- 13-WLAN advanced features
- 01-WLAN Probe Configuration Examples
- 02-Multicast Optimization Configuration Examples
- 03-Client Rate Limiting Configuration Examples
- 04-Inter-AC Roaming Configuration Examples
- 05-Inter-AC Roaming (IPv6) Configuration Examples
- 06-Inter-AC Roaming in Local Forwarding Mode Configuration Examples
- 07-Cooperative Roaming for 802.11v Clients Configuration Examples
- 08-WLAN Load Balancing Configuration Examples
- 09-Static Blacklist Configuration Examples
- 10-Client Quantity Control Configuration Examples
- 11-AP License Synchronization Configuration Examples
- 12-BLE Module iBeacon Transmission Configuration Examples
- 13-Medical RFID Tag Management Configuration Examples
- 14-iBeacon Management Configuration Examples
- 15-Mesh Link Establishment Between Fit APs Configuration Examples
- 16-Mesh Link Establishment Between a Fit AP and a Fat AP Configuration Examples
- 17-Auto-DFS and Auto-TPC Configuration Examples
- 18-AP Image Downloading Configuration Examples
- 19-Dual-Uplink Interfaces Configuration Guide
- 20-H3C Comware AC Cloud-Managed AP Centralized Management Configuration Examples
| 15-Mesh Link Establishment Between Fit APs Configuration Examples | 111.42 KB |
H3C Access Controllers |
Mesh Link Establishment Between Fit APs |
Introduction
The following information provides an example of configuring a mesh link between fit APs.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN mesh.
Example: Configuring a mesh link between fit APs
As shown in Figure 1, in centralized forwarding mode, the AC is connected to the switch, and the switch assigns an IP address to APs and clients as a DHCP server. Configure devices to meet the following requirements:
· AP 1 and AP 2 obtain an IP address from the address pool on VLAN 10 configured on the switch and come online from the AC.
· The wired client and wireless client are assigned to the same VLAN and are reachable to each other at Layer 2.
· Use the actual serial ID of an AP to uniquely identify that AP.
· To avoid too many packets in VLAN 1, configure GE1/0/4 that connects the switch to AP 1 as a trunk port, and remove the port from VLAN 1.
· To avoid mesh link errors, do not configure WLAN mesh and auto bandwidth adjustment of WLAN RRM at the same time.
Procedures
Configuring the switch
1. Configure interfaces on the switch:
# Create VLAN 10 and VLAN-interface 10, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<Switch> system-view
[Switch] vlan 10
[Switch-vlan10] quit
[Switch] interface vlan-interface 10
[Switch-Vlan-interface10] ip address 172.16.1.1 255.255.255.0
[Switch-Vlan-interface10] quit
# Create VLAN 20 and VLAN-interface 20, and assign an IP address to the VLAN interface. This VLAN will be used as the gateway for the clients.
[Switch] vlan 20
[Switch-vlan20] quit
[Switch] interface vlan-interface 20
[Switch-Vlan-interface20] ip address 192.168.10.1 255.255.255.0
[Switch-Vlan-interface20] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, and assign the port to all VLANs.
[Switch] interface gigabitEthernet 1/0/1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan all
# Configure GigabitEthernet 1/0/4 that connects the switch to AP 1 as a trunk port, remove the port from VLAN 1, and assign the port to all the other VLANs.
[Switch] interface gigabitEthernet 1/0/4
[Switch-GigabitEthernet1/0/4] port link-type trunk
[Switch-GigabitEthernet1/0/4] port trunk permit vlan all
[Switch-GigabitEthernet1/0/4] undo port trunk permit vlan 1
# Set the PVID of GigabitEthernet 1/0/4 to VLAN 10.
[Switch-GigabitEthernet1/0/4] port trunk pvid vlan 10
[Switch-GigabitEthernet1/0/4] quit
# Assign GigabitEthernet 1/0/2 that connects the switch to Client 1 to VLAN 20.
[Switch] interface gigabitEthernet 1/0/2
[Switch-GigabitEthernet1/0/2] port access vlan 20
[Switch] quit
2. Configure the DHCP server:
# Enable DHCP.
[Switch] dhcp enable
# Specify 172.16.1.0/24 as the address range for dynamic allocation in DHCP address pool 1, and specify 172.16.1.1 as the gateway address.
