| 00-Preface | 78.77 KB |
Preface
This deployment guide describes how to deploy U-Center 2.0. It contains the following chapters:
· Overview. This document mainly describes the deployment method for U-Center 2.0.
· U-Center 2.0 deployment procedure at a glance. This chapter describes the deployment procedure for U-Center 2.0.
· Preparing for deployment. This chapter describes the configuration requirements to be validated before deployment and the installation files to be prepared.
· Installing U-Center 2.0. This chapter describes the installation of the operating system and dependencies, the method of creating a Matrix cluster, and the installation of application packages.
· Logging in to U-Center 2.0. This chapter describes the method for logging in to U-Center 2.0.
· Registering the software. This chapter describes the procedure of requesting and installing licenses for U-Center 2.0.
· Backup and recovery. This chapter describes how to back up and recover data for U-Center 2.0 components.
· Cluster disaster recovery. This chapter describes the method of cluster disaster recovery.
· Upgrading U-Center 2.0. This chapter describes how to upgrade U-Center 2.0.
· Shutting down and powering off servers. This chapter describes the method of powering off nodes normally.
· Starting servers. This chapter describes the method of powering on nodes.
· Uninstalling U-Center 2.0. This chapter describes the procedure for uninstalling U-Center 2.0.
· FAQ. This chapter describes the frequently asked questions and their answers.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the Unified Platform.
Conventions
GUI conventions
Convention |
Window names, button names, menu items, field values |
Window names, button names, menu items, and field values are in bold text. |
Multi-level menus |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
