- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-NAT66 commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Multi-CPU packet distribution commands
- 10-Adjacency table commands
- 11-IRDP commands
- 12-IP performance optimization commands
- 13-UDP helper commands
- 14-IPv6 basics commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
- 17-AFT commands
- 18-Tunneling commands
- 19-GRE commands
- 20-ADVPN commands
- 21-WAAS commands
- 22-Lighttpd service commands
- 23-Web caching commands
- 24-STUN commands
- 25-HTTP proxy commands
| 22-Lighttpd service commands | 67.65 KB |
Lighttpd Web service commands
The following compatibility matrixes show the support of hardware platforms for Lighttpd Web service:
Hardware |
Lighttpd Web service compatibility |
MSR610 |
Yes |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN |
Yes |
No |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
MSR3600-28, MSR3600-51 |
No |
No |
No |
No |
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR3610-I-IG, MSR3610-IE-IG |
No |
No |
No |
MSR3610-G, MSR3620-G |
No |
MSR3640-G |
No |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
No |
MSR2600-10-X1-WiNet |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
No |
No |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
No |
MSR3600-28-XS |
No |
MSR3610-XS |
No |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
No |
MSR3640-XS |
No |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
light-http server directory
Use light-http server directory to specify the lighttpd Web service working directory.
light-http server directory directory
undo light-http server directory
No lighttpd Web service working directory is specified.
directory: Specifies the lighttpd Web service working directory.
If the lighttpd Web server is already enabled, the specified lighttpd Web service working directory takes effect after you disable the lighttpd Web server and then enable the server again.
To use the lighttpd Web server to provide HTTPS access service, you must save the required certificate to the lighttpd Web service working directory.
# Set the lighttpd Web service working directory to flash:/lighttpd.
[Sysname] light-http server directory flash:/lighttpd
light-http server enable
Use light-http server enable to enable the lighttpd Web server.
Use undo light-http server enable to disable the lighttpd Web server.
The lighttpd Web server is disabled.
Specify the lighttpd Web working directory before enabling the lighttpd Web server.
For the lighttpd Web server to provide lightweight HTTP or HTTPS access service correctly, make sure it uses different service ports than other services. By default, the lightweight HTTP service port number is 80 and the lightweight HTTPS service port number is 443.
# Enable the lighttpd Web server.
[Sysname] light-http server enable
light-http server http-port
Use light-http server http-port to specify the lightweight HTTP service port number.
Use undo light-http server http-port to restore the default.
light-http server http-port port-number
The lightweight HTTP service port number is 80.
port-number: Specifies the lightweight HTTP service port number, in the range of 1 to 65535.
When the lighttpd Web server is enabled, changing the lightweight HTTP service port number re-enables the lighttpd Web server and closes all lightweight HTTP and HTTPS connections. To log in again, users must enter the new URL in the Web browser's address bar.
# Set the lightweight HTTP service port number to 8080.
[Sysname] light-http server http-port 8080
Current configuration will restart the lighttpd service. Continue? [Y/N]:
light-http server https-port
Use light-http server https-port to specify the lightweight HTTPS service port number.
Use undo light-http server https-port to restore the default.
light-http server https-port port-number
The lightweight HTTPS service port number is 443.
port-number: Specifies the lightweight HTTPS service port number, in the range of 1 to 65535.
When the lighttpd Web server is enabled, changing the lightweight HTTPS service port number re-enables the lighttpd Web server and closes all lightweight HTTP and HTTPS connections. To log in again, users must enter the new URL in the Web browser's address bar.
# Set the lightweight HTTPS service port number to 8081.
[Sysname] light-http server https-port 8081
