07-IP Multicast Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R838x-6W10107-IP Multicast Command Reference
05-IGMP commands
05-IGMP commands 459.53 KB
IGMP commands· 1
display igmp attack-suppression configuration· 1
display igmp attack-suppression entry· 2
display igmp group· 5
display igmp host-tracking· 9
display igmp interface· 11
display igmp proxy group· 16
display igmp proxy routing-table· 18
display igmp ssm-mapping· 20
display igmp user-info· 21
host-tracking enable (IGMP view) 26
igmp· 27
igmp access-policy· 27
igmp attack-defense· 28
igmp attack-suppression aging-time· 29
igmp attack-suppression check-interval 30
igmp attack-suppression enable· 31
igmp attack-suppression threshold· 32
igmp authorization-enable· 33
igmp enable· 33
igmp fast-leave· 34
igmp group-policy· 35
igmp host-tracking { disable | enable }· 36
igmp host-tracking limit 37
igmp join-by-session· 37
igmp last-member-query-count 38
igmp last-member-query-interval 39
igmp max-response-time· 40
igmp other-querier-present-interval 40
igmp proxy enable· 41
igmp proxy forwarding· 42
igmp query-interval 42
igmp robust-count 43
igmp startup-query-count 44
igmp startup-query-interval 44
igmp static-group· 45
igmp user-vlan-aggregation· 47
igmp version· 49
last-member-query-count (IGMP view) 49
last-member-query-interval (IGMP view) 50
max-response-time (IGMP view) 50
other-querier-present-interval (IGMP view) 51
proxy multipath (IGMP view) 52
query-interval (IGMP view) 52
reset igmp attack-suppression entry· 53
reset igmp attack-suppression statistics· 54
reset igmp group· 55
robust-count (IGMP view) 56
snmp-agent trap enable igmp· 57
ssm-mapping (IGMP view) 57
startup-query-count (IGMP view) 58
startup-query-interval (IGMP view) 59
IGMP commands
Use display igmp attack-suppression configuration to display the configuration of IGMP suppression.
display igmp attack-suppression configuration { per-interface | source-ip | source-mac }
per-interface: Specifies interface-based IGMP suppression.
source-ip: Specifies source IP-based IGMP suppression.
source-mac: Specifies source MAC-based IGMP suppression.
# Display the configuration of interface-based IGMP suppression.
<Sysname> display igmp attack-suppression configuration per-interface
IGMP attack-suppression per-interface is enabled.
Check interval: 5s
Threshold: 20
Aging time: 300s
# Display the configuration of source IP-based IGMP suppression.
<Sysname> display igmp attack-suppression configuration source-ip
IGMP attack-suppression source-ip is enabled.
Check interval: 10s
Threshold: 5
Aging time: 30s
# Display the configuration of source MAC-based IGMP suppression.
<Sysname> display igmp attack-suppression configuration source-mac
IGMP attack-suppression source-mac is enabled.
Check interval: 5s
Threshold: 20
Aging time: 300s
Check interval
Check interval of IGMP suppression.
Threshold
Threshold for triggering IGMP suppression.
Aging time
Aging time of IGMP suppression entries.
Use display igmp attack-suppression entry to display IGMP suppression entries.
display igmp attack-suppression entry slot slot-number { per-interface [ interface interface-type interface-number ] | source-ip [ interface interface-type interface-number | ip-address address ]* | source-mac [ interface interface-type interface-number | mac-address address ]* } [ attack ] [ verbose ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IGMP suppression entries for all interfaces.
mac-address address: Specifies a source MAC address. If you do not specify a source MAC address, this command displays IGMP suppression entries for all source MAC addresses.
ip-address address: Specifies a source IP address. If you do not specify a source IP address, this command displays IGMP suppression entries for all source IP addresses.
slot slot-number: Specifies a card by its slot number.
attack: Displays IGMP suppression entries for IGMP attack packets. If you do not specify this keyword, the command displays all IGMP suppression entries.
verbose: Displays detailed information about IGMP suppression entries. If you do not specify this keyword, the command displays brief information about IGMP suppression entries.
# Display interface-based IGMP suppression entries for IGMP attack packets.
<Sysname> display igmp attack-suppression entry slot 1 per-interface attack
Total entries: 1
Interface             Attack start time      Expires
XGE3/0/4               2018/09/10 15:53:34    00:01:15
# Display detailed information about interface-based IGMP suppression entries.
<Sysname> display igmp attack-suppression entry slot 1 per-interface verbose
Total entries: 2
Interface: XGE3/0/1
Drv status: N/A
Attack start time: N/A
Expires: Off
CPU receive: 10
CPU drop: 0
Drv drop: 0
Interface: XGE3/0/2
Drv status: Succeeded
Attack start time: 2018/09/10 15:53:34
Expires: 00:01:15
CPU receive: 123456789
CPU drop: 123456
Drv drop: 18446744073709551615
# Display source MAC-based IGMP suppression entries for IGMP attack packets.
<Sysname> display igmp attack-suppression entry slot 1 source-mac attack
Total entries: 1
Interface             MAC address       Attack start time      Expires
XGE3/0/4               0001-0001-0004    2018/09/10 15:53:34    00:01:15
# Display detailed information about source MAC-based IGMP suppression entries.
<Sysname> display igmp attack-suppression entry slot 1 source-mac verbose
Total entries: 2
Interface: XGE3/0/1
MAC address: 0001-0001-0001
Drv status: N/A
Expires: Off
CPU receive: 10
CPU drop: 0
Drv drop: 0
Interface: XGE3/0/2
MAC address: 0001-0001-0002
Expires: 00:01:15
CPU drop : 123456
Drv drop : 18446744073709551615
# Display source IP-based IGMP suppression entries for IGMP attack packets.
<Sysname> display igmp attack-suppression entry source-ip slot 1 attack
Total entries: 1
Interface             IP address               Attack start time      Expires
XGE3/0/4               10.1.23.1                2019/06/12 15:38:46    00:00:21
# Display detailed information about source IP-based IGMP suppression entries.
<Sysname> display igmp attack-suppression entry source-ip slot 1 verbose
Total entries: 2
Interface: XGE3/0/1
IP address: 10.1.23.1
Drv status: N/A
Expires: Off
CPU receive: 10
CPU drop: 0
Drv drop: 0
Interface: XGE3/0/2
IP address: 10.1.23.2
Expires: 00:01:15
CPU drop : 123456
Total entries
Total number of IGMP suppression entries.
Interface name.
MAC address
MAC address of the attacker.
IP address
IP address of the attacker.
Drv status
Driver status:
·     Succeeded—The driver limits the IGMP packet rate.
·     Failed—The CPU limits the IGMP packet rate. The device has failed or hardware resources for IGMP suppression entries have been used up.
·     N/A—The incoming IGMP packets are not attack packets and the device does not limit the packet rate.
·     Not support—The device hardware does not support IGMP suppression. CPU resources are consumed if the device performs software-based rate limiting.
Attack start time
Time when the IGMP attack started. This field displays N/A if no IGMP attack is detected.
Expires
Remaining time of the IGMP suppression entry aging timer. This field displays Off if the aging timer is disabled.
CPU receive
Number of packets that the CPU received.
CPU drop
Number of packets dropped by the CPU.
Drv drop
Number of packets dropped by the driver.
display igmp group
Use display igmp group to display information about IGMP multicast groups (multicast groups that hosts have joined through IGMP).
display igmp [ vpn-instance vpn-instance-name ] [ group [ group-address | interface interface-type interface-number ] [ static | verbose ] | statistics ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about IGMP multicast groups on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about all IGMP multicast groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about IGMP multicast groups for all interfaces.
static: Specifies IGMP multicast groups that hosts have joined statically. If you do not specify this keyword, the command displays information about IGMP multicast groups that hosts have joined dynamically.
statistics: Displays the number of IGMP multicast groups that hosts have joined statically and dynamically and the number of IGMP multicast groups that hosts have joined dynamically. If you do not specify this keyword, the command displays information about IGMP multicast groups.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information about IGMP multicast groups.
# Display information about IGMP multicast groups that hosts have dynamically joined on the public network.
<Sysname> display igmp group
IGMP groups in total: 3
 Ten-GigabitEthernet3/0/1(10.10.1.20):
  IGMP groups reported in total: 3
   Group address   Last reporter   Uptime      Expires
   225.1.1.1       10.10.1.10      00:02:04    00:01:15
   225.1.1.2       10.10.1.10      00:02:04    00:01:15
   225.1.1.3       10.10.1.10      00:02:04    00:01:15
Total number of IGMP multicast groups.
Total number of IGMP multicast groups that hosts attached to the interface have joined dynamically.
Group address
Multicast group address.
Last reporter
Address of the last host that reported its membership to the multicast group.
Uptime
Length of time since the multicast group was reported.
Expire
Remaining lifetime for the multicast group. This field displays Off if the timer is disabled.
# Display detailed information about IGMP multicast group 232.1.1.1 that hosts have dynamically joined on the public network. In this example, the router is configured with IGMPv3.
<Sysname> display igmp group 232.1.1.1 verbose
   Group: 232.1.1.1
     Uptime: 00:00:34
     Exclude expires: 00:04:16
     Mapping expires: 00:02:16
     Last reporter: 10.10.1.10
     Last-member-query-counter: 0
     Last-member-query-timer-expiry: Off
     Mapping last-member-query-counter: 0
     Mapping last-member-query-timer-expiry: Off
     Group mode: Exclude
     Version1-host-present-timer-expiry: Off
     Version2-host-present-timer-expiry: 00:02:11
     Mapping version1-host-present-timer-expiry: Off
     Source list (sources in total: 1):
       Source: 10.1.1.1
          Uptime: 00:00:03
          V3 expires: 00:04:16
Group
Uptime
Exclude expires
Remaining lifetime for the multicast group in Exclude mode. This field displays Off if the timer is disabled.
Mapping expires
Remaining time for the multicast group specified in IGMP SSM mappings.
This field is displayed only when the device is configured with IGMP SSM mappings.
Last reporter
Address of the last host that reported its membership to this multicast group.
Number of IGMP group-specific queries or IGMP source-and-group-specific queries sent for the multicast group.
Remaining time for the last member query timer for the multicast group. This field displays Off if the timer is disabled.
Number of IGMP group-specific queries or IGMP source-and-group-specific queries sent for the multicast group specified in IGMP SSM mappings.
Remaining time for the last member query timer of the multicast group specified in IGMP SSM mappings.
Group mode
Multicast source filtering mode:
·     Include—Include mode.
·     Exclude—Exclude mode.
For a device that runs IGMPv1 or IGMPv2:
·     If IGMP SSM mappings are not configured, this field displays Exclude.
·     If IGMP SSM mappings are configured, this field displays Include or Exclude depending on the SSM mappings and the multicast groups that the host joins.
Remaining time for the IGMPv1 host present timer.
This field is displayed only when the device runs IGMPv2 or IGMPv3.
Remaining time for the IGMPv2 host present timer.
This field is displayed only when the device runs IGMPv3.
Remaining time for the IGMPv1 host present timer when the device is configured with IGMP SSM mappings.
Source list (sources in total)
List of multicast sources and total number of multicast sources.
This field is displayed only when the device runs IGMPv3 or when the device is configured with IGMP SSM mappings.
Source
Multicast source address.
Uptime
Length of time since the multicast source was reported.
V3 expires
Remaining time for the multicast source when the device runs IGMPv3.
This field displays Off if the timer is disabled and displays three hyphens (---) if the multicast source is specified in IGMP SSM mappings.
Mapping expires
Remaining time for the multicast source specified in IGMP SSM mappings.
Number of IGMP group-specific queries or IGMP group-and-source-specific queries sent for the multicast source and group.
This field is displayed only when the device runs IGMPv3 or is configured with IGMP SSM mappings.
Remaining time for the last member query timer for the multicast source and group.
# Display information about IGMP multicast groups that hosts have statically joined on the public network.
<Sysname> display igmp group static
 Entries in total: 2
   Group address   Source address  Interface           Expires
   225.1.1.1       0.0.0.0         XGE3/0/1            Never
   225.2.2.2       1.1.1.1         XGE3/0/1            Never
Table 5 Command output
Entries in total
Total number of the multicast groups that hosts have joined statically.
Group address
Source address
Interface name.
Expires
Remaining lifetime for the multicast group. This field always displays Never because the multicast group never expires.
# Display the number of IGMP multicast groups that hosts have joined dynamically and the number of IGMP multicast groups that hosts have joined statically.
<Sysname> display igmp group statistics
 Dynamic groups in total: 2
 Static groups in total: 1
reset igmp group
Use display igmp host-tracking to display IGMP host tracking information.
display igmp [ vpn-instance vpn-instance-name ] host-tracking [ interface interface-type interface-number ] [ group group-address ] [ source source-address ] [ active ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IGMP host tracking information on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IGMP host tracking information for all interfaces.
group group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify this option, the command displays IGMP host tracking information for all multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify this option, the command displays IGMP host tracking information for all multicast sources.
active: Specifies active hosts. If you do not specify this keyword, the command displays IGMP host tracking information for all hosts.
# Display IGMP tracking information for all hosts.
<Sysname> display igmp host-tracking
IGMP hosts in total: 4
 Ten-GigabitEthernet3/0/1(192.168.1.1):
  IGMP hosts reported in total: 2
   (0.0.0.0,224.1.1.1)
    Host                            Uptime          Expires
    192.168.1.1                     00:02:20        00:00:40
    192.168.1.2                     00:02:21        00:00:39
 Ten-GigabitEthernet3/0/2(192.168.2.1):
   (1.1.1.1,224.1.1.1)
    Host                            Uptime          Expires       Type
    192.168.2.1                     00:03:20        Expired       G
    192.168.2.2                     00:02:20        00:00:39      G
# Display IGMP tracking information for hosts that have joined multicast group 232.1.1.1 on Ten-GigabitEthernet3/0/1.
<Sysname> display igmp host-tracking interface ten-gigabitethernet 3/0/1 group 232.1.1.1
  IGMP hosts reported in total: 5
   (1.1.1.1,232.1.1.1)
    192.168.1.1                     00:02:20        00:00:40      M
    192.168.1.2                     00:02:21        00:00:39      M
   (2.2.2.2,232.1.1.1)
    192.168.1.1                     00:02:20        00:00:40      G/M
    192.168.1.2                     00:02:21        00:00:39      G/M
    192.168.1.3                     00:02:21        00:00:39      G/M
# Display IGMP tracking information for active hosts on Ten-GigabitEthernet3/0/1.
<Sysname> display igmp host-tracking interface ten-gigabitethernet 3/0/1 active
   (1.1.1.1, 224.1.1.1)
   (1.1.1.1, 225.1.1.1)
Table 6 Command output
IGMP hosts in total
Tracked hosts in total.
Interface name and IP address.
Number of tracked hosts on the interface.
(0.0.0.0, 224.1.1.1)
(S, G) entry. Value 0.0.0.0 in the S position indicates all multicast sources.
Host
IP address of the host.
Uptime
Length of time elapsed since the host joined the multicast group.
Expires
Remaining timeout time for the host. The host timeout time is the same as the aging timer for the port. The timer is reset when the port receives an IGMP report from the host.
This field displays Expired if the host timed out.
IGMP version:
·     G—The IGMP version is IGMPv3 and the host joins the multicast group normally.
·     M—The IGMP version is IGMPv1 or IGMPv2, and the host joins the multicast group through the SSM mapping.
·     G/M—Both of the above conditions exist at the same time.
This field is not displayed if the IGMP version is IGMPv1 or IGMPv2, and the host joins the multicast group without the SSM mapping.
Use display igmp interface to display IGMP information for interfaces.
display igmp [ vpn-instance vpn-instance-name ] interface [ access-interface interface-type interface-number | [ interface-type interface-number ] [ host | proxy ] ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IGMP information for interfaces on the public network.
access-interface interface-type interface-number: Specifies an access interface by its type and number, which is the actual interface through which a multicast user accesses the network.
host: Displays information about the interfaces enabled with the IGMP host feature. For more information about the IGMP host feature, see VXLAN Configuration Guide.
proxy: Displays the IGMP proxy interface information.
verbose: Displays detailed IGMP information.
A multicast-UA interface is a virtual interface created for maintaining IGMP information.
When an IPoE or PPPoE user assigned with the STB service comes online, the access module sends a notification to IGMP. If per-session multicast forwarding is enabled on the access interface, IGMP creates a multicast-UA interface for the user upon receiving the notification. When the user goes offline, IGMP deletes the multicast-UA interface immediately after receiving the notification from the access module. For more information about specifying the STB service for users in an ISP domain, see AAA configuration in BRAS Services Configuration Guide.
When a user comes online through an interface configured with QinQ and per-session multicast forwarding, IGMP creates a multicast-UA interface upon receiving an IGMP report from the user. For users that belong to the same SVLAN and CVLAN, only one multicast-UA interface is created. The multicast-UA interface ages out if the interface neither maintains membership information for any multicast groups nor receives IGMP reports for a period of time. For more information about QinQ, see Layer 2—LAN Switching Configuration Guide.
To display IGMP information for multicast-UA interfaces created for multicast users that come online through the same access interface, specify the access-interface interface-type interface-number option.
If you do not specify any parameters, this command displays IGMP information for all interfaces.
# Display detailed IGMP information for Ten-GigabitEthernet 3/0/1.3 (non-proxy interface) on the public network.
<Sysname> display igmp interface ten-gigabitethernet 3/0/1.3 verbose
 Ten-GigabitEthernet3/0/1.3(10.10.1.20):
   IGMP is enabled.
