H3C U-Center 2.0 Deployment Guide(on Unified Platform E0714)-5W105
HomeSupportNetwork Operations & ManagementH3C U-Center 2.0Install & UpgradeInstallation GuidesH3C U-Center 2.0 Deployment Guide(on Unified Platform E0714)-5W105
01-Text
01-Text 674.14 KB
Overview·· 1
U-Center 2.0 deployment procedure at a glance· 2
Preparing for deployment 3
IP address assignment 3
Installation packages· 4
Server requirements· 18
Hardware requirements· 18
Software requirements· 18
Client requirements· 19
Pre-installation checklist 19
Software package verification· 19
Installing Unified Platform·· 21
Installing U-Center 2.0· 22
(Optional.) Deploying the IOM component in convergence mode· 23
(Optional.) Deploying the CMDB component in convergence mode· 23
(Optional.) Deploying the BSM component in convergence mode· 24
(Optional.) Deploying the ITSM component in convergence mode· 25
(Optional.) Deploying the NTA component in convergence mode· 25
(Optional.) Deploying the AOM component in convergence mode· 26
(Optional.) Deploying the STM component in convergence mode· 26
Logging in to U-Center 2.0· 27
Registering the software· 28
License support 28
Installing and obtaining licenses· 32
Backing up and restoring the configuration· 33
Recovering the cluster from failures· 33
Upgrading U-Center 2.0· 33
Restrictions and guidelines· 33
Upgrading U-Center 2.0 through convergence deployment 33
Uninstalling U-Center 2.0· 34
Restrictions and guidelines· 34
Uninstalling U-Center 2.0 through convergence deployment 34
Uninstalling U-Center 2.0 through application deployment 34
Shutting down and powering off servers· 35
Backing up the configuration· 35
Shutting down and powering off part of nodes· 35
Shutting down and powering off all nodes· 35
Starting servers· 36
Starting servers and checking the network· 36
Starting the system service· 36
Verifying licenses and service functionalities· 36
FAQ·· 36
Overview
With an advanced containerized microservice architecture, U-Center 2.0 provides clustering and high availability capabilities, features easy deployment, and supports large-scale data storage. Based on the architecture, U-Center 2.0 integrates the monitoring, CMDB, automation, IT process management, and service management components to form a unified operations and maintenance (O & M) platform.
In the containerized microservice architecture, the installation and deployment of different components might vary. This document provides streamlined installation and deployment guidelines for correct deployment of U-Center 2.0.
U-Center 2.0 contains CMDB, IOM, BSM, ITSM, NTA, AOM, and STM components. It supports standalone deployment on one master node and cluster deployment on three master nodes and N worker nodes (N ≥ 0).
All components of U-Center 2.0 support small-, medium-, large-, and default-scale deployment. To deploy these components in small scale, make sure the Unified Platform is in simplified mode (lite mode). For more information about the lite deployment mode, see H3C Unified Platform Deployment Guide.
Table 1 shows the U-Center 2.0 deployment workflow.
Table 1 U-Center 2.0 deployment workflow
Step
Remarks
Prepare servers.
·     The standalone mode requires one server.
·     The cluster mode requires a minimum of three servers.
Required.
For hardware and software requirements, see "Server requirements."
Deploy Unified Platform.
Install an operating system and dependencies.
Required.
For more information, see H3C Unified Platform Deployment Guide.
Install Matrix.
Required if a non-H3Linux 1.0 operating system is used.
Configure cluster parameters.
Required.
Create a cluster.
Required.
Deploy Unified Platform installation packages.
Required.
Deploy U-Center 2.0.
Deploy various components of U-Center 2.0.
Convergence deployment is supported.
For more information, see “Installing U-Center 2.0.”
IMPORTANT
IMPORTANT:
Deploy the environment and make sure that:
·     The IP addresses of all the nodes can communicate with the internal virtual IP address of the cluster or northbound service virtual IP address.
·     The internal IP addresses of all the nodes can communicate with one another, including the IP addresses in the service IP pool and content IP pool.
IMPORTANT
IMPORTANT:
Follow these restrictions and guidelines when deploying, upgrading, or rebuilding a cluster in a scenario where multiple NICs exist:
·     Before deploying, upgrading, or rebuilding a cluster, make sure all NICs before the NIC whose IP is used as the node IP in the Matrix cluster have IPs assigned or the ONBOOT value set to no. For example, if the node uses the IP of NIC ens191 as the node IP in the Matrix cluster, and ens190 is before ens191 in order, make sure ens190 has an IP assigned.
·     You must use the ifconfig command to view the NIC order.
·     Make sure no abnormal NIC configuration file exists in the cluster. For example, the ONBOOT value is yes when the NIC is not connected or not configured with an IP.
·     If the cluster uses a bonding interface as the node IP in the Matrix cluster, make sure all NICs not the members of the bonding interface have IPs assigned or the ONBOOT value set to no.
Table 2 shows the IP address assignment for U-Center 2.0 deployment. Only IPv4 addresses are supported.
Table 2 Networking details
IP address
Remarks
Master node 1 IP
IP address assigned to the master node installed with an operating system.
Required. (Only one master node is required in standalone mode.)
IP addresses of master nodes in one cluster must be on the same subnet.
Master node 2 IP
Master node 3 IP
Northbound service VIP
The unified external access address for all applications deployed through Matrix.
Required.
The northbound service VIP must be on the same subnet as the subnet of the master nodes.
Worker node IP addresses
IP address assigned to a worker node.
Optional.
This IP address must be on the same subnet as those of the master nodes.
Table 3 describes the U-Center 2.0 installation packages when the H3C Linux operating system is used. If another operating system is used, H3Linux ISO files are not necessarily required. In this table, version indicates the version number and platform represents the CPU architecture type.
