05-HH3C-PIM-STD-MIB | 255.26 KB |
hh3cPimNotificationAddressFamily
hh3cPimNotificationThresholdCnt
hh3cPimThresholdClearReasonType
hh3cPimNotificationSourceAddress
hh3cPimNotificationGroupAddress
hh3cPimGroupMappingAddressType
hh3cPimGroupMappingGrpPrefixLen
hh3cPimGroupMappingRPAddressType
HH3C-PIM-STD-MIB
About this MIB
Use this MIB to manage PIM routers.
MIB file name
hh3c-pim-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPimStd(213)
Scalar objects
hh3cPimInstanceID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimInstanceID (1.3.6.1.4.1.25506.2.213.1.1) |
accessible-for-notify |
Unsigned32 |
Unsigned32(0..4294967295) |
PIM instance ID. |
As per the MIB. |
hh3cPimInstanceName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimInstanceName (1.3.6.1.4.1.25506.2.213.1.2) |
DisplayString |
OCTET STRING (0..255) |
PIM instance name. |
As per the MIB. |
hh3cPimNeighborExpiryTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNeighborExpiryTime (1.3.6.1.4.1.25506.2.213.1.3) |
TimeTicks |
INTEGER (0..4294967295) |
Timeout timer. |
As per the MIB. |
hh3cPimNotificationLimitType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationLimitType (1.3.6.1.4.1.25506.2.213.1.4) |
INTEGER |
sm-star-group(1), sm-source-group(2) |
Type of the PIM route entry. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationAddressFamily (1.3.6.1.4.1.25506.2.213.1.5) |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), |
Type of the PIM address. |
As per the MIB. |
hh3cPimNotificationEntryCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationEntryCount (1.3.6.1.4.1.25506.2.213.1.6) |
Unsigned32 |
Number of current PIM route entries. |
As per the MIB. |
hh3cPimNotificationLimitCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationLimitCount (1.3.6.1.4.1.25506.2.213.1.7) |
Unsigned32 |
Maximum number of PIM route entries. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationThresholdCnt (1.3.6.1.4.1.25506.2.213.1.8) |
Unsigned32 |
Upper limit on PIM entries that causes a log message to be generated |
As per the MIB. |
hh3cPimThresholdReasonType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimThresholdReasonType (1.3.6.1.4.1.25506.2.213.1.9) |
INTEGER |
entryCreated(1), configurationChanged(2) |
Reason why the number of PIM route entries exceeds the maximum number. |
As per the MIB. |
hh3cPimRouteEClearReasonType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimRouteEClearReasonType (1.3.6.1.4.1.25506.2.213.1.10) |
INTEGER |
entryDeleted(1), configurationChanged(2), |
Reason why the number of PIM route entries falls below the maximum number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimThresholdClearReasonType (1.3.6.1.4.1.25506.2.213.1.11) |
INTEGER |
Reason why the number of PIM route entries falls below the upper limit. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationSourceAddress (1.3.6.1.4.1.25506.2.213.1.12) |
InetAddress |
Source address of a PIM route entry. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationGroupAddress (1.3.6.1.4.1.25506.2.213.1.13) |
InetAddress |
Group address of a PIM route entry. |
As per the MIB. |
hh3cPimNbrAddressIfIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNbrAddressIfIndex (1.3.6.1.4.1.25506.2.213.1.14) |
InterfaceIndex |
Integer32(1..2147483647) |
PIM neighbor interface. |
As per the MIB. |
hh3cPimNbrAddressType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNbrAddressType (1.3.6.1.4.1.25506.2.213.1.15) |
InetAddressType |
unknown(0), ipv4(1), ipv6(2) |
PIM neighbor address type. |
As per the MIB. |
hh3cPimNbrAddress
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNbrAddress (1.3.6.1.4.1.25506.2.213.1.16) |
read-only |
InetAddress |
PIM neighbor address. |
As per the MIB. |
hh3cPimNeighborUpTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNeighborUpTime (1.3.6.1.4.1.25506.2.213.1.17) |
TimeTicks |
Timeout timer. |
As per the MIB. |
hh3cPimGroupMappingOrigin