   IGMP version: 2
   Query interval for IGMP: 125s
   Other querier present time for IGMP: 255s
   Maximum query response time for IGMP: 10s
   Last member query interval: 1s
   Last member query count: 2
   Startup query interval: 31s
   Startup query count: 2
   General query timer expiry (hh:mm:ss): 00:00:54
   Querier for IGMP: 10.10.1.20 (This router)
   IGMP activity: 1 join(s), 0 leave(s)
   Multicast routing on this interface: Enabled
   Robustness: 2
   Require-router-alert: Disabled
   Fast-leave: Disabled
   Startup-query: Off
   Other-querier-present-timer-expiry (hh:mm:ss): Off
   Authorization: Disabled
   Join-by-session: Disabled
   User-VLAN-aggregation: Enabled (Dynamic)
   VSRP instance: vsrp1 (State is master, synchronization is on)
   VSRP forward mode: all (Switchback delay: 180s)
  IGMP groups reported in total: 1
# Display detailed IGMP information for all IGMP proxy interfaces on the public network.
<Sysname> display igmp interface proxy verbose
 Ten-GigabitEthernet3/0/2(20.10.1.20):
   IGMP proxy is enabled.
   IGMP version: 2
   Version1-querier-present-timer-expiry (hh:mm:ss): Off
# Display detailed IGMP information for all interfaces enabled with the IGMP host feature on the public network.
<Sysname> display igmp interface host verbose
 Ten-GigabitEthernet3/0/3(30.10.1.20):
   IGMP host is enabled.
   IGMP version: 2
# Display detailed IGMP information for user access interface Ten-GigabitEthernet 3/0/2 on the public network.
<Sysname> display igmp interface access-interface ten-gigabitethernet 3/0/2 verbose
 Multicast-UA0(102.1.1.2):
   IGMP is enabled.
   IGMP version: 2
   General query timer expiry (hh:mm:ss): 00:00:23
   Querier for IGMP: 102.1.1.2 (This router)
   Robustness: 2
   Startup-query: Off
   Join-by-session: Enabled
   User-VLAN-aggregation: Disabled
   Access interface: Ten-GigabitEthernet3/0/2
# Display detailed IGMP information for Multicast-UA 0 on the public network.
<Sysname> display igmp interface Multicast-UA 0 verbose
 Multicast-UA0(10.10.1.20):
   IGMP is enabled.
   IGMP version: 2
   Robustness: 2
   Startup-query: Off
   User-ID: 0x40000001
   VLAN ID: 100
   Second VLAN ID: 10
   User address: 1.1.1.1
   User profile: profile1
   Access type: IPoE
   Access interface: Ten-GigabitEthernet3/0/1.1
Table 7 Command output
Interface and its IP address.
IGMP is enabled
IGMP is enabled on the interface.
IGMP version
Version of IGMP that the interface runs.
IGMP general query interval, in seconds.
IGMP other querier present interval, in seconds.
Maximum response time for IGMP general queries, in seconds.
Interval for sending IGMP group-specific queries or IGMP group-and-source-specific queries, in seconds.
Number of IGMP group-specific queries or IGMP group-and-source-specific queries sent for the multicast group.
Interval for sending IGMP general queries on startup, in seconds.
Startup query count
Number of IGMP general queries that the device sends on startup.
Remaining time for the IGMP general query timer. This field displays Off if the timer is disabled.
Querier for IGMP
IP address of the IGMP querier.
This field is not displayed when the device runs IGMPv1 and the device is not the IGMP querier.
In IGMPv1, the PIM DR acts as the IGMP querier. You can use the display pim interface command to display PIM information.
No querier elected
No IGMP querier election is performed.
This field is displayed when the device runs IGMPv1 and is not the IGMP querier.
Statistics of IGMP activities:
·     join(s)—Total number of multicast groups that this interface has joined.
·     leave(s)—Total number of multicast groups that this interface has left.
Whether IP multicast routing is enabled: Enabled or Disabled.
Robustness
Robustness variable of the IGMP querier.
Whether the feature of dropping IGMP messages without Router-Alert is enabled: Enabled or Disabled,
Fast-leave
Whether the fast-leave processing feature is enabled: Enabled or Disabled.
Startup-query
Whether the IGMP querier sends IGMP general queries at the startup query interval on startup:
·     OnThe IGMP querier performs the above action.
·     OffThe IGMP querier does not perform the above action.
Remaining time for the other querier present timer. This field displays Off if the timer is disabled.
Authorization
Whether the multicast access control feature is enabled: Enabled or Disabled.
Join-by-session
Whether the per-session multicast forwarding feature is enabled: Enabled or Disabled.
VLAN tagging configuration for multicast packets:
·     Enabled—The multicast packet VLAN tagging feature is enabled.
·     Disabled—The multicast packet VLAN tagging feature is disabled.
·     Dynamic—The multicast packets are tagged with VLANs of online users.
·     Dot1q vid n1 second-dot1q n2—The multicast packets are tagged with outer VLAN ID n1 and inner VLAN ID n2.
User-ID
ID of the multicast user on the interface.
VLAN ID
Outer VLAN ID or the only VLAN ID in the multicast user's packets.
This field is not displayed if the user's packets are not tagged with VLAN IDs.
Second VLAN ID
Inner VLAN ID in the multicast user's packets.
User address
IP address of the multicast user.
This field is not displayed if the device does not obtain the user's IP address.
User profile
Name of the user profile assigned to the multicast user.
The multicast user can join multicast groups permitted by the IGMP user access control policy in the user profile. To configure an IGMP user access control policy, use the igmp access-policy command.
Access interface
Actual interface through which the multicast user accesses the network.
This field is displayed only when IGMP information is maintained on a multicast-UA interface.
VSRP instance (State is master, synchronization is on)
Name of the VSRP instance associated with the IGMP-enabled interface, VSRP instance status, and the status of IGMP data synchronization.
This field is not displayed if the interface is not associated with a VSRP instance.
VSRP instance status:
·     master—The device acts as the master in the VSRP instance.
·     backup—The device acts as the backup in the VSRP instance.
·     down—The device is not running in the VSRP instance.
·     unknown—The state of the device is unknown.
Status of IGMP data synchronization:
·     on—IGMP data synchronization is enabled on the interface.
·     off—IGMP data synchronization is disabled on the interface.
VSRP forwarding mode and switchback mode.
This field is not displayed if the interface is not associated with a VSRP instance or is not enabled with load balancing.
VSRP forwarding mode:
·     Odd—Forwards multicast flows with an odd-numbered multicast group address.
·     Even—Forwards multicast flows with an even-numbered multicast group address.
·     All—Forwards all multicast flows.
·     None—Does not forward any multicast flows.
Switchback mode:
·     Switchback delay—The switchback delay is 180 seconds.
·     No switchback.
Total number of multicast groups that the interface has joined dynamically.
This field is not displayed if the interface does not join multicast groups.
IGMP proxying is enabled on the interface.
The IGMP host feature is enabled on the interface.
Remaining time for the IGMPv1 querier present timer. This field displays Off if the timer is disabled.
Use display igmp proxy group to display information about multicast groups maintained by the IGMP proxy.
display igmp [ vpn-instance vpn-instance-name ] proxy group [ group-address | interface interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about multicast groups maintained by the IGMP proxy on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about all multicast groups maintained by the IGMP proxy.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about multicast groups maintained by the IGMP proxy for all interfaces.
# Display information about multicast groups maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy group
IGMP proxy group records in total: 2
 Ten-GigabitEthernet3/0/1(1.1.1.20):
   Group address      Member state      Expires
   225.1.1.1          Delay             00:00:02
   225.1.1.2          Idle              Off
# Display detailed information about multicast group 225.1.1.1 maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy group 225.1.1.1 verbose
   Group: 225.1.1.1
     Group mode: Include
     Member state: Delay
     Expires: 00:00:02
       1.1.1.1
Table 8 Command output
IGMP groups records in total
Total number of multicast groups maintained by the IGMP proxy.
IGMP proxy interface and its IP address.
Pending proxy group
Pending multicast groups maintained by the IGMP proxy.
Group address/Group
Member state
Member host states:
·     Delay—The member host has joined a group and started a delay timer.
·     Idle—The member host has joined a group, but didn't start a delay timer.
Expires
Remaining delay time for the member host to send a responding report. This field displays Off if the timer is disabled.
Group mode
Multicast source filtering mode: Include or Exclude.
Source list
Multicast source list for the multicast group maintained by the IGMP proxy.
sources in total
Total number of multicast sources.
