06-Layer 3—IP Services Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command Reference-R838x-6W10106-Layer 3—IP Services Command Reference
05-IP forwarding basics commands
05-IP forwarding basics commands 165.52 KB
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
In standalone mode:
display fib | vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ] [ slot slot-number ]
In IRF mode:
display fib | vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ] [chassis chassis-number slot slot-number]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays FIB entries on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays FIB entries on all cards. (In IRF mode.)
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Route destination count: 5
Directly-connected host count: 0
Flag:
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
1.1.1.0/24         192.168.126.1   USGF     MGE0/0/0                Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Route destination count: 6
Flag:
  R:Relay     F:FRR
20.20.20.0/24      20.20.20.25     U        MGE0/0/0                Null
20.20.20.0/32      20.20.20.25     UBH      MGE0/0/0                Null
20.20.20.25/32     127.0.0.1       UH       InLoop0                  Null
20.20.20.255/32    20.20.20.25     UBH      MGE0/0/0                Null
20.20.20.255/32    2001::1         UBH      MGE0/0/0                Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
FIB entry count: 1
Flag:
  R:Relay     F:FRR
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
Number of route destination addresses.
Number of directly-connected hosts that are learned through features such as ARP.
FIB entry count
Total number of FIB entries.
Destination/Mask
Destination address and the mask length.
Nexthop
Next hop address.
Flag
Flags of routes:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Blackhole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Relay route.
·     F—Fast reroute.
OutInterface/Token
Output interface/LSP index number.
Label
Inner label.
display fib count
Use display fib count to display FIB entry statistics.
In standalone mode:
display fib count [ all | vpn-instance vpn-instance-name ] slot slot-number
In IRF mode:
display fib count [ all | vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
all: Displays FIB entry statistics for the public network and all VPN instances.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
If you do not specify the all or vpn-instance keyword, this command displays FIB entry statistics for the public network.
# Display FIB entry statistics for the public network and all VPN instances on slot 1. (In standalone mode.)
[Sysname] display fib count all slot 1
Total count: 3121
VPN-Instance Name      Route destination count      Directly-connected host count
1                      100                          3
vpn1                   1000                         10
vpn2                   2000                         2
# Display FIB entry statistics for the public network on slot 1.
[Sysname] display fib count slot 1
# Display FIB entry statistics for the public network and all VPN instances on slot 1. (In IRF mode.)
[Sysname] display fib count all chassis 1 slot 1
Total count: 3121
1                      100                          3
vpn1                   1000                         10
vpn2                   2000                         2
[Sysname] display fib count chassis 1 slot 1
Total count
Number of FIB entries.
VPN-Instance Name
VPN instance name.
fib log enable
Use fib log enable to enable FIB logging.
Use undo fib log enable to disable FIB logging.
fib log enable
undo fib log enable
FIB logging is disabled.
The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
To avoid memory consumption caused by log recording, you can use the undo fib log enable command to disable FIB logging.
# Enable FIB logging.
[Sysname] fib log enable
fib max-number
Use fib max-number to specify the maximum number of FIB entries on an interface module.
Use undo fib max-number to restore the default.
In standalone mode:
fib max-number max-number slot slot-number
undo fib max-number
In IRF mode:
fib max-number max-number chassis chassis-number slot slot-number
undo fib max-number
The maximum number of FIB entries on an interface module is the maximum number of FIB entries supported by the device.
max-number: Specifies the maximum number of IPv4 FIB entries on an interface module, in the range of 0 to 4294967295.
slot slot-number: Specifies an interface module by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an interface module on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the interface module. (In IRF mode.)
To save memory resources, you can use this command to decrease the maximum number of FIB entries on an interface module.
If the value for the max-number argument exceeds the maximum number supported by the device, the configuration does not take effect on interface modules. The maximum number supported by the device is then applied to the interface modules.
If the number of FIB entries has reached max-number on an interface module, the module stops accepting new FIB entries issued by the MPU. The existing services on the module are not affected. If the MPU deletes some old FIB entries and notifies the interface module to delete the entries, the interface module can accept new FIB entries until the upper limit is reached again.
# Specify the maximum number of FIB entries on the interface module in slot 1 as 1000.
[Sysname] fib max-number 1000 slot 1
fib smooth
Use fib smooth to perform one-time FIB entry synchronization.
In standalone mode:
fib smooth slot slot-number
In IRF mode:
fib smooth chassis chassis-number slot slot-number
Perform this task to synchronize FIB entries from the MPU to the specified interface module.
