- 17-Network Management and Monitoring Command Reference
- 01-Information center commands
- 02-Flow log commands
- 03-Fast log output commands
- 04-NetStream commands
- 05-Cloud connection commands
- 06-Mirroring commands
- 07-Packet capture commands
- 08-NQA commands
- 09-Track commands
- 10-BFD commands
- 11-Monitor Link commands
- 12-Smart Link commands
- 13-Interface backup commands
- 14-Interface collaboration commands
- 15-System maintenance and debugging commands
- 16-NTP commands
- 17-EAA commands
- 18-Process monitoring and maintenance commands
- 19-NETCONF commands
- 20-SNMP commands
- 21-RMON commands
- 22-Event MIB commands
- 23-CWMP commands
- 24-Process placement commands
05-Cloud connection commands | 107.89 KB |
cloud-management backup-server domain
cloud-management server domain
cloud-management server password
cloud-management unbinding-code
display cloud-management state
The following compatibility matrixes show the support of hardware platforms for cloud connections:
F1000 series |
Model |
Cloud connection compatibility |
F1000-X-G5 series |
F1000-A-G5, F1000-C-G5, F1000-C-G5-LI, F1000-E-G5, F1000-H-G5, F1000-S-G5 |
Yes |
F1000-X-G3 series |
F1000-A-G3, F1000-C-G3, F1000-E-G3, F1000-S-G3 |
No |
F1000-X-G2 series |
F1000-A-G2, F1000-C-G2, F1000-E-G2, F1000-S-G2 |
No |
F1000-9X0-AI series |
F1000-9390-AI, F1000-9385-AI, F1000-9380-AI, F1000-9370-AI, F1000-9360-AI, F1000-9350-AI, F1000-9330-AI, F1000-9320-AI |
Yes |
F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI , F1000-910-AI, F1000-905-AI |
No |
F1000-C83X0 series |
F1000-C8395, F1000-C8390, F1000-C8385, F1000-C8380, F1000-C8370, F1000-C8360, F1000-C8350, F1000-C8330 |
Yes |
F1000-C81X0 series |
F1000-C8180, F1000-C8170, F1000-C8160, F1000-C8150, F1000-C8130, F1000-C8120, F1000-C8110 |
Yes |
F1000-7X0-HI series |
F1000-770-HI, F1000-750-HI, F1000-740-HI, F1000-730-HI, F1000-720-HI, F1000-710-HI |
Yes |
F1000-C-X series |
F1000-C-EI, F1000-C-HI |
No |
F1000-C-XI, F1000-E-XI |
Yes |
F1000-V series |
F1000-E-VG, F1000-S-VG |
No |
SecBlade IV |
LSPM6FWD8, LSQM2FWDSC8 |
No |
F100 series |
Model |
F100-X-G5 series |
F100-A-G5, F100-C-G5, F100-E-G5, F100-M-G5, F100-S-G5 |
Yes |
F100-X-G3 series |
F100-A-G3, F100-C-G3, F100-E-G3, F100-M-G3, F100-S-G3 |
No |
F100-X-G2 series |
F100-A-G2, F100-C-G2, F100-E-G2, F100-M-G2, F100-S-G2 |
No |
F100-WiNet series |
F100-A80-WiNet, F100-C80-WiNet, F100-C60-WiNet, F100-C50-WiNet, F100-S80-WiNet, F100-A81-WiNet, F100-A91-WiNet |
Yes |
F100-C-A series |
F100-C-A6, F100-C-A5, F100-C-A3, F100-C-A2, F100-C-A1, F100-C-A6-WL, F100-C-A5-W, F100-C-A3-W |
Yes |
F100-X-XI series |
F100-A-EI, F100-A-HI, F100-A-SI, F100-C-EI, F100-C-HI, ,F100-E-EI, F100-S-HI |
No |
F100-C-XI, F100-S-XI |
Yes |
Use cloud-management backup-server domain to specify a backup cloud server by its domain name.
Use undo cloud-management backup-server domain to remove one or all backup cloud servers.
cloud-management backup-server domain domain-name [ vpn-instance vpn-instance-name ] [ source-ip ipv4-address ]
undo cloud-management backup-server domain [ domain-name ]
No backup cloud server is specified.
context-admin
domain-name: Specifies a backup cloud server by its domain name, a case-sensitive string of 1 to 253 characters. If you do not specify this parameter in the undo cloud-management backup-server domain command, all backup cloud servers will be deleted.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the backup cloud server is on the public network.
source-ip ipv4-address: Specifies the source IPv4 address for the device that connects to the backup cloud server. It must be the same as the IPv4 address configured on the device. If you do not specify this option, the device uses the primary IPv4 address of the egress interface to connect to the backup cloud server.