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimGroupMappingOrigin (1.3.6.1.4.1.25506.2.213.1.18) |
PimGroupMappingOriginType |
fixed(1); configRp(2); configSsm(3); bsr(4); autoRP(5); embedded(6); other(7) |
Mechanism used to learn the group mapping. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimGroupMappingAddressType (1.3.6.1.4.1.25506.2.213.1.19) |
InetAddressType |
INTEGER{ ipv4(1), ipv6(2), } |
Group address type. |
As per the MIB. |
hh3cPimGroupMappingGrpAddress
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimGroupMappingGrpAddress (1.3.6.1.4.1.25506.2.213.1.20) |
InetAddress |
OCTET STRING (4|8|16|20) |
PIM group address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimGroupMappingGrpPrefixLen (1.3.6.1.4.1.25506.2.213.1.21) |
InetAddressPrefixLength |
Unsigned32(4..128) |
PIM group address prefix length. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimGroupMappingRPAddressType (1.3.6.1.4.1.25506.2.213.1.22) |
InetAddressType |
INTEGER{ unknown(0), ipv4(1), ipv6(2), } |
RP address type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimGroupMappingRPAddress (1.3.6.1.4.1.25506.2.213.1.23) |
InetAddress |
OCTET STRING (0|4|8|16|20) |
RP address. |
As per the MIB. |
hh3cPimGroupMappingPimMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimGroupMappingPimMode (1.3.6.1.4.1.25506.2.213.1.24) |
PimMode |
none(1); ssm(2); asm(3); bidir(4); dm(5); other(6) |
PIM mode. |
As per the MIB. |
hh3cPimGroupMappingPrecedence
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimGroupMappingPrecedence (1.3.6.1.4.1.25506.2.213.1.25) |
Unsigned32 |
Standard MIB values. |
Priority. |
As per the MIB. |
hh3cPimInterfaceIfIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimInterfaceIfIndex (1.3.6.1.4.1.25506.2.213.1.26) |
InterfaceIndex |
Interface index. |
As per the MIB. |
hh3cPimInterfaceIPVersion
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimInterfaceIPVersion (1.3.6.1.4.1.25506.2.213.1.27) |
InetVersion |
INTEGER{ unknown(0), ipv4(1), ipv6(2) } |
IP version. |
As per the MIB. |
hh3cPimInterfaceAddressType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimInterfaceAddressType (1.3.6.1.4.1.25506.2.213.1.28) |
InetAddressType |
Interface address type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimInterfaceAddress (1.3.6.1.4.1.25506.2.213.1.29) |
InetAddress |
Interface address. |
As per the MIB. |
h3cPimNeighborLossReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNeighborLossReason (1.3.6.1.4.1.25506.2.213.1.30) |
INTEGER |
holdTimeTimeout(1), notReceiveHelloForALongTime(2) (This field is not supported in the current software version.), interfaceDown(3), receiveHelloAgain(4) (This field is not supported in the current software version.), neighbourDeleted(5), alarmTimeOut(6) (This field is not supported in the current software version. ), receiveHelloCancel(7), bfdSessionIsDown(8), userOperation(9) (This field is not supported in the current software version. ), alarmClear(100)(This field is not supported in the current software version. ) |
Reason for neighbor unavailability. |
As per the MIB. |
hh3cPimNeighborIfName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNeighborIfName (1.3.6.1.4.1.25506.2.213.1.31) |
DisplayString |
OCTET STRING (1..64) |
PIM neighbor interface name. |
As per the MIB. |
hh3cPimInterfaceName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimInterfaceName (1.3.6.1.4.1.25506.2.213.1.32) |
DisplayString |
Interface name. |
As per the MIB. |
Notifications
hh3cPimNeighborAdd
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.213.0.1 |
PIM neighbor created. |
Informational |
Minor |
N/A |
ON |
Notification triggers
This notification is generated when a PIM interface receives a hello packet and a PIM neighbor is created.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable pim new-neighbor command.
CLI: Use the snmp-agent trap enable pim6 new-neighbor command.
OFF
CLI: Use the undo snmp-agent trap enable pim new-neighbor command.
