05-Network Connectivity Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1210P01)-6W10105-Network Connectivity Command Reference
21-IP performance optimization commands
21-IP performance optimization commands 269.81 KB
display icmp statistics
Use display icmp statistics to display ICMP statistics.
ICMP statistics include information about received and sent ICMP packets.
# Display ICMP statistics.
<Sysname> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          175                 destination unreachable 0
         source quench 0                   redirects               0
         echo replies  201                 parameter problem       0
         timestamp     0                   information requests    0
         mask requests 0                   mask replies            0
         time exceeded 0                   invalid type            0
         router advert 0                   router solicit          0
         broadcast/multicast echo requests ignored            0
         broadcast/multicast timestamp requests ignored       0
 Output: echo          0                   destination unreachable 0
         echo replies  175                 parameter problem       0
         timestamp     0                   information replies     0
         time exceeded 0                   bad address             0
         packet error  1442                router advert           3
bad formats
Number of received messages with error format.
bad checksum
Number of received messages with checksum errors.
echo
Number of received or sent ICMP echo request messages.
Number of received or sent destination unreachable messages.
source quench
Number of received or sent source quench messages.
redirects
Number of received or sent redirect messages.
echo replies
Number of received or sent echo reply messages.
parameter problem
Number of received or sent parameter problem messages.
timestamp
Number of received timestamp request messages or number of sent timestamp reply messages.
Number of received information request messages.
mask requests
Number of received or sent mask request messages.
mask replies
Number of received or sent mask reply messages.
invalid type
Number of received messages with invalid type.
router solicit
Number of received RS messages.
Number of dropped incoming broadcast or multicast echo request messages.
Number of dropped incoming broadcast or multicast timestamp request messages.
information replies
Number of sent information reply messages.
time exceeded
Number of received or send ICMP time exceeded messages
bad address
Number of sent messages with invalid destination addresses.
packet error
Number of sent error messages.
router advert
Number of received or sent RA messages.
display ip statistics
Use display ip statistics to display IP packet statistics.
This command displays IP statistics that includes information about received and sent packets, fragments, and reassembly.
# Display IP packet statistics (Standard forwarding mode).
<Sysname> display ip statistics
  Input:           sum            7120          local             112
                   bad protocol   0             bad format        0
                   bad checksum   0             bad options       0
  Output:          forwarding     0             local             27
                   dropped        0             no route          2
                   compress fails 0
  Reassembling:    fragments      0             reassembled       0
                   dropped        0             timeouts          0
  Fragment:        fragmented     0             couldn't fragment 0
                   output frags   0
  Forwarded Frags: sum            0
Input
Statistics about received packets:
·     sum—Total number of packets received.
·     local—Total number of packets destined for the device.
·     bad protocol—Total number of unknown protocol packets.
·     bad format—Total number of packets with incorrect format.
·     bad checksum—Total number of packets with incorrect checksum.
·     bad options—Total number of packets with incorrect option.
Output
Statistics about sent packets:
·     forwarding—Total number of packets forwarded.
·     local—Total number of packets locally sent.
·     dropped—Total number of packets discarded.
·     no route—Total number of packets for which no route is available.
·     compress fails—Total number of packets that failed to be compressed.
Reassembling
Statistics about reassembling:
·     fragments—Total number of fragments that need reassembling.
·     reassembled—Total number of packets reassembled.
·     dropped—Total number of dropped fragments that failed the reassembling.
·     timeouts—Total number of reassembly timeouts.
Fragment
Statistics about fragments:
·     fragmented—Total number of packets successfully fragmented.
·     couldn't fragment—Total number of packets that failed to be fragmented.
·     output frags—Total number of fragments sent.
·     small packet—Total number of packets whose fragments are too short.
Forwarded Frags
Statistics about forwarded fragments. The sum field displays the total number of fragments that are directly forwarded.
display ip interface (Network Connectivity Command Reference)
reset ip statistics
display rawip
Use display rawip to display brief information about RawIP connections.
display rawip
Brief RawIP connection information includes local and peer addresses, protocol, and PCB.
# Display brief information about RawIP connections.
<Sysname> display rawip
 #: Kernel RawIP connection
 Local Addr       Foreign Addr     Protocol  PCB
 0.0.0.0          0.0.0.0          1         0x0000000000000009
 0.0.0.0          0.0.0.0          1         0x0000000000000008
 0.0.0.0          0.0.0.0          1         0x0000000000000002
#0.0.0.0          0.0.0.0          1         N/A
The pound sign (#) indicates a Comware kernel connection.