Use display igmp proxy routing-table to display multicast routing entries maintained by the IGMP proxy.
display igmp [ vpn-instance vpn-instance-name ] proxy routing-table [ source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] ] * [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast routing entries maintained by the IGMP proxy on the public network.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays multicast routing entries for all multicast sources maintained by the IGMP proxy.
group-address: Specifies a multicast group address by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays multicast routing entries for all multicast groups maintained by the IGMP proxy.
mask-length: Specifies a mask length of the multicast group address or multicast source address. For a multicast source address, the value range for this argument is 0 to 32. For a multicast group address, the value range for this argument is 4 to 32. The default value is 32 in both cases.
mask: Specifies a mask of the multicast group address or multicast source address. The default value is 255.255.255.255.
verbose: Displays detailed information about multicast routing entries maintained by the IGMP proxy.
# Display multicast routing entries maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy routing-table
 Total 1 (*, G) entries, 2 (S, G) entries.
 (172.168.0.12, 227.0.0.1)
     Upstream interface: Ten-GigabitEthernet3/0/1
     Downstream interfaces (1 in total):
         1: Ten-GigabitEthernet3/0/2
             Protocol: IGMP
(*, 225.1.1.1)
             Protocol: STATIC
  (2.2.2.2, 225.1.1.1)
     Downstream interfaces (2 in total):
         1: LoopBack1
             Protocol: STATIC
         2: Ten-GigabitEthernet3/0/2
             Protocol: PROXY
# Display detailed information about multicast routing entries maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy routing-table verbose
             Protocol: IGMP
             Querier state: Querier
             Join/Prune state:Join
     Non-downstream interfaces: None
 (*, 225.1.1.1)
             Protocol: STATIC
     Non-downstream interfaces (1 in total):
             Protocol: IGMP
             Querier state: Non-querier
         1: LoopBack1
             Protocol: STATIC
             Join/Prune state: Join
             Protocol: PROXY
Table 9 Command output
Total number of (*, G) entries, and the total number of (S, G) entries.
(S, G) entry.
Upstream interface
Incoming interface of the (S, G) entry.
Outgoing interfaces of the (S, G) entry, and the total number of outgoing interfaces.
Non-outgoing interfaces of the (S, G) entry, and the total number of non-outgoing interfaces.
Index of an interface, and the interface.
Protocol
Protocol type:
·     IGMP—Dynamic IGMP.
·     PROXY—IGMP proxy.
·     STATIC—Static IGMP.
Querier state
Querier state:
·     Querier.
·     Non-querier.
Join/Prune state
Joined or pruned state of the interface:
·     NI—Default state.
·     Join—Joined state.
·     Prune—Pruned state.
Use display igmp ssm-mapping to display IGMP SSM mappings.
display igmp [ vpn-instance vpn-instance-name ] ssm-mapping group-address
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about the IGMP SSM mappings on the public network.
# Display IGMP SSM mappings for multicast group 232.1.1.1 on the public network.
<Sysname> display igmp ssm-mapping 232.1.1.1
 Group: 232.1.1.1
 Source list:
        1.2.3.4
        5.5.5.5
        10.1.1.1
        100.1.1.10
Table 10 Command output
Group
Source list
List of multicast source addresses.
Use display igmp user-info to display authorization information for IGMP users.
display igmp user-info [ access-type { ipoe | ppp } ] [ access-interface interface-type interface-number | interface interface-type interface-number ] [ user-id user-id-number | user-ip user-ip-address ] [ active-group group-address | active-user | inactive-user ] [ statistics ]
access-type: Specifies an access type.
ipoe: Specifies the IPoE users.
ppp: Specifies the PPP users.
access-interface interface-type interface-number: Specifies a user access interface by its type and number.
user-id user-id-number: Specifies an online multicast user by its ID, a hexadecimal integer in the range of 1 to 7FFFFF. The ID is automatically assigned to the user by the system.
user-ip user-ip-address: Specifies an online multicast user by its IP address.
active-group group-address: Displays information about IGMP users that have joined the specified authorized multicast group. The group-address argument specifies the address of the authorized multicast group, in the range of 224.0.1.0 to 239.255.255.255.
active-user: Specifies IGMP users that have joined multicast groups.
inactive-user: Specifies IGMP users that have not joined multicast groups.
statistics: Displays authorization statistics for IGMP users.
If you do not specify any parameters, this command displays authorization information for all IGMP users.
# Display authorization information for IGMP users.
<Sysname> display igmp user-info
 Authorized users in total: 2
   User name: user1@isp1
   Access type: PPP
   Interface: Multicast-UA2
   Access interface: Ten-GigabitEthernet3/0/1.2
   User address: 102.1.1.1
   Gateway address: 102.1.1.2
   User mac-address: 0010-9400-133c
   User ID: 0x20000002 (Session ID 0x1, VLAN ID 101)
   Maximum allowed groups: 4
   Authorized group list:
     225.0.0.1
   User name: user2
   Access type: IPoE
   Interface: Multicast-UA0
   User address: 101.1.1.1
   Gateway address: 101.1.1.2
   User mac-address: 0010-9400-134c
   User ID: 0x30000001 (VLAN ID 100, Second VLAN ID 10, Account ID 0x72)
     225.0.0.1
     225.0.0.2
     225.0.0.3
   Total ordered programs: 1
   Ordered program list:
      Group IP                     Source IP
      225.0.0.1                    0.0.0.0
# Display authorization information for IGMP users that have joined multicast groups.
<Sysname> display igmp user-info active-user
 Authorized users in total: 3
 Active users in total: 1
   Access type: PPP
     225.0.0.1
      Group IP                     Source IP
      225.0.0.1                    0.0.0.0
# Display authorization information for IGMP users that access the network through PPP.
<Sysname> display igmp user-info access-type ppp
 Matching users in total: 1
   Access type: PPP
     225.0.0.1
# Display authorization information for IGMP users that access the network through PPP and have joined multicast groups.
<Sysname> display igmp user-info access-type ppp active-user
   Access type: PPP
     225.0.0.1
      Group IP                     Source IP
      225.0.0.1                    0.0.0.0
# Display authorization information for IGMP users that have not joined multicast groups.
<Sysname> display igmp user-info inactive-user
 Inactive users in total: 1
   Access type: PPP
     225.0.0.1
# Display authorization statistics for IGMP users that have joined multicast groups.
<Sysname> display igmp user-info group 225.0.0.1 statistics
 Authorized users in total: 8
 Matching users in total: 2
Table 11 Command output
Total number of authorized access users.
Total number of access users that have joined the authorized multicast group.
Total number of access users that have not joined the authorized multicast group.
Total number of matching IGMP users.
Access type
Access type:
·     IPoE.
·     PPP.
Multicast user interface.
Access interface
Actual interface through which the user accesses the network.
User VPN-instance
Name of the VPN instance authorized to the user. This field is not displayed if no VPN instance is authorized to the user.
User address
IP address of the user. This field is not displayed if the device does not obtain the IP address of the user.
Gateway address
Gateway IP address of the user. This field is not displayed if the device does not obtain the gateway IP address of the user.
User mac-address
MAC address of the user. This field is not displayed if the device does not obtain the MAC address of the user.
User ID
ID of the user.
Leased user ID
ID of the IPoE leased user. This field is displayed only for IPoE leased users.
Session ID
ID of the user session. This field is displayed only for PPPoE users.
VLAN ID
Outer VLAN ID or the only VLAN ID in the user packets. This field is not displayed if the user's packets are not tagged with VLAN IDs.
Second VLAN ID
Inner VLAN ID in the user packets. This field is not displayed if the user's packets are not tagged with VLAN IDs.
Account ID
Account ID. The device collectively limits the traffic rate of users that share the same account.
This field is displayed only when the user is an IPoE or PPPoE user that shares a user account with other users. For more information about shared-account users, see AAA configuration in BRAS Services Configuration Guide.
PVC ID
PVC ID. This field is displayed only when the multicast user accesses the network through an ATM interface.
VSI index
VSI index. This field is displayed only when the multicast user accesses the network through a VXLAN tunnel interface.
Link ID
Link ID. This field is displayed only when the multicast user accesses the network through a VXLAN tunnel interface.
Maximum number of the multicast groups that the user can join.
User profile
Name of the user profile name assigned to the multicast user.
List of the multicast groups that the user is authorized to join.
Total number of IGMP users that have joined multicast groups.
Total number of multicast sources and groups that the user has actually joined.
List of multicast sources and groups that the user has actually joined.
Group IP
Address of the multicast group in a multicast source and group that the user has actually joined.
Source IP
Address of the multicast source in a multicast source and group that the user has actually joined.
This field displays 0.0.0.0 if the multicast user has joined a multicast group.
Use host-tracking enable to enable IGMP host tracking globally.
Use undo host-tracing enable to disable IGMP host tracking globally.
undo host-tracking enable
IGMP host tracking is disabled globally.