A required application package must be installed for U-Center 2.0 to operate normally. An optional application package can be installed if you need the corresponding function.
Support for the x86 and ARM installation packages varies by component and version. For more information, see the release notes.
Table 3 Installation packages
Name
Product package
Remarks
Dependencies
common_Linux-version_platform.iso
H3Linux OS installation package
PLAT
Required
N/A
UDTP_Middle_version_platform.zip
Middleware image repository, including databases and message queues.
PLAT
Required.
N/A
UDTP_GlusterFS_version_platform.zip
Provides local shared storage functionalities:
·     Provides a universal tool for creating storage volumes.
·     Automatically repairs GFS anomalies caused by node anomalies and brain splits.
·     Supports remote disaster recovery system (RDRS).
PLAT
Required.
N/A
UDTP_Core_version_platform.zip
Provides portal, unified authentication, user management, service gateway, service data backup & restoration, application deployment management (installation, upgrade, expansion, and uninstallation), help center, permissions, operation groups, roles, role groups, unified resource UUIDs, license query and display, configuration center, and log service.
PLAT
Required.
Middle, GlusterFS
UDTP_IMonitor_version_platform.zip
Provides self-monitoring services, including:
·     Monitors hosts and containers, monitors the indexes of multiple middleware products, including etcd, GlusterFS, and MySQL, and provides a visual interface.
·     Provides the index alarm function. After you configure the level 1 and level 2 thresholds of the specified index, an alarm will be sent when the level 1 or level 2 threshold is reached.
·     Displays the list of K8s workloads, allows you to view basic information of the workloads, and supports multiple search options.
PLAT
Optional.
The host and container monitoring function provided by the component corresponds to the host and pod monitoring function of Matrix versions earlier than Unified Platform E0713.
Core
BMP_Report_version_platform.zip
Provides the report function, allows other components to register report templates, and adds report tasks:
·     Report templates
·     Report tasks
PLAT
Optional.
Corresponds to the report function in the general_PLAT_kernel-base_2.0_<version>.zip package for versions earlier than Unified Platform E0713.
N/A
BMP_QuickReport_version_platform.zip
Provides more convenient report customization functions, allows service components to register data sources, and generates charts based on data source configuration. Including:
·     Data source management
·     Template management
·     Task management
PLAT
Optional.
Report
BMP_Alarm_version_platform.zip
Provides basic alarm services, including receiving traps, upgrading to alarms, and forwarding alarms via SMS, email, WeChat, and WeCom.
PLAT
Optional.
Corresponds to the alarm function in the general_PLAT_kernel-base_2.0_<version>.zip package for versions earlier than Unified Platform E0713.
Report
BMP_Certificate_version_platform.zip
Provides the certificate management services, including:
·     Requesting certificates
·     Uploading certificates
·     Downloading certificates
PLAT
Optional.
Alarm
BMP_Dashboard_version_platform.zip
Provides the dashboard framework capabilities, including:
·     Dashboard management
·     Dashboard settings
·     Area dashboard
·     Default dashboard
·     Service component management
PLAT
Optional.
The dashboard application requires installation of both the dashboard and widget packages, with the dashboard installed before the widget.
BMP_Widget_version_platform.zip
Provides Unified Platform dashboard- and alarm-related widgets, and backend data interfaces
PLAT
Optional.
Dashboard
BMP_NETCONF_version_platform.zip
Provides NETCONF channel services, including NETCONF connection maintenance for Unified Platform systems and devices, and NETCONF message issuing and subscriptions.
PLAT
Optional.
N/A
BMP_OneClickCheck_version_platform.zip
·     Provides the one-click check function to check the basic CPU, memory, database status, and process service status of the operating system, the operation status of the basic services (such as cluster) on which the controller depends, and the operating status of user services such as network elements and vNetworks, and generate relevant check reports.
·     Supports setting the time for scheduled check and setting the thresholds for check items.
PLAT
Recommended.
Alarm
BMP_RDR_version_platform.zip
Remote disaster recovery system (RDRS), which provides primary/secondary disaster recovery between two remote sites located in different areas.
The components in the primary and secondary sites back up each other. When the RDRS is operating properly, it synchronizes data from the in-service site to the remote site in real time. This ensures data consistency between the two sites.
You can configure the switchover mode as manual switchover or auto switchover with arbitration. When the in-service site encounters failures (for example, power interruption, network failure, or link failure), the other site takes over to ensure service continuity and reduce losses.
PLAT
Optional.
Alarm
BMP_Snapshot_version_platform.zip
·     Snapshot management, which allows you to configure snapshots for tenant-specific or network-wide services, and compare and roll back snapshots.
·     Enables quick, fine-grained repairs during the configuration change process in case of configuration errors or omissions.
PLAT
Optional.
N/A
BMP_Subscription_version_platform.zip
Subscription service, which provides capabilities of forwarding via SMS, email, WeChat, and WeCom.
PLAT
Optional.
Corresponds to the forwarding function in the general_PLAT_kernel-base_2.0_<version>.zip package for versions earlier than Unified Platform E0713.
Alarm
BMP_Suspension_version_platform.zip
Adds maintenance tags to resources, including network devices, servers, storage devices, virtualization systems, containers, operating systems, databases, middleware products, and other resources.
Allows you to configure relevant parameters to enable the system to perform related operations on resources.
PLAT
Optional.
Alarm
BMP_Template_version_platform.zip
·     Monitor template feature, which provides monitor setting management and template-based monitor index selection, threshold settings, and collection interval settings. You can select monitor templates in the monitor and auto discovery components.
·     Access parameter template feature, which provides template-based management of the parameters used by the system to access networks, servers, storage devices, virtualization systems, containers, operating systems, databases, middleware products, or other resources.
PLAT
Optional.