If the maximum number of IPv4 or IPv6 FIB entries (specified by using the fib max-number or ipv6 fib max-number command) is reached on the interface module, the module stops accepting new entries.
# Perform one-time FIB entry synchronization.
[Sysname] fib smooth slot 1
fib max-number
ipv6 fib max-number
fib switch-enhance
Use fib switch-enhance to enable FIB route switching optimization.
Use undo fib switch-enhance to restore the default.
fib switch-enhance
FIB route switching optimization is disabled.
This feature is applicable to scenarios with high service traffic sustainability requirements. It enables the device to keep using the current route until the new route becomes available, instead of disconnecting the current route directly. This prevents packet loss caused by route switch, which might take hundreds of milliseconds.
The device can keep using the current route for a maximum of 10 seconds.
# Enable FIB route switching optimization.
[Sysname] fib switch-enhance
ip forwarding
Use ip forwarding to enable IPv4 packet forwarding on an interface that has no IPv4 address configured.
Use undo ip forwarding to disable IPv4 packet forwarding on an interface that has no IPv4 address configured.
ip forwarding
undo ip forwarding
If an interface has no IPv4 address configured, it cannot forward IPv4 packets.
Interface view
On a device that supports both IPv4 and IPv6, the next hop of an IPv4 packet might be an IPv4 address or an IPv6 address. If the output interface has no IPv4 address configured, the interface cannot forward the IPv4 packet. To solve this problem, execute this command on the interface. This feature allows the interface to forward IPv4 packets even though the interface has no IPv4 address configured.
# Enable IPv4 packet forwarding on Ten-GigabitEthernet 3/1/1 that has no IPv4 address configured.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] ip forwarding
# Enable IPv4 packet forwarding on VLAN-interface 1 that has no IPv4 address configured.
[Sysname-Vlan-interface1] ip forwarding
ip forwarding-table save
Use ip forwarding-table save to save the IP forwarding entries to a file.
ip forwarding-table save filename filename
filename filename: Specifies the name of a file, a string of 1 to 255 characters. For information about the filename argument, see Fundamentals Configuration Guide.
The command automatically creates the file if you specify a nonexistent file. If the file already exists, this command overwrites the file content.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
# Save the IP forwarding entries to the fib.txt file.
<Sysname> ip forwarding-table save filename fib.txt
ipv6 forwarding
Use ipv6 forwarding to enable IPv6 packet forwarding on an interface that has no IPv6 address configured.
Use undo ipv6 forwarding to disable IPv6 packet forwarding on an interface that has no IPv6 address configured.
ipv6 forwarding
If an interface has no IPv6 address configured, it cannot forward IPv6 packets.
Interface view
On a device that supports both IPv4 and IPv6, the next hop of an IPv6 packet might be an IPv4 address or an IPv6 address. If the output interface has no IPv6 address configured, the interface cannot forward the IPv6 packet. To solve this problem, execute this command on the interface. This feature allows the interface to forward IPv6 packets even though the interface has no IPv6 address configured.
# Enable IPv6 packet forwarding on Ten-GigabitEthernet 3/1/1 that has no IPv6 address configured.
[Sysname-Ten-GigabitEthernet3/1/1] ipv6 forwarding
# Enable IPv6 packet forwarding on VLAN-interface 1 that has no IPv6 address configured.
[Sysname-Vlan-interface1] ipv6 forwarding
snmp-agent trap enable fib
Use snmp-agent trap enable fib to enable SNMP notifications for FIB events.
Use undo snmp-agent trap enable fib to disable SNMP notifications for FIB events.
SNMP notifications for FIB events are enabled.
This feature enables the FIB module to generate SNMP notifications for critical FIB events. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for FIB events.
[Sysname] undo snmp-agent trap enable fib
snmp-agent trap enable ip-forwarding
Use snmp-agent trap enable ip-forwarding to enable SNMP notifications for IP forwarding events.
Use undo snmp-agent trap enable ip-forwarding to disable SNMP notifications for IP forwarding events.
SNMP notifications for IP forwarding events are enabled.
This feature enables the IP forwarding module to generate SNMP notifications for critical IP forwarding events. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for IP forwarding events.
[Sysname] undo snmp-agent trap enable ip-forwarding
Load sharing commands
bandwidth-based-sharing
Use bandwidth-based-sharing to enable IPv4 load sharing based on bandwidth.
Use undo bandwidth-based-sharing to disable IPv4 load sharing based on bandwidth.
The IPv4 load sharing based on bandwidth is disabled.
This feature load shares flow traffic among multiple output interfaces based on their load percentages. The device calculates the load percentage for each output interface in terms of their expected bandwidths.
