| 05-HH3C-PKI-MONITOR-MIB | 406.02 KB |
hh3cPKIGetLocCertSucLdapTrapCntl
hh3cPKIGetLocCertFailLdapTrapCntl
hh3cPKIGetLocCeSucScepTrapCntl
hh3cPKIGetLocCeFailScepTrapCntl
hh3cPKILocCertNearExpirTrapCntl
hh3cPKILocCertHasExpirTrapCntl
About this MIB
Use this MIB to obtain PKI trap information and PKI trap notifications.
MIB file name
hh3c-pki-monitor.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506). hh3cCommon(2).hh3cPKIMonitor(209)
Scalar objects
hh3cPKICACertIssuer
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICACertIssuer (1.3.6.1.4.1.25506.2.209.1.1.1) |
accessible-for-notify |
DisplayString |
OCTET STRING (0..255) |
Issuer of a CA certificate. |
As per the MIB. |
hh3cPKICACertSubject
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICACertSubject (1.3.6.1.4.1.25506.2.209.1.1.2) |
DisplayString |
Subject of a CA certificate. |
As per the MIB. |
hh3cPKICACertStartTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICACertStartTime (1.3.6.1.4.1.25506.2.209.1.1.3) |
DateAndTime |
OCTET STRING (8 | 11) |
Time when a CA certificate becomes valid. |
As per the MIB. |
hh3cPKICACertFinishTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICACertFinishTime (1.3.6.1.4.1.25506.2.209.1.1.4) |
DateAndTime |
Time when a CA certificate expires. |
As per the MIB. |
hh3cPKICrlIssuer
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICrlIssuer (1.3.6.1.4.1.25506.2.209.1.1.5) |
DisplayString |
Issuer of a CRL. |
As per the MIB. |
hh3cPKICrlStartTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICrlStartTime (1.3.6.1.4.1.25506.2.209.1.1.6) |
DateAndTime |
Time when a CRL becomes valid. |
As per the MIB. |
hh3cPKICrlFinishTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICrlFinishTime (1.3.6.1.4.1.25506.2.209.1.1.7) |
DateAndTime |
Time when a CRL expires. |
As per the MIB. |
hh3cPKIDomainName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIDomainName (1.3.6.1.4.1.25506.2.209.1.1.8) |
OCTET STRING |
OCTET STRING (0..31) |
PKI domain name. |
As per the MIB. |
hh3cPKICrlUrl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICrlUrl (1.3.6.1.4.1.25506.2.209.1.1.9) |
OCTET STRING |
OCTET STRING (0..1023) |
CRL repository URL. |
As per the MIB. |
hh3cPKIVrfName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIVrfName (1.3.6.1.4.1.25506.2.209.1.1.10) |
OCTET STRING |
VPN instance name. |
As per the MIB. |
hh3cPKICertUrl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICertUrl (1.3.6.1.4.1.25506.2.209.1.1.11) |
OCTET STRING |
URL for certificate request. |
As per the MIB. |
hh3cPKILocalCertIssuer
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKILocalCertIssuer (1.3.6.1.4.1.25506.2.209.1.1.12) |
DisplayString |
Issuer of a local certificate. |
As per the MIB. |
hh3cPKILocalCertSubject
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKILocalCertSubject (1.3.6.1.4.1.25506.2.209.1.1.13) |
DisplayString |
Subject of a local certificate. |
As per the MIB. |
hh3cPKILocalCertStartTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKILocalCertStartTime (1.3.6.1.4.1.25506.2.209.1.1.14) |
DateAndTime |
Time when a local certificate becomes valid. |
As per the MIB. |
hh3cPKILocalCertFinishTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKILocalCertFinishTime (1.3.6.1.4.1.25506.2.209.1.1.15) |
DateAndTime |
Time when a local certificate expires. |
As per the MIB. |
hh3cPKIEntityName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIEntityName (1.3.6.1.4.1.25506.2.209.1.1.16) |
OCTET STRING |
PKI entity name. |
As per the MIB. |
hh3cPKICertSave
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICertSave (1.3.6.1.4.1.25506.2.209.1.1.17) |
DisplayString |
Saved certificate file name. |
As per the MIB. |
hh3cPKITrapGlobalCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKITrapGlobalCntl (1.3.6.1.4.1.25506.2.209.1.2.1) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable trap notifications for PKI trap events globally. |
As per the MIB. |
hh3cPKICACertInvalidTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICACertInvalidTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.2) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKICACertInvalid trap notifications. |
As per the MIB. |
hh3cPKICACertValidTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICACertValidTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.3) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKICACertValid trap notifications. |
As per the MIB. |
hh3cPKICrlInvalidTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICrlInvalidTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.4) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKICrlInvalid trap notifications. |
As per the MIB. |
hh3cPKICrlValidTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICrlValidTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.5) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKICrlValid trap notifications. |
As per the MIB. |
hh3cPKIGetCrlSucHttpTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetCrlSucHttpTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.6) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetCrlSucHttp trap notifications. |
As per the MIB. |
hh3cPKIGetCrlFailHttpTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetCrlFailHttpTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.7) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetCrlFailHttp trap notifications. |
As per the MIB. |
hh3cPKIGetCrlSucLdapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetCrlSucLdapCntl (1.3.6.1.4.1.25506.2.209.1.2.8) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetCrlSucLdap trap notifications. |
As per the MIB. |
hh3cPKIGetCrlFailLdapTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetCrlFailLdapTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.9) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetCrlFailLdap trap notifications. |
As per the MIB. |
hh3cPKIGetCrlSucScepTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetCrlSucScepTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.10) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetCrlSucScep trap notifications. |
As per the MIB. |
hh3cPKIGetCrlFailScepTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetCrlFailScepTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.11) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetCrlFailSceptrap notifications. |
As per the MIB. |
hh3cPKILocCertInvalidTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKILocCertInvalidTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.12) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKILocCertInvalid trap notifications. |
As per the MIB. |
hh3cPKILocCertValidTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKILocCertValidTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.13) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKILocCertValid trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetLocCertSucLdapTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.14) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetLocCertSucLdap trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetLocCertFailLdapTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.15) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetLocCertFailLdap trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetLocCeSucScepTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.16) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetLocCeSucScep trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIGetLocCeFailScepTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.17) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIGetLocCeFailSceptrap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKILocCertNearExpirTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.18) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKILocCertNearExpir trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKILocCertHasExpirTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.19) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKILocCertHasExpir trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKICrlHasExpiredTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.20) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKICrlHasExpired trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPKIWriteToFlashFailTrapCntl (1.3.6.1.4.1.25506.2.209.1.2.21) |
read-write |
TruthValue |
Integer32 (1,2) |
Whether to enable hh3cPKIWriteToFlashFail trap notifications. |
As per the MIB. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.1 |
Invalid CA certificate. |
Informational |
Warning |
N/A |
OFF |
Notification triggers
This notification is generated when a CA certificate becomes invalid.
This notification might be generated when the following events occur:
· The system time of the device is not synchronized with that of the CA server.
· The fingerprint for verifying the root CA certificate is illegal.
· The format of the CA certificate does not meet the certificate requirements.
· The signature algorithm and public key length of the CA certificate do not meet the related requirements in FIPS mode.
System impact
Certificate-related services are unavailable.
Status control
ON
· CLI: Use the snmp-agent trap enable pki ca-cert-invalid command.
· MIB: Set hh3cPKICACertInvalidTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki ca-cert-invalid command.
· MIB: Set hh3cPKICACertInvalidTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.209.1.1.1 (hh3cPKICACertIssuer) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.209.1.1.2 (hh3cPKICACertSubject) |
Subject of the CA certificate. |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.209.1.1.3 (hh3cPKICACertStartTime) |
Time when the CA certificate becomes valid. |
N/A |
DateAndTime |
1.3.6.1.4.1.25506.2.209.1.1.4 (hh3cPKICACertFinishTime) |
Time when the CA certificate expires. |
N/A |
DateAndTime |
Recommended action
To resolve this issue:
1. Use the display clock command to view whether the device is time synchronized with the CA server:
¡ If no, use the clock datetime command in user view to synchronize the system time of the device with that of the CA server.
¡ If yes, go to step 2.
2. Check whether the fingerprint for verifying the root CA certificate is legal:
¡ If no, use the root-certificate fingerprint command to configure a legal fingerprint for verifying the root CA certificate.
¡ If yes, go to step 3.
3. Request a new CA certificate in online or offline mode.
4. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cPKICACertValid
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.2 |
Valid CA certificate. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when a CA certificate becomes valid.
System impact
No negative impact on services.
Status control
ON
· CLI: Use the snmp-agent trap enable pki ca-cert-valid command.
· MIB: Set hh3cPKICACertValidTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki ca-cert-valid command.
