitive string of 1 to 8 characters. To display module names, use the info-center source command (see information center commands in Network Management and Monitoring Command Reference).
mnemonic mnemonic-value: Specifies a mnemonic, a case-insensitive string of 1 to 32 characters.
# Display the log information for the SHELL module with the SHELL_CMD mnemonic for member 1.
<Sysname> display smartmc tc 1 log buffer module SHELL mnemonic SHELL_CMD
Time : 2017-07-15 13:51:46
Level : Informational
Module : SHELL
Mnemonic : SHELL_CMD
Content : -Line=con0-IPAddr=**-User=**; Command is qu
Time : 2017-07-15 13:51:39
Module : SHELL
Content : -Line=con0-IPAddr=**-User=**; Command is local-user admin
Time |
Time when the log was generated. |
Level |
Log level. |
Use display smartmc tc log restart to display the restart log information for a member.
display smartmc tc tc-id log restart
In addition to saving the logs generated by modules to the log buffer, a member sends restart logs to the commander. The commander creates a restart log buffer for each member to store their restart logs.
The commander stores a maximum of 10 restart logs for each member. The most recent restart log overwrites the oldest one when there are more than 10 restart logs for a member.
You can also use the display smartmc tc tc-id log buffer module SYSLOG mnemonic SYSLOG_RESTART command to display the restart log information.
# Display the restart log information for member 1.
<Sysname> display smartmc tc 1 log restart
Module : SYSLOG
Mnemonic : SYSLOG_RESTART
Content : System restarted -- H3C Comware Software.
Table 12 Command output
Time |
Level |
Log level. |
Use display smartmc upgrade status to display member upgrade status.
# Display member upgrade status.
<Sysname> display smartmc upgrade status
ID IpAddress MacAddress Status UpdateTime UpdateFile
1 192.168.56.1 82dd-a434-0200 Finished Immediately bootloader.ipe
2 192.168.56.103 5caf-2e5f-0100 Finished Immediately bootloader.ipe
Table 13 Command output
ID |
ID of the member. |
MacAddress |
IpAddress |
Status |
Upgrade status: · Waiting—The member is waiting for downloading the upgrade file. · Download-failed—The member failed to download the upgrade file. · Download-finished—The member has downloaded the upgrade file. · Downloading—The member is downloading the upgrade file. · Updating—The member is upgrading. · Finished—The member has finished upgrading. · Failed—The member failed to upgrade. · Unknown. |
Updated File |
Name of the upgrade file. |
UpdateTime |
Upgrade time: · Immediately—Upgrade at once. · Delay(m)—Upgrade after the specified delay. · Time(HH:MM)—Upgrade at the specified time. |
smartmc upgrade group
smartmc upgrade tc
display smartmc vlan
Use display smartmc vlan to display VLAN creation results for members.
# Display VLAN creation results.
<Sysname> display smartmc vlan
ID IpAddress MacAddress Vlan Status
1 192.168.22.222 703d-15ad-cd02 2 Success.
2 192.168.22.3 24ff-2264-0100 2 Success.
3 192.168.22.4 24ff-2f74-0200 2 Success.
4 192.168.22.223 487a-dac8-29ba 2 Success.
Table 14 Command output
TC ID |
Member ID. |
IpAddress |
MacAddress |
Vlan |
VLAN created for the member. |
Status |
VLAN creation status: · Processing—The VLAN is being created. · Success—The VLAN has been created successfully. · Failure. The port xxx is not an access port—The VLAN fails to be created, because ports connected to non-SmartMC devices are not access ports. · Failure. xxx not exist—The VLAN fails to be created, because all access ports are connected to SmartMC devices. |
smartmc vlan
match
Use match to set a match criterion to add all matching members to a SmartMC group.
Use undo match to delete a match criterion.
match { device-type device-type | ip-address ip-address { ip-mask-length | ip-mask } | mac-address mac-address mac-mask-length }
undo match { device-type device-type | ip-address ip-address { ip-mask-length | ip-mask } | mac-address mac-address mac-mask-length }
No match criterion is set.
SmartMC group view
device-type device-type: Sets a device type match criterion.
ip-address ip-address { ip-mask-length | ip-mask }: Sets an IP address match criterion. The ip-address argument specifies an IP address in dotted decimal notation. The ip-mask argument specifies the subnet mask in dotted decimal notation. The ip-mask-length argument specifies the subnet mask length in the range of 1 to 32.
mac-address mac-address mac-mask-length: Sets a MAC address match criterion. The mac-address argument specifies a MAC address in the format of H-H-H. The mac-mask-length argument specifies the mask length in the range of 1 to 48.
