04-IF-MIB | 193.67 KB |
IF-MIB
About this MIB
This MIB describes generic attributes for network interfaces.
MIB file name
rfc2863-if.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ifMIB(31)
Scalar objects
ifNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifNumber(1.3.6.1.2.1.2.1) |
read-only |
Integer32 |
Integer32(1..2147483647) |
Number of interfaces. |
As per the MIB. |
ifTableLastChange
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifTableLastChange (1.3.6.1.2.1.31.1.5) |
read-only |
TimeTicks |
TimeTicks (0..4294967295) |
Value of sysUpTime at the time of the last creation or deletion of an entry in the IfTable. |
Not supported |
ifStackLastChange
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifStackLastChange (1.3.6.1.2.1.31.1.6) |
read-only |
TimeTicks |
Value of sysUpTime at the time of the last creation or deletion of the whole interface stack. |
Not supported |
Tabular objects
ifTable
About this table
Use this table to obtain information about an interface by interface index.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifIndex (1.3.6.1.2.1.2.2.1.1) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Index of an interface. |
As per the MIB. |
ifDescr (1.3.6.1.2.1.2.2.1.2) |
read-only |
DisplayString |
OCTET STRING(0..255) |
Description of the interface. |
A string that contains information about the interface, null0, Vlan-interface2, Gigabitethernet1/0/1, Ten-Gigabitethernet2/0/1, for example. |
ifType (1.3.6.1.2.1.2.2.1.3) |
read-only |
IANAifType |
INTEGER { other(1), regular1822(2), hdh1822(3), ddnX25(4), rfc877x25(5), ethernetCsmacd(6), iso88023Csmacd(7), iso88024TokenBus(8), iso88025TokenRing(9), iso88026Man(10), starLan(11), proteon10Mbit(12), proteon80Mbit(13), hyperchannel(14), fddi(15), lapb(16), sdlc(17), ds1(18), e1(19), basicISDN(20), primaryISDN(21), propPointToPointSerial(22), ppp(23), softwareLoopback(24), eon(25), ethernet3Mbit(26), nsip(27), slip(28), ultra(29), ds3(30), sip(31), frameRelay(32), rs232(33), para(34), arcnet(35), arcnetPlus(36), atm(37), miox25(38), sonet(39), x25ple(40), iso88022llc(41), localTalk(42), smdsDxi(43), frameRelayService(44), v35(45), hssi(46), hippi(47), modem(48), aal5(49), sonetPath(50), sonetVT(51), smdsIcip(52), propVirtual(53), propMultiplexor(54), ieee80212(55), fibreChannel(56), hippiInterface(57), frameRelayInterconnect(58), aflane8023(59), aflane8025(60), cctEmul(61), fastEther(62), isdn(63), v11(64), v36(65), g703at64k(66), g703at2mb(67), qllc(68), fastEtherFX(69), channel(70), ieee80211(71), ibm370parChan(72), escon(73), dlsw(74), isdns(75), isdnu(76), lapd(77), ipSwitch(78), rsrb(79), atmLogical(80), ds0(81), ds0Bundle(82), bsc(83), async(84), cnr(85), iso88025Dtr(86), eplrs(87), arap(88), propCnls(89), hostPad(90), termPad(91), frameRelayMPI(92), x213(93), adsl(94), radsl(95), sdsl(96), vdsl(97), iso88025CRFPInt(98), myrinet(99), voiceEM(100), voiceFXO(101), voiceFXS(102), voiceEncap(103), voiceOverIp(104), atmDxi(105), atmFuni(106), atmIma(107), pppMultilinkBundle(108), ipOverCdlc(109), ipOverClaw(110), stackToStack(111), virtualIpAddress(112), mpc(113), ipOverAtm(114), iso88025Fiber(115), tdlc(116), gigabitEthernet(117), hdlc(118), lapf(119), v37(120), x25mlp(121), x25huntGroup(122), transpHdlc(123), interleave(124), fast(125), ip(126), docsCableMaclayer(127), docsCableDownstream(128), docsCableUpstream(129), a12MppSwitch(130), tunnel(131), coffee(132), ces(133), atmSubInterface(134), l2vlan(135), l3ipvlan(136), l3ipxvlan(137), digitalPowerline(138), mediaMailOverIp(139), dtm(140), dcn(141), ipForward(142), msdsl(143), ieee1394(144), if-gsn(145), dvbRccMacLayer(146), dvbRccDownstream(147), dvbRccUpstream(148), atmVirtual(149), mplsTunnel(150), srp(151), voiceOverAtm(152), voiceOverFrameRelay(153), idsl(154), compositeLink(155), ss7SigLink(156), propWirelessP2P(157), frForward(158), rfc1483(159), usb(160), ieee8023adLag(161), bgppolicyaccounting(162), frf16MfrBundle(163), h323Gatekeeper(164), h323Proxy(165), mpls(166), mfSigLink(167), hdsl2(168), shdsl(169), ds1FDL(170), pos(171), dvbAsiIn(172), dvbAsiOut(173), plc(174), nfas(175), tr008(176), gr303RDT(177), gr303IDT(178), isup(179), propDocsWirelessMaclayer(180), propDocsWirelessDownstream(181), propDocsWirelessUpstream(182), hiperlan2(183), propBWAp2Mp(184), sonetOverheadChannel(185), digitalWrapperOverheadChannel(186), aal2(187), radioMAC(188), atmRadio(189), imt(190), mvl(191), reachDSL(192), frDlciEndPt(193), atmVciEndPt(194), opticalChannel(195), opticalTransport(196), propAtm(197), voiceOverCable(198), infiniband(199), teLink(200), q2931(201), virtualTg(202), sipTg(203), sipSig(204), docsCableUpstreamChannel(205), econet(206), pon155(207), pon622(208), bridge(209), linegroup(210), voiceEMFGD(211), voiceFGDEANA(212), voiceDID(213), mpegTransport(214), sixToFour(215), gtp(216), pdnEtherLoop1(217), pdnEtherLoop2(218), opticalChannelGroup(219), homepna(220), gfp(221), ciscoISLvlan(222), actelisMetaLOOP(223), fcipLink(224), rpr(225), qam(226), lmp(227), cblVectaStar(228), docsCableMCmtsDownstream(229), adsl2(230), macSecControlledIF(231), macSecUncontrolledIF(232), aviciOpticalEther(233), atmbond(234), voiceFGDOS(235), mocaVersion1(236), ieee80216WMAN(237), adsl2plus(238), dvbRcsMacLayer(239), dvbTdm(240), dvbRcsTdma(241), x86Laps(242), wwanPP(243), wwanPP2(244), voiceEBS(245), ifPwType(246), ilan(247), pip(248), aluELP(249), gpon(250), vdsl2(251), capwapDot11Profile(252), capwapDot11Bss(253), capwapWtpVirtualRadio(254), bits(255), docsCableUpstreamRfPort(256), cableDownstreamRfPort(257), switchstack(65534) } |
Type of the interface. |
Implementation varies by product. |
ifMtu (1.3.6.1.2.1.2.2.1.4) |
read-only |
Integer32 |
MTU of the interface. |
Size of the largest packet that can be received or forwarded on the interface. This object is inapplicable to aggregate interfaces. |
ifSpeed (1.3.6.1.2.1.2.2.1.5) |
read-only |
Gauge32 |
Gauge32 (0..4294967295) |
Speed of the interface. |
Estimated bandwidth of the interface. |
ifPhysAddress (1.3.6.1.2.1.2.2.1.6) |
read-only |
PhysAddress |
OCTET STRING |
MAC address of the interface. |
Implementation varies by product. For a switch, only the following types of interfaces have a MAC address: · M-Ethernet port. · Vlan interface. · Ethernet port. · GigabitEthernet port. · XGigabitEthernet port. · Forty-GigabitEthernet port. · Hundred-GigabitEthernet port. |
ifAdminStatus (1.3.6.1.2.1.2.2.1.7) |
read- write |
OCTET STRING |
up(1), down(2), testing(3) |
Default status of the interface. |
Supports only the values up(1) and down(2). |
ifOperStatus (1.3.6.1.2.1.2.2.1.8) |
read-only |
OCTET STRING |
up(1), down(2), testing(3), unknown(4), dormant(5), notPresent(6), lowerLayerDown(7) |
Operational status of the interface. |
Current operational status of the interface. |
ifLastChange (1.3.6.1.2.1.2.2.1.9) |
read-only |
TimeTicks |
Duration of the interface. |
Time elapsed since the interface entered in the current status. |
ifInOctets (1.3.6.1.2.1.2.2.1.10) |
read-only |
Counter32 |
Counter32 (0..4294967295) |
Number of octets in incoming packets. |
As per the MIB. |
ifInUcastPkts (1.3.6.1.2.1.2.2.1.11) |
read-only |
Counter32 |
Number of incoming unicast packets. |
As per the MIB. |
ifInNUcastPkts (1.3.6.1.2.1.2.2.1.12) |
read-only |
Counter32 |
Number of incoming non-unicast packets. |
As per the MIB. |
ifInDiscards (1.3.6.1.2.1.2.2.1.13) |
read-only |
Counter32 |
Number of incoming packets that were dropped. |
Implementation varies by product. Not supported by switches. |
ifInErrors (1.3.6.1.2.1.2.2.1.14) |
read-only |
Counter32 |