· MIB: Set hh3cPKICACertValidTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
DisplayString |
N/A |
DisplayString |
N/A |
DateAndTime |
N/A |
DateAndTime |
Recommended action
No action is required.
hh3cPKICrlInvalid
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.3 |
Invalid CRL. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when a CRL becomes invalid.
· Failed to verify the signature of the CRL by using the public key of the CA certificate.
· The signature algorithm of the CRL does not meet the requirements in FIPS mode.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki crl-invalid command.
· MIB: Set hh3cPKICrlInvalidTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki crl-invalid command.
· MIB: Set hh3cPKICrlInvalidTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.209.1.1.5 (hh3cPKICrlIssuer) |
Issuer of a CRL. |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.209.1.1.6 (hh3cPKICrlStartTime) |
Time when the CRL becomes valid. |
N/A |
DateAndTime |
1.3.6.1.4.1.25506.2.209.1.1.7 (hh3cPKICrlFinishTime) |
Time when the CRL expires. |
N/A |
DateAndTime |
Recommended action
2. Obtain the CA certificate again, and obtain a new CRL through HTTP, LDAP, or SCEP.
3. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cPKICrlValid
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.4 |
Valid CRL. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when a CRL becomes valid.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki crl-valid command.
· MIB: Set hh3cPKICrlValidTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki crl-valid command.
· MIB: Set hh3cPKICrlValidTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Issuer of a CRL. |
N/A |
DisplayString |
N/A |
DateAndTime |
N/A |
DateAndTime |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.5 |
Obtaining a CRL through HTTP succeeded. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a CRL through HTTP succeeded.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki crl-http-success command.
· MIB: Set hh3cPKIGetCrlSucHttpTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki crl-http-success command.
· MIB: Set hh3cPKIGetCrlSucHttpTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.209.1.1.8 (hh3cPKIDomainName) |
PKI domain name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.209.1.1.9 (hh3cPKICrlUrl) |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.209.1.1.10 (hh3cPKIVrfName) |
N/A |
OCTET STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.6 |
Obtaining a CRL through HTTP failed. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a CRL through HTTP failed.
· The system time of the device is not synchronized with that of the HTTP server.
· The device and the HTTP server cannot reach each other.
· The CA server does not issue CRLs.
· The configured URL of the CRL repository is incorrect.
· Services unavailable on the HTTP server.
System impact
Certificate-related services are unavailable when the CRL expires.
Status control
ON
· CLI: Use the snmp-agent trap enable pki crl-http-failure command.
· MIB: Set hh3cPKIGetCrlFailHttpTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki crl-http-failure command.
· MIB: Set hh3cPKIGetCrlFailHttpTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
Recommended action
1. Use the display clock command to view whether the device is time synchronized with the HTTP server:
¡ If no, use the clock datetime command in user view to synchronize the system time of the device with that of the HTTP server.
2. Use the ping command to check whether the HTTP server is reachable:
¡ If no, troubleshoot the routes and physical links, and make sure the HTTP server is reachable.
3. Check whether the CA server issues CRLs:
¡ If no, make sure the CA server supports publishing CRLs.
¡ If yes, go to step 4.
4. Check whether the configured URL of the CRL repository is correct:
¡ If no, use the crl url command to configure the URL of the CRL repository correctly.
¡ If yes, go to step 5.
5. Check whether the services on the HTTP server are normal:
¡ If no, make sure the services on the HTTP server are normal.
¡ If yes, go to step 6.
6. Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.7 |
Obtaining a CRL through LDAP succeeded. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a CRL through LDAP succeeded.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki crl-ldap-success command.
· MIB: Set hh3cPKIGetCrlSucLdapTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki crl-ldap-success command.
· MIB: Set hh3cPKIGetCrlSucLdapTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.8 |
Obtaining a CRL through LDAP failed. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a CRL through LDAP failed.
· The system time of the device is not synchronized with that of the LDAP server.
· The device and the LDAP server cannot reach each other.
· The LDAP server's host name or IP address is neither contained in the CRL repository URL nor configured in the PKI domain.
· Services unavailable on the LDAP server.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki crl-ldap-failure command.
· MIB: Set hh3cPKIGetCrlFailLdapTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki crl-ldap-failure command.
· MIB: Set hh3cPKIGetCrlFailLdapTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
Recommended action
1. Use the display clock command to view whether the device is time synchronized with the LDAP server:
¡ If no, use the clock datetime command in user view to synchronize the system time of the device with that of the LDAP server.