# Create SmartMC group a and add members in subnet 192.168.1.0/24 to the group.
[Sysname] smartmc group a
[Sysname-smartmc-group-a] match ip-address 192.168.1.0 24
smartmc group
Use smartmc auto-link-aggregation enable to enable automatic Ethernet link aggregation.
Use undo smartmc auto-link-aggregation enable to disable automatic Ethernet link aggregation.
Automatic Ethernet link aggregation is disabled.
Automatic Ethernet link aggregation is performed only between member devices.
Enabling or disabling automatic Ethernet link aggregation might cause network flapping, and the members might go offline for a short period of time.
# Enable automatic Ethernet link aggregation.
[Sysname] smartmc auto-link-aggregation enable
Use smartmc auto-replace enable to enable the automatic faulty member replacement feature.
Use undo smartmc auto-replace enable to disable the automatic faulty member replacement feature.
The automatic faulty member replacement feature is disabled.
To perform an automatic fault replacement, first enable this feature on the commander, and then perform the following tasks:
1. Install the new member at the location where the faulty member was installed.
2. Connect all cables to the new member.
Make sure the new member and the faulty member have the same neighbor relationship, device model, and IRF member ID.
# Enable the automatic faulty member replacement feature.
[Sysname] smartmc auto-replace enable
smartmc replace
Use smartmc backup configuration to manually back up the configuration file on the commander or the specified members.
smartmc backup configuration { group group-name-list | tc [ tc-id-list ] }
group group-name-list: Specifies a space-separated list of up to 10 SmartMC groups. The group name is a case-sensitive string of 1 to 31 characters.
tc tc-id-list: Specifies a space-separated list of up to 10 device items. Each item specifies a device or a range of devices in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 0 to 255, with 0 representing the commander and 1 to 255 representing members. If you do not specify the commander or any members, all devices will perform configuration backup.
After you execute this command, the devices immediately save the running configuration to the next-startup configuration files and upload the configuration files to the FTP server.
The backup configuration files are named in the format of device_bridge_MAC_address_backup.cfg.
# Back up the configuration file on members 1 through 4.
[Sysname] smartmc backup configuration tc 1 to 4
# Back up the configuration file on all members in SmartMC groups test1, test2, and test3.
[Sysname] smartmc backup configuration group test1 test2 test3
Use smartmc backup configuration max-number to set the maximum number of members that can perform automatic configuration backup at the same time.
Use undo smartmc backup configuration max-number to restore the default.
smartmc backup configuration max-number max-number
A maximum of five members can perform automatic configuration backup at the same time.
max-number: Specifies the maximum number of members that can perform automatic configuration backup at the same time, in the range of 2 to 20.
The maximum number of members that can perform automatic configuration at the same time is limited by the performance of the FTP server. If automatic configuration backup fails, set the maximum number of members to a smaller value.
# Specify that a maximum of 10 members can perform automatic configuration backup at the same time.
[Sysname] smartmc backup configuration max-number 10
Use smartmc backup configuration interval to enable the automatic configuration file backup feature and set the automatic backup interval.
Use undo smartmc backup configuration interval to restore the default.
smartmc backup configuration interval interval
The automatic configuration file backup feature is disabled.
interval: Specifies the automatic configuration file backup interval in the range of 1 to 720 hours.
This command enables the commander and members to back up their configuration files by saving the running configuration to the files and then uploading them to the FTP server. When you configure this command, the commander and members immediately perform a backup. After that, they back up the configuration files at the specified interval. The backup configuration files are named in the format of bridge MAC address_backup.cfg.
# Enable the automatic configuration file backup feature and set the backup interval to 24 hours.
[Sysname] smartmc backup configuration interval 24
Use smartmc batch-file apply to specify a batch file to deploy to ports connecting APs or IP phones.
Use undo smartmc batch-file apply to remove a batch file specified for ports connecting APs or IP phones.
smartmc batch-file batch-file-name apply { ap | phone }
undo smartmc batch-file apply { ap | phone }
No batch file is specified for ports connecting APs or IP phones.
batch-file-name: Specifies a batch file by its name, a case-insensitive string of 1 to 255 characters.
ap: Specifies ports connecting APs.
phone: Specifies ports connecting IP phones.