Corresponds to the template function in the general_PLAT_kernel-base_2.0_<version>.zip package for versions earlier than Unified Platform E0713.
N/A
BMP_WebSocket_version_platform.zip
Southbound WebSocket channel service:
·     Manages the establishment, authentication, and termination of device WebSocket connections.
·     Delivers, responds to, and subscribes to messages.
PLAT
Optional.
N/A
BMP_RDRArbitrator_version_platform.zip
Third-party arbitration system installation package for RDRS, which provides automatic primary/secondary switchover in the RDRS scenario.
PLAT
Optional.
For the procedure of deploying the arbitration service, see H3C Unified Platform Deployment Guide.
BMP_Region_version_platform.zip
Provides hierarchical site management and hub channel service.
PLAT
Optional.
For the module to send alarms, you need also install Alarm.
BMP_Syslog_version_platform.zip
Receives, parses, stores, and generates alarms for Syslog data from network devices.
PLAT
Optional.
Alarm
BMP_Aggregation_version_platform.zip
Provides the alarm aggregation feature, including:
·     Configuring alarm aggregation rules: The system aggregates alarms according to the configured rules to generate aggregate alarms.
·     Viewing aggregate alarms: Displays aggregate alarms on the active alarms page.
PLAT
Optional.
Alarm
BMP_AIOPS_version_platform.zip
Installation package for the time-series data trend prediction and anomaly detection services.
PLAT
Optional.
N/A
NSM_FCAPS-Res_version_platform.zip
Installation package for discovery, incorporation, and basic information management of network devices.
NSM
Optional.
·     portal (UDTP_Core_version_platform.zip)
·     alarm (BMP_Alarm_version_platform.zip)
·     report (BMP_Report_version_platform.zip)
·     suspension (BMP_Suspension_version_platform.zip)
·     template (BMP_Template_version_platform.zip)
NSM_FCAPS-Perf_version_platform.zip
Installation package for network device performance monitoring and display.
NSM
Optional.
·     res (NSM_FCAPS-Res_version_platform.zip)
U-Center_UCP_version_platform.zip
Installation package for the U-Center public platform component service.
IOM
Optional.
N/A
U-Center_CLICKHOUSE_version_platform.zip
Installation package for the ClickHouse database service.
IOM
Optional.
N/A
U-Center_COLLECTPLAT_version_platform.zip
Installation package for the collection platform service.
IOM
Optional.
·     portal, kernel (UDTP_Core_version_platform.zip)
·     accesstemp, monitortemp (BMP_Template_version_platform.zip)
·     register, etcd (U-Center_UCP_version_platform.zip)
U-Center_IOM_version_platform.zip
Installation package for the application monitoring service.
IOM
Optional.
·     dashboard (BMP_Dashboard_version_platform.zip)
·     glusterfs (UDTP_GlusterFS_version_platform.zip)
·     collectplat (U-Center_COLLECTPLAT_version_platform.zip)
U-Center_ADDM_version_platform.zip
Installation package for the auto-discovery service.
IOM
Optional.
register, etcd(U-Center_UCP_version_platform.zip)
U-Center_AGENT_version_platform.zip
Installation package for the agent service.
IOM
Optional.
·     U-Center_COLLECTPLAT_version_platform.zip
·     register, etcd(U-Center_UCP_version_platform.zip)
U-Center_VKVM_2.0_version_platform.zip
Installation package for the server virtual remote console service.
IOM
Optional.
·     kernel-base (BMP_Template_version_platform.zip)
·     U-Center_IOM_version_platform.zip
U-Center_CMDB_version_platform.zip
Installation package for the configuration management database.
CMDB
Optional.
·     common (UDTP_Middle_version_platform.zip)
·     UDTP_Core_version_platform.zip
U-Center_BSM_version_platform.zip
Installation package for the service health analysis service.
BSM
Optional.
·     cmdb (U-Center_CMDB_version_platform.zip)
·     ucp (U-Center_UCP_version_platform.zip)
·     iop, iom (U-Center_IOM_version_platform.zip)
U-Center_UEM_version_platform.zip
Installation package for the user experience analysis service.
BSM
Optional.
N/A
U-Center_ITSM_version_platform.zip
Installation package for the process management service.
ITSM
Optional.
U-Center_NTA_version_platform.zip
Installation package for the traffic monitoring service.
NTA
Optional.
·     accesstemp (BMP_Template_version_platform.zip)
·     network (NSM_FCAPS-Res_version_platform.zip)
·     zookeeper, clickhouse (U-Center_CLICKHOUSE_version_platform.zip)
·     etcd (U-Center_UCP_version_platform.zip)
U-Center_STM_version_platform.zip
Installation package for service dialing test management.
STM
Optional.
·     iom (U-Center_IOM_version_platform.zip)
U-Center_STM_Collector_version_platform.zip
Installation package for the service dialing test collector
STM
Optional.
U-Center_NQA_version_platform.zip
Installation package for NQA dialing test management.
STM
Optional.
·     network (NSM_FCAPS-Perf_version_platform.zip)
U-Center_NQA_Collector_version_platform.zip
Installation package for the NQA dialing test collector.
STM
Optional.
U-Center_AOM_PLAT_version_platform.zip
Installation package for the basic function service.
AOM
Optional.
·     gluster (UDTP_GlusterFS_version_platform.zip)
U-Center_AOM_CCMS_version_platform.zip
Installation package for CCMS.
AOM
Optional.
·     U-Center_AOM_PLAT_version_platform.zip
U-Center_AOM_INI_version_platform.zip
Installation package for INI.
AOM
Optional.
U-Center_AOM_IPMS_version_platform.zip
Installation package for IPMS.
AOM
Optional.
U-Center_AOM_PROBE_version_platform.zip
Installation package for the collection client Web service
AOM
Optional.