2. Use the ping command to check whether the LDAP server is reachable:
¡ If no, troubleshoot the routes and physical links, and make sure the LDAP server is reachable.
5. Check whether the LDAP server's host name or IP address is correctly configured in the PKI domain:
¡ If no, use the ldap-server command to correctly configure the LDAP server's host name or IP address.
6. Check whether the services on the LDAP server are normal:
¡ If no, make sure the services on the LDAP server are normal.
¡ If yes, go to step 7.
7. Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.9 |
Obtaining a CRL through SCEP succeeded. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a CRL through SCEP succeeded.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki crl-scep-success command.
· MIB: Set hh3cPKIGetCrlSucScepTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki crl-scep-success command.
· MIB: Set hh3cPKIGetCrlSucScepTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.209.1.1.11 (hh3cPKICertUrl) |
N/A |
OCTET STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.10 |
Obtaining a CRL through SCEP failed. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a CRL through SCEP failed.
· The device and the CA server cannot reach each other.
· No local certificates and key pairs are obtained before the device tries to obtain CRLs.
· The certificate request reception authority is not configured or is configured incorrectly.
· The source IP address for PKI protocol packets is not configured or is configured incorrectly.
· Services unavailable on the CA server.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki crl-scep-failure command.
· MIB: Set hh3cPKIGetCrlFailScepTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki crl-scep-failure command.
· MIB: Set hh3cPKIGetCrlFailScepTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
Recommended action
2. Use the ping command to check whether the CA server is reachable:
¡ If no, troubleshoot the routes and physical links, and make sure the CA server is reachable.
3. Check whether local certificates and key pairs are obtained:
¡ If no, obtain a new local certificate in online or offline mode, and obtain the corresponding key pair.
4. Check whether the certificate request reception authority is configured and configured correctly:
¡ If the certificate request reception authority is not configured or incorrect, use the certificate request from command to specify the correct certificate request reception authority.
5. Check whether a correct source IP address for PKI protocol packets exists:
¡ If no, use the source command to specify the correct source IP address that the CA server can accept. For the correct settings, contact the CA administrator.
6. Check whether the services on the CA server are normal:
¡ If no, make sure the services on the CA server are normal.
hh3cPKILocalCertInvalid
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.11 |
Invalid local certificate. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when a local certificate is invalid.
· Failed to verify the signature of the local certificate by using the public key of the CA certificate.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki local-cert-invalid command.
· MIB: Set hh3cPKILocCertInvalidTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki local-cert-invalid command.
· MIB: Set hh3cPKILocCertInvalidTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.209.1.1.12 (hh3cPKILocalCertIssuer) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.209.1.1.13 (hh3cPKILocalCertSubject) |
Subject of the local certificate. |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.209.1.1.14 (hh3cPKILocalCertStartTime) |
Time when the local certificate becomes valid. |
N/A |
DateAndTime |
1.3.6.1.4.1.25506.2.209.1.1.15 (hh3cPKILocalCertFinishTime) |
Time when the local certificate expires. |
N/A |
DateAndTime |
Recommended action
2. Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cPKILocalCertValid
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.12 |
Valid local certificate. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when a local certificate is valid.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki local-cert-valid command.
· MIB: Set hh3cPKILocCertValidTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki local-cert-valid command.
· MIB: Set hh3cPKILocCertValidTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
DisplayString |
N/A |
DisplayString |
N/A |
DateAndTime |
N/A |
DateAndTime |
Recommended action
hh3cPKIGetLocalCertSucLdap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.13 |
Obtaining a local certificate through LDAP succeeded. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a local certificate through LDAP succeeded.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki local-cert-ldap-success command.
· MIB: Set hh3cPKIGetCertSucLdapTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki local-cert-ldap-success command.
· MIB: Set hh3cPKIGetCertSucLdapTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.209.1.1.16 (hh3cPKIEntityName) |
PKI entity name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.209.1.1.17 (hh3cPKICertSave) |
N/A |
DisplayString |
Recommended action
hh3cPKIGetLocalCertFailLdap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.14 |
Obtaining a local certificate through LDAP failed. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a local certificate through LDAP failed.
· The host name or IP address of the LDAP server is not configured or is configured incorrectly in the PKI domain.
· No PKI entity for certificate request is configured in the PKI domain or the PKI entity configuration is incorrect.