This feature allows the commander to automatically deploy specific configurations to a port connecting an AP or IP phone, simplifying access port configuration.
When the commander first detects the association of an AP or IP phone on a port through LLDP, it deploys the command lines in the specified batch file to the port. If no batch file is specified for the device type, the configurations on the port remain unchanged.
If the AP or IP phone disconnects from the port, the configurations on the port remain. When a new device comes online from the port, configurations used by the port depend on the new device type.
· If the new device is an AP or IP phone and has the same type as the disconnected device, the configurations on the port remain unchanged.
· If the new device is an AP or IP phone but has a different type as the disconnected device, the commander deploys the command lines in the specified batch file to the port. If no batch file is specified for the device type, the configurations on the port remain unchanged.
· If the new device is neither an AP nor an IP phone, the configurations on the port remain unchanged.
# Specify batch file ap.cmdset for ports connecting APs or IP phones.
[Sysname] smartmc batch-file ap.cmdset apply ap
create batch-file
Use smartmc batch-file deploy to deploy bulk command lines to a list of members or SmartMC groups.
smartmc batch-file batch-file-name deploy { group group-name-list | tc tc-id-list }
batch-file-name: Specifies the name of a batch file, a case-insensitive string of 1 to 255 characters.
tc tc-id-list: Specifies a space-separated list of up to 10 member items. Each item specifies a member or a range of members in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 1 to 255.
# Deploy batch file startup.cmdset to SmartMC group testgroup.
[Sysname] smartmc batch-file startup.cmdset deploy group testgroup
create batch-file
smartmc enable
Use smartmc enable to enable SmartMC and set the device role.
Use undo smartmc enable to disable SmartMC.
smartmc { tc | tm username username password { cipher | simple } string } enable
undo smartmc enable
SmartMC is disabled.
tc: Enables SmartMC and sets the device role to member.
tm: Enables SmartMC and sets the device role to commander.
username username: Specifies a username for the local user, a case-sensitive string of 1 to 55 characters.
password: Specifies a password for the local user.
simple: Specifies a password in plaintext form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
A SmartMC network must have one and only one commander.
To enable SmartMC, execute this command on both the commander and members. To configure the other SmartMC features, execute associated commands only on the commander.
If you change the role of the commander to member or disable SmartMC on the commander, all SmartMC settings in its running configuration will be cleared.
SmartMC fails to be enabled if ACL resources are insufficient. If ACL resources are insufficient, use the undo acl command to delete unnecessary ACLs and then enable SmartMC. You can execute the display acl command to view ACL configuration and match statistics. For more information about ACLs, see ACL and QoS Configuration Guide.
SmartMC fails to be enabled if ports 80 and 443 have been used.
# Enable SmartMC and set the device role to member.
[Sysname] smartmc tc enable
smartmc ftp-server
Use smartmc ftp-server to configure the FTP server information.
Use undo smartmc ftp-server to delete the FTP server information.
smartmc ftp-server server-address username username password { cipher | simple } string
No FTP server information is configured.
server-address: Specifies an FTP server by its IP address.
username username: Specifies the FTP server username, a case-sensitive string of 1 to 55 characters.
password: Specifies the FTP server password.
# Set the FTP server IP address, username, and password to 192.168.22.19, admin, and hello12345, respectively.
[Sysname] smartmc ftp-server 192.168.22.19 username admin password simple hello12345
smartmc group
Use smartmc group to create a SmartMC group and enter its view, or enter the view of an existing SmartMC group.
Use undo smartmc group to delete a SmartMC group.
smartmc group group-name
undo smartmc group group-name
No SmartMC groups exist.
group-name: Specifies the name of the SmartMC group, a case-sensitive string of 1 to 31 characters.
When you perform the following operations, you can specify a SmartMC group to apply the operations to all members in the group:
· Startup software upgrade.
· Configuration file upgrade.
· Configuration deployment.
# Create SmartMC group testgroup.
match
smartmc outbound
Use smartmc outbound to configure an outgoing interface for the SmartMC network.
Use undo smartmc outbound to restore the default.
smartmc outbound
No interface is used as an outgoing interface, and the SmartMC network cannot communicate with outside networks.
VLAN interface view
VLAN interface 1 cannot be used as an outgoing interface, because the SmartMC network is established in VLAN 1.
