| 02-Removable Components | 5.91 MB |
2 Removable components
MSUs
MSU-100
View
Figure2-1 MSU-100 view
(1) Captive screw |
(2) DIAG button |
(3) USB port |
(4) Management Ethernet port |
(5) Reset button (RESET) |
(6) Console port |
(7) Ejector lever |
LEDs
Figure2-2 MSU-100 LEDs
(1) Management Ethernet copper port LED |
(1) System status LED (SYS) |
(3) MSU active/standby status LED (ACT) |
(4) Fan tray status LED (FAN) |
Table2-1 LED description
LED |
Status |
System LED (SYS) |
Flashing green (eight times per second) |
The device is in BootWare stage. |
Steady green |
The device is in Kernel stage, including Eshell stage. |
Flashing green (once per second) |
The Comware system is starting up or is operating correctly. |
Flashing yellow (once per second) |
Memory test failed in BootWare stage. |
Flashing yellow (eight times per second) |
The extended BootWare segment does not exist. |
Steady yellow |
The boot.bin file does not exist. |
Off |
No power input, or an exception has occurred. |
Steady green |
The MSU is in active mode. |
Off |
The MSU is in standby mode. |
Steady green |
Both fan trays are operating correctly. |
One fan tray is operating correctly and the other one is not present. |
Steady yellow |
A minimum of one fan try is faulty. |
Off |
Both fan trays are not present. |
Steady green |
A 1000 Mbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 1000 Mbps. |
Steady yellow |
A 10 or 100 Mbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 10 or 100 Mbps. |
Off |
No link is present on the port. |
Ports
Table2-2 Port specifications
Port type |
Specification |
Console port |
1 |
GE management port |
1 |
USB port |
1 |
DIAG button |
1 |
Technical specifications
Table2-3 Technical specifications
Item |
Specification |
Net weight |
1.54 kg (3.40 lb) |
Dimensions (H × W × D) |
42.6 × 375 × 227 mm (1.68 × 14.76 × 8.94 in) |
Max power consumption |
24.60 W |
Memory |
4 GB DDR4 |
Flash |
4 GB |
MSU-200
View
Figure2-3 MSU-200 view
(1) Captive screw |
(2) SIC slot |
(3) DIAG button |
(4) SFP+ port SFP+10 |
(5) SFP+ port SFP+11 |
(6) GE copper ports GE2 to GE9 |
(7) GE copper port GE1 |
(8) GE fiber port SFP0 |
(9) GE fiber port SFP1 |
(10) USB port |
(11) Management Ethernet port |
(12) Reset button (RESET) |
(13) Console port |
(14) Ejector lever |
(15) GE copper port GE0 |
LEDs
Figure2-4 MSU-200 LEDs
(1) SFP+ fiber port LED |
(2) GE port LED |
(3) SFP fiber port LED |
(4) Management Ethernet copper port LED |
(5) System status LED (SYS) |
(6) MSU active/standby status LED (ACT) |
(7) Fan tray status LED (FAN) |
Table2-4 LED description
LED |
Status |
System LED (SYS) |
Steady green |
Steady yellow |
Off |
Steady green |
Off |
Steady green |
Steady yellow |
Off |
Steady green |
A 10 Gbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 10 Gbps. |
Steady yellow |
Flashing yellow |
Off |
Steady green |
Flashing green |
Steady yellow |
A 100 Mbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 100 Mbps. |
Off |
GE port LED/Management Ethernet copper port LED |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
Ports
Table2-5 Port specifications
Port type |
Specification |
Console port |
1 |
1 |
GE copper port |
8 |
Combo interface |
2 (SFP0/GE0, SFP1/GE1) |
SFP+ fiber port |
2 |
USB port |
1 |
DIAG button |
1 |
SIC slot |
1 |
Table2-6 Technical specifications
Item |
Specification |
Net weight |
1.72 kg (3.79 lb) |
45.00 W |
Memory |
4 GB DDR4 |
Flash |
4 GB |
MSU-400-G
View
Figure2-5 MSU-400-G view
(1) Captive screw |
(2) Management Ethernet port |
(3) SFP+ ports SFP+8 to SFP+17 |
(4) GE copper ports GE0 to GE7 |
(5) Cloud cluster management SFP+ fiber port |
(6) USB port |
(7) Reset button (RESET) |
(8) Ejector lever |
(9) Console port |
(10) DIAG button |
LEDs
Figure2-6 MSU-400-G LEDs
(2) SFP+ fiber port LED |
(3) GE port LED |
(4) Cloud cluster management SFP+ fiber port LED |
Table2-7 LED description
LED |
Status |
System LED (SYS) |
Steady green |
Steady yellow |
Off |
Steady green |
Bulk backup in progress. |
Off |
Steady green |
Steady yellow |
Off |
Cloud cluster management SFP+ fiber port LED SFP+ fiber port LED |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
