03-Layer 2—LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6800 & S6860 Switch Series Command References-Release 6715-6W10003-Layer 2—LAN Switching Command Reference
01-MAC address table commands
01-MAC address table commands 214.38 KB
This document covers the configuration of unicast MAC address entries, including static, dynamic, blackhole, and multiport unicast MAC address entries. For more information about configuring static multicast MAC address entries, see IGMP snooping and IPv6 multicast routing and forwarding in IP Multicast Configuration Guide. For more information about MAC address table configuration in VPLS, see MPLS Configuration Guide.
display mac-address
Use display mac-address to display MAC address entries.
display mac-address [ mac-address [ vlan vlan-id ] | [ [ dynamic | static ] [ interface interface-type interface-number ] | blackhole | multiport ] [ vlan vlan-id ] [ count ] | nickname nickname ]
mac-address: Specifies a MAC address in the format of H-H-H. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter f-e2-1 for 000f-00e2-0001.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
dynamic: Displays dynamic MAC address entries.
static: Displays static MAC address entries.
blackhole: Displays blackhole MAC address entries.
multiport: Displays multiport unicast MAC address entries.
count: Displays only the number of MAC address entries that match all entry attributes you specify in the command. Detailed information about MAC address entries is not displayed. For example, you can use the display mac-address vlan 20 dynamic count command to display the number of dynamic entries for VLAN 20. If you do not specify an entry attribute, the command displays the number of entries in the MAC address table. If you do not specify this keyword, the command displays detailed information about the specified MAC address entries.
nickname nickname: Specifies an egress RB by its nickname. The value range for the nickname argument is 1 to fffe in hexadecimal format.
A MAC address entry includes a destination MAC address, an outgoing interface, and a VLAN ID.
If you do not specify any parameters, the command displays all MAC address entries.
This command displays dynamic MAC address entries for an aggregate interface only when the aggregate interface has a minimum of one Selected member port.
Multiport unicast MAC address entries have no impact on the MAC address learning. When receiving a frame whose source MAC address matches a multiport unicast entry, the device can still learn the MAC address of the frame and generate a dynamic entry. However, the generated dynamic entry has lower priority. The device prefers to use the multiport unicast entry to forward frames destined for the MAC address in the entry.
# Display MAC address entries for VLAN 100.
<Sysname> display mac-address vlan 100
MAC Address      VLAN ID    State            Port/Nickname            Aging
0001-0101-0101   100        Multiport        XGE1/0/1                 N
                                             XGE1/0/2
0033-0033-0033   100        Blackhole        N/A                      N
0000-0000-0002   100        Static           XGE1/0/3                 N
00e0-fc00-5829   100        Learned          XGE1/0/4                 Y
# Display the number of MAC address entries.
<Sysname> display mac-address count
1 mac address(es) found.
# Display the MAC address entries of the egress RB with the nickname 0x8c81.
<Sysname> display mac-address nickname 8c81
0000-3300-0001   10         Learned          0x8c81                   Y
0000-3300-0002   10         Learned          0x8c81                   Y
0000-3300-0003   10         Learned          0x8c81                   Y
VLAN ID
ID of the VLAN to which the outgoing interface of the MAC address entry belongs.
MAC address entry state:
·     Static—Static MAC address entry.
·     Learned—Dynamic MAC address entry. Dynamic entries can be learned or manually configured.
·     Blackhole—Blackhole MAC address entry.
·     Multiport—Multiport unicast MAC address entry.
·     OpenFlow—MAC address entry for an OpenFlow instance.
·     Block—MAC address entry for a user who failed MAC authentication.
·     Security—MAC address entry configured or learned by port security.
·     M-LAG—MAC address entry learned by an M-LAG peer device and synchronized to the local end.
Port/Nickname
When the field displays an interface name, the field indicates the outgoing interface for packets that are destined for the MAC address. This field displays N/A for a blackhole MAC address entry.
When the field displays a 16-bit number in hexadecimal format (for example, 0x12ab), it indicates the RB through which the packets leave the TRILL network. For information about RBs and TRILL, see TRILL Configuration Guide.
Aging
Whether the entry can age out:
·     Y—The entry can age out.
·     N—The entry never ages out.
Number of matching MAC address entries.
mac-address
mac-address timer
display mac-address aging-time
Use display mac-address aging-time to display the aging timer for dynamic MAC address entries.
# Display the aging timer for dynamic MAC address entries.
<Sysname> display mac-address aging-time
MAC address aging time: 300s.
mac-address timer
display mac-address mac-learning
Use display mac-address mac-learning to display the global MAC address learning status and the MAC learning status of the specified interface or all interfaces.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays the global MAC address learning status and the MAC address learning status of all interfaces.