A member port of a Layer 3 aggregation group cannot be used as an outgoing interface for SmartMC, and vice versa. If a configured outgoing interface is a member port of a Layer 3 aggregation group, the outgoing interface does not take effect. For more information about Layer 3 aggregation groups, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide.
# Configure GigabitEthernet 1/0/1 as an outgoing interface for the SmartMC network.
[Sysname-GigabitEthernet1/0/1] smartmc outbound
Use smartmc resource-monitor to enable resource monitoring.
Use undo smartmc resource-monitor to disable resource monitoring.
smartmc resource-monitor [ cpu | memory | temperature ] * [ group group-name-list | tc { tc-id-list | mac-address mac-address } | tm ]
undo smartmc resource-monitor [ cpu | memory | temperature ] * [ group group-name-list | tc { tc-id-list | mac-address mac-address } | tm ]
Resource monitoring is disabled.
cpu: Enables CPU usage monitoring.
memory: Enables memory usage monitoring.
temperature: Enables temperature monitoring.
group group-name-list: Specifies the SmartMC groups to monitor. You can specify a space-separated list of up to 10 SmartMC groups. The group name is a case-sensitive string of 1 to 31 characters.
tc: Specifies the members to monitor.
mac-address mac-address: Specifies a member by its MAC address in the format of H-H-H.
tm: Enables resource monitoring on the commander.
If you do not specify a resource type, this command enables resource monitoring for all resource types.
If you do not specify a device to monitor (member or the commander), this command enables resource monitoring on the commander and all members.
# Enable resource monitoring for all resource types on members 1 through 3.
[Sysname] smartmc resource-monitor tc 1 to 3
Use smartmc resource-monitor interval to set the interval for the commander to obtain resource monitoring information.
Use undo smartmc resource-monitor interval to restore the default.
smartmc resource-monitor interval interval
The interval for the commander to obtain resource monitoring information is 1 minute.
interval: Specifies the interval for the commander to obtain resource monitoring information, in the range of 1 to 60 minutes.
# Set the interval for the commander to obtain resource monitoring information to 5 minutes.
[Sysname] smartmc resource-monitor interval 5
Use smartmc resource-monitor max-age to set the aging time for resource monitoring information.
Use undo smartmc resource-monitor max-age to restore the default.
smartmc resource-monitor max-age max-age
The aging time for resource monitoring information is 24 hours.
max-age: Specifies the aging time for resource monitoring information, in the range of 1 to 168 hours.
# Set the aging time for resource monitoring information to 1 hour.
[Sysname] smartmc resource-monitor max-age 1
smartmc replace
Use smartmc replace to manually replace a faulty member.
smartmc replace tc tc-id1 faulty-tc tc-id2
tc tc-id1: Specifies the ID of the new member, in the range of 1 to 255.
faulty-tc tc-id2: Specifies the ID of the faulty member, in the range of 1 to 255.
Before you execute this command, perform the following tasks:
# Replace faulty member 5 with new member 10.
[Sysname] smartmc replace tc 10 faulty-tc 5
smartmc tc boot-loader
Use smartmc tc boot-loader to specify the upgrade startup software files for a member.
Use undo smartmc tc boot-loader to remove the configuration.
smartmc tc tc-id boot-loader { ipe-filename | boot boot-filename system system-filename }
undo smartmc tc tc-id boot-loader
tc tc-id: Specifies a member by its ID in the range of 1 to 255.
# Specify boot image file boot.bin and system image file system.bin for member 1.
[Sysname] smartmc tc 1 boot-loader boot boot.bin system system.bin
display smartmc tc
smartmc tc device-type
Use smartmc tc device-type to define a member type on the commander.
Use undo smartmc tc device-type to delete a member type.
smartmc tc sysoid sysoid device-type device-type
undo smartmc tc sysoid sysoid device-type device-type
sysoid sysoid: Specifies the SYSOID of a device.
device-type device-type: Specifies a device type.
A device type can correspond to multiple device models. You can identify different device models with different SYSOIDs by specifying a SYSOID for each device model. The commander identifies member types by SYSOID.
The system predefines the device types for some device models based on SYSOIDs. For device models without predefined device types, you must define their member types by SYSOID manually. If you do not do so, the commander cannot identify the types of such devices.
You cannot modify the predefined device types.
