- 05-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-DHCP-SNOOP2-MIB
- 05-HH3C-DHCP4-CLIENT-MIB
- 06-HH3C-DHCP4-MIB
- 07-HH3C-DNS-MIB
- 08-HH3C-FIB-MIB
- 09-HH3C-IP-ADDRESS-MIB
- 10-HH3C-IPV6-ADDRESS-MIB
- 11-HH3C-ND-TRAP-MIB
- 12-HH3C-TCP-MIB
- 13-IP-FORWARD-MIB
- 14-IP-MIB
- 15-IPV6-ICMP-MIB
- 16-IPV6-MIB
- 17-IPV6-TCP-MIB
- 18-IPV6-UDP-MIB
- 19-TCP-MIB
- 20-UDP-MIB
08-HH3C-FIB-MIB | 227.43 KB |
HH3C-FIB-MIB
About this MIB
Use this MIB to detect whether the number of FIB entries reaches the threshold and whether the messages to be forwarded on the module are congested.
MIB file name
hh3c-fib.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cFibTrap(216)
Scalar objects
hh3cFibChassisID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibChassisID (1.3.6.1.4.1.25506.2.216.1.1.1) |
accessible-for-notify |
Unsigned32 |
Standard MIB values. |
Module ID. |
As per the MIB. |
hh3cFibSlotID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibSlotID (1.3.6.1.4.1.25506.2.216.1.1.2) |
Unsigned32 |
Module slot ID. |
As per the MIB. |
hh3cFibOverloadModule
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibOverloadModule (1.3.6.1.4.1.25506.2.216.2.1.1) |
OCTET STRING |
OCTET STRING (0..255) |
Module name (FIB4/FIB6). |
As per the MIB. |
hh3cFibIPv4MaxNumChassis
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibIPv4MaxNumChassis (1.3.6.1.4.1.25506.2.216.3.1.1) |
Unsigned32 |
Chassis number for the alarm. |
As per the MIB. |
hh3cFibIPv4MaxNumSlot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibIPv4MaxNumSlot (1.3.6.1.4.1.25506.2.216.3.1.2) |
Unsigned32 |
Module slot for the alarm. |
As per the MIB. |
hh3cFibIPv4MaxNumCurCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibIPv4MaxNumCurCount (1.3.6.1.4.1.25506.2.216.3.1.3) |
Unsigned32 |
Current number of FIB4 entries for the module. |
As per the MIB. |
hh3cFibIPv6MaxNumChassis
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibIPv6MaxNumChassis (1.3.6.1.4.1.25506.2.216.4.1.1) |
Unsigned32 |
As per the MIB. |
hh3cFibIPv6MaxNumSlot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibIPv6MaxNumSlot (1.3.6.1.4.1.25506.2.216.4.1.2) |
Unsigned32 |
As per the MIB. |
hh3cFibIPv6MaxNumCurCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibIPv6MaxNumCurCount (1.3.6.1.4.1.25506.2.216.4.1.3) |
Unsigned32 |
Current number of FIB6 entries for the module. |
As per the MIB. |
hh3cFibPub4OverloadCurCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibPub4OverloadCurCount (1.3.6.1.4.1.25506.2.216.5.1.1) |
Unsigned32 |
Current number of FIB4 public network entries. |
As per the MIB. |
hh3cFibPub6OverloadCurCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibPub6OverloadCurCount (1.3.6.1.4.1.25506.2.216.6.1.1) |
Unsigned32 |
Current number of FIB6 public network entries. |
As per the MIB. |
hh3cFibEntryChassisID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibEntryChassisID (1.3.6.1.4.1.25506.2.216.7.1.1) |
Unsigned32 |
As per the MIB. |
hh3cFibEntrySlotID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibEntrySlotID (1.3.6.1.4.1.25506.2.216.7.1.2) |
Unsigned32 |
As per the MIB. |
hh3cFibDeliverFailedVrf
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibDeliverFailedVrf (1.3.6.1.4.1.25506.2.216.8.1.1) |
Unsigned32 |
VRF value for the FIB entry. |
As per the MIB. |
h3cFibDeliverFailedIPType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
h3cFibDeliverFailedIPType (1.3.6.1.4.1.25506.2.216.8.1.2) |
InetAddressType |
unknown(0), ipv4(1), ipv6(2) |
IP address type for the FIB entry. |
As per the MIB. |
hh3cFibDeliverFailedIPAddress
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibDeliverFailedIPAddress (1.3.6.1.4.1.25506.2.216.8.1.3) |
InetAddress |
IP address for the FIB entry. |
As per the MIB. |
hh3cFibDeliverFailedMask
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibDeliverFailedMask (1.3.6.1.4.1.25506.2.216.8.1.4) |
Unsigned32 |
Subnet mask for the FIB entry. |
As per the MIB. |
hh3cFibDeliverFailedReasonId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFibDeliverFailedReasonId (1.3.6.1.4.1.25506.2.216.8.1.5) |
1 (noResource) 2 (lpmFailed) |
Reason for the FIB entry deployment failure. |
As per the MIB. |
Notifications
hh3cFibMsgCongest
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.216.1.0.1 |
The messages to be forwarded on the module were congested. |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.1.0.2 (hh3cFibBoardMsgCongestResume) |
ON |
Notification triggers
This notification is generated when FIB message processing is congested because the device hardware fails or a large number of FIB entries are refreshed.
