05-Layer 3 - IP Services
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 MIB Companion-Release 6715-6W10005-Layer 3 - IP Services
07-HH3C-DNS-MIB
07-HH3C-DNS-MIB 50.54 KB
HH3C-DNS-MIB
About this MIB
Use this MIB to obtain and configure DNS server settings.
MIB file name
hh3c-dns.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDns(97)
Tabular objects
hh3cDnsStaticSrvIpTable
About this table
This table allows manual configuration of static DNS servers for the public network.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cDnsStaticSrvIpType and hh3cDnsStaticSrvIpAddr.
Object (OID)
Access
Value range
Implementation
hh3cDnsStaticSrvIpType (1.3.6.1.4.1.25506.2.97.1.1.1.1)
not-accessible
InetAddressType
Standard MIB values.
IP address type of the static DNS server.
Only support IPv4.
hh3cDnsStaticSrvIpAddr (1.3.6.1.4.1.25506.2.97.1.1.1.2)
not-accessible
InetAddress
OCTET STRING (0..255)
IP address of the static DNS server.
As per the MIB.
hh3cDnsStaticSrvIpPriority (1.3.6.1.4.1.25506.2.97.1.1.1.3)
read-only
Integer32
Integer32(0..2147483647)
Priority of the static DNS server.
As per the MIB.
hh3cDnsStaticSrvIpRowStatus (1.3.6.1.4.1.25506.2.97.1.1.1.4)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status of the static DNS server.
As per the MIB.
hh3cDnsDynamicSrvIpTable
About this table
This table queries dynamic DNS servers in the public network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cDnsDynamicSrvIpType and hh3cDnsDynamicSrvIpAddr.
Object (OID)
Access
Value range
Implementation
hh3cDnsDynamicSrvIpType (1.3.6.1.4.1.25506.2.97.1.2.1.1)
not-accessible
InetAddressType
IP address type of the dynamic DNS server.
As per the MIB.
hh3cDnsDynamicSrvIpAddr (1.3.6.1.4.1.25506.2.97.1.2.1.2)
not-accessible
InetAddress
IP address of the dynamic DNS server.
As per the MIB.
hh3cDnsDynamicSrvIpPriority (1.3.6.1.4.1.25506.2.97.1.2.1.3)
read-only
Integer32
Integer32(0.2147483647)
Priority of the dynamic DNS server.
As per the MIB.