[Switch] dhcp server ip-pool 1
[Switch-dhcp-pool-1] network 172.16.1.0 mask 255.255.255.0
[Switch-dhcp-pool-1] gateway-list 172.16.1.1
# Exclude 172.16.1.2 from dynamic allocation.
[Switch-dhcp-pool-1] forbidden-ip 172.16.1.2
[Switch-dhcp-pool-1] quit
# Configure DHCP address pool 2. In the address pool, specify 192.168.10.1 as the gateway IP address, 192.168.10.0/24 as the subnet for dynamic allocation, and 192.168.10.1 as the DNS server address.
[Switch] dhcp server ip-pool 2
[Switch-dhcp-pool-2] network 192.168.10.0 mask 255.255.255.0
[Switch-dhcp-pool-2] gateway-list 192.168.10.1
[Switch-dhcp-pool-2] dns-list 192.168.10.1
[Switch-dhcp-pool-2] quit
Configuring the AC
1. Configure interfaces on the AC:
[AC] vlan 10
[AC-vlan10] quit
[AC] interface vlan-interface 10
[AC-Vlan-interface10] ip address 172.16.1.2 255.255.255.0
[AC-Vlan-interface10] quit
# Create VLAN 20.
[AC] vlan 20
[AC-vlan20] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, and assign the port to all VLANs.
[AC-GigabitEthernet1/0/1] port trunk permit vlan all
2. Configure a wireless service:
# Create service template office.
[AC] wlan service-template office
# Set the SSID to Documents.
[AC-wlan-st-office] ssid Documents
# Specify VLAN 20 for the service. Clients will join the VLAN after coming online from the service.
[AC-wlan-st-office] vlan 20
# Set the AKM mode to PSK, and specify the plaintext preshared key as 12345678.
[AC-wlan-st-office] akm mode psk
[AC-wlan-st-office] preshared-key pass-phrase simple 12345678
# Set the cipher suite to CCMP and set the security IE to WPA.
[AC-wlan-st-office] cipher-suite ccmp
[AC-wlan-st-office] security-ie wpa
# Configure the AC to forward client data traffic. If the AC acts as the client traffic forwarder by default, skip this step.
[AC-wlan-st-office] client forwarding-location ac
# Enable the service template.
[AC-wlan-st-office] service-template enable
[AC-wlan-st-office] quit
3. Configure AP 1:
NOTE: In a large-scale network, configure AP settings in AP group view instead of AP view as a best practice. |
# Create a manual AP named ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA6330
[AC-wlan-ap-ap1] serial-id 219801A23V8192E00021
# Create AP group group1, and configure a grouping rule by AP name to add AP ap1 to the group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
# Specify the radio type as dot11an, and specify the channel as 36.
[AC-wlan-ap-group-group1] ap-model WA6330
[AC-wlan-ap-group-group1-ap-model-WA6330] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] type dot11an
