- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Emergency shell commands
- 09-Automatic configuration commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
- 14-RAID management commands (routers)
- 15-Preprovisioning commands
| 09-Automatic configuration commands | 59.23 KB |
autodeploy sms enable
Use autodeploy sms enable to enable SMS-based automatic configuration.
Use undo autodeploy sms enable to disable SMS-based automatic configuration.
SMS-based automatic configuration is enabled.
# Disable SMS-based automatic configuration.
[Sysname] undo autodeploy sms enable
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
autodeploy url enable
Use autodeploy url enable to enable URL-based automatic configuration.
Use undo autodeploy url enable to disable URL-based automatic configuration.
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware |
Command compatibility |
MSR610 |
Yes |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
Yes |
Yes |
MSR-iMC |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
MSR3620-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
URL-based automatic configuration is enabled.
# Disable URL-based automatic configuration.
[Sysname] autodeploy url enable