# Display the global MAC address learning status and the MAC learning status of all interfaces.
<Sysname> display mac-address mac-learning
Global MAC address learning status: Enabled.
Port                         Learning Status
XGE1/0/1                     Enabled
XGE1/0/2                     Enabled
·     Enabled.
·     Disabled.
Learning Status
MAC address learning status of an interface:
·     Enabled.
·     Disabled.
mac-address mac-learning enable
display mac-address mac-move
Use display mac-address mac-move to display the MAC address move records after the device is started.
display mac-address mac-move [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays MAC address move records for all IRF member devices.
When a MAC address frequently moves between the specified two interfaces, Layer 2 loops might occur in the network. To discover and locate loops, you can view the MAC address move records.
In the MAC address move records, records with the same MAC address, VLAN, source port, and current port are considered to be one record.
An IRF member device can generate a maximum of 200 MAC address move records.
# Display the MAC address move records for a slot.
<Sysname> display mac-address mac-move slot 1
MAC address    VLAN Current port  Source port   Last time           Times
0000-0001-002c 1    XGE1/0/1      XGE1/0/2      2013-05-20 13:40:52 1
0000-0001-002c 1    XGE1/0/2      XGE1/0/1      2013-05-20 13:41:30 1
---  2 MAC address moving records found  ---
# Display the MAC address move records for all slots.
0000-0001-002c 1    XGE1/0/1      XGE1/0/2      2013-05-20 13:40:52 20
0000-0001-002c 1    XGE1/0/2      XGE1/0/1      2013-05-20 13:41:32 20
0000-0094-0001 1    XGE1/0/3      XGE1/0/4      2013-05-20 13:42:22 13
0000-0094-0001 1    XGE1/0/4      XGE1/0/3      2013-05-20 13:42:21 12
---  4 MAC address moving records found  ---
VLAN
Current port
Interface to which the MAC address was moved.
Source port
Interface from which the MAC address was moved.
Last time
Last time when the MAC address was moved.
Times
Number of MAC address moves after the device is started. For a MAC address record, the number of MAC address moves is increased by 1 when a new MAC address move has the same MAC address, VLAN, Current Port, and Source Port fields as the MAC address record.
mac-address notification mac-move
display mac-address statistics
Use display mac-address statistics to display MAC address table statistics.
This command displays the number of MAC address entries per type and the maximum number of MAC address entries allowed for each type.
# Display MAC address table statistics.
<Sysname> display mac-address statistics
MAC Address Count:
Dynamic Unicast Address (Learned) Count:                         3
Dynamic Unicast Address (Security-service-defined) Count:        4
Static Unicast Address (User-defined) Count:                     0
Static Unicast Address (System-defined) Count:                   3
Total Unicast MAC Addresses In Use:                              10
Total Unicast MAC Addresses Available:                           32768
Multicast and Multiport MAC Address Count:                       1
Static Multicast and Multiport MAC Address (User-defined) Count: 1
Total Multicast and Multiport MAC Addresses Available:           256
Number of dynamic unicast MAC address entries triggered by packets.
Number of dynamic unicast MAC address entries triggered by the security service.
Number of static unicast MAC address entries added by users.
Number of static unicast MAC address entries added by the system.
Number of unicast MAC address entries.
Maximum number of unicast MAC address entries allowed. The value of this parameter varies by device model. Values in the examples are for illustrative purposes only.
Number of multicast and multiport unicast MAC address entries.
Number of static multicast and multiport unicast MAC address entries added by users.
Maximum number of multicast and multiport unicast MAC address entries allowed. The value of this parameter varies by device model. Values in the examples are for illustrative purposes only.
mac-address (interface view)
Use mac-address to add or modify a MAC address entry on an interface.
Use undo mac-address to delete a MAC address entry on an interface.
Layer 2 Ethernet interface view and Layer 2 aggregate interface view:
mac-address { dynamic | multiport | static } mac-address vlan vlan-id
undo mac-address { dynamic | multiport | static } mac-address vlan vlan-id
S-channel interface view, S-channel aggregate interface view, and S-channel bundle interface view:
mac-address { dynamic | static } mac-address vlan vlan-id
undo mac-address { dynamic | static } mac-address vlan vlan-id
An interface is not configured with MAC address entries.
dynamic: Specifies dynamic MAC address entries.
static: Specifies static MAC address entries.
multiport: Specifies multiport unicast MAC address entries. A frame whose destination MAC address matches a multiport unicast MAC address entry is sent out of multiple ports.
mac-address: Specifies a MAC address in the format of H-H-H, excluding multicast, all-zero, and all-F MAC addresses. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter f-e2-1 for 000f-00e2-0001.
vlan vlan-id: Specifies an existing VLAN to which the specified interface belongs. The value range for the vlan-id argument is 1 to 4094.
