- 20-Network Management and Monitoring Command Reference
- 01-Ping and tracert commands
- 02-System debugging commands
- 03-NQA commands
- 04-SNMP commands
- 05-RMON commands
- 06-NETCONF commands
- 07-Process monitoring and maintenance commands
- 08-Mirroring commands
- 09-Email Notification Service Commands
- 10-UCC commands
- 11-SQA commands
- 12-Packet capture commands
| 11-SQA commands | 98.14 KB |
SQA commands
application enable
Use application enable to enable SQA for an audio or video application.
Use undo application enable to disable SQA for an audio or video application.
application app-name enable
undo application app-name enable
SQA is disabled for all audio and video applications.
SQA profile view
app-name: Specifies an audio or video application.
After SQA is enabled, the service template bound to the SQA profile will analyze the audio and video traffic of wireless endpoints. The service template also collects and saves basic information (such as source and destination IP addresses) and quality information (such as delay and jitter) about the audio and video streams. The device can report the analysis data to a control terminal through NETCONF.
To enable SQA for multiple audio or video applications, you can execute this command multiple times.
# In SQA profile ssidcompany, enable SQA for the Tencent Meeting application.
[Sysname] sqa profile ssidcompany
[Sysname-sqa-profile-ssidcompany] application tencentmeeting enable
sqa profile
application interval
Use application interval to specify the interval at which analysis data for audio and video applications is collected and sent.
Use undo application interval to restore the default.
application interval interval
Analysis data for audio and video applications is collected and sent at 300-second intervals.
SQA profile view
interval: Specifies the interval at which analysis data for audio and video applications is collected and sent, in the range of 10 to 3600 seconds.
After SQA is enabled, APs will collect and send analysis data to the control terminal that subscribes to the data at the specified.
# In SQA profile ssidcompany, specify the interval for collecting and sending analysis data as 200 seconds.
[Sysname-sqa-profile-ssidcompany] application interval 200
application enable
sqa profile
application statistics enable
Use application statistics enable to enable statistics collection for endpoint application traffic.
Use undo application statistics enable to disable statistics collection for endpoint application traffic.
Statistics collection for endpoint application traffic is disabled.
SQA profile view
After this command is executed, the service template bound to the SQA profile will collect traffic statistics on identifiable applications for wireless endpoints. The device can report the statistics to a control terminal through NETCONF. For information about NETCONF, see Network Management and Monitoring Configuration Guide.
# In SQA profile ssidcompany, enable statistics collection for endpoint application traffic.
[Sysname-sqa-profile-ssidcompany] application statistics enable
sqa profile
application statistics interval
Use application statistics interval to specify the interval at which traffic statistics are collected and sent.
Use undo application statistics interval to restore the default.
application statistics interval interval
Traffic statistics for endpoint applications is collected and sent at 5-minute intervals.
SQA profile view
interval: Specifies the interval at which analysis data for traffic statistics for endpoint applications are collected and sent, in the range of 1 to 60 minutes.
After traffic statistics for endpoint applications is enabled, APs will collect and send traffic statistics to the control terminal that subscribes to the data at the specified.
# In SQA profile ssidcompany, specify the interval for collecting and sending traffic statistics as 4 minutes.
[Sysname-sqa-profile-ssidcompany] application statistics interval 4
sqa profile
display sqa profile
Use display sqa profile to display configuration information for SQA profiles.
display sqa profile [ profile-name ]
profile-name: Specifies an SQA profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify an SQA profile, this command displays configuration information for all SQA profiles.
# Display configuration information for all SQA profiles.
<Sysname> display sqa profile
SQA profile information:
SQA profile name: ssidcompany1
SIP: Enabled
SQA-enabled applications: tencentmeeting
Application statistics: Enabled
Application SQA interval: 300s
Application statistics interval: 5min
SQA profile name: ssidcompany2
SIP: Enabled
Total SQA profiles: 2
SIP |
Status of SIP-based SQA for the SQA profile: · Enabled. · Disabled. |
application enable
sip enable
display sqa sip call
Use display sqa sip call to display SIP call information.
display sqa sip call [ [ call-id call-id ] verbose ]
call-id call-id: Specifies a SIP call by its call ID, a case-insensitive string of 1 to 64 characters. If you do not specify a SIP call, this command displays information for all SIP calls.
verbose: Displays detailed information about a SIP call.
If you do not specify any parameters, this command displays brief information about all SIP calls.