IGMP view
This feature allows the device to record IP addresses, running time, timeout time, and other information about receiver hosts. You can monitor and manage receiver hosts based on the recorded information.
You can enable IGMP host tracking globally for all interfaces, or use the igmp host-tracking enable command in interface view to enable host tracking for an interface. For an interface, the interface-specific configuration has higher priority than the global configuration.
# Enable IGMP host tracking globally on the public network.
[Sysname] igmp
[Sysname-igmp] host-tracking enable
# Enable IGMP host tracking globally in VPN instance mvpn.
[Sysname] igmp vpn-instance mvpn
[Sysname-igmp-mvpn] host-tracking enable
igmp
Use igmp to enter IGMP view.
Use undo igmp to delete the configurations in IGMP view.
undo igmp [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command applies to the public network.
# Enter IGMP view for the public network.
[Sysname] igmp
[Sysname-igmp]
# Enter IGMP view for the VPN instance mvpn.
[Sysname-igmp-mvpn]
igmp access-policy
Use igmp access-policy to configure an IGMP user access policy.
Use undo igmp access-policy to delete an IGMP user access policy.
igmp access-policy ipv4-acl-number
undo igmp access-policy ipv4-acl-number
No IGMP user access policy exists. IGMP users are not authorized to join any multicast groups.
User profile view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL number, in the range of 2000 to 3999. IGMP users can join only multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, IGMP users cannot join multicast groups.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
·     An ACL rule containing the vpn-instance vpn-instance option does not take effect.
·     In a basic ACL, the source source-address source-wildcard option specifies a multicast group address.
·     In an advanced ACL, the source source-address source-wildcard option specifies a multicast source address. The destination dest-address dest-wildcard option specifies a multicast group address.
To match the following IGMP reports, set the source source-address source-wildcard option to 0.0.0.0:
¡     IGMPv1 and IGMPv2 reports.
¡     IGMPv3 IS_EX and IGMPv3 TO_EX reports that do not carry multicast source addresses.
·     Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
# Configure an access policy in user profile abc to authorize IGMP users to join multicast group 225.1.1.2.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 225.1.1.2 0
[Sysname] user-profile abc
[Sysname-user-profile-abc] igmp access-policy 2000
igmp attack-defense
Use igmp attack-defense to enable IGMP attack defense on an interface.
Use undo igmp attack-defense to disable IGMP attack defense on an interface.
igmp attack-defense
IGMP attack defense is disabled on an interface.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
CAUTION
CAUTION:
Use this feature only on an interface that is configured with IPoE access authentication. If an interface is not configured with IPoE access authentication, this feature discards IGMP messages from all users and online users cannot join multicast groups.
This feature enables the device to process IGMP messages from online users and to discard IGMP messages from non-online users.
# Enable IGMP attack defense on Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] igmp attack-defense
Use igmp attack-suppression aging-time to set the aging time for IGMP suppression entries.
Use undo igmp attack-suppression aging-time to restore the default.
igmp attack-suppression { per-interface | source-ip | source-mac } aging-time time
undo igmp attack-suppression { per-interface | source-ip | source-mac } aging-time
The aging time is 30 seconds for IGMP suppression entries.
time: Specifies the aging time of IGMP suppression entries, in the range of 1 to 65535 seconds.
When the aging time of a source IP-based or source MAC-based IGMP suppression entry expires, the device ages out the entry and stops rate limiting packets from this IP or MAC address. Then, the device recounts the number of incoming IGMP packets from this source IP or MAC address to detect IGMP attacks.
When the aging time of the IGMP suppression entry on an interface expires, the device ages out the entry and stops limiting the packet rate only if no IGMP attack exists on the interface. Then, the device recounts the number of incoming IGMP packets on the interface to start a new IGMP suppression process.
This command takes effect only after you execute the igmp attack-suppression enable command.
If you execute the command multiple times, the most recent configuration takes effect.
# Set the aging time to 60 seconds for interface-based IGMP suppression entries.
[Sysname] igmp attack-suppression per-interface aging-time 60
# Set the aging time to 10 seconds for source IP-based IGMP suppression entries.
[Sysname] igmp attack-suppression source-ip aging-time 10
# Set the aging time to 100 seconds for source MAC-based IGMP suppression entries.
[Sysname] igmp attack-suppression source-mac aging-time 100
Use igmp attack-suppression check-interval to set the check interval for IGMP suppression.
Use undo igmp attack-suppression check-interval to restore the default.
igmp attack-suppression { per-interface | source-ip | source-mac } check-interval interval
undo igmp attack-suppression { per-interface | source-ip | source-mac } check-interval
The check interval is 30 seconds for IGMP suppression.
interval: Specifies the check interval for IGMP suppression, in the range of 1 to 255 seconds.
# Set the check interval to 10 seconds for interface-based IGMP suppression.
[Sysname] igmp attack-suppression per-interface check-interval 10
# Set the check interval to 20 seconds for source IP-based IGMP suppression.
[Sysname] igmp attack-suppression source-ip check-interval 20
# Set the check interval to 10 seconds for source MAC-based IGMP suppression.
[Sysname] igmp attack-suppression source-mac check-interval 10
Use igmp attack-suppression enable to enable IGMP suppression.
Use undo igmp attack-suppression enable to disable IGMP suppression.
igmp attack-suppression { per-interface | source-ip | source-mac } enable
undo igmp attack-suppression { per-interface | source-ip | source-mac } enable
IGMP suppression is disabled.
The source IP-based IGMP suppression feature creates IGMP suppression entries and counts the number of received IGMP packets on a per source IP address basis. When the number of packets received from an IP address exceeds the threshold within the check interval, the device identifies these packets as attack packets. To ensure CPU resource allocation for normal IGMP packets, the device drops the IGMP attack packets from the IP address.
The source MAC-based IGMP suppression feature creates IGMP suppression entries and counts the number of received IGMP packets on a per MAC address basis. When the number of IGMP packets from a MAC address exceeds the threshold within the check interval, the device identifies these packets as attack packets. To ensure CPU resource allocation for normal IGMP packets, the device drops the IGMP attack packets from the MAC address.
The interface-based IGMP suppression feature allows the device to create IGMP suppression entries and count the number of received IGMP packets on a per interface basis. When the number exceeds the threshold within the check interval, the device identifies these packets as attack packets and limits the rate for sending them to the CPU.
This feature takes effect only on Layer 3 Ethernet interfaces and Layer 3 Ethernet subinterfaces if you enable IGMP snooping globally on the device. IGMP packets received on VLAN interfaces and Layer 2 interfaces (such as Layer 2 aggregate interfaces) are processed at Layer 2.
# Enable interface-based IGMP suppression.
[Sysname] igmp attack-suppression per-interface enable
# Enable source IP-based IGMP suppression.
[Sysname] igmp attack-suppression source-ip enable
# Enable source MAC-based IGMP suppression.
[Sysname] igmp attack-suppression source-mac enable
Use igmp attack-suppression threshold to set the threshold for triggering IGMP suppression.
Use undo igmp attack-suppression threshold to restore the default.
igmp attack-suppression { per-interface | source-ip | source-mac } threshold threshold-value
undo igmp attack-suppression { per-interface | source-ip | source-mac } threshold
The threshold is 6000 for triggering interface-based IGMP suppression and is 1000 for triggering source IP-based IGMP suppression and source MAC-based IGMP suppression.
threshold-value: Specifies the threshold for triggering IGMP suppression, in the range of 1 to 4294967295. The threshold defines the maximum number of IGMP packets that can be received within the check interval.
Packets from an IP address or MAC address are attack packets if the number of received IGMP packets from this IP or MAC address exceeds the threshold within the check interval.
An interface is attacked if the number of received IGMP packets on the interface exceeds the threshold within the check interval.
# Set the threshold to 300 for triggering interface-based IGMP suppression.
[Sysname] igmp attack-suppression per-interface threshold 300
# Set the threshold to 300 for triggering source IP-based IGMP suppression.
[Sysname] igmp attack-suppression source-ip threshold 300
# Set the threshold to 400 for triggering source MAC-based IGMP suppression.
[Sysname] igmp attack-suppression source-mac threshold 400
Use igmp authorization-enable to enable the multicast access control feature.
Use undo igmp authorization-enable to disable the multicast access control feature.
The multicast access control feature is disabled.
VT interface view
This command takes effect only on local online users. Non-local users and offline users are not affected.
# Enable the multicast access control feature on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp authorization-enable
igmp enable
Use igmp enable to enable IGMP on an interface.
Use undo igmp enable to disable IGMP on an interface.
igmp enable
undo igmp enable
IGMP is disabled on an interface.
Interface view
This command takes effect only when IP multicast routing is enabled on the public network or for the VPN instance to which the interface belongs.
Other IGMP configurations on the interface take effects only when IGMP is enabled on the interface.