System impact
Device message forwarding cannot operate correctly.
Status control
ON
CLI: Use the snmp-agent trap enable fib command.
OFF
CLI: Use the undo snmp-agent trap enable fib command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.1.1.1 (hh3cFibChassisID) |
Chassis number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.216.1.1.2 (hh3cFibSlotID) |
Slot number. |
N/A |
Unsigned32 |
Recommended action
To resovle the issue:
1. Use the display ip routing-table all-routes statistics and display ipv6 routing-table all-routes statistics commands to verify if a large number of routes are changed. If yes, proceed to step 2. If no, proceed to step 3.
2. Identify the source protocol for the route changes and analyze the change reason. If the reason cannot be identified, proceed to step 3.
3. If the issue persists, collect the configuration file and alarm information, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.1.0.2 |
The module recovered from a message congestion alarm. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the module recovers from a message congestion alarm.
System impact
No negative impact on services.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number. |
N/A |
Unsigned32 |
Slot number. |
N/A |
Unsigned32 |
Recommended action
No action is required.
hh3cFibOverloadForward
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.2.0.1 |
The number of FIB entries on the device exceeded the threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.2.0.2 (hh3cFibOverloadForwardResume) |
ON |
This notification is generated when the number of FIB entries on the device exceeds 80% of the threshold.
System impact
If the number of FIB entries exceeds the threshold, the device cannot issue FIB entries and service errors might occur.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.2.1.1 (hh3cFibOverloadModule) |
Module name (FIB4/FIB6) |
N/A |
OCTET STRING |
Recommended action
Use the display ip routing-table all-routes statistics and display ipv6 routing-table all-routes statistics commands to view the number of entries issued by each protocol. Analyze whether redundant routes exist based on service requirements and delete redundant routes if they exist.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.2.0.2 |
The device recovered from a FIB entry capacity usage alarm. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the device recovers from a FIB entry capacity usage alarm.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
Recommended action
hh3cFibIPv4MaxNumAlarm
Basic informationBasic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.3.0.1 |
The FIB capacity upper limit is exceeded on the device. |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.3.0.2 (hh3cFibIPv4MaxNumResume) |
ON |
This notification is generated if the number of IPv4 FIB entries on the interface module on the current device exceeds the upper limit.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.3.1.1 (hh3cFibIPv4MaxNumChassis) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.216.3.1.2 (hh3cFibIPv4MaxNumSlot) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.216.3.1.3 (hh3cFibIPv4MaxNumCurCount) |
N/A |
Unsigned32 |
Recommended action
Use the display ip routing-table all-routes statistics command to view the number of entries issued by each protocol. Analyze whether redundant routes exist based on service requirements and delete redundant routes if they exist.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.3.0.2 |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the device recovers from an IPv4 FIB entry capacity usage alarm.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Recommended action
hh3cFibIPv6MaxNumAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.4.0.1 |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.4.0.2 (hh3cFibIPv6MaxNumResume) |
ON |
This notification is generated if the number of IPv6 FIB entries on the interface module on the current device exceeds the upper limit.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.4.1.1 (hh3cFibIPv6MaxNumChassis) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.216.4.1.2 (hh3cFibIPv6MaxNumSlot) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.216.4.1.3 (hh3cFibIPv6MaxNumCurCount) |
N/A |
Unsigned32 |
Recommended action
Use the display ipv6 routing-table all-routes statistics command to view the number of entries issued by each protocol. Analyze whether redundant routes exist based on service requirements and delete redundant routes if they exist.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.4.0.2 |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the device recovers from an IPv6 FIB entry capacity usage alarm.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Recommended action
hh3cFibPub4OverloadForward
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.5.0.1 |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.5.0.2 (hh3cFibPub4OverloadForwardResume) |
ON |
This notification is generated when the number of IPv4 FIB entries on the device exceeds 80% of the threshold.
