| 07-HH3C-SAVA-MIB | 69.37 KB |
HH3C-SAVA-MIB
About this MIB
Use this MIB to configure and obtain SAVA settings.
MIB file name
hh3c-sava.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSava(191)
Tabular objects
hh3cSavaSystemTable
About this table
Use this table to configure and obtain SAVA settings in the system level.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cSavaSystemIPVersion.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSavaSystemIPVersion (1.3.6.1.4.1.25506.2.191.1.1.1.1) |
not-accessible |
INTEGER |
unknown(0), ipv4(1), ipv6(2) |
IP version. |
As per the MIB. |
hh3cSavaSystemNotify (1.3.6.1.4.1.25506.2.191.1.1.1.2) |
read-write |
INTEGER |
true(1), false(2) |
Enabling status of SAVA logging. |
As per the MIB. |
hh3cSavaSystemNotifyInterva(1.3.6.1.4.1.25506.2.191.1.1.1.3) |
read-write |
Integer32 |
Integer32 (5..3600) |
SAVA logging interval, in seconds. |
As per the MIB. |
hh3cSavaSystemNotifyNumber (1.3.6.1.4.1.25506.2.191.1.1.1.4) |
read-write |
Integer32 |
Integer32 (1..128) |
Number of logs generated in an interval. |
As per the MIB. |
hh3cSavaIfTable
About this table
Use this table to configure and obtain settings on the SAVA-enabled interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cSavaIfIPVersion and hh3cSavaIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSavaIfIPVersion (1.3.6.1.4.1.25506.2.191.1.2.1.1) |
not-accessible |
INTEGER |
IP version. |
As per the MIB. |
hh3cSavaIfIndex (1.3.6.1.4.1.25506.2.191.1.2.1.2) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Interface index. |
As per the MIB. |
hh3cSavaIfEnable (1.3.6.1.4.1.25506.2.191.1.2.1.3) |
read-write |
INTEGER |
enable(1), disable(2) |
Enabling status of SAVA on the interface. |
As per the MIB. |
hh3cSavaIfRemoteRoutetag (1.3.6.1.4.1.25506.2.191.1.2.1.4) |
read-write |
Integer32 |
Integer32 (1.. 4294967295) |
Remote route tag. |
As per the MIB. |
hh3cSavaIfAccessSubnet (1.3.6.1.4.1.25506.2.191.1.2.1.5) |
read-write |
DisplayString |
OCTET STRING (0..255) |
SAVA access group to which the interface is added. |
As per the MIB. |
hh3cSavaPrefixTable
About this table
Use this table to configure and obtain the basic information about the SAVA prefix entry.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cSavaPrefixAddressType, hh3cSavaPrefixIfIndex, hh3cSavaPrefixAddress, and hh3cSavaPrefixLength.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSavaPrefixAddressType (1.3.6.1.4.1.25506.2.191.1.3.1.1) |
not-accessible |
INTEGER |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), |
IP version. |
As per the MIB. |
hh3cSavaPrefixIfIndex (1.3.6.1.4.1.25506.2.191.1.3.1.2) |
not-accessible |
Integer32 |
Interface index. |
As per the MIB. |
hh3cSavaPrefixAddress (1.3.6.1.4.1.25506.2.191.1.3.1.3) |
not-accessible |
OCTET STRING |
Prefix. |
As per the MIB. |
hh3cSavaPrefixLength (1.3.6.1.4.1.25506.2.191.1.3.1.4) |
not-accessible |
Integer32 |
Prefix length. |
As per the MIB. |
hh3cSavaPrefixSource (1.3.6.1.4.1.25506.2.191.1.3.1.5) |
read-only |
INTEGER |
localroute(1), remoteroute(2), otherif(3), |
Flag of the SAVA entry. |
As per the MIB. |
hh3cSavaCountTable
About this table
Use this table to obtain SAVA packet filtering statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cSavaCountIPVersion and hh3cSavaCountIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSavaCountIPVersion (1.3.6.1.4.1.25506.2.191.1.4.1.1) |
not-accessible |
INTEGER |
unknown(0), ipv4(1), ipv6(2), |
IP version of the source address of packets. |
As per the MIB. |
hh3cSavaCountIfIndex (1.3.6.1.4.1.25506.2.191.1.4.1.2) |
not-accessible |
Integer32 |
Interface index. |
As per the MIB. |
hh3cSavaCountFilterPkt (1.3.6.1.4.1.25506.2.191.1.4.1.3) |
read-only |
Integer64 |
Integer32 (1.. 9223372036854775807) |
Number of packets discarded by SAVA. |
As per the MIB. |
hh3cSavaCountFilterOctets (1.3.6.1.4.1.25506.2.191.1.4.1.4) |
read-only |
Integer64 |
Number of bytes discarded by SAVA. |
As per the MIB. |