Typically, the device automatically builds the MAC address table by learning the source MAC addresses of incoming frames on each interface. However, you can manually configure static MAC address entries. For a MAC address, a manually configured static entry takes precedence over a dynamically learned entry. To improve the security for the user device connected to an interface, manually configure a static entry to bind the user device to the interface. Then, the frames destined for the user device (for example, Host A) are always sent out of the interface. Other hosts using the forged MAC address of Host A cannot obtain the frames destined for Host A.
The MAC address entry configuration cannot survive a reboot unless you save it. The dynamic MAC address entries, however, are lost upon reboot whether or not you save the configuration.
# Add a static entry for MAC address 000f-e201-0101 on Ten-GigabitEthernet 1/0/1 that belongs to VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] mac-address static 000f-e201-0101 vlan 2
# Add a static entry for MAC address 000f-e201-0101 on Bridge-Aggregation 1 that belongs to VLAN 1.
[Sysname-Bridge-Aggregation1] mac-address static 000f-e201-0102 vlan 1
# Add a static entry for MAC address 000f-e201-0102 on S-Channel 1/0/1:10 that belongs to VLAN 1.
[Sysname] interface s-channel 1/0/1:10
[Sysname-S-Channel1/0/1:10] mac-address static 000f-e201-0102 vlan 1
# Add a static entry for MAC address 000f-e201-0102 on Schannel-Aggregation 1:2 that belongs to VLAN 1.
[Sysname] interface schannel-aggregation 1:2
[Sysname-Schannel-Aggregation1:2] mac-address static 000f-e201-0102 vlan 1
# Add a multiport unicast MAC address entry for MAC address 0001-0001-0101 on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 that belong to VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] mac-address multiport 0001-0001-0101 vlan 2
[Sysname-Ten-GigabitEthernet1/0/2] mac-address multiport 0001-0001-0101 vlan 2
display mac-address
mac-address (system view)
Use mac-address to add or modify a MAC address entry.
Use undo mac-address to delete one or all MAC address entries.
undo mac-address [ [ dynamic | static ] mac-address interface interface-type interface-number vlan vlan-id ]
undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id
undo mac-address [ dynamic | static ] interface interface-type interface-number
undo mac-address multiport mac-address interface interface-list vlan vlan-id
undo mac-address [ multiport ] [ [ mac-address ] vlan vlan-id ]
undo mac-address nickname nickname
undo mac-address mac-address nickname nickname vlan vlan-id
The system is not configured with MAC address entries.
blackhole: Specifies blackhole MAC address entries. Packets whose source or destination MAC addresses match blackhole MAC address entries are dropped.
vlan vlan-id: Specifies an existing VLAN to which the interface belongs. The value range for the vlan-id argument is 1 to 4094.
interface interface-type interface-number: Specifies an outgoing interface by its type and number.
interface interface-list: Specifies a list of up to four interface items. Each interface item can be an individual interface in the format of interface-type interface-number or a range of interfaces in the format of interface-type interface-number1 to interface-type interface-number2. The interfaces can only be Layer 2 Ethernet interfaces or Layer 2 aggregate interfaces. The value for the interface-number2 argument cannot be lower than the value for the interface-number1 argument.
nickname nickname: Specifies an RB (through which the packets leave the TRILL network) by its nickname. The nickname is a hexadecimal number in the range of 1 to fffe.
You can use this command to configure the following types of MAC address entries:
·     Dynamic entries.
Dynamic entries include manually configured dynamic entries and automatically learned dynamic entries.
·     Static entries.
For a MAC address, a manually configured static entry takes precedence over a dynamic entry. To improve the security for the user device connected to an interface, manually configure a static entry to bind the user device to the interface. Then, the frames destined for the user device (for example, Host A) are always sent out of the interface. Other hosts using the forged MAC address of Host A cannot obtain the frames destined for Host A.
·     Blackhole entries.
To drop frames with the specified source MAC addresses or destination MAC addresses, you can configure blackhole entries.
·     Multiport unicast entries.
To send frames with a specific destination MAC address out of multiple ports, configure a multiport unicast entry. When you execute this command for the first time, the command adds an entry. When you execute the command again with the same MAC address and VLAN but with different interfaces, this command adds the specified interfaces for this entry.