Local Addr
Local IP address.
Foreign Addr
Peer IP address.
Protocol
Protocol number.
PCB
Protocol control block.
display rawip verbose
Use display rawip verbose to display detailed information about RawIP connections.
display rawip verbose [ pcb pcb-index ]
The detailed information includes socket creator, state, option, type, protocol number, and the source and destination IP addresses of RawIP connections.
# Display detailed information about RawIP connections.
<Sysname> display rawip verbose
Total RawIP socket number: 1
 Connection info: src = 0.0.0.0, dst = 0.0.0.0
 Creator: ping[320]
 State: N/A
 Options: N/A
 Error: 0
 Type: 3
 Protocol: 1
 Inpcb flags: N/A
 Inpcb extflag: INP_EXTRCVICMPERR INP_EXTFILTER
 Inpcb vflag: INP_IPV4
 TTL: 255(minimum TTL: 0)
 Sending VRF: 0x0
 Receiving VRF: 0x0
Total number of RawIP sockets.
Connection info
Connection information, including source IP address and destination IP address.
Creator
Name of the operation that created the socket. The number in brackets is the process number of the creator.
Socket state:
·     NOFDREF—The user has closed the connection.
·     ISCONNECTED—The connection has been established.
·     ISCONNECTING—The connection is being established.
·     ISDISCONNECTING—The connection is being interrupted.
·     ISDISCONNECTED—The connection has been terminated.
·     ISPCBSYNCING—Internet protocol control blocks are being synchronized.
·     ISSMOOTHING—Synchronization is in progress.
·     N/A—None of above state.
Options
Socket options:
·     SO_DEBUG—Records socket debugging information.
·     SO_ACCEPTCONN—Enables the server to listen connection requests.
·     SO_REUSEADDR—Allows the local address reuse.
·     SO_KEEPALIVE—Requires the protocol to test whether the connection is still alive.
·     SO_DONTROUTE—Bypasses the routing table query for outgoing packets because the destination is in a directly connected network.
·     SO_BROADCAST—Supports broadcast packets.
·     SO_LINGER—Closes the socket. The system can still send remaining data in the socket send buffer.
·     SO_OOBINLINE—Stores the out-of-band data in the input queue.
·     SO_REUSEPORT—Allows the local port reuse.
·     SO_TIMESTAMP—Records the timestamps of the input packets, accurate to milliseconds. This option is applicable to protocols that are not connection orientated.
·     SO_FILTER—Supports setting the packet filter criterion. This option takes effect on received packets.
·     SO_TIMESTAMPNS—Has a similar function with the timestamp, accurate to nanoseconds.
·     N/A—No options are set.
Error
Error code.
Receiving buffer (cc/hiwat/lowat/drop/state)
Displays receive buffer information in the following order:
·     cc—Used space.
·     hiwat—Maximum space.
·     lowat—Minimum space.
·     drop—Number of dropped packets.
·     state—Buffer state:
¡     CANTSENDMORE—Unable to send data to the peer.
¡     CANTRCVMORE—Unable to receive data from the peer.
¡     N/A—None of the above states.
Sending buffer (cc/hiwat/lowat/state)
Displays send buffer information in the following order:
·     cc—Used space.
¡     CANTRCVMORE—Unable to receive data from the peer..
Socket type:
·     1SOCK_STREAM. This socket uses TCP to provide reliable transmission of byte streams.
·     2SOCK_DGRAM. This socket uses UDP to provide datagram transmission.
·     3SOCK_RAW. This socket allows an application to change the next upper-layer protocol header.
·     N/A—None of the above types.
Protocol
Number of the protocol using the socket.
Inpcb flags
Flags in the Internet PCB:
·     INP_RECVOPTS—Receives IP options.
·     INP_RECVRETOPTS—Receives replied IP options.
·     INP_RECVDSTADDR—Receives destination IP address.
·     INP_HDRINCL—Provides the entire IP header.
·     INP_REUSEADDR—Reuses the IP address.
·     INP_REUSEPORT—Reuses the port number.
·     INP_ANONPORT—Port number not specified.
·     INP_RECVIF—Records the input interface of the packet.
·     INP_RECVTTL—Receives TTL of the packet. Only UDP and RawIP support this flag.
·     INP_DONTFRAG—Sets the Don't Fragment flag.
·     INP_ROUTER_ALERT—Receives packets with the router alert option. Only RawIP supports this flag.
·     INP_PROTOCOL_PACKET—Identifies a protocol packet.
·     INP_RCVVLANID—Receives the VLAN ID of the packet. Only UDP and RawIP support this flag.
