13-Security
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10013-Security
08-HH3C-SSH-MIB
08-HH3C-SSH-MIB 178.49 KB
HH3C-SSH-MIB
About this MIB
Secure Shell (SSH) is a network security protocol. Using encryption and authentication, SSH can implement secure remote access and file transfer over an insecure network.
SSH uses the typical client-server model to establish a channel for secure data transfer based on TCP.
SSH includes two versions: SSH1.x and SSH2.0 (hereinafter referred to as SSH1 and SSH2), which are not compatible. SSH2 is better than SSH1 in performance and security.
Use this MIB to configure the SSH service.
MIB file name
hh3c-ssh.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSSH(22)
Scalar objects
hh3cSSHServerVersion
Object (OID)
Access
Value range
Implementation
hh3cSSHServerVersion (1.3.6.1.4.1.25506.2.22.1.1.1.1)
read-only
DisplayString
Standard MIB values.
The SSH protocol version of the SSH server.
The default value is 2.00. It is not compatible with SSH 1.x versions.
hh3cSSHServerCompatibleSSH1x
Object (OID)
Access
Value range
Implementation
hh3cSSHServerCompatibleSSH1x (1.3.6.1.4.1.25506.2.22.1.1.1.2)
read-write
INTEGER
enableCompatibleSSH1x(1),
disableCompatibleSSH1x(2)
Compatibility with SSH  1.x versions.
The default value is disableCompatibleSSH1x(2).
hh3cSSHServerRekeyInterval
Object (OID)
Access
Value range
Implementation
hh3cSSHServerRekeyInterval (1.3.6.1.4.1.25506.2.22.1.1.1.3)
read-write
Integer32
Time interval at which the SSH server key is regenerated.
Value range: 0 to 24.
The default value is 0, meaning that the key will not be refreshed.
hh3cSSHServerAuthRetries
Object (OID)
Access
Value range
Implementation
hh3cSSHServerAuthRetries (1.3.6.1.4.1.25506.2.22.1.1.1.4)
read-write
Integer32
Maximum number of SSH server authentication retries.
Range from 1 to 5.
The default value is 3.
hh3cSSHServerAuthTimeout
Object (OID)
Access
Value range
Implementation
hh3cSSHServerAuthTimeout (1.3.6.1.4.1.25506.2.22.1.1.1.5)
read-write
Integer32
SSH server authentication timeout time.
Range from 1 to 120.
The default value is 60.
hh3cSFTPServerIdleTimeout
Object (OID)
Access
Value range
Implementation
hh3cSFTPServerIdleTimeout (1.3.6.1.4.1.25506.2.22.1.1.1.6)
read-write
Integer32
SFTP connection idle timeout time.
Range from 1 to 35791.
The default value is 10.
hh3cSSHServerEnable
Object (OID)
Access
Value range
Implementation
hh3cSSHServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.7)
read-write
INTEGER
enableSSHServer(1),
disableSSHServer(2)
Enable or disable the SSH server.
The default value is disableSSHServer(2).
hh3cSFTPServerEnable
Object (OID)
Access
Value range
Implementation
hh3cSFTPServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.8)
read-write
INTEGER
enableSFTPService(1),
disableSFTPService(2)
Enable or disable the SFTP server.
The default value is disableSFTPService(2).
hh3cSTelnetServerEnable
Object (OID)
Access
Value range
Implementation
hh3cSTelnetServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.9)
read-write
INTEGER
enableSTelnetService(1),
disableSTelnetService(2)
Enable or disable Stelnet server.
As per the MIB.
hh3cSCPServerEnable
Object (OID)
Access
Value range
Implementation
hh3cSCPServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.10)
read-write
INTEGER
enableSCPServer(1),
disableSCPServer(2)
Enable or disable SCP server.
As per the MIB.
hh3cSSHAttemptUserName
Object (OID)
Access
Value range
Implementation
hh3cSSHAttemptUserName (1.3.6.1.4.1.25506.2.22.1.2.1)
accessible-for-notify
DisplayString
Name of the user who failed to connect to the server.