·     U-Center_AOM_PLAT_version_platform.zip (not dependent on this installation package for deployment through application deployment)
Server requirements
You can contact Technical Support for hardware configuration evaluation.
Table 4 Available Operating systems
Architecture
Operating system
x86
H3Linux V1.1.2
H3Linux V2.0.2
Red Hat Enterprise Linux 7.6
Community Enterprise Operating System 7.6
Red Hat Enterprise Linux 8.4
Red Hat Enterprise Linux 8.6
Kylin-Server-10-SP2-x86-RC01-Build09-20210524.iso
ARM
H3Linux V2.0.2
Kylin-Server-10-SP2-aarch64-RC01-Build09-20210524.iso
IMPORTANT
IMPORTANT:
·     You must install the same operating system version on all nodes in a cluster.
·     Support for the x86 and ARM installation packages varies by component and version. For more information, see the release notes.
Client requirements
You can use a browser to access U-Center 2.0 without installing client software. As a best practice, use Google Chrome 70 or Firefox 78 or higher with a minimum resolution width of 1600 pixels.
Table 5 shows the check list for the installation requirements. Make sure the U-Center 2.0 installation requirements are met.
Table 5 Pre-installation checklist
Item
Requirements
Server or VM
Hardware
The CPU, memory, disk, and NIC settings are as required.
Software
·     The operating system meets the requirements.
·     The system time settings are configured correctly. As a best practice, configure NTP on each node to ensure time synchronization on the network, and make sure the NTP server time is the same as the current time.
·     RAID is configured.
Client
Make sure the browser version meets the requirement.
Server and OS compatibility
To view the compatibility matrix between H3C servers and
operating systems, click http://www.h3c.com/en/home/qr/default.htm?id=65
CAUTION
CAUTION:
·     During the U-Center 2.0 deployment process, do not enable or disable firewall services.
·     To avoid exceptions, do not modify the system time after cluster deployment.
IMPORTANT
IMPORTANT:
·     As a best practice, set the mode to UEFI for the next startup of the server or VM. Select EFI from the boot firmware list. Do not select Enable UEFI secure boot for the VM.
·     Do not use KVM to install the same image for multiple servers when installing an operating system.
·     H5 KVM is unstable in performance and issues such as slow or unsuccessful image loading might occur during installation. As a best practice, use Java KVM to mount the image and install the operating system.
·     A power failure during the installation process might cause installation failure of some service components. For function integrity, perform a reinstallation when a power failure occurs during installation.
·     Do not enable or disable firewalls during the U-Center 2.0 deployment.
·     To avoid cluster exceptions, do not edit the system time after the completion of cluster deployment.
Before installing the software, first perform MD5 verification on each software package to ensure its integrity and correctness.
Before deploying U-Center 2.0, first deploy Unified Platform and then deploy U-Center 2.0 components on Unified Platform.
To deploy Unified Platform:
1.     Install the operating system and dependencies.
2.     Install Matrix.
3.     Create a cluster and configure cluster parameters.
4.     Deploy Unified Platform components.
For more information about the deployment procedure, see H3C Unified Platform Deployment Guide.
CAUTION
CAUTION:
U-Center 2.0 components (IOM, CMDB, BSM, STM, ITSM, AOM, NTA, and NSM) of version E0715 and later must be installed on the convergence deployment page.
1.     In the address bar of the browser, enter https://ip_address:8443/matrix/ui to log in to Matrix.
The default username is admin and the default password is Pwd@12345. If the operating system password has been set, enter the set password. The ip_address parameter specifies the northbound service VIP.
2.     On the top navigation bar, click DEPLOY.
3.     From the navigation pane, select Convergence Deployment.
4.     Click Install to access the page for uploading installation packages. On this page, you can upload and delete installation packages for convergence deployment.
The list displays the names, versions, sizes, creation time, and other information of the uploaded installation packages for convergence deployment.
5.     Click Upload. In the window that opens, click Select Files, and upload installation packages.
You can bulk upload application installation packages.
When you install U-Center 2.0, follow these restrictions and guidelines:
·     After accessing the installation package uploading page for convergence deployment, see the following sections for the specific deployment procedures of each component in U-Center 2.0.
·     On the convergence deployment page, you can view, expand, upgrade, and perform other operations on the specified applications.
·     If the components that have been installed through application deployment do not support convergence deployment, perform the following tasks before performing operations such as viewing details, expanding, and upgrading:
a.     Upload the convergence deployment packages of the related application components.
b.     After the upload is completed, click Data Synchronization to synchronize the data from the Applications page to the Convergence Deployment page.
·     Middle, GlusterFS, Core, and IMonitor are required installation packages for Unified Platform. If the packages have been installed during Unified Platform deployment, you do not need to install them again.
·     If you want to use the upper-level and lower-level functions, install BMP_Region_version_platform.zip.
·     You can select and install all of the following packages simultaneously: UCP, COLLECTPLAT, IOM, ADDM, and AGENT.
·     You can select and install all of the following packages simultaneously: BSM, UEM, ITSM, and VDI. NTA and ITSM require a separate installation and cannot be selected simultaneously with other packages.
·     NTA requires installation of the NTA, NSM_FCAPS-Res, UCP, and CLICKHOUSE packages, which must be installed in the following order: NSM_FCAPS-Res, UCP, CLICKHOUSE, and NTA.
·     To install AOM, first install the AOM_PLAT component, and then install the other components in any order. IPMS, INI, CCMS, and PROBE can be installed at different steps. In a scenario with low performance or low disk read or write speed, install them in multiple steps.
·     You can select the number of probes for AOM as needed. Select a minimum of one collector. As a best practice, add one collector for every 400 devices.