·     INP_RCVMACADDR—Receives the MAC address of the frame.
·     INP_RECVTOS—Receives TOS of the packet. Only UDP and RawIP support this flag.
·     INP_USEICMPSRC—Uses the specified IP address as the source IP address for outgoing ICMP packets.
·     N/A—None of the above flags.
Inpcb extflag
Extension flags in the Internet PCB:
·     INP_EXTRCVPVCIDX—Records the PVC index of the received packet.
·     INP_RCVPWID—Records the PW ID of the received packet.
·     INP_EXTRCVICMPERR—Receives an ICMP error packet.
·     INP_EXTFILTER—Filters the contents in the received packet.
Inpcb vflag
IP version flags in the Internet PCB:
·     INP_IPV4—IPv4 protocol.
·     N/A—Not the above flag.
TTL
TTL value in the Internet PCB.
Sending VRF
VRF from which packets are sent.
Receiving VRF
VRF from which packets are received.
display tcp
Use display tcp to display brief information about TCP connections.
display tcp
Brief TCP connection information includes local IP address, local port number, peer IP address, peer port number, and TCP connection state.
# Display brief information about TCP connections.
<Sysname> display tcp
 *: TCP connection with authentication
 #: Kernel TCP connection
 Local Addr:port       Foreign Addr:port     State       PCB
*0.0.0.0:21            0.0.0.0:0             LISTEN      0x000000000000c387
#1.0.0.1:179           1.0.0.2:29376         ESTABLISHED N/A
 192.168.20.200:23     192.168.20.14:1284    ESTABLISHED 0x0000000000000009
 192.168.20.200:23     192.168.20.14:1283    ESTABLISHED 0x0000000000000002
Table 5 Command output
Indicates that the TCP connection uses authentication.
Local Addr:port
Local IP address and port number.
Foreign Addr:port
Peer IP address and port number.
TCP connection state:
·     CLOSED—The server receives a disconnection request's reply from the client.
·     LISTEN—The server is waiting for connection requests.
·     SYN_SENT—The client is waiting for the server to reply to the connection request.
·     SYN_RCVD—The server receives a connection request.
·     ESTABLISHED—The server and client have established connections and can transmit data bidirectionally.
·     CLOSE_WAIT—The server receives a disconnection request from the client.
·     FIN_WAIT_1—The client is waiting for the server to reply to a disconnection request.
·     CLOSING—The server and client are waiting for peer's disconnection reply when receiving disconnection requests from each other.
·     LAST_ACK—The server is waiting for the client to reply to a disconnection request.
·     FIN_WAIT_2—The client receives a disconnection reply from the server.
·     TIME_WAIT—The client receives a disconnection request from the server.
PCB
PCB index.
display tcp verbose
Use display tcp verbose to display detailed information about TCP connections.
display tcp verbose [ pcb pcb-index ]
The detailed TCP connection information includes socket creator, state, option, type, protocol number, source IP address and port number, destination IP address and port number, and connection state.
# Display detailed information about TCP connections.
<Sysname> display tcp verbose
 Connection info: src = 192.168.20.200:179, dst = 192.168.20.14:4181
 Creator: bgpd[199]
 State: ISCONNECTED
 Options: N/A
 Error: 0
 Receiving buffer(cc/hiwat/lowat/drop/state): 0 / 65700 / 1 / 0 / N/A
 Sending buffer(cc/hiwat/lowat/state): 0 / 65700 / 512 / N/A
 Type: 1
 Protocol: 6
 NAT kernel port: 0
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Connection state: ESTABLISHED
 NSR state: READY(M)
 Sending VRF: 0x0
 Receiving VRF: 0x0
Table 6 Command output
TCP inpcb number
Number of TCP IP PCBs.
tcpcb number
Number of TCP PCBs. This field is not displayed if the connection is in TIME_WAIT state.
Connection info
Connection information, including source IP address, source port number, destination IP address and destination port number.
Creator
Socket state:
Options
Socket options:
·     SO_KEEPALIVETIME—Sets a keepalive time.
Error
Error code.
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
NAT kernel port
TCP port for NAT in the kernel mode. If NAT is not enabled, the value of this field is 0.
Inpcb flags
Inpcb extflag
·     INP_EXTDONTDROP—Does not drop the received packet.
Inpcb vflag
TTL
Connection state
TCP options
TCP options:
·     TF_SIGNATURE—Enables MD5 signature.
·     TF_NODELAY—Disables the Nagle algorithm that buffers the sent data inside the TCP.
·     TF_BINDFOREIGNADDR—Binds the peer IP address.
