03-Layer 2—LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6800 & S6860 Switch Series Command References-Release 6715-6W10003-Layer 2—LAN Switching Command Reference
10-QinQ commands
10-QinQ commands 78.70 KB
QinQ commands
This document uses the following terms:
·     CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
·     SVLAN—Service provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
display qinq
Use display qinq to display QinQ-enabled interfaces.
display qinq [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays all QinQ-enabled interfaces.
If QinQ is not enabled on any interfaces, this command does not provide any output.
# Enable QinQ on Ten-GigabitEthernet 1/0/1. Then, verify that QinQ is enabled on the interface.
[Sysname-Ten-GigabitEthernet1/0/1] qinq enable
[Sysname-Ten-GigabitEthernet1/0/1] display qinq interface ten-gigabitethernet 1/0/1
# Enable QinQ on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/3. Then, verify that QinQ is enabled on the interfaces.
[Sysname] interface ten-gigabitethernet 1/0/3
[Sysname-Ten-GigabitEthernet1/0/3] qinq enable
[Sysname-Ten-GigabitEthernet1/0/3] display qinq
qinq enable
qinq enable
Use qinq enable to enable QinQ on an interface.
Use undo qinq enable to disable QinQ on an interface.
qinq enable
undo qinq enable
QinQ is disabled on interfaces.
display qinq
qinq ethernet-type (interface view)
Use qinq ethernet-type to set the TPID value in SVLAN tags on an interface.
Use undo qinq ethernet-type to restore the default TPID value in SVLAN tags on an interface.
qinq ethernet-type service-tag hex-value
undo qinq ethernet-type service-tag
The TPID value in SVLAN tags is 8100 in hexadecimal notation.
service-tag: Sets the TPID value in the SVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 1 to ffff, excluding the reserved EtherType values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86dd
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
LLDP
0x88cc
802.1X
0x888e
802.1ag
0x8902
Cluster
0x88a7
Reserved
0xfffd/0xfffe/0xffff
A port without QinQ enabled uses the SVLAN TPID to match incoming tagged frames. The port modifies the TPID in the SVLAN tag of outgoing frames as the configured value.
# Set the TPID value in SVLAN tags to 9100 (hexadecimal) on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qinq ethernet-type service-tag 9100
qinq ethernet-type (system view)
Use qinq ethernet-type to set the TPID value in CVLAN tags.
Use undo qinq ethernet-type to restore the default TPID value in CVLAN tags.
qinq ethernet-type customer-tag hex-value
undo qinq ethernet-type customer-tag
The TPID value in CVLAN tags is 8100 in hexadecimal notation.
customer-tag: Sets the TPID value in the CVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 1 to ffff, excluding the reserved EtherType values listed in Table 2.
Table 2 Reserved EtherType values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86dd
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
LLDP
0x88cc
802.1X
0x888e
802.1ag
0x8902
Cluster
0x88a7
Reserved
A QinQ-enabled port uses the CVLAN TPID to match incoming tagged frames. An incoming frame is handled as untagged if its TPID is different from the CVLAN TPID.
# Set the TPID value in CVLAN tags to 8200 (hexadecimal).
[Sysname] qinq ethernet-type customer-tag 8200
qinq transparent-vlan
Use qinq transparent-vlan to enable transparent transmission for a list of VLANs on a port.
Use undo qinq transparent-vlan to disable transparent transmission for a list of VLANs on a port.
qinq transparent-vlan vlan-id-list
undo qinq transparent-vlan { vlan-id-list | all }
Transparent transmission is disabled for all VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a single VLAN ID or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The end VLAN ID must be equal to or greater than the start VLAN ID.
all: Specifies all VLANs.
By default, QinQ tags all incoming frames with the PVID on a port. This command disables QinQ to tag incoming traffic from a list of VLANs. These VLANs are called transparent VLANs.
You can repeat this command to add VLANs to the list of transparent VLANs.
To ensure successful transmission for a transparent VLAN, follow these configuration guidelines:
·     Set the link type of the port to trunk or hybrid, and assign the port to the transparent VLAN.
·     Do not configure any other VLAN manipulation actions for the transparent VLAN on the port.
·     Make sure all ports on the traffic path permit the transparent VLAN to pass through.
·     If you use both transparent VLANs and VLAN mappings on an interface, the transparent VLANs cannot be the following VLANs:
¡     Original or translated VLANs in one-to-one, many-to-one, or one-to-two VLAN mappings.
¡     Original or translated VLANs in two-to-one VLAN mappings.
¡     Original or translated outer VLANs in two-to-two VLAN mappings.
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port, and assign the port to VLAN 2, VLAN 3, and VLANs 50 through 100. Enable QinQ on Ten-GigabitEthernet 1/0/1, and configure the port to transparently transmit frames from VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] port link-type trunk
[Sysname-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2 3 50 to 100
[Sysname-Ten-GigabitEthernet1/0/1] qinq transparent-vlan 2
