14-IP Tunnel and VPN
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10014-IP Tunnel and VPN
02-HH3C-TUNNEL-TRAP-MIB
02-HH3C-TUNNEL-TRAP-MIB 131.19 KB
About this MIB
Use this MIB to output notifications for the tunnel module.
MIB file name
hh3c-tunnel-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTunnelTrap(226)
Scalar objects
hh3cTunnelTrapVxlanStatusSType
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanStatusSType (1.3.6.1.4.1.25506.2.226.1.1.1.1)
accessible-for-notify
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
IP type of the tunnel source address.
As per the MIB.
hh3cTunnelTrapVxlanStatusSrcIP
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanStatusSrcIP (1.3.6.1.4.1.25506.2.226.1.1.1.2)
InetAddress
OCTET STRING (0..255)
Source address of the tunnel.
As per the MIB.
hh3cTunnelTrapVxlanStatusDType
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanStatusDType (1.3.6.1.4.1.25506.2.226.1.1.1.3)
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
IP type of the tunnel destination address.
As per the MIB.
hh3cTunnelTrapVxlanStatusDstIP
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanStatusDstIP (1.3.6.1.4.1.25506.2.226.1.1.1.5)
InetAddress
Destination address of the tunnel.
As per the MIB.
hh3cTunnelTrapVxlanCfgTunnelIfNo
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanCfgTunnelIfNo (1.3.6.1.4.1.25506.2.226.2.1.1)
Integer32
Standard MIB values.
Tunnel interface number.
As per the MIB.
hh3cTunnelTrapVxlanChassis
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanChassis (1.3.6.1.4.1.25506.2.226.3.1.1)
Unsigned32
Chassis number for the trap.
As per the MIB.
hh3cTunnelTrapVxlanSlot
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanSlot (1.3.6.1.4.1.25506.2.226.3.1.2)
Unsigned32
Slot number for the trap.
As per the MIB.
hh3cTunnelTrapVxlanVni
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanVni (1.3.6.1.4.1.25506.2.226.3.1.3)
Unsigned32
VXLAN ID of the VXLAN tunnel.
As per the MIB.
hh3cTunnelTrapVxlanSrcType
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanSrcType (1.3.6.1.4.1.25506.2.226.3.1.4)
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
IP type of the source address of the VXLAN tunnel.
As per the MIB.
hh3cTunnelTrapVxlanSrcIP
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanSrcIP (1.3.6.1.4.1.25506.2.226.3.1.5)
InetAddress
Source IP address of the VXLAN tunnel.
As per the MIB.
hh3cTunnelTrapVxlanDstType
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanDstType (1.3.6.1.4.1.25506.2.226.3.1.6)
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
IP type of the destination address of the VXLAN tunnel.
As per the MIB.
hh3cTunnelTrapVxlanDstIP
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapVxlanDstIP (1.3.6.1.4.1.25506.2.226.3.1.7)
InetAddress
Destination IP address of the VXLAN tunnel.
As per the MIB.
hh3cTunnelTrapIfNumExceedCurNum
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapIfNumExceedCurNum (1.3.6.1.4.1.25506.2.226.4.1.1)
Unsigned32
Current number of tunnel interfaces.
As per the MIB.
hh3cTunnelTrapIfNumExceedSpecNum
Object (OID)
Access
Value range
Implementation
hh3cTunnelTrapIfNumExceedSpecNum (1.3.6.1.4.1.25506.2.226.4.1.2)
Unsigned32
Maximum number of tunnel interfaces.
As per the MIB.
Notifications
hh3cTunnelTrapVxlanStatusUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.226.1.1.0.1
A VXLAN tunnel came up.
Recovery
Warning
N/A
OFF
Notification triggers
This notification is generated when a VXLAN tunnel comes up at the link layer.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable tunnel vxlan-tunnel-status command.
OFF
CLI: Use the undo snmp-agent trap enable tunnel vxlan-tunnel-status command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.226.1.1.1.1 (hh3cTunnelTrapVxlanStatusSType)
Tunnel source address type.
N/A
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
1.3.6.1.4.1.25506.2.226.1.1.1.2 (hh3cTunnelTrapVxlanStatusSrcIP)
Tunnel source address.
N/A
InetAddress
1.3.6.1.4.1.25506.2.226.1.1.1.3 (hh3cTunnelTrapVxlanStatusDType)
Tunnel destination address type.
