- 06-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-NAT66 commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Multi-CPU packet distribution commands
- 10-Adjacency table commands
- 11-IP performance optimization commands
- 12-UDP helper commands
- 13-IPv6 basics commands
- 14-DHCPv6 commands
- 15-IPv6 fast forwarding commands
- 16-AFT commands
- 17-Tunneling commands
- 18-GRE commands
- 19-ADVPN commands
- 20-WAAS commands
- 21-Web caching commands
- 22-HTTP proxy commands
- 23-IRDP commands
- 24-STUN commands
| 24-STUN commands | 87.00 KB |
STUN commands
display stun client info
Use display stun client info to display packet statistics and NAT information on the STUN client.
# Display packet statistics and NAT information on the STUN client.
<Sysname> display stun client info
Totally 1 STUN clients
Local IP/port : 1.1.1.24/6666
Local VPN : -
NAT IP/port : 66.1.1.1/6666
NAT type : Full Cone NAT
STUN refresh times : 5657
STUN request timeouts : 2
Basic requests sent : 11324
Behavior requests sent : 5517
Filter requests sent : 5518
Received response to basic requests : 11315
Received response to behavior requests : 5517
Received response to filter requests : 5517
Transaction ID errors in received responses : 0
Local IP/port |
IP address and port number that the STUN client uses for detection. |
Local VPN |
VPN instance to which the tunnel interface on the STUN client belongs. |
NAT IP/port |
Public IP address and port number |
NAT type |
NAT type: · Full Cone NAT. · Restricted Cone NAT. · Port Restricted Cone NAT. · Symmetric NAT. · NO NAT—No NAT device exists. · -—Unknown type. |
STUN refresh times |
Number of times the STUN client refreshes the detection result. |
STUN request timeouts |
Number of detection timeouts. |
Basic requests sent |
Number of Basic requests sent. A Basic request is used to detect the public IP address and port number assigned by a NAT device. |
Behavior requests sent |
Number of Behavior requests sent. A Behavior request is used to detect the NAT mapping type. |
Filter requests sent |
Number of Filtering requests sent. A Filtering request is used to detect the NAT filtering method. |
reset stun client statistics
display stun server packet-statistics
Use display stun server packet-statistics to display packet statistics on the STUN server.
# Display packet statistics on the STUN client.
<Sysname> display stun server packet-statistics
STUN success/error requests received : 22386/0
STUN success/error responses sent : 22386/0
STUN requests dropped : 0
STUN packets received : 22386
STUN unknown packets received : 0
STUN success/error requests received |
Number of success/error requests received by the STUN server. |
STUN success/error responses sent |
Number of success/error responses sent by the STUN server. |
STUN requests dropped |
Number of requests dropped by the STUN server. |
STUN packets received |
Number of packets received by the STUN server. |
STUN unknown packets received |
Number of unknown packets received by the STUN server. |
reset stun server packet-statistics
Use reset stun client statistics to clear packet statistics on all STUN clients.
This command clears packet statistics on all STUN clients. Please use command with caution.
# Clear packet statistics on all STUN clients.
<Sysname> reset stun client statistics
Use reset stun server packet-statistics to clear packet statistics on all STUN servers.
# Clear packet statistics on all STUN servers.
<Sysname> reset stun server packet-statistics
stun client
Use stun client to enable the STUN client on an interface and specify the IP address and port number of the STUN server.
Use undo stun client to disable the STUN client on an interface or delete the configuration for the specified STUN server.
stun client destination-ip ip-address [ destination-port port-number ] [ out-interface interface-type interface-number ]
undo stun client destination-ip [ ip-address ]
The STUN client is disabled.
Tunnel interface view
destination-ip ip-address: Specifies the IP address of the STUN server.
destination-port port-number: Specifies the port number of the STUN server, in the range of 1024 to 65535. The default is 3478.
out-interface interface-type interface-number: Specifies an output interface by its type and number. If you do not specify this option, the STUN client sends packets through the output interface of the route.
Application scenarios
STUN uses a client-server model that consists of a STUN client and a STUN server. The STUN server and STUN client exchange STUN packets (Binding requests and Binding responses) to detect the IP address and port number assigned by a NAT device and the NAT type.
Operating mechanism
The STUN client is an entity that sends STUN requests and receives STUN responses. After you execute this command on a tunnel interface of the device, the device operates as a STUN client to establish a connection with the specified STUN server. Then, it sends a Binding request to the STUN server.
You can specify multiple STUN servers on the STUN client to perform detection. The STUN client works as follows:
1. The STUN client sends a Binding request to each specified STUN server.
2. The STUN client can process only one Binding response sent from a STUN server at a time. Once the STUN client obtains the NAT type and public IP address and port number after NAT, the detection stops.