·     To use HTTPS, log in to Unified Platform after the applications and components are installed and then select System > System Settings > Security Settings to enable HTTPS.
·     After completing installation package upload, the system automatically synchronizes the installation packages to the following directory of each node: /opt/matrix/app/install/packages/
The installation packages listed as IOM in the Product Package column in Table 3 are IOM component-related installation packages. You can deploy the installation package as needed.
To deploy the IOM component:
1.     After accessing the installation package uploading page for convergence deployment, upload the convergence deployment packages to be deployed. Take U-Center_IOM_version_platform.zip as an example.
2.     Click Next.
3.     On the application selection page, all application groups are selected by default, which contain applications of Unified Platform and other components. Select application groups as needed.
¡     All: Related applications of Unified Platform and all other components.
¡     U-Center Scenario: Related applications of Unified Platform and U-Center components.
4.     In the U-Center scenario area, select the applications to be deployed.
If you select an application with dependent applications, its dependent applications will be automatically selected. If a dependent application is not deployed or not included in the current installation package, the system will prompt relevant information.
5.     Click Next to access the package selection page, and select the convergence deployment packages to be installed.
The system will verify the packages.
6.     After verification, click Next to access the parameter configuration page. Configure the parameters as needed.
¡     Resource Scale: Select the deployment scale. Options include small, medium, large, and default.
7.     Click Deploy. In the dialog box that opens, confirm the applications to be installed.
8.     After confirmation, click OK to start deployment.
The installation packages listed as CMDB in the Product Package column in Table 3 are CMDB component-related installation packages. You can deploy the installation package as needed.
To deploy the CMDB component:
1.     After accessing the installation package uploading page for convergence deployment, upload the convergence deployment packages to be deployed. Take U-Center_CMDB_2.0_version_platform.zip as an example.
2.     Click Next.
¡     Bind deployment nodes: Select the nodes for deployment.
The installation packages listed as BSM in the Product Package column in Table 3 are BSM component-related installation packages. You can deploy the installation package as needed.
To deploy the BSM component:
1.     After accessing the installation package uploading page for convergence deployment, upload the convergence deployment packages to be deployed. Take U-Center_BSM_version_platform.zip as an example.
2.     Click Next.
The installation packages listed as ITSM in the Product Package column in Table 3 are ITSM component-related installation packages. You can deploy the installation package as needed.
To deploy the ITSM component:
1.     After accessing the installation package uploading page for convergence deployment, upload the convergence deployment packages to be deployed. Take U-Center_ITSM_version_platform.zip as an example.
2.     Click Next.
The installation packages listed as NTA in the Product Package column in Table 3 are NTA component-related installation packages. You can deploy the installation package as needed.
To deploy the NTA component:
1.     After accessing the installation package uploading page for convergence deployment, upload the convergence deployment packages to be deployed. Take U-Center_NTA_version_platform.zip as an example.
2.     Click Next.
The installation packages listed as AOM in the Product Package column in Table 3 are AOM component-related installation packages. You can deploy the installation package as needed.
1.     After accessing the installation package uploading page for convergence deployment, upload the convergence deployment packages to be deployed. Take U-Center_AOM_PLAT_version_platform.zip as an example.
2.     Click Next.
The installation packages listed as STM in the Product Package column in Table 3 are STM component-related installation packages. You can deploy the installation package as needed.
1.     After accessing the installation package uploading page for convergence deployment, upload the convergence deployment packages to be deployed. Take U-Center_STM_version_platform.zip as an example.
2.     Click Next.
1.     Enter the URL of U-Center 2.0 http://ip_address:30000 in your browser. Replace ip_address with the northbound service VIP. The default port number is 30000. Figure 1 shows the login page.
Figure 1 U-Center 2.0 login page
2.     Enter the username and password, and then click Login.
The default username is admin and the default password is Pwd@12345. If you have set the password when installing the operating system, enter the set password.
After you deploy U-Center 2.0, you must obtain licenses to use it. If you have purchased the product, obtain the relevant license key to complete the consequent registration process. To obtain a trial license, contact relevant H3C marketing personnel.
For more information about requesting and installing licenses, see H3C Software Products Remote Licensing Guide.
License support
The license server and U-Center 2.0 are one-to-one related. A license server can be used by only one U-Center 2.0.
Table 6 describes the licenses for each component of U-Center 2.0.