A static or blackhole entry can overwrite a dynamic entry, but not vice versa.
If you execute the undo mac-address command without specifying any parameters, this command deletes all unicast MAC address entries and static multicast MAC address entries.
You can delete all the MAC address entries (including unicast and static multicast MAC address entries) from the specified VLAN. You can also delete only one type (dynamic, static, blackhole, or multiport unicast) of MAC address entries. You can single out an interface and delete the unicast MAC address entries on it, but not the static multicast MAC address entries. You can single out an RB through which the packets leave the TRILL network and delete the corresponding unicast MAC address entries.
# Add a static entry for MAC address 000f-e201-0101. Then, all frames that are destined for this MAC address are sent out of Ten-GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname] mac-address static 000f-e201-0101 interface ten-gigabitethernet 1/0/1 vlan 2
# Add a multiport unicast MAC address entry for MAC address 000f-e201-0101. Then, all frames that are destined for this MAC address are sent out of Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3, which belong to VLAN 2.
[Sysname] mac-address multiport 000f-e201-0101 interface ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3 vlan 2
display mac-address
mac-address multiport vsi
Use mac-address multiport vsi to configure a multiport unicast MAC address entry for VXLAN.
Use undo mac-address multiport vsi to delete a multiport unicast MAC address entry for VXLAN or delete outgoing interfaces for such an entry.
For local multiport unicast MAC address entries:
mac-address multiport mac-address interface { peer-link | { interface-type interface-number service-instance instance-id }&<1-4> } * vsi vsi-name
undo mac-address multiport [ mac-address [ interface [ peer-link | { interface-type interface-number service-instance instance-id }&<1-4> ] * ] ] vsi vsi-name
For remote multiport unicast MAC address entries:
mac-address multiport mac-address { interface { tunnel tunnel-number1 [ to tunnel tunnel-number2 ] }&<1-4> } vsi vsi-name
undo mac-address multiport [ mac-address [ interface { tunnel tunnel-number1 [ to tunnel tunnel-number2 ] }&<1-4> ] ] vsi vsi-name
No multiport unicast MAC address entries exist.
mac-address: Specifies a MAC address in the format of H-H-H, excluding the all-zero MAC address. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter f-e2-1 for 000f-00e2-0001.
interface { interface-type interface-number service-instance instance-id }&<1-4>: Specifies a space-separated list of up to four Ethernet service instances. The interface-type interface-number argument specifies the interface that hosts an Ethernet service instance by its type and number. The instance-id argument specifies the Ethernet service instance by its ID in the range of 1 to 4096.
peer-link: Specifies a peer-link interface as an outgoing interface in the local multiport unicast MAC address entry. For more information about peer-link interfaces, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
interface { tunnel tunnel-number1 [ to tunnel tunnel-number2 ] }&<1-4>: Specifies a space-separated list of up to four VXLAN tunnel interface items. Each item specifies a VXLAN tunnel interface number or a range of VXLAN tunnel interface numbers in the format of tunnel tunnel-number1 to tunnel tunnel-number2. The value range for VXLAN tunnel interface numbers is 0 to 15359. The value of tunnel tunnel-number2 must be equal to or larger than the value of tunnel tunnel-number1. The specified VXLAN tunnel interfaces must exist.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
To send frames with a specific destination MAC address out of multiple ports, use this command to configure a multiport unicast MAC address entry. You can repeat this command to add outgoing interfaces for an existing entry.
Use mac-address multiport vsi to configure a local multiport unicast MAC address entry for VXLAN. A local MAC address is the MAC address of a VM in the local site.
For successful configuration, follow these restrictions when you configure multiport unicast MAC address entries:
·     For a local MAC address entry, make sure the specified Ethernet service instances have been mapped to the specified VSI.
Follow these guidelines when you use the undo mac-address multiport vsi command:
·     To delete all multiport unicast MAC address entries for a VSI, do not specify any optional parameters.
·     To delete a multiport unicast MAC address entry, specify the MAC address.
·     To delete outgoing interfaces from a multiport unicast MAC address entry, specify the MAC address and the interfaces.
In an EVPN network, you cannot configure the same multiport unicast MAC address entry on multiple leaf nodes or VTEPs. When configured with EVPN multihoming or EVPN M-LAG, a VTEP does not support synchronization of multiport unicast MAC address entries.