N/A
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
1.3.6.1.4.1.25506.2.226.1.1.1.4 (hh3cTunnelTrapVxlanStatusDstIP)
Tunnel destination address.
N/A
InetAddress
Recommended action
No action is required.
hh3cTunnelTrapVxlanStatusDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.226.1.1.0.2
A VXLAN tunnel went down.
Error
Warning
1.3.6.1.4.1.25506.2.226.1.1.0.1(hh3cTunnelTrapVxlanStatusUp)
OFF
This notification is generated when a VXLAN tunnel goes down at the link layer.
System impact
The tunnel becomes unavailable. Service traffic carried on the tunnel will be interrupted.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
N/A
InetAddress
N/A
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
N/A
InetAddress
Recommended action
To resolve this issue:
1.     Use the display interface and display ip routing-table commands to check whether the tunnel route and outgoing interface are normal.
a.     If the interface is down, verify that the link is well connected.
b.     If the route is lost, verify that the remote end is online.
2.     If the issue persists, collect log messages and configuration data, and then contact Technical Support for help.
hh3cTunnelTrapVxlanCfgFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.226.2.0.1
Failed to deploy the VXLAN tunnel configuration.
Error
Warning
N/A
OFF
This notification is generated when the VXLAN tunnel configuration failed to be deployed.
System impact
Configuration deployment will fail and function is unavailable.
Status control
ON
CLI: Use the snmp-agent trap enable tunnel vxlan-tunnel-config command.
OFF
CLI: Use the undo snmp-agent trap enable tunnel vxlan-tunnel-config command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.226.2.1.1 (hh3cTunnelTrapVxlanCfgTunnelIfNo)
N/A
Integer32
Recommended action
1.     Check whether the deployed configuration parameters are correct.
a.     If errors exist, correct the errors and then redeploy the parameters.
b.     If the parameter settings are correct, go to step 2.
2.     Collect log messages and configuration data, and then contact Technical Support for help.
hh3cTunnelTrapVxlanFailDecapPkt
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.226.3.0.1
Failed to decapsulate a VXLAN packet.
Error
Warning
N/A
OFF
This notification is generated when the device fails to decapsulate a VXLAN packet.
System impact
The tunnel packet cannot be decapsulated and will be dropped. Services might be affected.
Status control
ON
CLI: Use the snmp-agent trap enable tunnel vxlan-tunnel-decap command.
OFF
CLI: Use the undo snmp-agent trap enable tunnel vxlan-tunnel-decap command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.226.3.1.1 (hh3cTunnelTrapVxlanChassis)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.226.3.1.2 (hh3cTunnelTrapVxlanSlot)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.226.3.1.3  (hh3cTunnelTrapVxlanVni)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.226.3.1.4 (hh3cTunnelTrapVxlanSrcType)
IP type of the VXLAN tunnel source address.
N/A
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
1.3.6.1.4.1.25506.2.226.3.1.5 (hh3cTunnelTrapVxlanSrcIP)
N/A
InetAddress
1.3.6.1.4.1.25506.2.226.3.1.6 (hh3cTunnelTrapVxlanDstType)
IP type of the VXLAN tunnel destination address.
N/A
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
1.3.6.1.4.1.25506.2.226.3.1.7 (hh3cTunnelTrapVxlanDstIP)
N/A
InetAddress
Recommended action
1.     Identify whether the packet is destined for the local tunnel according to the information in the notification message. If yes, go to step 2. If no, no action is required.
hh3cTunnelTrapIfNumExceeded
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.226.4.0.1
The number of tunnel interfaces reached the maximum allowed on the device.
Error
Warning
N/A
OFF
This notification is generated when the number of tunnel interfaces reached the maximum allowed on the device.
System impact
The number of tunnel interfaces has reached the maximum. No more tunnel interfaces can be added.
Status control
ON
CLI: Use the snmp-agent trap enable tunnel max-threshold-reached command.
OFF
CLI: Use the undo snmp-agent trap enable tunnel max-threshold-reached command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.226.4.1.1 (hh3cTunnelTrapIfNumExceedCurNum)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.226.4.1.2 (hh3cTunnelTrapIfNumExceedSpecNum)
N/A
Unsigned32
Recommended action
Use the display interface tunnel command to view information about all tunnels. Identify the unneeded tunnels and then delete them.