Number of incoming packets that contain errors. |
As per the MIB. |
ifInUnknownProtos (1.3.6.1.2.1.2.2.1.15) |
read-only |
Counter32 |
Number of incoming protocol-unknown packets. |
As per the MIB. |
ifOutOctets (1.3.6.1.2.1.2.2.1.16) |
read-only |
Counter32 |
Number of octets in outgoing packets. |
As per the MIB. |
ifOutUcastPkts (1.3.6.1.2.1.2.2.1.17) |
read-only |
Counter32 |
Number of outgoing unicast packets. |
As per the MIB. |
ifOutNUcastPkts (1.3.6.1.2.1.2.2.1.18) |
read-only |
Counter32 |
Number of outgoing non-unicast packets. |
As per the MIB. |
ifOutDiscards (1.3.6.1.2.1.2.2.1.19) |
read-only |
Counter32 |
Number of outgoing packets that were dropped. |
As per the MIB. |
ifOutErrors (1.3.6.1.2.1.2.2.1.20) |
read-only |
Counter32 |
Number of outgoing packets that contain errors. |
As per the MIB. |
ifOutQLen (1.3.6.1.2.1.2.2.1.21) |
read-only |
Gauge32 |
Length of the outgoing packet queue. |
ifSpecific (1.3.6.1.2.1.2.2.1.22) |
read-only |
OCTET IDENTIFIER |
OCTET IDENTIFIER |
Interface for realize specific definitions. |
Not supported |
ifXTable
About this table
Use this table to obtain information about an interface by interface name.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is ifName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifName (1.3.6.1.2.1.31.1.1.1.1) |
read-only |
DisplayString |
Name of an interface. |
Interface name. |
ifInMulticastPkts (1.3.6.1.2.1.31.1.1.1.2) |
read-only |
Counter32 |
Number of incoming multicast packets. |
As per the MIB. |
ifInBroadcastPkts (1.3.6.1.2.1.31.1.1.1.3) |
read-only |
Counter32 |
Number of incoming broadcast packets. |
As per the MIB. |
ifOutMulticastPkts (1.3.6.1.2.1.31.1.1.1.4) |
read-only |
Counter32 |
Number of outgoing multicast packets. |
As per the MIB. |
ifOutBroadcastPkts (1.3.6.1.2.1.31.1.1.1.5) |
read-only |
Counter32 |
Number of outgoing broadcast packets. |
As per the MIB. |
ifHCInOctets (1.3.6.1.2.1.31.1.1.1.6) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
As per the MIB. |
ifHCInUcastPkts (1.3.6.1.2.1.31.1.1.1.7) |
read-only |
Counter64 |
As per the MIB. |
ifHCInMulticastPkts (1.3.6.1.2.1.31.1.1.1.8) |
read-only |
Counter64 |
As per the MIB. |
ifHCInBroadcastPkts (1.3.6.1.2.1.31.1.1.1.9) |
read-only |
Counter64 |
As per the MIB. |
ifHCOutOctets (1.3.6.1.2.1.31.1.1.1.10) |
read-only |
Counter64 |
Number of octets in outgoing multicast packets. |
As per the MIB. |
ifHCOutUcastPkts (1.3.6.1.2.1.31.1.1.1.11) |
read-only |
Counter64 |
As per the MIB. |
ifHCOutMulticastPkts (1.3.6.1.2.1.31.1.1.1.12) |
read-only |
Counter64 |
As per the MIB. |
ifHCOutBroadcastPkts (1.3.6.1.2.1.31.1.1.1.13) |
read-only |
Counter64 |
As per the MIB. |
ifLinkUpDownTrapEnable (1.3.6.1.2.1.31.1.1.1.14) |
read-write |
INTEGER |
enabled(1), disabled(2) |
Whether to enable link-up or link-down traps on the interface. |
As per the MIB. |
ifHighSpeed (1.3.6.1.2.1.31.1.1.1.15) |
read-only |
Gauge32 |
Bandwidth of the interface. |
As per the MIB. |
ifPromiscuousMode (1.3.6.1.2.1.31.1.1.1.16) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of promiscuous mode. |
ifConnectorPresent (1.3.6.1.2.1.31.1.1.1.17) |
read-only |
TruthValue |
true(1), false(2) |
Whether the interface sublayer has a physical connector. |
As per the MIB. |
ifAlias (1.3.6.1.2.1.31.1.1.1.18) |
read-write |
DisplayStringOCTET STRING |
OCTET STRING(0..64) |
Alias of the interface. |
As per the MIB. |
ifCounterDiscontinuityTime (1.3.6.1.2.1.31.1.1.1.19) |
read-only |
TimeTicks |
Time when the interface's counters suffered discontinuity. |
ifRcvAddressTable
About this table
Use this table to configure the address of an interface to receive packets.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Supported |
Supported |
Columns
The table index is ifRcvAddressAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifRcvAddressAddress (1.3.6.1.2.1.31.1.4.1.1) |