Interfaces specified by using the interface interface-type interface-number service-instance instance-id option of this command cannot be peer-link interfaces. To specify a peer-link interface as an outgoing interface in a multiport MAC address entry, specify the peer-link keyword. The traffic matching the multiport MAC address entry will be forwarding out of the Ethernet service instances on the peer-link interface. For the peer-link keyword to take effect, execute the l2vpn drni peer-link ac-match-rule vxlan-mapping command on the device.
Before specifying the peer-link keyword when you execute this command, you must configure peer-link interfaces on the device.
For more information about VXLAN, see VXLAN Configuration Guide. For more information about EVPN, see EVPN Configuration Guide.
# Configure a local multiport unicast MAC address entry for VSI vsi1.
[Sysname] mac-address multiport 000f-e201-0101 interface ten-gigabitethernet 1/0/1 service-instance 1 ten-gigabitethernet 1/0/2 service-instance 1 vsi vsi1
display l2vpn mac-address (VXLAN Command Reference)
l2vpn drni peer-link ac-match-rule vxlan-mapping (EVPN Command Reference)
Use mac-address mac-learning enable to enable MAC address learning globally, on an interface, or on a VLAN.
Use undo mac-address mac-learning enable to disable MAC address learning globally, on an interface, or on a VLAN.
MAC address learning is enabled.
VLAN view
To prevent the MAC address table from becoming saturated, you can disable MAC address learning.
For example, a number of packets with different source MAC addresses reaching a device can affect the MAC address table update. To avoid such attacks, you can disable MAC address learning by following these guidelines:
·     You can disable MAC address learning on a per-interface basis. The device will stop learning MAC addresses on the interfaces with MAC address learning disabled and cannot dynamically update MAC address entries.
·     If you disable MAC address learning globally, MAC address learning is disabled for all interfaces.
·     Because disabling MAC address learning can result in broadcast storms, enable broadcast storm suppression after you disable MAC address learning on an interface. For more information about broadcast storm suppression, see Interface Configuration Guide.
·     With MAC address learning enabled globally, you can disable MAC address learning for an interface or VLAN.
·     After MAC address learning is disabled, the device immediately deletes existing dynamic MAC address entries.
This command does not take effect on a TRILL network, S-channel, VPLS VSI, EVB VSI, or VXLAN VSI. For information about TRILL, see TRILL Configuration Guide. For information about VPLS VSIs, see MPLS Configuration Guide. For information about S-channels and EVB VSIs, see EVB Configuration Guide. For information about VXLAN VSIs, see VXLAN Configuration Guide.
# Disable MAC address learning globally.
[Sysname] undo mac-address mac-learning enable
# Disable MAC address learning for VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] undo mac-address mac-learning enable
# Disable MAC address learning on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] undo mac-address mac-learning enable
# Disable MAC address learning on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo mac-address mac-learning enable
# Disable MAC address learning on S-Channel 1/0/1:10.
[Sysname-S-Channel1/0/1:10] undo mac-address mac-learning enable
# Disable MAC address learning on Schannel-Aggregation 1:2.
[Sysname-Schannel-Aggregation1:2] undo mac-address mac-learning enable
mac-address mac-learning pdu
Use mac-address mac-learning pdu to enable the device to learn the source MAC addresses of Layer 2 protocol packets.
Use undo mac-address mac-learning pdu to disable the device from learning the source MAC addresses of Layer 2 protocol packets.
The device does not learn the source MAC addresses of Layer 2 protocol packets.
If you disable the device from learning the source MAC addresses of Layer 2 protocol packets, the device does not learn the source MAC addresses of the following protocol packets:
·     BPDUs destined for a MAC address in the range of 0x01-80-c2-00-00-00 to 0x01-80-c2-00-00-0f.
·     GARP PDUs destined for a MAC address in the range of 0x01-80-c2-00-00-20 to 0x01-80-c2-00-00-2f.
·     PVST BPDUs destined for MAC address 0x01-00-0c-cc-cc-cd.
# Disable the device from learning the source MAC addresses of Layer 2 protocol packets.
[Sysname] undo mac-address mac-learning pdu
mac-address mac-learning priority
Use mac-address mac-learning priority to assign MAC learning priority to an interface.
Use undo mac-address mac-learning priority to restore the default.
mac-address mac-learning priority { high | low }
Low MAC address learning priority is used.
high: Assigns high MAC learning priority.
low: Assigns low MAC learning priority.
The MAC address learning priority values can be high and low. An interface with high MAC address learning priority can learn any MAC address. An interface with low MAC address learning priority can learn only the MAC addresses that have not been learned by high-priority interfaces.