# Enable IP multicast routing on the public network, and enable IGMP on Ten-GigabitEthernet 3/0/1.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-Ten-GigabitEthernet3/0/1] igmp enable
multicast routing
igmp fast-leave
Use igmp fast-leave to enable fast-leave processing on an interface.
Use undo igmp fast-leave to disable fast-leave processing on an interface.
igmp fast-leave [ group-policy ipv4-acl-number ]
Fast-leave processing is disabled. The IGMP querier sends IGMP group-specific or group-and-source-specific queries after receiving a leave message.
Interface view
ipv4-acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, the fast-leave processing feature takes effect only on the multicast groups that the ACL permits. The feature takes effect on all multicast groups when one of the following conditions exists:
·     You do not specify an ACL.
·     The specified ACL does not exist.
·     The specified ACL does not have valid rules.
The fast-leave processing feature enables an IGMP querier to suppress IGMP group-specific or group-and-source-specific queries upon receiving IGMP leave messages permitted by the ACL.
When you configure a rule in the IPv4 basic ACL, follow these restrictions and guidelines:
·     The source source-address source-wildcard option specifies a multicast group address.
# Enable fast-leave processing on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp fast-leave
igmp group-policy
Use igmp group-policy to configure a multicast group policy on an interface to control the multicast groups that hosts attached to the interface can join.
Use undo igmp group-policy to delete the multicast group policy on an interface.
igmp group-policy { ipv4-acl-number | name ipv4-acl-name } [ version-number ]
No multicast group policy exists on an interface. Hosts attached to the interface can join any multicast groups.
Interface view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts can join only the multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, hosts cannot join any multicast groups.
name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with letters and it cannot be all. Hosts can join only the multicast groups that the ACL permits. If the ACL with the specified name does not exist or does not have valid rules, hosts cannot join any multicast groups.
version-number: Specifies an IGMP version in the range of 1 to 3. By default, this command takes effect on IGMP reports of all versions.
A multicast group policy filters IGMP reports to control the multicast groups that the hosts can join.
This command does not take effect on static member interfaces because static member interfaces do not send IGMP reports.
# Configure a multicast group policy on Ten-GigabitEthernet 3/0/1 so that hosts attached to the interface can join only multicast group 225.1.1.1.
[Sysname] acl basic 2005
[Sysname-acl-ipv4-basic-2005] rule permit source 225.1.1.1 0
[Sysname-acl-ipv4-basic-2005] quit
[Sysname-Ten-GigabitEthernet3/0/1] igmp group-policy 2005
Use igmp host-tracking enable to enable IGMP host tracking on an interface.
Use igmp host-tracking disable to disable IGMP host tracking on an interface.
Use undo igmp host-tracking to restore the default.
The interface-specific IGMP host tracking status is consistent with the global IGMP host tracking status.
Interface view
You can enable IGMP host tracking on an interface, or use the host-tracking enable command in IGMP view to enable IGMP host tracking for all interfaces. For an interface, the interface-specific configuration has higher priority than the global configuration.
# Enable IGMP host tracking on Ten-GigabitEthernet3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp host-tracking enable
Use igmp host-tracking limit to set the maximum number of hosts that can be tracked on an interface.
Use undo igmp host-tracking limit to restore the default.
igmp host-tracking limit limit
An interface can track a maximum of 4096 hosts.
Interface view
limit: Specifies the maximum number of hosts that can be tracked on an interface, in the range of 1 to 65535.
If you execute this command multiple times, the most recent configuration takes effect. When the maximum number is reached, new host records overwrite old ones.
# Set the maximum number to 2000 for hosts that can be tracked on Ten-GigabitEthernet3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp host-tracking limit 2000
Use igmp join-by-session to enable per-session multicast forwarding.
Use undo igmp join-by-session to restore the default.
igmp join-by-session [ mode { both | bras | non-bras } ]
Multicast data is forwarded on a per-interface basis.
mode: Specifies a user access type. If you do not specify this option, per-session multicast forwarding is enabled for users of all access types.
both: Specifies BRAS and non-BRAS user access types.
bras: Specifies the BRAS user access type, including IPoE and PPP.
non-bras: Specifies the non-BRAS user access type. Non-BRAS users refer to users that do not need to perform authentication.
This feature enables an interface to send a separate copy of multicast data to each user attached to the interface.
The igmp join-by-session and igmp user-vlan-aggregation commands are mutually exclusive. You cannot configure them on the same device.
# Enable per-session multicast forwarding on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp join-by-session
Use igmp last-member-query-count to set the IGMP last member query count on an interface.
Use undo igmp last-member-query-count to restore the default.
igmp last-member-query-count count
The IGMP last member query count equals the IGMP querier's robustness variable.
Interface view
count: Specifies an IGMP last member query count in the range of 1 to 255.
You can set the IGMP last member query count for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP last member query count to 6 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp last-member-query-count 6
Use igmp last-member-query-interval to set the IGMP last member query interval on an interface.
Use undo igmp last-member-query-interval to restore the default.
igmp last-member-query-interval interval
The IGMP last member query interval is 1 second.
Interface view
interval: Specifies an IGMP last member query interval in the range of 1 to 25 seconds.
You can set the IGMP last member query interval for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP last member query interval to 6 seconds on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp last-member-query-interval 6
Use igmp max-response-time to set the maximum response time for IGMP general queries on an interface.
Use undo igmp max-response-time to restore the default.
igmp max-response-time time
The maximum response time for IGMP general queries is 10 seconds.
Interface view
time: Specifies the maximum response time for IGMP general queries, in the range of 1 to 3174 seconds.
You can set the maximum response time for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the maximum response time for IGMP general queries to 25 seconds on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp max-response-time 25
Use igmp other-querier-present-interval to set the IGMP other querier present timer on an interface.
Use undo igmp other-querier-present-interval to restore the default.
igmp other-querier-present-interval interval
The IGMP other querier present timer is calculated by using the following formula:
[ IGMP general query interval ] × [ IGMP querier's robustness variable ] + [ maximum response time for IGMP general queries ] / 2.
Interface view
interval: Specifies an IGMP other querier present timer in the range of 1 to 31744 seconds.
You can set the IGMP other querier present timer for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP other querier present timer to 125 seconds on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp other-querier-present-interval 125
igmp proxy enable
Use igmp proxy enable to enable IGMP proxying on an interface.
Use to undo igmp proxy enable to disable IGMP proxying on an interface.
igmp proxy enable
IGMP proxying is disabled on an interface.
Interface view
# Enable IP multicast routing on the public network, and enable IGMP proxying on Ten-GigabitEthernet 3/0/1.
[Sysname] multicast routing-enable
[Sysname-Ten-GigabitEthernet3/0/1] igmp proxy enable
multicast routing
igmp proxy forwarding
Use igmp proxy forwarding to enable multicast forwarding on a non-querier interface.
Use undo igmp proxy forwarding to disable multicast forwarding on a non-querier interface.
Multicast forwarding is disabled for a non-querier interface.
Interface view
Typically, only IGMP queriers can forward multicast traffic but non-queriers cannot. This mechanism prevents multicast data from being repeatedly forwarded. If a router interface on the IGMP proxy failed the querier election, enable multicast forwarding on the interface to forward multicast data to attached receivers.
# Enable multicast forwarding on Ten-GigabitEthernet 3/0/1. (Ten-GigabitEthernet 3/0/1 is a non-querier interface on the IGMP proxy device.)
[Sysname-Ten-GigabitEthernet3/0/1] igmp proxy forwarding
igmp query-interval
Use igmp query-interval to set the IGMP general query interval on an interface.
Use undo igmp query-interval to restore the default.
igmp query-interval interval
The IGMP general query interval is 125 seconds.
Interface view
interval: Specifies an IGMP general query interval in the range of 1 to 31744 seconds.
You can set the IGMP general query interval for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP general query interval to 60 seconds on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp query-interval 60
query-interval (IGMP view)
igmp robust-count
Use igmp robust-count to set the IGMP querier's robustness variable on an interface.
Use undo igmp robust-count to restore the default.
igmp robust-count count
The IGMP querier's robustness variable is 2.
Interface view
count: Specifies an IGMP querier's robustness variable in the range of 1 to 255.
The IGMP querier's robustness variable defines the number of times to retransmit queries if packet loss occurs. A higher robustness variable makes the IGMP querier more robust, but it increases timeout time for multicast groups.
You can set the IGMP querier's robustness variable for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP querier's robustness variable to 5 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp robust-count 5
robust-count (IGMP view)
igmp startup-query-count
Use igmp startup-query-count to set the IGMP startup query count on an interface.
Use undo igmp startup-query-count to restore the default.
igmp startup-query-count count
The IGMP startup query count equals the IGMP querier's robustness variable.
Interface view
count: Specifies an IGMP startup query count in the range of 1 to 255.