3. If the detection fails, the STUN client repeats the above procedure.
Recommended configuration
In an SDWAN network with multiple WAN interfaces, the NAT type and address translation result might be wrong when you use STUN to detect the IP address and port number after NAT. To avoid such an issue, specify the output interface when you execute the stun client command. The specified output interface must be the same as that specified for tunneled packets by using the tunnel out-interface command.
For the STUN client to establish a connection with a STUN server, do not specify the alternate IP address of the STUN server in this command.
When you specify multiple STUN servers on a STUN client, make sure the STUN servers are located behind the same NAT device. If the STUN servers are located behind different NAT devices, the detection result might be incorrect.
When you execute this command, follow these restrictions and guidelines:
· When you execute the undo stun client destination-ip command, if you specify the IP address of the STUN server, this command only deletes the configuration for the STUN server. If you do not specify the IP address of the STUN server, this command disables the STUN client.
· To change the IP address and port number of the STUN server specified in this command, you must execute the undo stun client command and then specify a new IP address and port number by using the stun client command.
· You can specify a maximum of eight STUN servers by repeating this command.
For STUN detection to work correctly, make sure the STUN client can reach both the IP address and alternate IP address of the STUN server.
# Enable the STUN client on SDWAN tunnel interface Tunnel1 and specify the IP address and port number of the STUN server.
[Sysname] interface tunnel 1 mode sdwan udp
[Sysname-Tunnel1] stun client destination-ip 122.225.128.143 destination-port 1025
stun server
Use stun server to enable the STUN server and configure an IP address and port number for the STUN server.
Use undo stun server to disable the STUN server.
stun server ip ip-address [ port port-number ] [ alternative-ip ip-address [ alternative-port port-number ] ] [ vpn-instance vpn-instance-name ] [ global-ip global-ip-address [ global-port port-number ] [ global-alternative-ip ip-address [ global-alternative-port port-number ] ] ]
undo stun server ip ip-address [ port port-number ] [ vpn-instance vpn-instance-name ]
The STUN server is disabled.
ip ip-address: Specifies an IP address for the STUN server.
port port-number: Specifies a port number for the STUN server, in the range of 1024 to 65535. The default is 3478.
alternative-ip ip-address: Specifies an alternate IP address for the STUN server.
alternative-port port-number: Specifies an alternate port number for the STUN server, in the range of 1024 to 65535. The default is 3479. If do not specify this option for a STUN server that is deployed in the public network, the STUN client cannot determine the NAT type.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the STUN server belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the STUN server belongs to the public network, do not specify this option.
global-ip ip-address: Specifies the public IP address for the STUN server after NAT.
global-port port-number: Specifies the public port number for the STUN server after NAT, in the range of 1024 to 65535.
global-alternative-ip ip-address: Specifies the alternate public IP address for the STUN server after NAT. If do not specify this option for a STUN server that is deployed in a private network, the STUN client cannot determine the NAT type.
global-alternative-port port-number: Specifies the alternate public port number for the STUN server after NAT, in the range of 1024 to 65535.
Typically deployed on the public network, the STUN server is an entity that receives STUN requests and sends STUN responses. The STUN server and STUN client exchange STUN packets to detect the IP address and port number assigned by a NAT device and the NAT type.
If a STUN server is deployed in a private network and communicates with the public network through a NAT device configured with a one-to-one NAT mapping rule, the STUN server uses its private address as the IP address in Binding responses. When receiving a subsequent Binding request, the STUN server-side NAT device will not translate the private address in the request to a public address, which leads to STUN detection failure.
To solve the problem, specify the global-ip global-ip-address and global-alternative-ip ip-address parameters. The STUN server will uses the specified public address in Binding responses it sends. The specified public addresses must match the public IP addresses on the NAT device.
In a multi-egress environment, you can execute this command multiple times to configure multiple STUN servers.
For STUN detection to work correctly, make sure the STUN client can reach both the IP address and alternate IP address of the STUN server. To change the IP address and port number of the STUN server configured in this command, you must execute the undo stun server command and then configure a new IP address and port number by using the stun server command.
In the public network or in the same VPN instance:
· Any two IP addresses of a STUN server must be different. Any IP address of a STUN server cannot be the same as any IP address of another STUN server.
· The port number and alternate port number of the same STUN server cannot be the same. The public port number or alternate public port number of a STUN server cannot be the same as the public port number or alternate public port number of another STUN server.
As a best practice, execute the display udp command to obtain the value for the Local Addr:port field before you configure a STUN server. The Local Addr:port field represents the local IPv4 addresses and port numbers that are being used. To deploy configuration successfully, do not specify a used local port number for the STUN server.
# Enable the STUN server and configure an IP address and port number and an alternate IP address and port number for the STUN server.
[Sysname] stun server ip 10.1.1.1 port 4396 alternative-ip 20.1.1.1 alternative-port 4397
display udp