The MAC learning priority mechanism can help defend your network against MAC address spoofing attacks. To prevent the downlink interface from learning the MAC address of an upper layer device (for example, the gateway), you can perform the following tasks:
·     Assign high MAC learning priority to an uplink interface.
·     Assign low MAC learning priority to a downlink interface.
# Assign high MAC learning priority to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-address mac-learning priority high
# Assign high MAC learning priority to Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] mac-address mac-learning priority high
# Assign high MAC learning priority to S-Channel 1/0/1:10.
[Sysname-S-Channel1/0/1:10] mac-address mac-learning priority high
# Assign high MAC learning priority to Schannel-Aggregation 1:2.
[Sysname-Schannel-Aggregation1:2] mac-address mac-learning priority high
mac-address mac-move fast-update
Use mac-address mac-move fast-update to enable ARP fast update for MAC address moves.
Use undo mac-address mac-move fast-update to disable ARP fast update for MAC address moves.
When the device starts with the factory default configuration, the device uses the factory default value for the software feature, and ARP fast update is enabled.
When the device starts with empty configuration, the device uses the default value for the software feature, and ARP fast update is disabled.
For more information about the factory default configuration and empty configuration, see configuration file management in Fundamentals Configuration Guide.
# Enable ARP fast update for MAC address moves.
[Sysname] mac-address mac-move fast-update
mac-address mac-roaming enable
Use mac-address mac-roaming enable to enable MAC address synchronization.
Use undo mac-address mac-roaming enable to disable MAC address synchronization.
MAC address synchronization is disabled.
On an IRF fabric, if ports on different IRF member devices are Selected ports from the same aggregation group, MAC address entries are synchronized among these IRF member devices. They are synchronized whether or not MAC address synchronization is enabled for the IRF fabric. For more information about aggregation groups, see Layer 2—LAN Switching Configuration Guide.
The MAC address table size might vary by IRF member device. With MAC address synchronization enabled, MAC address entries exceeding the table size of an IRF member device cannot be synchronized to the MAC address table.
# Enable MAC address synchronization.
[Sysname] mac-address mac-roaming enable
mac-address max-mac-count
Use mac-address max-mac-count to set the MAC learning limit on an interface.
Use undo mac-address max-mac-count to restore the default.
The number of MAC addresses that can be learned on an interface is not limited.
count: Specifies the maximum number of MAC addresses that can be learned on an interface. When the argument is set to 0, the interface is not allowed to learn MAC addresses. The value range for this argument is 0 to 4096.
You cannot both set the MAC learning limit and configure VLAN mapping on an interface. The later configuration does not take effect.
This command helps limit the MAC address table size. When the number of MAC address entries learned by an interface reaches the limit, the interface stops learning MAC address entries.
With this feature configured on an interface, if the number of MAC address entries learned by the interface is larger than the configured MAC learning limit, the interface first delete the learned MAC address entries. If the number of MAC address entries learned by the interface is smaller than the configured MAC learning limit, the interface continues to learn MAC addresses until the MAC learning limit is reached.
# Configure Ten-GigabitEthernet 1/0/1 to learn a maximum of 600 MAC address entries.
[Sysname-Ten-GigabitEthernet1/0/1] mac-address max-mac-count 600
mac-address
mac-address max-mac-count enable-forwarding
Use mac-address max-mac-count enable-forwarding to enable the device to forward unknown frames received on an interface after the MAC learning limit on the interface is reached. Unknown frames refer to frames whose source MAC addresses are not in the MAC address table.
Use undo mac-address max-mac-count enable-forwarding to disable the device from forwarding unknown frames received on an interface after the MAC learning limit on the interface is reached.
When the MAC learning limit on an interface is reached, the device can forward unknown frames received on the interface.
# Disable the device from forwarding unknown frames received on Ten-GigabitEthernet 1/0/1 after the MAC learning limit on Ten-GigabitEthernet 1/0/1 is reached.
[Sysname-Ten-GigabitEthernet1/0/1] undo mac-address max-mac-count enable-forwarding
mac-address
Use mac-address notification mac-move to enable MAC address move notifications and optionally specify a MAC move detection interval.
Use undo mac-address notification mac-move to disable MAC address move notifications.
MAC address move notifications are disabled.
interval interval: Specifies the interval for detecting MAC address moves, in the range of 1 to 60 minutes. If you do not specify this option, the default setting of 1 minute is used.
With MAC address move notifications enabled, the system records the MAC address move logs every MAC move detection interval. Each record of the MAC address move logs contains the following information:
·     MAC address.
·     VLAN ID of the MAC address entry.