·     TF_NSR—Enables TCP NSR.
·     TF_REQ_SCALE—Enables the TCP window scale option.
·     TF_REQ_TSTMP—Enables the time stamp option.
·     TF_SACK_PERMIT—Enables the TCP selective acknowledgement option.
·     TF_ENHANCED_AUTH—Enables the enhanced authentication option.
·     TF_PMTU—Enables path MTU discovery.
NSR state
NSR state of the TCP connection:
·     CLOSED—Closed (initial) state.
·     CLOSING—The connection is to be closed.
·     ENABLED—The connection backup is enabled.
·     OPEN—The connection synchronization has started.
·     PENDING—The connection backup is not ready.
·     READY—The connection backup is ready.
·     SMOOTH—The connection data is being smoothed.
Between the parentheses is the role of the connection:
·     M—Main connection.
·     S—Standby connection.
Sending VRF
Receiving VRF
display udp
Use display udp to display brief information about UDP connections.
display udp
Brief UDP connection information includes local IP address and port number, and peer IP address and port number.
# Display brief information about UDP connections.
<Sysname> display udp
 #: Kernel UDP connection
 Local Addr:port        Foreign Addr:port      PCB
 0.0.0.0:69             0.0.0.0:0              0x0000000000000003
#1.0.0.1:179            0.0.0.0:0              N/A
 192.168.20.200:1024    192.168.20.14:69       0x0000000000000002
Table 7 Command output
Local Addr:port
Foreign Addr:port
PCB
PCB index.
display udp socket-loadbalance
Use display udp socket-loadbalance to display brief information about UDP socket load balancing.
Service modules might create multiple UDP sockets on a service port and balance loads among the sockets to improve packet processing performance. In this case, the system distributes packets received on the same port with the same local IP address to multiple UDP sockets.
# Display brief information about UDP socket load balancing.
<Sysname> display udp socket-loadbalance
LocalAddr:port       VrfIndex      LBCount
192.168.5.1:4568     0             10
10::1:457            0             10
Table 8 Command output
LocalAddr:port
VrfIndex
VPN instance index.
LBCount
Number of UDP sockets.
Slot
Slot number of the card.
display udp socket-loadbalance verbose
Use display udp socket-loadbalance verbose to display detailed information about UDP socket load balancing.
display udp socket-loadbalance verbose [ port port-number ]
port port-number: Specifies a port by its number. The value range for the port-number argument is 1025 to 65535. If you do not specify a port, this command displays detailed information about UDP socket load balancing for all ports that have multiple UDP sockets.
# Display detailed information about UDP socket load balancing for all ports.
<Sysname> display udp socket-loadbalance verbose
LocalAddr:port: 192.168.5.1:4568
VrfIndex: 0
LBCount: 10
LBConnectionlist:
NO Cc         Drops      Failures      RvdPkts   PCB
1  4294967296 4294967296 4294967296 4294967296   000000000000000C
2  9600       429        429        111111111    000000000000000D
3  960        4          4          11111111     000000000000000E
4  42         42         42         1111         000000000000000F
5  4          4          4          111          0000000000000010
6  4294       42949      42949      1111111      0000000000000011
7  429496     429496     429496     1111111      0000000000000012
8  429        42         42         1111         0000000000000013
9  429        429        429        11911        0000000000000014
10 42949      429496     429496     111111111    0000000000000015
# Display detailed information about UDP socket load balancing for a specific port.
<Sysname> display udp socket-loadbalance verbose port 4568
Local Addr:port: 192.168.5.1:4568
VrfIndex: 0
Index: 00000001
LBCount: 10
LBConnectionlist:
Table 9  Command output
LocalAddr:port
VrfIndex
VPN instance index.
Location
Socket location. This field is not available for centralized devices.
LBCount
LBConnectionlist
UDP socket list.
No
Entry sequence number.
Cc
Used receiving buffer space in bytes.
Drops
Number of dropped packets because the receiving buffer is full.
Failures
Number of the packets that failed to be issued to the kernel.
RvdPkts
Number of received packets.
PCB
Protocol control block index.
display udp verbose
display udp statistics
Use display udp statistics to display UDP traffic statistics.
UDP traffic statistics include information about received and sent UDP packets.
# Display UDP traffic statistics.
<Sysname> display udp statistics
Received packets:
     Total: 240
     checksum error: 0, no checksum: 0
     shorter than header: 0, data length larger than packet: 0
     no socket on port(unicast): 0
     no socket on port(broadcast/multicast): 240
     not delivered, input socket full: 0 ;kenerl buff full: 0
Sent packets:
     Total: 0
Table 10 Command output
Received packets:
Information about received packets.