You can set the IGMP startup query count for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP startup query count to 5 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp startup-query-count 5
startup-query-count (IGMP view)
igmp startup-query-interval
Use igmp startup-query-interval to set the IGMP startup query interval on an interface.
Use undo igmp startup-query-interval to restore the default.
igmp startup-query-interval interval
The IGMP startup query interval equals one quarter of the IGMP general query interval.
Interface view
interval: Specifies an IGMP startup query interval in the range of 1 to 31744 seconds.
You can set the IGMP startup query interval for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP startup query interval to 100 seconds on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp startup-query-interval 100
startup-query-interval (IGMP view)
igmp static-group
Use igmp static-group to configure an interface as a static group member of multicast groups.
Use undo igmp static-group to restore the default.
igmp static-group group-address [ inc-step-mask { group-mask | group-mask-length } number group-number ] [ source source-address ] [ dot1q vid vlan-list | dot1q vid vlan-id second-dot1q vlan-list ]
undo igmp static-group { all | group-address [ inc-step-mask { group-mask | group-mask-length } number group-number ] [ source source-address ] [ dot1q vid vlan-list | dot1q vid vlan-id second-dot1q vlan-list ] }
An interface is not a static group member of multicast groups.
Interface view
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. In the batch configuration, this multicast group address represents the start address.
inc-step-mask group-mask: Specifies the mask step for multicast groups in batch configuration, the gap between two adjacent multicast group addresses. The step mask is in the dotted decimal notation format, in the range of 0.0.0.1 to 15.255.255.255.
inc-step-mask group-mask-length: Specifies the mask length step for multicast groups in batch configuration. The mask length step is an integer in the range of 5 to 32.
group-number: Specifies the number of multicast groups in batch configuration, an integer in the range of 2 to 512.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command configures an interface as a static member of the multicast groups with all multicast source addresses.
dot1q vid vlan-list: Specifies a space-separated list of up to 10 inner VLAN ID items. Each item specifies an inner VLAN ID or a range of inner VLAN IDs in the form of start-vlan-id to end-vlan-id. The value range for VLAN IDs is 1 to 4094. If you specify this option, the command configures an interface as a single-VLAN-tagged static member interface for a multicast group. This option is supported in Layer 3 Ethernet subinterface view and Layer 3 aggregate subinterface view.
dot1q vid vlan-id second-dot1q vlan-list: Specifies the outer and inner VLAN IDs. The vlan-id argument specifies the outer VLAN ID in the range of 1 to 4094. The vlan-list argument specifies a space-separated list of up to 10 inner VLAN ID items. Each item specifies an inner VLAN ID or a range of inner VLAN IDs in the form of start-vlan-id to end-vlan-id. The value range for VLAN IDs is 1 to 4094. If you specify this option, the command configures an interface as a double-VLAN-tagged static member interface for a multicast group. This option is supported in Layer 3 Ethernet subinterface view and Layer 3 aggregate subinterface view.
all: Specifies all multicast groups that the interface has statically joined.
For multicast routing entries to be created, you must specify a multicast source if the specified multicast group is in the SSM group range.
When you configure an interface as a static group member of multiple multicast groups or multicast sources and groups in batch, follow these restrictions and guidelines:
·     Multicast group addresses in different batch configurations can overlap.
·     The undo command does not support deleting one multicast group from batch configuration. When you delete a batch configuration, make sure the setting in the undo command matches the batch configuration.
·     If two batch configurations have the same parameter settings except the setting of the number group-number option, the new configuration takes effect.
If you specify a mask length step in batch configuration, the system coverts the mask length to the mask in the output from the display current-configuration command. The conversion format is group-mask = 1 << (32 – group-mask-length), where the double left angle brackets (<<) is a bitwise left shift operator. For example, 1 << 0 represents 0.0.0.1, 1 << 1 represents 0.0.0.2, and 1 << 3 represents 0.0.0.8.
For the same multicast group, the non-VLAN-based, single-VLAN-based, or double-VLAN-based static member interface configurations are mutually exclusive.
When you configure a subinterface as a non-VLAN-based static member interface, do not configure the igmp join-by-session or igmp user-vlan-aggregation command on this subinterface. If you configure either of the commands on the subinterface, static multicast forwarding entries cannot be created.
When you configure a subinterface as a VLAN-based static member interface, a static multicast forwarding entry can be created under either of the following conditions:
·     Users that belong to the specified VLANs come online if the igmp user-vlan-aggregation command is not configured on the subinterface.
·     The VLAN IDs specified in this command are the same as or included in the VLAN IDs specified in the igmp user-vlan-aggregation command configured on the subinterface.
# Configure Ten-GigabitEthernet 3/0/1 as a static group member of multicast group 224.1.1.1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp static-group 224.1.1.1
# Configure Ten-GigabitEthernet 3/0/1 as a static group member of multicast source and group (192.168.1.1, 232.1.1.1).
[Sysname-Ten-GigabitEthernet3/0/1] igmp static-group 232.1.1.1 source 192.168.1.1
# Enable per-session multicast forwarding on Ten-GigabitEthernet 3/0/1.1. Configure the subinterface as a static group member of multicast group 224.1.1.1 for users with outer VLAN ID 10 and inner VLAN IDs in the range of 10 to 20.
[Sysname] interface ten-gigabitethernet 3/0/1.1
[Sysname-Ten-GigabitEthernet3/0/1.1] igmp join-by-session
[Sysname-Ten-GigabitEthernet3/0/1.1] igmp static-group 224.1.1.1 dot1q vid 10 second-dot1q 10 to 20
# Configure Ten-GigabitEthernet 3/0/1 as a static group member of multicast groups 224.1.1.1 and 224.1.1.2 in batch. In the batch configuration, the start multicast group address is 224.1.1.1, the mask step is 0.0.0.1, and the number of multicast groups is 2.
[Sysname-Ten-GigabitEthernet3/0/1] igmp static-group 224.1.1.1 inc-step-mask 0.0.0.1 number 2
# Configure Ten-GigabitEthernet 3/0/1 as a static group member of multicast sources and groups (192.168.1.1, 224.1.1.1) and (192.168.1.1, 224.1.1.2) in batch. In the batch configuration, the start multicast group address is 224.1.1.1, the multicast source address is 192.168.1.1, the mask step is 0.0.0.1, and the number of multicast groups is 2.
[Sysname-Ten-GigabitEthernet3/0/1] igmp static-group 224.1.1.1 inc-step-mask 0.0.0.1 number 2 source 192.168.1.1
# Configure Ten-GigabitEthernet 3/0/1.1 as a VLAN-based static group member of multicast groups 224.1.1.1 and 224.1.1.2 in batch. In the batch configuration, the start multicast group address is 224.1.1.1, the mask step is 0.0.0.1, the number of multicast groups is 2, and the VLAN ID is 10.
[Sysname-Ten-GigabitEthernet3/0/1.1] igmp static-group 224.1.1.1 inc-step-mask 0.0.0.1 number 2 dot1q vid 10
Use igmp user-vlan-aggregation to configure VLAN tagging for multicast packets.
Use undo igmp user-vlan-aggregation to restore the default.
igmp user-vlan-aggregation { dynamic | dot1q vid vlan-id [ second-dot1q vlan-id ] }
The multicast packets are not tagged.
dynamic: Tags multicast packets with the VLANs of online users. This keyword is used in dynamic tagging of multicast packets.
dot1q vid vlan-id: Specifies an outer VLAN ID in the range of 1 to 4094. This keyword is used in static tagging of multicast packets.
second-dot1q vlan-id: Specifies an inner VLAN ID in the range of 1 to 4094. This keyword is used in static tagging of multicast packets.
The dynamic tagging method is exclusive with the static tagging method for multicast packets. The VLANs specified in the static tagging method must be VLANs allowed by the interface.
When users of a multicast group are in different VLANs, the device processes a multicast packet of this group as follows:
·     In static tagging mode, the device tags the multicast packet with the specified VLAN ID and sends the tagged multicast packet to the downstream device.
·     In dynamic tagging mode, the device first duplicates the multicast packet according to the number of VLANs of the multicast users. Then, it tags each multicast packet with a user VLAN ID and sends the tagged multicast packets to the downstream device.
Before you configure dynamic VLAN tagging or cancel the configuration, first log out all online users. Otherwise, the configuration or the cancellation does not take effect and an error occurs.
This command does not take effect on PPPoE users.
An IGMP user access policy does not  take effect for the static VLAN tagging mode.
# Configure the multicast packets to be tagged with outer VLAN ID 10 and inner VLAN ID 20 on Ten-GigabitEthernet 3/0/1.1.
[Sysname-Ten-GigabitEthernet3/0/1.1] vlan-type dot1q vid 10 second-dot1q 1 to 100
[Sysname-Ten-GigabitEthernet3/0/1.1] igmp user-vlan-aggregation dot1q vid 10 second-dot1q 20
# Configure dynamic VLAN tagging for multicast packets on Ten-GigabitEthernet 3/0/1.1.
[Sysname-Ten-GigabitEthernet3/0/1.1] igmp user-vlan-aggregation dynamic
igmp version
Use igmp version to specify an IGMP version on an interface.