·     Current port and source port of the MAC address moves.
·     Number of MAC address moves within a detection interval.
A MAC address can have only one MAC address move record. If a MAC address moves multiple times, the new record overrides the old record.
Within a detection interval, an IRF member device can record MAC address move information for a maximum of 20 MAC addresses. The records are ranked in descending order of MAC move counts. If the number of MAC address move records exceeds 20, only the first 20 records are retained. Then in the next detection interval, the device discards all MAC address move records generated in the previous detection interval and starts another round of MAC move record generation.
After you execute this command, the system sends only syslog messages to the information center module. If the snmp-agent trap enable mac-address command is also executed, the system also sends SNMP notifications to the SNMP module.
# Enable MAC address move notifications.
[Sysname] mac-address notification mac-move
[Sysname]
%May 14 17:16:45:688 2019 Sysname MAC/4/MAC_FLAPPING: MAC address 0000-0012-0034 in VLAN 500 has moved from port XGE1/0/1 to port XGE1/0/2 for 1 times
The output shows that:
·     The VLAN ID of MAC address 0000-0012-0034 is VLAN 500.
·     The MAC address moved from Ten-GigabitEthernet 1/0/1 to Ten-GigabitEthernet 1/0/2.
·     The MAC address has moved once within a MAC move detection interval.
mac-address notification mac-move suppression (interface view)
Use mac-address notification mac-move suppression to enable MAC address move suppression on an interface.
Use undo mac-address notification mac-move suppression to disable MAC address move suppression on an interface.
MAC address moves are not suppressed.
This feature shuts an interface down when a MAC address has been moved to or from the interface more than the suppression threshold within a MAC move detection interval. The shutdown interface automatically goes up after a suppression interval. Also, you can use the shutdown command and then the undo shutdown command to bring up the interface.
When MAC address move suppression shuts an interface down, the system sends only syslog messages to the information center module. If the snmp-agent trap enable mac-address command is also executed, the system also sends SNMP notifications to the SNMP module.
# Enable MAC address move suppression on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-address notification mac-move suppression
mac-address notification mac-move suppression (system view)
Use mac-address notification mac-move suppression to set the suppression interval or the suppression threshold.
Use undo mac-address notification mac-move suppression to restore the default.
undo mac-address notification mac-move suppression { interval | threshold }
The suppression interval is 30 seconds. The suppression threshold is 3.
interval interval: Specifies the MAC address move suppression interval during which a suppressed interface stays down. The value range for the interval-value argument is 30 to 86400 seconds. If you do not specify this option, the default suppression interval of 30 seconds is used.
threshold threshold: Specifies the suppression threshold for MAC address moves sourced from or destined for an interface within a MAC move detection interval. The value range for this argument is 0 to 1024. If you do not specify this option, the default suppression threshold of 3 is used.
For this command to take effect on an interface, you must also enable MAC address move suppression on the interface.
If you set the suppression interval or suppression threshold multiple times, the most recent configuration applies. The suppression interval setting is independent of the suppression threshold setting.
# Set the suppression interval to 40 seconds and the suppression threshold to 1 for MAC address moves.
[Sysname] mac-address notification mac-move suppression interval 40
[Sysname] mac-address notification mac-move suppression threshold 1
mac-address static source-check enable
Use mac-address static source-check enable to enable the static source check feature.
Use undo mac-address static source-check enable to disable the static source check feature.
The static source check feature is enabled.
IRF physical interface view
In system view, this command takes effect on all interfaces.
# Disable the static source check feature on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] undo mac-address static source-check enable
mac-address timer
Use mac-address timer to set the aging timer for dynamic MAC address entries.
Use undo mac-address timer to restore the default.
The aging timer is 300 seconds for dynamic MAC address entries.
aging seconds: Specifies an aging timer for dynamic MAC address entries, in seconds. The value range for the seconds argument is 10 to 1000000.
no-aging: Configures dynamic MAC address entries not to age.
To set the aging timer appropriately, follow these guidelines:
·     A long aging interval causes the MAC address table to retain outdated entries and fail to accommodate the most recent network changes.
·     A short aging interval results in removal of valid entries. Then, unnecessary broadcast packets appear and affect device performance.
# Set the aging time to 500 seconds for dynamic MAC address entries.
Use snmp-agent trap enable mac-address to enable SNMP notifications for the MAC address table.