Length: 1 to 255 characters.
hh3cSSHAttemptIpAddrType
Object (OID)
Access
Value range
Implementation
hh3cSSHAttemptIpAddrType (1.3.6.1.4.1.25506.2.22.1.2.2)
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of the user who failed to connect to the server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cSSHAttemptIpAddr (1.3.6.1.4.1.25506.2.22.1.2.3)
InetAddress
OCTET STRING (0..255)
Address of user who failed to connect to the server.
As per the MIB.
hh3cSSHUserAuthFailureReason
Object (OID)
Access
Value range
Implementation
hh3cSSHUserAuthFailureReason (1.3.6.1.4.1.25506.2.22.1.2.4)
INTEGER
exceedRetries(1),
authTimeout(2),
otherReason(3)
Reason for the connection failure.
As per the MIB.
hh3cSSHStatisticPeriod
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.22.1.2.10)
Unsigned32
(1..120)
Authentication failure statistics period.
As per the MIB.
Tabular objects
hh3cSSHUserConfigTable
About this table
Use this table to configure or obtain SSH user information.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cSSHUserName.
Object (OID)
Access
Value range
Implementation
hh3cSSHUserName (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.1)
not-accessible
DisplayString
Name of an SSH user.
hh3cSSHUserServiceType (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.2)
read-create
INTEGER
invalid(1),
all(2),
stelnet(3),
sftp(4),
scp(5),
netconf(6)
Service type of the SSH user.
The default value is invalid(1).
hh3cSSHUserAuthType (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.3)
read-create
INTEGER
invalid(1),
password(2),
publicKey(3),
any(4),
publicKeyPassword(5),
keyboardInteractive(6)
Authentication type for the SSH user.
If the value is password, the user must pass password authentication of AAA.
If the value is publicKey, the user must pass the public key authentication of PKEY module.
If the value is any, the user must pass password or public key authentication.
If the value is publicKeyPassword, the user must pass both public key authentication and password authentication.
hh3cSSHUserPublicKeyName (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.4)
read-create
DisplayString
Name of the public key used for authentication of the SSH user.
Length: 1 to 64 characters.
The default value is a zero-length string.
The value for this object is obtained from the public key generated in the PKEY module.
hh3cSSHUserWorkDirectory (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.5)
read-create
DisplayString
Work directory of the SSH user.
Not supported.
hh3cSSHUserRowStatus (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
When the hh3cSSHUserRowStatus is set to active(1), no objects in the conceptual row can be modified.
In particular, a newly created user row which uses public key authentication cannot be made active(1) until the corresponding instance of `hh3cSSHUserAuthType' is 'publicKey' or 'publicKeyPassword', and the 'hh3cSSHUserPublicKeyName' or at least one of the 'hh3cSSHUserPublicKeyName[2-6]' is configured appropriately.
hh3cSSHUserPublicKeyName2
(1.3.6.1.4.1.25506.2.22.1.1.2.1.1.7)
read-create
DisplayString
hh3cSSHUserPublicKeyName3 (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.8)
read-create
DisplayString
hh3cSSHUserPublicKeyName4 (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.9)
read-create
DisplayString
hh3cSSHUserPublicKeyName5 (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.10)
read-create
DisplayString
hh3cSSHUserPublicKeyName6 (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.11)
read-create
DisplayString
hh3cSSHSessionInfoTable
About this table
This table contains SSH session information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSSHSessionID.
Object (OID)
Access
Value range
Implementation
hh3cSSHSessionID (1.3.6.1.4.1.25506.2.22.1.1.3.1.1)
not-accessible
Integer32
VTY number of an SSH session.
As per the MIB.
hh3cSSHSessionUserName (1.3.6.1.4.1.25506.2.22.1.1.3.1.2)
read-only
DisplayString
User name of the SSH session.
hh3cSSHSessionUserIpAddrType (1.3.6.1.4.1.25506.2.22.1.1.3.1.3)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
User IP address type of the SSH session.
