- 13-User Access and Authentication Configuration Guide
- 01-WLAN access authentication configuration
- 02-WLAN IP snooping configuration
- 03-AAA configuration
- 04-802.1X configuration
- 05-MAC authentication configuration
- 06-Portal configuration
- 07-HTTP redirect configuration
- 08-User identification configuration
02-WLAN IP snooping configuration | 76.17 KB |
Disabling snooping ARP packets
Configuring snooping DHCPv4 packets
Enabling snooping DHCPv6 packets
Enabling snooping HTTP and HTTPS requests redirected to the portal server
Enabling IP address conflict detection
Configuring WLAN IP snooping
About WLAN IP snooping
WLAN IP snooping enables an AP to learn clients' IP addresses through snooping ARP, DHCP, and HTTP/HTTPS packets and generate snooping entries that record client IP address, MAC address, and learning method. The entries will be used by AAA for 802.1X and MAC authentication client accounting to determine whether to forward client packets.
NOTE: In an AP+AC network, APs report snooping entries to the AC. |
Client IPv4 address learning
An AP learns client IPv4 addresses by using the following methods:
· Snooping ARP packets sent by clients.
For more information about ARP, see Network Connectivity Configuration Guide.
· Snooping DHCPv4 packets exchanged between client and server.
For more information about DHCP, see Network Connectivity Configuration Guide.
· Snooping HTTP/HTTPS requests redirected to the portal server.
For more information about portal authentication, see User Access and Authentication Configuration Guide.
The priorities for learning IP addresses through snooping DHCPv4 packets, ARP packets, and HTTP/HTTPS requests are in descending order.
Client IPv6 address learning
An AP learns client IPv6 addresses by using the following methods:
· Snooping DHCPv6 packets exchanged between client and server.
For more information about DHCPv6, see Layer 3—IP Services Configuration Guide.
· Snooping ND packets, including Router Advertisement (RA) packets, Neighbor Solicitation (NS) packets, and Neighbor Advertisement (NA) packets sent by clients.
For more information about ND, see Layer 3—IP Services Configuration Guide.
The priorities for learning IPv6 addresses through snooping DHCPv6 packets, ND packets, and HTTP/HTTPS requests are in descending order.
By default, an AP learns client IPv4 addresses by snooping ARP and DHCPv4 packets. Perform this task to disable client IPv4 address learning from ARP packets.
1. Enter system view.
2. Create a service template and enter its view.
wlan service-template service-template-name
3. Disable snooping ARP packets.
undo client ipv4-snooping arp-learning enable
By default, snooping ARP packets is enabled.
By default, an AP learns client IPv4 addresses by snooping ARP and DHCPv4 packets. You can perform this task to disable client IPv4 address learning from DHCPv4 packets and set the timeout for IPv4 address learning through DHCP.
With the timeout set, the system logs off clients that fail to obtain an IPv4 address through DHCP within the specified period.
The timeout takes effect only on clients coming online afterwards from the AC.
3. Disable snooping DHCPv4 packets.
undo client ipv4-snooping dhcp-learning enable
By default, snooping DHCPv4 packets is enabled.
4. (Optional.) Enable forced logoff of clients that fail to obtain an IPv4 address through DHCP.
client ipv4-snooping dhcp-learning timeout value
By default, forced logoff of clients that fail to obtain an IPv4 address through DHCP is disabled.
By default, an AP does not learn client IPv6 addresses. Perform this task to enable client IPv6 address learning from DHCPv6 packets.
3. Enable snooping DHCPv6 packets.
client ipv6-snooping dhcpv6-learning enable
By default, snooping DHCPv6 packets is disabled.
Enabling snooping ND packets
By default, an AP does not learn client IPv6 addresses. Perform this task to enable client IPv6 address learning from ND packets.
3. Enable snooping ND packets.
client ipv6-snooping nd-learning enable
By default, snooping ND packets is disabled.
Before a client passes portal authentication, all of its HTTP and HTTPS requests are redirected to the portal server. Perform this task to enable snooping of redirected HTTP and HTTPS requests for the AC to learn client IPv4 addresses.
This feature can only be used to learn IP addresses of portal-authenticated clients.
3. Enable snooping HTTP and HTTPS requests redirected to the portal server.
client ip-snooping http-learning enable
By default, snooping HTTP and HTTPS requests is disabled.
This feature enables the system to detect IP address conflicts between a client attempting to come online and online clients. The system logs off the online clients that use the same IP address as the new client and creates IP address conflict entries for the clients. The system deletes the IP address conflict entry for a client when the client cache expires or the client's IP address changes.
In an AC hierarchy network, you can disable IP address conflict detection on the central AC if portal authentication has been disabled or accounting has been disabled for 802.1X or MAC authentication clients. This allows clients from different local ACs to come online with the same IP address, simplifying DHCP configuration.
2. Enable IP address conflict detection.
wlan client ip-conflict-detection enable
By default, IP address conflict detection is enabled.