Devices that run load sharing protocols, such as Locator/ID Separation Protocol (LISP), implement load sharing based on the ratios defined by these protocols.
Only the incoming traffic on the following cards supports bandwidth-based IPv4 load sharing:
Card category
Cards
CEPC
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RXA, CEPC-CP4RX-L, CEPC-CQ8L, CEPC-CQ8LA, CEPC-CQ16L1, CEPC-CQ8L1A
CSPEX
CSPEX-1304X, CSPEX-1404X, CSPEX-1502X, CSPEX-1504X, CSPEX-1504XA, CSPEX-1602X, CSPEX-1602XA, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1802X, CSPEX-1802XA, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-1502XA,CSPEX-2612XA
SPE
RX-SPE200, RX-SPE200-E
# Enable IPv4 load sharing based on bandwidth.
[Sysname] bandwidth-based-sharing
display ip load-sharing mode
Use display ip load-sharing mode to display the load sharing mode in use.
In standalone mode:
display ip load-sharing mode slot slot-number [ cpu cpu-number ]
In IRF mode:
display ip load-sharing mode chassis chassis-number slot slot-number [ cpu cpu-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the load sharing mode for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the load sharing mode for all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
# Display the load sharing mode in use.
<Sysname> display ip load-sharing mode slot 1
Load-sharing mode: per-flow
Load-sharing options: dest-ip | src-ip | ip-pro | dest-port | src-port | dest-mac | src-mac | ingress-port
Load-sharing algorithm: 1
IP tunnel load-sharing mode: outer
Load-sharing mode
The load sharing mode in use:
·     per-packet—Per-packet load sharing.
·     per-flow—Per-flow load sharing.
Options configured for load sharing:
·     dest-ip—Identifies flows by packet's destination IP address.
·     src-ip—Identifies flows by packet's source IP address.
·     ip-pro—Identifies flows by packet's IP protocol.
·     dest-port—Identifies flows by packet's destination port number.
·     src-port—Identifies flows by packet's source port number.
·     ingress-port—Identifies flows by packet's ingress port.
·     dest-mac—Identifies flows by packet's destination MAC address.
·     src-mac—Identifies flows by packet's source MAC address.
Algorithm used by load sharing.
Load sharing for IP tunnel packets:
·     all—Identifies flows by inner and outer IP header information.
·     inner—Identifies flows by inner IP header information.
·     outer—Identifies flows by outer IP header information.
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
In standalone mode:
ip load-sharing mode { per-flow [ algorithm algorithm-number |  | [ dest-ip | dest-mac | dest-port | ip-pro | src-ip | src-mac | src-port ] * |per-packet  } { global | slot slot-number [ cpu cpu-number ] }
undo ip load-sharing mode [ per-flow { algorithm } ] { global | slot slot-number [ cpu cpu-number ] }
In IRF mode:
ip load-sharing mode { per-flow [ algorithm algorithm-number | [ dest-ip | dest-mac | dest-port | ip-pro | src-ip | src-mac | src-port ] * | per-packet } { chassis chassis-number slot slot-number [ cpu cpu-number ] | global }
undo ip load-sharing mode [ per-flow { algorithm } ] { chassis chassis-number slot slot-number [ cpu cpu-number ] | global }
The device implements per-flow load sharing.
·     For fragmented packets, the device uses the dest-ip and src-ip loading sharing modes.
·     For non-fragmented packets, the default load sharing modes vary by module model.