·     Total—Total number of UDP packets.
·     checksum error—Number of packets with checksum error.
·     no checksum—Number of packets with no checksum.
·     shorter than header—Number of packets whose packet length is shorter than the header length.
·     data length larger than packet—Number of packets whose data length is longer than the packet length.
·     no socket on port(unicast)—Number of unicasts with no socket on the port.
·     no socket on port(broadcast/multicast)—Number of broadcasts and multicasts with no socket on the port.
·     not delivered, input socket full: xxx ;kenerl buff full: yyy—Number of packets that are not delivered to the upper layer because the socket buffer is full. Number of discarded packets because the kernel buffer is full.
Sent packets
Number of sent packets.
reset udp statistics
display udp verbose
Use display udp verbose to display detailed information about UDP connections.
display udp verbose [ pcb pcb-index ]
The detailed information includes socket creator, status, option, type, protocol number, source IP address and port number, and destination IP address and port number for UDP connections.
# Display detailed UDP connection information.
<Sysname> display udp verbose
Total UDP socket number: 1
 Connection info: src = 0.0.0.0:69, dst = 0.0.0.0:0
 Creator: sock_test_mips[250]
 State: N/A
 Options: N/A
 Error: 0
 Receiving buffer(cc/hiwat/lowat/drop/full/state): 0 / 41600 / 1 / 0 / 0 / N/A
 Type: 2
 Protocol: 17
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Sending VRF: 0
 Receiving VRF: 0xffff
Table 11 Command output
Total number of UDP sockets.
Connection info
Connection information, including source IP address, source port number, destination IP address, and destination port number.
Creator
Socket state:
Options
Socket options:
Error
Error code.
·     cc—Used space.
·     full—Number of dropped packets because the kernel sending buffer is full.
·     cc—Used space.
Socket type:
Protocol
Inpcb flags
Inpcb extflag
Inpcb vflag
TTL
Sending VRF
Receiving VRF
ip forward-broadcast
Use ip forward-broadcast to enable an interface to forward directed broadcast packets destined for the directly connected network.
Use undo ip forward-broadcast to disable an interface from forwarding directed broadcast packets destined for the directly connected network.
An interface cannot forward directed broadcasts destined for the directly connected network.
Interface view
A directed broadcast packet is destined for all hosts on a specific network. In the destination IP address of the directed broadcast, the network ID identifies the target network, and the host ID is made up of all ones.
This command enables an interface to forward directed broadcasts destined for the directly connected network.
# Enable VLAN-interface 2 to forward directed broadcast packets destined for the directly connected network.
[Sysname-Vlan-interface2] ip forward-broadcast
ip icmp error-interval
Use ip icmp error-interval to set the interval for tokens to arrive in the bucket and the bucket size for ICMP error messages.
Use undo ip icmp error-interval to restore the default.
A token is placed in the bucket every 100 milliseconds, and the bucket allows a maximum of 10 tokens.
interval: Specifies the interval for tokens to arrive in the bucket. The value range is 0 to 2147483647 milliseconds. To disable the ICMP rate limit, set the value to 0.
bucketsize: Specifies the maximum number of tokens allowed in the bucket. The value range is 1 to 200.
This command limits the rate at which ICMP error messages are sent. Use this command to avoid sending excessive ICMP error messages within a short period that might cause network congestion. A token bucket algorithm is used with one token representing one ICMP error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMP error message is sent. When the bucket is empty, ICMP error messages are not sent until a new token is placed in the bucket.
# Set the interval to 200 milliseconds for tokens to arrive in the bucket and the bucket size to 40 tokens for ICMP error messages.
[Sysname] ip icmp error-interval 200 40
ip icmp source
Use ip icmp source to specify the source address for outgoing ICMP packets.
Use undo ip icmp source to remove the specified source address for outgoing ICMP packets.
ip icmp source ip-address
undo ip icmp source
No source address is specified for outgoing ICMP packets. The default source IP addresses for different types of ICMP packets vary as follows:
·     For an ICMP error message, the source IP address is the IP address of the receiving interface of the packet that triggers the ICMP error message. ICMP error messages include Time Exceeded, Port Unreachable, and Parameter Problem messages.
·     For an ICMP echo request, the source IP address is the IP address of the sending interface.
·     For an ICMP echo reply, the source IP address is the destination IP address of the ICMP echo request specific to this reply.
ip-address: Specifies an IP address.