Before defining a device type for a member, you can use the display smartmc tc command to determine whether the member has a predefined one.
· If the member has been predefined with one device type, the DeviceType field displays the actual predefined device type.
· If the member does not have a predefined device type, the DeviceType field displays unknown.
To obtain the SYSOID of a member, use the display smartmc tc verbose command.
As a best practice, define the same device type for devices of the same model and use predefined device types. You can use the display device command to view the device model. For more information about this command, see device management commands in Fundamentals Configuration Guide. You can use the smartmc tc sysoid sysoid device-type ? command to display predefined device types.
You can configure device types as SmartMC grouping criteria to add devices of the same type to the same group.
# Define a member type by specifying the SYSOID as 1.3.6.1.4.1.25506.1.1588 and the device type as ROUTER.
[Sysname] smartmc tc sysoid 1.3.6.1.4.1.25506.1.1588 device-type ROUTER
smartmc tc password
Use smartmc tc password to modify the password for the default user on members.
Use undo smartmc tc password to restore the default.
smartmc tc password [ cipher ] string
The password of the default user is admin.
cipher: Specifies a password in encrypted form. If you do not specify this keyword, the system creates a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies a password. This argument is case sensitive. Its plaintext form is 1 to 63 characters. Its encrypted form is 1 to 117 characters.
During SmartMC network establishment, the commander establishes NETCONF sessions to members and adds them to the network. The default username and password on the members for NETCONF session establishment are admin and admin. To enhance security, you can perform this task to change the password for the default user admin of the members after the commander adds the members to the network.
If the default password cannot meet the password complexity requirements on members, you cannot execute the undo smartmc tc password command to restore the default.
Do not modify the password for members that are manually added to the SmartMC network. If you modify the password for a manually added member, you will not be able to manage that member from the commander.
# Modify the password to Hello12345 for the default user on members.
[Sysname] smartmc tc password Hello12345
Use smartmc tc startup-configuration to specify the upgrade configuration file for a member.
Use undo smartmc tc startup-configuration to remove the configuration.
smartmc tc tc-id startup-configuration cfg-filename
undo smartmc tc tc-id startup-configuration
cfg-filename: Specifies a configuration file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .cfg extension.
# Specify upgrade configuration file startup.cfg for member 1.
[Sysname] smartmc tc 1 startup-configuration startup.cfg
display smartmc tc
Use smartmc topology-refresh to manually refresh the network topology.
To display topology changes, use this command to manually refresh the topology.
# Manually refresh the network topology.
<Sysname> smartmc topology-refresh
Use smartmc topology-refresh interval to set the automatic network topology refresh interval.
Use undo smartmc topology-refresh interval to restore the default.
smartmc topology-refresh interval interval
The automatic network topology refresh interval is 60 seconds.
interval: Specifies the automatic network topology refresh interval in the range of 60 to 300 seconds.
# Set the automatic network topology refresh interval to 100 seconds.
[Sysname] smartmc topology-refresh interval 100
smartmc topology-save
Use smartmc topology-save to save the current network topology.
This task allows you to save the current network topology to the topology.dba file in the flash memory. After the commander reboots, it uses the topology.dba file to restore the network topology.
# Save the current network topology
[Sysname] smartmc topology-save
Use smartmc upgrade boot-loader to upgrade the startup software on a list of members or SmartMC groups.
Use undo smartmc upgrade delete the startup software upgrade task.
smartmc upgrade boot-loader { group | tc } list [ delay minutes | time time ]
smartmc upgrade boot-loader { group | tc } { list { boot boot-filename system system-filename | file ipe-filename } }&<1-40> [ delay delay-time | time time ]
group: Specifies the SmartMC groups to be upgraded.
tc: Specifies the members to be upgraded.
list: Specifies a space-separated list of member items or SmartMC group items.
· SmartMC group—Each item specifies a SmartMC group name, a case-sensitive string of 1 to 31 characters.
· Member—Each item specifies a member ID or a range of member IDs in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 1 to 255.
boot boot-filename: Specifies a boot image file by its name.
system system-filename: Specifies a system image file by its name.
file ipe-filename: Specifies an IPE file by its name, a case-insensitive string of 5 to 45 characters.
delay delay-time: Specifies the upgrade delay time in the range of 1 to 1440 minutes.
time in-time: Specifies the upgrade time in the format of hh:mm. The value range for the hh argument is 0 to 23 hours. The value range for the mm argument is 0 to 59 minutes.