CLI: Use the undo snmp-agent trap enable pim6 new-neighbor command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.213.1.3 (hh3cPimNeighborExpiryTime) |
Neighbor timeout time. |
N/A |
TimeTicks |
1.3.6.1.4.1.25506.213.1.1 (hh3cPimInstanceID) |
PIM instance ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.213.1.2 (hh3cPimInstanceName) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.213.1.15 (hh3cPimNbrAddressType) |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.213.1.14 (hh3cPimNbrAddressIfIndex) |
N/A |
InterfaceIndex |
1.3.6.1.4.1.25506.2.213.1.16 (hh3cPimNbrAddress) |
N/A |
InetAddress |
Recommended action
No action is required.
hh3cPimRouteThresholdExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.2 |
The number of global PIM entries exceeded the upper limit that causes a log message to be generated. |
Error |
Major |
1.3.6.1.4.1.25506.2.213.0.3 (hh3cPimRouteThresholdExceedClear) |
ON |
This notification is generated when the number of global PIM entries exceeds the alarm threshold.
Possible causes for the issue include:
· After new global PIM entries are generated, the number of global PIM entries exceeds the alarm threshold.
· The alarm threshold on the number of global PIM entries is inappropriately small.
System impact
The number of global PIM entries might reach the maximum number if it keeps increasing.
Status control
ON
CLI: Use the snmp-agent trap enable pim route-threshold-exceed command.
CLI: Use the snmp-agent trap enable pim6 route-threshold-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-threshold-exceed command.
CLI: Use the undo snmp-agent trap enable pim6 route-threshold-exceed command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.213.1.4 (hh3cPimNotificationLimitType) |
PIM entry type. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.213.1.5 (hh3cPimNotificationAddressFamily) |
PIM address type. |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.213.1.6 (hh3cPimNotificationEntryCount) |
Current number of PIM entries. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.8 (hh3cPimNotificationThresholdCnt) |
Upper limit of PIM entries that causes a log message to be generated. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.9 (hh3cPimThresholdReasonType) |
Reason why the number of PIM entries exceeded the upper limit. |
N/A |
INTEGER |
Recommended action
To resolve the issue:
1. Use the display multicast global statistics or display ipv6 multicast global statistics command to identify whether the upper limit on global PIM entries is low.
¡ If yes, go to step 2.
¡ If no, go to step 3.
2. Use the multicast global limit or ipv6 multicast global limit command to increase the upper limit.
3. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.3 |
The number of global PIM entries fell below the upper limit that causes a log message to be generated. |
Recovery |
Major |
N/A |
ON |
This notification is generated when the number of global PIM entries falls below the upper limit that causes a log message to be generated.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable pim route-threshold-exceed-clear command.
CLI: Use the snmp-agent trap enable pim6 route-threshold-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-threshold-exceed-clear command.
CLI: Use the undo snmp-agent trap enable pim6 route-threshold-exceed-clear command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PIM entry type. |
N/A |
INTEGER |
PIM address type |
N/A |
InetAddressType |
Current number of PIM entries |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.11 (hh3cPimThresholdClearReasonType) |
N/A |
INTEGER |
Recommended action
hh3cPimRouteExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.4 |
The number of global PIM entries exceeded the maximum number. |
Error |
Major |
1.3.6.1.4.1.25506.2.213.0.5 (hh3cPimRouteExceedClear) |
ON |
This notification is generated when the number of global PIM entries exceeds the maximum number.
System impact
No global PIM entries can be created any more.
Status control
ON
CLI: Use the snmp-agent trap enable pim route-exceed command.
CLI: Use the snmp-agent trap enable pim6 route-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-exceed command.
CLI: Use the undo snmp-agent trap enable pim6 route-exceed command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PIM entry type. |
N/A |
INTEGER |
PIM address type. |
N/A |
InetAddressType |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.7 (hh3cPimNotificationLimitCount) |
Maximum number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.12 (hh3cPimNotificationSourceAddress) |
Source address of the PIM entry. |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.213.1.13 (hh3cPimNotificationGroupAddress) |
Group address of the PIM entry. |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.213.1.2 (hh3cPimInstanceName) |
N/A |
DisplayString |
Recommended action
1. Use the display multicast global statistics or display ipv6 multicast global statistics command to identify whether the maximum number of global PIM entries is low.