Use undo snmp-agent trap enable mac-address to disable SNMP notifications for the MAC address table.
snmp-agent trap enable mac-address [ entry-limit | hash-conflict | illegal-mac | mac-move ] *
undo snmp-agent trap enable mac-address [ entry-limit | hash-conflict | illegal-mac | mac-move ] *
SNMP notifications are enabled for the MAC address table.
entry-limit: Specifies notifications generated when the number of learned MAC address entries reaches the upper limit and drops to 80% of the upper limit.
illegal-mac: Specifies notifications generated when a port receives packets sourced from or destined for an all-zero MAC address.
hash-conflict: Specifies notifications generated when MAC address hash conflicts occur.
mac-move: Specifies notifications about the MAC address moves for the MAC address table.
To report critical MAC address move events to an NMS, enable SNMP notifications for the MAC address table. For MAC address move event notifications to be sent correctly, you must also configure SNMP on the device.
When SNMP notifications are disabled for the MAC address table, the device sends the generated logs to the information center. To display the logs, configure the log destination and output rule configuration in the information center.
For information about SNMP and information center configuration, see the network management and monitoring configuration guide for the device.
The MAC address table supports only SNMP notifications about MAC address moves. When you enable or disable SNMP notifications about MAC address moves, you enable or disable all types of SNMP notifications for the MAC address table.
If you execute this command without specifying any keywords, the command enables all types of SNMP notifications for the MAC address table. If you specify a keyword, the command enables only the specified type of SNMP notifications for the MAC address table.
# Disable SNMP notifications about MAC address moves for the MAC address table.
[Sysname] undo snmp-agent trap enable mac-address mac-move
MAC Information commands
mac-address information enable (interface view)
Use mac-address information enable to enable MAC Information on an interface.
Use undo mac-address information enable to disable MAC Information on an interface.
undo mac-address information enable { added | deleted }
MAC Information is disabled on an interface.
added: Enables the device to record MAC change information when a new MAC address is learned on an interface.
deleted: Enables the device to record MAC change information when an existing MAC address is deleted.
Before you enable MAC Information on an interface, enable MAC Information globally.
# Enable MAC Information on Ten-GigabitEthernet 1/0/1 to enable the interface to record MAC change information when learning a new MAC address.
[Sysname-Ten-GigabitEthernet1/0/1] mac-address information enable added
# Enable MAC Information on S-Channel 1/0/1:10 to enable the interface to record MAC change information when learning a new MAC address.
[Sysname-S-Channel1/0/1:10] mac-address information enable added
# Enable MAC Information on Schannel-Aggregation 1:2 to enable the interface to record MAC change information when learning a new MAC address.
[Sysname-Schannel-Aggregation1:2] mac-address information enable added
mac-address information enable (system view)
Use mac-address information enable to enable MAC Information globally.
Use undo mac-address information enable to disable MAC Information globally.
MAC Information is disabled globally.
# Enable MAC Information globally.
[Sysname] mac-address information enable
mac-address information interval
Use mac-address information interval to set the MAC change notification interval.
Use undo mac-address information interval to restore the default.
mac-address information interval interval
The MAC change notification interval is 1 second.
interval: Specifies the MAC change notification interval in the range of 1 to 20000 seconds.
To prevent syslog messages or SNMP notifications from being sent too frequently, set the MAC change notification interval to a larger value.
# Set the MAC change notification interval to 200 seconds.
[Sysname] mac-address information interval 200
mac-address information mode
Use mac-address information mode to set the MAC Information mode. The MAC Information mode specifies the type of messages (syslog messages or SNMP notifications) used to notify MAC changes.
Use undo mac-address information mode to restore the default.
SNMP notifications are sent to notify MAC changes.
syslog: Specifies that the device sends syslog messages to notify MAC changes.
trap: Specifies that the device sends SNMP notifications to notify MAC changes.
# Configure the MAC Information mode as trap.
[Sysname] mac-address information mode trap
mac-address information queue-length
Use mac-address information queue-length to set the MAC Information queue length.
Use undo mac-address information queue-length to restore the default.
The MAC Information queue length is 50.
value: Specifies the MAC Information queue length in the range of 0 to 1000. The MAC Information queue length indicates the number of MAC change messages.
If the MAC Information queue length is 0, the device sends a syslog message or SNMP notification immediately after learning or deleting a MAC address.
If the MAC Information queue length is not 0, the device stores MAC changes in the queue:
·     The device overwrites the oldest MAC change written into the queue with the most recent MAC change when the following conditions exist:
¡     The MAC change notification interval does not expire.
¡     The queue has been exhausted.
·     The device sends syslog messages or SNMP notifications only if the MAC change notification interval expires.
# Set the MAC Information queue length to 600.
[Sysname] mac-address information queue-length 600