It is a good practice to specify the IP address of the loopback interface as the source IP address for outgoing ping echo request and ICMP error messages. This feature helps users locate the sending device easily.
# Specify 1.1.1.1 as the source address for outgoing ICMP packets.
[Sysname] ip icmp source 1.1.1.1
ip mtu
Use ip mtu to set the MTU of IPv4 packets sent over an interface.
Use undo ip mtu to restore the default.
ip mtu mtu-size
undo ip mtu
The MTU of IPv4 packets sent over an interface is not set.
Interface view
mtu-size: Specifies the MTU in bytes. The value range for the mtu-size argument is 128 to 1748.
When a packet exceeds the MTU of IPv4 packets sent over an interface, the device processes the packet in one of the following ways:
·     If the packet disallows fragmentation, the device discards it.
·     If the packet allows fragmentation, the device fragments it and forwards the fragments.
Fragmentation and reassembling consume system resources, so set an appropriate MTU to avoid fragmentation.
If an interface supports both the mtu and ip mtu commands, the device fragments a packet based on the MTU set by the ip mtu command.
# Set the MTU of VLAN-interface 100 to 1280 bytes.
[Sysname-Vlan-interface100] ip mtu 1280
ip redirects enable
Use ip redirects enable to enable sending ICMP redirect messages.
Use undo ip redirects enable to disable sending ICMP redirect messages.
ip redirects enable
Sending ICMP redirect messages is disabled.
ICMP redirect messages simplify host management and enable hosts to gradually optimize their routing tables.
A host that has only one route destined for the default gateway sends all packets to the default gateway. The default gateway sends an ICMP redirect message to inform the host of a correct next hop by following these rules:
·     The receiving and sending interfaces are the same.
·     The packet source IP address and the IP address of the packet receiving interface are on the same segment.
·     There is no source route option in the received packet.
# Enable sending ICMP redirect messages.
[Sysname] ip redirects enable
ip ttl-expires enable
Use ip ttl-expires enable to enable sending ICMP time exceeded messages.
Use undo ip ttl-expires enable to disable sending ICMP time exceeded messages.
Sending ICMP time exceeded messages is disabled.
A device sends ICMP time exceeded messages by following these rules:
·     The device sends an ICMP TTL exceeded in transit message to the source when the following conditions are met:
¡     The received packet is not destined for the device.
¡     The TTL field of the packet is 1.
·     When the device receives the first fragment of an IP datagram destined for the device itself, it starts a timer. If the timer expires before all the fragments of the datagram are received, the device sends an ICMP fragment reassembly time exceeded message to the source.
A device disabled from sending ICMP time exceeded messages does not send ICMP TTL exceeded in transit messages but can still send ICMP fragment reassembly time exceeded messages.
# Enable sending ICMP time exceeded messages.
[Sysname] ip ttl-expires enable
ip unreachables enable
Use ip unreachables enable to enable sending ICMP destination unreachable messages.
Use undo ip unreachables enable to disable sending ICMP destination unreachable messages.
Sending ICMP destination unreachable messages is disabled.
A device sends ICMP destination unreachable messages by following these rules:
·     The device sends the source an ICMP network unreachable message when the following conditions are met:
¡     The received packet does not match any route.
¡     No default route exists in the routing table.
·     The device sends the source an ICMP protocol unreachable message when the following conditions are met:
¡     The received packet is destined for the device.
¡     The transport layer protocol of the packet is not supported by the device.
·     The device sends the source an ICMP port unreachable message when the following conditions are met:
¡     The received UDP packet is destined for the device.
¡     The packet's port number does not match the running process.
·     The device sends the source an ICMP source route failed message when the following conditions are met:
¡     The source uses Strict Source Routing to send packets.
¡     The intermediate device finds that the next hop specified by the source is not directly connected.
·     The device sends the source an ICMP fragmentation needed and DF set message when the following conditions are met:
¡     The MTU of the sending interface is smaller than the packet.
¡     The packet has Don't Fragment set.
# Enable sending ICMP destination unreachable messages.
[Sysname] ip unreachables enable
ip virtual-reassembly aging
Use ip virtual-reassembly aging to set the aging time for cached packet fragments.
Use undo ip virtual-reassembly aging to restore the default.
ip virtual-reassembly aging aging-milliseconds
The aging time for cached packet fragments is 3000 milliseconds.
aging-milliseconds: Set the aging time for cached packet fragments, in milliseconds. The value range for this argument is 100 to 5000.
With virtual fragment reassembly enabled, the device sets an aging timer for each cached fragment. When the timer of a packet fragment expires, the device discards the fragment. You can perform this task to set the aging time as needed.