not-accessible |
PhysAddress |
OCTET STRING (4) |
Address of an interface to receive packets. |
ifRcvAddressStatus (1.3.6.1.2.1.31.1.4.1.2) |
read-create |
INTEGER |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Status of the receiving address. |
ifRcvAddressType (1.3.6.1.2.1.31.1.4.1.3) |
read-create |
INTEGER |
other(1), volatile(2), nonVolatile(3) |
Type of the receiving address. |
Notifications
This section contains the IF-MIB notifications.
linkDown
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.6.3.1.1.5.3 |
Link down. |
Error |
Major |
1.3.6.1.6.3.1.1.5.4 (linkUp) |
ON |
Notification triggers
This notification is generated when the SNMPv2 entity, acting in an agent role, has detected that the ifOperStatus object for one of its communication links is about to enter the down state from some other state (but not from the notPresent state. Other states refer to the values of the ifOperStatus variable.
Possible reasons are:
· The physical link of the interface is down, and the link is disconnected.
· The interface goes down at the data link layer.
· The interface is shut down.
· This notification is generated if an interface is deleted.
System impact
The interface cannot normally forward packets, and the services carried over the interface are interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable standard linkdown command.
OFF
CLI: Use the undo snmp-agent trap enable standard linkdown command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
ifIndex |
InterfaceIndex |
1.3.6.1.2.1.2.2.1.7 (ifAdminStatus) |
Administrative status of the interface. |
ifIndex |
INTEGER |
up(1) down(2) testing(3) |
1.3.6.1.2.1.2.2.1.8 (ifOperStatus) |
ifIndex |
INTEGER |
up(1) down(2) testing(3) unknown(4) dormant(5) notPresent(6) lowerLayerDown(7) |
Recommended action
To resolve the issue:
1. If this interface is deleted, no action is required.
2. Execute the display this command in interface view to identify whether the interfaces on both end are shut down. If the interfaces are shut down, execute the undo shutdown command in interface view to bring them up. Identify whether the interfaces have restored.
3. Execute the display interface [ interface-type [ interface-number ] ] command to view the interface state. If an interface is down at the data link layer, check the protocol down reason according to the data link layer protocol.
4. Identify whether the physical connection is normal (for example, whether the network cables or transceiver modules are firmly connected). If the physical connection is abnormal, correctly connect the interfaces. Identify whether the alarm is cleared.
5. If the issue persists, contact H3C Support.
linkUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.6.3.1.1.5.4 |
Link up. |
Recovery |
Major |
N/A |
ON |
This notification is generated when that the SNMPv2 entity, acting in an agent role, has detected that the ifOperStatus object for one of its communication links left the down state and transitioned into some other state (but not into the notPresent state). Other states refer to the values of the ifOperStatus variable.
· The undo shutdown command is executed on the interface.
· The interface or link failure is resolved.
· The physical state of the interface comes up.
· The interface comes up at the data link layer.
· The newly created interface can operate normally.
System impact
The interface can normally forward packets.
Status control
ON
CLI: Use the snmp-agent trap enable standard linkup command.
OFF
CLI: Use the undo snmp-agent trap enable standard linkup command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
ifIndex |
InterfaceIndex |
ifIndex |
INTEGER |
ifIndex |
INTEGER |
Recommended action
No action is required.
