13-WLAN advanced features
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10413-WLAN advanced features
03-Client Rate Limiting Configuration Examples
03-Client Rate Limiting Configuration Examples 92.80 KB
Introduction
The following information provides an example for configuring client rate limiting.
This document applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of client rate limiting.
Example: Configuring client rate limiting
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the clients. The AC forwards client traffic. Configure service-template-based client rate limiting to limit both the incoming and outgoing traffic rates to 6000 Kbps in dynamic mode.
Figure 1 Network diagram
Use the actual serial ID of an AP to uniquely identify that AP.
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.0.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.0.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC and the switch as a trunk port, and assign it to VLANs 1, 100, and 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
2.     Configure wireless services:
# Create a service template named service and enter its view.
[AC] wlan service-template service
# Configure the SSID of service template service as service.
[AC-wlan-st-service] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-service] vlan 200
# Specify the AKM mode as PSK, and specify plaintext string 12345678 as the preshared key.
[AC-wlan-st-service] akm mode psk
[AC-wlan-st-service] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC-wlan-st-service] cipher-suite ccmp
[AC-wlan-st-service] security-ie rsn
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-service] client forwarding-location ac
# Limit the client traffic rate in both directions to 6000 Kbps in dynamic mode, and enable client rate limiting for service template service.
[AC-wlan-st-service] client-rate-limit inbound mode dynamic cir 6000
[AC-wlan-st-service] client-rate-limit outbound mode dynamic cir 6000
# Enable the service template.
[AC-wlan-st-1] quit
3.     Configure the AP:
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create a manual AP named officeap, and specify the model and serial ID.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 219801A28N819CE0002T
# Create AP group group1, add the AP to the AP group, and specify the AP model.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
[AC-wlan-ap-group-group1] ap-model WA6320
# Enter the view of radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
# Bind service template service to radio 1, and enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template service
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnel between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch and the AC as a trunk port, and assign the trunk port to VLANs 1, 100, and 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch and the AP as an access port, and assign the access port to VLAN 100.
# Enable PoE on GigabitEthernet 1/0/2.
# Create VLAN-interface 100, and assign an IP address to the VLAN interface.
[Switch-Vlan-interface100] ip address 192.1.0.2 16
# Create VLAN-interface 200, and assign an IP address to the VLAN interface.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.0.2 24
[Switch-Vlan-interface200] quit
# Enable DHCP.
[Switch] dhcp enable
# Configure DHCP pool 100 to assign an IP address to the AP.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 192.1.0.0 mask 255.255.0.0
[Switch-dhcp-pool-100] gateway-list 192.1.0.1
[Switch-dhcp-pool-100] quit
# Configure DHCP pool 200 to assign an IP address to clients. Specify the gateway address and DNS server address. In this example, the gateway also acts as a DNS server.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 192.2.0.0 mask 255.255.255.0
[Switch-dhcp-pool-200] gateway-list 192.2.0.1
[Switch-dhcp-pool-200] dns-list 192.2.0.1
[Switch-dhcp-pool-200] quit
# Verify that the incoming and outgoing traffic rates of client 1 and client 2 are both limited within 3000 Kbps. (Details not shown.)
Configuration files
·     AC:
vlan 100
vlan 200
 ssid service
 vlan 200
akm mode psk
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
 ip address 192.1.0.1 255.255.0.0
interface Vlan-interface200
 ip address 192.2.0.1 255.255.255.0
ap officeap
ap-model WA6320
radio 1
radio enable
·     Switch:
vlan 100
vlan 200
 dns-list 192.2.0.1
 ip address 192.1.0.2 255.255.0.0
 ip address 192.2.0.2 255.255.255.0
 port access permit vlan 100
 poe enable
Related documentation
·     QoS Command Reference in H3C Access Controllers Command References
·     QoS Configuration Guide in H3C Access Controllers Configuration Guides