Table 4 shows the default load sharing modes used by the following cards:
Card category
Cards
CEPC
CSPEX
SPE
RX-SPE200
Table 4 Default load sharing modes
Packet type
IP unicast packets
dest-ip, src-ip
IP multicast packets
dest-mac, src-mac
Layer 2 frames
dest-mac, src-mac
MPLS L3VPN packets
dest-ip, src-ip
MPLS L2VPN packets
·     IP packets: dest-ip, src-ip
·     Other packets: dest-mac, src-mac
MPLS LSPs
·     IP packets: mpls-label1, mpls-label2, dest-ip, src-ip
·     Other packets: mpls-label1, mpls-label2, dest-mac, src-mac
Other MPLS packets
IP tunnel packets
·     IP packets: inner dest-ip, inner src-ip
·     Non-termination MPLS packets: mpls-label1, mpls-label2
Table 5 shows the default load sharing modes used by the following cards:
Card category
Cards
CEPC
CSPEX
CSPEX-1802X, CSPEX-1802XA, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-1502XA, CSPEX-2612XA
SPE
RX-SPE200-E
Table 5 Default load sharing modes
Packet type
IP unicast packets
dest-ip, src-ip, dest-port, src-port
Layer 2 frames
dest-mac, src-mac
MPLS L3VPN packets
MPLS L2VPN packets
·     IP packets: dest-ip, src-ip, dest-port, src-port
MPLS LSPs
·     IP packets: mpls-label1, mpls-label2, dest-ip, src-ip, dest-port, src-port
Other MPLS packets
IP tunnel packets
·     IP packets: inner dest-ip, inner src-ip, inner src-port, inner dest-port
Table 6 shows the default load sharing modes used by the following cards:
Card category
Cards
CEPC
CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E
CSPEX
CSPEX-1104-E, CSPEX-1204
Table 6 Default load sharing modes
Packet type
IP unicast packets
dest-ip, src-ip
dest-mac, src-mac
Layer 2 frames
dest-mac, src-mac
MPLS L3VPN packets
dest-ip, src-ip
MPLS L2VPN packets
·     MPLS VPLS packets: dest-mac, src-mac
·     MPLS L2VPN packets: mpls-label1, mpls-label2
MPLS LSPs
Other MPLS packets
IP tunnel packets
per-flow: Implements per-flow load sharing. If you specify none of the destination IP address, destination MAC address, destination port number, protocol number, source IP address, source MAC address, and source port number, the device performs per-flow load sharing based on the destination IP address and the source IP address of the packets.
algorithm algorithm-number: Specifies an algorithm for per-flow load sharing. The value range for the algorithm-number argument is 0 to 9. If you do not specify an algorithm, the default algorithm value is 0. If you specify an algorithm and then execute the undo ip load-sharing mode command, the algorithm value is set to 0.
dest-ip: Identifies flows by destination IP address.
dest-mac: Identifies flows by destination MAC address.
dest-port: Identifies flows by destination port.
global: Configures the load sharing mode globally.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-mac: Identifies flows by source MAC address.
src-port: Identifies flows by source port.
per-packet: Implements per-packet load sharing.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command configures the load sharing mode for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command configures the load sharing mode for all cards. (In IRF mode.)
Follow these guidelines when you use the ip load-sharing mode command to configure the load sharing mode on the following cards:
·     The configuration of per-packet load sharing does not take effect on the following cards.
Card category
Cards
CEPC
CSPEX
·     The ip-pro keyword is not supported on the following cards.
Card category
Cards
CEPC
CSPEX
CSPEX-1304X, CSPEX-1404X, CSPEX-1502X, CSPEX-1504X, CSPEX-1504XA, CSPEX-1602X, CSPEX-1602XA, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1802X, CSPEX-1802XA, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-1502XA, CSPEX-2612XA
SPE
·     On the following cards, the per-flow load sharing modes take effect on the specified card in the following order:
Card category
Cards
CEPC
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RXA, CEPC-CP4RX-L, CEPC-CQ8LA, CEPC-CQ16L1, CEPC-CQ8L1A
CSPEX
CSPEX-1304X, CSPEX-1404X, CSPEX-1502X, CSPEX-1504X, CSPEX-1504XA, CSPEX-1602X, CSPEX-1602XA, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1802XA, CSPEX-2612XA
SPE
RX-SPE200
a.     Algorithm-based per-flow load sharing configured globally or on the card (specified by the algorithm algorithm-number option).
b.     Per-flow load sharing with a random combination of the dest-ip, dest-mac, dest-port, src-ip, src-mac, and src-port keywords on the specified card.
c.     Global per-flow load sharing with a random combination of the dest-ip, dest-mac, dest-port, src-ip, src-mac, and src-port keywords.
d.     Link-aggregation load sharing mode (configured by using the link-aggregation global load-sharing mode command). For more information, see Ethernet link aggregation configuration in Layer 2—LAN Switching Configuration Guide.
e.     Global default load sharing mode.
·     On the CSPEX-1802X, CSPEX-1812X-E, CEPC-CQ8L, CSPEX-2304X-G, RX-SPE200-E, and CSPEX-1502XA cards, the per-flow load sharing modes take effect on the specified card in the following order:
d.     Global default load sharing mode.
# (In standalone mode.) Configure per-packet load sharing on slot 1.
[Sysname] ip load-sharing mode per-packet slot 1
# (In standalone mode.) Configure per-flow load sharing by destination IP address and source IP address on slot 1.
[Sysname] ip load-sharing mode per-flow dest-ip src-ip slot 1
# (In standalone mode.) Specify algorithm 1 for per-flow load sharing on slot 1.
[Sysname] ip load-sharing mode per-flow algorithm 1 slot 1