As per the MIB.
hh3cSSHSessionUserIpAddr (1.3.6.1.4.1.25506.2.22.1.1.3.1.4)
read-only
InetAddress
User IP address of the SSH session.
As per the MIB.
hh3cSSHSessionClientVersion (1.3.6.1.4.1.25506.2.22.1.1.3.1.5)
read-only
DisplayString
Client protocol version of the SSH session.
As per the MIB.
hh3cSSHSessionServiceType (1.3.6.1.4.1.25506.2.22.1.1.3.1.6)
read-only
INTEGER
invalid(1),
stelnet(2),
sftp(3),
scp(4),
netconf(5)
Service type of the SSH session.
As per the MIB.
hh3cSSHSessionEncry (1.3.6.1.4.1.25506.2.22.1.1.3.1.7)
read-only
INTEGER
invalid(1),
aes128CBC(2),
desCBC(3),
des3CBC(4),
aes128CTR(5),
aes192CTR(6),
aes256CTR(7),
aes128GCM(8),
aes256GCM(9),
aes256CBC(10),
other(11)
Encryption algorithm of the SSH session.
As per the MIB.
hh3cSSHSessionState (1.3.6.1.4.1.25506.2.22.1.1.3.1.8)
read-only
INTEGER
init(1),
verExchange(2),
keysExchange(3),
authRequest(4),
serviceRequest(5),
established(6),
disconnect(7)
Status of the SSH session.
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.22.1.3.0.1
User authentication failure
Informational
Informational
N/A
ON
Notification triggers
This notification is generated when the SSH user failed authentication.
This notification might be generated when the following events occur:
·     The authentication configuration on the SSH server is incorrect.
·     An unauthorized SSH client requests for authentication.
System impact
If this notification is generated frequently, illegal attacks might occur, which affects other users from coming online.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.22.1.2.1 (hh3cSSHAttemptUserName)
Name of the user.
N/A
DisplayString
OCTET STRING(SIZE (0..255))
1.3.6.1.4.1.25506.2.22.1.2.2 (hh3cSSHAttemptIpAddrType)
Address type of the user.
N/A
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
1.3.6.1.4.1.25506.2.22.1.2.3 (hh3cSSHAttemptIpAddr)
Address of the user.
N/A
InetAddress
OCTET STRING(0..255)
1.3.6.1.4.1.25506.2.22.1.2.4 (hh3cSSHUserAuthFailureReason)
Reason for the authentication failure.
N/A
INTEGER
exceedRetries(1)
authTimeout(2)
otherReason(3)
Recommended action
To resolve this issue:
1.     Verify whether the SSH client is an unauthorized client through the hh3cSSHAttemptIpAddr node:
¡     If the SSH client is an authorized client, go to step 2.
¡     If the SSH client is an unauthorized client, exclude the IP address of the client from the permit rule of the ACL.
2.     Verify whether the authentication method specified on the device is consistent with that used by the SSH client:
¡     If the authentication methods are consistent, go to step 3 if password authentication is used, go to step 5 if publickey authentication is used, and go to step 7 if X.509v3 certificate authentication is used.
¡     If the authentication methods are inconsistent, use the ssh user command to configure the SSH user correctly.
3.     Verify whether the user exists on the local or authentication server:
¡     If the user exists, go to step 4.
¡     If the user does not exist, add the user.
4.     Verify whether the username and password of the user are correct:
¡     If they are correct, go to step 9.
¡     If they are incorrect, use the correct username and password for login.
5.     Verify whether the client public key has been assigned to the user:
¡     If the public key has not been assigned, make sure the client public key has been imported to the device, and use the ssh user command to assign the key to the user.
¡     If the public key has been assigned, go to step 6.
6.     Execute the display public-key peer command to verify whether the assigned public key is correct:
¡     If the public key is incorrect, use the public-key peer command to import the correct key.