System impact
If the number of IPv4 FIB entries exceeds the threshold, the device cannot issue IPv4 FIB entries and service errors might occur.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.5.1.1 (hh3cFibPub4OverloadCurCount) |
N/A |
Unsigned32 |
Recommended action
Use the display ip routing-table statistics command to view the number of entries issued by each protocol. Analyze whether redundant routes exist based on service requirements and delete redundant routes if they exist.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.5.0.2 |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the number of FIB entries on the device drops below 60% of the threshold. The device recovers from a FIB entry capacity usage alarm.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Unsigned32 |
Recommended action
hh3cFibPub6OverloadForward
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.6.0.1 |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.6.0.2 (hh3cFibPub6OverloadForwardResume) |
ON |
This notification is generated when the number of IPv6 FIB entries on the device exceeds 80% of the threshold.
System impact
If the number of IPv6 FIB entries exceeds the threshold, the device cannot issue IPv6 FIB entries and service errors might occur.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.6.1.1 (hh3cFibPub6OverloadCurCount) |
N/A |
Unsigned32 |
Recommended action
Use the display ipv6 routing-table statistics command to view the number of entries issued by each protocol. Analyze whether redundant routes exist based on service requirements and delete redundant routes if they exist.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.6.0.2 |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the number of IPv6 FIB entries on the device drops below 60% of the threshold. The device recovers from a FIB entry capacity usage alarm.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.6.1.1 (hh3c FibPub6OverloadCurCount) |
N/A |
Unsigned32 |
Recommended action
hh3cFibEntryConsistencyAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.7.0.1 |
A device FIB entry conflict occurs. |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.7.0.2 (hh3cFibEntryConsistencyResume) |
ON |
This notification is generated when a FIB entry on the device conflicts with driver hardware entry.
System impact
If a FIB entry conflict occurs, a service failure might occur.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.7.1.1 (hh3cFibEntryChassisID) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.216.7.1.2 (hh3cFibEntrySlotID) |
N/A |
Unsigned32 |
Recommended action
To resolve this issue:
1. View the log information generated by executing the fib consistency-check enable command.
2. Identify whether the route is necessary based on service requirements, and then choose to redeploy or delete the route.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.7.0.2 |
The device recovered from a FIB entry conflict alarm. |
Informational |
Informational |
N/A |
ON |
This notification is generated when the conflicting FIB entry is refreshed again.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Recommended action
hh3cFibEcmpMemberLimitAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.7.0.3 |
The number of members in a single ECMP group on the device exceeded the threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.8.0.4 (hh3cFibEcmpMemberLimitResume) |
ON |
This notification is generated when the number of members in a single ECMP group on the device exceeds the threshold.
System impact
If the number of members in a single ECMP group on the device exceeds the threshold, the device cannot issue the FIB entry, and a service failure might occur.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Recommended action
1. Use the display max-ecmp-num command to view the configured maximum number of ECMP routes.
2. Use the max-ecmp-num command to configure the maximum number of ECMP routes again.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.7.0.4 |
The number of members in the ECMP group dropped below the threshold. |
Informational |
Informational |
N/A |
ON |
This notification is generated when the number of members in the ECMP group drops below the threshold.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.8.0.1 |
FIB entry deployment fails. |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.8.0.2 (hh3c FibDeliverFailedResume) |
ON |
This notification is generated when FIB entry deployment fails.
System impact
If the FIB entry deployment fails, a service failure might occur.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.8.1.1 (hh3cFibDeliverFailedVrf) |
VRF value of the FIB entry. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.216.8.1.2 (hh3cFibDeliverFailedIPType) |
IP address type of the FIB entry. |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.216.8.1.3 (hh3cFibDeliverFailedIPAddress) |
IP address of the FIB entry. |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.216.8.1.4 (hh3cFibDeliverFailedMask) |
Subnet mask of the FIB entry. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.216.8.1.5 (hh3cFibDeliverFailedReasonId) |
N/A |
Recommended action
Based on the alarm information, use the display ipv6 routing-table command to view the route that failed to be deployed, and then delete or redeploy the route according to service requirements.
hh3cFibDeliverFailedResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.8.0.2 |
No FIB entry deployment failure occurs within 60 minutes |
Informational |
Informational |
N/A |
ON |
This notification is generated when no FIB entry deployment failure occurs within 60 minutes.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Unsigned32 |
N/A |
InetAddressType |
N/A |
InetAddress |
N/A |
Unsigned32 |
N/A |
Recommended action