· No key pair is specified for certificate request in the PKI domain, or the specified key pair does not match the one contained in the local certificate to be obtained.
System impact
Certificate-related services are unavailable when the certificate expires.
Status control
ON
· CLI: Use the snmp-agent trap enable pki local-cert-ldap-failure command.
· MIB: Set hh3cPKIGetCertFailLdapTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki local-cert-ldap-failure command.
· MIB: Set hh3cPKIGetCertFailLdapTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
PKI entity name. |
N/A |
OCTET STRING |
N/A |
DisplayString |
Recommended action
3. Check whether the correct host name or IP address of the LDAP server is configured in the PKI domain:
¡ If the host name is not configured or is configured incorrectly, use the ldap-server command to specify an LDAP server for the PKI domain.
4. Check whether a correct PKI entity for certificate request is configured in the PKI domain:
¡ If no PKI entity is configured or the configuration is incorrect, use the certificate request entity command to specify a PKI entity for certificate request.
5. Check whether a correct key pair for certificate request is specified in the PKI domain:
¡ If no key pair is specified or the key pair is specified incorrectly, use the public-key command to specify a key pair and make sure the key pair matches the one contained in the local certificate to be obtained.
hh3cPKIGetLocalCertSucScep
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.15 |
Obtaining a local certificate through SCEP succeeded. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a local certificate through SCEP succeeded.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki local-cert-scep-success command.
· MIB: Set hh3cPKIGetLocCeSucScepTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki local-cert-scep-success command.
· MIB: Set hh3cPKIGetLocCeSucScepTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
DisplayString |
Recommended action
hh3cPKIGetLocalCertFailScep
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.16 |
Obtaining a local certificate through SCEP failed. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when obtaining a local certificate through SCEP failed.
· The key pair specified in the PKI domain does not match the one contained in the local certificate to be obtained.
· The URL of the certificate request reception authority is specified incorrectly in the PKI domain.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki local-cert-scep-failure command.
· MIB: Set hh3cPKIGetLocCeFailScepTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki local-cert-scep-failure command.
· MIB: Set hh3cPKIGetLocCeFailScepTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
DisplayString |
Recommended action
3. Check whether a correct key pair is specified in the PKI domain:
¡ If no, use the public-key command to specify a key pair and make sure the key pair matches the one contained in the local certificate to be obtained.
4. Check whether the correct URL of the certificate request reception authority is specified in the PKI domain:
¡ If no, use the certificate request url command to specify the URL of the certificate request reception authority.
5. Check whether the services on the CA server are normal:
hh3cPKILocalCertNearlyExpired
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.17 |
A local certificate is about to expire. |
Informational |
Warning |
N/A |
OFF |
This notification is generated 30 or fewer days prior to expiration of the local certificate.
· The time difference between the certificate expiration time and the current system time of the device is 30 or fewer days.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki local-cert-nearly-expired command.
· MIB: Set hh3cPKILocCertNearExpirTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki local-cert-nearly-expired command.
· MIB: Set hh3cPKILocCertNearExpirTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
DisplayString |
N/A |
DisplayString |
N/A |
DateAndTime |
N/A |
DateAndTime |
Recommended action
2. Request a new certificate in offline mode or through SCEP/LDAP in online mode.
hh3cPKILocalCertHasExpired
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.18 |
A local certificate expired. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when the validity end time of a local certificate is before the current system time of the device.
· The validity end time of the local certificate is before the current system time of the device.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki local-cert-has-expired command.
· MIB: Set hh3cPKILocCertHasExpirTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki local-cert-has-expired command.
· MIB: Set hh3cPKILocCertHasExpirTrapCntl to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PKI domain name. |
N/A |
OCTET STRING |
N/A |
DisplayString |
N/A |
DisplayString |
N/A |
DateAndTime |
N/A |
DateAndTime |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.209.1.3.0.20 |
Failed to write certificate and CRL files to flash. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when certificate and CRL files failed to be written to flash, possibly because the device does not have enough storage space to store these files.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable pki write-to-flash-fail command.
· MIB: Set hh3cPKIWriteToFlashFailTrapCntl to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable pki write-to-flash-fail command.
· MIB: Set hh3cPKIWriteToFlashFailTrapCntl to false(2).
Objects
N/A
Recommended action
1. Use the dir command to check the device storage space:
¡ If the device does not have enough storage space, delete some unnecessary files to free up space for storing certificates and CRL files.
¡ If the device has enough storage space, go to step 2.
