09-IP Multicast
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10009-IP Multicast
08-IPV6-MLD-MIB
08-IPV6-MLD-MIB 68.83 KB
IPV6-MLD-MIB
About this MIB
Use this table to manage MLD.
This MIB contains the following tables:
·     MLD interface table—Each row contains an interface that is enabled with MLD.
·     MLD cache table—Each row contains  an IPv6 multicast group that has members on an interface.
The tables are intended to be implemented by hosts and routers. However, some objects in the tables are applicable only to routers.
MIB file name
rfc3019-ipv6-mld.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).mldMIB(91)
Tabular objects
mldInterfaceTable
About this table
This table contains an interface that is enabled with MLD.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is mldInterfaceIfIndex.
Object (OID)
Access
Value range
Implementation
mldInterfaceIfIndex
(1.3.6.1.2.1.91.1.1.1.1)
not-accessible
InterfaceIndex
Integer32(1..2147483647)
Index of an interface enabled with MLD.
As per the MIB.
mldInterfaceQueryInterval
(1.3.6.1.2.1.91.1.1.1.2)
read-create
Unsigned32
Unsigned32(1..31744)
General query interval, in seconds.
Value range: 1 to 31744.
mldInterfaceStatus
(1.3.6.1.2.1.91.1.1.1.3)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
mldInterfaceVersion
(1.3.6.1.2.1.91.1.1.1.4)
read-create
Unsigned32
Standard MIB values.
MLD version.
Value range: 1 to 2.
mldInterfaceQuerier
(1.3.6.1.2.1.91.1.1.1.5)
read-only
InetAddressIPv6
OCTET STRING(16)
IP address of the MLD querier on the subnet to which the interface is attached.
As per the MIB.
mldInterfaceQueryMaxResponseDelay
(1.3.6.1.2.1.91.1.1.1.6)
read-create
Unsigned32
Unsigned32(1..3174)
Maximum response time, in seconds.
Value range: 1 to 3174.
mldInterfaceJoins
(1.3.6.1.2.1.91.1.1.1.7)
read-only
Counter32
INTEGER(0..4294967295)
Number of times a group membership has been added on the interface.
As per the MIB.
mldInterfaceGroups
(1.3.6.1.2.1.91.1.1.1.8)
read-only
Gauge32
Number of group entries on the interface.
As per the MIB.
mldInterfaceRobustness
(1.3.6.1.2.1.91.1.1.1.9)
read-create
Unsigned32
Unsigned32(1..255)
Robustness variable.
Value range: 1 to 155.
mldInterfaceLastListenQueryIntvl
(1.3.6.1.2.1.91.1.1.1.10)
read-create
Unsigned32
Unsigned32(1..25)
Last member query interval, in seconds.
Value range: 1 to 25.
mldInterfaceProxyIfIndex
(1.3.6.1.2.1.91.1.1.1.11)
read-create
InterfaceIndexOrZero
Integer32(0..2147483647)
Index of the interface that acts as the proxy.
Supports only the read operation.
mldInterfaceQuerierUpTime
(1.3.6.1.2.1.91.1.1.1.12)
read-only
Timeticks
Time elapsed since the MLD querier was changed.
As per the MIB.
mldInterfaceQuerierExpiryTime
(1.3.6.1.2.1.91.1.1.1.13)
read-only
Timeticks
Time remaining before the other querier present timer expires.
As per the MIB.
mldCacheTable
About this table
This table contains IPv6 multicast groups for which there are members on an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are mldCacheAddress and mldCacheIfIndex.
Object (OID)
Access
Value range
Implementation
mldCacheAddress
(1.3.6.1.2.1.91.1.2.1.1)
not-accessible
InetAddressIPv6
OCTET STRING (16)
IPv6 address of a multicast group.
As per the MIB.
mldCacheIfIndex
(1.3.6.1.2.1.91.1.2.1.2)
not-accessible
InterfaceIndex
Index of an interface that has members of the IPv6 multicast group.
As per the MIB.
mldCacheSelf
(1.3.6.1.2.1.91.1.2.1.3)
read-create
TruthValue
false(2)
whether the local system is a member of the group address on the interface.
Supports only false(2).
mldCacheLastReporter
(1.3.6.1.2.1.91.1.2.1.4)
read-only
InetAddressIPv6
OCTET STRING (16)
IPv6 address of the last host that joined the multicast group.
As per the MIB.
mldCacheUpTime
(1.3.6.1.2.1.91.1.2.1.5)
read-only
Timeticks
Time elapsed since this entry was created.
As per the MIB.
mldCacheExpiryTime
(1.3.6.1.2.1.91.1.2.1.6)
read-only
Timeticks
Time remaining before this entry ages out.
As per the MIB.
mldCacheStatus
(1.3.6.1.2.1.91.1.2.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