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] channel 36
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] quit
[AC-wlan-ap-group-group1-ap-model-WA6330] quit
[AC-wlan-ap-group-group1] quit
4. Configure AP 2:
# Create a manual AP named ap2, and specify the AP model and serial ID.
[AC] wlan ap ap2 model WA6330
[AC-wlan-ap-ap2] serial-id 219801A23V8192E00022
# Create AP group group2, and configure a grouping rule by AP name to add AP ap2 to the group.
[AC] wlan ap-group group2
[AC-wlan-ap-group-group2] ap ap2
[AC-wlan-ap-group-group2] ap-model WA6330
[AC-wlan-ap-group-group2-ap-model-WA6330] radio 1
[AC-wlan-ap-group-group2-ap-model-WA6330-radio-1] type dot11an
[AC-wlan-ap-group-group2-ap-model-WA6330-radio-1] channel 36
# Bind service template office to radio 1 and enable radio 1.
[AC-wlan-ap-group-group2-ap-model-WA6330-radio-1] service-template office
[AC-wlan-ap-group-group2-ap-model-WA6330-radio-1] radio enable
[AC-wlan-ap-group-group2-ap-model-WA6330-radio-1] quit
[AC-wlan-ap-group-group2-ap-model-WA6330] quit
[AC-wlan-ap-group-group2] quit
5. Configure a mesh profile:
# Create mesh profile 1.
[AC] wlan mesh-profile 1
# Set the mesh ID to 1.
[AC-wlan-mesh-profile-1] mesh-id 1
# Set the authentication and key management (AKM) mode to sae.
[AC-wlan-mesh-profile-1] akm mode sae
# Configure simple character string meshlink as the PSK.
[AC-wlan-mesh-profile-1] preshared-key pass-phrase simple meshlink
# Enable the mesh profile.
[AC-wlan-mesh-profile-1] mesh-profile enable
[AC-wlan-mesh-profile-1] quit
# Bind radio 1 in AP group group1 to mesh profile 1. Bind radio 1 in AP group group2 to mesh profile 1 in the same way.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] mesh-profile 1
6. Add the MAC address of AP 2 to the mesh peer whitelist for APs in group group1. Add the MAC address of AP 1 to the mesh peer whitelist for APs in group group2 in the same way.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] mesh peer-mac-address 90e7-1066-e060
7. Configure a WLAN-mesh interface: The following uses AP group group1 as an example. Configure a WLAN-mesh interface for AP group group2 in the same way.
# Create a WLAN-mesh interface.
[AC-wlan-ap-group-group1] interface wlan-mesh 1
# Configure WLAN-mesh interface 1 as a trunk port, and assign the port to all VLANs.
[AC-wlan-ap-group-group1-wlan-mesh-1] mesh-port link-type trunk
[AC-wlan-ap-group-group1-wlan-mesh-1] mesh-port trunk permit vlan all
[AC-wlan-ap-group-group1-wlan-mesh-1] quit
# Bind WLAN-mesh interface 1 to radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] mesh-interface 1
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
8. Editing the AP’s configuration file
# Edit the AP’s configuration file, name it map.txt.
vlan 20
9. Upload the configuration file to the AC.
[AC-wlan-ap-group-group1-ap-model-WA6330] map-configuration map.txt
1. Verify that the APs have been associated with the AC. If the APs are in R/M state, the APs have been associated with the AC.
<AC> display wlan ap all
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name APID State Model Serial ID
ap1 1 R/M WA6330 219801A23V8192E00021
ap2 2 R/M WA6330 219801A23V8192E00022
2. Display mesh link information on the AC.
<AC> display wlan mesh-link ap
AP name: ap1
Peer Local Status RSSI Packets(Rx/Tx)
90e7-1066-e060 542b-dea7-a8c0 Forwarding 57 6919/6452
AP name: ap2
542b-dea7-a8c0 90e7-1066-e060 Forwarding 55 7726/6801
3. Ping Client 2 from Client 1 to verify that they are reachable to each other.
C:\Users\system32> ping 192.168.10.3
Pinging 192.168.10.3 with 32 bytes of data:
Reply from 192.168.10.3: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.10.3:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Configuration files
· Switch:
dhcp enable
vlan 10
vlan 20
interface Vlan-interface10
interface Vlan-interface20
port access vlan 20
interface GigabitEthernet1/0/4
port trunk permit vlan 2 to 4094
· AC:
wlan mesh-profile 1
mesh-id 1
akm mode sae
preshared-key pass-phrase cipher $c$3$qVXx1KuNn4FeEi3nMUkQ7A8jcIMrN8JH2AOv
mesh-profile enable
vlan 10
vlan 20
ssid Documents
vlan 20
akm mode psk
preshared-key pass-phrase cipher $c$3$hqxvBKKM0Go5NmRe1XGhiy/nVnzusK20fzlz
cipher-suite ccmp
security-ie wpa
vlan 1
ap ap1
ap-model WA6330
radio 1
type dot11an
channel 36
radio enable
service-template 1
mesh-interface 1
mesh-profile 1
map-configuration flash:/map.txt
vlan 1
ap ap2
ap-model WA6330
radio 1
type dot11an
channel 36
radio enable
mesh-interface 1
mesh-profile 1
mesh peer-mac-address 542b-dea7-a8c0
Related documentation
· AP Management Command Reference in H3C Access Controllers Command References
· AP Management Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Mesh Command Reference in H3C Access Controllers Command References
· WLAN Mesh Configuration Guide in H3C Access Controllers Configuration Guides