CAUTION: Upgrading the startup software might interrupt services. Before upgrading the startup software, make sure service operation will not be affected. |
To use this command to upgrade the startup software on members without specifying the upgrade files, you must first perform one of the following tasks:
· Execute the smartmc tc boot-loader command to specify the upgrade files for members.
· Execute the boot-loader command to specify the upgrade files for a SmartMC group.
A member can perform only one upgrade task at a time.
If you execute this command without specifying the delay time or update time, the members or SmartMC group immediately upgrades the startup software and the upgrade operation cannot be cancelled. If you specify a delay time or upgrade time to perform a scheduled upgrade, the upgrade operation can be cancelled by using the undo smartmc upgrade command before it starts.
# Upgrade startup software images boot.bin and sys.bin on all members in SmartMC groups test1 and test2.
[Sysname] smartmc upgrade boot-loader group test1 test2 boot boot.bin system sys.bin
boot-loader
Use smartmc upgrade startup-configuration to upgrade the configuration file on a list of members or on all members in SmartMC groups.
Use undo smartmc upgrade delete the configuration file upgrade task.
smartmc upgrade startup-configuration { group | tc } list [ delay minutes | time time ]
smartmc upgrade startup-configuration group { list file cfg-filename }&<1-40> [ delay delay-time | time time ]
smartmc upgrade startup-configuration tc { list cfg-filename }&<1-40> [ delay delay-time | time time ]
file cfg-filename: Specifies a configuration file by its name.
CAUTION: After a file upgrade, the device runs with the configurations in the new file. For the device to operate correctly, make sure configurations in the new file are correct. |
To use this command to upgrade the configuration file on members without specifying the upgrade file, you must first perform one of the following tasks:
· Execute the smartmc tc startup-configuration command to specify the upgrade file for members.
· Execute the startup-configuration command to specify the upgrade file for a SmartMC group.
If you execute this command without specifying the delay time or update time, the members or SmartMC group immediately upgrades the configuration file and the upgrade operation cannot be cancelled. If you specify a delay time or upgrade time to perform a scheduled upgrade, the upgrade operation can be cancelled by using the undo smartmc upgrade command before it starts.
# Upgrade configuration file startup.cfg on all members in SmartMC groups test1 and test2.
[Sysname] smartmc upgrade startup-configuration group test1 test2 file startup.cfg
boot-loader
smartmc vlan
Use smartmc vlan to create a VLAN for members.
smartmc vlan vlan-id { group group-name-list | tc tc-id-list }
vlan-id: Specifies the VLAN ID in the range of 1 to 4094.
group group-name-list: Specifies the SmartMC groups for which the VLAN is created. You can specify a space-separated list of up to 10 SmartMC groups. The group name is a case-sensitive string of 1 to 31 characters.
tc tc-id-list: Specifies the members for which the VLAN is created. You can specify a space-separated list of up to 10 member items. Each item specifies a member or a range of members in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 1 to 255.
Execute this command when the network topology is stable. As a best practice, use the smartmc topology-refresh command to refresh the network topology before executing this command.
After you configure this command, all access ports on members except the following access ports are assigned to the VLAN:
· Access ports connecting to the commander.
· Access ports connecting to other members.
· Access ports connecting to offline devices. Remove offline devices before configuring this command.
If the VLAN is successfully created but some access ports of a member cannot be assigned to the VLAN, the VLAN memberships of the member is restored to the state before the VLAN is created.
The failure to assign an access port of a member to the created VLAN does not affect the VLAN assignment for other members.
After command execution, you can use the display smartmc vlan command to examine the VLAN creation result.
# Create a VLAN for member 1 and member 2.
[Sysname] smartmc vlan 2 tc 1 to 2
As a best practice, execute the display smartmc vlan command to verify that the VLAN has been created successfully.
Use startup-configuration to specify an upgrade configuration file for a SmartMC group .
Use undo startup-configuration to restore the default.
startup-configuration cfgfile
No upgrade configuration file is specified for the SmartMC group.
SmartMC group view
cfgfile: Specifies a configuration file by its name, a string of 5 to 45 characters. The file name must include the .cfg extension.
# Specify configuration file startup.cfg for SmartMC group testgroup.
[Sysname-smartmc-group-testgroup] startup-configuration startup.cfg
smartmc group