Fragments of different packets in the cache queue might have the same packet ID, especially when the device has cached a large number of packet fragments. If a fragment is lost, the system might mistakenly use a fragment of a later received packet that has the same packet ID to substitute for the lost one, causing reassembly errors. To resolve this issue, set a short aging time as a best practice to reduce cached fragments if a large number of packets are cached for a service and packet loss occurs.
This command takes effect only when IPv4 virtual fragment reassembly is enabled.
# Set the aging time to 300 milliseconds for cached packet fragments.
[Sysname] ip virtual-reassembly aging 300
ip virtual-reassembly enable
Use ip virtual-reassembly enable to enable IPv4 virtual fragment reassembly.
Use  undo ip virtual-reassembly enable to disable IPv4 virtual fragment reassembly.
IPv4 virtual fragment reassembly is disabled.
To prevent each service module from processing packet fragments that do not arrive in order, you can enable the virtual fragment reassembly feature. This feature virtually reassembles the fragments of a datagram through fragment check, sequencing, and caching, ensuring fragments arrive at each service module in order.
VFR can detect and prevent the following types of attacks:
·     Tiny fragment attack—The first fragment size is too small to hold the Layer 4 (such as TCP and UDP) header field, which is forced into the second fragment. VFR discards all tiny fragments.
·     Overlapping fragment attack—Two consecutive incoming fragments are identical or overlap with each other. If an overlapping fragment is detected, VFR discards all fragments within a fragment chain.
·     Fragment flooding attack—The maximum number of concurrent preassemblies or the number of fragments per datagram exceeds the upper limits. VFR discards subsequent fragments if the upper limit is reached.
The enabling status of VFR can be managed through CLI or controlling the enabling status of a service module that can call VFR. VRF is enabled in either of the following conditions:
·     A service module that can call it is enabled.
·     The ip virtual-reassembly enable command is executed.
If fragment reassembly is required, but a service module cannot call it, execute this command at CLI.
# Enable IPv4 virtual fragment reassembly
[Sysname] ip virtual-reassembly enable
reset ip statistics
Use reset ip statistics to clear IP traffic statistics.
reset ip statistics
Use this command to clear history IP traffic statistics before you collect IP traffic statistics for a time period.
# Clear IP traffic statistics.
<Sysname> reset ip statistics
Use reset udp statistics to clear UDP traffic statistics.
# Clear UDP traffic statistics.
<Sysname> reset udp statistics
tcp mss
Use tcp mss to set the TCP maximum segment size (MSS).
Use undo tcp mss to restore the default.
tcp mss value
undo tcp mss
The TCP MSS is not set.
Interface view
value: Specifies the TCP MSS in bytes. The minimum value is 128 bytes. The maximum value equals the maximum MTU that the interface supports minus 40.
The MSS option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment. If the size of a TCP segment is smaller than the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, TCP fragments the segment according to the receiver's MSS.
If you set the TCP MSS on an interface, the size of each TCP segment received or sent on the interface cannot exceed the MSS value.
This configuration takes effect only on TCP connections that are established after the configuration and not on the TCP connections that already exist.
This configuration is effective only on IP packets.
# Set the TCP MSS to 300 bytes on VLAN-interface 100.
[Sysname-Vlan-interface100] tcp mss 300
tcp path-mtu-discovery
Use tcp path-mtu-discovery to enable TCP path MTU discovery.
Use undo tcp path-mtu-discovery to disable TCP path MTU discovery.
TCP path MTU discovery is disabled.
aging age-time: Specifies the aging time for the path MTU, in the range of 10 to 30 minutes. The default aging time is 10 minutes.
no-aging: Does not age out the path MTU.
After you enable TCP path MTU discovery, all new TCP connections detect the path MTU. The device uses the path MTU to calculate the MSS to avoid IP fragmentation.
After you disable TCP path MTU discovery, the system stops all path MTU timers. The TCP connections established later do not detect the path MTU, but the TCP connections previously established still can detect the path MTU.
# Enable TCP path MTU discovery and set the path MTU aging time to 20 minutes.
[Sysname] tcp path-mtu-discovery aging 20
tcp-proxy congestion-method
Use tcp-proxy congestion-method to specify a TCP congestion control algorithm for TCP proxy.