¡     If the public key is correct, go to step 9.
7.     Verify whether SSH certificate authentication has been configured:
¡     If SSH certificate authentication has not been configured, execute the ssh server pki-domain command on the device to specify a PKI domain for the SSH server, and execute the ssh user command to specify a PKI domain for the SSH client.
¡     If SSH certificate authentication has been configured, go to step 8.
8.     Use the display pki certificate domain command to verify whether the CA certificates on the SSH server and SSH client are correct:
¡     If the certificates are incorrect, execute the pki import domain command on the device to import the correct certificate file, use the ssh server pki-domain command to specify a PKI domain for the SSH server, and use the ssh user command to specify a PKI domain for the SSH client.
¡     If the certificates are correct, go to step 9.
9.     Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cSSHVersionNegotiationFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.22.1.3.0.2
SSH version negotiation failure
Informational
Informational
N/A
ON
This notification is generated when the SSH version on the SSH server is incompatible with that on the SSH client.
System impact
No negative impact on the system.
Status control
Objects
OID (object name)
Index nodes
Value range
Address type of the SSH user.
N/A
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address of the SSH user.
N/A
InetAddress
Recommended action
1.     Execute the display ssh server status command on the device to view the SSH version of the SSH server:
¡     If the SSH version is 1.99, the device supports SSH1 clients. Go to step 2.
¡     If the SSH version is 2.0, execute the ssh server compatible-ssh1x enable command on the device to enable support for SSH1 clients.
2.     Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cSSHUserLogin
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.22.1.3.0.3
User login
Informational
Informational
N/A
ON
This notification is generated when a user successfully logs in.
Status control
System impact
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.22.1.1.3.1.2 (hh3cSSHSessionUserName)
hh3cSSHSessionID
DisplayString
1.3.6.1.4.1.25506.2.22.1.1.3.1.3 (hh3cSSHSessionUserIpAddrType)
User address type of the SSH session.
hh3cSSHSessionID
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
1.3.6.1.4.1.25506.2.22.1.1.3.1.4 (hh3cSSHSessionUserIpAddr)
User address of the SSH session.
hh3cSSHSessionID
InetAddress
Recommended action
No action is required.
hh3cSSHUserLogoff
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.22.1.3.0.4
User logout
Informational
Informational
N/A
ON
This notification is generated when a user logs out.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
hh3cSSHSessionID
DisplayString
hh3cSSHSessionID
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
hh3cSSHSessionID
InetAddress
Recommended action
To resolve this issue, use the hh3cSSHSessionUserIpAddr node to verify whether the SSH client is authorized:
·     If the SSH client is unauthorized, exclude the IP address of the client from the permit rule of the ACL, and edit the user authentication configuration of the client.
·     If the SSH client is authorized, no action is required.
hh3cSSHLoginFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.22.1.3.0.5
Frequent consecutive authentication failures of a user
Error
Warning
1.3.6.1.4.1.25506.2.22.1.3.0.6(hh3cSSHLoginFailedClear)
ON
This notification is generated when the number of consecutive authentication failures of a user logging in to the SSH server reaches the upper threshold during the specified period.
System impact
The system might be attacked by unauthorized users.
Status control
Objects
OID(object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.22.1.2.9
(hh3cSSHLoginFailedTimes)
Number of authentication failures
N/A
Unsigned32
(0..65535)
(hh3cSSHStatisticPeriod)
Statistics period
N/A
Unsigned32
(1..120)
Recommended action
1.     To resolve this issue, verify whether the user is unauthorized through the logs:
¡     If the user is unauthorized, exclude the IP address of the client from the permit rule of the ACL.
¡     If the user is authorized, contact the administrator to obtain the correct username and password of the user. If the issue persists, go to step 2.
Basic information
OID
Event
Severity
Default status
SSH user authentication failure notification clear
Recovery
Warning
N/A
ON
This notification is generated when the SSH user login failure notification is cleared.
System impact
Status control
Objects
N/A
Recommended action
