14-Layer 3—IP Routing Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath Firewall Series Configuration Guides(V7)-6W60214-Layer 3—IP Routing Configuration Guide
10-Policy-based routing configuration
10-Policy-based routing configuration 136.67 KB
Configuring PBR
About PBR
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify parameters for packets that match specific criteria such as ACLs or that have specific lengths. The parameters include the next hop, output interface, default next hop, and default output interface.
Packet forwarding process
When the device receives a packet, the device searches the PBR policy for a matching node to forward that packet.
·     If a matching node is found and its match mode is permit, the device performs the following operations:
a.     Uses the next hops or output interfaces specified on the node to forward the packet.
b.     Searches the routing table for a route (except the default route) to forward the packet if one of the following conditions exists:
-     No next hops or output interfaces are specified on the node.
-     Forwarding failed based on the next hops or output interfaces.
c.     Uses the default next hop or default output interface specified on the node to forward the packet if one of the following conditions exists:
-     No matching route was found in the routing table.
-     The routing table-based forwarding failed.
d.     Uses the default route to forward the packet if one of the following conditions exists:
-     No default next hops or default output interfaces are specified on the node.
-     The forwarding failed based on the default next hops or default output interfaces.
·     The device perfoms routing table lookup to forward the packet in either of the following conditions:
¡     No matching node is found.
¡     A matching node is found, but its match mode is deny.
PBR types
PBR includes the following types:
·     Local PBR—Guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
·     Interface PBR—Guides the forwarding of packets received on an interface.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
A policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup.
Relationship between if-match clauses
On a node, you can specify multiple types of if-match clauses but only one if-match clause for each type.
To match a node, a packet must match all types of the if-match clauses for the node but only one if-match clause for each type.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about relationship between apply clauses, see "Configuring actions for a node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
Permit
Deny
Yes.
·     If the node contains apply clauses, PBR executes the apply clauses on the node.
¡     If PBR-based forwarding succeeds, PBR does not compare the packet with the next node.
¡     If PBR-based forwarding fails and the apply continue clause is not configured, PBR does not compare the packet with the next node.
¡     If PBR-based forwarding fails and the apply continue clause is configured, PBR compares the packet with the next node.
·     If the node does not contain apply clauses, the device performs a routing table lookup for the packet.
The device performs a routing table lookup for the packet.
No.
A node that has no if-match clauses matches any packet.
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop, output interface, default next hop, or default output interface.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track-PBR collaboration, see Network Management and Monitoring Configuration Guide.
Restrictions and guidelines: PBR configuration
If the device performs forwarding in software, PBR does not process IP packets destined for the local device.
If the device performs forwarding in hardware and a packet destined for it matches a PBR policy, PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure a PBR policy, be careful to avoid this situation.
PBR tasks at a glance
To configure PBR, perform the following tasks:
1.     Configuring a policy
a.     Creating a node
b.     Setting match criteria for a node
c.     Configuring actions for a node
2.     Specifying a policy for PBR
¡     Specifying a policy for local PBR
¡     Specifying a policy for interface PBR
Creating a node
2.     Create a node for a policy, and enter its view.
2.     Enter policy node view.
3.     Set match criteria.
¡     Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
¡     Set a packet length match criterion.
if-match packet-length min-len max-len
By default, no packet length match criterion is set.
¡     Set a source IP address match criterion for local PBR.
if-match source-ip { interface interface-type interface-number | [ vpn-instance vpn-instance-name ] ip-address }
By default, no source IP address match criterion is set for local PBR.
Support for this command depends on the device model. For more information, see the command reference.
¡     Set application group match criteria.
if-match app-group app-group-name&<1-6>
By default, no application group match criteria are set.
Application group match criteria apply only to interface PBR.
For more information about application groups, see APR configuration in Security Configuration Guide.
¡     Set service object group match criteria.
if-match object-group service object-group-name&<1-6>
By default, no service object group match criteria are set.
For more information about service object groups, see object group configuration in Security Configuration Guide.
The apply clauses allow you to specify the actions to be taken on matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
·     apply access-vpn
·     apply next-hop
·     apply output-interface
·     apply default-next-hop
·     apply default-output-interface
PBR supports the apply clauses in Table 1.
Table 1 Apply clauses supported in PBR
Clause
Meaning
Remarks
apply precedence
Sets an IP precedence.
This clause is always executed.
apply ip-df df-value
Sets the Don't Fragment (DF) bit in the IP header.
apply loadshare { next-hop | output-interface | default-next-hop | default-output-interface }
Enables load sharing among multiple next hops, output interfaces, default next hops, or default output interfaces.
Multiple next hop, output interface, default next hop, or default output interface options operate in either primary/backup or load sharing mode.
·     Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple output interfaces are configured, the first configured output interface is selected. When the selected output interface fails, the next available output interface takes over.
·     Load sharing mode—Matching traffic is distributed across the available options, as follows:
¡     Multiple output interface, default next hop, or default output interface options—Load share traffic in round robin manner, starting from the first configured option. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
¡     Multiple next hops—Load share traffic in proportion to their weight. By default, all next hops have the same weight and traffic is evenly distributed among them.