Use undo tcp-proxy congestion-method to restore the default.
tcp-proxy congestion-method { bbrv1 | bbrv2 | bic | reno }
The TCP congestion control algorithm is Reno for TCP proxy.
bbrv1: Specifies BBRv1 as the TCP congestion control algorithm for TCP proxy.
bbrv2: Specifies BBRv2 as the TCP congestion control algorithm for TCP proxy.
bic: Specifies BIC as the TCP congestion control algorithm for TCP proxy.
reno: Specifies Reno as the TCP congestion control algorithm for TCP proxy.
This command does not take effect on the modules that support TCP congestion control algorithm configuration. The TCP congestion control algorithm used by such a module depends on its configuration.
The modules that do not support TCP congestion control algorithm configuration use the same algorithm as the TCP proxy module.
When you use this command, you can configure one of the following TCP congestion control algorithms:
·     Reno—Use this algorithm in scenarios with low latency and low bandwidth. In scenarios with high latency and high bandwidth, the speed of data transmission takes a long time to reach the maximum and thus the bandwidth utilization rate is low.
Reno is an early TCP congestion control algorithm that increases the number of congestion windows on receipt of ACK messages.
·     BICUse this algorithm in scenarios with high bandwidth and low packet loss rate.
BIC can make good use of remaining bandwidth resources and improve throughput, because this algorithm does not slow down packet sending as long as no packet loss occurs. However, the transmission latency of this algorithm is high. This algorithm will reduce the number of congestion windows when transmission errors cause packet loss.
·     BBR—Use this algorithm in scenarios with high bandwidth, high latency, and packet loss.
BBR does not use packet loss as a congestion signal. In a scenario with high packet loss rate, this algorithm can ensure high throughput and reduce transmission latency effectively. BBRv2 improves intra-protocol fairness by balancing aggressiveness.
# Specify Reno as the TCP congestion control algorithm for TCP proxy.
[Sysname] tcp-proxy congestion-method reno
tcp syn-cookie enable
Use tcp syn-cookie enable to enable SYN Cookie to protect the device from SYN flood attacks.
Use undo tcp syn-cookie enable to disable SYN Cookie.
SYN Cookie is disabled.
A TCP connection is established through a three-way handshake:
1.     The sender sends a SYN packet to the server.
2.     The server receives the SYN packet, establishes a TCP semi-connection in SYN_RECEIVED state, and replies with a SYN ACK packet to the sender.
3.     The sender receives the SYN ACK packet and replies with an ACK packet. Then, a TCP connection is established.
An attacker can exploit this mechanism to mount SYN flood attacks. The attacker sends a large number of SYN packets, but they do not respond to the SYN ACK packets from the server. As a result, the server establishes a large number of TCP semi-connections and cannot handle normal services.
SYN Cookie can protect the server from SYN flood attacks. When the server receives a SYN packet, it responds to the request with a SYN ACK packet without establishing a TCP semi-connection.
The server establishes a TCP connection and enters ESTABLISHED state only when it receives an ACK packet from the sender.
# Enable SYN Cookie.
[Sysname] tcp syn-cookie enable
tcp timer fin-timeout
Use tcp timer fin-timeout to set the TCP FIN wait timer.
Use undo tcp timer fin-timeout to restore the default.
The TCP FIN wait timer is 675 seconds.
time-value: Specifies the TCP FIN wait timer in the range of 76 to 3600 seconds.
TCP starts the FIN wait timer when the state of a TCP connection changes to FIN_WAIT_2. If no FIN packet is received within the timer interval, the TCP connection is terminated.
If a FIN packet is received, TCP changes the connection state to TIME_WAIT. If a non-FIN packet is received, TCP restarts the timer and tears down the connection when the timer expires.
# Set the TCP FIN wait timer to 800 seconds.
[Sysname] tcp timer fin-timeout 800
tcp timer syn-timeout
Use tcp timer syn-timeout to set the TCP SYN wait timer.
Use undo tcp timer syn-timeout to restore the default.
The TCP SYN wait timer is 75 seconds.
time-value: Specifies the TCP SYN wait timer in the range of 2 to 600 seconds.
TCP starts the SYN wait timer after sending a SYN packet. Within the SYN wait timer if no response is received or the upper limit on TCP connection tries is reached, TCP fails to establish the connection.
# Set the TCP SYN wait timer to 80 seconds.
[Sysname] tcp timer syn-timeout 80
tcp window
Use tcp window to set the size of the TCP receive/send buffer.
Use undo tcp window to restore the default.
tcp window window-size
undo tcp window
The size of the TCP receive/send buffer is 63 KB.
window-size: Specifies the size of the TCP receive/send buffer, in the range of 5 to 64 KB.
# Set the size of the TCP receive/send buffer to 6 KB.
[Sysname] tcp window 6
