- 06-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-NAT66 commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Multi-CPU packet distribution commands
- 10-Adjacency table commands
- 11-IP performance optimization commands
- 12-UDP helper commands
- 13-IPv6 basics commands
- 14-DHCPv6 commands
- 15-IPv6 fast forwarding commands
- 16-AFT commands
- 17-Tunneling commands
- 18-GRE commands
- 19-ADVPN commands
- 20-WAAS commands
- 21-Web caching commands
- 22-HTTP proxy commands
- 23-IRDP commands
- 24-STUN commands
| 08-Fast forwarding commands | 85.90 KB |
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
ip fast-forwarding load-sharing
reset ip fast-forwarding cache
Use display ip fast-forwarding aging-time to display the aging time of fast forwarding entries.
# Display the aging time of fast forwarding entries.
<Sysname> display ip fast-forwarding aging-time
Aging time: 30s
Use display ip fast-forwarding cache to display fast forwarding entries.
In standalone mode:
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
In IRF mode:
display ip fast-forwarding cache [ ip-address ] [ chassis chassis-number slot slot-number ]
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays all fast forwarding entries.
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command displays fast forwarding entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card in an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number represents the slot number of the card. If you do not specify a card, this command displays fast forwarding entries for all cards.(In IRF mode.)
# Display all fast forwarding entries.
<Sysname> display ip fast-forwarding cache
Total number of fast-forwarding entries: 1
SIP SPort DIP DPort Pro Input_If Output_If Flg
7.0.0.13 68 8.0.0.1 67 17 GE2/0/3 GE2/0/1 5
SIP |
Source IP address. |
SPort |
Source port number. |
DIP |
Destination IP address. |
DPort |
Destination port number. |
Pro |
Protocol number. |
Input_If |
Input interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the input interface does not exist, this field displays a hyphen (-). |
Output_If |
Output interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the output interface does not exist, this field displays a hyphen (-). |
Flg |
Internal tag, marking internal operation information, such as fragmentation. |
Use display ip fast-forwarding fragcache to display fast forwarding entries for fragmented packets.
In standalone mode:
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
In IRF mode:
display ip fast-forwarding fragcache [ ip-address ] [ chassis chassis-number slot slot-number ]
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays fast forwarding entries for all fragmented packets.
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command displays fast forwarding entries for fragmented packets on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number represents the slot number of the card. If you do not specify a card, this command displays fast forwarding entries for fragmented packets on all cards. (In IRF mode.)
The system creates fast forwarding entries for fragments only when virtual fragment reassembly (VFR) is enabled. If VFR is disabled, this command does not display fast forwarding entries for fragments.
# Display fast forwarding entries about all fragmented packets.
<Sysname> display ip fast-forwarding fragcache
Total number of fragment fast-forwarding entries: 1
SIP SPort DIP DPort Pro Input_If ID Relay_flag
7.0.0.13 68 8.0.0.1 67 17 GE2/0/3 2
SIP |
SPort |
DIP |
DPort |
Pro |
Protocol number. |
Input_If |
ID |
Fragment ID. |
Relay_flag |
Fragment pass-through flag: · 0—Not pass through. · 1—Pass through. |
Use ip fast-forwarding aging-time to configure the aging time for fast forwarding entries.
Use undo ip fast-forwarding aging-time to restore the default.
ip fast-forwarding aging-time aging-time
The aging time is 30 seconds.
aging-time: Specifies the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for fast forwarding entries.
[Sysname] ip fast-forwarding aging-time 20
ip fast-forwarding dscp
Use ip fast-forwarding dscp to enable DSCP-based fast forwarding for GRE and VXLAN packets.
Use undo ip fast-forwarding dscp to restore the default.
DSCP-based fast forwarding for GRE and VXLAN packets is disabled.
This command is applicable to GRE packets (with IP as the passenger protocol) and VXLAN packets that are processed by software.
This feature uses the DSCP value in the outer header instead of the source port number among the identification criteria to identify GRE and VXLAN traffic flows.
This command is mutually exclusive with NAT and load balancing.
# Enable DSCP-based GRE and VXLAN packet fast forwarding.
[Sysname] ip fast-forwarding dscp
ip fast-forwarding enable
Use ip fast-forwarding enable to enable fast forwarding.
Use undo ip fast-forwarding enable to disable fast forwarding.
Fast forwarding is enabled.
The fast forwarding feature will create fast forwarding entries for the device to speed up forwarding. A large number of fast forwarding entries will cause high memory usage, which eventually leads to memory allocation failure for other services. In this case, you can disable fast forwarding temporarily to free up the device memory.
Do not disable fast forwarding if the device run services that are based on sessions. Disabling fast forwarding will make these services become ineffective:
· NAT.
· ASPF.
· Attack detection and prevention.
# Disable fast forwarding.
[Sysname] undo ip fast-forwarding enable
Use ip fast-forwarding load-sharing to enable fast forwarding load sharing.
Use undo ip fast-forwarding load-sharing to disable fast forwarding load sharing.
Fast forwarding load sharing is enabled.
Fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the packet information.
If fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface. No load sharing is implemented.
# Enable fast forwarding load sharing.
<Sysname> system-Views
[Sysname] ip fast-forwarding load-sharing
ip fast-forwarding vxlan-port
Use ip fast-forwarding vxlan-port to specify the destination UDP port number for identifying VXLAN packets.
Use undo ip fast-forwarding vxlan-port to restore the default.
ip fast-forwarding vxlan-port port-number
The destination UDP port number is 4789.
Predefined use roles
port-number: Specifies a UDP port number in the range of 1 to 65535.
This feature is applicable to only the UDP packets that are processed by software.
In a VXLAN network, configure this command on intermediate devices to identify VXLAN packets.
# Specify the destination UDP port number to 4900 for identifying VXLAN packets.
[Sysname] ip fast-forwarding vxlan-port 4900
Use reset ip fast-forwarding cache to clear the fast forwarding table.
In standalone mode:
reset ip fast-forwarding cache [ slot slot-number ]
In IRF mode:
reset ip fast-forwarding cache [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command clears the fast forwarding table for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears the fast forwarding table for all cards. (In IRF mode.)
# Clear the fast forwarding table.
<Sysname> reset ip fast-forwarding cache
