- 20-Network Management and Monitoring Configuration Guide
- 01-Ping and tracert configuration
- 02-System debugging configuration
- 03-NQA configuration
- 04-SNMP configuration
- 05-RMON configuration
- 06-NETCONF configuration
- 07-Process monitoring and maintenance configuration
- 08-Mirroring configuration
- 09-Email Notification Service Configuration
- 10-SQA configuration
- 11-UCC configuration
- 12-Packet capture configuration
00-Preface | 110.43 KB |
Preface
The WX3800X Series access controllers documentation set describes the software features for the access controllers and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The Network Management and Monitoring Configuration Guide describes the fundamentals and configuration procedures for the network management and monitoring features, including Ping and tracert, system debugging, NQA, SNMP, RMON, NETCONF, SQA, UCC, Packet capture, Email Notification Service, process monitoring and maintenance, and Mirroring.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
