06-Layer 3—IP Services Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command Reference-R838x-6W10106-Layer 3—IP Services Command Reference
12-IPv6 fast forwarding commands
12-IPv6 fast forwarding commands 62.10 KB
display ipv6 fast-forwarding aging-time
Use display ipv6 fast-forwarding aging-time to display the aging time of IPv6 fast forwarding entries.
# Display the aging time of IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding aging-time
Aging time: 30s
Aging time
Aging time of IPv6 fast forwarding entries, in seconds.
display ipv6 fast-forwarding cache
Use display ipv6 fast-forwarding cache to display IPv6 fast forwarding entries.
In standalone mode:
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display ipv6 fast-forwarding cache [ ipv6-address ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast forwarding entries.
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command displays IPv6 fast forwarding entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 fast forwarding entries for all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
# Display all IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding cache
Total number of IPv6 fast-forwarding items: 2
Src IP: 2002::1                                        Src port: 129
Dst IP: 2001::1                                        Dst port: 65535
Protocol: 58
VPN instance: vpn1
Input interface: XGE3/1/2
Output interface: XGE3/1/1
Src IP: 2001::1                                        Src port: 128
Dst IP: 2002::1                                        Dst port: 0
Protocol: 58
VPN instance: vpn2
Input interface: XGE3/1/1
Output interface: XGE3/1/2
Number of IPv6 fast forwarding entries.
Src IP
Source IPv6 address.
Src port
Source port number.
Dst IP
Destination IPv6 address.
Dst Port
Destination port number.
Protocol
Protocol number.
VPN instance
VPN instance.
Input interface
Input interface type and number.
If no interface is involved in fast forwarding, this field displays N/A.
If the input interface does not exist, this field displays a hyphen (-).
Output interface
Output interface type and number.
If the output interface does not exist, this field displays a hyphen (-).
reset ipv6 fast-forwarding cache
Use ipv6 fast-forwarding aging-time to set the aging time for IPv6 fast forwarding entries.
Use undo ipv6 fast-forwarding aging-time to restore the default.
ipv6 fast-forwarding aging-time aging-time
The aging time is 30 seconds.
aging-time: Sets the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for IPv6 fast forwarding entries.
[Sysname] ipv6 fast-forwarding aging-time 20
ipv6 fast-forwarding load-sharing
Use ipv6 fast-forwarding load-sharing to enable IPv6 fast forwarding load sharing.
Use undo ipv6 fast-forwarding load-sharing to disable IPv6 fast forwarding load sharing.
IPv6 fast forwarding load sharing is enabled.
IPv6 fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the five-tuple (source IP, source port, destination IP, destination port, and protocol).
If IPv6 fast forwarding load sharing is disabled, the device identifies a data flow by the five-tuple and the input interface. No load sharing is implemented.
# Enable IPv6 fast forwarding load sharing.
<Sysname> system-Views
[Sysname] ipv6 fast-forwarding load-sharing
Use reset ipv6 fast-forwarding cache to clear the IPv6 fast forwarding table.
In standalone mode:
reset ipv6 fast-forwarding cache [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset ipv6 fast-forwarding cache [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears the IPv6 fast forwarding table for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears the IPv6 fast forwarding table for all cards. (In IRF mode.)
# Clear the IPv6 fast forwarding table.
<Sysname> reset ipv6 fast-forwarding cache