# Display brief information about all SIP calls.
<Sysname> display sqa sip call
Caller Callee Call ID
192.168.111.222:65000 192.168.111.223:5000 asdlkfjakdjfkl
192.121.111.252:65012 192.171.251.223:5000 adfdfdffjakdjfkl
Caller |
IP address and port number of the calling party. |
Callee |
IP address and port number of the called party. |
Call ID |
ID of a SIP call, which uniquely identifies the call. |
# Display detailed information about a SIP call.
<Sysname> display sqa sip call call-id asdlkfjakdjfkl verbose
Call ID: asdlkfjakdjfkl
Caller information:
IP: 192.168.111.222 Port: 65000 MAC: 0011-2233-CD55
Tag: [email protected]
Callee information:
IP: 192.168.111.123 Port: 65000 MAC: 0111-2AB3-4456
Type: Audio VLAN: 1024 StartTime: 2019-10-12 14:21:36
MOS(F): 3 MOS(R): 3
Forward flow (octets): 123564 Forward flow (packets): 456215
Reverse flow (octets): 25642354 Reverse flow (packets): 2451235
Call ID |
ID of the call, which uniquely identifies the call. |
IP |
IP address of the calling party or called party. |
Port |
Port number of the calling party or called party. |
MAC |
MAC address of the calling party or called party. |
Tag |
Tag of the calling party or called party. The tag is a URL in the format of x@y, where x represents the username or phone number and y represents the domain name or address of the proxy server. |
Type |
Media type: · Audio. · Video. |
VLAN |
ID of the VLAN to which the SIP call belongs. This field displays a hyphen (-) if data of the the caller uses a wired client. |
StartTime |
Time when the SIP call was established. |
MOS(F) |
This field is not supported in the current software version. Mean Opinion Score (MOS) value for the originating voice traffic (traffic from the calling party to the called party), in the range of 0 to 5. The higher the value, the better the service. This field displays a hyphen (-) if the system fails to obtain the value. |
MOS(R) |
This field is not supported in the current software version. MOS value for the returning voice traffic (traffic from the called party to the calling party), in the range of 0 to 5. The higher the value, the better the service. This field displays a hyphen (-) if the system fails to obtain the value. |
Forward flow (octets) |
This field is not supported in the current software version. Statistics of the originating voice traffic, in bytes. |
Forward flow (packets) |
This field is not supported in the current software version. Statistics of the originating voice traffic, in packets. |
Reverse flow (octets) |
This field is not supported in the current software version. Statistics of the returning voice traffic, in bytes. |
Reverse flow (packets) |
This field is not supported in the current software version. Statistics of the returning voice traffic, in packets. |
sqa enable
sqa-profile
sqa profile
display sqa sip call-statistics
Use display sqa sip call-statistics to display SIP call statistics.
# Display SIP call statistics.
<Sysname> display sqa sip call-statistics
Total calls : 21
Successful calls : 15 (Active: 10)
Timeout calls : -
Abnormal calls : 3
Total calls |
Total number of calls that have been placed. |
Successful calls |
Total number of calls that have been established successfully. |
Active |
Total number of ongoing calls. |
Timeout calls |
This field is not supported in the current software version. Total number of timeout calls. |
Abnormal calls |
Total number of abnormal calls. |
sip enable
sip enable
Use sip enable to enable SIP-based SQA.
Use undo sip enable to disable SIP-based SQA.
sip enable
undo sip enable
SIP-based SQA is disabled.
SQA profile view
With this command configured, the service template bound to an SQA profile can preferentially forward audio and video traffic to provide high-quality audio and video services. It also enables the device to analyze, collect, and save traffic and session information.
SQA does not support analysis of encrypted SIP protocol packets or fragments.
For SIP-based SQA to take effect on a service template bound to a radio, do not enable fast forwarding of AP-to-client data frames for the radio (see WLAN optimization in WLAN Advanced Features Configuration Guide).
# Enable SIP-based SQA for SQA profile ssidcompany.
[Sysname-sqa-profile-ssidcompany] sip enable
sqa profile
sip profile
Use sip profile to create an SQA profile and enter its view, or enter the view of an existing SQA profile.
Use undo sqa profile to delete an SQA profile.
sqa profile profile-name
undo sqa profile profile-name
No SQA profiles exist.
profile-name: Specifies the name of an SQA profile, a case-insensitive string of 1 to 31 characters. The SQA profile name can contain digits, letters, hyphens (-), underscores (_), left brackets ([), right brackets (]), and slashes (/).
# Create SQA profile ssidcompany and enter its view.
display sqa profile
sqa-profile
sqa-profile
Use sqa-profile to bind an SQA profile to a service template.
Use undo sqa-profile to unbind an SQA profile from a service template.
sqa-profile profile-name
undo sqa-profile
No SQA profile is bound to a service template.
Service template view
Use this command to enable a service template to optimize and analyze audio and video traffic for wireless clients associated with the service template.
You can bind only one SQA profile to a service template. To bind a different SQA template to the service template, first unbind the existing SQA profile from the service template.
# Bind SQA profile ssidcompany to service template service.
[Sysname-sqa-profile-ssidcompany] quit
[Sysname] wlan service-template service
[Sysname-wlan-st-service] sqa-profile ssidcompany
sip enable
sqa profile