Table 6 NSM licenses
Component
License description
Product code
Product description
NSM
Network basic license
LIS-IMC9-NSM
H3C iMC9.0, Intelligent Management Center License
Network quantity license
LIS-IMC9-NSMA-25
H3C iMC9.0, Intelligent Management Platform (Network Management), 25 Licenses
LIS-IMC9-NSMB-50
H3C iMC9.0, Intelligent Management Platform (Network Management), 50 Licenses
LIS-IMC9-NSMC-100
H3C iMC9.0, Intelligent Management Platform (Network Management), 100 Licenses
LIS-IMC9-NSMD-200
H3C iMC9.0, Intelligent Management Platform (Network Management), 200 Licenses
LIS-IMC9-NSME-500
H3C iMC9.0, Intelligent Management Platform (Network Management), 500 Licenses
LIS-IMC9-NSMF-1K
H3C iMC9.0, Intelligent Management Platform (Network Management), 1000 Licenses
Table 7 U-Center 2.0 licenses
Component
License description
Product code
Product description
CMDB
U-Center basic license
LIS-UCENTER2-IOP
H3C U-Center2.0, Intelligent Operations Platform Software
CMDB basic license
LIS-UCENTER2-CMDB
H3C U-Center2.0, CMDB License
CMDB quantity license
LIS-UCENTER2-CMDB-25
H3C U-Center2.0, CMDB, 25 Licenses
LIS-UCENTER2-CMDB-50
H3C U-Center2.0, CMDB, 50 Licenses
LIS-UCENTER2-CMDB-100
H3C U-Center2.0, CMDB, 100 Licenses
LIS-UCENTER2-CMDB-200
H3C U-Center2.0, CMDB, 200 Licenses
LIS-UCENTER2-CMDB-500
H3C U-Center2.0, CMDB, 500 Licenses
LIS-UCENTER2-CMDB-1K
H3C U-Center2.0, CMDB, 1000 Licenses
LIS-UCENTER2-CMDB-1
H3C U-Center2.0, CMDB, 1 License
LIS-UCENTER2-CMDB-100-A
Report
Report
LIS-UCENTER2-IOM-IAR
H3C U-Center2.0, IOM, Intelligent Analysis Report License
IOM
IOM basic license
LIS-UCENTER2-IOM
H3C U-Center2.0, IOM Licenses
IOM quantity license
LIS-UCENTER2-IOM-25
H3C U-Center2.0, IOM, 25 Licenses
LIS-UCENTER2-IOM-50
H3C U-Center2.0, IOM, 50 Licenses
LIS-UCENTER2-IOM-100
H3C U-Center2.0, IOM, 100 Licenses
LIS-UCENTER2-IOM-200
H3C U-Center2.0, IOM, 200 Licenses
LIS-UCENTER2-IOM-500
H3C U-Center2.0, IOM, 500 Licenses
LIS-UCENTER2-IOM-1K
H3C U-Center2.0, IOM, 1000 Licenses
LIS-UCENTER2-IOM-1
H3C U-Center2.0, IOM, 1 License
LIS-UCENTER2-IOM-100-A
BSM
BSM basic license
LIS-UCENTER2-BSM
H3C U-Center2.0, BSM License
BSM quantity license
LIS-UCENTER2-BSM-1
H3C U-Center2.0, BSM, 1 License
LIS-UCENTER2-BSM-5
H3C U-Center2.0, BSM, 5 Licenses
LIS-UCENTER2-BSM-10
H3C U-Center2.0, BSM, 10 Licenses
UEM quantity license
LIS-UCENTER2-BSM-UEM-1-B
H3C U-Center2.0, BSM, UEM, 1 License
LIS-UCENTER2-BSM-UEM-2
H3C U-Center2.0, BSM, UEM, 2 License
LIS-UCENTER2-BSM-UEM-5
H3C U-Center2.0, BSM, UEM, 5 License
NTA
NTA basic license
LIS-UCENTER2-IOM-NTA
H3C U-Center2.0, IOM, Network Traffic Analyzer License
NTA quantity license
LIS-UCENTER2-IOM-NTA-1-B
H3C U-Center2.0, IOM, Network Traffic Analyzer, 1 License
LIS-UCENTER2-IOM-NTA-2
H3C U-Center2.0, IOM, Network Traffic Analyzer, 2 License
LIS-UCENTER2-IOM-NTA-5
H3C U-Center2.0, IOM, Network Traffic Analyzer, 5 License
ITSM
ITSM basic license
LIS-UCENTER2-ITSM
H3C U-Center2.0, ITSM License
ITSM quantity license
LIS-UCENTER2-ITSM-1
H3C U-Center2.0, ITSM, 1 License
LIS-UCENTER2-ITSM-5
H3C U-Center2.0-ITSM-5 License
LIS-UCENTER2-ITSM-10
H3C U-Center2.0-ITSM-10 License
LIS-UCENTER2-ITSM-20
H3C U-Center2.0-ITSM-20 License
LIS-UCENTER2-ITSM-50
H3C U-Center2.0-ITSM-50 License
LIS-UCENTER2-ITSM-100
H3C U-Center2.0-ITSM-100 License
ITSM change release management license
LIS-UCENTER2-ITSM-CRM
H3C U-Center2.0, ITSM, Change and Release Management License
ITSM service level management basic license
LIS-UCENTER2-ITSM-SLM
H3C U-Center2.0, ITSM, Service Level Management License
ITSM knowledge base license
LIS-UCENTER2-ITSM-KB
H3C U-Center2.0, ITSM, Knowledge Base License
ITSM self-service platform license
LIS-UCENTER2-ITSM-SSD
H3C U-Center2.0, ITSM, Self-Service Desk License
AOM
IP address management
LIS-UCENTER-AOM-IPMS-50
H3C UCenter, AOM, IP Address Management System, 50 Licenses
LIS-UCENTER-AOM-IPA-100
H3C UCenter, AOM, IP Address Management System, 100 Licenses
LIS-UCENTER-AOM-IPA-200
H3C UCenter, AOM, IP Address Management System, 200 Licenses
LIS-UCENTER-AOM-IPA-500
H3C UCenter, AOM, IP Address Management System, 500 Licenses
LIS-UCENTER-AOM-IPA-1000
H3C UCenter, AOM, IP Address Management System, 1000 Licenses
LIS-UCENTER2-AOM-IPA-1
H3C U-Center2.0, AOM, IP Address Management System, 1 License
LIS-UCENTER2-AOM-IPA-100-A
H3C U-Center2.0, AOM, IP Address Management System, 100 Licenses
Configuration and compliance intelligent management license
LIS-UCENTER-AOM-CCI-50-2
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 50 Licenses
LIS-UCENTER-AOM-CCI-100-2
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 100 Licenses
LIS-UCENTER-AOM-CCI-200-2
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 200 Licenses
LIS-UCENTER-AOM-CCI-500-2
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 500 Licenses
LIS-UCENTER-AOM-CCI-1000-2
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 1000 Licenses
LIS-UCENTER2-AOM-CCI-1
H3C U-Center2.0, AOM, Configuration And Compliance Intelligent Management, 1 License
LIS-UCENTER2-AOM-CCI-100-A
H3C U-Center2.0, AOM, Configuration And Compliance Intelligent Management, 100 Licenses
Intelligent inspection
LIS-UCENTER-AOM-IIE-50
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 50 Licenses
LIS-UCENTER-AOM-IIE-100
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 100 Licenses
LIS-UCENTER-AOM-IIE-200
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 200 Licenses
LIS-UCENTER-AOM-IIE-500
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 500 Licenses
LIS-UCENTER-AOM-IIE-1000
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 1000 Licenses
LIS-UCENTER2-AOM-IIE-1
H3C U-Center2.0, AOM, Intelligent Inspection Expert Provider Edition, 1 License
LIS-UCENTER2-AOM-IIE-100-A
H3C U-Center2.0, AOM, Intelligent Inspection Expert Provider Edition, 100 Licenses
STM
STM quantity license
LIS-UCENTER2-IOM-STM-1
H3C U-Center2.0, IOM, STM, 1 License
STM license
H3C U-Center2.0, IOM, STM License
For more information about license request and installation, see H3C Software Products Remote Licensing Guide. After importing a license file to the H3C license management system, configure U-Center 2.0 as the license client to access the license server.