By default, the primary/backup mode applies.
For the load sharing mode to take effect, make sure multiple next hops, output interfaces, default next hops, or default output interfaces are set in the policy.
apply access-vpn
Specifies the forwarding tables that can be used for the matching packets.
Use this clause only in special scenarios that require sending packets received from one network to another network, for example, from a VPN to the public network, or from one VPN to another VPN.
If a packet matches the forwarding table for a specified VPN instance, it is forwarded in the VPN.
apply remark-vpn
Enables VPN remark action.
VPN remark action marks the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command. All subsequent service modules of PBR handle the packets as belonging to the re-marked VPN instance.
If the VPN remark action is not enabled, the forwarded matching packets are marked as belonging to the VPN instance or the public network from which they were received.
VPN remark action applies only to packets that have been successfully forwarded based on the apply access-vpn vpn-instance command.
apply next-hop and apply output-interface
Sets next hops and sets output interfaces.
If both clauses are configured, only the apply next-hop clause is executed.
apply default-next-hop and apply default-output-interface
Sets default next hops and sets default output interfaces.
If both clauses are configured, only the apply default-next-hop clause is executed.
The clauses take effect only in the following cases:
·     No next hops or output interfaces are set or the next hops and output interfaces are invalid.
·     The packet does not match any route in the routing table.
apply continue
Compares packets with the next node upon failure on the current node.
The apply continue clause applies when either of the the following conditions exist:
·     None of the following clauses is configured for packet forwarding:
¡     apply access-vpn vpn-instance
¡     apply next-hop
¡     apply output-interface
¡     apply default-next-hop
¡     apply default-output-interface
·     A clause listed above is configured, but it has become invalid. Then, a routing table lookup also fails for the matching packet.
A clause might become invalid because the specified next hop is unreachable, packets cannot be forwarded in the specified VPN instance, or the specified output interface is down.
For outbound PBR, you can specify only one next hop and the next hop must be directly connected.
If you specify a next hop or default next hop, PBR periodically performs a lookup in the FIB table to determine its availability. Temporary service interruption might occur if PBR does not update the route immediately after its availability status changes.
Configuring actions to modify packet fields
3.     Configure actions.
¡     Set an IP precedence.
By default, no IP precedence is specified.
¡     Set the DF bit in the IP header.
By default, the DF bit in the IP header is not set.
Configuring actions to direct packet forwarding
¡     Specify the forwarding tables that can be used for the matching packets.
apply access-vpn { public | vpn-instance vpn-instance-name&<1-4> }
By default, the device forwards matching packets by using the forwarding table for the network from which the packets are received.
You can repeat this command to specify the forwarding tables for the public network and VPN instances. The device forwards the matching packets by using the first available forwarding table selected in the order in which they are specified.
¡     Enable VPN remark action to mark the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command.
apply remark-vpn
By default, VPN remark action is not configured.
¡     Set next hops.
apply next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ip-address [ direct ] [ track track-entry-number ] [ weight weight-value ] }&<1-4>
By default, no next hops are specified.
On a node, you can specify a maximum of four next hops for backup or load sharing in one command line or by executing this command multiple times.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
The value for n varies by device model. For more information, see the command reference.
¡     Enable load sharing among multiple next hops.
apply loadshare next-hop
By default, the next hops operate in primary/backup mode.
¡     Set output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, no output interfaces are specified.
On a node, you can specify a maximum of four output interfaces for backup or load sharing in one command line or by executing this command multiple times.
¡     Enable load sharing among multiple output interfaces.
apply loadshare output-interface
By default, the output interfaces operate in primary/backup mode.
¡     Set default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ip-address [ direct ] [ track track-entry-number ] }&<1-4>
By default, no default next hops are specified.
On a node, you can specify a maximum of four default next hops for backup or load sharing in one command line or by executing this command multiple times.
¡     Enable load sharing among multiple default next hops.
apply loadshare default-next-hop
By default, the default next hops operate in primary/backup mode.
¡     Set default output interfaces.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, no default output interfaces are specified.
On a node, you can specify a maximum of four default output interfaces for backup or load sharing in one command line or by executing this command multiple times.
¡     Enable load sharing among multiple default output interfaces.
apply loadshare default-output-interface
By default, the default output interfaces operate in primary/backup mode.
Comparing packets with the next node upon match failure on the current node
3.     Compare packets with the next node upon match failure on the current node.
apply continue
By default, PBR does not compare packets with the next node upon match failure on the current node.
This command takes effect only when the match mode of the node is permit.
Perform this task to specify a policy for local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
2.     Specify a policy for local PBR.
ip local policy-based-route policy-name
By default, local PBR is not enabled.
Perform this task to apply a policy to an interface to guide the forwarding of packets received on the interface.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you can apply a new interface PBR policy to an interface, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
2.     Enter interface view.
3.     Specify a policy for interface PBR.
ip policy-based-route policy-name
By default, no policy is applied to an interface.
Display and maintenance commands for PBR
Display PBR policy information.
display ip policy-based-route [ policy policy-name ]
Display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
Display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
Display PBR configuration.
display ip policy-based-route setup
Clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