2. Use the multicast global limit or ipv6 multicast global limit command to increase the maximum number.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.5 |
The number of global PIM entries fell below the maximum number. |
Recovery |
Major |
N/A |
ON |
This notification is generated when the number of global PIM entries falls below the maximum number.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable pim route-exceed-clear command.
CLI: Use the snmp-agent trap enable pim6 route-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-exceed-clear command.
CLI: Use the undo snmp-agent trap enable pim6 route-exceed-clear command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PIM entry type. |
N/A |
INTEGER |
PIM address type. |
N/A |
InetAddressType |
N/A |
Unsigned32 |
Maximum number. |
N/A |
Unsigned32 |
N/A |
InetAddress |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.213.1.10 (hh3cPimRouteEClearReasonType) |
Reason why the number of PIM entries fell below the maximum number. |
N/A |
INTEGER |
N/A |
DisplayString |
Recommended action
hh3cPimNeighborLoss
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.6 |
PIM neighbor loss. |
Error |
Minor |
1.3.6.1.4.1.25506.2.213.0.1(hh3cPimNeighborAdd) |
ON |
This notification is generated when the timer of a neighbor expires and no neighbor of the same IP version and with a lower IP address exists.
This notification might be generated for the following reasons:
· The hold timer of the PIM neighbor expires.
· The interface where the PIM neighbor resides goes down.
· The PIM neighbor is deleted.
· The device receives a neighbor message with the hold time as 0.
· The BFD session of the neighbor goes down.
System impact
A connection will fail to be established, and data forwarding will be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable pim private-neighbor-loss command.
CLI: Use the snmp-agent trap enable pim6 private-neighbor-loss command.
OFF
CLI: Use the undo snmp-agent trap enable pim private-neighbor-loss command.
CLI: Use the undo snmp-agent trap enable pim6 private-neighbor-loss command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.213.1.17 (hh3cPimNeighborUpTime) |
Time since the neighbor has come up. |
N/A |
TimeTicks |
1.3.6.1.4.1.25506.2.213.1.1 (hh3cPimInstanceID) |
PIM instance ID. |
N/A |
Unsigned32 |
N/A |
DisplayString |
N/A |
InetAddressType |
N/A |
InterfaceIndex |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.213.1.31 |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.213.1.30 |
Reason why the neighbor is lost. |
N/A |
INTEGER |
holdTimeTimeout(1), notReceiveHelloForALongTime(2) (This field is not supported in the current software version.), interfaceDown(3), receiveHelloAgain(4) (This field is not supported in the current software version.), neighbourDeleted(5), alarmTimeOut(6) (This field is not supported in the current software version.), receiveHelloCancel(7), bfdSessionIsDown(8), userOperation(9) (This field is not supported in the current software version.), alarmClear(100)(This field is not supported in the current software version.) |
Recommended action
To resolve this issue:
1. Use the display this command to identify whether the pim neighbor-policy or ipv6 pim neighbor-policy command is executed on the interface.
2. Use the display acl or display acl ipv6 command to identify whether the neighbor is permitted by the ACL.
¡ If yes, go to step 3.
¡ If no, reconfigure the ACL to permit the neighbor.
3. Use the display interface command on the local device and the neighbor device to identify the physical state of the interface.
¡ If the physical state is Administratively DOWN, execute the undo shutdown command.
¡ If the physical state is Down, check the physical connection (including whether the network cable and transceiver module are loose or disconnected), and reconnect the physical connection.
¡ If the physical state is Up, go to step 4.
4. Use the display ip interface or display ipv6 interface command on the local device and the neighbor device to identify the protocol state of the interface.
¡ If the protocol state is Up, go to step 5.
¡ If the protocol state is Down, use the ip address or ipv6 address command to assign an IP address to the interface.
5. Use the display this command on the local device and the neighbor device to identify whether the interface is enabled with PIM SM or IPv6 PIM SM.
¡ If yes, go to step 6.
¡ If no, execute the pim sm or ipv6 pim sm command on the interface.