Creating a license client
1.     Log in to the license server, and navigate to the Configuration > License Clients page.
2.     Click Add. On the page that opens, configure the client name and password.
3.     Click OK.
Configuring the client connection
This function allows you to connect the client to the license server to obtain licenses.
1.     Log in to U-Center 2.0.
2.     Navigate to the System > License Management > License Information page.
3.     In the License Server Info area, configure the following parameters of the license server, and then click Connect:
¡     Address—Specify the IP address of the license server.
¡     Port Number—Enter the service port number of the license server. The default value is 5555.
¡     Username—Enter the client name configured on the license server.
¡     Password—Enter the client password configured on the license server.
4.     You can obtain the license if the client is connected to the license server. When the connection status is Connected, click Refresh in 5 minutes to view the latest license information.
IMPORTANT
IMPORTANT:
·     To avoid failure to connect to the license server, make sure the firewall is disabled for the license server when you start the client service.
·     To obtain licenses successfully, make sure the license server has available licenses when you start the client service.
Viewing the license usage
1.     Log in to the license server.
2.     Navigate to the Clients > Client Connections page.
On the page that opens, you can view and manage clients connected to the license server.
To bulk disconnect clients from the license server, select them and then click Bulk Disconnect. To disconnect all clients, click Disconnect All.
To reclaim all licenses from a client, click Details in the Actions column for the client and then click Reclaim All on the page that opens. To reclaim a license from the client, click Reclaim for the license.
You can back up and restore configuration for U-Center 2.0 components on Unified Platform. For more information, see H3C Unified Platform Deployment Guide.
On Unified Platform, you can recover the cluster when a failure occurs. For more information, see H3C Unified Platform Deployment Guide.
CAUTION
CAUTION:
U-Center 2.0 components (IOM, CMDB, BSM, STM, ITSM, AOM, NTA, and NSM) of version E0715 and later must be upgraded on the convergence deployment page.
·     Before upgrade, you must back up your data.
·     Before upgrading U-Center 2.0, upgrade Matrix and Unified Platform to the corresponding version. For more information about upgrading Matrix and Unified Platform, see H3C Unified Platform Deployment Guide.
·     Before upgrade, first clear the browser cache and sessions.
·     Follow the installation sequence of application packages to upgrade the applications.
4.     Click Install. The installation package-uploading page opens.
5.     Click Upload, select Choose File in the pop-up window, and then upload the installation packages for convergence deployment. You can upload multiple application packages in bulk.
6.     After the uploading is complete, click Cancel to return to the convergence deployment page.
7.     Click Data Synchronization. The components to be upgraded are displayed in the list.
8.     Click the  icon in the Actions column for a component to be upgraded to access the upgrade page.
9.     Select the installation packages to be upgraded.
If a selected installation package does not meet the dependencies and version verification of the current application, the system will prompt an error.
10.     After selecting the installation packages that comply with the upgrade rules, click Upgrade to proceed with upgrade and deployment.
After you uninstall and reinstall U-Center 2.0, you must clear the content in the /var/lib/ssdata/ directory on each node.
To retain the component configuration and data, use the backup function before uninstallation. For more information about the backup function, see "Backing up and restoring the configuration."
4.     Select the applications to be uninstalled in the list, and click Uninstall.
·     The system supports bulk uninstallation.
·     If other applications depend on the application to be uninstalled, the system will also select all applications that depend on the application to ensure the integrity of the application operation. In this case, you cannot uninstall the application separately.
·     If no application depends on the selected application, you can uninstall the application separately.
5.     In the confirmation dialog box that opens, click OK.
CAUTION
CAUTION:
Uninstalling a single component or application might affect the operation of other components or applications. Uninstall applications with caution. For the application dependencies, see "Installation packages."
To uninstall an application through application deployment:
1.     Enter https://ip_address:8443/matrix/ui in the browser to log in to Matrix. Replace ip_address with the northbound service VIP.
3.     From the navigation pane, select Applications.
4.     Click the  icon in the Actions column for an application.
5.     In the dialog box that opens, click OK.
1.     In the address bar of the browser, enter http://ip_address:30000. Then, enter the username and password.
¡     Both HTTP and HTTPS are supported. The default protocol is HTTP and the default port number is 30000. If the protocol and port number have been set, enter the set protocol and port number.
¡     The default username and password are admin and Pwd@12345, respectively. If the username and password have been set, enter the set username and password.
2.     Navigate to the System > Backup & Restore page.
3.     Manually back up the configuration and save the backup files locally.
For more information about the backup procedure and restrictions and guidelines, see the online help and configuration backup and restoration in H3C Unified Platform Deployment Guide.