Ports
Table2-8 Port specifications
Port type |
Specification |
Console port |
1 |
1 |
GE copper port |
8 |
SFP+ fiber port |
11 (including one cloud cluster management port) |
USB port |
1 |
DIAG button |
1 |
Table2-9 Technical specifications
Item |
Specification |
Net weight |
2.2 kg (4.85 lb) |
121.30 W |
Memory |
8 GB DDR4 |
Flash |
4 GB |
Interface modules
Weights, dimensions, and power consumptions
Table2-1 Weights, dimensions, and power consumptions
Module model |
Net weight |
RT-SIC-5G |
0.19 kg (0.42 lb) |
7.60 W |
19.8 × 80 × 138 mm (0.78 × 3.15 × 5.43 in) |
RT-XMIM-8GEE-R |
0.64 kg (1.41 lb) |
8.80 W |
19.8 × 186 × 228 mm (0.78 × 7.32 × 8.98 in) |
RT-XMIM-8GEF-R |
0.65 kg (1.43 lb) |
17.16 W |
RT-XMIM-4XP |
0.7 kg (1.54 lb) |
25 W |
RT-XMIM-1POS |
0.62 kg (1.37 lb) |
9.70 W |
RT-XMIM-2POS |
0.64 kg (1.41 lb) |
10.30 W |
RT-XMIM-1CPOS |
0.64 kg (1.41 lb) |
11 W |
RT-XMIM-2E1 |
0.6 kg (1.32 lb) |
5.00 W |
RT-XMIM-4E1 |
0.62 kg (1.37 lb) |
5.40 W |
RT-XMIM-8E1 |
0.64 kg (1.41 lb) |
6.10 W |
RT-XMIM-CNDE-SJK |
0.6 kg (1.32 lb) |
13 W |
Interface modules
The device supports SIC and XMIM interface modules. For more information about the views, LEDs, and specifications of the interface modules, see H3C MSR Router Series Interface Module Guide.
Power supplies
The device supports AC power supplies, DC power supplies, and mix of AC and DC power supplies. The power supplies can be hot swapped and configured in redundancy. In AC or DC power supply mode, you can install only one power supply, or two or three power supplies for 1+1 or 1+2 power supply redundancy respectively. In mixed power supply mode, you can install two power supplies, or three power supplies for 2+1 power supply redundancy.
The device supports only mix of 450 W AC and DC power supplies.
PSR250-12A
View
Figure2-7 PSR250-12A power supply view
(1) Latch |
(2) Handle |
(3) Power receptacle |
LEDs
Figure2-8 PSR250-12A AC power supply LEDs
(1) Status LED |
Table2-2 LED description
LED |
Status |
Status LED |
Steady green |
The power supply is operating correctly. |
Flashing green |
The power supply has normal power input but has not been turned on. |
Steady red |
The power supply is faulty. |
Flashing red/green |
An alarm is present on the power supply. |
Flashing red |
This power supply does not have power input but the other power supply has power input. |
Off |
No power is present. |
Item |
Specification |
Net weight |
0.64 kg (1.41 lb) |
40 × 51 × 221 mm (1.57 × 2.01 × 8.70 in) |
Rated input voltage |
100 to 240 VAC @ 50 or 60 Hz |
Max input current |
4 A |
Max power |
250 W |
PSR450-12A
View
Figure2-9 PSR450-12A power supply view
(1) Latch |
(2) Handle |
LEDs
Figure2-10 PSR450-12A AC power supply LEDs
(1) Status LED |
LED |
Status |
Status LED |
Steady green |
Flashing green |
Steady red |
Flashing red |
Off |
Table2-5 Technical specifications
Item |
Specification |
Net weight |
0.65 kg (1.43 lb) |
Max input current |
6 A |
Max power |
450 W |
PSR450-12D-F
View
Figure2-11 PSR450-12D-F power supply view
(1) Latch |
(2) Handle |
LEDs
Figure2-12 PSR450-12D-F DC power supply LEDs
(1) Status LED |
Table2-6 LED description
LED |
Status |
Status LED |
Steady green |
Flashing green |
Steady red |
Flashing red |
Off |
Table2-7 Technical specifications
Item |
Specification |
Net weight |
0.68 kg (1.50 lb) |
–48 to –60 VDC |
Max input current |
12 to 10 A |
Max power |
450 W |
Fan trays
FAN-80B-2-C
View
Figure2-13 FAN-80B-2-C fan tray view
(1) Handle |
LEDs
Figure2-14 FAN-80B-2-C fan tray LEDs
(1) Status LED |
Table2-8 LED description
LED |
LED status |
RUN |
Steady green |
The fan tray is operating correctly. |
Steady yellow |
The fan tray is faulty. |
Off |
No fan tray is present or no power is present on the fan tray. |
Item |
Specification |
Net weight |
1.06 kg (2.34 lb) |
171 × 136 × 93 mm (6.73 × 5.35 × 3.66 in) |
90 W |
Maximum rotating speed |
13800 RPM |
Maximum air flow rate |
135.15 CFM (3.83 m3/min) |
Number of fans |
2 |
Automatic speed adjustment |
Supported |
Anti-misinsertion |
Supported |
Hot swapping |
Supported |