6. Use the display current-configuration command on the local device and the neighbor device to identify whether the VPN instance is enabled multicast routing or IPv6 multicast routing.
¡ If yes, go to step 7.
¡ If no, execute the multicast routing or ipv6 multicast routing command on the interface.
7. Use the display memory command on the local device and the neighbor device to identify the memory usage.
¡ If the memory is insufficient, address the memory issue.
¡ If the memory is sufficient, go to step 8.
8. Use the ping or ping ipv6 command on the local device to test the connectivity with the neighbor device.
¡ If the ping succeeds, go to step 10.
¡ If the ping fails, go to step 9.
9. Use the display ip routing-table or display ipv6 routing-table command on the local device and the neighbor device to identify the unicast routes to each other are normal.
¡ If the unicast routes are normal, go to step 10.
¡ If the unicast routes are abnormal, address the route issues.
10. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cPimRPMappingChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.7 |
RP change. |
Informational |
Warning |
N/A |
ON |
This notification is generated for the following possible reasons:
· The configuration of the RP changes.
· The RP fails.
· An RP is added.
System impact
The source and multicast group members might fail to communicate, affecting multicast services.
Status control
ON
CLI: Use the snmp-agent trap enable pim private-rp-mapping-change command.
CLI: Use the snmp-agent trap enable pim6 private-rp-mapping-change command.
OFF
CLI: Use the undo snmp-agent trap enable pim private-rp-mapping-change command.
CLI: Use the undo snmp-agent trap enable pim6 private-rp-mapping-change command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.213.1.18 (hh3cPimGroupMappingOrigin) |
Mapping mechanism. |
N/A |
1.3.6.1.4.1.25506.2.213.1.19 (hh3cPimGroupMappingAddressType) |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.213.1.20 (hh3cPimGroupMappingGrpAddress) |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.213.1.21 (hh3cPimGroupMappingGrpPrefixLen) |
Prefix length for the group address. |
N/A |
1.3.6.1.4.1.25506.2.213.1.22 (hh3cPimGroupMappingRPAddressType) |
RP address type. |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.213.1.23 (hh3cPimGroupMappingRPAddress) |
RP address. |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.213.1.24 (hh3cPimGroupMappingPimMode) |
PIM mode. |
N/A |
PimMode |
1.3.6.1.4.1.25506.2.213.1.25 (hh3cPimGroupMappingPrecedence) |
Priority. |
N/A |
Unsigned32 |
PIM instance ID. |
N/A |
Unsigned32 |
N/A |
DisplayString |
Recommended action
If the RP change is not desired, configure the device as a static RP or increase the priority of the original RP.
If the RP change is desired, no action is required.
hh3cPimInterfaceElection
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.8 |
DR change. |
Informational |
Warning |
N/A |
ON |
· A PIM interface receives a hello packet, and the DR priority or IP address of the interface is higher than that of all other interface on the shared network segment.
· A PIM interface does not receive hello packets from other interfaces during the first hello interval after the interface comes up.
System impact
The RP might receive incorrect Register messages if the multicast source-side DR changes. The RP might receive incorrect Join messages if the multicast receiver-side DR changes.
Status control
ON
CLI: Use the snmp-agent trap enable pim private-interface-election command.
CLI: Use the snmp-agent trap enable pim6 private-interface-election command.
OFF
CLI: Use the undo snmp-agent trap enable pim private-interface-election command.
CLI: Use the undo snmp-agent trap enable pim6 private-interface-election command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.213.1.26 (hh3cPimInterfaceIfIndex) |
Interface index. |
N/A |
InterfaceIndex |
1.3.6.1.4.1.25506.2.213.1.32 |
Interface name. |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.213.1.27 (hh3cPimInterfaceIPVersion) |
IP version. |
N/A |
InetVersion |
1.3.6.1.4.1.25506.2.213.1.28 (hh3cPimInterfaceAddressType) |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.213.1.29 (hh3cPimInterfaceAddress) |
Interface address |
N/A |
InetAddress |
PIM instance ID. |
N/A |
Unsigned32 |
N/A |
DisplayString |
Recommended action
If the DR change is not desired, configure a lower DR priority or a lower IP address.
If the DR change is desired, no action is required.