Perform this task to shut down and power off one or multiple nodes to ensure that the system is still operating correctly when U-Center is deployed in cluster mode. This task applies to scenarios such as software upgrade and hardware replacement for nodes and routine inspection.
To shut down and power off part of nodes:
1.     In the address bar of the browser, enter https://ip_address:8443/matrix/ui to log in to Matrix. Then, enter the username, password, and verification code.
The default username and password are admin and Pwd@12345, respectively. If the Matrix username and password has been set, enter the set username and password.
2.     Navigate to the DEPLOY > Clusters > Deploy Cluster page, select a node. To shut down and power off multiple nodes, disable these nodes one by one. That is, perform operations on a node only after the operations such as backup and restoration have been completed on another node.
3.     To disable a node, click the set icon in the upper right corner of the node and click Disable.
4.     After a node is disabled, execute the shutdown -h now command to shut down the node.
5.     Before you power off a node, make sure the node power status is off on HDM or the power LED of the node indicates that the node is in standby state.
Perform this task to shut down and power off the system. This task applies to scenarios such as emergency power outages and equipment room relocations.
To shut down and power off all nodes:
2.     Navigate to the DEPLOY > Clusters > Deploy Cluster page. Disable all master nodes in the cluster.
Starting servers
1.     Power on and start up servers.
2.     After the servers start up, execute the ip addr command to verify that the nodes and the service networks are up.
3.     Verify network connectivity. Make sure a node can reach the other nodes in different network segments and the client can reach the service networks of all nodes in the cluster.
1.     Access Matrix from the browser.
2.     Navigate to the DEPLOY > Clusters > Deploy Cluster page, and then enable nodes.
Wait for about 30 minutes. The actual waiting time might vary by data volume being processed.
3.     On the top navigation pane, click DASHBOARD to view system operation statistics to identify whether the system service has started up.
4.     On the top navigation pane, click OBSERVE to view workload information about Pods.
1.     Access U-Center from the browser.
3.     Verify that the license information is synchronized from the license server and the authorization status is normal.
4.     Verify that the features of U-Center are operating correctly.
FAQ
How can I prepare a disk partition for GlusterFS on a node?
Prepare a disk partition for GlusterFS on each node in the cluster, and record the disk partition name for future use.
To prepare a disk partition for GlusterFS on a node, perform one of the following tasks:
Manually create a new disk partition
1.     Reserve sufficient disk space for GlusterFS when you install the operating system.
2.     After the operating system is installed, execute the fdisk command to create a disk partition.
Figure 2 gives an example of how to create a 250 GB disk partition /dev/sda7 on disk sda. If the system fails to obtain the partition list, execute the reboot command to restart the node.
Figure 2 Creating a disk partition
Use an existing disk partition
If an existing disk partition with 250 GB or more capacity has not been used or mounted, you can clear the disk partition and use it for GlusterFS, for example, /dev/sda7 as shown in Figure 3. To clear the disk partition, execute the wipefs -a /dev/sda7 command.
Figure 3 Disk partition information
Prepare an independent disk for GlusterFS
Execute the wipefs -a command to clear the disk before using it for GlusterFS.
Figure 4 Clearing disk
I have activated IOM basic and quantity licenses, but the application incorporation fails. An error massage is displayed that the number of monitors exceeds license limit. Why does this happen?
IOM depends on COLLECTPLAT. You need to activate CMDB quantity license of COLLECTPLAT.
Is there any additional information that I should pay attention to?
After the IOP license (H3C U-Center2.0, Intelligent Operations Platform Software) is registered, two license names, UCENTER-UCENTER-UCD and UCENTER-UCENTER2, are generated.
How can I manually modifying the ES values in the back end?
1.     Execute the kubectl edit sts elasticsearch-node-1 -n service-software command.
2.     Locate ES_JAVA_OPTS in the env entry, and change its value to -Xms8g -Xmx8g, where 8g can be adjusted as needed. Make sure the value following Xms is the same as that following Xmx.
3.     Locate memory in the limits entry, and change its value from 2G to 12G. You can adjust the value 12G as needed. Make sure the value is at least 3G greater than the value following Xms or Xmx.
4.     Save the configuration and exit.
5.     Execute the kubectl edit sts elasticsearch-node-2 -n service-software command. Repeat steps 2 through 4.
6.     Execute the kubectl edit sts elasticsearch-node-3 -n service-software command. Repeat steps 2 through 4.
7.     After modification, enter any elasticsearch pod, and execute the curl ‘elasticsearch-http-service:9200/_cat/health?v’ command to view the cluster state. When the status is green or yellow in the returned value, the cluster is available. If a large amount of data exist, ES takes a certain period of time to restore data after you complete the preceding steps.
How can I identify the enabling status for the RAID controller cache policies when configuring a RAID array for servers if the IOPS of a disk is as low as 1k?
When configuring a RAID array for servers, you must enable the RAID controller cache policies. Table 8 shows only some parameters in the RAID configuration. In the actual configuration, see the storage controller user guide for the corresponding server model.
Table 8 Parameters
Parameter
Array Label
Name of the RAID array. The default is DefaultValue0.
Stripe Size
Strip size, which determines the data block size of a stripe on each drive.
Array Size Selection
RAID array capacity.
Read Cache
Read cache policy status. Options include Enabled and Disabled.
Write Cache
Write cache policy status. Options include:
·     Enable Always—Always enables the write cache. Without a supercapacitor installed, this status might cause data loss if power supply fails.
·     Enable With Backup Unit—Disables the write cache when the supercapacitor is absent or not ready.
·     Disabled—Disables the write cache.
Create RAID via
Operation after the RAID array is created. Options include Quick Init, Skip Init, Build/Verify, and Clear.