Before configuring this command, make sure a DNS server is configured to translate domain names.
If you execute this command multiple times to configure a backup cloud server with the same domain name, the most recent configuration takes effect.
You can specify one primary server by using the cloud-management server domain command and a maximum of eight backup servers by repeating the cloud-management backup-server domain command.
When establishing a cloud connection, the device connects to one of the primary and backup servers according to the sequence in which they are specified. The first specified server has the highest priority. When the connected server fails, the device switches to another server and does not switch back to the original server even if the original server recovers.
To view the connected server, execute the display cloud-management state command.
# Specify the server with domain name 123.com as a backup cloud server.
[Sysname] cloud-management backup-server domain 123.com
cloud-management keepalive
Use cloud-management keepalive to set the keepalive interval for the local device to send keepalive packets to the cloud server.
Use undo cloud-management keepalive to restore the default.
cloud-management keepalive interval
The keepalive interval is 180 seconds.
context-admin
interval: Specifies the keepalive interval in the range of 10 to 600 seconds.
If the device does not receive a response from the cloud server within three keepalive intervals, the device sends a registration request to re-establish the cloud connection.
# Set the keepalive interval to 360 seconds.
[Sysname] cloud-management keepalive 360
cloud-management ping
Use cloud-management ping to set the interval at which the local device sends ping packets to the cloud server.
Use undo cloud-management ping to restore the default.
cloud-management ping interval
The local device sends ping packets to the cloud server at intervals of 60 seconds.
context-admin
interval: Specifies the interval at which the local device sends ping packets to the cloud server, in the range of 10 to 600 seconds.
After the connection to the cloud server is established, the local device sends ping packets to the server periodically to prevent NAT entry aging. Reduce the interval value if the network condition is poor or the NAT entry aging time is short.
The cloud server does not respond to ping packets.
# Configure the local device to send ping packets to the cloud server at intervals of 120 seconds.
[Sysname] cloud-management ping 120
Use cloud-management server domain to specify the primary cloud server by its domain name.
Use undo cloud-management server domain to restore the default.
cloud-management server domain domain-name [ vpn-instance vpn-instance-name ] [ source-ip ipv4-address ]
The cloud server uses domain name ops.seccloud.h3c.com.
context-admin
domain-name: Specifies the primary cloud server by its domain name, a case-sensitive string of 1 to 253 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the primary cloud server is on the public network.
source-ip ipv4-address: Specifies the source IPv4 address for the device that connects to the primary cloud server. It must be the same as the IPv4 address configured on the device. If you do not specify this option, the device uses the primary IPv4 address of the egress interface to connect to the primary cloud server.
If you execute the command multiple times, the most recent configuration takes effect.
# Specify the server with domain name lvzhouv3.h3c.com as the primary cloud server.
[Sysname] cloud-management server domain lvzhouv3.h3c.com
Use cloud-management server password to set the password for establishing cloud connections to the ADWAN server.
Use cloud-management server password to restore the default.
cloud-management server password { cipher | simple } string
undo cloud-management server password
No password is set for establishing cloud connections to the ADWAN server.
context-admin
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. The plaintext form is a case-sensitive string of 1 to 63 characters. The encrypted form is a case-sensitive string of 1 to 117 characters.
After you change the password, the device terminates the cloud connections that have been established (if any) and uses the new password to establish cloud connections.
# Set the password for establishing cloud connections to the ADWAN server to 12345678 in plaintext format.
[Sysname] cloud-management server password simple 12345678
cloud-management server port
Use cloud-management server port to specify the TCP port number used to establish cloud connections.
Use undo cloud-management server port to restore the default.
cloud-management server port port-number
TCP port number 19443 is used to establish cloud connections.
context-admin
port-number: Specifies a TCP port number in the range of 1 to 65535.
After you change the port number, the device terminates the cloud connections that have been established (if any) and uses the new port number to establish cloud connections.
# Specify the TCP port number used to establish cloud connections as 80.
[Sysname] cloud-management server port 80
Use cloud-management unbinding-code to send the verification code for device unbinding to the cloud server.
cloud-management unbinding-code code
context-admin
code: Specifies the verification code obtained from the cloud server. The verification code is a case-sensitive string of 16 characters.