Use undo igmp version to restore the default.
igmp version version-number
undo igmp version
The IGMP version on an interface is 2.
Interface view
CAUTION
CAUTION:
For IGMP to operate correctly, specify the same IGMP version for all routers on the same subnet.
# Specify IGMP version 1 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] igmp version 1
last-member-query-count (IGMP view)
Use last-member-query-count to set the IGMP last member query count globally.
Use undo last-member-query-count to restore the default.
IGMP view
You can set the IGMP last member query count globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP last member query count to 6 on the public network.
[Sysname] igmp
[Sysname-igmp] last-member-query-count 6
last-member-query-interval (IGMP view)
Use last-member-query-interval to set the IGMP last member query interval globally.
Use undo last-member-query-interval to restore the default.
IGMP view
You can set the IGMP last member query interval globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP last member query interval to 6 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] last-member-query-interval 6
max-response-time (IGMP view)
Use max-response-time to set the maximum response time for IGMP general queries globally.
Use undo max-response-time to restore the default.
IGMP view
time: Specifies the maximum response time for IGMP general queries in the range of 1 to 3174 seconds.
You can set the maximum response time globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
#Set the global maximum response time for IGMP general queries to 25 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] max-response-time 25
other-querier-present-interval (IGMP view)
Use other-querier-present-interval to set the IGMP other querier present timer globally.
Use undo other-querier-present-interval to restore the default.
IGMP view
You can set the IGMP other querier present timer globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP other querier present timer to 125 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] other-querier-present-interval 125
proxy multipath (IGMP view)
Use proxy multipath to enable load splitting on an IGMP proxy device.
Use undo proxy multipath to disable load splitting on an IGMP proxy device.
proxy multipath
The load splitting feature is disabled on the IGMP proxy device.
IGMP view
Use this feature when the IGMP proxy device has multiple proxy interfaces. All proxy interfaces on the IGMP proxy device share multicast traffic on a per-group basis. If you do not enable this feature, only the proxy interface with the highest IP address forwards multicast data.
# Enable load splitting on the IGMP proxy device on the public network.
[Sysname] igmp
[Sysname-igmp] proxy multipath
Use query-interval to set the IGMP general query interval globally.
Use undo query-interval to restore the default.
undo query-interval
IGMP view
You can set the IGMP general query interval globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP general query interval to 60 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] query-interval 60
igmp query-interval
reset igmp attack-suppression entry
Use reset igmp attack-suppression entry to remove IGMP suppression entries.
reset igmp attack-suppression entry { all { per-interface | source-ip | source-mac } | slot slot-number { per-interface { all | interface interface-type interface-number } | source-ip { all | [ interface interface-type interface-number | ip-address address ] * } | source-mac { all | [ interface interface-type interface-number | mac-address address ] * } }
per-interface: Specifies interface-based IGMP suppression.
source-ip: Specifies source IP-based IGMP suppression.
source-mac: Specifies source MAC-based IGMP suppression.
all: Specifies all cards (the first all keyword), or specifies all interface-based, source IP-based, or source MAC-based IGMP suppression entries (last three all keywords).
slot slot-number: Specifies a card by its slot number.
mac-address address: Specifies a source MAC address.
ip-address address: Specifies a source IP address.
# Remove all interface-based IGMP suppression entries.
<Sysname> reset igmp attack-suppression entry per-interface all
# Remove all source IP-based IGMP suppression entries.
<Sysname> reset igmp attack-suppression entry source-ip all
# Remove all source MAC-based IGMP suppression entries.
<Sysname> reset igmp attack-suppression entry source-mac all
display igmp attack-suppression entry
reset igmp attack-suppression statistics
Use reset igmp attack-suppression statistics to clear IGMP packet statistics about IGMP suppression entries.
reset igmp attack-suppression statistics { all { per-interface | source-ip | source-mac } | slot slot-number {  per-interface { all | interface interface-type interface-number } | source-ip { all | [ interface interface-type interface-number | ip-address address ] * } | source-mac { all | [ interface interface-type interface-number | mac-address address ] * } }
This command clears statistics of the following fields in the output from the display igmp attack-suppression per-interface entry verbose command: CPU receive, CPU drop, and Drv drop.
# Clear IGMP packet statistics about all interface-based IGMP suppression entries.
<Sysname> reset igmp attack-suppression statistics per-interface all
# Clear IGMP packet statistics about all source IP-based IGMP suppression entries.
<Sysname> reset igmp attack-suppression statistics source-ip all
# Clear IGMP packet statistics about all source MAC-based IGMP suppression entries.
<Sysname> reset igmp attack-suppression statistics source-mac all
reset igmp group
Use reset igmp group to clear dynamic IGMP multicast group entries.
reset igmp [ vpn-instance vpn-instance-name ] group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears dynamic IGMP multicast group entries on the public network.
all: Specifies all interfaces (the first all keyword), or all IGMP multicast groups (the second all keyword).
source-address: Specifies a multicast source address. If you do not specify a multicast source, this command clears dynamic IGMP multicast group entries for all multicast source addresses.
mask: Specifies an address mask. The default is 255.255.255.255.
mask-length: Specifies an address mask length. The default is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
CAUTION
CAUTION:
This command might cause multicast data transmission failures.
# Clear dynamic IGMP multicast group entries for all interfaces on the public network.
<Sysname> reset igmp group all
# Clear all dynamic IGMP multicast group entries for Ten-GigabitEthernet 3/0/1 on the public network.
<Sysname> reset igmp group interface ten-gigabitethernet 3/0/1 all
# Clear the dynamic IGMP multicast group entry of group 225.0.0.1 for Ten-GigabitEthernet 3/0/1 on the public network.
<Sysname> reset igmp group interface ten-gigabitethernet 3/0/1 225.0.0.1
display igmp group
Use robust-count to set the IGMP querier's robustness variable globally.
Use undo robust-count to restore the default.
robust-count count
undo robust-count
IGMP view
The IGMP querier's robustness variable defines the number of times to retransmit queries if packet loss occurs. A higher robustness variable makes the IGMP querier more robust, but it increases the timeout time for multicast groups.
You can set the IGMP querier's robustness variable globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP querier's robustness variable to 5 on the public network.
[Sysname] igmp
[Sysname-igmp] robust-count 5
igmp robust-count
snmp-agent trap enable igmp
Use snmp-agent trap enable igmp to enable SNMP notifications for IGMP.
Use undo snmp-agent trap enable igmp to disable SNMP notifications for IGMP.
snmp-agent trap enable igmp [ join | leave ] *
undo snmp-agent trap enable igmp [ join | leave ] *
SNMP notifications for IGMP are enabled.
join: Specifies notifications when an IGMP report is received.
leave: Specifies notifications when an IGMP leave message is received.
If you do not specify an optional keyword, this command enables or disables IGMP to generate all SNMP notifications.
To report critical IGMP events to an NMS, enable SNMP notifications for IGMP. For IGMP event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable all SNMP notifications for IGMP.
[Sysname] undo snmp-agent trap enable igmp
ssm-mapping (IGMP view)
Use ssm-mapping to configure an IGMP SSM mapping.
Use undo ssm-mapping to delete IGMP SSM mappings.
ssm-mapping source-address { ipv4-acl-number| name ipv4-acl-name }
undo ssm-mapping { source-address | all }
No IGMP SSM mappings exist.
IGMP view
ipv4-acl-number: Specifies a basic ACL number in the range of 2000 to 2999. Multicast groups in IGMP reports permitted by the ACL are associated with the multicast source. If the ACL does not exist or does not have valid rules, no multicast groups are associated with the IPv6 multicast source.
name ipv4-acl-name: Specifies an IPv4 basic ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with letters and it cannot be all. Multicast groups in IGMP reports permitted by the ACL are mapped to the specified multicast source. If the ACL with the specified name does not exist or does not have valid rules, no multicast groups are mapped to the specified multicast source.
all: Specifies all IGMP SSM mappings.
# Configure an IGMP SSM mapping with multicast source 125.1.1.1 and multicast group range 232.1.1.0/24 on the public network.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 232.1.1.1 0.0.0.255
[Sysname] igmp
[Sysname-igmp] ssm-mapping 125.1.1.1 2001
Use startup-query-count to set the IGMP startup query count globally.
Use undo startup-query-count to restore the default.
IGMP view
You can set the IGMP startup query count globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP startup query count to 5 on the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-count 5
Use startup-query-interval to set the IGMP startup query interval globally.
Use undo startup-query-interval to restore the default.
IGMP view
You can set the IGMP startup query interval globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP startup query interval to 100 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-interval 100
