20-Network Management and Monitoring Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1210P01)-6W10120-Network Management and Monitoring Command Reference
10-UCC commands
10-UCC commands 58.03 KB
UCC commands
application enable
Support for this command depends on the device model.
Use application enable to enable UCC for an audio or video application.
Use undo application enable to disable UCC for an audio or video application.
application app-name enable
undo application app-name enable
UCC is disabled for audio and video applications.
UCC profile view
app-name: Specifies an application name.
With UCC enabled for an audio or video application, the wireless service bound to the UCC profile will preferentially forward traffic from that application for wireless users that use the application to obtain higher-quality services.
# Enable UCC for FeiShu applications.
[Sysname] ucc profile ssidcompany
[Sysname-ucc-profile-ssidcompany] application feishu enable
ucc profile
application flow-mark
Use application flow-mark to configure priority marking for traffic from an audio or video application.
Use undo application flow-mark to restore the default.
application app-name flow-mark
undo application app-name flow-mark
Priority marking is not configured for traffic from audio and video applications.
UCC profile view
Priority marking marks the priority of uplink traffic for an audio or video application and sends the priority to other service modules for them to process the traffic as configured.
# Configure priority marking for Tencent Meeting traffic.
[Sysname-ucc-profile-ssidcompany] application tencentmeeting flow-mark
ucc profile
display ucc profile
Use display ucc profile to display configuration information for UCC profiles.
display ucc profile [ profile-name ]
profile-name: Specifies a UCC profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a UCC profile, this command displays configuration information for all UCC profiles.
# Display configuration information for all UCC profiles.
<Sysname> display ucc profile
  UCC profile name: ssidcompany1
    Application enable: tencentmeeting
                              qq
    Application flow-mark enable: tencentmeeting
                                          qq
Total UCC profiles: 1
Application enable
Audio or video applications enabled with UCC.
Audio or video applications of which the traffic is enabled with priority marking.
application enable
ucc profile
Use ucc profile to create a UCC profile and enter its view, or enter the view of an existing UCC profile.
Use undo ucc profile to delete a UCC profile.
ucc profile profile-name
undo ucc profile profile-name
No UCC profiles exist.
profile-name: Specifies the name of a UCC profile, a case-insensitive string of 1 to 31 characters. The UCC profile name can contain hyphens (-), underscores (_), left brackets ([), right brackets (]), and slashes (/).
# Create UCC profile ssidcompany and enter its view.
display ucc profile
ucc-profile
ucc-profile
Use ucc-profile to bind a UCC profile to a service template.
Use undo ucc-profile to unbind a UCC profile from a service template.
ucc-profile profile-name
undo ucc-profile
No UCC profile is bound to a service template.
Service template view
Use this command to enable a service template to optimize and analyze audio and video traffic for wireless clients associated with the service template.
You can bind only one UCC profile to a service template. To bind a different UCC profile to the service template, first unbind the existing UCC profile from the service template.
# Bind UCC profile ssidcompany to service template service.
[Sysname-ucc-profile-ssidcompany] quit
[Sysname] wlan service-template service
[Sysname-wlan-st-service] ucc-profile ssidcompany
application enable
ucc profile