A device can be registered on the cloud server by only one user.
To register a device that has been registered by another user, you need to take the following steps:
1. Obtain a verification code for device unbinding from the cloud server.
2. Execute this command on the device to send the verification code to the cloud server.
3. Register the device on the cloud server.
# Send the verification code for device unbinding to the cloud server.
[Sysname] cloud-management unbinding-code A6B9C3C2D5A8Z1S7
Use display cloud-management state to display cloud connection state information.
context-admin
context-operator
# Display cloud connection state information.
<Sysname> display cloud-management state
Cloud connection state : Established
Device state : Request_success
Cloud server address : 10.1.1.1
Cloud server domain name : ops.seccloud.h3c.com
Cloud connection mode : Https
Cloud server port : 19443
Connected at : Wed Jan 27 14:18:40 2018
Duration : 00d 00h 02m 01s
Process state : Message received
Failure reason : N/A
Last down reason : socket connection error (Details:N/A)
Last down at : Wed Jan 27 13:18:40 2018
Last report failure reason : N/A
Last report failure at : N/A
Dropped packets after reaching buffer limit : 0
Total dropped packets : 1
Last report incomplete reason : N/A
Last report incomplete at : N/A
Buffer full count : 0
Cloud connection state |
Cloud connection state: Unconnected, Request, and Established. |
Device state |
Local device state: · Idle—In idle state. · Connecting—Connecting to the cloud server. · Request_CAS_url—Sent a central authentication service (CAS) URL request. · Request_CAS_url_success—Requesting CAS URL succeeded. · Request_CAS_TGT—Sent a ticket granting ticket (TGT) request. · Request_CAS_TGT_success—Requesting TGT succeeded. · Request_CAS_ST—Sent a service ticket (ST) request. · Request_CAS_ST_success—Requesting ST succeeded. · Request_cloud_auth—Sent an authentication request. · Request_cloud_auth_success—Authentication succeeded. · Register—Sent a registration request. · Register_success—Registration succeeded. · Request—Sent a handshake request. · Request_success—Handshake succeeded. |
Cloud server address |
IP address of the cloud server. |
Cloud server domain name |
Domain name of the cloud server. |
Cloud server port |
TCP port number used to establish cloud connections. |
Connected at |
Time when the cloud connection was established. |
Duration |
Duration since the establishment of the cloud connection. |
Process state |
Cloud connection processing state: · DNS not parsed. · DNS parsed. · Message not sent. · Message sent. · Message not received. · Message received. |
Failure reason |
Cloud connection failure reason: · DNS parse failed. · Socket connection failed. · SSL creation failed. · Sending CAS url request failed. · Sending CAS TGT failed. · Sending CAS ST failed. · Sending cloud auth failed. · Sending register failed. · Processing CAS url response failed. · Processing CAS TGT response failed. · Processing CAS ST response failed. · Processing cloud auth response failed. · Processing register response failed. · Sending handshake request failed. · Processing handshake failed. · Sending websocket request failed. · Processing websocket packet failed. |
Last down reason |
Reason for the most recent cloud connection interruption: · Device or process rebooted. · Socket connection error. · Configuration changed. · Received websocket close packet from cloud. · Keepalive expired. · Packet processing failed. · Main connection went down. · Cloud reset connection. · Memory reached threshold. |
Last down at |
Time when the cloud connection went down most recently. |
Last report failure reason |
Reason for the most recent cloud connection packet sending failure: · Tunnel is being deleted. · Tunnel socket is invalid. · Failed to convert string to json. · Failed to convert json to string. · Failed to create message node. · Tunnel is not ready. · Failed to create packet buffer. · SSL sending failure. If the reason is SSL sending failure, one of the following detailed reason will be displayed: · ssl error none. · ssl error ssl. · ssl error read. · ssl error write. · ssl error x509 lookup. · ssl error syscall. · ssl error zero return. · ssl error connect. · ssl error accept. |
Last report failure at |
Time when the most recent cloud connection packet sending failure occurred. |
Dropped packets after reaching buffer limit |
Number of packets that are dropped because the CMTNL buffer limit is reached. |
Total dropped packets |
Total number of dropped packets. |
Last report incomplete reason |
Reason for the most recent unfinished packet sending: · Interrupted system call. · Socket buffer is full. |
Last report incomplete at |
Time when the most recent unfinished packet sending occurred. |
Buffer full count |
Number of times that the buffer becomes full. |
